[U-Boot] [PATCH] at91: Add esd gmbh MEESC board support
This patch adds support for esd gmbh MEESC board. The MEESC is based on an Atmel AT91SAM9263 SoC.
Signed-off-by: Daniel Gorsulowski Daniel.Gorsulowski@esd.eu ---
Jean-Christophe: This patch requires an up-to-date mach-types.h, please sync it.
MAINTAINERS | 4 + MAKEALL | 1 + Makefile | 3 + board/esd/meesc/Makefile | 55 +++++++++++ board/esd/meesc/config.mk | 1 + board/esd/meesc/meesc.c | 211 +++++++++++++++++++++++++++++++++++++++++++ board/esd/meesc/partition.c | 37 ++++++++ include/configs/meesc.h | 185 +++++++++++++++++++++++++++++++++++++ 8 files changed, 497 insertions(+), 0 deletions(-) create mode 100644 board/esd/meesc/Makefile create mode 100644 board/esd/meesc/config.mk create mode 100644 board/esd/meesc/meesc.c create mode 100644 board/esd/meesc/partition.c create mode 100644 include/configs/meesc.h
diff --git a/MAINTAINERS b/MAINTAINERS index 9379c7e..449443a 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -532,6 +532,10 @@ Peter Figuli peposh@etc.sk
wepep250 xscale
+Daniel Gorsulowski daniel.gorsulowski@esd.eu + + meesc ARM926EJS (AT91SAM9263 SoC) + Marius Gröger mag@sysgo.de
impa7 ARM720T (EP7211) diff --git a/MAKEALL b/MAKEALL index f4599d6..eb7b0d7 100755 --- a/MAKEALL +++ b/MAKEALL @@ -587,6 +587,7 @@ LIST_at91=" \ cmc_pu2 \ csb637 \ kb9202 \ + meesc \ mp2usb \ m501sk \ pm9263 \ diff --git a/Makefile b/Makefile index 46871d0..a5db70d 100644 --- a/Makefile +++ b/Makefile @@ -2787,6 +2787,9 @@ at91sam9rlek_config : unconfig fi; @$(MKCONFIG) -a at91sam9rlek arm arm926ejs at91sam9rlek atmel at91
+meesc_config : unconfig + @$(MKCONFIG) $(@:_config=) arm arm926ejs meesc esd at91 + pm9263_config : unconfig @$(MKCONFIG) $(@:_config=) arm arm926ejs pm9263 ronetix at91
diff --git a/board/esd/meesc/Makefile b/board/esd/meesc/Makefile new file mode 100644 index 0000000..2dd6b25 --- /dev/null +++ b/board/esd/meesc/Makefile @@ -0,0 +1,55 @@ +# +# (C) Copyright 2003-2008 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# (C) Copyright 2008 +# Stelian Pop stelian.pop@leadtechdesign.com +# Lead Tech Design <www.leadtechdesign.com> +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS-y += $(BOARD).o +COBJS-$(CONFIG_HAS_DATAFLASH) += partition.o + +SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS-y)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) $(SOBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak $(obj).depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/esd/meesc/config.mk b/board/esd/meesc/config.mk new file mode 100644 index 0000000..9ce161e --- /dev/null +++ b/board/esd/meesc/config.mk @@ -0,0 +1 @@ +TEXT_BASE = 0x21f00000 diff --git a/board/esd/meesc/meesc.c b/board/esd/meesc/meesc.c new file mode 100644 index 0000000..557a51c --- /dev/null +++ b/board/esd/meesc/meesc.c @@ -0,0 +1,211 @@ +/* + * (C) Copyright 2007-2008 + * Stelian Pop stelian.pop@leadtechdesign.com + * Lead Tech Design <www.leadtechdesign.com> + * + * (C) Copyright 2009 + * Daniel Gorsulowski daniel.gorsulowski@esd.eu + * esd electronic system design gmbh <www.esd.eu> + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/arch/at91sam9263.h> +#include <asm/arch/at91sam9263_matrix.h> +#include <asm/arch/at91sam9_smc.h> +#include <asm/arch/at91_common.h> +#include <asm/arch/at91_pmc.h> +#include <asm/arch/at91_rstc.h> +#include <asm/arch/clk.h> +#include <asm/arch/gpio.h> +#include <asm/arch/hardware.h> +#include <asm/arch/io.h> +#include <netdev.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* + * Miscelaneous platform dependent initialisations + */ + +int get_hw_rev(void) +{ + int rev = at91_get_gpio_value(AT91_PIN_PB19); + rev |= at91_get_gpio_value(AT91_PIN_PB20) << 1; + rev |= at91_get_gpio_value(AT91_PIN_PB21) << 2; + rev |= at91_get_gpio_value(AT91_PIN_PB22) << 3; + + if (rev == 15) + rev = 0; + + return rev; +} + +#ifdef CONFIG_CMD_NAND +static void meesc_nand_hw_init(void) +{ + unsigned long csa; + + /* Enable CS3 */ + csa = at91_sys_read(AT91_MATRIX_EBI0CSA); + at91_sys_write(AT91_MATRIX_EBI0CSA, + csa | AT91_MATRIX_EBI0_CS3A_SMC_SMARTMEDIA); + + /* Configure SMC CS3 for NAND/SmartMedia */ + at91_sys_write(AT91_SMC_SETUP(3), + AT91_SMC_NWESETUP_(1) | AT91_SMC_NCS_WRSETUP_(0) | + AT91_SMC_NRDSETUP_(1) | AT91_SMC_NCS_RDSETUP_(0)); + at91_sys_write(AT91_SMC_PULSE(3), + AT91_SMC_NWEPULSE_(3) | AT91_SMC_NCS_WRPULSE_(3) | + AT91_SMC_NRDPULSE_(3) | AT91_SMC_NCS_RDPULSE_(3)); + at91_sys_write(AT91_SMC_CYCLE(3), + AT91_SMC_NWECYCLE_(5) | AT91_SMC_NRDCYCLE_(5)); + at91_sys_write(AT91_SMC_MODE(3), + AT91_SMC_READMODE | AT91_SMC_WRITEMODE | + AT91_SMC_EXNWMODE_DISABLE | +#ifdef CONFIG_SYS_NAND_DBW_16 + AT91_SMC_DBW_16 | +#else /* CONFIG_SYS_NAND_DBW_8 */ + AT91_SMC_DBW_8 | +#endif + AT91_SMC_TDF_(2)); + + /* Configure RDY/BSY */ + at91_set_gpio_input(CONFIG_SYS_NAND_READY_PIN, 1); + + /* Enable NandFlash */ + at91_set_gpio_output(CONFIG_SYS_NAND_ENABLE_PIN, 1); +} +#endif /* CONFIG_CMD_NAND */ + +#ifdef CONFIG_MACB +static void meesc_macb_hw_init(void) +{ + /* Enable clock */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9263_ID_EMAC); + at91_macb_hw_init(); +} +#endif + +/* + * Static memory controller initialization to enable Beckhoff ET1100 EtherCAT + * controller debugging + * The ET1100 is located at physical address 0x70000000 + * Its process memory is located at physical address 0x70001000 + */ +static void meesc_ethercat_hw_init(void) +{ + /* Configure SMC EBI1_CS0 for EtherCAT */ + at91_sys_write(AT91_SMC1_SETUP(0), + AT91_SMC_NWESETUP_(0) | AT91_SMC_NCS_WRSETUP_(0) | + AT91_SMC_NRDSETUP_(0) | AT91_SMC_NCS_RDSETUP_(0)); + at91_sys_write(AT91_SMC1_PULSE(0), + AT91_SMC_NWEPULSE_(4) | AT91_SMC_NCS_WRPULSE_(9) | + AT91_SMC_NRDPULSE_(4) | AT91_SMC_NCS_RDPULSE_(9)); + at91_sys_write(AT91_SMC1_CYCLE(0), + AT91_SMC_NWECYCLE_(10) | AT91_SMC_NRDCYCLE_(5)); + /* Configure