[PATCH v2 0/6] Enable https for wget
Hi all,
This is a respin of [0] adding https support to wget. In short
patch#1 enables the crypto algorithms we need in mbedTLS patches#2, #3 enable anf fix the lwIP part we need patch#4 is adding https:// parsing support in our wget patch#5 is making https:// the default for QEMU lwip defconfig so people can easily test and finaly patch#6 updates our documentation
[0] https://lore.kernel.org/u-boot/20241018142235.715571-1-ilias.apalodimas@lina...
Changes since v1: - re-arranged the Makefile objects so they only get compiled when TLS ie enabled - Fix all the applicable remarks Simon had on the wget patches - Fixed the title of a patch pointer out by Peter - Rebased on -master - Collected r-b tags
Ilias Apalodimas (4): mbedtls: Enable TLS 1.2 support net: lwip: Enable https:// support for wget configs: Enable https for wget on qemu arm64 doc: uefi: Describe UEFI HTTPs boot
Javier Tia (2): net: lwip: Update lwIP for mbedTLS > 3.0 support and enable https net: lwip: Add Support Server Name Indication support
cmd/Kconfig | 19 +++++ configs/qemu_arm64_lwip_defconfig | 1 + doc/develop/uefi/uefi.rst | 45 ++++++++++- lib/lwip/Makefile | 3 + .../src/apps/altcp_tls/altcp_tls_mbedtls.c | 50 +++++++----- lib/lwip/lwip/src/core/tcp_out.c | 10 +-- lib/lwip/lwip/src/include/lwip/altcp_tls.h | 2 +- lib/lwip/u-boot/lwipopts.h | 6 ++ lib/mbedtls/Kconfig | 12 +++ lib/mbedtls/Makefile | 31 ++++++++ lib/mbedtls/mbedtls_def_config.h | 52 +++++++++++++ net/lwip/Kconfig | 2 +- net/lwip/wget.c | 78 +++++++++++++++++-- 13 files changed, 272 insertions(+), 39 deletions(-)
-- 2.45.2
Since lwIP and mbedTLS have been merged we can tweak the config options and enable TLS1.2 support. Add RSA and ECDSA by default and enable enough block cipher modes of operation to be comatible with modern TLS requirements and webservers
Signed-off-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- lib/mbedtls/Kconfig | 12 ++++++++ lib/mbedtls/Makefile | 31 +++++++++++++++++++ lib/mbedtls/mbedtls_def_config.h | 52 ++++++++++++++++++++++++++++++++ 3 files changed, 95 insertions(+)
diff --git a/lib/mbedtls/Kconfig b/lib/mbedtls/Kconfig index d71adc3648ad..f3e172633999 100644 --- a/lib/mbedtls/Kconfig +++ b/lib/mbedtls/Kconfig @@ -430,4 +430,16 @@ endif # SPL
endif # MBEDTLS_LIB_X509
+config MBEDTLS_LIB_TLS + bool "MbedTLS TLS library" + depends on RSA_PUBLIC_KEY_PARSER_MBEDTLS + depends on X509_CERTIFICATE_PARSER_MBEDTLS + depends on ASYMMETRIC_PUBLIC_KEY_MBEDTLS + depends on ASN1_DECODER_MBEDTLS + depends on ASYMMETRIC_PUBLIC_KEY_MBEDTLS + depends on MBEDTLS_LIB_CRYPTO + help + Enable MbedTLS TLS library. If enabled HTTPs support will be enabled + in wget + endif # MBEDTLS_LIB diff --git a/lib/mbedtls/Makefile b/lib/mbedtls/Makefile index 83cb3c2fa705..ce0a61e40541 100644 --- a/lib/mbedtls/Makefile +++ b/lib/mbedtls/Makefile @@ -26,6 +26,7 @@ mbedtls_lib_crypto-y := \ $(MBEDTLS_LIB_DIR)/platform_util.o \ $(MBEDTLS_LIB_DIR)/constant_time.o \ $(MBEDTLS_LIB_DIR)/md.o + mbedtls_lib_crypto-$(CONFIG_$(SPL_)MD5_MBEDTLS) += $(MBEDTLS_LIB_DIR)/md5.o mbedtls_lib_crypto-$(CONFIG_$(SPL_)SHA1_MBEDTLS) += $(MBEDTLS_LIB_DIR)/sha1.o mbedtls_lib_crypto-$(CONFIG_$(SPL_)SHA256_MBEDTLS) += \ @@ -54,3 +55,33 @@ mbedtls_lib_x509-$(CONFIG_$(SPL_)X509_CERTIFICATE_PARSER_MBEDTLS) += \ $(MBEDTLS_LIB_DIR)/x509_crt.o