[U-Boot] [PATCH v2 0/4] arm: odroid: Convert to distro_bootcmd.
Switch odroid platform to use distro_bootcmd, adjusting to use standardized environment variable names, and use the default bootdelay.
The additional environment variables from distro_bootcmd requires increasing the default environment size, which would break backwards compatibility with saved environments. At Marek's suggestion, I've bumped it well over the size needed (~4.5k vs. 16k) to give room for future growth.
Variations on these patches have been in use in Debian's u-boot packages since 2016.
A variation of this patch series was originally submitted to u-boot over a year ago, and resent a few times since, with little to no response.
Thanks for considering!
Changes in v2: - Change from 16384 to SZ_16K, as suggested by Minkyu Kang.
Vagrant Cascadian (4): arm: odroid: Use standard environment variable names kernel_addr_r, ramdisk_addr_r and fdt_addr_r. arm: odroid: Increase default env size in preparation for distro_bootcmd. arm: odroid: Enable distro_bootcmd support. arm: odroid: Inherit default value for bootdelay from distro_bootcmd.
include/configs/odroid.h | 36 ++++++++++++++++++++---------------- 1 file changed, 20 insertions(+), 16 deletions(-)
Replace non-standard variable names kerneladdr, initrdaddr and fdtaddr with kernel_addr_r, ramdisk_addr_r and fdt_addr_r, as documented in u-boot README.
Acked-by: Lukasz Majewski lukma@denx.de Signed-off-by: Vagrant Cascadian vagrant@debian.org ---
Changes in v2: None
include/configs/odroid.h | 24 +++++++++++------------- 1 file changed, 11 insertions(+), 13 deletions(-)
diff --git a/include/configs/odroid.h b/include/configs/odroid.h index 92811cfc54..b7b75c0dc0 100644 --- a/include/configs/odroid.h +++ b/include/configs/odroid.h @@ -100,21 +100,21 @@ #define CONFIG_EXTRA_ENV_SETTINGS \ "loadbootscript=load mmc ${mmcbootdev}:${mmcbootpart} ${scriptaddr} " \ "boot.scr\0" \ - "loadkernel=load mmc ${mmcbootdev}:${mmcbootpart} ${kerneladdr} " \ + "loadkernel=load mmc ${mmcbootdev}:${mmcbootpart} ${kernel_addr_r} " \ "${kernelname}\0" \ - "loadinitrd=load mmc ${mmcbootdev}:${mmcbootpart} ${initrdaddr} " \ + "loadinitrd=load mmc ${mmcbootdev}:${mmcbootpart} ${ramdisk_addr_r} " \ "${initrdname}\0" \ - "loaddtb=load mmc ${mmcbootdev}:${mmcbootpart} ${fdtaddr} " \ + "loaddtb=load mmc ${mmcbootdev}:${mmcbootpart} ${fdt_addr_r} " \ "${fdtfile}\0" \ "check_ramdisk=" \ "if run loadinitrd; then " \ - "setenv initrd_addr ${initrdaddr};" \ + "setenv initrd_addr ${ramdisk_addr_r};" \ "else " \ "setenv initrd_addr -;" \ "fi;\0" \ "check_dtb=" \ "if run loaddtb; then " \ - "setenv fdt_addr ${fdtaddr};" \ + "setenv fdt_addr ${fdt_addr_r};" \ "else " \ "setenv fdt_addr;" \ "fi;\0" \ @@ -125,27 +125,24 @@ "run loadbootscript;" \ "source ${scriptaddr}\0" \ "boot_fit=" \ - "setenv kerneladdr 0x42000000;" \ "setenv kernelname Image.itb;" \ "run loadkernel;" \ "run kernel_args;" \ - "bootm ${kerneladdr}#${boardname}\0" \ + "bootm ${kernel_addr_r}#${boardname}\0" \ "boot_uimg=" \ - "setenv kerneladdr 0x40007FC0;" \ "setenv kernelname uImage;" \ "run check_dtb;" \ "run check_ramdisk;" \ "run loadkernel;" \ "run kernel_args;" \ - "bootm ${kerneladdr} ${initrd_addr} ${fdt_addr};\0" \ + "bootm ${kernel_addr_r} ${initrd_addr} ${fdt_addr};\0" \ "boot_zimg=" \ - "setenv kerneladdr 0x40007FC0;" \ "setenv kernelname zImage;" \ "run check_dtb;" \ "run check_ramdisk;" \ "run loadkernel;" \ "run kernel_args;" \ - "bootz ${kerneladdr} ${initrd_addr} ${fdt_addr};\0" \ + "bootz ${kernel_addr_r} ${initrd_addr} ${fdt_addr};\0" \ "autoboot=" \ "if test -e mmc 0 boot.scr; then; " \ "run boot_script; " \ @@ -167,9 +164,10 @@ "consoleon=set console console=ttySAC1,115200n8; save; reset\0" \ "consoleoff=set console console=ram; save; reset\0" \ "initrdname=uInitrd\0" \ - "initrdaddr=42000000\0" \ + "ramdisk_addr_r=0x42000000\0" \ "scriptaddr=0x42000000\0" \ - "fdtaddr=40800000\0" + "fdt_addr_r=0x40800000\0" \ + "kernel_addr_r=0x41000000\0"
/* GPT */
Adding distro_bootcmd support bumps the default environment size over 4500. Increase to SZ_16K to allow for room to grow in the future.
