[U-Boot] [PATCH] 8/12 Multiadapter/multibus I2C, configs part 1
Signed-off-by: Sergey Kubushyn ksi@koi8.net --- diff -purN u-boot-i2c.orig/include/configs/ATUM8548.h u-boot-i2c/include/configs/ATUM8548.h --- u-boot-i2c.orig/include/configs/ATUM8548.h 2009-02-12 10:43:41.000000000 -0800 +++ u-boot-i2c/include/configs/ATUM8548.h 2009-02-12 10:46:00.000000000 -0800 @@ -229,14 +229,14 @@ /* * I2C */ -#define CONFIG_FSL_I2C /* Use FSL common I2C driver */ -#define CONFIG_HARD_I2C /* I2C with hardware support*/ -#undef CONFIG_SOFT_I2C /* I2C bit-banged */ -#define CONFIG_SYS_I2C_SPEED 400000 /* I2C speed and slave address */ -#define CONFIG_SYS_I2C_EEPROM_ADDR 0x57 -#define CONFIG_SYS_I2C_SLAVE 0x7F -#define CONFIG_SYS_I2C_NOPROBES {0x69} /* Don't probe these addrs */ -#define CONFIG_SYS_I2C_OFFSET 0x3000 +#define CONFIG_NEW_I2C /* New I2C code */ +#define CONFIG_FSL_I2C /* Use FSL common I2C driver */ +#define CONFIG_SYS_FSL_I2C_SPEED 400000 /* I2C speed and slave address */ +#define CONFIG_SYS_FSL_I2C_EEPROM_ADDR 0x57 +#define CONFIG_SYS_FSL_I2C_SLAVE 0x7F +#define CONFIG_SYS_I2C_NOPROBES {0x69} /* Don't probe these addrs */ +#define CONFIG_SYS_FSL_I2C_OFFSET 0x3000 +#define CONFIG_SYS_I2C_ADAPTERS {&fsl_i2c_adap[0]}
/* * General PCI diff -purN u-boot-i2c.orig/include/configs/CPU86.h u-boot-i2c/include/configs/CPU86.h --- u-boot-i2c.orig/include/configs/CPU86.h 2009-02-12 10:43:41.000000000 -0800 +++ u-boot-i2c/include/configs/CPU86.h 2009-02-12 10:46:00.000000000 -0800 @@ -123,10 +123,12 @@ /*----------------------------------------------------------------------- * I2C/EEPROM/RTC configuration */ -#define CONFIG_SOFT_I2C /* Software I2C support enabled */ - -# define CONFIG_SYS_I2C_SPEED 50000 -# define CONFIG_SYS_I2C_SLAVE 0xFE +#define CONFIG_NEW_I2C +#define CONFIG_SOFT_I2C /* I2C bit-banged */ +#define I2C_SOFT_DECLARATIONS I2C_SOFT_DEFS +#define CONFIG_SYS_SOFT_I2C_SPEED 50000 +#define CONFIG_SYS_SOFT_I2C_SLAVE 0xFE +#define CONFIG_SYS_I2C_ADAPTERS {&soft_i2c_adap[0]} /* * Software (bit-bang) I2C driver configuration */ diff -purN u-boot-i2c.orig/include/configs/CPU87.h u-boot-i2c/include/configs/CPU87.h --- u-boot-i2c.orig/include/configs/CPU87.h 2009-02-12 10:43:41.000000000 -0800 +++ u-boot-i2c/include/configs/CPU87.h 2009-02-12 10:46:00.000000000 -0800 @@ -127,10 +127,12 @@ /*----------------------------------------------------------------------- * I2C/EEPROM/RTC configuration */ -#define CONFIG_SOFT_I2C /* Software I2C support enabled */ - -# define CONFIG_SYS_I2C_SPEED 50000 -# define CONFIG_SYS_I2C_SLAVE 0xFE +#define CONFIG_NEW_I2C +#define CONFIG_SOFT_I2C /* I2C bit-banged */ +#define I2C_SOFT_DECLARATIONS