mbedtls_lib_x509-$(CONFIG_$(SPL_)PKCS7_MESSAGE_PARSER_MBEDTLS) += \ $(MBEDTLS_LIB_DIR)/pkcs7.o + +#mbedTLS TLS support +obj-$(CONFIG_MBEDTLS_LIB_TLS) += mbedtls_lib_tls.o +mbedtls_lib_tls-y := \ + $(MBEDTLS_LIB_DIR)/mps_reader.o \ + $(MBEDTLS_LIB_DIR)/mps_trace.o \ + $(MBEDTLS_LIB_DIR)/net_sockets.o \ + $(MBEDTLS_LIB_DIR)/pk_ecc.o \ + $(MBEDTLS_LIB_DIR)/ssl_cache.o \ + $(MBEDTLS_LIB_DIR)/ssl_ciphersuites.o \ + $(MBEDTLS_LIB_DIR)/ssl_client.o \ + $(MBEDTLS_LIB_DIR)/ssl_cookie.o \ + $(MBEDTLS_LIB_DIR)/ssl_debug_helpers_generated.o \ + $(MBEDTLS_LIB_DIR)/ssl_msg.o \ + $(MBEDTLS_LIB_DIR)/ssl_ticket.o \ + $(MBEDTLS_LIB_DIR)/ssl_tls.o \ + $(MBEDTLS_LIB_DIR)/ssl_tls12_client.o \ + $(MBEDTLS_LIB_DIR)/hmac_drbg.o \ + $(MBEDTLS_LIB_DIR)/ctr_drbg.o \ + $(MBEDTLS_LIB_DIR)/entropy.o \ + $(MBEDTLS_LIB_DIR)/entropy_poll.o \ + $(MBEDTLS_LIB_DIR)/aes.o \ + $(MBEDTLS_LIB_DIR)/cipher.o \ + $(MBEDTLS_LIB_DIR)/cipher_wrap.o \ + $(MBEDTLS_LIB_DIR)/ecdh.o \ + $(MBEDTLS_LIB_DIR)/ecdsa.o \ + $(MBEDTLS_LIB_DIR)/ecp.o \ + $(MBEDTLS_LIB_DIR)/ecp_curves.o \ + $(MBEDTLS_LIB_DIR)/ecp_curves_new.o \ + $(MBEDTLS_LIB_DIR)/gcm.o \ diff --git a/lib/mbedtls/mbedtls_def_config.h b/lib/mbedtls/mbedtls_def_config.h index 1af911c2003f..ac8f0bbf2c0e 100644 --- a/lib/mbedtls/mbedtls_def_config.h +++ b/lib/mbedtls/mbedtls_def_config.h @@ -87,4 +87,56 @@
#endif /* #if defined CONFIG_MBEDTLS_LIB_X509 */
+#if CONFIG_IS_ENABLED(MBEDTLS_LIB_TLS) +#include "rtc.h" + +/* Generic options */ +#define MBEDTLS_ENTROPY_HARDWARE_ALT +#define MBEDTLS_HAVE_TIME +#define MBEDTLS_PLATFORM_MS_TIME_ALT +#define MBEDTLS_PLATFORM_TIME_MACRO rtc_mktime +#define MBEDTLS_PLATFORM_C +#define MBEDTLS_SSL_CLI_C +#define MBEDTLS_SSL_TLS_C +#define MBEDTLS_CIPHER_C +#define MBEDTLS_MD_C +#define MBEDTLS_CTR_DRBG_C +#define MBEDTLS_AES_C +#define MBEDTLS_ENTROPY_C +#define MBEDTLS_NO_PLATFORM_ENTROPY +#define MBEDTLS_SSL_PROTO_TLS1_2 +#define MBEDTLS_SSL_SERVER_NAME_INDICATION +#define MBEDTLS_KEY_EXCHANGE_PSK_ENABLED + +/* RSA */ +#define MBEDTLS_KEY_EXCHANGE_RSA_ENABLED +#define MBEDTLS_KEY_EXCHANGE_ECDHE_RSA_ENABLED +#define MBEDTLS_KEY_EXCHANGE_ECDH_RSA_ENABLED +#define MBEDTLS_GCM_C + +/* ECDSA */ +#define MBEDTLS_ECDSA_C +#define MBEDTLS_ECDH_C +#define MBEDTLS_ECDSA_DETERMINISTIC +#define MBEDTLS_HMAC_DRBG_C +#define MBEDTLS_KEY_EXCHANGE_ECDHE_ECDSA_ENABLED +#define MBEDTLS_KEY_EXCHANGE_ECDH_ECDSA_ENABLED +#define MBEDTLS_CAN_ECDH +#define MBEDTLS_PK_CAN_ECDSA_SIGN +#define MBEDTLS_ECP_C +#define MBEDTLS_ECP_DP_SECP256K1_ENABLED +#define MBEDTLS_ECP_DP_SECP192R1_ENABLED +#define MBEDTLS_ECP_DP_SECP224R1_ENABLED +#define MBEDTLS_ECP_DP_SECP256R1_ENABLED +#define MBEDTLS_ECP_DP_SECP384R1_ENABLED +#define MBEDTLS_ECP_DP_SECP521R1_ENABLED +#define MBEDTLS_ECP_DP_SECP192K1_ENABLED +#define MBEDTLS_ECP_DP_SECP224K1_ENABLED +#define MBEDTLS_ECP_DP_SECP256K1_ENABLED +#define MBEDTLS_ECP_DP_BP256R1_ENABLED +#define MBEDTLS_ECP_DP_BP384R1_ENABLED +#define MBEDTLS_ECP_DP_BP512R1_ENABLED + +#endif /* #if defined CONFIG_MBEDTLS_LIB_TLS */ + #endif /* #if defined CONFIG_MBEDTLS_LIB */
Hi Ilias,
On Thu, 24 Oct 2024 at 07:25, Ilias Apalodimas ilias.apalodimas@linaro.org wrote:
help
enabled
in wget
It would be better to use "#if defined CONFIG_MBEDTLS_LIB_TLS" here, as in SPL build it implicitly expects a "CONFIG_SPL_MBEDTLS_LIB_TLS" which we don't have.
