[PATCH] usb: xhci-dwc3: Bail out if "dr_mode" is "peripheral"
Since the compatible "snps,dwc3" can be specified in the device-tree for the Designware USB Controller configured for not only Host and OTG modes of operation, but also for Peripheral mode of operation, bail out if "dr_mode" is "peripheral".
Signed-off-by: Siddharth Vadapalli s-vadapalli@ti.com ---
Hello,
This patch is based on commit 448add55297 Merge branch 'master' of https://source.denx.de/u-boot/custodians/u-boot-pmic of the master branch of U-Boot.
Regards, Siddharth.
drivers/usb/host/xhci-dwc3.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/drivers/usb/host/xhci-dwc3.c b/drivers/usb/host/xhci-dwc3.c index e3e0ceff43e..7b1311503fe 100644 --- a/drivers/usb/host/xhci-dwc3.c +++ b/drivers/usb/host/xhci-dwc3.c @@ -208,6 +208,9 @@ static int xhci_dwc3_probe(struct udevice *dev) writel(reg, &dwc3_reg->g_usb2phycfg[0]);
dr_mode = usb_get_dr_mode(dev_ofnode(dev)); + if (dr_mode == USB_DR_MODE_PERIPHERAL) + return -ENODEV; + if (dr_mode == USB_DR_MODE_OTG && dev_read_bool(dev, "usb-role-switch")) { dr_mode = usb_get_role_switch_default_mode(dev_ofnode(dev));
Hi Siddharth,
Hello,
Regards, Siddharth.
- if (dr_mode == USB_DR_MODE_PERIPHERAL)
return -ENODEV;
- if (dr_mode == USB_DR_MODE_OTG && dev_read_bool(dev, "usb-role-switch")) { dr_mode = usb_get_role_switch_default_mode(dev_ofnode(dev));
Although this proposal was suggested in [1] and later clarified in [2] I will summarize the discussion here.
This patch fix is not sufficient for all cases as the xhci-dwc3.c driver will still be probed if dr_mode is OTG or HOST along with other platform drivers if enabled in config.
The only current solution is not not enable CONFIG_USB_XHCI_DWC3 together with another platform driver config (e.g. CONFIG_USB_DWC3_GENERIC) if snps,dwc3 should not be managed by xhci-dwc3.c.
[1] - https://lore.kernel.org/all/unf757pwgah5ylkcfdumtdo5zs2ny3nxct5u26t6up7aldqi... [2] - https://lore.kernel.org/all/a9c458f8-68e5-448b-9977-e7bf37b00d35@kernel.org/
Hi Siddharth,
On lun., déc. 09, 2024 at 15:20, Roger Quadros rogerq@kernel.org wrote:
Hi Siddharth,
Hello,
Regards, Siddharth.
return -ENODEV;
Given Roger's explanation, should we simply drop this, or is any other action expected from the U-Boot maintainers?
Thanks, Mattijs
-- cheers, -roger
On Thu, Jan 16, 2025 at 10:36:45AM +0100, Mattijs Korpershoek wrote:
Hi Siddharth,
Hello Mattijs,
Hi Siddharth,
return -ENODEV;
This patch could be dropped. Roger's suggestion is to fix this issue by updating the platform configs wherein CONFIG_USB_XHCI_DWC3 should be disabled on platforms that have "dr_mode" set to "peripheral".
Regards, Siddharth.
On jeu., janv. 16, 2025 at 15:48, Siddharth Vadapalli s-vadapalli@ti.com wrote:
Hi Siddharth,
Hello Mattijs,
Hi Siddharth,
return -ENODEV;
Thank you for confirming.
I've marked as "Handled elsewhere" on patchwork: https://patchwork.ozlabs.org/project/uboot/patch/20241206110424.897283-1-s-v...
Regards, Siddharth.
Mattijs Korpershoek
Roger Quadros
Siddharth Vadapalli