I2C_SOFT_DEFS +#define CONFIG_SYS_SOFT_I2C_SPEED 50000 +#define CONFIG_SYS_SOFT_I2C_SLAVE 0xFE +#define CONFIG_SYS_I2C_ADAPTERS {&soft_i2c_adap[0]} /* * Software (bit-bang) I2C driver configuration */ diff -purN u-boot-i2c.orig/include/configs/GEN860T.h u-boot-i2c/include/configs/GEN860T.h --- u-boot-i2c.orig/include/configs/GEN860T.h 2009-02-12 10:43:41.000000000 -0800 +++ u-boot-i2c/include/configs/GEN860T.h 2009-02-12 10:46:00.000000000 -0800 @@ -180,6 +180,11 @@ #endif
#ifdef CONFIG_SOFT_I2C +#define CONFIG_NEW_I2C +#define I2C_SOFT_DECLARATIONS I2C_SOFT_DEFS +#define CONFIG_SYS_SOFT_I2C_SPEED 50000 +#define CONFIG_SYS_SOFT_I2C_SLAVE 0xFE +#define CONFIG_SYS_I2C_ADAPTERS {&soft_i2c_adap[0]} #define PB_SCL 0x00000020 /* PB 26 */ #define PB_SDA 0x00000010 /* PB 27 */ #define I2C_INIT (immr->im_cpm.cp_pbdir |= PB_SCL) diff -purN u-boot-i2c.orig/include/configs/HIDDEN_DRAGON.h u-boot-i2c/include/configs/HIDDEN_DRAGON.h --- u-boot-i2c.orig/include/configs/HIDDEN_DRAGON.h 2009-02-12 10:43:41.000000000 -0800 +++ u-boot-i2c/include/configs/HIDDEN_DRAGON.h 2009-02-12 10:46:00.000000000 -0800 @@ -177,6 +177,11 @@
#ifdef CONFIG_SOFT_I2C #error "Soft I2C is not configured properly. Please review!" +#define CONFIG_NEW_I2C +#define I2C_SOFT_DECLARATIONS I2C_SOFT_DEFS +#define CONFIG_SYS_SOFT_I2C_SPEED 50000 +#define CONFIG_SYS_SOFT_I2C_SLAVE 0xFE +#define CONFIG_SYS_I2C_ADAPTERS {&soft_i2c_adap[0]} #define I2C_PORT 3 /* Port A=0, B=1, C=2, D=3 */ #define I2C_ACTIVE (iop->pdir |= 0x00010000) #define I2C_TRISTATE (iop->pdir &= ~0x00010000) diff -purN u-boot-i2c.orig/include/configs/HMI10.h u-boot-i2c/include/configs/HMI10.h --- u-boot-i2c.orig/include/configs/HMI10.h 2009-02-12 10:43:41.000000000 -0800 +++ u-boot-i2c/include/configs/HMI10.h 2009-02-12 10:46:00.000000000 -0800 @@ -91,12 +91,12 @@ #undef CONFIG_SYS_LOADS_BAUD_CHANGE /* don't allow baudrate change */
/* enable I2C and select the hardware/software driver */ -#undef CONFIG_HARD_I2C /* I2C with hardware support */ -#define CONFIG_SOFT_I2C 1 /* I2C bit-banged */ - -#define CONFIG_SYS_I2C_SPEED 40000 /* 40 kHz is supposed to work */ -#define CONFIG_SYS_I2C_SLAVE 0xFE - +#define CONFIG_NEW_I2C +#define CONFIG_SOFT_I2C /* I2C bit-banged */ +#define I2C_SOFT_DECLARATIONS I2C_SOFT_DEFS +#define CONFIG_SYS_SOFT_I2C_SPEED 40000 +#define CONFIG_SYS_SOFT_I2C_SLAVE 0xFE +#define CONFIG_SYS_I2C_ADAPTERS {&soft_i2c_adap[0]} /* Software (bit-bang) I2C driver configuration */ #define PB_SCL 0x00000020 /* PB 26 */ #define PB_SDA 0x00000010 /* PB 27 */ diff -purN u-boot-i2c.orig/include/configs/IAD210.h u-boot-i2c/include/configs/IAD210.h --- u-boot-i2c.orig/include/configs/IAD210.h 2009-02-12 10:43:41.000000000 -0800 +++ u-boot-i2c/include/configs/IAD210.h 2009-02-12 10:46:00.000000000 -0800 @@ -109,10 +109,12 @@