behavior at external wait signal, byte-select mode, 16 bit + data bus width, none data float wait states and TDF optimization */ + at91_sys_write(AT91_SMC1_MODE(0), + AT91_SMC_READMODE | AT91_SMC_EXNWMODE_READY | + AT91_SMC_BAT_SELECT | AT91_SMC_DBW_16 | AT91_SMC_TDF_(0) | + AT91_SMC_TDFMODE); + + /* Configure RDY/BSY */ + at91_set_B_periph(AT91_PIN_PE20, 0); /* EBI1_NWAIT */ +} + +int dram_init(void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM; + gd->bd->bi_dram[0].size = get_ram_size((long *) PHYS_SDRAM, (1 << 27)); + return 0; +} + +int board_eth_init(bd_t *bis) +{ + int rc = 0; +#ifdef CONFIG_MACB + rc = macb_eth_initialize(0, (void *)AT91SAM9263_BASE_EMAC, 0x00); +#endif + return rc; +} + +int checkboard(void) +{ + char str[32]; + char buf[32]; + + puts("Board: esd CAN-EtherCAT Gateway"); + if (getenv_r("serial#", str, sizeof(str)) > 0) { + puts(", serial# "); + puts(str); + } + printf("\nHardware-revision: 1.%d\n", get_hw_rev()); + printf("Crystal frequency:\t%8s MHz\n", + strmhz(buf, get_main_clk_rate())); + printf("CPU clock:\t\t%8s MHz\n", + strmhz(buf, get_cpu_clk_rate())); +#ifdef CONFIG_SHOW_VERBOSE_CLOCKINFO + printf("Master clock:\t\t%8s MHz\n", + strmhz(buf, get_mck_clk_rate())); + printf("PLL A clock:\t\t%8s MHz\n", + strmhz(buf, get_plla_clk_rate())); + printf("PLL B Reg.:\t\t0x%08X\n", + at91_sys_read(AT91_CKGR_PLLBR)); + printf("PLL B clock:\t\t%8s MHz\n", + strmhz(buf, get_pllb_clk_rate())); +#endif + printf("Mach-type: %lu\n", gd->bd->bi_arch_number); + return 0; +} + +int board_init(void) +{ + /* Enable Ctrlc */ + console_init_f(); + + /* Peripheral Clock Enable Register */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9263_ID_PIOA | + 1 << AT91SAM9263_ID_PIOB | + 1 << AT91SAM9263_ID_PIOCDE | + 1 << AT91SAM9263_ID_CAN); + + /* arch number of MEESC-Board */ + gd->bd->bi_arch_number = MACH_TYPE_MEESC; + + /* adress of boot parameters */ + gd->bd->bi_boot_params = PHYS_SDRAM + 0x100; + + at91_serial_hw_init(); +#ifdef CONFIG_CMD_NAND + meesc_nand_hw_init(); +#endif + meesc_ethercat_hw_init(); +#ifdef CONFIG_HAS_DATAFLASH + at91_spi0_hw_init(1 << 0); +#endif +#ifdef CONFIG_MACB + meesc_macb_hw_init(); +#endif + at91_set_A_periph(AT91_PIN_PA13, 0); /* CAN_TX */ + at91_set_A_periph(AT91_PIN_PA14, 1); /* CAN_RX */ + return 0; +} diff --git a/board/esd/meesc/partition.c b/board/esd/meesc/partition.c new file mode 100644 index 0000000..df0e1db --- /dev/null +++ b/board/esd/meesc/partition.c @@ -0,0 +1,37 @@ +/* + * (C) Copyright 2008 + * Ulf Samuelsson ulf@atmel.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + */ +#include <common.h> +#include <config.h> +#include <asm/hardware.h> +#include <dataflash.h> + +AT91S_DATAFLASH_INFO dataflash_info[CONFIG_SYS_MAX_DATAFLASH_BANKS]; + +struct dataflash_addr cs[CONFIG_SYS_MAX_DATAFLASH_BANKS] = { + {CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0, 0}, /* Logical adress, CS */ +}; + +/* define the area offsets */ +dataflash_protect_t area_list[NB_DATAFLASH_AREA] = { + {0x00000000, 0x000041FF, FLAG_PROTECT_SET, 0, "Bootstrap"}, + {0x00004200, 0x000083FF, FLAG_PROTECT_CLEAR, 0, "Environment"}, + {0x00008400, 0x00041FFF, FLAG_PROTECT_SET, 0, "U-Boot"}, +}; diff --git a/include/configs/meesc.h b/include/configs/meesc.h new file mode 100644 index 0000000..5ff90c7 --- /dev/null +++ b/include/configs/meesc.h @@ -0,0 +1,185 @@ +/* + * (C) Copyright 2007-2008 + * Stelian Pop stelian.pop@leadtechdesign.com + * Lead Tech Design <www.leadtechdesign.com> + * + * (C) Copyright 2009 + * Daniel Gorsulowski daniel.gorsulowski@esd.eu + * esd electronic system design gmbh <www.esd.eu> + * + * Configuation settings for the esd MEESC board. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* Common stuff */ +#define AT91_CPU_NAME "AT91SAM9263" +#define CONFIG_SYS_HZ 1000 /* decrementer freq */ +#define CONFIG_MEESC 1 /* Board is esd MEESC */ +#define CONFIG_ARM926EJS 1 /* This is an ARM926EJS Core */ +#define CONFIG_AT91SAM9263 1 /* It's an AT91SAM9263 SoC */ +#define CONFIG_ENV_OVERWRITE 1 /* necessary on prototypes */ +#define CONFIG_DISPLAY_BOARDINFO 1 +#define CONFIG_PREBOOT /* enable preboot variable */ +#define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ +#define CONFIG_SETUP_MEMORY_TAGS 1 +#define CONFIG_INITRD_TAG 1 +#undef CONFIG_USE_IRQ /* don't need IRQ/FIQ stuff */ + +#define CONFIG_SKIP_LOWLEVEL_INIT +#define CONFIG_SKIP_RELOCATE_UBOOT + +#define CONFIG_ARCH_CPU_INIT + +/* + * Hardware drivers + */ + +/* Console output */ +#define CONFIG_ATMEL_USART 1 +#undef CONFIG_USART0 +#undef CONFIG_USART1 +#undef CONFIG_USART2 +#define CONFIG_USART3 1 /* USART 3 is DBGU */ + +#define CONFIG_BOOTDELAY 3 +#define CONFIG_ZERO_BOOTDELAY_CHECK 1 + +/* + * BOOTP options + */ +#define CONFIG_BOOTP_BOOTFILESIZE 1 +#define CONFIG_BOOTP_BOOTPATH 1 +#define CONFIG_BOOTP_GATEWAY 1 +#define CONFIG_BOOTP_HOSTNAME 1 + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> +#undef CONFIG_CMD_BDI +#undef CONFIG_CMD_AUTOSCRIPT +#undef CONFIG_CMD_FPGA +#undef CONFIG_CMD_LOADS +#undef CONFIG_CMD_IMLS +#undef CONFIG_CMD_USB + +#define CONFIG_CMD_PING 1 +#define CONFIG_CMD_DHCP 1 +#define CONFIG_CMD_NAND 1 + +/* LED */ +#define CONFIG_AT91_LED 1 + +/* SDRAM */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM 0x20000000 + +/* DataFlash */ +#define CONFIG_ATMEL_DATAFLASH_SPI +#define CONFIG_HAS_DATAFLASH 1 +#define CONFIG_SYS_SPI_WRITE_TOUT (5 * CONFIG_SYS_HZ) +#define CONFIG_SYS_MAX_DATAFLASH_BANKS 1 +#define CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 0xC0000000 /* CS0 */ +#define AT91_SPI_CLK 15000000 +#define DATAFLASH_TCSS (0x1a << 16) +#define DATAFLASH_TCHS (0x1 << 24) + +/* NOR flash is not populated, disable it */ +#define