include/configs/odroid.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/configs/odroid.h b/include/configs/odroid.h index b7b75c0dc0..07882aca9a 100644 --- a/include/configs/odroid.h +++ b/include/configs/odroid.h @@ -50,7 +50,7 @@ #define CONFIG_SYS_MONITOR_BASE 0x00000000
#define CONFIG_SYS_MMC_ENV_DEV CONFIG_MMC_DEFAULT_DEV -#define CONFIG_ENV_SIZE 4096 +#define CONFIG_ENV_SIZE SZ_16K #define CONFIG_ENV_OFFSET (SZ_1K * 1280) /* 1.25 MiB offset */ #define CONFIG_ENV_OVERWRITE
Enable distro_bootcmd for a standardized boot process across multiple platforms.
Changes in v2: None
include/configs/odroid.h | 11 +++++++++-- 1 file changed, 9 insertions(+), 2 deletions(-)
diff --git a/include/configs/odroid.h b/include/configs/odroid.h index 07882aca9a..a4d1a76c36 100644 --- a/include/configs/odroid.h +++ b/include/configs/odroid.h @@ -41,7 +41,7 @@
/* Console configuration */
-#define CONFIG_BOOTCOMMAND "run autoboot" +#define CONFIG_BOOTCOMMAND "run distro_bootcmd ; run autoboot" #define CONFIG_DEFAULT_CONSOLE "ttySAC1,115200n8"
#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_LOAD_ADDR \ @@ -83,6 +83,12 @@ "bl2 raw 0x1f 0x1d;" \ "tzsw raw 0x83f 0x138\0"
+#define BOOT_TARGET_DEVICES(func) \ + func(MMC, mmc, 1) \ + func(MMC, mmc, 0) + +#include <config_distro_bootcmd.h> + /* * Bootable media layout: * dev: SD eMMC(part boot) @@ -167,7 +173,8 @@ "ramdisk_addr_r=0x42000000\0" \ "scriptaddr=0x42000000\0" \ "fdt_addr_r=0x40800000\0" \ - "kernel_addr_r=0x41000000\0" + "kernel_addr_r=0x41000000\0" \ + BOOTENV
/* GPT */
The default value with distro_bootcmd is 2 seconds, which is reasonably fast, and provides a consistent experience across platforms supporting distro_bootcmd.
The current bootdelay value of 0 seconds is a bit challenging to interrupt when desired.
Changes in v2: None
include/configs/odroid.h | 1 - 1 file changed, 1 deletion(-)
diff --git a/include/configs/odroid.h b/include/configs/odroid.h index a4d1a76c36..67a790ef02 100644 --- a/include/configs/odroid.h +++ b/include/configs/odroid.h @@ -164,7 +164,6 @@ "mmcbootpart=1\0" \ "mmcrootdev=0\0" \ "mmcrootpart=2\0" \ - "bootdelay=0\0" \ "dfu_alt_system="CONFIG_DFU_ALT \ "dfu_alt_info=Please reset the board\0" \ "consoleon=set console console=ttySAC1,115200n8; save; reset\0" \
Hi Vagrant,
Yes, the Samsung port of u-boot could work better.
I think that Tom can apply those patches directly if no response is given in a reasonable time.
I would like to emphasize this one more time - thanks for your patches.
Changes in v2:
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de
2018년 7월 25일 (수) 16:25, Lukasz Majewski lukma@denx.de님이 작성:
Hi Vagrant,
I was waiting v2 of this patchset. It will be accepted soon.
Changes in v2:
Lukasz Majewski
Thanks, Minkyu Kang.
2018년 7월 25일 (수) 16:45, Minkyu Kang promsoft@gmail.com님이 작성:
Hi Vagrant,
Changes in v2:
Lukasz Majewski
applied to u-boot-samsung.
Lukasz Majewski
Minkyu Kang
Vagrant Cascadian