/* enable I2C and select the hardware/software driver */ #undef CONFIG_HARD_I2C /* I2C with hardware support */ -#define CONFIG_SOFT_I2C 1 /* I2C bit-banged */ -# define CONFIG_SYS_I2C_SPEED 50000 -# define CONFIG_SYS_I2C_SLAVE 0xDD -# define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 +#define CONFIG_NEW_I2C +#define CONFIG_SOFT_I2C /* I2C bit-banged */ +#define I2C_SOFT_DECLARATIONS I2C_SOFT_DEFS +#define CONFIG_SYS_SOFT_I2C_SPEED 50000 +#define CONFIG_SYS_SOFT_I2C_SLAVE 0xDD +#define CONFIG_SYS_I2C_ADAPTERS {&soft_i2c_adap[0]} /* * Software (bit-bang) I2C driver configuration */ @@ -131,6 +133,8 @@
#define CONFIG_RTC_MPC8xx /* use internal RTC of MPC8xx */
+#define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 +
/* * Command line configuration. diff -purN u-boot-i2c.orig/include/configs/ICU862.h u-boot-i2c/include/configs/ICU862.h --- u-boot-i2c.orig/include/configs/ICU862.h 2009-02-12 10:43:41.000000000 -0800 +++ u-boot-i2c/include/configs/ICU862.h 2009-02-12 10:46:00.000000000 -0800 @@ -105,11 +105,12 @@
/* enable I2C and select the hardware/software driver */ #undef CONFIG_HARD_I2C /* I2C with hardware support */ -#define CONFIG_SOFT_I2C 1 /* I2C bit-banged */ -# define CONFIG_SYS_I2C_SPEED 50000 -# define CONFIG_SYS_I2C_SLAVE 0xFE -# define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 -# define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 /* Bytes of address */ +#define CONFIG_NEW_I2C +#define CONFIG_SOFT_I2C /* I2C bit-banged */ +#define I2C_SOFT_DECLARATIONS I2C_SOFT_DEFS +#define CONFIG_SYS_SOFT_I2C_SPEED 50000 +#define CONFIG_SYS_SOFT_I2C_SLAVE 0xFE +#define CONFIG_SYS_I2C_ADAPTERS {&soft_i2c_adap[0]} /* * Software (bit-bang) I2C driver configuration */ @@ -131,6 +132,9 @@
+#define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 +#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 /* Bytes of address */ +
/* * Command line configuration. diff -purN u-boot-i2c.orig/include/configs/IDS8247.h u-boot-i2c/include/configs/IDS8247.h --- u-boot-i2c.orig/include/configs/IDS8247.h 2009-02-12 10:43:41.000000000 -0800 +++ u-boot-i2c/include/configs/IDS8247.h 2009-02-12 10:46:00.000000000 -0800 @@ -72,10 +72,12 @@
