[U-Boot] [PATCH] New QorIQ p1020 based board support from Arcturus Networks Inc.
New QorIQ p1020 based board support from Arcturus Networks Inc. http://www.arcturusnetworks.com/products/ucp1020/
Signed-off-by: Michael Durrant mdurrant@arcturusnetworks.com Signed-off-by: Oleksandr G Zhadan oleks@arcturusnetworks.com ---
arch/powerpc/cpu/mpc85xx/Kconfig | 4 + board/Arcturus/ucp1020/Kconfig | 44 ++ board/Arcturus/ucp1020/MAINTAINERS | 7 + board/Arcturus/ucp1020/Makefile | 33 ++ board/Arcturus/ucp1020/README | 54 ++ board/Arcturus/ucp1020/cmd_arc.c | 215 +++++++ board/Arcturus/ucp1020/ddr.c | 161 ++++++ board/Arcturus/ucp1020/law.c | 25 + board/Arcturus/ucp1020/spl.c | 126 ++++ board/Arcturus/ucp1020/spl_minimal.c | 67 +++ board/Arcturus/ucp1020/tlb.c | 101 ++++ board/Arcturus/ucp1020/ucp1020.c | 383 ++++++++++++ configs/UCP1020_SPIFLASH_defconfig | 6 + configs/UCP1020_defconfig | 5 + include/configs/UCP1020.h | 1058 ++++++++++++++++++++++++++++++++++ 15 files changed, 2289 insertions(+) create mode 100644 board/Arcturus/ucp1020/Kconfig create mode 100644 board/Arcturus/ucp1020/MAINTAINERS create mode 100644 board/Arcturus/ucp1020/Makefile create mode 100644 board/Arcturus/ucp1020/README create mode 100644 board/Arcturus/ucp1020/cmd_arc.c create mode 100644 board/Arcturus/ucp1020/ddr.c create mode 100644 board/Arcturus/ucp1020/law.c create mode 100644 board/Arcturus/ucp1020/spl.c create mode 100644 board/Arcturus/ucp1020/spl_minimal.c create mode 100644 board/Arcturus/ucp1020/tlb.c create mode 100644 board/Arcturus/ucp1020/ucp1020.c create mode 100644 configs/UCP1020_SPIFLASH_defconfig create mode 100644 configs/UCP1020_defconfig create mode 100644 include/configs/UCP1020.h
diff --git a/arch/powerpc/cpu/mpc85xx/Kconfig b/arch/powerpc/cpu/mpc85xx/Kconfig index adb5bd3..e481ab4 100644 --- a/arch/powerpc/cpu/mpc85xx/Kconfig +++ b/arch/powerpc/cpu/mpc85xx/Kconfig @@ -153,6 +153,9 @@ config TARGET_XPEDITE537X config TARGET_XPEDITE550X bool "Support xpedite550x"
+config TARGET_UCP1020 + bool "Support uCP1020" + endchoice
source "board/freescale/b4860qds/Kconfig" @@ -194,5 +197,6 @@ source "board/stx/stxssa/Kconfig" source "board/xes/xpedite520x/Kconfig" source "board/xes/xpedite537x/Kconfig" source "board/xes/xpedite550x/Kconfig" +source "board/Arcturus/ucp1020/Kconfig"
endmenu diff --git a/board/Arcturus/ucp1020/Kconfig b/board/Arcturus/ucp1020/Kconfig new file mode 100644 index 0000000..feca03a --- /dev/null +++ b/board/Arcturus/ucp1020/Kconfig @@ -0,0 +1,44 @@ +if TARGET_UCP1020 + +config SYS_BOARD + string + default "ucp1020" + +config SYS_VENDOR + string + default "Arcturus" + +config SYS_CONFIG_NAME + string + default "UCP1020" + +config SPI_FLASH + bool + default y + +config SPI_PCI + bool + default y + +choice + prompt "Target image select" + +config TARGET_UCP1020_NOR + bool "NOR flash u-boot image" + +config TARGET_UCP1020_SPIFLASH + bool "SPI flash u-boot image" + +endchoice + +if TARGET_UCP1020_SPIFLASH +config UCBOOT + bool + default y + +config SPIFLASH + bool + default y +endif + +endif diff --git a/board/Arcturus/ucp1020/MAINTAINERS b/board/Arcturus/ucp1020/MAINTAINERS new file mode 100644 index 0000000..e4a4718 --- /dev/null +++ b/board/Arcturus/ucp1020/MAINTAINERS @@ -0,0 +1,7 @@ +UCP1020 BOARD +M: Oleksandr Zhadan and Michael Durrant arcsupport@arcturusnetworks.com +S: Maintained +F: board/Arcturus/ucp1020/ +F: include/configs/UCP1020.h +F: configs/UCP1020_defconfig +F: configs/UCP1020_SPIFLASH_defconfig diff --git a/board/Arcturus/ucp1020/Makefile b/board/Arcturus/ucp1020/Makefile new file mode 100644 index 0000000..35c88b9 --- /dev/null +++ b/board/Arcturus/ucp1020/Makefile @@ -0,0 +1,33 @@ +# +# Copyright 2013-2015 Arcturus Networks, Inc. +# based on board/freescale/p1_p2_rdb_pc/Makefile +# original copyright follows: +# Copyright 2010-2011 Freescale Semiconductor, Inc. +# +# SPDX-License-Identifier: GPL-2.0+ +# + +MINIMAL= + +ifdef CONFIG_SPL_BUILD +ifdef CONFIG_SPL_INIT_MINIMAL +MINIMAL=y +endif +endif + +ifdef MINIMAL + +obj-y += spl_minimal.o tlb.o law.o + +else +ifdef CONFIG_SPL_BUILD +obj-y += spl.o +endif + +obj-y += ucp1020.o +obj-y += ddr.o +obj-y += law.o +obj-y += tlb.o +obj-y += cmd_arc.o + +endif diff --git a/board/Arcturus/ucp1020/README b/board/Arcturus/ucp1020/README new file mode 100644 index 0000000..555c4ef --- /dev/null +++ b/board/Arcturus/ucp1020/README @@ -0,0 +1,54 @@ +The uCP1020 product family (ucp1020) is an Arcturus Networks Inc. System on Modules +product featuring a Freescale P1020 CPU, optionally populated with 1, 2 or 3 Gig-Ethernet PHYs, +DDR3, NOR Flash, eMMC NAND Flash and/or SPI Flash. + +Information on the generic product family can be found here: + http://www.arcturusnetworks.com/products/ucp1020 + +The UCP1020 several configurable options +======================================== + +- the selection of populated phy(s): + KSZ9031 (current default for eTSEC 1 and 3) + +- the selection of boot location: + SPI Flash or NOR flash + +The UCP1020 includes 2 default configurations +============================================= +NOR boot image: + configs/UCP1020_defconfig +SPI boot image: + configs/UCP1020_SPIFLASH_defconfig + +The UCP1020 adds an additional command in cmd_arc.c to access and program +SPI resident factory defaults for serial number, and 1, 2 or 3 Ethernet +HW Addresses. + + +Build example +============= + +make distclean +make UCP1020_defconfig +make + +Default Scripts +=============== +A default upgrade scripts is included in the default environment variable example: + +B$ run tftpflash + +Dual Environment +================ + +This build enables dual / failover environment environment. + +NOR Flash Partition declarations and scripts +============================================ +Several scripts are available to allow TFTP of images and programming directly +into defined NOR flash partitions. Examples: + +B$ run program0 +B$ run program1 +B$ run program2 diff --git a/board/Arcturus/ucp1020/cmd_arc.c b/board/Arcturus/ucp1020/cmd_arc.c new file mode 100644 index 0000000..bfd91ae --- /dev/null +++ b/board/Arcturus/ucp1020/cmd_arc.c @@ -0,0 +1,215 @@ +/* + * Command for accessing Arcturus factory environment. + * + * Copyright 2013-2015 Arcturus Networks Inc. + * http://www.arcturusnetworks.com/products/ucp1020/ + * by Oleksandr G Zhadan et al. + * + * SPDX-License-Identifier: GPL-2.0+ BSD-3-Clause + * + */ + +#include <common.h> +#include <div64.h> +#include <malloc.h> +#include <spi_flash.h> + +#include <asm/io.h> + +#ifndef CONFIG_SF_DEFAULT_SPEED +# define CONFIG_SF_DEFAULT_SPEED 1000000 +#endif +#ifndef CONFIG_SF_DEFAULT_MODE +# define CONFIG_SF_DEFAULT_MODE SPI_MODE0 +#endif +#ifndef CONFIG_SF_DEFAULT_CS +# define CONFIG_SF_DEFAULT_CS 0 +#endif +#ifndef CONFIG_SF_DEFAULT_BUS +# define CONFIG_SF_DEFAULT_BUS 0 +#endif + +#define MAX_SERIAL_SIZE 15 +#define MAX_HWADDR_SIZE 17 + +static struct spi_flash *flash; +char smac[4][18]; + +static int ishwaddr(char *hwaddr) +{ + if (strlen(hwaddr) == MAX_HWADDR_SIZE) + if (hwaddr[2] == ':' && + hwaddr[5] == ':' && + hwaddr[8] == ':' && + hwaddr[11] == ':' && + hwaddr[14] == ':') + return 0; + return -1; +} + +static int set_arc_product(int argc, char *const argv[]) +{ + int err = 0; + char mystrerr[] = "ERROR: Failed to save factory info in spi locations"; + + if (argc != 5) + return -1; + + /* Check serial number */ + if (strlen(argv[1]) != MAX_SERIAL_SIZE) + return -1; + + /* Check HWaddrs */ + if (ishwaddr(argv[2]) || ishwaddr(argv[3]) || ishwaddr(argv[4])) + return -1; + + strcpy(smac[3], argv[1]); + strcpy(smac[2], argv[2]); + strcpy(smac[1], argv[3]); + strcpy(smac[0], argv[4]); + + flash = spi_flash_probe(CONFIG_ENV_SPI_BUS, CONFIG_ENV_SPI_CS, + CONFIG_ENV_SPI_MAX_HZ, CONFIG_ENV_SPI_MODE); + + /* + * Save factory defaults + */ + if (spi_flash_write(flash, (0x200 - sizeof(smac)), sizeof(smac), smac)) { + printf("%s: %s [1]\n", __func__, mystrerr); + err++; + } + if (spi_flash_write(flash, (0x400 - sizeof(smac)), sizeof(smac), smac)) { + printf("%s: %s [2]\n", __func__, mystrerr); + err++; + } + + if (spi_flash_write(flash, (CONFIG_ENV_SECT_SIZE + 0x200 - sizeof(smac)), sizeof(smac), smac)) { + printf("%s: %s [3]\n", __func__, mystrerr); + err++; + } + + if (spi_flash_write(flash, (CONFIG_ENV_SECT_SIZE + 0x400 - sizeof(smac)), sizeof(smac), smac)) { + printf("%s: %s [4]\n", __func__, mystrerr); + err++; + } + + if (err == 4) { + printf("%s: %s [ALL]\n", __func__, mystrerr); + return -2; + } + + return 0; +} + +int get_arc_info(void) +{ + int location = 1; + + flash = spi_flash_probe(CONFIG_ENV_SPI_BUS, CONFIG_ENV_SPI_CS, + CONFIG_ENV_SPI_MAX_HZ, CONFIG_ENV_SPI_MODE); + + if (spi_flash_read(flash, (0x200 - sizeof(smac)), sizeof(smac), smac)) { + location++; + if (spi_flash_read(flash, (0x400 - sizeof(smac)), sizeof(smac), smac)) { + location++; + if (spi_flash_read(flash, (CONFIG_ENV_SECT_SIZE + 0x200 - sizeof(smac)), sizeof(smac), smac)) { + location++; + if (spi_flash_read(flash, (CONFIG_ENV_SECT_SIZE + 0x400 - sizeof(smac)), sizeof(smac), smac)) { + printf("%s: ERROR: Failed to read all %d factory info spi locations\n", __func__, location); + return -2; + } + } + } + } + if (smac[3][0] != 0) { + if (location > 1) + printf("Using region %d\n", location); + printf("SERIAL: "); + if (smac[3][0] == 0xFF) { + printf("\t<not found>\n"); + } else { + printf("\t%s\n", smac[3]); + setenv("SERIAL", smac[3]); + } + } + if (strcmp(smac[2], "00:00:00:00:00:00") != 0) { + printf("HWADDR0:"); + if (smac[2][0] == 0xFF) { + printf("\t<not found>\n"); + } else { + char *ret = getenv("ethaddr"); + + if (strcmp(ret, __stringify(CONFIG_ETHADDR)) == 0) { + setenv("ethaddr", smac[2]); + printf("\t%s (factory)\n", smac[2]); + } else { + printf("\t%s\n", ret); + } + } + if (strcmp(smac[1], "00:00:00:00:00:00") != 0) { + printf("HWADDR1:"); + if (smac[1][0] == 0xFF) { + printf("\t<not found>\n"); + } else { + char *ret = getenv("eth1addr"); + + if (strcmp(ret, __stringify(CONFIG_ETH1ADDR)) == 0) { + setenv("eth1addr", smac[1]); + printf("\t%s (factory)\n", smac[1]); + } else { + printf("\t%s\n", ret); + } + } + if (strcmp(smac[0], "00:00:00:00:00:00") != 0) { + printf("HWADDR2:"); + if (smac[0][0] == 0xFF) { + printf("\t<not found>\n"); + } else { + char *ret = getenv("eth2addr"); + + if (strcmp(ret, __stringify(CONFIG_ETH2ADDR)) == 0) { + setenv("eth2addr", smac[0]); + printf("\t%s (factory)\n", smac[0]); + } else { + printf("\t%s\n", ret); + } + } + } else { + setenv("eth2addr", smac[1]); + } + } else { + setenv("eth1addr", smac[2]); + setenv("eth2addr", smac[2]); + } + } + return 0; +} + +static int do_arc_cmd(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) +{ + const char *cmd; + int ret = -1; + + cmd = argv[1]; + --argc; + ++argv; + + if (strcmp(cmd, "product") == 0) { + ret = set_arc_product(argc, argv); + goto done; + } + if (strcmp(cmd, "info") == 0) { + ret = get_arc_info(); + goto done; + } +done: + if (ret == -1) + return CMD_RET_USAGE; + + return ret; +} + +U_BOOT_CMD(arc, 6, 1, do_arc_cmd, + "Arcturus product command sub-system", + "product serial hwaddr0 hwaddr1 hwaddr2 - save Arcturus factory env\n" + "info - show Arcturus factory env\n\n"); diff --git a/board/Arcturus/ucp1020/ddr.c b/board/Arcturus/ucp1020/ddr.c new file mode 100644 index 0000000..42fbae0 --- /dev/null +++ b/board/Arcturus/ucp1020/ddr.c @@ -0,0 +1,161 @@ +/* + * Copyright 2013-2015 Arcturus Networks, Inc. + * http://www.arcturusnetworks.com/products/ucp1020/ + * based on board/freescale/p1_p2_rdb_pc/spl.c + * original copyright follows: + * Copyright 2013 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/mmu.h> +#include <asm/immap_85xx.h> +#include <asm/processor.h> +#include <fsl_ddr_sdram.h> +#include <fsl_ddr_dimm_params.h> +#include <asm/io.h> +#include <asm/fsl_law.h> + +#ifdef CONFIG_SYS_DDR_RAW_TIMING +#if defined(CONFIG_UCP1020) || defined(CONFIG_UCP1020T1) +/* + * Micron MT41J128M16HA-15E + * */ +dimm_params_t ddr_raw_timing = { + .n_ranks = 1, + .rank_density = 536870912u, + .capacity = 536870912u, + .primary_sdram_width = 32, + .ec_sdram_width = 8, + .registered_dimm = 0, + .mirrored_dimm = 0, + .n_row_addr = 14, + .n_col_addr = 10, + .n_banks_per_sdram_device = 8, + .edc_config = 2, + .burst_lengths_bitmask = 0x0c, + + .tckmin_x_ps = 1650, + .caslat_x = 0x7e << 4, /* 5,6,7,8,9,10 */ + .taa_ps = 14050, + .twr_ps = 15000, + .trcd_ps = 13500, + .trrd_ps = 75000, + .trp_ps = 13500, + .tras_ps = 40000, + .trc_ps = 49500, + .trfc_ps = 160000, + .twtr_ps = 75000, + .trtp_ps = 75000, + .refresh_rate_ps = 7800000, + .tfaw_ps = 30000, +}; + +#else +#error Missing raw timing data for this board +#endif + +int fsl_ddr_get_dimm_params(dimm_params_t *pdimm, + unsigned int controller_number, + unsigned int dimm_number) +{ + const char dimm_model[] = "Fixed DDR on board"; + + if ((controller_number == 0) && (dimm_number == 0)) { + memcpy(pdimm, &ddr_raw_timing, sizeof(dimm_params_t)); + memset(pdimm->mpart, 0, sizeof(pdimm->mpart)); + memcpy(pdimm->mpart, dimm_model, sizeof(dimm_model) - 1); + } + + return 0; +} +#endif /* CONFIG_SYS_DDR_RAW_TIMING */ + +#ifdef CONFIG_SYS_DDR_CS0_BNDS +/* Fixed sdram init -- doesn't use serial presence detect. */ +phys_size_t fixed_sdram(void) +{ + sys_info_t sysinfo; + char buf[32]; + size_t ddr_size; + fsl_ddr_cfg_regs_t ddr_cfg_regs = { + .cs[0].bnds = CONFIG_SYS_DDR_CS0_BNDS, + .cs[0].config = CONFIG_SYS_DDR_CS0_CONFIG, + .cs[0].config_2 = CONFIG_SYS_DDR_CS0_CONFIG_2, +#if CONFIG_CHIP_SELECTS_PER_CTRL > 1 + .cs[1].bnds = CONFIG_SYS_DDR_CS1_BNDS, + .cs[1].config = CONFIG_SYS_DDR_CS1_CONFIG, + .cs[1].config_2 = CONFIG_SYS_DDR_CS1_CONFIG_2, +#endif + .timing_cfg_3 = CONFIG_SYS_DDR_TIMING_3, + .timing_cfg_0 = CONFIG_SYS_DDR_TIMING_0, + .timing_cfg_1 = CONFIG_SYS_DDR_TIMING_1, + .timing_cfg_2 = CONFIG_SYS_DDR_TIMING_2, + .ddr_sdram_cfg = CONFIG_SYS_DDR_CONTROL, + .ddr_sdram_cfg_2 = CONFIG_SYS_DDR_CONTROL_2, + .ddr_sdram_mode = CONFIG_SYS_DDR_MODE_1, + .ddr_sdram_mode_2 = CONFIG_SYS_DDR_MODE_2, + .ddr_sdram_md_cntl = CONFIG_SYS_DDR_MODE_CONTROL, + .ddr_sdram_interval = CONFIG_SYS_DDR_INTERVAL, + .ddr_data_init = CONFIG_SYS_DDR_DATA_INIT, + .ddr_sdram_clk_cntl = CONFIG_SYS_DDR_CLK_CTRL, + .ddr_init_addr = CONFIG_SYS_DDR_INIT_ADDR, + .ddr_init_ext_addr = CONFIG_SYS_DDR_INIT_EXT_ADDR, + .timing_cfg_4 = CONFIG_SYS_DDR_TIMING_4, + .timing_cfg_5 = CONFIG_SYS_DDR_TIMING_5, + .ddr_zq_cntl = CONFIG_SYS_DDR_ZQ_CONTROL, + .ddr_wrlvl_cntl = CONFIG_SYS_DDR_WRLVL_CONTROL, + .ddr_sr_cntr = CONFIG_SYS_DDR_SR_CNTR, + .ddr_sdram_rcw_1 = CONFIG_SYS_DDR_RCW_1, + .ddr_sdram_rcw_2 = CONFIG_SYS_DDR_RCW_2 + }; + + get_sys_info(&sysinfo); + printf("Configuring DDR for %s MT/s data rate\n", + strmhz(buf, sysinfo.freq_ddrbus)); + + ddr_size = CONFIG_SYS_SDRAM_SIZE * 1024 * 1024; + + fsl_ddr_set_memctl_regs(&ddr_cfg_regs, 0, 0); + + if (set_ddr_laws(CONFIG_SYS_DDR_SDRAM_BASE, + ddr_size, LAW_TRGT_IF_DDR_1) < 0) { + printf("ERROR setting Local Access Windows for DDR\n"); + return 0; + }; + + return ddr_size; +} +#endif + +void fsl_ddr_board_options(memctl_options_t *popts, + dimm_params_t *pdimm, + unsigned int ctrl_num) +{ + int i; + + popts->clk_adjust = 6; + popts->cpo_override = 0x1f; + popts->write_data_delay = 2; + popts->half_strength_driver_enable = 1; + /* Write leveling override */ + popts->wrlvl_en = 1; + popts->wrlvl_override = 1; + popts->wrlvl_sample = 0xf; + popts->wrlvl_start = 0x8; + popts->trwt_override = 1; + popts->trwt = 0; + + if (pdimm->primary_sdram_width == 64) + popts->data_bus_width = 0; + else if (pdimm->primary_sdram_width == 32) + popts->data_bus_width = 1; + else + printf("Error in DDR bus width configuration!\n"); + + for (i = 0; i < CONFIG_CHIP_SELECTS_PER_CTRL; i++) { + popts->cs_local_opts[i].odt_rd_cfg = FSL_DDR_ODT_NEVER; + popts->cs_local_opts[i].odt_wr_cfg = FSL_DDR_ODT_CS; + } +} diff --git a/board/Arcturus/ucp1020/law.c b/board/Arcturus/ucp1020/law.c new file mode 100644 index 0000000..7d40905 --- /dev/null +++ b/board/Arcturus/ucp1020/law.c @@ -0,0 +1,25 @@ +/* + * Copyright 2013-2015 Arcturus Networks, Inc. + * http://www.arcturusnetworks.com/products/ucp1020/ + * based on board/freescale/p1_p2_rdb_pc/spl.c + * original copyright follows: + * Copyright 2013 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/fsl_law.h> +#include <asm/mmu.h> + +struct law_entry law_table[] = { +#ifdef CONFIG_VSC7385_ENET + SET_LAW(CONFIG_SYS_VSC7385_BASE_PHYS, LAW_SIZE_1M, LAW_TRGT_IF_LBC), +#endif + SET_LAW(CONFIG_SYS_FLASH_BASE_PHYS, LAW_SIZE_64M, LAW_TRGT_IF_LBC), +#ifdef CONFIG_SYS_NAND_BASE_PHYS + SET_LAW(CONFIG_SYS_NAND_BASE_PHYS, LAW_SIZE_32K, LAW_TRGT_IF_LBC), +#endif +}; + +int num_law_entries = ARRAY_SIZE(law_table); diff --git a/board/Arcturus/ucp1020/spl.c b/board/Arcturus/ucp1020/spl.c new file mode 100644 index 0000000..236b0d0 --- /dev/null +++ b/board/Arcturus/ucp1020/spl.c @@ -0,0 +1,126 @@ +/* + * Copyright 2013-2015 Arcturus Networks, Inc. + * http://www.arcturusnetworks.com/products/ucp1020/ + * based on board/freescale/p1_p2_rdb_pc/spl.c + * original copyright follows: + * Copyright 2013 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <ns16550.h> +#include <malloc.h> +#include <mmc.h> +#include <nand.h> +#include <i2c.h> +#include <fsl_esdhc.h> +#include <spi_flash.h> + +DECLARE_GLOBAL_DATA_PTR; + +static const u32 sysclk_tbl[] = { + 66666000, 7499900, 83332500, 8999900, + 99999000, 11111000, 12499800, 13333200 +}; + +phys_size_t get_effective_memsize(void) +{ + return CONFIG_SYS_L2_SIZE; +} + +void board_init_f(ulong bootflag) +{ + u32 plat_ratio, bus_clk; + ccsr_gur_t *gur = (void *)CONFIG_SYS_MPC85xx_GUTS_ADDR; + + console_init_f(); + + /* Set pmuxcr to allow both i2c1 and i2c2 */ + setbits_be32(&gur->pmuxcr, in_be32(&gur->pmuxcr) | 0x1000); + setbits_be32(&gur->pmuxcr, + in_be32(&gur->pmuxcr) | MPC85xx_PMUXCR_SD_DATA); + + /* Read back the register to synchronize the write. */ + in_be32(&gur->pmuxcr); + +#ifdef CONFIG_SPL_SPI_BOOT + clrbits_be32(&gur->pmuxcr, MPC85xx_PMUXCR_SD_DATA); +#endif + + /* initialize selected port with appropriate baud rate */ + plat_ratio = in_be32(&gur->porpllsr) & MPC85xx_PORPLLSR_PLAT_RATIO; + plat_ratio >>= 1; + bus_clk = CONFIG_SYS_CLK_FREQ * plat_ratio; + gd->bus_clk = bus_clk; + + NS16550_init((NS16550_t)CONFIG_SYS_NS16550_COM1, + bus_clk / 16 / CONFIG_BAUDRATE); +#ifdef CONFIG_SPL_MMC_BOOT + puts("\nSD boot...