[snip]
With above change, Reviewed-by: Raymond Mao raymond.mao@linaro.org
Regards, Raymond
Hi Raymond
On Thu, 24 Oct 2024 at 17:13, Raymond Mao raymond.mao@linaro.org wrote:
Hi Ilias,
help
in wget
We usually prefer CONFIG_IS_ENABLED(MBEDTLS_LIB_TLS) regardless of an SPL flag or not.
Thanks /Ilias
[snip]
Regards, Raymond
Hi Ilias,
On Thu, 24 Oct 2024 at 10:44, Ilias Apalodimas ilias.apalodimas@linaro.org wrote:
Hi Raymond
Hi Ilias,
On Thu, 24 Oct 2024 at 07:25, Ilias Apalodimas <
help
enabled
in wget
If the flag is never expected to be enabled in SPL build, that is OK.
Because in SPL, CONFIG_IS_ENABLED(MBEDTLS_LIB_TLS) will be always false without a CONFIG_SPL_MBEDTLS_LIB_TLS.
Regards, Raymond
Hi Ilias,
Signed-off-by: Ilias Apalodimas ilias.apalodimas@linaro.org Reviewed-by: Raymond Mao raymond.mao@linaro.org
- bool "MbedTLS TLS library"
- depends on RSA_PUBLIC_KEY_PARSER_MBEDTLS
- depends on X509_CERTIFICATE_PARSER_MBEDTLS
- depends on ASYMMETRIC_PUBLIC_KEY_MBEDTLS
- depends on ASN1_DECODER_MBEDTLS
- depends on MBEDTLS_LIB_CRYPTO
- help
in wget
Technically not true until patch 4/6. Maybe "Required for HTTPS support in wget"? Aside from that, LGTM.
Acked-by: Jerome Forissier jerome.forissier@linaro.org
Thanks,
The current code support mbedTLS 2.28. Since we are using a newer version in U-Boot, update the necessary accessors and the lwIP codebase to work with mbedTLS 3.6.0. It's worth noting that the patches are already sent to lwIP [0]
While at it enable LWIP_ALTCP_TLS and enable TLS support in lwIP
[0] https://github.com/lwip-tcpip/lwip/pull/47
Signed-off-by: Javier Tia javier.tia@linaro.org Signed-off-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- lib/lwip/Makefile | 3 ++ .../src/apps/altcp_tls/altcp_tls_mbedtls.c | 39 ++++++++++++------- lib/lwip/lwip/src/core/tcp_out.c | 10 +---- lib/lwip/u-boot/lwipopts.h | 6 +++ 4 files changed, 34 insertions(+), 24 deletions(-)
diff --git a/lib/lwip/Makefile b/lib/lwip/Makefile index dfcd700ca474..19e5c6897f5a 100644 --- a/lib/lwip/Makefile +++ b/lib/lwip/Makefile @@ -53,3 +53,6 @@ obj-y += \ lwip/src/core/timeouts.o \ lwip/src/core/udp.o \ lwip/src/netif/ethernet.o + +obj-$(CONFIG_MBEDTLS_LIB_TLS) += lwip/src/apps/altcp_tls/altcp_tls_mbedtls.o \ + lwip/src/apps/altcp_tls/altcp_tls_mbedtls_mem.o diff --git a/lib/lwip/lwip/src/apps/altcp_tls/altcp_tls_mbedtls.c b/lib/lwip/lwip/src/apps/altcp_tls/altcp_tls_mbedtls.c index a8c2fc2ee2cd..ef19821b89e0 100644 --- a/lib/lwip/lwip/src/apps/altcp_tls/altcp_tls_mbedtls.c +++ b/lib/lwip/lwip/src/apps/altcp_tls/altcp_tls_mbedtls.c @@ -3,7 +3,7 @@ * Application layered TCP/TLS connection API (to be used from TCPIP thread) * * This file provides a TLS layer using mbedTLS - * + * * This version is currently compatible with the 2.x.x branch (current LTS). */
@@ -70,7 +70,6 @@ /* @todo: which includes are really needed? */ #include "mbedtls/entropy.h" #include "mbedtls/ctr_drbg.h" -#include "mbedtls/certs.h" #include "mbedtls/x509.h" #include "mbedtls/ssl.h" #include "mbedtls/net_sockets.h" @@ -81,8 +80,6 @@ #include "mbedtls/ssl_cache.h" #include "mbedtls/ssl_ticket.h"
-#include "mbedtls/ssl_internal.h" /* to call mbedtls_flush_output after ERR_MEM */ - #include <string.h>
#ifndef ALTCP_MBEDTLS_ENTROPY_PTR @@ -132,6 +129,16 @@ static err_t altcp_mbedtls_lower_recv_process(struct altcp_pcb *conn, altcp_mbed static err_t altcp_mbedtls_handle_rx_appldata(struct altcp_pcb *conn, altcp_mbedtls_state_t *state); static int altcp_mbedtls_bio_send(void *ctx, const unsigned char *dataptr, size_t size);