CONFIG_SYS_NO_FLASH 1 + +/* NAND flash */ +#ifdef CONFIG_CMD_NAND +#define CONFIG_NAND_ATMEL +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_SYS_NAND_BASE 0x40000000 +#define CONFIG_SYS_NAND_DBW_8 1 +/* our ALE is AD21 */ +#define CONFIG_SYS_NAND_MASK_ALE (1 << 21) +/* our CLE is AD22 */ +#define CONFIG_SYS_NAND_MASK_CLE (1 << 22) +#define CONFIG_SYS_NAND_ENABLE_PIN AT91_PIN_PD15 +#define CONFIG_SYS_NAND_READY_PIN AT91_PIN_PA22 +#endif + +/* Ethernet */ +#define CONFIG_MACB 1 +#define CONFIG_RMII 1 +#define CONFIG_NET_MULTI 1 +#define CONFIG_NET_RETRY_COUNT 20 +#undef CONFIG_RESET_PHY_R + +#define CONFIG_SYS_LOAD_ADDR 0x22000000 /* load address */ + +#define CONFIG_SYS_MEMTEST_START PHYS_SDRAM +#define CONFIG_SYS_MEMTEST_END 0x21e00000 + +#define CONFIG_SYS_USE_DATAFLASH 1 +#undef CONFIG_SYS_USE_NANDFLASH + +#ifdef CONFIG_SYS_USE_DATAFLASH + +/* bootstrap + u-boot + env + linux in dataflash on CS0 */ +#define CONFIG_ENV_IS_IN_DATAFLASH 1 +#define CONFIG_SYS_MONITOR_BASE (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 + \ + 0x8400) +#define CONFIG_ENV_OFFSET 0x4200 +#define CONFIG_ENV_ADDR (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 + \ + CONFIG_ENV_OFFSET) +#define CONFIG_ENV_SIZE 0x4200 +#define CONFIG_BOOTCOMMAND "cp.b C0042000 22000000 210000; bootm" + +#else /* CONFIG_SYS_USE_NANDFLASH */ + +/* bootstrap + u-boot + env + linux in nandflash */ +#define CONFIG_ENV_IS_IN_NAND 1 +#define CONFIG_ENV_OFFSET 0x60000 +#define CONFIG_ENV_OFFSET_REDUND 0x80000 +#define CONFIG_ENV_SIZE 0x20000 /* 1 sector = 128 kB */ +#define CONFIG_BOOTCOMMAND "nand read 22000000 A0000 200000; bootm" + +#endif + +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE {115200 , 19200, 38400, 57600, 9600 } + +#define CONFIG_SYS_PROMPT "=> " +#define CONFIG_SYS_CBSIZE 256 +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_LONGHELP 1 +#define CONFIG_CMDLINE_EDITING 1 + +/* + * Size of malloc() pool + */ +#define CONFIG_SYS_MALLOC_LEN 0x2D000 +#define CONFIG_SYS_GBL_DATA_SIZE 128 /* 128 bytes for initial data */ + +#define CONFIG_STACKSIZE (32 * 1024) /* regular stack */ + +#ifdef CONFIG_USE_IRQ +#error CONFIG_USE_IRQ not supported +#endif + +#endif
- (C) Copyright 2007-2008
- Stelian Pop stelian.pop@leadtechdesign.com
- Lead Tech Design <www.leadtechdesign.com>
- (C) Copyright 2009
- Daniel Gorsulowski daniel.gorsulowski@esd.eu
- esd electronic system design gmbh <www.esd.eu>
- project.
- MA 02111-1307 USA
please use <asm/arch/at91sam9_matrix.h>
- Miscelaneous platform dependent initialisations
it will be better to only read it only and store it in a static
- int rev = at91_get_gpio_value(AT91_PIN_PB19);
please add an empty line
- rev |= at91_get_gpio_value(AT91_PIN_PB20) << 1;
- rev |= at91_get_gpio_value(AT91_PIN_PB21) << 2;
- rev |= at91_get_gpio_value(AT91_PIN_PB22) << 3;
- if (rev == 15)
rev = 0;
- return rev;
<snip>
- char str[32];
- char buf[32];
- puts("Board: esd CAN-EtherCAT Gateway");
- if (getenv_r("serial#", str, sizeof(str)) > 0) {
puts(", serial# ");
puts(str);
- printf("\nHardware-revision: 1.%d\n", get_hw_rev());
- printf("Crystal frequency:\t%8s MHz\n",
- printf("CPU clock:\t\t%8s MHz\n",
- printf("Master clock:\t\t%8s MHz\n",
- printf("PLL A clock:\t\t%8s MHz\n",
- printf("PLL B Reg.:\t\t0x%08X\n",
- printf("PLL B clock:\t\t%8s MHz\n",
- printf("Mach-type: %lu\n", gd->bd->bi_arch_number);
please use cpu_info when it's possible to avoid copy & paste
- /* Enable Ctrlc */
- console_init_f();
no need
- /* Peripheral Clock Enable Register */
- at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9263_ID_PIOA |
- /* arch number of MEESC-Board */
- gd->bd->bi_arch_number = MACH_TYPE_MEESC;
- /* adress of boot parameters */
- gd->bd->bi_boot_params = PHYS_SDRAM + 0x100;
- at91_serial_hw_init();
- meesc_nand_hw_init();
- meesc_ethercat_hw_init();
- at91_spi0_hw_init(1 << 0);
- meesc_macb_hw_init();
- at91_set_A_periph(AT91_PIN_PA13, 0); /* CAN_TX */
- at91_set_A_periph(AT91_PIN_PA14, 1); /* CAN_RX */
please add a at91_can_hw_init function
<snio>
please remove
why which value?
Best Regards, J.
- project.
- MA 02111-1307 USA
ok
I only use it once, but if you really mean, I'll change it.
ok
- if (rev == 15)
rev = 0;
- return rev;
<snip> > + > +int checkboard(void) > +{ > + char str[32]; > + char buf[32]; > + > + puts("Board: esd CAN-EtherCAT Gateway"); > + if (getenv_r("serial#", str, sizeof(str)) > 0) { > + puts(", serial# "); > + puts(str); > + } > + printf("\nHardware-revision: 1.%d\n", get_hw_rev()); > + printf("Crystal frequency:\t%8s MHz\n", > + strmhz(buf, get_main_clk_rate())); > + printf("CPU clock:\t\t%8s MHz\n", > + strmhz(buf, get_cpu_clk_rate())); > +#ifdef CONFIG_SHOW_VERBOSE_CLOCKINFO > + printf("Master clock:\t\t%8s MHz\n", > + strmhz(buf, get_mck_clk_rate())); > + printf("PLL A clock:\t\t%8s MHz\n", > + strmhz(buf, get_plla_clk_rate())); > + printf("PLL B Reg.:\t\t0x%08X\n", > + at91_sys_read(AT91_CKGR_PLLBR)); > + printf("PLL B clock:\t\t%8s MHz\n", > + strmhz(buf, get_pllb_clk_rate())); > +#endif > + printf("Mach-type: %lu\n", gd->bd->bi_arch_number); > + return 0; > +} please use cpu_info when it's possible to avoid copy & paste
Coud you explain a few more? I can't find a function called 'cpu_info'.
- console_init_f();
no need
Ok, I'll remove it
Ok, I'll do this by a separate patch
<snio> > + > +#ifndef __CONFIG_H > +#define __CONFIG_H > + > +/* Common stuff */ > +#define AT91_CPU_NAME "AT91SAM9263" please remove
ok
why which value?
This is a custom value, which is set, during putting the board into operation. So it is unalterable to define CONFIG_PREBOOT
Best Regards, J. _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Best regards, Daniel Gorsulowski
Found config option CONFIG_DISPLAY_CPUINFO and enabled it, thank you for the hint.