/* enable I2C and select the hardware/software driver */ #undef CONFIG_HARD_I2C /* I2C with hardware support */ -#define CONFIG_SOFT_I2C 1 /* I2C bit-banged */ -#define CONFIG_SYS_I2C_SPEED 400000 /* I2C speed and slave address */ -#define CONFIG_SYS_I2C_SLAVE 0x7F - +#define CONFIG_NEW_I2C +#define CONFIG_SOFT_I2C /* I2C bit-banged */ +#define I2C_SOFT_DECLARATIONS I2C_SOFT_DEFS +#define CONFIG_SYS_SOFT_I2C_SPEED 400000 +#define CONFIG_SYS_SOFT_I2C_SLAVE 0x7F +#define CONFIG_SYS_I2C_ADAPTERS {&soft_i2c_adap[0]} /* * Software (bit-bang) I2C driver configuration */ diff -purN u-boot-i2c.orig/include/configs/IP860.h u-boot-i2c/include/configs/IP860.h --- u-boot-i2c.orig/include/configs/IP860.h 2009-02-12 10:43:41.000000000 -0800 +++ u-boot-i2c/include/configs/IP860.h 2009-02-12 10:46:00.000000000 -0800 @@ -59,7 +59,12 @@
/* enable I2C and select the hardware/software driver */ #undef CONFIG_HARD_I2C /* I2C with hardware support */ -#define CONFIG_SOFT_I2C 1 /* I2C bit-banged */ +#define CONFIG_NEW_I2C +#define CONFIG_SOFT_I2C /* I2C bit-banged */ +#define I2C_SOFT_DECLARATIONS I2C_SOFT_DEFS +#define CONFIG_SYS_SOFT_I2C_SPEED 50000 +#define CONFIG_SYS_SOFT_I2C_SLAVE 0xFE +#define CONFIG_SYS_I2C_ADAPTERS {&soft_i2c_adap[0]} /* * Software (bit-bang) I2C driver configuration */ @@ -76,9 +81,6 @@ else immr->im_cpm.cp_pbdat &= ~PB_SCL #define I2C_DELAY udelay(5) /* 1/4 I2C clock duration */
- -# define CONFIG_SYS_I2C_SPEED 50000 -# define CONFIG_SYS_I2C_SLAVE 0xFE # define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 /* EEPROM X24C16 */ # define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 /* bytes of address */ /* mask of address bits that overflow into the "EEPROM chip address" */ diff -purN u-boot-i2c.orig/include/configs/IPHASE4539.h u-boot-i2c/include/configs/IPHASE4539.h --- u-boot-i2c.orig/include/configs/IPHASE4539.h 2009-02-12 10:43:41.000000000 -0800 +++ u-boot-i2c/include/configs/IPHASE4539.h 2009-02-12 10:46:00.000000000 -0800 @@ -109,14 +109,15 @@ * configuration items that the driver uses to drive the port pins. */ #undef CONFIG_HARD_I2C /* I2C with hardware support */ -#define CONFIG_SOFT_I2C 1 /* I2C bit-banged */ -#define CONFIG_SYS_I2C_SPEED 400000 /* I2C speed and slave address */ -#define CONFIG_SYS_I2C_SLAVE 0x7F - +#define CONFIG_NEW_I2C +#define CONFIG_SOFT_I2C /* I2C bit-banged */ +#define I2C_SOFT_DECLARATIONS I2C_SOFT_DEFS +#define CONFIG_SYS_SOFT_I2C_SPEED 400000 +#define CONFIG_SYS_SOFT_I2C_SLAVE 0x7F +#define CONFIG_SYS_I2C_ADAPTERS {&soft_i2c_adap[0]} /* * Software (bit-bang) I2C driver configuration */ -#ifdef CONFIG_SOFT_I2C #define I2C_PORT 3 /* Port A=0, B=1, C=2, D=3 */ #define I2C_ACTIVE (iop->pdir |= 0x00010000) #define I2C_TRISTATE (iop->pdir &= ~0x00010000) @@ -126,7 +127,6 @@ #define I2C_SCL(bit) if(bit) iop->pdat |= 0x00020000; \ else iop->pdat &= ~0x00020000 #define I2C_DELAY udelay(5) /* 1/4 I2C clock duration */ -#endif /* CONFIG_SOFT_I2C */