+static void +altcp_mbedtls_flush_output(altcp_mbedtls_state_t *state) +{ + if (state->ssl_context.MBEDTLS_PRIVATE(out_left) != 0) { + int flushed = mbedtls_ssl_send_alert_message(&state->ssl_context, 0, 0); + if (flushed) { + LWIP_DEBUGF(ALTCP_MBEDTLS_DEBUG, ("mbedtls_ssl_send_alert_message failed: %d\n", flushed)); + } + } +}
/* callback functions from inner/lower connection: */
@@ -524,14 +531,14 @@ altcp_mbedtls_lower_sent(void *arg, struct altcp_pcb *inner_conn, u16_t len) LWIP_ASSERT("state", state != NULL); LWIP_ASSERT("pcb mismatch", conn->inner_conn == inner_conn); /* calculate TLS overhead part to not send it to application */ - overhead = state->overhead_bytes_adjust + state->ssl_context.out_left; + overhead = state->overhead_bytes_adjust + state->ssl_context.MBEDTLS_PRIVATE(out_left); if ((unsigned)overhead > len) { overhead = len; } /* remove ACKed bytes from overhead adjust counter */ state->overhead_bytes_adjust -= len; /* try to send more if we failed before (may increase overhead adjust counter) */ - mbedtls_ssl_flush_output(&state->ssl_context); + altcp_mbedtls_flush_output(state); /* remove calculated overhead from ACKed bytes len */ app_len = len - (u16_t)overhead; /* update application write counter and inform application */ @@ -559,7 +566,7 @@ altcp_mbedtls_lower_poll(void *arg, struct altcp_pcb *inner_conn) if (conn->state) { altcp_mbedtls_state_t *state = (altcp_mbedtls_state_t *)conn->state; /* try to send more if we failed before */ - mbedtls_ssl_flush_output(&state->ssl_context); + altcp_mbedtls_flush_output(state); if (altcp_mbedtls_handle_rx_appldata(conn, state) == ERR_ABRT) { return ERR_ABRT; } @@ -683,7 +690,7 @@ altcp_tls_set_session(struct altcp_pcb *conn, struct altcp_tls_session *session) if (session && conn && conn->state) { altcp_mbedtls_state_t *state = (altcp_mbedtls_state_t *)conn->state; int ret = -1; - if (session->data.start) + if (session->data.MBEDTLS_PRIVATE(start)) ret = mbedtls_ssl_set_session(&state->ssl_context, &session->data); return ret < 0 ? ERR_VAL : ERR_OK; } @@ -776,7 +783,7 @@ altcp_tls_create_config(int is_server, u8_t cert_count, u8_t pkey_count, int hav struct altcp_tls_config *conf; mbedtls_x509_crt *mem;
- if (TCP_WND < MBEDTLS_SSL_MAX_CONTENT_LEN) { + if (TCP_WND < MBEDTLS_SSL_IN_CONTENT_LEN || TCP_WND < MBEDTLS_SSL_OUT_CONTENT_LEN) { LWIP_DEBUGF(ALTCP_MBEDTLS_DEBUG|LWIP_DBG_LEVEL_SERIOUS, ("altcp_tls: TCP_WND is smaller than the RX decrypion buffer, connection RX might stall!\n")); } @@ -900,7 +907,7 @@ err_t altcp_tls_config_server_add_privkey_cert(struct altcp_tls_config *config, return ERR_VAL; }
- ret = mbedtls_pk_parse_key(pkey, (const unsigned char *) privkey, privkey_len, privkey_pass, privkey_pass_len); + ret = mbedtls_pk_parse_key(pkey, (const unsigned char *) privkey, privkey_len, privkey_pass, privkey_pass_len, mbedtls_ctr_drbg_random, &altcp_tls_entropy_rng->ctr_drbg); if (ret != 0) { LWIP_DEBUGF(ALTCP_MBEDTLS_DEBUG, ("mbedtls_pk_parse_public_key failed: %d\n", ret)); mbedtls_x509_crt_free(srvcert); @@ -1003,7 +1010,7 @@ altcp_tls_create_config_client_2wayauth(const u8_t *ca, size_t ca_len, const u8_ }