\n"); +#elif defined(CONFIG_SPL_SPI_BOOT) + puts("\nSPI Flash boot...\n"); +#endif + + /* copy code to RAM and jump to it - this should not return */ + /* NOTE - code has to be copied out of NAND buffer before + * other blocks can be read. + */ + relocate_code(CONFIG_SPL_RELOC_STACK, 0, CONFIG_SPL_RELOC_TEXT_BASE); +} + +void board_init_r(gd_t *gd, ulong dest_addr) +{ + /* Pointer is writable since we allocated a register for it */ + gd = (gd_t *)CONFIG_SPL_GD_ADDR; + bd_t *bd; + + memset(gd, 0, sizeof(gd_t)); + bd = (bd_t *)(CONFIG_SPL_GD_ADDR + sizeof(gd_t)); + memset(bd, 0, sizeof(bd_t)); + gd->bd = bd; + bd->bi_memstart = CONFIG_SYS_INIT_L2_ADDR; + bd->bi_memsize = CONFIG_SYS_L2_SIZE; + + probecpu(); + get_clocks(); + mem_malloc_init(CONFIG_SPL_RELOC_MALLOC_ADDR, + CONFIG_SPL_RELOC_MALLOC_SIZE); + +#ifndef CONFIG_SPL_NAND_BOOT + env_init(); +#endif +#ifdef CONFIG_SPL_MMC_BOOT + mmc_initialize(bd); +#endif + /* relocate environment function pointers etc. */ +#ifdef CONFIG_SPL_NAND_BOOT + nand_spl_load_image(CONFIG_ENV_OFFSET, CONFIG_ENV_SIZE, + (uchar *)CONFIG_ENV_ADDR); + gd->env_addr = (ulong)(CONFIG_ENV_ADDR); + gd->env_valid = 1; +#else + env_relocate(); +#endif + +#ifdef CONFIG_SYS_I2C + i2c_init_all(); +#else + i2c_init(CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE); +#endif + + gd->ram_size = initdram(0); +#ifdef CONFIG_SPL_NAND_BOOT + puts("Tertiary program loader running in sram..."); +#else + puts("Second program loader running in sram...\n"); +#endif + +#ifdef CONFIG_SPL_MMC_BOOT + mmc_boot(); +#elif defined(CONFIG_SPL_SPI_BOOT) + spi_boot(); +#elif defined(CONFIG_SPL_NAND_BOOT) + nand_boot(); +#endif +} diff --git a/board/Arcturus/ucp1020/spl_minimal.c b/board/Arcturus/ucp1020/spl_minimal.c new file mode 100644 index 0000000..5bdefb8 --- /dev/null +++ b/board/Arcturus/ucp1020/spl_minimal.c @@ -0,0 +1,67 @@ +/* + * Copyright 2013-2015 Arcturus Networks, Inc. + * http://www.arcturusnetworks.com/products/ucp1020/ + * based on board/freescale/p1_p2_rdb_pc/spl_minimal.c + * original copyright follows: + * Copyright 2011 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <ns16550.h> +#include <asm/io.h> +#include <nand.h> +#include <linux/compiler.h> +#include <asm/fsl_law.h> +#include <fsl_ddr_sdram.h> +#include <asm/global_data.h> + +DECLARE_GLOBAL_DATA_PTR; + +void board_init_f(ulong bootflag) +{ + u32 plat_ratio; + ccsr_gur_t *gur = (void *)CONFIG_SYS_MPC85xx_GUTS_ADDR; + +#if defined(CONFIG_SYS_NAND_BR_PRELIM) && defined(CONFIG_SYS_NAND_OR_PRELIM) + set_lbc_br(0, CONFIG_SYS_NAND_BR_PRELIM); + set_lbc_or(0, CONFIG_SYS_NAND_OR_PRELIM); +#endif + + /* initialize selected port with appropriate baud rate */ + plat_ratio = in_be32(&gur->porpllsr) & MPC85xx_PORPLLSR_PLAT_RATIO; + plat_ratio >>= 1; + gd->bus_clk = CONFIG_SYS_CLK_FREQ * plat_ratio; + + NS16550_init((NS16550_t)CONFIG_SYS_NS16550_COM1, + gd->bus_clk / 16 / CONFIG_BAUDRATE); + + puts("\nNAND boot... "); + + /* copy code to RAM and jump to it - this should not return */ + /* NOTE - code has to be copied out of NAND buffer before + * other blocks can be read. + */ + relocate_code(CONFIG_SPL_RELOC_STACK, 0, CONFIG_SPL_RELOC_TEXT_BASE); +} + +void board_init_r(gd_t *gd, ulong dest_addr) +{ + puts("\nSecond program loader running in sram..."); + nand_boot(); +} + +void putc(char c) +{ + if (c == '\n') + NS16550_putc((NS16550_t)CONFIG_SYS_NS16550_COM1, '\r'); + + NS16550_putc((NS16550_t)CONFIG_SYS_NS16550_COM1, c); +} + +void puts(const char *str) +{ + while (*str) + putc(*str++); +} diff --git a/board/Arcturus/ucp1020/tlb.c b/board/Arcturus/ucp1020/tlb.c new file mode 100644 index 0000000..fd7134f --- /dev/null +++ b/board/Arcturus/ucp1020/tlb.c @@ -0,0 +1,101 @@ +/* + * Copyright 2013-2015 Arcturus Networks, Inc + * http://www.arcturusnetworks.com/products/ucp1020/ + * based on board/freescale/p1_p2_rdb_pc/tlb.c + * original copyright follows: + * Copyright 2010-2011 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/mmu.h> + +struct fsl_e_tlb_entry tlb_table[] = { + /* TLB 0 - for temp stack in cache */ + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR, + CONFIG_SYS_INIT_RAM_ADDR_PHYS, + MAS3_SX | MAS3_SW | MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 4 * 1024, + CONFIG_SYS_INIT_RAM_ADDR_PHYS + 4 * 1024, + MAS3_SX | MAS3_SW | MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 8 * 1024, + CONFIG_SYS_INIT_RAM_ADDR_PHYS + 8 * 1024, + MAS3_SX | MAS3_SW | MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 12 * 1024, + CONFIG_SYS_INIT_RAM_ADDR_PHYS + 12 * 1024, + MAS3_SX | MAS3_SW | MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + + /* TLB 1 */ + /* *I*** - Covers boot page */ + SET_TLB_ENTRY(1, 0xfffff000, 0xfffff000, + MAS3_SX | MAS3_SW | MAS3_SR, MAS2_I, + 0, 0, BOOKE_PAGESZ_4K, 1), + + /* *I*G* - CCSRBAR */ + SET_TLB_ENTRY(1, CONFIG_SYS_CCSRBAR, CONFIG_SYS_CCSRBAR_PHYS, + MAS3_SX | MAS3_SW | MAS3_SR, MAS2_I | MAS2_G, + 0, 1, BOOKE_PAGESZ_1M, 1), + +#ifndef CONFIG_SPL_BUILD + /* W**G* - Flash/promjet, localbus */ + /* This will be changed to *I*G* after relocation to RAM. */ + SET_TLB_ENTRY(1, CONFIG_SYS_FLASH_BASE, CONFIG_SYS_FLASH_BASE_PHYS, + MAS3_SX | MAS3_SR, MAS2_W | MAS2_G, + 0, 2, BOOKE_PAGESZ_64M, 1), + +#ifdef CONFIG_PCI + /* *I*G* - PCI memory 1.5G */ + SET_TLB_ENTRY(1, CONFIG_SYS_PCIE1_MEM_VIRT, CONFIG_SYS_PCIE1_MEM_PHYS, + MAS3_SX | MAS3_SW | MAS3_SR, MAS2_I | MAS2_G, + 0, 3, BOOKE_PAGESZ_1G, 1), + + /* *I*G* - PCI I/O effective: 192K */ + SET_TLB_ENTRY(1, CONFIG_SYS_PCIE1_IO_VIRT, CONFIG_SYS_PCIE1_IO_PHYS, + MAS3_SX | MAS3_SW | MAS3_SR, MAS2_I | MAS2_G, + 0, 4, BOOKE_PAGESZ_256K, 1), +#endif + +#ifdef CONFIG_VSC7385_ENET + /* *I*G - VSC7385 Switch */ + SET_TLB_ENTRY(1, CONFIG_SYS_VSC7385_BASE, CONFIG_SYS_VSC7385_BASE_PHYS, + MAS3_SX | MAS3_SW | MAS3_SR, MAS2_I | MAS2_G, + 0, 5, BOOKE_PAGESZ_1M, 1), +#endif +#endif /* not SPL */ + +#ifdef CONFIG_SYS_NAND_BASE + /* *I*G - NAND */ + SET_TLB_ENTRY(1, CONFIG_SYS_NAND_BASE, CONFIG_SYS_NAND_BASE_PHYS, + MAS3_SX | MAS3_SW | MAS3_SR, MAS2_I | MAS2_G, + 0, 7, BOOKE_PAGESZ_1M, 1), +#endif + +#if defined(CONFIG_SYS_RAMBOOT) || \ + (defined(CONFIG_SPL) && !defined(CONFIG_SPL_COMMON_INIT_DDR)) + /* *I*G - eSDHC/eSPI/NAND boot */ + SET_TLB_ENTRY(1, CONFIG_SYS_DDR_SDRAM_BASE, CONFIG_SYS_DDR_SDRAM_BASE, + MAS3_SX | MAS3_SW | MAS3_SR, 0, + 0, 8, BOOKE_PAGESZ_1G, 1), + +#endif /* RAMBOOT/SPL */ + +#ifdef CONFIG_SYS_INIT_L2_ADDR + /* *I*G - L2SRAM */ + SET_TLB_ENTRY(1, CONFIG_SYS_INIT_L2_ADDR, CONFIG_SYS_INIT_L2_ADDR_PHYS, + MAS3_SX | MAS3_SW | MAS3_SR, MAS2_G, + 0, 11, BOOKE_PAGESZ_256K, 1), +#if CONFIG_SYS_L2_SIZE >= (256 << 10) + SET_TLB_ENTRY(1, CONFIG_SYS_INIT_L2_ADDR + 0x40000, + CONFIG_SYS_INIT_L2_ADDR_PHYS + 0x40000, + MAS3_SX | MAS3_SW | MAS3_SR, MAS2_I | MAS2_G, + 0, 12, BOOKE_PAGESZ_256K, 1) +#endif +#endif +}; + +int num_tlb_entries = ARRAY_SIZE(tlb_table); diff --git a/board/Arcturus/ucp1020/ucp1020.c b/board/Arcturus/ucp1020/ucp1020.c new file mode 100644 index 0000000..daba4c7 --- /dev/null +++ b/board/Arcturus/ucp1020/ucp1020.c @@ -0,0 +1,383 @@ +/* + * Copyright 2013-2015 Arcturus Networks, Inc. + * http://www.arcturusnetworks.com/products/ucp1020/ + * by Oleksandr G Zhadan et al. + * based on board/freescale/p1_p2_rdb_pc/spl.c + * original copyright follows: + * Copyright 2013 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <command.h> +#include <hwconfig.h> +#include <pci.h> +#include <i2c.h> +#include <miiphy.h> +#include <libfdt.h> +#include <fdt_support.h> +#include <fsl_mdio.h> +#include <tsec.h> +#include <ioports.h> +#include <netdev.h> +#include <micrel.h> +#include <spi_flash.h> +#include <mmc.h> +#include <linux/ctype.h> +#include <asm/fsl_serdes.h> +#include <asm/gpio.h> +#include <asm/processor.h> +#include <asm/mmu.h> +#include <asm/cache.h> +#include <asm/immap_85xx.h> +#include <asm/fsl_pci.h> +#include <fsl_ddr_sdram.h> +#include <asm/io.h> +#include <asm/fsl_law.h> +#include <asm/fsl_lbc.h> +#include <asm/mp.h> + +#define GPIO0 31 +#define GPIO1 30 +#define GPIO2 29 +#define GPIO3 28 +#define GPIO4 27 +#define GPIO5 26 +#define GPIO6 25 +#define GPIO7 24 +#define GPIO8 23 +#define GPIO9 22 +#define GPIO10 21 +#define GPIO11 20 +#define GPIO12 19 +#define GPIO13 18 +#define GPIO14 17 +#define GPIO15 16 +#define GPIO_MAX_NUM 16 + +#define GPIO_SDHC_CD GPIO8 +#define GPIO_SDHC_WP GPIO9 +#define GPIO_USB_PCTL0 GPIO10 +#define GPIO_PCIE1_EN GPIO11 +#define GPIO_PCIE2_EN GPIO10 +#define GPIO_USB_PCTL1 GPIO11 + +#define GPIO_WD GPIO15 + +int get_arc_info(void); + +void spi_set_speed(struct spi_slave *slave, uint hz) +{ + /* TO DO: It's actially have to be in spi/ */ +} + +/* + * To be compatible with cmd_gpio + */ +int name_to_gpio(const char *name) +{ + int gpio = 31 - simple_strtoul(name, NULL, 10); + + if (gpio < 16) + gpio = -1; + + return gpio; +} + +void board_gpio_init(void) +{ + int i; + char envname[8], *val; + + for (i = 0; i < GPIO_MAX_NUM; i++) { + sprintf(envname, "GPIO%d", i); + val = getenv(envname); + if (val) { + char direction = toupper(val[0]); + char level = toupper(val[1]); + + if (direction == 'I') { + gpio_direction_input(i); + } else { + if (direction == 'O') { + if (level == '1') + gpio_direction_output(i, 1); + else + gpio_direction_output(i, 0); + } + } + } + } + + val = getenv("PCIE_OFF"); + if (val) { + gpio_direction_input(GPIO_PCIE1_EN); + gpio_direction_input(GPIO_PCIE2_EN); + } else { + gpio_direction_output(GPIO_PCIE1_EN, 1); + gpio_direction_output(GPIO_PCIE2_EN, 1); + } + + val = getenv("SDHC_CDWP_OFF"); + if (!val) { + ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + + setbits_be32(&gur->pmuxcr, (MPC85xx_PMUXCR_SDHC_CD | MPC85xx_PMUXCR_SDHC_WP)); + } +} + +int board_early_init_f(void) +{ + return 0; /* Just in case. Could be disable in config file */ +} + +int checkboard(void) +{ + printf("Board: %s\n", CONFIG_BOARDNAME_LOCAL); + board_gpio_init(); + printf("SD/MMC: 4-bit Mode\n"); + + return 0; +} + +#ifdef CONFIG_PCI +void pci_init_board(void) +{ + fsl_pcie_init_board(0); +} +#endif + +int board_early_init_r(void) +{ + const unsigned int flashbase = CONFIG_SYS_FLASH_BASE; + const u8 flash_esel = find_tlb_idx((void *)flashbase, 1); + + /* + * Remap Boot flash region to caching-inhibited + * so that flash can be erased properly. + */ + + /* Flush d-cache and invalidate i-cache of any FLASH data */ + flush_dcache(); + invalidate_icache(); + + /* invalidate existing TLB entry for flash */ + disable_tlb(flash_esel); + + set_tlb(1, flashbase, CONFIG_SYS_FLASH_BASE_PHYS, /* tlb, epn, rpn */ + MAS3_SX | MAS3_SW | MAS3_SR, MAS2_I | MAS2_G, /* perms, wimge */ + 0, flash_esel, BOOKE_PAGESZ_64M, 1); /* ts, esel, tsize, iprot */ + + return 0; +} + +int board_phy_config(struct phy_device *phydev) +{ +#if defined(CONFIG_PHY_MICREL_KSZ9021) + int regval; + static int cnt; + + if (cnt++ == 0) + printf("PHYs address ["); + + if (phydev->addr == TSEC1_PHY_ADDR || phydev->addr == TSEC3_PHY_ADDR) { + regval = ksz9021_phy_extended_read(phydev, MII_KSZ9021_EXT_STRAP_STATUS); + /* + * min rx data delay + */ + ksz9021_phy_extended_write(phydev, MII_KSZ9021_EXT_RGMII_RX_DATA_SKEW, 0x6666); + /* + * max rx/tx clock delay, min rx/tx control + */ + ksz9021_phy_extended_write(phydev, MII_KSZ9021_EXT_RGMII_CLOCK_SKEW, 0xf6f6); + printf("0x%x", (regval & 0x1f)); + } else { + printf("0x%x", (TSEC2_PHY_ADDR & 0x1f)); + } + if (cnt == 3) + printf("] "); + else + printf(","); +#endif + +#if defined(CONFIG_PHY_MICREL_KSZ9031_DEBUG) + regval = ksz9031_phy_extended_read(phydev, 2, 0x01, 0x4000); + if (regval >= 0) + printf(" (ADDR 0x%x) ", regval & 0x1f); +#endif + + return 0; +} + +int last_stage_init(void) +{ + static char newkernelargs[256]; + static u8 id1[16]; + static u8 id2; + struct mmc *mmc; + char *sval, *kval; + + if (i2c_read(CONFIG_SYS_I2C_IDT6V49205B, 7, 1, &id1[0], 2) < 0) { + printf("Error reading i2c IDT6V49205B information!\n"); + } else { + printf("IDT6V49205B(0x%02x): ready\n", id1[1]); + i2c_read(CONFIG_SYS_I2C_IDT6V49205B, 4, 1, &id1[0], 2); + if (!(id1[1] & 0x02)) { + id1[1] |= 0x02; + i2c_write(CONFIG_SYS_I2C_IDT6V49205B, 4, 1, &id1[0], 2); + asm("nop; nop"); + } + } + + if (i2c_read(CONFIG_SYS_I2C_NCT72_ADDR, 0xFE, 1, &id2, 1) < 0) + printf("Error reading i2c NCT72 information!\n"); + else + printf("NCT72(0x%x): ready\n", id2); + + kval = getenv("kernelargs"); + + mmc = find_mmc_device(0); + if (mmc) + if (!mmc_init(mmc)) { + printf("MMC/SD card detected\n"); + if (kval) { + char *tmp = strstr(kval, "root=/dev/mtdblock1 rootfstype=cramfs ro"); + int n = strlen("root=/dev/mtdblock1 rootfstype=cramfs ro"); + + *tmp = 0; + strcpy(newkernelargs, kval); + strcat(newkernelargs, " root=/dev/mmcblk0p1 rootwait rw "); + strcat(newkernelargs, &tmp[n]); + setenv("kernelargs", newkernelargs); + } else { + setenv("kernelargs", "root=/dev/mmcblk0p1 rootwait rw"); + } + } + get_arc_info(); + + if (kval) { + sval = getenv("SERIAL"); + if (sval) { + strcpy(newkernelargs, "SN="); + strcat(newkernelargs, sval); + strcat(newkernelargs, " "); + strcat(newkernelargs, kval); + setenv("kernelargs", newkernelargs); + } + } else { + printf("Error reading kernelargs env variable!\n"); + } + + return 0; +} + +int board_eth_init(bd_t *bis) +{ + struct fsl_pq_mdio_info mdio_info; + struct tsec_info_struct tsec_info[4]; +#ifdef CONFIG_TSEC2 + ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); +#endif + int num = 0; + +#ifdef CONFIG_TSEC1 + SET_STD_TSEC_INFO(tsec_info[num], 1); + num++; +#endif +#ifdef CONFIG_TSEC2 + SET_STD_TSEC_INFO(tsec_info[num], 2); + if (is_serdes_configured(SGMII_TSEC2)) { + if ((in_be32(&gur->pordevsr) & MPC85xx_PORDEVSR_SGMII2_DIS) == 0) { + puts("eTSEC2 is in sgmii mode.\n"); + tsec_info[num].flags |= TSEC_SGMII; + tsec_info[num].phyaddr = TSEC2_PHY_ADDR_SGMII; + } + } + num++; +#endif +#ifdef CONFIG_TSEC3 + SET_STD_TSEC_INFO(tsec_info[num], 3); + num++; +#endif + + if (!num) { + printf("No TSECs initialized\n"); + return 0; + } + + mdio_info.regs = (struct tsec_mii_mng *)CONFIG_SYS_MDIO_BASE_ADDR; + mdio_info.name = DEFAULT_MII_NAME; + + fsl_pq_mdio_init(bis, &mdio_info); + + tsec_eth_init(bis, tsec_info, num); + + return pci_eth_init(bis); +} + +#ifdef CONFIG_OF_BOARD_SETUP +int ft_board_setup(void *blob, bd_t *bd) +{ + phys_addr_t base; + phys_size_t size; + const char *soc_usb_compat = "fsl-usb2-dr"; + int err, usb1_off, usb2_off; + + ft_cpu_setup(blob, bd); + + base = getenv_bootm_low(); + size = getenv_bootm_size(); + + fdt_fixup_memory(blob, (u64)base, (u64)size); + + FT_FSL_PCI_SETUP; + +#if defined(CONFIG_HAS_FSL_DR_USB) + fdt_fixup_dr_usb(blob, bd); +#endif + +#if defined(CONFIG_SDCARD) || defined(CONFIG_SPIFLASH) + /* Delete eLBC node as it is muxed with USB2 controller */ + if (hwconfig("usb2")) { + const char *soc_elbc_compat = "fsl,p1020-elbc"; + int off = fdt_node_offset_by_compatible(blob, -1, + soc_elbc_compat); + if (off < 0) { + printf("WARNING: could not find compatible node %s: %s.\n", + soc_elbc_compat, + fdt_strerror(off)); + return off; + } + err = fdt_del_node(blob, off); + if (err < 0) { + printf("WARNING: could not remove %s: %s.\n", + soc_elbc_compat, fdt_strerror(err)); + } + return err; + } +#endif + +/* Delete USB2 node as it is muxed with eLBC */ + usb1_off = fdt_node_offset_by_compatible(blob, -1, soc_usb_compat); + if (usb1_off < 0) { + printf("WARNING: could not find compatible node %s: %s.\n", + soc_usb_compat, + fdt_strerror(usb1_off)); + return usb1_off; + } + usb2_off = fdt_node_offset_by_compatible(blob, usb1_off, soc_usb_compat); + if (usb2_off < 0) { + printf("WARNING: could not find compatible node %s: %s.\n", + soc_usb_compat, + fdt_strerror(usb2_off)); + return usb2_off; + } + err = fdt_del_node(blob, usb2_off); + if (err < 0) { + printf("WARNING: could not remove %s: %s.\n", + soc_usb_compat, fdt_strerror(err)); + } + return 0; +} +#endif diff --git a/configs/UCP1020_SPIFLASH_defconfig b/configs/UCP1020_SPIFLASH_defconfig new file mode 100644 index 0000000..2ffb8da --- /dev/null +++ b/configs/UCP1020_SPIFLASH_defconfig @@ -0,0 +1,6 @@ +CONFIG_PPC=y +CONFIG_MPC85xx=y +CONFIG_TARGET_UCP1020=y +CONFIG_TARGET_UCP1020_SPIFLASH=y +CONFIG_SPI_FLASH=y +CONFIG_UCP1020=y diff --git a/configs/UCP1020_defconfig b/configs/UCP1020_defconfig new file mode 100644 index 0000000..61de360 --- /dev/null +++ b/configs/UCP1020_defconfig @@ -0,0 +1,5 @@ +CONFIG_PPC=y +CONFIG_MPC85xx=y +CONFIG_TARGET_UCP1020=y +CONFIG_SPI_FLASH=y +CONFIG_UCP1020=y diff --git a/include/configs/UCP1020.h b/include/configs/UCP1020.h new file mode 100644 index 0000000..2bbd4ae --- /dev/null +++ b/include/configs/UCP1020.h @@ -0,0 +1,1058 @@ +/* + * Copyright 2013-2015 Arcturus Networks, Inc. + * http://www.arcturusnetworks.com/products/ucp1020/ + * based on include/configs/p1_p2_rdb_pc.h + * original copyright follows: + * Copyright 2009-2011 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/* + * QorIQ uCP1020-xx boards configuration file + */ +#ifndef __CONFIG_H +#define __CONFIG_H + +#define CONFIG_SYS_GENERIC_BOARD +#define CONFIG_DISPLAY_BOARDINFO + +#define CONFIG_FSL_ELBC +#define CONFIG_PCI +#define CONFIG_PCIE1 /* PCIE controller 1 (slot 1) */ +#define CONFIG_PCIE2 /* PCIE controller 2 (slot 2) */ +#define CONFIG_FSL_PCI_INIT /* Use common FSL init code */ +#define CONFIG_PCI_INDIRECT_BRIDGE /* indirect PCI bridge support */ +#define CONFIG_FSL_PCIE_RESET /* need PCIe reset errata */ +#define CONFIG_SYS_PCI_64BIT /* enable 64-bit PCI resources */ + +#if defined(CONFIG_TARTGET_UCP1020T1) + +#define CONFIG_UCP1020_REV_1_3 + +#define CONFIG_BOARDNAME "uCP1020-64EE512-0U1-XR-T1" +#define CONFIG_P1020 + +#define CONFIG_TSEC_ENET +#define