Hi Tom,
This PR includes the following changes for v2021.07 release:
- x86: Discard .note.gnu.property sections - nvme: Skip block device creation for inactive namespaces - nvme: Convert NVMe doc to reST, and various minor fixes
Azure results: PASS https://dev.azure.com/bmeng/GitHub/_build/results?buildId=381&view=resul...
The following changes since commit 1ce892cb1ce970d8ee6ffcecc22351c84e67fca4:
azure: Use msys2 20210604 installer for Windows build (2021-06-22 09:06:03 -0400)
https://source.denx.de/u-boot/custodians/u-boot-x86
for you to fetch changes up to f68d5a66cd53a238d64d79cdd330b4dce17c7197:
MAINTAINERS: Add an entry for NVMe (2021-06-23 17:21:14 +0800)
---------------------------------------------------------------- Bin Meng (8): x86: Discard .note.gnu.property sections nvme: Move block dev creation from uclass post_probe() to driver probe() nvme: Skip block device creation for inactive namespaces nvme: Eliminate the offset of one during block dev creation nvme: Drop useless members of 'struct nvme_ns' nvme: Don't clear nvme blk device's priv space doc: develop: Convert README.nvme to reST MAINTAINERS: Add an entry for NVMe
David Lamparter (1): nvme: fix for big endian systems
Wesley Sheng (2): nvme: Correct the prps per page calculation method nvme: Remove the redundant aqa value setting
MAINTAINERS | 8 ++++++++ arch/x86/cpu/u-boot-64.lds | 1 + arch/x86/cpu/u-boot-spl.lds | 1 + arch/x86/cpu/u-boot.lds | 1 + doc/develop/driver-model/index.rst | 1 + doc/{README.nvme => develop/driver-model/nvme.rst} | 25 +++++++++++++++++++------ drivers/nvme/nvme-uclass.c | 30 ------------------------------ drivers/nvme/nvme.c | 57 ++++++++++++++++++++++++++++++++++++++++++++++----------- drivers/nvme/nvme.h | 2 -- 9 files changed, 77 insertions(+), 49 deletions(-) rename doc/{README.nvme => develop/driver-model/nvme.rst} (88%)
Regards, Bin
On Wed, Jun 23, 2021 at 07:01:14PM +0800, Bin Meng wrote:
Hi Tom,
Bin Meng