mbedtls_pk_init(conf->pkey); - ret = mbedtls_pk_parse_key(conf->pkey, privkey, privkey_len, privkey_pass, privkey_pass_len); + ret = mbedtls_pk_parse_key(conf->pkey, privkey, privkey_len, privkey_pass, privkey_pass_len, mbedtls_ctr_drbg_random, &altcp_tls_entropy_rng->ctr_drbg); if (ret != 0) { LWIP_DEBUGF(ALTCP_MBEDTLS_DEBUG, ("mbedtls_pk_parse_key failed: %d 0x%x\n", ret, -1*ret)); altcp_tls_free_config(conf); @@ -1189,7 +1196,7 @@ altcp_mbedtls_sndbuf(struct altcp_pcb *conn) size_t ret; #if defined(MBEDTLS_SSL_MAX_FRAGMENT_LENGTH) /* @todo: adjust ssl_added to real value related to negotiated cipher */ - size_t max_frag_len = mbedtls_ssl_get_max_frag_len(&state->ssl_context); + size_t max_frag_len = mbedtls_ssl_get_max_in_record_payload(&state->ssl_context); max_len = LWIP_MIN(max_frag_len, max_len); #endif /* Adjust sndbuf of inner_conn with what added by SSL */ @@ -1232,9 +1239,9 @@ altcp_mbedtls_write(struct altcp_pcb *conn, const void *dataptr, u16_t len, u8_t /* HACK: if there is something left to send, try to flush it and only allow sending more if this succeeded (this is a hack because neither returning 0 nor MBEDTLS_ERR_SSL_WANT_WRITE worked for me) */ - if (state->ssl_context.out_left) { - mbedtls_ssl_flush_output(&state->ssl_context); - if (state->ssl_context.out_left) { + if (state->ssl_context.MBEDTLS_PRIVATE(out_left)) { + altcp_mbedtls_flush_output(state); + if (state->ssl_context.MBEDTLS_PRIVATE(out_left)) { return ERR_MEM; } } @@ -1284,6 +1291,8 @@ altcp_mbedtls_bio_send(void *ctx, const unsigned char *dataptr, size_t size) while (size_left) { u16_t write_len = (u16_t)LWIP_MIN(size_left, 0xFFFF); err_t err = altcp_write(conn->inner_conn, (const void *)dataptr, write_len, apiflags); + /* try to send data... */ + altcp_output(conn->inner_conn); if (err == ERR_OK) { written += write_len; size_left -= write_len; diff --git a/lib/lwip/lwip/src/core/tcp_out.c b/lib/lwip/lwip/src/core/tcp_out.c index 64579ee5cbd8..b5d312137368 100644 --- a/lib/lwip/lwip/src/core/tcp_out.c +++ b/lib/lwip/lwip/src/core/tcp_out.c @@ -1255,14 +1255,6 @@ tcp_output(struct tcp_pcb *pcb) LWIP_ASSERT("don't call tcp_output for listen-pcbs", pcb->state != LISTEN);
- /* First, check if we are invoked by the TCP input processing - code. If so, we do not output anything. Instead, we rely on the - input processing code to call us when input processing is done - with. */ - if (tcp_input_pcb == pcb) { - return ERR_OK; - } - wnd = LWIP_MIN(pcb->snd_wnd, pcb->cwnd);
seg = pcb->unsent; @@ -2036,7 +2028,7 @@ tcp_rst(const struct tcp_pcb *pcb, u32_t seqno, u32_t ackno, u16_t local_port, u16_t remote_port) { struct pbuf *p; - + p = tcp_rst_common(pcb, seqno, ackno, local_ip, remote_ip, local_port, remote_port); if (p != NULL) { tcp_output_control_segment(pcb, p, local_ip, remote_ip); diff --git a/lib/lwip/u-boot/lwipopts.h b/lib/lwip/u-boot/lwipopts.h index 9d618625facb..88d6faf327ae 100644 --- a/lib/lwip/u-boot/lwipopts.h +++ b/lib/lwip/u-boot/lwipopts.h @@ -154,4 +154,10 @@ #define MEMP_MEM_INIT 1 #define MEM_LIBC_MALLOC 1
+#if defined(CONFIG_MBEDTLS_LIB_TLS) +#define LWIP_ALTCP 1 +#define LWIP_ALTCP_TLS 1 +#define LWIP_ALTCP_TLS_MBEDTLS 1 +#endif + #endif /* LWIP_UBOOT_LWIPOPTS_H */
- lwip/src/apps/altcp_tls/altcp_tls_mbedtls_mem.o
- Application layered TCP/TLS connection API (to be used from TCPIP thread)
- This file provides a TLS layer using mbedTLS
Unrelated formatting change, do we want to do this in a separate patch maybe?
- This version is currently compatible with the 2.x.x branch (current LTS).