CONFIG_TSEC1 +#define CONFIG_TSEC3 +#define CONFIG_HAS_ETH0 +#define CONFIG_HAS_ETH1 +#define CONFIG_ETHADDR 00:19:D3:FF:FF:FF +#define CONFIG_ETH1ADDR 00:19:D3:FF:FF:FE +#define CONFIG_ETH2ADDR 00:19:D3:FF:FF:FD +#define CONFIG_IPADDR 10.80.41.229 +#define CONFIG_SERVERIP 10.80.41.227 +#define CONFIG_NETMASK 255.255.252.0 +#define CONFIG_ETHPRIME "eTSEC3" + +#ifndef CONFIG_SPI_FLASH +#define CONFIG_SPI_FLASH y +#endif +#define CONFIG_SYS_REDUNDAND_ENVIRONMENT + +#define CONFIG_MMC +#define CONFIG_SYS_L2_SIZE (256 << 10) +#define CONFIG_ENV_FIT_UCBOOT_TODO + +#define CONFIG_LAST_STAGE_INIT + +#if !defined(CONFIG_DONGLE) +#define CONFIG_SILENT_CONSOLE +#endif + +#endif + +#if defined(CONFIG_TARGET_UCP1020) + +#define CONFIG_UCP1020 +#define CONFIG_UCP1020_REV_1_3 + +#define CONFIG_BOARDNAME_LOCAL "uCP1020-64EEE512-OU1-XR" +#define CONFIG_P1020 + +#define CONFIG_TSEC_ENET +#define CONFIG_TSEC1 +#define CONFIG_TSEC2 +#define CONFIG_TSEC3 +#define CONFIG_HAS_ETH0 +#define CONFIG_HAS_ETH1 +#define CONFIG_HAS_ETH2 +#define CONFIG_ETHADDR 00:06:3B:FF:FF:FF +#define CONFIG_ETH1ADDR 00:06:3B:FF:FF:FE +#define CONFIG_ETH2ADDR 00:06:3B:FF:FF:FD +#define CONFIG_IPADDR 192.168.1.81 +#define CONFIG_IPADDR1 192.168.1.82 +#define CONFIG_IPADDR2 192.168.1.83 +#define CONFIG_SERVERIP 192.168.1.80 +#define CONFIG_GATEWAYIP 102.168.1.1 +#define CONFIG_NETMASK 255.255.255.0 +#define CONFIG_ETHPRIME "eTSEC1" + +#ifndef CONFIG_SPI_FLASH +#define CONFIG_SPI_FLASH y +#endif +#define CONFIG_SYS_REDUNDAND_ENVIRONMENT + +#define CONFIG_MMC +#define CONFIG_SYS_L2_SIZE (256 << 10) +#define CONFIG_ENV_FIT_UCBOOT_TODO + +#define CONFIG_LAST_STAGE_INIT + +#endif + +#if defined(CONFIG_TARGET_UCP2020) +#define CONFIG_BOARDNAME "uCP2020-A" +#define CONFIG_NAND_FSL_ELBC +#define CONFIG_P2020 + +#define CONFIG_TSEC_ENET +#define CONFIG_TSEC1 +#define CONFIG_TSEC2 +#define CONFIG_TSEC3 + +#define CONFIG_SPI_FLASH +#define CONFIG_SYS_REDUNDAND_ENVIRONMENT + +#define CONFIG_VSC7385_ENET +#define __SW_BOOT_MASK 0x03 +#define __SW_BOOT_NOR 0xc8 +#define __SW_BOOT_SPI 0x28 +#define __SW_BOOT_SD 0x68 /* or 0x18 */ +#define __SW_BOOT_NAND 0xe8 +#define __SW_BOOT_PCIE 0xa8 +#define CONFIG_SYS_L2_SIZE (512 << 10) +#define CONFIG_ENV_FIT_UCBOOT_TODO +#endif + +#if CONFIG_SYS_L2_SIZE >= (512 << 10) +/* must be 32-bit */ +#define CONFIG_SYS_INIT_L2_ADDR 0xf8f80000 +#define CONFIG_SYS_INIT_L2_ADDR_PHYS CONFIG_SYS_INIT_L2_ADDR +#define CONFIG_SYS_INIT_L2_END (CONFIG_SYS_INIT_L2_ADDR + CONFIG_SYS_L2_SIZE) +#endif + +#ifdef CONFIG_SDCARD +#define CONFIG_RAMBOOT_SDCARD +#define CONFIG_SYS_RAMBOOT +#define CONFIG_SYS_EXTRA_ENV_RELOC +#define CONFIG_SYS_TEXT_BASE 0x11000000 +#define CONFIG_RESET_VECTOR_ADDRESS 0x1107fffc +#endif + +#ifdef CONFIG_SPIFLASH +#define CONFIG_RAMBOOT_SPIFLASH +#define CONFIG_SYS_RAMBOOT +#define CONFIG_SYS_EXTRA_ENV_RELOC +#define CONFIG_SYS_TEXT_BASE 0x11000000 +#define CONFIG_RESET_VECTOR_ADDRESS 0x1107fffc +#endif + +#ifndef CONFIG_SYS_TEXT_BASE +#define CONFIG_SYS_TEXT_BASE 0xeff80000 +#endif +#define CONFIG_SYS_TEXT_BASE_NOR 0xeff80000 + +#ifndef CONFIG_RESET_VECTOR_ADDRESS +#define CONFIG_RESET_VECTOR_ADDRESS 0xeffffffc +#endif + +#ifndef CONFIG_SYS_MONITOR_BASE +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE /* start of monitor */ +#endif + +/* High Level Configuration Options */ +#define CONFIG_BOOKE +#define CONFIG_E500 +/* #define CONFIG_MPC85xx */ + +#define CONFIG_MP + +#define CONFIG_FSL_LAW + +#define CONFIG_ENV_OVERWRITE + +#define CONFIG_CMD_SATA +#define CONFIG_SATA_SIL +#define CONFIG_SYS_SATA_MAX_DEVICE 2 +#define CONFIG_LIBATA +#define CONFIG_LBA48 + +#if defined(CONFIG_UCP2020) +#define CONFIG_SYS_CLK_FREQ 100000000 +#else +#define CONFIG_SYS_CLK_FREQ 66666666 +#endif +#define CONFIG_DDR_CLK_FREQ 66666666 + +#define CONFIG_HWCONFIG + +#define CONFIG_DTT_ADM1021 1 /* ADM1021 temp sensor support */ +#define CONFIG_SYS_DTT_BUS_NUM 1 /* The I2C bus for DTT */ +#define CONFIG_DTT_SENSORS { 0, 1 } /* Sensor index */ +/* + * ADM1021/NCT72 temp sensor configuration (see dtt/adm1021.c for details). + * there will be one entry in this array for each two (dummy) sensors in + * CONFIG_DTT_SENSORS. + * + * For uCP1020 module: + * - only one ADM1021/NCT72 + * - i2c addr 0x41 + * - conversion rate 0x02 = 0.25 conversions/second + * - ALERT output disabled + * - local temp sensor enabled, min set to 0 deg, max set to 85 deg + * - remote temp sensor enabled, min set to 0 deg, max set to 85 deg + */ +#define CONFIG_SYS_DTT_ADM1021 { { CONFIG_SYS_I2C_NCT72_ADDR, 0x02, 0, 1, 0, 85, 1, 0, 85} } + +#define CONFIG_CMD_DTT + +/* + * These can be toggled for performance analysis, otherwise use default. + */ +#define CONFIG_L2_CACHE +#define CONFIG_BTB + +#define CONFIG_BOARD_EARLY_INIT_F /* Call board_pre_init */ + +#define CONFIG_ENABLE_36BIT_PHYS + +#define CONFIG_SYS_MEMTEST_START 0x00200000 /* memtest works on */ +#define CONFIG_SYS_MEMTEST_END 0x1fffffff +#define CONFIG_PANIC_HANG /* do not reset board on panic */ + +#define CONFIG_SYS_CCSRBAR 0xffe00000 +#define CONFIG_SYS_CCSRBAR_PHYS_LOW CONFIG_SYS_CCSRBAR + +/* IN case of NAND bootloader relocate CCSRBAR in RAMboot code not in the 4k + SPL code*/ +#ifdef CONFIG_SPL_BUILD +#define CONFIG_SYS_CCSR_DO_NOT_RELOCATE +#endif + +/* DDR Setup */ +#define CONFIG_DDR_ECC_ENABLE +#define CONFIG_SYS_FSL_DDR3 +#ifndef CONFIG_DDR_ECC_ENABLE +#define CONFIG_SYS_DDR_RAW_TIMING +#define CONFIG_DDR_SPD +#endif +#define CONFIG_SYS_SPD_BUS_NUM 1 +#undef CONFIG_FSL_DDR_INTERACTIVE + +#define CONFIG_SYS_SDRAM_SIZE_LAW LAW_SIZE_512M +#define CONFIG_CHIP_SELECTS_PER_CTRL 1 +#define CONFIG_SYS_SDRAM_SIZE (1u << (CONFIG_SYS_SDRAM_SIZE_LAW - 19)) +#define CONFIG_SYS_DDR_SDRAM_BASE 0x00000000 +#define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_DDR_SDRAM_BASE + +#define CONFIG_NUM_DDR_CONTROLLERS 1 +#define CONFIG_DIMM_SLOTS_PER_CTLR 1 + +/* Default settings for DDR3 */ +#ifndef CONFIG_UCP2020 +#define CONFIG_SYS_DDR_CS0_BNDS 0x0000003f +#define CONFIG_SYS_DDR_CS0_CONFIG 0x80014302 +#define CONFIG_SYS_DDR_CS0_CONFIG_2 0x00000000 +#define CONFIG_SYS_DDR_CS1_BNDS 0x0040007f +#define CONFIG_SYS_DDR_CS1_CONFIG 0x80014302 +#define CONFIG_SYS_DDR_CS1_CONFIG_2 0x00000000 + +#define CONFIG_SYS_DDR_DATA_INIT 0xdeadbeef +#define CONFIG_SYS_DDR_INIT_ADDR 0x00000000 +#define CONFIG_SYS_DDR_INIT_EXT_ADDR 0x00000000 +#define CONFIG_SYS_DDR_MODE_CONTROL 0x00000000 + +#define CONFIG_SYS_DDR_ZQ_CONTROL 0x89080600 +#define CONFIG_SYS_DDR_WRLVL_CONTROL 0x8655A608 +#define CONFIG_SYS_DDR_SR_CNTR 0x00000000 +#define CONFIG_SYS_DDR_RCW_1 0x00000000 +#define CONFIG_SYS_DDR_RCW_2 0x00000000 +#ifdef CONFIG_DDR_ECC_ENABLE +#define CONFIG_SYS_DDR_CONTROL 0xE70C0000 /* Type = DDR3 & ECC */ +#else +#define CONFIG_SYS_DDR_CONTROL 0xC70C0000 /* Type = DDR3 */ +#endif +#define CONFIG_SYS_DDR_CONTROL_2 0x04401050 +#define CONFIG_SYS_DDR_TIMING_4 0x00220001 +#define CONFIG_SYS_DDR_TIMING_5 0x03402400 + +#define CONFIG_SYS_DDR_TIMING_3 0x00020000 +#define CONFIG_SYS_DDR_TIMING_0 0x00330004 +#define CONFIG_SYS_DDR_TIMING_1 0x6f6B4846 +#define CONFIG_SYS_DDR_TIMING_2 0x0FA8C8CF +#define CONFIG_SYS_DDR_CLK_CTRL 0x03000000 +#define CONFIG_SYS_DDR_MODE_1 0x40461520 +#define CONFIG_SYS_DDR_MODE_2 0x8000c000 +#define CONFIG_SYS_DDR_INTERVAL 0x0C300000 +#endif + +#undef CONFIG_CLOCKS_IN_MHZ + +/* + * Memory map + * + * 0x0000_0000 0x7fff_ffff DDR Up to 2GB cacheable + * 0x8000_0000 0xdfff_ffff PCI Express Mem 1.5G non-cacheable(PCIe * 3) + * 0xec00_0000 0xefff_ffff NOR flash Up to 64M non-cacheable CS0/1 + * 0xf8f8_0000 0xf8ff_ffff L2 SRAM Up to 512K cacheable + * (early boot only) + * 0xffc0_0000 0xffc3_ffff PCI IO range 256k non-cacheable + * 0xffd0_0000 0xffd0_3fff L1 for stack 16K cacheable + * 0xffe0_0000 0xffef_ffff CCSR 1M non-cacheable + */ + +/* + * Local Bus Definitions + */ +#define CONFIG_SYS_MAX_FLASH_SECT 512 /* 64M */ +#define CONFIG_SYS_FLASH_BASE 0xec000000 + +#define CONFIG_SYS_FLASH_BASE_PHYS CONFIG_SYS_FLASH_BASE + +#define CONFIG_FLASH_BR_PRELIM (BR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS) \ + | BR_PS_16 | BR_V) + +#define CONFIG_FLASH_OR_PRELIM 0xfc000ff7 + +#define CONFIG_SYS_FLASH_BANKS_LIST {CONFIG_SYS_FLASH_BASE_PHYS} +#define CONFIG_SYS_FLASH_QUIET_TEST +#define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */ + +#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ + +#undef CONFIG_SYS_FLASH_CHECKSUM +#define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ +#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */ + +#define CONFIG_FLASH_CFI_DRIVER +#define CONFIG_SYS_FLASH_CFI +#define CONFIG_SYS_FLASH_EMPTY_INFO +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE + +#define CONFIG_BOARD_EARLY_INIT_R /* call board_early_init_r function */ + +#define CONFIG_SYS_INIT_RAM_LOCK +#define CONFIG_SYS_INIT_RAM_ADDR 0xffd00000 /* stack in RAM */ +/* Initial L1 address */ +#define CONFIG_SYS_INIT_RAM_ADDR_PHYS CONFIG_SYS_INIT_RAM_ADDR +#define CONFIG_SYS_INIT_RAM_ADDR_PHYS_HIGH 0 +#define