Signed-off-by: Daniel Gorsulowski Daniel.Gorsulowski@esd.eu --- MAINTAINERS | 4 + MAKEALL | 1 + Makefile | 3 + board/esd/meesc/Makefile | 55 ++++++++++++ board/esd/meesc/config.mk | 1 + board/esd/meesc/meesc.c | 197 +++++++++++++++++++++++++++++++++++++++++++ board/esd/meesc/partition.c | 37 ++++++++ include/configs/meesc.h | 188 +++++++++++++++++++++++++++++++++++++++++ 8 files changed, 486 insertions(+), 0 deletions(-) create mode 100644 board/esd/meesc/Makefile create mode 100644 board/esd/meesc/config.mk create mode 100644 board/esd/meesc/meesc.c create mode 100644 board/esd/meesc/partition.c create mode 100644 include/configs/meesc.h
diff --git a/MAINTAINERS b/MAINTAINERS index f36a1cc..c9066a9 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -530,6 +530,10 @@ Peter Figuli peposh@etc.sk
wepep250 xscale
impa7 ARM720T (EP7211) diff --git a/MAKEALL b/MAKEALL index 063ebfc..47eb5af 100755 --- a/MAKEALL +++ b/MAKEALL @@ -583,6 +583,7 @@ LIST_at91=" \ cmc_pu2 \ csb637 \ kb9202 \ + meesc \ mp2usb \ m501sk \ pm9261 \ diff --git a/Makefile b/Makefile index 0d92d67..282b9fd 100644 --- a/Makefile +++ b/Makefile @@ -2769,6 +2769,9 @@ at91sam9rlek_config : unconfig fi; @$(MKCONFIG) -a at91sam9rlek arm arm926ejs at91sam9rlek atmel at91
+meesc_config : unconfig + @$(MKCONFIG) $(@:_config=) arm arm926ejs meesc esd at91 + pm9261_config : unconfig @$(MKCONFIG) $(@:_config=) arm arm926ejs pm9261 ronetix at91
diff --git a/board/esd/meesc/Makefile b/board/esd/meesc/Makefile new file mode 100644 index 0000000..2dd6b25 --- /dev/null +++ b/board/esd/meesc/Makefile @@ -0,0 +1,55 @@ +# +# (C) Copyright 2003-2008 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# (C) Copyright 2008 +# Stelian Pop stelian.pop@leadtechdesign.com +# Lead Tech Design <www.leadtechdesign.com> +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS-y += $(BOARD).o +COBJS-$(CONFIG_HAS_DATAFLASH) += partition.o + +SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS-y)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) $(SOBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak $(obj).depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/esd/meesc/config.mk b/board/esd/meesc/config.mk new file mode 100644 index 0000000..9ce161e --- /dev/null +++ b/board/esd/meesc/config.mk @@ -0,0 +1 @@ +TEXT_BASE = 0x21f00000 diff --git a/board/esd/meesc/meesc.c b/board/esd/meesc/meesc.c new file mode 100644 index 0000000..cb567ac --- /dev/null +++ b/board/esd/meesc/meesc.c @@ -0,0 +1,197 @@ +/* + * (C) Copyright 2007-2008 + * Stelian Pop stelian.pop@leadtechdesign.com + * Lead Tech Design <www.leadtechdesign.com> + * + * (C) Copyright 2009 + * Daniel Gorsulowski daniel.gorsulowski@esd.eu + * esd electronic system design gmbh <www.esd.eu> + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/arch/at91sam9263.h> +#include <asm/arch/at91sam9_matrix.h> +#include <asm/arch/at91sam9_smc.h> +#include <asm/arch/at91_common.h> +#include <asm/arch/at91_pmc.h> +#include <asm/arch/at91_rstc.h> +#include <asm/arch/clk.h> +#include <asm/arch/gpio.h> +#include <asm/arch/hardware.h> +#include <asm/arch/io.h> +#include <netdev.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* + * Miscelaneous platform dependent initialisations + */ + +static int hw_rev; /* hardware revision */ + +int get_hw_rev(void) +{ + int rev = at91_get_gpio_value(AT91_PIN_PB19); + + rev |= at91_get_gpio_value(AT91_PIN_PB20) << 1; + rev |= at91_get_gpio_value(AT91_PIN_PB21) << 2; + rev |= at91_get_gpio_value(AT91_PIN_PB22) << 3; + + if (rev == 15) + rev = 0; + + return rev; +} + +#ifdef CONFIG_CMD_NAND +static void meesc_nand_hw_init(void) +{ + unsigned long csa; + + /* Enable CS3 */ + csa = at91_sys_read(AT91_MATRIX_EBI0CSA); + at91_sys_write(AT91_MATRIX_EBI0CSA, + csa | AT91_MATRIX_EBI0_CS3A_SMC_SMARTMEDIA); + + /* Configure SMC CS3 for NAND/SmartMedia */ + at91_sys_write(AT91_SMC_SETUP(3), + AT91_SMC_NWESETUP_(1) | AT91_SMC_NCS_WRSETUP_(0) | + AT91_SMC_NRDSETUP_(1) | AT91_SMC_NCS_RDSETUP_(0)); + at91_sys_write(AT91_SMC_PULSE(3), + AT91_SMC_NWEPULSE_(3) | AT91_SMC_NCS_WRPULSE_(3) | + AT91_SMC_NRDPULSE_(3) | AT91_SMC_NCS_RDPULSE_(3)); + at91_sys_write(AT91_SMC_CYCLE(3), + AT91_SMC_NWECYCLE_(5) | AT91_SMC_NRDCYCLE_(5)); + at91_sys_write(AT91_SMC_MODE(3), + AT91_SMC_READMODE | AT91_SMC_WRITEMODE | + AT91_SMC_EXNWMODE_DISABLE | +#ifdef CONFIG_SYS_NAND_DBW_16 + AT91_SMC_DBW_16 | +#else /* CONFIG_SYS_NAND_DBW_8 */ + AT91_SMC_DBW_8 | +#endif + AT91_SMC_TDF_(2)); + + /* Configure RDY/BSY */ + at91_set_gpio_input(CONFIG_SYS_NAND_READY_PIN, 1); + + /* Enable NandFlash */ + at91_set_gpio_output(CONFIG_SYS_NAND_ENABLE_PIN, 1); +} +#endif /* CONFIG_CMD_NAND */ + +#ifdef CONFIG_MACB +static void meesc_macb_hw_init(void) +{ + /* Enable clock */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9263_ID_EMAC); + at91_macb_hw_init(); +} +#endif + +/* + * Static memory controller initialization to enable Beckhoff ET1100 EtherCAT + * controller debugging + * The ET1100 is located at physical address 0x70000000 + * Its process memory is located at physical address 0x70001000 + */ +static void meesc_ethercat_hw_init(void) +{ + /* Configure SMC EBI1_CS0 for EtherCAT */ + at91_sys_write(AT91_SMC1_SETUP(0), + AT91_SMC_NWESETUP_(0) | AT91_SMC_NCS_WRSETUP_(0) | + AT91_SMC_NRDSETUP_(0) | AT91_SMC_NCS_RDSETUP_(0)); + at91_sys_write(AT91_SMC1_PULSE(0), + AT91_SMC_NWEPULSE_(4) | AT91_SMC_NCS_WRPULSE_(9) | + AT91_SMC_NRDPULSE_(4) | AT91_SMC_NCS_RDPULSE_(9)); + at91_sys_write(AT91_SMC1_CYCLE(0), + AT91_SMC_NWECYCLE_(10) | AT91_SMC_NRDCYCLE_(5)); + /* Configure behavior at external wait signal, byte-select mode, 16 bit + data bus width, none data float wait states and TDF optimization */ + at91_sys_write(AT91_SMC1_MODE(0), + AT91_SMC_READMODE | AT91_SMC_EXNWMODE_READY | + AT91_SMC_BAT_SELECT | AT91_SMC_DBW_16 | AT91_SMC_TDF_(0) | + AT91_SMC_TDFMODE); + + /* Configure RDY/BSY */ + at91_set_B_periph(AT91_PIN_PE20, 0); /* EBI1_NWAIT */ +} + +int dram_init(void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM; + gd->bd->bi_dram[0].size = get_ram_size((long *) PHYS_SDRAM, (1 << 27)); + return 0; +} + +int board_eth_init(bd_t *bis) +{ + int rc = 0; +#ifdef CONFIG_MACB + rc = macb_eth_initialize(0, (void *)AT91SAM9263_BASE_EMAC, 0x00); +#endif + return rc; +} + +int checkboard(void) +{ + char str[32]; + hw_rev = get_hw_rev(); + + puts("Board: esd CAN-EtherCAT Gateway"); + if (getenv_r("serial#", str, sizeof(str)) > 0) { + puts(", serial# "); + puts(str); + } + printf("\nHardware-revision: 1.