#include <string.h>
- if (state->ssl_context.MBEDTLS_PRIVATE(out_left) != 0) {
- int flushed = mbedtls_ssl_send_alert_message(&state->ssl_context, 0, 0);
- if (flushed) {
- overhead = state->overhead_bytes_adjust + state->ssl_context.MBEDTLS_PRIVATE(out_left); if ((unsigned)overhead > len) { overhead = len; } /* remove ACKed bytes from overhead adjust counter */ state->overhead_bytes_adjust -= len; /* try to send more if we failed before (may increase overhead adjust counter) */
- altcp_mbedtls_flush_output(state); /* remove calculated overhead from ACKed bytes len */ app_len = len - (u16_t)overhead; /* update application write counter and inform application */
- if (session->data.MBEDTLS_PRIVATE(start)) ret = mbedtls_ssl_set_session(&state->ssl_context, &session->data); return ret < 0 ? ERR_VAL : ERR_OK; }
- if (TCP_WND < MBEDTLS_SSL_IN_CONTENT_LEN || TCP_WND < MBEDTLS_SSL_OUT_CONTENT_LEN) { LWIP_DEBUGF(ALTCP_MBEDTLS_DEBUG|LWIP_DBG_LEVEL_SERIOUS, ("altcp_tls: TCP_WND is smaller than the RX decrypion buffer, connection RX might stall!\n")); }
- ret = mbedtls_pk_parse_key(pkey, (const unsigned char *) privkey, privkey_len, privkey_pass, privkey_pass_len, mbedtls_ctr_drbg_random, &altcp_tls_entropy_rng->ctr_drbg); if (ret != 0) { LWIP_DEBUGF(ALTCP_MBEDTLS_DEBUG, ("mbedtls_pk_parse_public_key failed: %d\n", ret)); mbedtls_x509_crt_free(srvcert);
- ret = mbedtls_pk_parse_key(conf->pkey, privkey, privkey_len, privkey_pass, privkey_pass_len, mbedtls_ctr_drbg_random, &altcp_tls_entropy_rng->ctr_drbg); if (ret != 0) { LWIP_DEBUGF(ALTCP_MBEDTLS_DEBUG, ("mbedtls_pk_parse_key failed: %d 0x%x\n", ret, -1*ret)); altcp_tls_free_config(conf);
- if (state->ssl_context.MBEDTLS_PRIVATE(out_left)) {
- if (state->ssl_context.MBEDTLS_PRIVATE(out_left)) { return ERR_MEM; } }
- /* try to send data... */
- altcp_output(conn->inner_conn); if (err == ERR_OK) { written += write_len; size_left -= write_len;
with. */
return ERR_OK;
seg = pcb->unsent;
Thanks,
On Wed, 6 Nov 2024 at 13:37, Jerome Forissier jerome.forissier@linaro.org wrote:
#include <string.h>
- if (flushed) {
with. */
return ERR_OK;
seg = pcb->unsent;
Thanks,
Thanks I'll get rid of the line changes in v3
-- Jerome
SNI, or Server Name Indication, is an addition to the TLS encryption protocol that enables a client device to specify the domain name it is trying to reach in the first step of the TLS handshake, preventing common name mismatch errors and not reaching to HTTPS server that enforce this condition. Since most of the websites require it nowadays add support for it.
It's worth noting that this is already sent to lwIP [0]
Signed-off-by: Javier Tia javier.tia@linaro.org Signed-off-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- lib/lwip/lwip/src/apps/altcp_tls/altcp_tls_mbedtls.c | 11 +++++++---- lib/lwip/lwip/src/include/lwip/altcp_tls.h | 2 +- 2 files changed, 8 insertions(+), 5 deletions(-)
diff --git a/lib/lwip/lwip/src/apps/altcp_tls/altcp_tls_mbedtls.c b/lib/lwip/lwip/src/apps/altcp_tls/altcp_tls_mbedtls.c index ef19821b89e0..24b432966312 100644 --- a/lib/lwip/lwip/src/apps/altcp_tls/altcp_tls_mbedtls.c +++ b/lib/lwip/lwip/src/apps/altcp_tls/altcp_tls_mbedtls.c @@ -106,6 +106,7 @@ struct altcp_tls_config { u8_t pkey_count; u8_t pkey_max; mbedtls_x509_crt *ca; + char host[256]; #if defined(MBEDTLS_SSL_CACHE_C) && ALTCP_MBEDTLS_USE_SESSION_CACHE /** Inter-connection cache for fast connection startup */ struct mbedtls_ssl_cache_context cache; @@ -642,6 +643,7 @@ altcp_mbedtls_setup(void *conf, struct altcp_pcb *conn, struct altcp_pcb *inner_ /* tell mbedtls about our I/O functions */ mbedtls_ssl_set_bio(&state->ssl_context, conn, altcp_mbedtls_bio_send, altcp_mbedtls_bio_recv, NULL);
+ mbedtls_ssl_set_hostname(&state->ssl_context, config->host); altcp_mbedtls_setup_callbacks(conn, inner_conn); conn->inner_conn = inner_conn; conn->fns = &altcp_mbedtls_functions; @@ -951,7 +953,7 @@ altcp_tls_create_config_server_privkey_cert(const u8_t *privkey, size_t privkey_ }
static struct altcp_tls_config * -altcp_tls_create_config_client_common(const u8_t *ca, size_t ca_len, int is_2wayauth) +altcp_tls_create_config_client_common(const u8_t *ca, size_t ca_len, int is_2wayauth, char *host) { int ret; struct altcp_tls_config *conf = altcp_tls_create_config(0, (is_2wayauth) ? 1 : 0, (is_2wayauth) ? 1 : 0, ca != NULL); @@ -973,13 +975,14 @@ altcp_tls_create_config_client_common(const u8_t *ca, size_t ca_len, int is_2way