CONFIG_SYS_INIT_RAM_ADDR_PHYS_LOW CONFIG_SYS_INIT_RAM_ADDR_PHYS +/* Size of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x00004000 + +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - \ + GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET + +#define CONFIG_SYS_MONITOR_LEN (256 * 1024)/* Reserve 256 kB for Mon */ +#define CONFIG_SYS_MALLOC_LEN (1024 * 1024)/* Reserved for malloc */ + +#define CONFIG_SYS_PMC_BASE 0xff980000 +#define CONFIG_SYS_PMC_BASE_PHYS CONFIG_SYS_PMC_BASE +#define CONFIG_PMC_BR_PRELIM (BR_PHYS_ADDR(CONFIG_SYS_PMC_BASE_PHYS) | \ + BR_PS_8 | BR_V) +#define CONFIG_PMC_OR_PRELIM (OR_AM_64KB | OR_GPCM_CSNT | OR_GPCM_XACS | \ + OR_GPCM_SCY | OR_GPCM_TRLX | OR_GPCM_EHTR | \ + OR_GPCM_EAD) + +#define CONFIG_SYS_BR0_PRELIM CONFIG_FLASH_BR_PRELIM /* NOR Base Address */ +#define CONFIG_SYS_OR0_PRELIM CONFIG_FLASH_OR_PRELIM /* NOR Options */ +#ifdef CONFIG_NAND_FSL_ELBC +#define CONFIG_SYS_BR1_PRELIM CONFIG_SYS_NAND_BR_PRELIM /* NAND Base Addr */ +#define CONFIG_SYS_OR1_PRELIM CONFIG_SYS_NAND_OR_PRELIM /* NAND Options */ +#endif + +/* Serial Port - controlled on board with jumper J8 + * open - index 2 + * shorted - index 1 + */ +#define CONFIG_CONS_INDEX 1 +#undef CONFIG_SERIAL_SOFTWARE_FIFO +#define CONFIG_SYS_NS16550 +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE 1 +#define CONFIG_SYS_NS16550_CLK get_bus_freq(0) +#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_INIT_MINIMAL) +#define CONFIG_NS16550_MIN_FUNCTIONS +#endif + +#define CONFIG_SYS_BAUDRATE_TABLE \ + {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 57600, 115200} + +#define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_CCSRBAR + 0x4500) +#define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_CCSRBAR + 0x4600) + +/* Use the HUSH parser */ +#define CONFIG_SYS_HUSH_PARSER + +/* + * Pass open firmware flat tree + */ +#define CONFIG_OF_LIBFDT +#define CONFIG_OF_BOARD_SETUP +#define CONFIG_OF_STDOUT_VIA_ALIAS + +/* new uImage format support */ +#define CONFIG_FIT +#define CONFIG_FIT_VERBOSE /* enable fit_format_{error,warning}() */ + +/* I2C */ +#define CONFIG_SYS_I2C +#define CONFIG_SYS_I2C_FSL +#define CONFIG_SYS_FSL_I2C_SPEED 400000 +#define CONFIG_SYS_FSL_I2C_SLAVE 0x7F +#define CONFIG_SYS_FSL_I2C_OFFSET 0x3000 +#define CONFIG_SYS_FSL_I2C2_SPEED 400000 +#define CONFIG_SYS_FSL_I2C2_SLAVE 0x7F +#define CONFIG_SYS_FSL_I2C2_OFFSET 0x3100 +#define CONFIG_SYS_I2C_NOPROBES { {0, 0x29} } +#define CONFIG_SYS_SPD_BUS_NUM 1 /* For rom_loc and flash bank */ + +#define CONFIG_RTC_DS1337 +#define CONFIG_SYS_RTC_DS1337_NOOSC +#define CONFIG_SYS_I2C_RTC_ADDR 0x68 +#define CONFIG_SYS_I2C_PCA9557_ADDR 0x18 +#define CONFIG_SYS_I2C_NCT72_ADDR 0x4C +#define CONFIG_SYS_I2C_IDT6V49205B 0x69 + +/* + * eSPI - Enhanced SPI + */ +#define CONFIG_HARD_SPI +#define CONFIG_FSL_ESPI + +#define CONFIG_SPI_FLASH_SST 1 +#define CONFIG_SPI_FLASH_STMICRO 1 +#define CONFIG_SPI_FLASH_WINBOND 1 +#define CONFIG_CMD_SF 1 +#define CONFIG_CMD_SPI 1 +#define CONFIG_SF_DEFAULT_SPEED 10000000 +#define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 + +#if defined(CONFIG_PCI) +/* + * General PCI + * Memory space is mapped 1-1, but I/O space must start from 0. + */ + +/* controller 2, direct to uli, tgtid 2, Base address 9000 */ +#define CONFIG_SYS_PCIE2_NAME "PCIe SLOT CON9" +#define CONFIG_SYS_PCIE2_MEM_VIRT 0xa0000000 +#define CONFIG_SYS_PCIE2_MEM_BUS 0xa0000000 +#define CONFIG_SYS_PCIE2_MEM_PHYS 0xa0000000 +#define CONFIG_SYS_PCIE2_MEM_SIZE 0x20000000 /* 512M */ +#define CONFIG_SYS_PCIE2_IO_VIRT 0xffc10000 +#define CONFIG_SYS_PCIE2_IO_BUS 0x00000000 +#define CONFIG_SYS_PCIE2_IO_PHYS 0xffc10000 +#define CONFIG_SYS_PCIE2_IO_SIZE 0x00010000 /* 64k */ + +/* controller 1, Slot 2, tgtid 1, Base address a000 */ +#define CONFIG_SYS_PCIE1_NAME "PCIe SLOT CON10" +#define CONFIG_SYS_PCIE1_MEM_VIRT 0x80000000 +#define CONFIG_SYS_PCIE1_MEM_BUS 0x80000000 +#define CONFIG_SYS_PCIE1_MEM_PHYS 0x80000000 +#define CONFIG_SYS_PCIE1_MEM_SIZE 0x20000000 /* 512M */ +#define CONFIG_SYS_PCIE1_IO_VIRT 0xffc00000 +#define CONFIG_SYS_PCIE1_IO_BUS 0x00000000 +#define CONFIG_SYS_PCIE1_IO_PHYS 0xffc00000 +#define CONFIG_SYS_PCIE1_IO_SIZE 0x00010000 /* 64k */ + +#define CONFIG_PCI_PNP /* do pci plug-and-play */ +#define CONFIG_E1000 /* Defind e1000 pci Ethernet card*/ +#define CONFIG_CMD_PCI +#define CONFIG_CMD_NET + +#define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ +#define CONFIG_DOS_PARTITION +#endif /* CONFIG_PCI */ + +/* + * Environment + */ +#ifdef CONFIG_ENV_FIT_UCBOOT + +#define CONFIG_ENV_IS_IN_FLASH +#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x20000) +#define CONFIG_ENV_SIZE 0x20000 +#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ + +#else + +#define CONFIG_ENV_SPI_BUS 0 +#define CONFIG_ENV_SPI_CS 0 +#define CONFIG_ENV_SPI_MAX_HZ 10000000 +#define CONFIG_ENV_SPI_MODE 0 + +#ifdef CONFIG_RAMBOOT_SPIFLASH + +#define CONFIG_ENV_IS_IN_SPI_FLASH +#define CONFIG_ENV_SIZE 0x3000 /* 12KB */ +#define CONFIG_ENV_OFFSET 0x2000 /* 8KB */ +#define CONFIG_ENV_SECT_SIZE 0x1000 + +#if defined(CONFIG_SYS_REDUNDAND_ENVIRONMENT) +/* Address and size of Redundant Environment Sector */ +#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE) +#define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE +#endif + +#elif defined(CONFIG_RAMBOOT_SDCARD) +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_FSL_FIXED_MMC_LOCATION +#define CONFIG_ENV_SIZE 0x2000 +#define CONFIG_SYS_MMC_ENV_DEV 0 + +#elif defined(CONFIG_SYS_RAMBOOT) +#define CONFIG_ENV_IS_NOWHERE /* Store ENV in memory only */ +#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) +#define CONFIG_ENV_SIZE 0x2000 + +#else +#define CONFIG_ENV_IS_IN_FLASH +#define CONFIG_ENV_BASE (CONFIG_SYS_FLASH_BASE) +#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ +#define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE +#define CONFIG_ENV_ADDR (CONFIG_ENV_BASE + 0xC0000) +#if defined(CONFIG_SYS_REDUNDAND_ENVIRONMENT) +/* Address and size of Redundant Environment Sector */ +#define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR + CONFIG_ENV_SIZE) +#define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE +#endif + +#endif + +#endif /* CONFIG_ENV_FIT_UCBOOT */ + +#define CONFIG_LOADS_ECHO /* echo on for serial download */ +#define CONFIG_SYS_LOADS_BAUD_CHANGE /* allow baudrate change */ + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_IRQ +#define CONFIG_CMD_PING +#define CONFIG_CMD_I2C +#define CONFIG_CMD_MII +#define CONFIG_CMD_DATE +#define CONFIG_CMD_ELF +#define CONFIG_CMD_I2C +#define CONFIG_CMD_IRQ +#define CONFIG_CMD_MII +#define CONFIG_CMD_PING +#define CONFIG_CMD_SETEXPR +#define CONFIG_CMD_REGINFO +#define CONFIG_CMD_ERRATA +#define CONFIG_CMD_CRAMFS +#define CONFIG_CRAMFS_CMDLINE + +/* + * USB + */ +#define CONFIG_HAS_FSL_DR_USB + +#if defined(CONFIG_HAS_FSL_DR_USB) +#define CONFIG_USB_EHCI + +#define CONFIG_USB_MAX_CONTROLLER_COUNT 1 + +#ifdef CONFIG_USB_EHCI +#define CONFIG_CMD_USB +#define CONFIG_EHCI_HCD_INIT_AFTER_RESET +#define CONFIG_USB_EHCI_FSL +#define CONFIG_USB_STORAGE +#endif +#endif + +#undef CONFIG_WATCHDOG /* watchdog disabled */ + +#ifdef CONFIG_MMC +#define CONFIG_FSL_ESDHC +#define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC85xx_ESDHC_ADDR +#define CONFIG_CMD_MMC +#define CONFIG_MMC_SPI +#define CONFIG_CMD_MMC_SPI +#define CONFIG_GENERIC_MMC +#endif + +#if defined(CONFIG_MMC) || defined(CONFIG_USB_EHCI) || defined(CONFIG_FSL_SATA) +#define CONFIG_CMD_EXT2 +#define CONFIG_CMD_FAT +#define CONFIG_DOS_PARTITION +#endif + +/* Misc Extra Settings */ +#define CONFIG_CMD_GPIO 1 +#undef CONFIG_WATCHDOG /* watchdog disabled */ + +/* + * Miscellaneous configurable options + */ +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_CMDLINE_EDITING /* Command-line editing */ +#define CONFIG_SYS_LOAD_ADDR 0x2000000 /* default load address */ +#define CONFIG_SYS_PROMPT "B$ " /* Monitor Command Prompt */ +#if defined(CONFIG_CMD_KGDB) +#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ +#else +#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ +#endif +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) + /* Print Buffer Size */ +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE/* Boot Argument Buffer Size */ +#define CONFIG_SYS_HZ 1000 /* decrementer freq: 1ms tick */ + +/* + * For booting Linux, the board info and command line data + * have to be in the first 64 MB of memory, since this is + * the maximum mapped by the Linux kernel during initialization. + */ +#define CONFIG_SYS_BOOTMAPSZ (64 << 20) /* Initial Memory for Linux*/ +#define CONFIG_SYS_BOOTM_LEN (64 << 20) /* Increase max gunzip size */ + +#if defined(CONFIG_CMD_KGDB) +#define CONFIG_KGDB_BAUDRATE 230400 /* speed to run kgdb serial port */ +#define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ +#endif + +/* + * Environment Configuration + */ + +#if defined(CONFIG_TSEC_ENET) + +#if defined(CONFIG_UCP1020_REV_1_2) +#define CONFIG_PHY_MICREL_KSZ9021 +#elif