%d\n", hw_rev); + printf("Mach-type: %lu\n", gd->bd->bi_arch_number); + return 0; +} + +int board_init(void) +{ + /* Peripheral Clock Enable Register */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9263_ID_PIOA | + 1 << AT91SAM9263_ID_PIOB | + 1 << AT91SAM9263_ID_PIOCDE); + + /* arch number of MEESC-Board */ + gd->bd->bi_arch_number = MACH_TYPE_MEESC; + + /* adress of boot parameters */ + gd->bd->bi_boot_params = PHYS_SDRAM + 0x100; + + at91_serial_hw_init(); +#ifdef CONFIG_CMD_NAND + meesc_nand_hw_init(); +#endif + meesc_ethercat_hw_init(); +#ifdef CONFIG_HAS_DATAFLASH + at91_spi0_hw_init(1 << 0); +#endif +#ifdef CONFIG_MACB + meesc_macb_hw_init(); +#endif +#ifdef CONFIG_CAN + at91_can_hw_init(); +#endif + return 0; +} diff --git a/board/esd/meesc/partition.c b/board/esd/meesc/partition.c new file mode 100644 index 0000000..df0e1db --- /dev/null +++ b/board/esd/meesc/partition.c @@ -0,0 +1,37 @@ +/* + * (C) Copyright 2008 + * Ulf Samuelsson ulf@atmel.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + */ +#include <common.h> +#include <config.h> +#include <asm/hardware.h> +#include <dataflash.h> + +AT91S_DATAFLASH_INFO dataflash_info[CONFIG_SYS_MAX_DATAFLASH_BANKS]; + +struct dataflash_addr cs[CONFIG_SYS_MAX_DATAFLASH_BANKS] = { + {CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0, 0}, /* Logical adress, CS */ +}; + +/* define the area offsets */ +dataflash_protect_t area_list[NB_DATAFLASH_AREA] = { + {0x00000000, 0x000041FF, FLAG_PROTECT_SET, 0, "Bootstrap"}, + {0x00004200, 0x000083FF, FLAG_PROTECT_CLEAR, 0, "Environment"}, + {0x00008400, 0x00041FFF, FLAG_PROTECT_SET, 0, "U-Boot"}, +}; diff --git a/include/configs/meesc.h b/include/configs/meesc.h new file mode 100644 index 0000000..0708372 --- /dev/null +++ b/include/configs/meesc.h @@ -0,0 +1,188 @@ +/* + * (C) Copyright 2007-2008 + * Stelian Pop stelian.pop@leadtechdesign.com + * Lead Tech Design <www.leadtechdesign.com> + * + * (C) Copyright 2009 + * Daniel Gorsulowski daniel.gorsulowski@esd.eu + * esd electronic system design gmbh <www.esd.eu> + * + * Configuation settings for the esd MEESC board. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* Common stuff */ +#define CONFIG_SYS_HZ 1000 /* decrementer freq */ +#define CONFIG_MEESC 1 /* Board is esd MEESC */ +#define CONFIG_ARM926EJS 1 /* This is an ARM926EJS Core */ +#define CONFIG_AT91SAM9263 1 /* It's an AT91SAM9263 SoC */ +#define CONFIG_ENV_OVERWRITE 1 /* necessary on prototypes */ +#define CONFIG_DISPLAY_BOARDINFO 1 +#define CONFIG_DISPLAY_CPUINFO 1 /* display cpu info and speed */ +#define CONFIG_PREBOOT /* enable preboot variable */ +#define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ +#define CONFIG_SETUP_MEMORY_TAGS 1 +#define CONFIG_INITRD_TAG 1 +#undef CONFIG_USE_IRQ /* don't need IRQ/FIQ stuff */ + +#define CONFIG_SKIP_LOWLEVEL_INIT +#define CONFIG_SKIP_RELOCATE_UBOOT + +#define CONFIG_ARCH_CPU_INIT + +/* + * Hardware drivers + */ + +/* Console output */ +#define CONFIG_ATMEL_USART 1 +#undef CONFIG_USART0 +#undef CONFIG_USART1 +#undef CONFIG_USART2 +#define CONFIG_USART3 1 /* USART 3 is DBGU */ + +#define CONFIG_BOOTDELAY 3 +#define CONFIG_ZERO_BOOTDELAY_CHECK 1 + +/* + * BOOTP options + */ +#define CONFIG_BOOTP_BOOTFILESIZE 1 +#define CONFIG_BOOTP_BOOTPATH 1 +#define CONFIG_BOOTP_GATEWAY 1 +#define CONFIG_BOOTP_HOSTNAME 1 + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> +#undef CONFIG_CMD_BDI +#undef CONFIG_CMD_AUTOSCRIPT +#undef CONFIG_CMD_FPGA +#undef CONFIG_CMD_LOADS +#undef CONFIG_CMD_IMLS +#undef CONFIG_CMD_USB + +#define CONFIG_CMD_PING 1 +#define CONFIG_CMD_DHCP 1 +#define CONFIG_CMD_NAND 1 + +/* LED */ +#define CONFIG_AT91_LED 1 + +/* SDRAM */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM 0x20000000 + +/* DataFlash */ +#define CONFIG_ATMEL_DATAFLASH_SPI +#define CONFIG_HAS_DATAFLASH 1 +#define CONFIG_SYS_SPI_WRITE_TOUT (5 * CONFIG_SYS_HZ) +#define CONFIG_SYS_MAX_DATAFLASH_BANKS 1 +#define CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 0xC0000000 /* CS0 */ +#define AT91_SPI_CLK 15000000 +#define DATAFLASH_TCSS (0x1a << 16) +#define DATAFLASH_TCHS (0x1 << 24) + +/* NOR flash is not populated, disable it */ +#define CONFIG_SYS_NO_FLASH 1 + +/* NAND flash */ +#ifdef CONFIG_CMD_NAND +#define CONFIG_NAND_ATMEL +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_SYS_NAND_BASE 0x40000000 +#define CONFIG_SYS_NAND_DBW_8 1 +/* our ALE is AD21 */ +#define CONFIG_SYS_NAND_MASK_ALE (1 << 21) +/* our CLE is AD22 */ +#define CONFIG_SYS_NAND_MASK_CLE (1 << 22) +#define CONFIG_SYS_NAND_ENABLE_PIN AT91_PIN_PD15 +#define CONFIG_SYS_NAND_READY_PIN AT91_PIN_PA22 +#endif + +/* Ethernet */ +#define CONFIG_MACB 1 +#define CONFIG_RMII 1 +#define CONFIG_NET_MULTI 1 +#define CONFIG_NET_RETRY_COUNT 20 +#undef CONFIG_RESET_PHY_R + +#define CONFIG_SYS_LOAD_ADDR 0x22000000 /* load address */ + +#define CONFIG_SYS_MEMTEST_START PHYS_SDRAM +#define CONFIG_SYS_MEMTEST_END 0x21e00000 + +#define CONFIG_SYS_USE_DATAFLASH 