/* diff -purN u-boot-i2c.orig/include/configs/KUP4K.h u-boot-i2c/include/configs/KUP4K.h --- u-boot-i2c.orig/include/configs/KUP4K.h 2009-02-12 10:43:41.000000000 -0800 +++ u-boot-i2c/include/configs/KUP4K.h 2009-02-12 10:46:00.000000000 -0800 @@ -107,12 +107,12 @@ * enable I2C and select the hardware/software driver */ #undef CONFIG_HARD_I2C /* I2C with hardware support */ -#define CONFIG_SOFT_I2C 1 /* I2C bit-banged */ - -#define CONFIG_SYS_I2C_SPEED 93000 /* 93 kHz is supposed to work */ -#define CONFIG_SYS_I2C_SLAVE 0xFE - -#ifdef CONFIG_SOFT_I2C +#define CONFIG_NEW_I2C +#define CONFIG_SOFT_I2C /* I2C bit-banged */ +#define I2C_SOFT_DECLARATIONS I2C_SOFT_DEFS +#define CONFIG_SYS_SOFT_I2C_SPEED 93000 /* 93 kHz is supposed to work */ +#define CONFIG_SYS_SOFT_I2C_SLAVE 0xFE +#define CONFIG_SYS_I2C_ADAPTERS {&soft_i2c_adap[0]} /* * Software (bit-bang) I2C driver configuration */ @@ -128,7 +128,6 @@ #define I2C_SCL(bit) if(bit) immr->im_cpm.cp_pbdat |= PB_SCL; \ else immr->im_cpm.cp_pbdat &= ~PB_SCL #define I2C_DELAY udelay(2) /* 1/4 I2C clock duration */ -#endif /* CONFIG_SOFT_I2C */
/*----------------------------------------------------------------------- diff -purN u-boot-i2c.orig/include/configs/M52277EVB.h u-boot-i2c/include/configs/M52277EVB.h --- u-boot-i2c.orig/include/configs/M52277EVB.h 2009-02-12 10:43:41.000000000 -0800 +++ u-boot-i2c/include/configs/M52277EVB.h 2009-02-12 10:46:00.000000000 -0800 @@ -144,13 +144,13 @@ #define CONFIG_MCFTMR #undef CONFIG_MCFPIT
-/* I2c */ +/* I2C */ +#define CONFIG_NEW_I2C #define CONFIG_FSL_I2C -#define CONFIG_HARD_I2C /* I2C with hardware support */ -#undef CONFIG_SOFT_I2C /* I2C bit-banged */ -#define CONFIG_SYS_I2C_SPEED 80000 /* I2C speed and slave address */ -#define CONFIG_SYS_I2C_SLAVE 0x7F -#define CONFIG_SYS_I2C_OFFSET 0x58000 +#define CONFIG_SYS_FSL_I2C_SPEED 80000 /* I2C speed and slave address */ +#define CONFIG_SYS_FSL_I2C_SLAVE 0x7F +#define CONFIG_SYS_FSL_I2C_OFFSET 0x58000 +#define CONFIG_SYS_I2C_ADAPTERS {&fsl_i2c_adap[0]} #define CONFIG_SYS_IMMR CONFIG_SYS_MBAR
/* DSPI and Serial Flash */ diff -purN u-boot-i2c.orig/include/configs/M5235EVB.h u-boot-i2c/include/configs/M5235EVB.h --- u-boot-i2c.orig/include/configs/M5235EVB.h 2009-02-12 10:43:41.000000000 -0800 +++ u-boot-i2c/include/configs/M5235EVB.h 2009-02-12 10:46:00.000000000 -0800 @@ -101,12 +101,12 @@ #undef CONFIG_MCFPIT