defined(CONFIG_UCP1020_REV_1_3) +#define CONFIG_PHY_MICREL_KSZ9031 +#else +#error "UCP1020 module revision is not defined !!!" +#endif + +#define CONFIG_CMD_DHCP +#define CONFIG_BOOTP_SERVERIP + +#define CONFIG_MII /* MII PHY management */ +#define CONFIG_TSEC1_NAME "eTSEC1" +#define CONFIG_TSEC2_NAME "eTSEC2" +#define CONFIG_TSEC3_NAME "eTSEC3" + +#define TSEC1_PHY_ADDR 4 +#define TSEC2_PHY_ADDR 0 +#define TSEC2_PHY_ADDR_SGMII 0x00 +#define TSEC3_PHY_ADDR 6 + +#define TSEC1_FLAGS (TSEC_GIGABIT | TSEC_REDUCED) +#define TSEC2_FLAGS (TSEC_GIGABIT | TSEC_REDUCED) +#define TSEC3_FLAGS (TSEC_GIGABIT | TSEC_REDUCED) + +#define TSEC1_PHYIDX 0 +#define TSEC2_PHYIDX 0 +#define TSEC3_PHYIDX 0 + +#define CONFIG_PHY_GIGE 1 /* Include GbE speed/duplex detection */ + +#endif + +#define CONFIG_HOSTNAME UCP1020 +#define CONFIG_ROOTPATH "/opt/nfsroot" +#define CONFIG_BOOTFILE "uImage" +#define CONFIG_UBOOTPATH u-boot.bin /* U-Boot image on TFTP server */ + +/* default location for tftp and bootm */ +#define CONFIG_LOADADDR 1000000 + +/* + * Autobooting + */ +#define CONFIG_AUTOBOOT_KEYED +#define CONFIG_AUTOBOOT_STOP_STR "\x1b" +#define DEBUG_BOOTKEYS 0 +#undef CONFIG_AUTOBOOT_DELAY_STR +#undef CONFIG_BOOTARGS +#define CONFIG_AUTOBOOT_PROMPT "Autobooting in %d seconds, " \ + "press "<Esc>" to stop\n", bootdelay + +#define CONFIG_BOOTARGS /* the boot command will set bootargs */ + +#define CONFIG_BAUDRATE 115200 + +#if defined(CONFIG_DONGLE) + +#define CONFIG_BOOTDELAY 1 /* autoboot after 1 seconds */ +#define CONFIG_EXTRA_ENV_SETTINGS \ +"bootcmd=run prog_spi_mbrbootcramfs\0" \ +"bootfile=uImage\0" \ +"consoledev=ttyS0\0" \ +"cramfsfile=image.cramfs\0" \ +"dtbaddr=0x00c00000\0" \ +"dtbfile=image.dtb\0" \ +"ethaddr=" __stringify(CONFIG_ETHADDR) "\0" \ +"eth1addr=" __stringify(CONFIG_ETH1ADDR) "\0" \ +"eth2addr=" __stringify(CONFIG_ETH2ADDR) "\0" \ +"fileaddr=0x01000000\0" \ +"filesize=0x00080000\0" \ +"flashmbr=sf probe 0; " \ + "tftp $loadaddr $mbr; " \ + "sf erase $mbr_offset +$filesize; " \ + "sf write $loadaddr $mbr_offset $filesize\0" \ +"flashrecovery=tftp $recoveryaddr $cramfsfile; " \ + "protect off $nor_recoveryaddr +$filesize; " \ + "erase $nor_recoveryaddr +$filesize; " \ + "cp.b $recoveryaddr $nor_recoveryaddr $filesize; " \ + "protect on $nor_recoveryaddr +$filesize\0 " \ +"flashuboot=tftp $ubootaddr $ubootfile; " \ + "protect off $nor_ubootaddr +$filesize; " \ + "erase $nor_ubootaddr +$filesize; " \ + "cp.b $ubootaddr $nor_ubootaddr $filesize; " \ + "protect on $nor_ubootaddr +$filesize\0 " \ +"flashworking=tftp $workingaddr $cramfsfile; " \ + "protect off $nor_workingaddr +$filesize; " \ + "erase $nor_workingaddr +$filesize; " \ + "cp.b $workingaddr $nor_workingaddr $filesize; " \ + "protect on $nor_workingaddr +$filesize\0 " \ +"hwconfig=usb1:dr_mode=host,phy_type=ulpi\0 " \ +"kerneladdr=0x01100000\0" \ +"kernelfile=uImage\0" \ +"loadaddr=0x01000000\0" \ +"mbr=uCP1020d.mbr\0" \ +"mbr_offset=0x00000000\0" \ +"mmbr=uCP1020Quiet.mbr\0" \ +"mmcpart=0:2\0" \ +"mmc__mbrd=fatload mmc $mmcpart $loadaddr $mbr; " \ + "mmc erase 1 1; " \ + "mmc write $loadaddr 1 1\0" \ +"mmc__uboot=fatload mmc $mmcpart $loadaddr $ubootfile; " \ + "mmc erase 0x40 0x400; " \ + "mmc write $loadaddr 0x40 0x400\0" \ +"netdev=eth0\0" \ +"nor_recoveryaddr=0xEC0A0000\0" \ +"nor_ubootaddr=0xEFF80000\0" \ +"nor_workingaddr=0xECFA0000\0" \ +"norbootrecovery=setenv bootargs $recoverybootargs console=$consoledev,$baudrate $othbootargs; " \ + "run norloadrecovery; " \ + "bootm $kerneladdr - $dtbaddr\0" \ +"norbootworking=setenv bootargs $workingbootargs console=$consoledev,$baudrate $othbootargs; " \ + "run norloadworking; " \ + "bootm $kerneladdr - $dtbaddr\0" \ +"norloadrecovery=mw.l $kerneladdr 0x0 0x00a00000; " \ + "setenv cramfsaddr $nor_recoveryaddr; " \ + "cramfsload $dtbaddr $dtbfile; " \ + "cramfsload $kerneladdr $kernelfile\0" \ +"norloadworking=mw.l $kerneladdr 0x0 0x00a00000; " \ + "setenv cramfsaddr $nor_workingaddr; " \ + "cramfsload $dtbaddr $dtbfile; " \ + "cramfsload $kerneladdr $kernelfile\0" \ +"prog_spi_mbr=run spi__mbr\0" \ +"prog_spi_mbrboot=run spi__mbr; run spi__boot1; run spi__boot2\0" \ +"prog_spi_mbrbootcramfs=run spi__mbr; run spi__boot1; run spi__boot2; " \ + "run spi__cramfs\0" \ +"ramboot=setenv bootargs root=/dev/ram ramdisk_size=$ramdisk_size ro console=$consoledev,$baudrate $othbootargs; " \ + "tftp $rootfsaddr $rootfsfile; " \ + "tftp $loadaddr $kernelfile; " \ + "tftp $dtbaddr $dtbfile; " \ + "bootm $loadaddr $rootfsaddr $dtbaddr\0" \ +"ramdisk_size=120000\0" \ +"ramdiskfile=rootfs.ext2.gz.uboot\0" \ +"recoveryaddr=0x02F00000\0" \ +"recoverybootargs=root=/dev/mtdblock0 rootfstype=cramfs ro\0" \ +"releasefpga=mw.l 0xffe0f000 0x00400000; mw.l 0xffe0f004 0x00000000; " \ + "mw.l 0xffe0f008 0x00400000\0" \ +"rootfsaddr=0x02F00000\0" \ +"rootfsfile=rootfs.ext2.gz.uboot\0" \ +"rootpath=/opt/nfsroot\0" \ +"spi__boot1=fatload mmc $mmcpart $loadaddr u-boot.bin; " \ + "protect off 0xeC000000 +$filesize; " \ + "erase 0xEC000000 +$filesize; " \ + "cp.b $loadaddr 0xEC000000 $filesize; " \ + "cmp.b $loadaddr 0xEC000000 $filesize; " \ + "protect on 0xeC000000 +$filesize\0" \ +"spi__boot2=fatload mmc $mmcpart $loadaddr u-boot.bin; " \ + "protect off 0xeFF80000 +$filesize; " \ + "erase 0xEFF80000 +$filesize; " \ + "cp.b $loadaddr 0xEFF80000 $filesize; " \ + "cmp.b $loadaddr 0xEFF80000 $filesize; " \ + "protect on 0xeFF80000 +$filesize\0" \ +"spi__bootd=fatload mmc $mmcpart $loadaddr $ubootd; " \ + "sf probe 0; sf erase 0x8000 +$filesize; " \ + "sf write $loadaddr 0x8000 $filesize\0" \ +"spi__cramfs=fatload mmc $mmcpart $loadaddr image.cramfs; " \ + "protect off 0xec0a0000 +$filesize; " \ + "erase 0xeC0A0000 +$filesize; " \ + "cp.b $loadaddr 0xeC0A0000 $filesize; " \ + "protect on 0xec0a0000 +$filesize\0" \ +"spi__mbr=fatload mmc $mmcpart $loadaddr $mmbr; " \ + "sf probe 1; sf erase 0 +$filesize; " \ + "sf write $loadaddr 0 $filesize\0" \ +"spi__mbrd=fatload mmc $mmcpart $loadaddr $mbr; " \ + "sf probe 0; sf erase 0 +$filesize; " \ + "sf write $loadaddr 0 $filesize\0" \ +"tftpflash=tftpboot $loadaddr $uboot; " \ + "protect off " __stringify(CONFIG_SYS_TEXT_BASE_NOR) " +$filesize; " \ + "erase " __stringify(CONFIG_SYS_TEXT_BASE_NOR) " +$filesize; " \ + "cp.b $loadaddr " __stringify(CONFIG_SYS_TEXT_BASE_NOR) " $filesize; " \ + "protect on " __stringify(CONFIG_SYS_TEXT_BASE_NOR) " +$filesize; " \ + "cmp.b $loadaddr " __stringify(CONFIG_SYS_TEXT_BASE_NOR) " $filesize\0" \ +"uboot= " __stringify(CONFIG_UBOOTPATH) "\0" \ +"ubootaddr=0x01000000\0" \ +"ubootfile=u-boot.bin\0" \ +"ubootd=u-boot4dongle.bin\0" \ +"upgrade=run flashworking\0" \ +"usb_phy_type=ulpi\0 " \ +"workingaddr=0x02F00000\0" \ +"workingbootargs=root=/dev/mtdblock1 rootfstype=cramfs ro\0" + +#else + +#if defined(CONFIG_UCP1020T1) + +#define CONFIG_BOOTDELAY 2 /* autoboot after 2 sec, -1 disables auto-boot */ +#define CONFIG_EXTRA_ENV_SETTINGS \ +"bootcmd=run releasefpga; run norbootworking || run norbootrecovery\0" \ +"bootfile=uImage\0" \ +"consoledev=ttyS0\0" \ +"cramfsfile=image.cramfs\0" \ +"dtbaddr=0x00c00000\0" \ +"dtbfile=image.dtb\0" \ +"ethaddr=" __stringify(CONFIG_ETHADDR) "\0" \ +"eth1addr=" __stringify(CONFIG_ETH1ADDR) "\0" \ +"eth2addr=" __stringify(CONFIG_ETH2ADDR) "\0" \ +"fileaddr=0x01000000\0" \ +"filesize=0x00080000\0" \ +"flashmbr=sf probe 0; " \ + "tftp $loadaddr $mbr; " \ + "sf erase $mbr_offset +$filesize; " \ + "sf write $loadaddr $mbr_offset $filesize\0" \ +"flashrecovery=tftp $recoveryaddr $cramfsfile; " \ + "protect off $nor_recoveryaddr +$filesize; " \ + "erase $nor_recoveryaddr +$filesize; " \ + "cp.b $recoveryaddr $nor_recoveryaddr $filesize; " \ + "protect on $nor_recoveryaddr +$filesize\0 " \ +"flashuboot=tftp $ubootaddr $ubootfile; " \ + "protect off $nor_ubootaddr +$filesize; " \ + "erase $nor_ubootaddr +$filesize; " \ + "cp.b $ubootaddr $nor_ubootaddr $filesize; " \ + "protect on $nor_ubootaddr +$filesize\0 " \ +"flashworking=tftp $workingaddr $cramfsfile; " \ + "protect off $nor_workingaddr +$filesize; " \ + "erase $nor_workingaddr +$filesize; " \ + "cp.b $workingaddr $nor_workingaddr $filesize; " \ + "protect on $nor_workingaddr +$filesize\0 " \ +"hwconfig=usb1:dr_mode=host,phy_type=ulpi\0 " \ +"kerneladdr=0x01100000\0" \ +"kernelfile=uImage\0" \ +"loadaddr=0x01000000\0" \ +"mbr=uCP1020.mbr\0" \ +"mbr_offset=0x00000000\0" \ +"netdev=eth0\0" \ +"nor_recoveryaddr=0xEC0A0000\0" \ +"nor_ubootaddr=0xEFF80000\0" \ +"nor_workingaddr=0xECFA0000\0" \ +"norbootrecovery=setenv bootargs $recoverybootargs console=$consoledev,$baudrate $othbootargs; " \ + "run norloadrecovery; " \ + "bootm $kerneladdr - $dtbaddr\0" \ +"norbootworking=setenv bootargs $workingbootargs console=$consoledev,$baudrate $othbootargs; " \ + "run norloadworking; " \ + "bootm $kerneladdr - $dtbaddr\0" \ +"norloadrecovery=mw.l $kerneladdr 0x0 0x00a00000; " \ + "setenv cramfsaddr $nor_recoveryaddr; " \ + "cramfsload $dtbaddr $dtbfile; " \ + "cramfsload $kerneladdr $kernelfile\0" \ +"norloadworking=mw.l $kerneladdr 0x0 0x00a00000; " \ + "setenv cramfsaddr $nor_workingaddr; " \ + "cramfsload $dtbaddr $dtbfile; " \ + "cramfsload $kerneladdr $kernelfile\0" \ +"othbootargs=quiet\0" \ +"ramboot=setenv bootargs root=/dev/ram ramdisk_size=$ramdisk_size ro console=$consoledev,$baudrate $othbootargs; " \ + "tftp $rootfsaddr $rootfsfile; " \ + "tftp $loadaddr $kernelfile; " \ + "tftp $dtbaddr $dtbfile; " \ + "bootm $loadaddr $rootfsaddr $dtbaddr\0" \ +"ramdisk_size=120000\0" \ +"ramdiskfile=rootfs.ext2.gz.uboot\0" \ +"recoveryaddr=0x02F00000\0" \ +"recoverybootargs=root=/dev/mtdblock0 rootfstype=cramfs ro\0" \ +"releasefpga=mw.l 0xffe0f000 0x00400000; mw.l 0xffe0f004 0x00000000; " \ + "mw.l 0xffe0f008 0x00400000\0" \ +"rootfsaddr=0x02F00000\0" \ +"rootfsfile=rootfs.ext2.gz.uboot\0" \ +"rootpath=/opt/nfsroot\0" \ +"silent=1\0" \ +"tftpflash=tftpboot $loadaddr $uboot; " \ + "protect off " __stringify(CONFIG_SYS_TEXT_BASE_NOR) " +$filesize; " \ + "erase " __stringify(CONFIG_SYS_TEXT_BASE_NOR) " +$filesize; " \ + "cp.b $loadaddr " __stringify(CONFIG_SYS_TEXT_BASE_NOR) " $filesize; " \ + "protect on " __stringify(CONFIG_SYS_TEXT_BASE_NOR) " +$filesize; " \ + "cmp.b $loadaddr " __stringify(CONFIG_SYS_TEXT_BASE_NOR) " $filesize\0" \ +"uboot= " __stringify(CONFIG_UBOOTPATH) "\0" \ +"ubootaddr=0x01000000\0" \ +"ubootfile=u-boot.bin\0" \ +"upgrade=run flashworking\0" \ +"workingaddr=0x02F00000\0" \ +"workingbootargs=root=/dev/mtdblock1 rootfstype=cramfs ro\0" + +#else /* For Arcturus Modules */ + +#define CONFIG_BOOTDELAY 2 /* autoboot after 2 sec, -1 disables auto-boot */ +#define CONFIG_EXTRA_ENV_SETTINGS \ +"bootcmd=run norkernel\0" \ +"bootfile=uImage\0" \ +"consoledev=ttyS0\0" \ +"dtbaddr=0x00c00000\0" \ +"dtbfile=image.dtb\0" \ +"ethaddr=" __stringify(CONFIG_ETHADDR) "\0" \ +"eth1addr=" __stringify(CONFIG_ETH1ADDR) "\0" \ +"eth2addr=" __stringify(CONFIG_ETH2ADDR) "\0" \ +"fileaddr=0x01000000\0" \ +"filesize=0x00080000\0" \ +"flashmbr=sf probe 0; " \ + "tftp $loadaddr $mbr; " \ + "sf erase $mbr_offset +$filesize; " \ + "sf write $loadaddr $mbr_offset $filesize\0" \ +"flashuboot=tftp $loadaddr $ubootfile; " \ + "protect off $nor_ubootaddr0 +$filesize; " \ + "erase $nor_ubootaddr0 +$filesize; " \ + "cp.b $loadaddr $nor_ubootaddr0 $filesize; " \ + "protect on $nor_ubootaddr0 +$filesize; " \ + "protect off $nor_ubootaddr1 +$filesize; " \ + "erase $nor_ubootaddr1 +$filesize; " \ + "cp.b $loadaddr $nor_ubootaddr1 $filesize; " \ + "protect on $nor_ubootaddr1 +$filesize\0 " \ +"format0=protect off $part0base +$part0size; " \ + "erase $part0base +$part0size\0" \ +"format1=protect off $part1base +$part1size; " \ + "erase $part1base +$part1size\0" \ +"format2=protect off $part2base +$part2size; " \ + "erase $part2base +$part2size\0" \ +"format3=protect off $part3base +$part3size; " \ + "erase $part3base +$part3size\0" \ +"hwconfig=usb1:dr_mode=host,phy_type=ulpi\0 " \ +"kerneladdr=0x01100000\0" \ +"kernelargs=root=/dev/mtdblock1 rootfstype=cramfs ro\0" \ +"kernelfile=uImage\0" \ +"loadaddr=0x01000000\0" \ +"mbr=uCP1020.mbr\0" \ +"mbr_offset=0x00000000\0" \ +"netdev=eth0\0" \ +"nor_ubootaddr0=0xEC000000\0" \ +"nor_ubootaddr1=0xEFF80000\0" \ +"norkernel=setenv bootargs $kernelargs console=$consoledev,$baudrate; " \ + "run norkernelload; " \ + "bootm $kerneladdr - $dtbaddr\0" \ +"norkernelload=mw.l $kerneladdr 0x0 0x00a00000; " \ + "setenv cramfsaddr $part0base; " \ + "cramfsload $dtbaddr $dtbfile; " \ + "cramfsload $kerneladdr $kernelfile\0" \ +"part0base=0xEC100000\0" \ +"part0size=0x00700000\0" \ +"part1base=0xEC800000\0" \ +"part1size=0x02000000\0" \ +"part2base=0xEE800000\0" \ +"part2size=0x00800000\0" \ +"part3base=0xEF000000\0" \ +"part3size=0x00F80000\0" \ +"partENVbase=0xEC080000\0" \ +"partENVsize=0x00080000\0" \ +"program0=tftp part0-000000.bin; " \ + "protect off $part0base +$filesize; " \ + "erase $part0base +$filesize; " \ + "cp.b $loadaddr $part0base $filesize; " \ + "echo Verifying...; " \ + "cmp.b $loadaddr $part0base $filesize\0" \ +"program1=tftp part1-000000.bin; " \ + "protect off $part1base +$filesize; " \ + "erase $part1base +$filesize; " \ + "cp.b $loadaddr $part1base $filesize; " \ + "echo Verifying...; " \ + "cmp.b $loadaddr $part1base $filesize\0" \ +"program2=tftp part2-000000.bin; " \ + "protect off $part2base +$filesize; " \ + "erase $part2base +$filesize; " \ + "cp.b $loadaddr $part2base $filesize; " \ + "echo Verifying...; " \ + "cmp.b $loadaddr $part2base $filesize\0" \ +"ramboot=setenv bootargs root=/dev/ram ramdisk_size=$ramdisk_size ro console=$consoledev,$baudrate $othbootargs; " \ + "tftp $rootfsaddr $rootfsfile; " \ + "tftp $loadaddr $kernelfile; " \ + "tftp $dtbaddr $dtbfile; " \ + "bootm $loadaddr $rootfsaddr $dtbaddr\0" \ +"ramdisk_size=120000\0" \ +"ramdiskfile=rootfs.ext2.gz.uboot\0" \ +"releasefpga=mw.l 0xffe0f000 0x00400000; mw.l 0xffe0f004 0x00000000; " \ + "mw.l 0xffe0f008 0x00400000\0" \ +"rootfsaddr=0x02F00000\0" \ +"rootfsfile=rootfs.ext2.gz.uboot\0" \ +"rootpath=/opt/nfsroot\0" \ +"spi__mbr=fatload mmc $mmcpart $loadaddr $mmbr; " \ + "sf probe 0; sf erase 0 +$filesize; " \ + "sf write $loadaddr 0 $filesize\0" \ +"spi__boot=fatload mmc $mmcpart $loadaddr u-boot.bin; " \ + "protect off 0xeC000000 +$filesize; " \ + "erase 0xEC000000 +$filesize; " \ + "cp.b $loadaddr 0xEC000000 $filesize; " \ + "cmp.b $loadaddr 0xEC000000 $filesize; " \ + "protect on 0xeC000000 +$filesize\0" \ +"tftpflash=tftpboot $loadaddr $uboot; " \ + "protect off " __stringify(CONFIG_SYS_TEXT_BASE_NOR) " +$filesize; " \ + "erase " __stringify(CONFIG_SYS_TEXT_BASE_NOR) " +$filesize; " \ + "cp.b $loadaddr " __stringify(CONFIG_SYS_TEXT_BASE_NOR) " $filesize; " \ + "protect on " __stringify(CONFIG_SYS_TEXT_BASE_NOR) " +$filesize; " \ + "cmp.b $loadaddr " __stringify(CONFIG_SYS_TEXT_BASE_NOR) " $filesize\0" \ +"uboot= " __stringify(CONFIG_UBOOTPATH) "\0" \ +"ubootfile=u-boot.bin\0" \ +"upgrade=run flashuboot\0" \ +"usb_phy_type=ulpi\0 " \ +"boot_nfs= " \ + "setenv bootargs root=/dev/nfs rw " \ + "nfsroot=$serverip:$rootpath " \ + "ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:$netdev:off " \ + "console=$consoledev,$baudrate $othbootargs;" \ + "tftp $loadaddr $bootfile;" \ + "tftp $fdtaddr $fdtfile;" \ + "bootm $loadaddr - $fdtaddr\0" \ +"boot_hd = " \ + "setenv bootargs root=/dev/$bdev rw rootdelay=30 " \ + "console=$consoledev,$baudrate $othbootargs;" \ + "usb start;" \ + "ext2load usb 0:1 $loadaddr /boot/$bootfile;" \ + "ext2load usb 0:1 $fdtaddr /boot/$fdtfile;" \ + "bootm $loadaddr - $fdtaddr\0" \ +"boot_usb_fat = " \ + "setenv bootargs root=/dev/ram rw " \ + "console=$consoledev,$baudrate $othbootargs " \ + "ramdisk_size=$ramdisk_size;" \ + "usb start;" \ + "fatload usb 0:2 $loadaddr $bootfile;" \ + "fatload usb 0:2 $fdtaddr $fdtfile;" \ + "fatload usb 0:2 $ramdiskaddr $ramdiskfile;" \ + "bootm $loadaddr $ramdiskaddr $fdtaddr\0 " \ +"boot_usb_ext2 = " \ + "setenv bootargs root=/dev/ram rw " \ + "console=$consoledev,$baudrate $othbootargs " \ + "ramdisk_size=$ramdisk_size;" \ + "usb start;" \ + "ext2load usb 0:4 $loadaddr $bootfile;" \ + "ext2load usb 0:4 $fdtaddr $fdtfile;" \ + "ext2load usb 0:4 $ramdiskaddr $ramdiskfile;" \ + "bootm $loadaddr $ramdiskaddr $fdtaddr\0 " \ +"boot_nor = " \ + "setenv bootargs root=/dev/$jffs2nor rw " \ + "console=$consoledev,$baudrate rootfstype=jffs2 $othbootargs;" \ + "bootm $norbootaddr - $norfdtaddr\0 " \ +"boot_ram = " \ + "setenv bootargs root=/dev/ram rw " \ + "console=$consoledev,$baudrate $othbootargs " \ + "ramdisk_size=$ramdisk_size;" \ + "tftp $ramdiskaddr $ramdiskfile;" \ + "tftp $loadaddr $bootfile;" \ + "tftp $fdtaddr $fdtfile;" \ + "bootm $loadaddr $ramdiskaddr $fdtaddr\0" + +#endif +#endif + +#endif /* __CONFIG_H */
Oleks,
I suggest to change the subject to "powerpc/mpc85xx: Add board support for ucp1020".
On 04/15/2015 12:37 PM, Oleksandr G Zhadan wrote:
New QorIQ p1020 based board support from Arcturus Networks Inc. http://www.arcturusnetworks.com/products/ucp1020/
Signed-off-by: Michael Durrant mdurrant@arcturusnetworks.com Signed-off-by: Oleksandr G Zhadan oleks@arcturusnetworks.com
<snip>
+int get_arc_info(void) +{
- int location = 1;
- flash = spi_flash_probe(CONFIG_ENV_SPI_BUS, CONFIG_ENV_SPI_CS,
CONFIG_ENV_SPI_MAX_HZ, CONFIG_ENV_SPI_MODE);
- if (spi_flash_read(flash, (0x200 - sizeof(smac)), sizeof(smac), smac)) {
location++;
if (spi_flash_read(flash, (0x400 - sizeof(smac)), sizeof(smac), smac)) {
location++;
if (spi_flash_read(flash, (CONFIG_ENV_SECT_SIZE + 0x200 - sizeof(smac)), sizeof(smac), smac)) {
location++;
if (spi_flash_read(flash, (CONFIG_ENV_SECT_SIZE + 0x400 - sizeof(smac)), sizeof(smac), smac)) {
printf("%s: ERROR: Failed to read all %d factory info spi locations\n", __func__, location);
These lines are way too long. Please wrap them back at or before 80 characters. You can keep printf string in one line, but the arguments should be in next.
There are many lines over 80 characters. Please try to fix all.
York
Oleksandr G Zhadan
York Sun