1 +#undef CONFIG_SYS_USE_NANDFLASH + +#ifdef CONFIG_SYS_USE_DATAFLASH + +/* CAN */ +#define CONFIG_CAN 1 + +/* bootstrap + u-boot + env + linux in dataflash on CS0 */ +#define CONFIG_ENV_IS_IN_DATAFLASH 1 +#define CONFIG_SYS_MONITOR_BASE (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 + \ + 0x8400) +#define CONFIG_ENV_OFFSET 0x4200 +#define CONFIG_ENV_ADDR (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 + \ + CONFIG_ENV_OFFSET) +#define CONFIG_ENV_SIZE 0x4200 +#define CONFIG_BOOTCOMMAND "cp.b C0042000 22000000 210000; bootm" + +#else /* CONFIG_SYS_USE_NANDFLASH */ + +/* bootstrap + u-boot + env + linux in nandflash */ +#define CONFIG_ENV_IS_IN_NAND 1 +#define CONFIG_ENV_OFFSET 0x60000 +#define CONFIG_ENV_OFFSET_REDUND 0x80000 +#define CONFIG_ENV_SIZE 0x20000 /* 1 sector = 128 kB */ +#define CONFIG_BOOTCOMMAND "nand read 22000000 A0000 200000; bootm" + +#endif + +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE {115200 , 19200, 38400, 57600, 9600 } + +#define CONFIG_SYS_PROMPT "=> " +#define CONFIG_SYS_CBSIZE 256 +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_LONGHELP 1 +#define CONFIG_CMDLINE_EDITING 1 + +/* + * Size of malloc() pool + */ +#define CONFIG_SYS_MALLOC_LEN 0x2D000 +#define CONFIG_SYS_GBL_DATA_SIZE 128 /* 128 bytes for initial data */ + +#define CONFIG_STACKSIZE (32 * 1024) /* regular stack */ + +#ifdef CONFIG_USE_IRQ +#error CONFIG_USE_IRQ not supported +#endif + +#endif
wepep250 xscale
- meesc ARM926EJS (AT91SAM9263 SoC)
Marius Gr�ger mag@sysgo.de
- meesc \ mp2usb \ m501sk \ pm9261 \
- @$(MKCONFIG) $(@:_config=) arm arm926ejs meesc esd at91
- $(AR) $(ARFLAGS) $@ $(OBJS) $(SOBJS)
+clean:
- rm -f $(SOBJS) $(OBJS)
+distclean: clean
- rm -f $(LIB) core *.bak $(obj).depend
- project.
- MA 02111-1307 USA
you miss my point here as if you can use the get_hw_rev multiple time then please do something like thie
static int hw_rev = -1; /* hardware revision */
int get_hw_rev(void) { if (hw_rev >= 0) return hw_rev;
hw_rev = at91_get_gpio_value(AT91_PIN_PB19);
hw_rev |= at91_get_gpio_value(AT91_PIN_PB20) << 1; hw_rev |= at91_get_gpio_value(AT91_PIN_PB21) << 2; hw_rev |= at91_get_gpio_value(AT91_PIN_PB22) << 3;
if (hw_rev == 15) hw_rev = 0;
return hw_rev; }
<snip>
CONFIG_AT91_CAN will be better as the code is at91 specific
Best Regards, J.
To enable CAN init, CONFIG_CAN has to be defined in the board config file and at91_can_hw_init() has to be called in the board specific code.
CAN is available on AT91SAM9263 and AT91CAP9 SoC.
Signed-off-by: Daniel Gorsulowski Daniel.Gorsulowski@esd.eu --- cpu/arm926ejs/at91/at91cap9_devices.c | 15 +++++++++++++++ cpu/arm926ejs/at91/at91sam9263_devices.c | 15 +++++++++++++++ include/asm-arm/arch-at91/at91_common.h | 1 + 3 files changed, 31 insertions(+), 0 deletions(-)
diff --git a/cpu/arm926ejs/at91/at91cap9_devices.c b/cpu/arm926ejs/at91/at91cap9_devices.c index c0024ac..39e405f 100644 --- a/cpu/arm926ejs/at91/at91cap9_devices.c +++ b/cpu/arm926ejs/at91/at91cap9_devices.c @@ -3,6 +3,10 @@ * Stelian Pop stelian.pop@leadtechdesign.com * Lead Tech Design <www.leadtechdesign.com> * + * (C) Copyright 2009 + * Daniel Gorsulowski daniel.gorsulowski@esd.eu + * esd electronic system design gmbh <www.esd.eu> + * * See file CREDITS for list of people who contributed to this * project. * @@ -174,3 +178,14 @@ void at91_macb_hw_init(void) #endif } #endif + +#ifdef CONFIG_AT91_CAN +void at91_can_hw_init(void) +{ + at91_set_A_periph(AT91_PIN_PA12, 0); /* CAN_TX */ + at91_set_A_periph(AT91_PIN_PA13, 1); /* CAN_RX */ + + /* Enable clock */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91CAP9_ID_CAN); +} +#endif diff --git a/cpu/arm926ejs/at91/at91sam9263_devices.c b/cpu/arm926ejs/at91/at91sam9263_devices.c index 0f2613e..f72efdf 100644 --- a/cpu/arm926ejs/at91/at91sam9263_devices.c +++ b/cpu/arm926ejs/at91/at91sam9263_devices.c @@ -3,6 +3,10 @@ * Stelian Pop stelian.pop@leadtechdesign.com * Lead Tech Design <www.leadtechdesign.com> * + * (C) Copyright 2009 + * Daniel Gorsulowski daniel.gorsulowski@esd.eu + * esd electronic system design gmbh <www.esd.eu> + * * See file CREDITS for list of people who contributed to this * project. * @@ -182,3 +186,14 @@ void at91_uhp_hw_init(void) at91_set_gpio_output(AT91_PIN_PA24, 0); } #endif + +#ifdef CONFIG_AT91_CAN +void at91_can_hw_init(void) +{ + at91_set_A_periph(AT91_PIN_PA13, 0); /* CAN_TX */ + at91_set_A_periph(AT91_PIN_PA14, 1); /* CAN_RX */ + + /* Enable clock */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9263_ID_CAN); +} +#endif diff --git a/include/asm-arm/arch-at91/at91_common.h b/include/asm-arm/arch-at91/at91_common.h index 9c4e019..01840ee 100644 --- a/include/asm-arm/arch-at91/at91_common.h +++ b/include/asm-arm/arch-at91/at91_common.h @@ -25,6 +25,7 @@ #ifndef AT91_COMMON_H #define AT91_COMMON_H
+void at91_can_hw_init(void); void at91_macb_hw_init(void); void at91_serial_hw_init(void); void at91_serial0_hw_init(void);
Signed-off-by: Daniel Gorsulowski Daniel.Gorsulowski@esd.eu --- MAINTAINERS | 4 + MAKEALL | 1 + Makefile | 3 + board/esd/meesc/Makefile | 55 ++++++++++++ board/esd/meesc/config.mk | 1 + board/esd/meesc/meesc.c | 198 +++++++++++++++++++++++++++++++++++++++++++ board/esd/meesc/partition.c | 37 ++++++++ include/configs/meesc.h | 188 ++++++++++++++++++++++++++++++++++++++++ 8 files changed, 487 insertions(+), 0 deletions(-) create mode 100644 board/esd/meesc/Makefile create mode 100644 board/esd/meesc/config.mk create mode 100644 board/esd/meesc/meesc.c create mode 100644 board/esd/meesc/partition.c create mode 100644 include/configs/meesc.h
wepep250 xscale