mbedtls_ssl_conf_ca_chain(&conf->conf, conf->ca, NULL); } + memcpy(conf->host, host, sizeof(conf->host)); return conf; }
struct altcp_tls_config * -altcp_tls_create_config_client(const u8_t *ca, size_t ca_len) +altcp_tls_create_config_client(const u8_t *ca, size_t ca_len, char *host) { - return altcp_tls_create_config_client_common(ca, ca_len, 0); + return altcp_tls_create_config_client_common(ca, ca_len, 0, host); }
struct altcp_tls_config * @@ -995,7 +998,7 @@ altcp_tls_create_config_client_2wayauth(const u8_t *ca, size_t ca_len, const u8_ return NULL; }
- conf = altcp_tls_create_config_client_common(ca, ca_len, 1); + conf = altcp_tls_create_config_client_common(ca, ca_len, 1, NULL); if (conf == NULL) { return NULL; } diff --git a/lib/lwip/lwip/src/include/lwip/altcp_tls.h b/lib/lwip/lwip/src/include/lwip/altcp_tls.h index fcb784d89d70..fb0618234481 100644 --- a/lib/lwip/lwip/src/include/lwip/altcp_tls.h +++ b/lib/lwip/lwip/src/include/lwip/altcp_tls.h @@ -92,7 +92,7 @@ struct altcp_tls_config *altcp_tls_create_config_server_privkey_cert(const u8_t /** @ingroup altcp_tls * Create an ALTCP_TLS client configuration handle */ -struct altcp_tls_config *altcp_tls_create_config_client(const u8_t *cert, size_t cert_len); +struct altcp_tls_config *altcp_tls_create_config_client(const u8_t *cert, size_t cert_len, char *host);
/** @ingroup altcp_tls * Create an ALTCP_TLS client configuration handle with two-way server/client authentication
- char host[256];
- mbedtls_ssl_set_hostname(&state->ssl_context, config->host); altcp_mbedtls_setup_callbacks(conn, inner_conn); conn->inner_conn = inner_conn; conn->fns = &altcp_mbedtls_functions;
- memcpy(conf->host, host, sizeof(conf->host));
What if host is smaller than sizeof(conf->host)? Should be strncpy() IMHO.
return conf; }
- return altcp_tls_create_config_client_common(ca, ca_len, 0, host);
- conf = altcp_tls_create_config_client_common(ca, ca_len, 1, NULL); if (conf == NULL) { return NULL; }
- Create an ALTCP_TLS client configuration handle
- Create an ALTCP_TLS client configuration handle with two-way server/client authentication
With the above comment addressed:
Reviewed-by: Jerome Forissier jerome.forissier@linaro.org
Thanks,
Hi Jerome,
On Wed, 6 Nov 2024 at 13:39, Jerome Forissier jerome.forissier@linaro.org wrote:
- char host[256];
Looking at it, if host is smaller than sizeof(conf->host) we will copy random bytes from that and we dont know what... So I think it's better to memcpy the min value of strlen(host) and sizeof(conf->host)?
Thanks /Ilias
return conf; }
Thanks,
Jerome
With the recent changes of lwip & mbedTLS we can now download from https:// urls instead of just http://. Adjust our wget lwip version parsing to support both URLs. While at it adjust the default TCP window for QEMU since https seems to require at least 16384
Signed-off-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- cmd/Kconfig | 19 ++++++++++++ net/lwip/Kconfig | 2 +- net/lwip/wget.c | 78 +++++++++++++++++++++++++++++++++++++++++++----- 3 files changed, 91 insertions(+), 8 deletions(-)
diff --git a/cmd/Kconfig b/cmd/Kconfig index 3ee70f31b142..1d90a884e2c1 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -2126,6 +2126,25 @@ config CMD_WGET wget is a simple command to download kernel, or other files, from a http server over TCP.
+config WGET_HTTPS + bool "wget https" + depends on CMD_WGET + depends on PROT_TCP_LWIP + depends on MBEDTLS_LIB + select SHA256 + select RSA + select ASYMMETRIC_KEY_TYPE + select ASYMMETRIC_PUBLIC_KEY_SUBTYPE + select X509_CERTIFICATE_PARSER + select PKCS7_MESSAGE_PARSER + select MBEDTLS_LIB_CRYPTO + select MBEDTLS_LIB_TLS + select RSA_VERIFY_WITH_PKEY + select X509_CERTIFICATE_PARSER + select PKCS7_MESSAGE_PARSER + help + Enable TLS over http for wget. + endif # if CMD_NET
config CMD_PXE diff --git a/net/lwip/Kconfig b/net/lwip/Kconfig index 8a67de4cf335..a9ae9bf7fa2a 100644 --- a/net/lwip/Kconfig +++ b/net/lwip/Kconfig @@ -37,7 +37,7 @@ config PROT_UDP_LWIP
config LWIP_TCP_WND int "Value of TCP_WND" - default 8000 if ARCH_QEMU + default 32768 if ARCH_QEMU default 3000000 help Default value for TCP_WND in the lwIP configuration diff --git a/net/lwip/wget.c b/net/lwip/wget.c index b495ebd1aa96..1a2ecdcddf34 100644 --- a/net/lwip/wget.c +++ b/net/lwip/wget.c @@ -7,13 +7,17 @@ #include <efi_loader.h> #include <image.h> #include <lwip/apps/http_client.h> +#include "lwip/altcp_tls.h" #include <lwip/timeouts.h> +#include <rng.h> #include <mapmem.h> #include <net.h> #include <time.h> +#include <dm/uclass.h>
