[U-Boot] build failure on denx top
Hello All, On denx tree master branch , u-boot build is failing for 83xx and 85xx platforms. Build log make[1]: Entering directory `/project/p1020_swe_nobackup/usr/poonam/p20x0/denx/latest/mirrors.u-boot /u-boot/examples/standalone' /opt/freescale/usr/local/gcc-4.3.74-eglibc-2.8.74-dp-2/powerpc-none-linu x-gnuspe/bin/powerpc-none-linux-gnuspe-gcc -g -Os -fPIC -ffixed-r14 -meabi -D__KERNEL__ -DTEXT_BASE=0xFE000000 -I/project/p1020_swe_nobackup/usr/poonam/p20x0/denx/latest/mirrors.u-boo t/u-boot/include -fno-builtin -ffreestanding -nostdinc -isystem /opt/freescale/usr/local/gcc-4.3.74-eglibc-2.8.74-dp-2/powerpc-none-linu x-gnuspe/lib/gcc/powerpc-none-linux-gnuspe/4.3.2/include -pipe -DCONFIG_PPC -D__powerpc__ -DCONFIG_MPC83xx -DCONFIG_E300 -ffixed-r2 -msoft-float -Wall -Wstrict-prototypes -fno-stack-protector -g -Os -fPIC -ffixed-r14 -meabi -D__KERNEL__ -DTEXT_BASE=0xFE000000 -I/project/p1020_swe_nobackup/usr/poonam/p20x0/denx/latest/mirrors.u-boo t/u-boot/include -fno-builtin -ffreestanding -nostdinc -isystem /opt/freescale/usr/local/gcc-4.3.74-eglibc-2.8.74-dp-2/powerpc-none-linu x-gnuspe/lib/gcc/powerpc-none-linux-gnuspe/4.3.2/include -pipe -DCONFIG_PPC -D__powerpc__ -DCONFIG_MPC83xx -DCONFIG_E300 -ffixed-r2 -msoft-float -I.. -Bstatic -T u-boot.lds -n -Ttext 0xFE000000 -o .c powerpc-none-linux-gnuspe-gcc: 0xFE000000: No such file or directory powerpc-none-linux-gnuspe-gcc: no input files make[1]: *** [.c] Error 1 make[1]: Leaving directory `/project/p1020_swe_nobackup/usr/poonam/p20x0/denx/latest/mirrors.u-boot /u-boot/examples/standalone' make: *** [examples/standalone] Error 2 When I remove the following commit, things work fine. From 557555fe0b82940ba7cc69f81d31d6ef4d4933b4 Mon Sep 17 00:00:00 2001 From: Mike Frysinger <vapier@gentoo.org mailto:vapier@gentoo.org > Date: Fri, 4 Sep 2009 19:54:45 -0400 Subject: [PATCH] standalone: convert to kbuild style Clean up the arch/cpu/board/config checks as well as redundant setting of srec/bin variables by using the kbuild VAR-$(...) style. Signed-off-by: Mike Frysinger vapier@gentoo.org I am facing it for FSL 83xx and 85xx platforms. Is anybody else also seeing this build failure. Regards Poonam
Dear Aggrwal Poonam-B10812,
2009/9/30 Aggrwal Poonam-B10812 Poonam.Aggrwal@freescale.com:
Hello All,
Which version is your make? 3.80 or earlier?
I think make-3.81 can solve your problem.
Best regards, Po-Yu Chuang
-----Original Message----- From: Po-Yu Chuang [mailto:ratbert.chuang@gmail.com] Sent: Wednesday, September 30, 2009 11:15 AM To: Aggrwal Poonam-B10812 Cc: u-boot@lists.denx.de Subject: Re: [U-Boot] build failure on denx top
Hello All,
failing for 83xx
and 85xx platforms.
-ffixed-r2
-ffixed-r2
0xFE000000 -o
redundant
Thanks a lot. It works with make 3.81. Just a question is there any documentation in u-boot which captures it? Or is it like we must always work with latest versions of these utilities.
Po-Yu Chuang