diff --git a/board/esd/meesc/Makefile b/board/esd/meesc/Makefile new file mode 100644 index 0000000..2dd6b25 --- /dev/null +++ b/board/esd/meesc/Makefile @@ -0,0 +1,55 @@ +# +# (C) Copyright 2003-2008 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# (C) Copyright 2008 +# Stelian Pop stelian.pop@leadtechdesign.com +# Lead Tech Design <www.leadtechdesign.com> +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS-y += $(BOARD).o +COBJS-$(CONFIG_HAS_DATAFLASH) += partition.o + +SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS-y)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) $(SOBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak $(obj).depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/esd/meesc/config.mk b/board/esd/meesc/config.mk new file mode 100644 index 0000000..9ce161e --- /dev/null +++ b/board/esd/meesc/config.mk @@ -0,0 +1 @@ +TEXT_BASE = 0x21f00000 diff --git a/board/esd/meesc/meesc.c b/board/esd/meesc/meesc.c new file mode 100644 index 0000000..636d0ed --- /dev/null +++ b/board/esd/meesc/meesc.c @@ -0,0 +1,198 @@ +/* + * (C) Copyright 2007-2008 + * Stelian Pop stelian.pop@leadtechdesign.com + * Lead Tech Design <www.leadtechdesign.com> + * + * (C) Copyright 2009 + * Daniel Gorsulowski daniel.gorsulowski@esd.eu + * esd electronic system design gmbh <www.esd.eu> + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/arch/at91sam9263.h> +#include <asm/arch/at91sam9_matrix.h> +#include <asm/arch/at91sam9_smc.h> +#include <asm/arch/at91_common.h> +#include <asm/arch/at91_pmc.h> +#include <asm/arch/at91_rstc.h> +#include <asm/arch/clk.h> +#include <asm/arch/gpio.h> +#include <asm/arch/hardware.h> +#include <asm/arch/io.h> +#include <netdev.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* + * Miscelaneous platform dependent initialisations + */ + +static int hw_rev = -1; /* hardware revision */ + +int get_hw_rev(void) +{ + if (hw_rev >= 0) + return hw_rev; + + hw_rev = at91_get_gpio_value(AT91_PIN_PB19); + hw_rev |= at91_get_gpio_value(AT91_PIN_PB20) << 1; + hw_rev |= at91_get_gpio_value(AT91_PIN_PB21) << 2; + hw_rev |= at91_get_gpio_value(AT91_PIN_PB22) << 3; + + if (hw_rev == 15) + hw_rev = 0; + + return hw_rev; +} + +#ifdef CONFIG_CMD_NAND +static void meesc_nand_hw_init(void) +{ + unsigned long csa; + + /* Enable CS3 */ + csa = at91_sys_read(AT91_MATRIX_EBI0CSA); + at91_sys_write(AT91_MATRIX_EBI0CSA, + csa | AT91_MATRIX_EBI0_CS3A_SMC_SMARTMEDIA); + + /* Configure SMC CS3 for NAND/SmartMedia */ + at91_sys_write(AT91_SMC_SETUP(3), + AT91_SMC_NWESETUP_(1) | AT91_SMC_NCS_WRSETUP_(0) | + AT91_SMC_NRDSETUP_(1) | AT91_SMC_NCS_RDSETUP_(0)); + at91_sys_write(AT91_SMC_PULSE(3), + AT91_SMC_NWEPULSE_(3) | AT91_SMC_NCS_WRPULSE_(3) | + AT91_SMC_NRDPULSE_(3) | AT91_SMC_NCS_RDPULSE_(3)); + at91_sys_write(AT91_SMC_CYCLE(3), + AT91_SMC_NWECYCLE_(5) | AT91_SMC_NRDCYCLE_(5)); + at91_sys_write(AT91_SMC_MODE(3), + AT91_SMC_READMODE | AT91_SMC_WRITEMODE | + AT91_SMC_EXNWMODE_DISABLE | +#ifdef CONFIG_SYS_NAND_DBW_16 + AT91_SMC_DBW_16 | +#else /* CONFIG_SYS_NAND_DBW_8 */ + AT91_SMC_DBW_8 | +#endif + AT91_SMC_TDF_(2)); + + /* Configure RDY/BSY */ + at91_set_gpio_input(CONFIG_SYS_NAND_READY_PIN, 1); + + /* Enable NandFlash */ + at91_set_gpio_output(CONFIG_SYS_NAND_ENABLE_PIN, 1); +} +#endif /* CONFIG_CMD_NAND */ + +#ifdef CONFIG_MACB +static void meesc_macb_hw_init(void) +{ + /* Enable clock */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9263_ID_EMAC); + at91_macb_hw_init(); +} +#endif + +/* + * Static memory controller initialization to enable Beckhoff ET1100 EtherCAT + * controller debugging + * The ET1100 is located at physical address 0x70000000 + * Its process memory is located at physical address 0x70001000 + */ +static void meesc_ethercat_hw_init(void) +{ + /* Configure SMC EBI1_CS0 for EtherCAT */ + at91_sys_write(AT91_SMC1_SETUP(0), + AT91_SMC_NWESETUP_(0) | AT91_SMC_NCS_WRSETUP_(0) | + AT91_SMC_NRDSETUP_(0) | AT91_SMC_NCS_RDSETUP_(0)); + at91_sys_write(AT91_SMC1_PULSE(0), + AT91_SMC_NWEPULSE_(4) | AT91_SMC_NCS_WRPULSE_(9) | + AT91_SMC_NRDPULSE_(4) | AT91_SMC_NCS_RDPULSE_(9)); + at91_sys_write(AT91_SMC1_CYCLE(0), + AT91_SMC_NWECYCLE_(10) | AT91_SMC_NRDCYCLE_(5)); + /* Configure behavior at external wait signal, byte-select mode, 16 bit + data bus width, none data float wait states and TDF optimization */ + at91_sys_write(AT91_SMC1_MODE(0), + AT91_SMC_READMODE | AT91_SMC_EXNWMODE_READY | + AT91_SMC_BAT_SELECT | AT91_SMC_DBW_16 | AT91_SMC_TDF_(0) | + AT91_SMC_TDFMODE); + + /* Configure RDY/BSY */ + at91_set_B_periph(AT91_PIN_PE20, 0); /* EBI1_NWAIT */ +} + +int dram_init(void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM; + gd->bd->bi_dram[0].size = get_ram_size((long *) PHYS_SDRAM, (1 << 27)); + return 0; +} + +int board_eth_init(bd_t *bis) +{ + int rc = 0; +#ifdef CONFIG_MACB + rc = macb_eth_initialize(0, (void *)AT91SAM9263_BASE_EMAC, 0x00); +#endif + return rc; +} + +int checkboard(void) +{ + char str[32]; + + puts("Board: esd CAN-EtherCAT Gateway"); + if (getenv_r("serial#", str, sizeof(str)) > 0) { + puts(", serial# "); + puts(str); + } + printf("\nHardware-revision: 1.%d\n", get_hw_rev()); + printf("Mach-type: %lu\n", gd->bd->bi_arch_number); + return 0; +} + +int board_init(void) +{ + /* Peripheral Clock Enable Register */ + at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9263_ID_PIOA | + 1 << AT91SAM9263_ID_PIOB | + 1 << AT91SAM9263_ID_PIOCDE); + + /* arch number of MEESC-Board */ + gd->bd->bi_arch_number = MACH_TYPE_MEESC; + + /* adress of boot parameters */ + gd->bd->bi_boot_params = PHYS_SDRAM + 0x100; + + at91_serial_hw_init(); +#ifdef CONFIG_CMD_NAND + meesc_nand_hw_init(); +#endif + meesc_ethercat_hw_init(); +#ifdef CONFIG_HAS_DATAFLASH + at91_spi0_hw_init(1 << 0); +#endif +#ifdef CONFIG_MACB + meesc_macb_hw_init(); +#endif +#ifdef CONFIG_AT91_CAN + at91_can_hw_init(); +#endif + return 0; +} diff --git a/board/esd/meesc/partition.c b/board/esd/meesc/partition.c new file mode 100644 index 0000000..df0e1db --- /dev/null +++ b/board/esd/meesc/partition.c @@ -0,0 +1,37 @@ +/* + * (C) Copyright 2008 + * Ulf Samuelsson ulf@atmel.