/* I2C */ +#define CONFIG_NEW_I2C #define CONFIG_FSL_I2C -#define CONFIG_HARD_I2C /* I2C with hw support */ -#undef CONFIG_SOFT_I2C /* I2C bit-banged */ -#define CONFIG_SYS_I2C_SPEED 80000 -#define CONFIG_SYS_I2C_SLAVE 0x7F -#define CONFIG_SYS_I2C_OFFSET 0x00000300 +#define CONFIG_SYS_FSL_I2C_SPEED 80000 +#define CONFIG_SYS_FSL_I2C_SLAVE 0x7F +#define CONFIG_SYS_FSL_I2C_OFFSET 0x00000300 +#define CONFIG_SYS_I2C_ADAPTERS {&fsl_i2c_adap[0]} #define CONFIG_SYS_IMMR CONFIG_SYS_MBAR #define CONFIG_SYS_I2C_PINMUX_REG (gpio->par_qspi) #define CONFIG_SYS_I2C_PINMUX_CLR ~(GPIO_PAR_FECI2C_SCL_MASK | GPIO_PAR_FECI2C_SDA_MASK) diff -purN u-boot-i2c.orig/include/configs/M5253DEMO.h u-boot-i2c/include/configs/M5253DEMO.h --- u-boot-i2c.orig/include/configs/M5253DEMO.h 2009-02-12 10:43:41.000000000 -0800 +++ u-boot-i2c/include/configs/M5253DEMO.h 2009-02-12 10:46:00.000000000 -0800 @@ -119,11 +119,12 @@ #define CONFIG_HOSTNAME M5253DEMO
/* I2C */ +#define CONFIG_NEW_I2C #define CONFIG_FSL_I2C -#define CONFIG_HARD_I2C /* I2C with hw support */ -#define CONFIG_SYS_I2C_SPEED 80000 -#define CONFIG_SYS_I2C_SLAVE 0x7F -#define CONFIG_SYS_I2C_OFFSET 0x00000280 +#define CONFIG_SYS_FSL_I2C_SPEED 80000 +#define CONFIG_SYS_FSL_I2C_SLAVE 0x7F +#define CONFIG_SYS_FSL_I2C_OFFSET 0x00000280 +#define CONFIG_SYS_I2C_ADAPTERS {&fsl_i2c_adap[0]} #define CONFIG_SYS_IMMR CONFIG_SYS_MBAR #define CONFIG_SYS_I2C_PINMUX_REG (*(u32 *) (CONFIG_SYS_MBAR+0x19C)) #define CONFIG_SYS_I2C_PINMUX_CLR (0xFFFFE7FF) diff -purN u-boot-i2c.orig/include/configs/M5271EVB.h u-boot-i2c/include/configs/M5271EVB.h --- u-boot-i2c.orig/include/configs/M5271EVB.h 2009-02-12 10:43:41.000000000 -0800 +++ u-boot-i2c/include/configs/M5271EVB.h 2009-02-12 10:46:00.000000000 -0800 @@ -111,12 +111,12 @@ #endif
#define CONFIG_BOOTDELAY 1 /* autoboot after 1 seconds */ diff -purN u-boot-i2c.orig/include/configs/M5275EVB.h u-boot-i2c/include/configs/M5275EVB.h --- u-boot-i2c.orig/include/configs/M5275EVB.h 2009-02-12 10:43:41.000000000 -0800 +++ u-boot-i2c/include/configs/M5275EVB.h 2009-02-12 10:46:00.000000000 -0800 @@ -111,12 +111,12 @@ #endif
/* I2C */ +#define CONFIG_NEW_I2C #define CONFIG_FSL_I2C -#define CONFIG_HARD_I2C /* I2C with hw support */ -#undef CONFIG_SOFT_I2C -#define CONFIG_SYS_I2C_SPEED 80000 -#define CONFIG_SYS_I2C_SLAVE 0x7F -#define CONFIG_SYS_I2C_OFFSET 0x00000300 +#define CONFIG_SYS_FSL_I2C_SPEED 80000 +#define CONFIG_SYS_FSL_I2C_SLAVE 0x7F +#define CONFIG_SYS_FSL_I2C_OFFSET 0x00000300 +#define CONFIG_SYS_I2C_ADAPTERS {&fsl_i2c_adap[0]} #define CONFIG_SYS_IMMR CONFIG_SYS_MBAR #define CONFIG_SYS_I2C_PINMUX_REG (gpio_reg->par_feci2c) #define CONFIG_SYS_I2C_PINMUX_CLR (0xFFF0) diff -purN u-boot-i2c.orig/include/configs/M53017EVB.h u-boot-i2c/include/configs/M53017EVB.h --- u-boot-i2c.orig/include/configs/M53017EVB.h 2009-02-12 10:43:41.000000000 -0800 +++ u-boot-i2c/include/configs/M53017EVB.h 2009-02-12 10:46:00.000000000 -0800 @@ -98,12 +98,12 @@ #undef CONFIG_MCFPIT
