[U-Boot] [PATCH v2] mmc: sdhci-cadence: add Cadence SD4HC support
Add a driver for the Cadence SD4HC SD/SDIO/eMMC Controller.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
Changes in v2: - Remove unneeded version setting - Add SoC specific compatible "socionext,uniphier-sd4hc" - Add "depends on BLK && DM_MMC_OPS && MMC_SDHCI"
drivers/mmc/Kconfig | 12 +++++ drivers/mmc/Makefile | 1 + drivers/mmc/sdhci-cadence.c | 125 ++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 138 insertions(+) create mode 100644 drivers/mmc/sdhci-cadence.c
diff --git a/drivers/mmc/Kconfig b/drivers/mmc/Kconfig index 2ba1254..ff4344f 100644 --- a/drivers/mmc/Kconfig +++ b/drivers/mmc/Kconfig @@ -159,6 +159,18 @@ config MMC_SDHCI_BCM2835
If unsure, say N.
+config MMC_SDHCI_CADENCE + bool "SDHCI support for the Cadence SD/SDIO/eMMC controller" + depends on BLK && DM_MMC_OPS + depends on MMC_SDHCI + depends on OF_CONTROL + help + This selects the Cadence SD/SDIO/eMMC driver. + + If you have a controller with this interface, say Y here. + + If unsure, say N. + config MMC_SDHCI_KONA bool "SDHCI support on Broadcom KONA platform" depends on MMC_SDHCI diff --git a/drivers/mmc/Makefile b/drivers/mmc/Makefile index 2b136ea..a543188 100644 --- a/drivers/mmc/Makefile +++ b/drivers/mmc/Makefile @@ -64,6 +64,7 @@ obj-$(CONFIG_MSM_SDHCI) += msm_sdhci.o # SDHCI obj-$(CONFIG_MMC_SDHCI) += sdhci.o obj-$(CONFIG_MMC_SDHCI_BCM2835) += bcm2835_sdhci.o +obj-$(CONFIG_MMC_SDHCI_CADENCE) += sdhci-cadence.o obj-$(CONFIG_MMC_SDHCI_KONA) += kona_sdhci.o obj-$(CONFIG_MMC_SDHCI_MV) += mv_sdhci.o obj-$(CONFIG_MMC_SDHCI_S5P) += s5p_sdhci.o diff --git a/drivers/mmc/sdhci-cadence.c b/drivers/mmc/sdhci-cadence.c new file mode 100644 index 0000000..2253bbc --- /dev/null +++ b/drivers/mmc/sdhci-cadence.c @@ -0,0 +1,125 @@ +/* + * Copyright (C) 2016 Socionext Inc. + * Author: Masahiro Yamada yamada.masahiro@socionext.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <linux/io.h> +#include <linux/sizes.h> +#include <dm/device.h> +#include <mmc.h> +#include <sdhci.h> + +/* HRS - Host Register Set (specific to Cadence) */ +#define SDHCI_CDNS_HRS04 0x10 /* PHY access port */ +#define SDHCI_CDNS_HRS04_ACK BIT(26) +#define SDHCI_CDNS_HRS04_RD BIT(25) +#define SDHCI_CDNS_HRS04_WR BIT(24) +#define SDHCI_CDNS_HRS04_RDATA_SHIFT 12 +#define SDHCI_CDNS_HRS04_WDATA_SHIFT 8 +#define SDHCI_CDNS_HRS04_ADDR_SHIFT 0 + +/* SRS - Slot Register Set (SDHCI-compatible) */ +#define SDHCI_CDNS_SRS_BASE 0x200 + +/* PHY */ +#define SDHCI_CDNS_PHY_DLY_SD_HS 0x00 +#define SDHCI_CDNS_PHY_DLY_SD_DEFAULT 0x01 +#define SDHCI_CDNS_PHY_DLY_UHS_SDR12 0x02 +#define SDHCI_CDNS_PHY_DLY_UHS_SDR25 0x03 +#define SDHCI_CDNS_PHY_DLY_UHS_SDR50 0x04 +#define SDHCI_CDNS_PHY_DLY_UHS_DDR50 0x05 +#define SDHCI_CDNS_PHY_DLY_EMMC_LEGACY 0x06 +#define SDHCI_CDNS_PHY_DLY_EMMC_SDR 0x07 +#define SDHCI_CDNS_PHY_DLY_EMMC_DDR 0x08 + +struct sdhci_cdns_plat { + struct mmc_config cfg; + struct mmc mmc; + void __iomem *hrs_addr; +}; + +static void sdhci_cdns_write_phy_reg(struct sdhci_cdns_plat *plat, + u8 addr, u8 data) +{ + void __iomem *reg = plat->hrs_addr + SDHCI_CDNS_HRS04; + u32 tmp; + + tmp = (data << SDHCI_CDNS_HRS04_WDATA_SHIFT) | + (addr << SDHCI_CDNS_HRS04_ADDR_SHIFT); + writel(tmp, reg); + + tmp |= SDHCI_CDNS_HRS04_WR; + writel(tmp, reg); + + tmp &= ~SDHCI_CDNS_HRS04_WR; + writel(tmp, reg); +} + +static void sdhci_cdns_phy_init(struct sdhci_cdns_plat *plat) +{ + sdhci_cdns_write_phy_reg(plat, SDHCI_CDNS_PHY_DLY_SD_HS, 4); + sdhci_cdns_write_phy_reg(plat, SDHCI_CDNS_PHY_DLY_SD_DEFAULT, 4); + sdhci_cdns_write_phy_reg(plat, SDHCI_CDNS_PHY_DLY_EMMC_LEGACY, 9); + sdhci_cdns_write_phy_reg(plat, SDHCI_CDNS_PHY_DLY_EMMC_SDR, 