[U-Boot] [PATCH] mtd: nand: fsmc: Fixes and cleanup for fsmc_nand_switch_ecc()
This patch addresses some comments raised by Scott in the last versions. Here the changes in detail:
- Removed __maybe_unused as its not needed - Added check for strength == 4 and error out for the unsupported ECC strength values - Don't set .caclulate, .correct, and .bytes for NAND_ECC_SOFT_BCH as this will be done in nand_scan_tail() - Set .caclulate back to fsmc_read_hwecc() in the HW case - Added comment that this function will only be called on SPEAr platforms, not supporting the BCH8 HW ECC (FSMC_VER8)
Signed-off-by: Stefan Roese sr@denx.de Cc: Scott Wood scottwood@freescale.com Cc: Tom Rini trini@konsulko.com --- drivers/mtd/nand/fsmc_nand.c | 21 +++++++++++++++------ 1 file changed, 15 insertions(+), 6 deletions(-)
diff --git a/drivers/mtd/nand/fsmc_nand.c b/drivers/mtd/nand/fsmc_nand.c index 0976a67..e0e9e1e 100644 --- a/drivers/mtd/nand/fsmc_nand.c +++ b/drivers/mtd/nand/fsmc_nand.c @@ -13,7 +13,6 @@ #include <asm/io.h> #include <linux/bitops.h> #include <linux/err.h> -#include <linux/mtd/nand_bch.h> #include <linux/mtd/nand_ecc.h> #include <linux/mtd/fsmc_nand.h> #include <asm/arch/hardware.h> @@ -398,12 +397,18 @@ static int fsmc_read_page_hwecc(struct mtd_info *mtd, struct nand_chip *chip, * @eccstrength - the number of bits that could be corrected * (1 - HW, 4 - SW BCH4) */ -int __maybe_unused fsmc_nand_switch_ecc(uint32_t eccstrength) +int fsmc_nand_switch_ecc(uint32_t eccstrength) { struct nand_chip *nand; struct mtd_info *mtd; int err;
+ /* + * This functions is only called on SPEAr600 platforms, supporting + * 1 bit HW ECC. The BCH8 HW ECC (FSMC_VER8) from the ST-Ericsson + * Nomadik SoC is currently supporting this fsmc_nand_switch_ecc() + * function, as it doesn't need to switch to a different ECC layout. + */ mtd = &nand_info[nand_curr_device]; nand = mtd->priv;
@@ -413,14 +418,18 @@ int __maybe_unused fsmc_nand_switch_ecc(uint32_t eccstrength) nand->ecc.bytes = 3; nand->ecc.strength = 1; nand->ecc.layout = &fsmc_ecc1_layout; + nand->ecc.calculate = fsmc_read_hwecc; nand->ecc.correct = nand_correct_data; - } else { + } else if (eccstrength == 4) { + /* + * .calculate .correct and .bytes will be set in + * nand_scan_tail() + */ nand->ecc.mode = NAND_ECC_SOFT_BCH; - nand->ecc.calculate = nand_bch_calculate_ecc; - nand->ecc.correct = nand_bch_correct_data; - nand->ecc.bytes = 7; nand->ecc.strength = 4; nand->ecc.layout = NULL; + } else { + printf("Error: ECC strength %d not supported!\n", eccstrength); }
/* Update NAND handling after ECC mode switch */
Acked-by: Scott Wood scottwood@freescale.com
-Scott
Signed-off-by: Stefan Roese sr@denx.de Cc: Scott Wood scottwood@freescale.com Cc: Tom Rini trini@konsulko.com Acked-by: Scott Wood scottwood@freescale.com
Scott Wood
Stefan Roese