/* I2C */ +#define CONFIG_NEW_I2C #define CONFIG_FSL_I2C -#define CONFIG_HARD_I2C /* I2C with hw support */ -#undef CONFIG_SOFT_I2C /* I2C bit-banged */ -#define CONFIG_SYS_I2C_SPEED 80000 -#define CONFIG_SYS_I2C_SLAVE 0x7F -#define CONFIG_SYS_I2C_OFFSET 0x58000 +#define CONFIG_SYS_FSL_I2C_SPEED 80000 +#define CONFIG_SYS_FSL_I2C_SLAVE 0x7F +#define CONFIG_SYS_FSL_I2C_OFFSET 0x58000 +#define CONFIG_SYS_I2C_ADAPTERS {&fsl_i2c_adap[0]} #define CONFIG_SYS_IMMR CONFIG_SYS_MBAR
#define CONFIG_BOOTDELAY 1 /* autoboot after 5 seconds */ diff -purN u-boot-i2c.orig/include/configs/M5329EVB.h u-boot-i2c/include/configs/M5329EVB.h --- u-boot-i2c.orig/include/configs/M5329EVB.h 2009-02-12 10:43:41.000000000 -0800 +++ u-boot-i2c/include/configs/M5329EVB.h 2009-02-12 10:46:00.000000000 -0800 @@ -97,12 +97,12 @@ #undef CONFIG_MCFPIT
#define CONFIG_BOOTDELAY 1 /* autoboot after 5 seconds */ diff -purN u-boot-i2c.orig/include/configs/M5373EVB.h u-boot-i2c/include/configs/M5373EVB.h --- u-boot-i2c.orig/include/configs/M5373EVB.h 2009-02-12 10:43:41.000000000 -0800 +++ u-boot-i2c/include/configs/M5373EVB.h 2009-02-12 10:46:00.000000000 -0800 @@ -97,12 +97,12 @@ #undef CONFIG_MCFPIT
#define CONFIG_BOOTDELAY 1 /* autoboot after 5 seconds */ diff -purN u-boot-i2c.orig/include/configs/M54451EVB.h u-boot-i2c/include/configs/M54451EVB.h --- u-boot-i2c.orig/include/configs/M54451EVB.h 2009-02-12 10:43:41.000000000 -0800 +++ u-boot-i2c/include/configs/M54451EVB.h 2009-02-12 10:46:00.000000000 -0800 @@ -157,12 +157,12 @@ #undef CONFIG_MCFPIT
/* I2c */ +#define CONFIG_NEW_I2C #define CONFIG_FSL_I2C -#define CONFIG_HARD_I2C /* I2C with hardware support */ -#undef CONFIG_SOFT_I2C /* I2C bit-banged */ -#define CONFIG_SYS_I2C_SPEED 80000 /* I2C speed and slave address */ -#define CONFIG_SYS_I2C_SLAVE 0x7F -#define CONFIG_SYS_I2C_OFFSET 0x58000 +#define CONFIG_SYS_FSL_I2C_SPEED 80000 /* I2C speed and slave address */ +#define CONFIG_SYS_FSL_I2C_SLAVE 0x7F +#define CONFIG_SYS_FSL_I2C_OFFSET 0x58000 +#define CONFIG_SYS_I2C_ADAPTERS {&fsl_i2c_adap[0]} #define CONFIG_SYS_IMMR CONFIG_SYS_MBAR
/* DSPI and Serial Flash */ diff -purN u-boot-i2c.orig/include/configs/M54455EVB.h u-boot-i2c/include/configs/M54455EVB.h --- u-boot-i2c.orig/include/configs/M54455EVB.h 2009-02-12 10:43:41.000000000 -0800 +++ u-boot-i2c/include/configs/M54455EVB.h 2009-02-12 10:46:00.000000000 -0800 @@ -192,12 +192,12 @@ #undef CONFIG_MCFPIT