2); + sdhci_cdns_write_phy_reg(plat, SDHCI_CDNS_PHY_DLY_EMMC_DDR, 3); +} + +static int sdhci_cdns_bind(struct udevice *dev) +{ + struct sdhci_cdns_plat *plat = dev_get_platdata(dev); + + return sdhci_bind(dev, &plat->mmc, &plat->cfg); +} + +static int sdhci_cdns_probe(struct udevice *dev) +{ + struct mmc_uclass_priv *upriv = dev_get_uclass_priv(dev); + struct sdhci_cdns_plat *plat = dev_get_platdata(dev); + struct sdhci_host *host = dev_get_priv(dev); + fdt_addr_t base; + int ret; + + base = dev_get_addr(dev); + if (base == FDT_ADDR_T_NONE) + return -EINVAL; + + plat->hrs_addr = devm_ioremap(dev, base, SZ_1K); + if (!plat->hrs_addr) + return -ENOMEM; + + host->name = dev->name; + host->ioaddr = plat->hrs_addr + SDHCI_CDNS_SRS_BASE; + host->quirks |= SDHCI_QUIRK_WAIT_SEND_CMD; + + sdhci_cdns_phy_init(plat); + + ret = sdhci_setup_cfg(&plat->cfg, host, 0, 0); + if (ret) + return ret; + + upriv->mmc = &plat->mmc; + host->mmc = &plat->mmc; + host->mmc->priv = host; + + return sdhci_probe(dev); +} + +static const struct udevice_id sdhci_cdns_match[] = { + { .compatible = "socionext,uniphier-sd4hc" }, + { .compatible = "cdns,sd4hc" }, + { /* sentinel */ } +}; + +U_BOOT_DRIVER(sdhci_cdns) = { + .name = "sdhci-cdns", + .id = UCLASS_MMC, + .of_match = sdhci_cdns_match, + .bind = sdhci_cdns_bind, + .probe = sdhci_cdns_probe, + .priv_auto_alloc_size = sizeof(struct sdhci_host), + .platdata_auto_alloc_size = sizeof(struct sdhci_cdns_plat), + .ops = &sdhci_ops, +};
Applied on u-boot-mmc. Thanks!
Best Regards, Jaehoon Chung
Changes in v2:
If unsure, say N.
- bool "SDHCI support for the Cadence SD/SDIO/eMMC controller"
- depends on BLK && DM_MMC_OPS
- depends on MMC_SDHCI
- depends on OF_CONTROL
- help
If unsure, say N.
- Copyright (C) 2016 Socionext Inc.
- Author: Masahiro Yamada yamada.masahiro@socionext.com
- struct mmc_config cfg;
- struct mmc mmc;
- void __iomem *hrs_addr;
u8 addr, u8 data)
- void __iomem *reg = plat->hrs_addr + SDHCI_CDNS_HRS04;
- u32 tmp;
- tmp = (data << SDHCI_CDNS_HRS04_WDATA_SHIFT) |
- writel(tmp, reg);
- tmp |= SDHCI_CDNS_HRS04_WR;
- writel(tmp, reg);
- tmp &= ~SDHCI_CDNS_HRS04_WR;
- writel(tmp, reg);
- sdhci_cdns_write_phy_reg(plat, SDHCI_CDNS_PHY_DLY_SD_HS, 4);
- sdhci_cdns_write_phy_reg(plat, SDHCI_CDNS_PHY_DLY_SD_DEFAULT, 4);
- sdhci_cdns_write_phy_reg(plat, SDHCI_CDNS_PHY_DLY_EMMC_LEGACY, 9);
- sdhci_cdns_write_phy_reg(plat, SDHCI_CDNS_PHY_DLY_EMMC_SDR, 2);
- sdhci_cdns_write_phy_reg(plat, SDHCI_CDNS_PHY_DLY_EMMC_DDR, 3);
- struct sdhci_cdns_plat *plat = dev_get_platdata(dev);
- return sdhci_bind(dev, &plat->mmc, &plat->cfg);
- struct mmc_uclass_priv *upriv = dev_get_uclass_priv(dev);
- struct sdhci_host *host = dev_get_priv(dev);
- fdt_addr_t base;
- int ret;
- base = dev_get_addr(dev);
- if (base == FDT_ADDR_T_NONE)
return -EINVAL;
- plat->hrs_addr = devm_ioremap(dev, base, SZ_1K);
- if (!plat->hrs_addr)
return -ENOMEM;
- host->name = dev->name;
- host->ioaddr = plat->hrs_addr + SDHCI_CDNS_SRS_BASE;
- host->quirks |= SDHCI_QUIRK_WAIT_SEND_CMD;
- sdhci_cdns_phy_init(plat);
- ret = sdhci_setup_cfg(&plat->cfg, host, 0, 0);
- if (ret)
return ret;
- upriv->mmc = &plat->mmc;
- host->mmc = &plat->mmc;
- host->mmc->priv = host;
- return sdhci_probe(dev);
- { .compatible = "socionext,uniphier-sd4hc" },
- { .compatible = "cdns,sd4hc" },
- { /* sentinel */ }
- .name = "sdhci-cdns",
- .id = UCLASS_MMC,
- .of_match = sdhci_cdns_match,
- .bind = sdhci_cdns_bind,
- .probe = sdhci_cdns_probe,
- .priv_auto_alloc_size = sizeof(struct sdhci_host),
- .platdata_auto_alloc_size = sizeof(struct sdhci_cdns_plat),
- .ops = &sdhci_ops,
Jaehoon Chung
Masahiro Yamada
