[PATCH] xilinx: zynqmp: Update descriptions for u-boot.its
Use TF-A instead of ATF in description. And update generic description with removing ATF because also configurations without it are supported.
arch/arm/mach-zynqmp/mkimage_fit_atf.sh | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-zynqmp/mkimage_fit_atf.sh b/arch/arm/mach-zynqmp/mkimage_fit_atf.sh index feb3a6260a34..72a8a3eb7714 100755 --- a/arch/arm/mach-zynqmp/mkimage_fit_atf.sh +++ b/arch/arm/mach-zynqmp/mkimage_fit_atf.sh @@ -57,7 +57,7 @@ cat << __HEADER_EOF /dts-v1/;
/ { - description = "Configuration to load ATF before U-Boot"; + description = "Configuration for Xilinx ZynqMP SoC";
images { uboot { @@ -78,7 +78,7 @@ __HEADER_EOF if [ -f $BL31 ]; then cat << __ATF atf { - description = "ARM Trusted Firmware"; + description = "Trusted Firmware-A"; data = /incbin/("$BL31"); type = "firmware"; os = "arm-trusted-firmware";
po 23. 8. 2021 v 8:43 odesÃlatel Michal Simek michal.simek@xilinx.com napsal:
description = "Configuration for Xilinx ZynqMP SoC"; images { uboot {
-- 2.33.0
Applied. M
Michal Simek
Michal Simek