/* I2c */ +#define CONFIG_NEW_I2C #define CONFIG_FSL_I2C -#define CONFIG_HARD_I2C /* I2C with hardware support */ -#undef CONFIG_SOFT_I2C /* I2C bit-banged */ -#define CONFIG_SYS_I2C_SPEED 80000 /* I2C speed and slave address */ -#define CONFIG_SYS_I2C_SLAVE 0x7F -#define CONFIG_SYS_I2C_OFFSET 0x58000 +#define CONFIG_SYS_FSL_I2C_SPEED 80000 /* I2C speed and slave address */ +#define CONFIG_SYS_FSL_I2C_SLAVE 0x7F +#define CONFIG_SYS_FSLI2C_OFFSET 0x58000 +#define CONFIG_SYS_I2C_ADAPTERS {&fsl_i2c_adap[0]} #define CONFIG_SYS_IMMR CONFIG_SYS_MBAR
/* DSPI and Serial Flash */ diff -purN u-boot-i2c.orig/include/configs/M5475EVB.h u-boot-i2c/include/configs/M5475EVB.h --- u-boot-i2c.orig/include/configs/M5475EVB.h 2009-02-12 10:43:41.000000000 -0800 +++ u-boot-i2c/include/configs/M5475EVB.h 2009-02-12 10:46:00.000000000 -0800 @@ -122,12 +122,12 @@ #endif
/* I2C */ +#define CONFIG_NEW_I2C #define CONFIG_FSL_I2C -#define CONFIG_HARD_I2C /* I2C with hw support */ -#undef CONFIG_SOFT_I2C /* I2C bit-banged */ -#define CONFIG_SYS_I2C_SPEED 80000 -#define CONFIG_SYS_I2C_SLAVE 0x7F -#define CONFIG_SYS_I2C_OFFSET 0x00008F00 +#define CONFIG_SYS_FSL_I2C_SPEED 80000 +#define CONFIG_SYS_FSL_I2C_SLAVE 0x7F +#define CONFIG_SYS_FSL_I2C_OFFSET 0x00008F00 +#define CONFIG_SYS_I2C_ADAPTERS {&fsl_i2c_adap[0]} #define CONFIG_SYS_IMMR CONFIG_SYS_MBAR
/* PCI */ diff -purN u-boot-i2c.orig/include/configs/M5485EVB.h u-boot-i2c/include/configs/M5485EVB.h --- u-boot-i2c.orig/include/configs/M5485EVB.h 2009-02-12 10:43:41.000000000 -0800 +++ u-boot-i2c/include/configs/M5485EVB.h 2009-02-12 10:46:00.000000000 -0800 @@ -119,12 +119,12 @@ #endif
/* PCI */
Dear ksi@koi8.net,
Do we really need sucheven more unreadable names?
Why do you have to add the FSL_, SOFT_, ... everywhere?
I think this should be redundant. Omit it.
On Mon, 16 Feb 2009, Wolfgang Denk wrote:
Dear ksi@koi8.net,
Because you can have several DIFFERENT adapters in the system. Each of those adapters should have its own set of configuration parameters. That's why adapter-specific prefixes are used. There are no prefixes on options common to the entire I2C sybsystem, e.g. CONFIG_SYS_I2C_ADAPTERS.
Once more - one can have both hardware adapter able to run at 400 kHz and a bitbanged one only capable of 20 kHz. If we used a generic CONFIG_SYS_I2C_SPEED, what should we put there? 20000? But why that slow bitbanged interface be a handicap on a fast hardware one? 400000? But bitbanged one can not run at that speed... The same is true for slaveaddr.
CONFIG_SYS_FSL_I2C_EEPROM_ADDR is an error, it should NOT have FSL_ prefix. That's a typo I will fix.
--- ****************************************************************** * KSI@home KOI8 Net < > The impossible we do immediately. * * Las Vegas NV, USA < > Miracles require 24-hour notice. * ******************************************************************
ksi@koi8.net