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + */ +#include <common.h> +#include <config.h> +#include <asm/hardware.h> +#include <dataflash.h> + +AT91S_DATAFLASH_INFO dataflash_info[CONFIG_SYS_MAX_DATAFLASH_BANKS]; + +struct dataflash_addr cs[CONFIG_SYS_MAX_DATAFLASH_BANKS] = { + {CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0, 0}, /* Logical adress, CS */ +}; + +/* define the area offsets */ +dataflash_protect_t area_list[NB_DATAFLASH_AREA] = { + {0x00000000, 0x000041FF, FLAG_PROTECT_SET, 0, "Bootstrap"}, + {0x00004200, 0x000083FF, FLAG_PROTECT_CLEAR, 0, "Environment"}, + {0x00008400, 0x00041FFF, FLAG_PROTECT_SET, 0, "U-Boot"}, +}; diff --git a/include/configs/meesc.h b/include/configs/meesc.h new file mode 100644 index 0000000..28c4de0 --- /dev/null +++ b/include/configs/meesc.h @@ -0,0 +1,188 @@ +/* + * (C) Copyright 2007-2008 + * Stelian Pop stelian.pop@leadtechdesign.com + * Lead Tech Design <www.leadtechdesign.com> + * + * (C) Copyright 2009 + * Daniel Gorsulowski daniel.gorsulowski@esd.eu + * esd electronic system design gmbh <www.esd.eu> + * + * Configuation settings for the esd MEESC board. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* Common stuff */ +#define CONFIG_SYS_HZ 1000 /* decrementer freq */ +#define CONFIG_MEESC 1 /* Board is esd MEESC */ +#define CONFIG_ARM926EJS 1 /* This is an ARM926EJS Core */ +#define CONFIG_AT91SAM9263 1 /* It's an AT91SAM9263 SoC */ +#define CONFIG_ENV_OVERWRITE 1 /* necessary on prototypes */ +#define CONFIG_DISPLAY_BOARDINFO 1 +#define CONFIG_DISPLAY_CPUINFO 1 /* display cpu info and speed */ +#define CONFIG_PREBOOT /* enable preboot variable */ +#define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ +#define CONFIG_SETUP_MEMORY_TAGS 1 +#define CONFIG_INITRD_TAG 1 +#undef CONFIG_USE_IRQ /* don't need IRQ/FIQ stuff */ + +#define CONFIG_SKIP_LOWLEVEL_INIT +#define CONFIG_SKIP_RELOCATE_UBOOT + +#define CONFIG_ARCH_CPU_INIT + +/* + * Hardware drivers + */ + +/* Console output */ +#define CONFIG_ATMEL_USART 1 +#undef CONFIG_USART0 +#undef CONFIG_USART1 +#undef CONFIG_USART2 +#define CONFIG_USART3 1 /* USART 3 is DBGU */ + +#define CONFIG_BOOTDELAY 3 +#define CONFIG_ZERO_BOOTDELAY_CHECK 1 + +/* + * BOOTP options + */ +#define CONFIG_BOOTP_BOOTFILESIZE 1 +#define CONFIG_BOOTP_BOOTPATH 1 +#define CONFIG_BOOTP_GATEWAY 1 +#define CONFIG_BOOTP_HOSTNAME 1 + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> +#undef CONFIG_CMD_BDI +#undef CONFIG_CMD_AUTOSCRIPT +#undef CONFIG_CMD_FPGA +#undef CONFIG_CMD_LOADS +#undef CONFIG_CMD_IMLS +#undef CONFIG_CMD_USB + +#define CONFIG_CMD_PING 1 +#define CONFIG_CMD_DHCP 1 +#define CONFIG_CMD_NAND 1 + +/* LED */ +#define CONFIG_AT91_LED 1 + +/* SDRAM */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM 0x20000000 + +/* DataFlash */ +#define CONFIG_ATMEL_DATAFLASH_SPI +#define CONFIG_HAS_DATAFLASH 1 +#define CONFIG_SYS_SPI_WRITE_TOUT (5 * CONFIG_SYS_HZ) +#define CONFIG_SYS_MAX_DATAFLASH_BANKS 1 +#define CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 0xC0000000 /* CS0 */ +#define AT91_SPI_CLK 15000000 +#define DATAFLASH_TCSS (0x1a << 16) +#define DATAFLASH_TCHS (0x1 << 24) + +/* NOR flash is not populated, disable it */ +#define CONFIG_SYS_NO_FLASH 1 + +/* NAND flash */ +#ifdef CONFIG_CMD_NAND +#define CONFIG_NAND_ATMEL +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_SYS_NAND_BASE 0x40000000 +#define CONFIG_SYS_NAND_DBW_8 1 +/* our ALE is AD21 */ +#define CONFIG_SYS_NAND_MASK_ALE (1 << 21) +/* our CLE is AD22 */ +#define CONFIG_SYS_NAND_MASK_CLE (1 << 22) +#define CONFIG_SYS_NAND_ENABLE_PIN AT91_PIN_PD15 +#define CONFIG_SYS_NAND_READY_PIN AT91_PIN_PA22 +#endif + +/* Ethernet */ +#define CONFIG_MACB 1 +#define CONFIG_RMII 1 +#define CONFIG_NET_MULTI 1 +#define CONFIG_NET_RETRY_COUNT 20 +#undef CONFIG_RESET_PHY_R + +#define CONFIG_SYS_LOAD_ADDR 0x22000000 /* load address */ + +#define CONFIG_SYS_MEMTEST_START PHYS_SDRAM +#define CONFIG_SYS_MEMTEST_END 0x21e00000 + +#define CONFIG_SYS_USE_DATAFLASH 1 +#undef CONFIG_SYS_USE_NANDFLASH + +#ifdef CONFIG_SYS_USE_DATAFLASH + +/* CAN */ +#define CONFIG_AT91_CAN 1 + +/* bootstrap + u-boot + env + linux in dataflash on CS0 */ +#define CONFIG_ENV_IS_IN_DATAFLASH 1 +#define CONFIG_SYS_MONITOR_BASE (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 + \ + 0x8400) +#define CONFIG_ENV_OFFSET 0x4200 +#define CONFIG_ENV_ADDR (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 + \ + CONFIG_ENV_OFFSET) +#define CONFIG_ENV_SIZE 0x4200 +#define CONFIG_BOOTCOMMAND "cp.b C0042000 22000000 210000; bootm" + +#else /* CONFIG_SYS_USE_NANDFLASH */ + +/* bootstrap + u-boot + env + linux in nandflash */ +#define CONFIG_ENV_IS_IN_NAND 1 +#define CONFIG_ENV_OFFSET 0x60000 +#define CONFIG_ENV_OFFSET_REDUND 0x80000 +#define CONFIG_ENV_SIZE 0x20000 /* 1 sector = 128 kB */ +#define CONFIG_BOOTCOMMAND "nand read 22000000 A0000 200000; bootm" + +#endif + +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE {115200 , 19200, 38400, 57600, 9600 } + +#define CONFIG_SYS_PROMPT "=> " +#define CONFIG_SYS_CBSIZE 256 +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_LONGHELP 1 +#define CONFIG_CMDLINE_EDITING 1 + +/* + * Size of malloc() pool + */ +#define CONFIG_SYS_MALLOC_LEN 0x2D000 +#define CONFIG_SYS_GBL_DATA_SIZE 128 /* 128 bytes for initial data */ + +#define CONFIG_STACKSIZE (32 * 1024) /* regular stack */ + +#ifdef CONFIG_USE_IRQ +#error CONFIG_USE_IRQ not supported +#endif + +#endif
Applied to u-boot-arm
Best Regards, J.
Best Regards, J.
Daniel Gorsulowski