#define SERVER_NAME_SIZE 200 #define HTTP_PORT_DEFAULT 80 +#define HTTPS_PORT_DEFAULT 443 #define PROGRESS_PRINT_STEP_BYTES (100 * 1024)
enum done_state { @@ -32,18 +36,53 @@ struct wget_ctx { enum done_state done; };
+bool wget_validate_uri(char *uri); + +int mbedtls_hardware_poll(void *data, unsigned char *output, size_t len, + size_t *olen) +{ + struct udevice *dev; + u64 rng = 0; + int ret; + + *olen = 0; + + ret = uclass_get_device(UCLASS_RNG, 0, &dev); + if (ret) { + log_err("Failed to get an rng: %d\n", ret); + return ret; + } + ret = dm_rng_read(dev, &rng, sizeof(rng)); + if (ret) + return ret; + + memcpy(output, &rng, len); + *olen = sizeof(rng); + + return 0; +} + static int parse_url(char *url, char *host, u16 *port, char **path) { char *p, *pp; long lport; + size_t prefix_len = 0; + + if (!wget_validate_uri(url)) { + log_err("Invalid URL. Use http(s)://\n"); + return -EINVAL; + }
+ *port = HTTP_PORT_DEFAULT; + prefix_len = strlen("http://"); p = strstr(url, "http://"); if (!p) { - log_err("only http:// is supported\n"); - return -EINVAL; + p = strstr(url, "https://"); + prefix_len = strlen("https://"); + *port = HTTPS_PORT_DEFAULT; }
- p += strlen("http://"); + p += prefix_len;
/* Parse hostname */ pp = strchr(p, ':'); @@ -67,9 +106,8 @@ static int parse_url(char *url, char *host, u16 *port, char **path) if (lport > 65535) return -EINVAL; *port = (u16)lport; - } else { - *port = HTTP_PORT_DEFAULT; } + if (*pp != '/') return -EINVAL; *path = pp; @@ -210,6 +248,9 @@ static void httpc_result_cb(void *arg, httpc_result_t httpc_result, static int wget_loop(struct udevice *udev, ulong dst_addr, char *uri) { char server_name[SERVER_NAME_SIZE]; +#if defined CONFIG_WGET_HTTPS + altcp_allocator_t tls_allocator; +#endif httpc_connection_t conn; httpc_state_t *state; struct netif *netif; @@ -232,6 +273,22 @@ static int wget_loop(struct udevice *udev, ulong dst_addr, char *uri) return -1;
memset(&conn, 0, sizeof(conn)); +#if defined CONFIG_WGET_HTTPS + if (port == HTTPS_PORT_DEFAULT) { + tls_allocator.alloc = &altcp_tls_alloc; + tls_allocator.arg = + altcp_tls_create_config_client(NULL, 0, server_name); + + if (!tls_allocator.arg) { + log_err("error: Cannot create a TLS connection\n"); + net_lwip_remove_netif(netif); + return -1; + } + + conn.altcp_allocator = &tls_allocator; + } +#endif + conn.result_fn = httpc_result_cb; ctx.path = path; if (httpc_get_file_dns(server_name, port, path, &conn, httpc_recv_cb, @@ -316,6 +373,7 @@ bool wget_validate_uri(char *uri) char c; bool ret = true; char *str_copy, *s, *authority; + size_t prefix_len = 0;
for (c = 0x1; c < 0x21; c++) { if (strchr(uri, c)) { @@ -323,15 +381,21 @@ bool wget_validate_uri(char *uri) return false; } } + if (strchr(uri, 0x7f)) { log_err("invalid character is used\n"); return false; }
- if (strncmp(uri, "http://", 7)) { - log_err("only http:// is supported\n"); + if (!strncmp(uri, "http://", strlen("http://"))) { + prefix_len = strlen("http://"); + } else if (!strncmp(uri, "https://", strlen("https://"))) { + prefix_len = strlen("https://"); + } else { + log_err("only http(s):// is supported\n"); return false; } + str_copy = strdup(uri); if (!str_copy) return false;
Replying to myself here but
On Thu, 24 Oct 2024 at 14:25, Ilias Apalodimas ilias.apalodimas@linaro.org wrote:
+config WGET_HTTPS
bool "wget https"
depends on CMD_WGET
select SHA256
select RSA
help
endif # if CMD_NET
size_t *olen)
u64 rng = 0;
int ret;
*olen = 0;
if (ret) {
return ret;
if (ret)
return ret;
I just realized I forgot to address this. I'll fix it on v3, but the rest of the code is ok to review
Thanks /Ilias
return -EINVAL;
return -EINVAL;
p += prefix_len; /* Parse hostname */ pp = strchr(p, ':');
} else {
tls_allocator.arg =
return -1;
size_t prefix_len = 0; for (c = 0x1; c < 0x21; c++) { if (strchr(uri, c)) {
} else {
-- 2.45.2
On Thu, 24 Oct 2024 at 17:04, Ilias Apalodimas ilias.apalodimas@linaro.org wrote:
+config WGET_HTTPS
bool "wget https"
depends on CMD_WGET
select SHA256
select RSA
help
endif # if CMD_NET
size_t *olen)
u64 rng = 0;
int ret;
*olen = 0;
if (ret) {
return ret;
if (ret)
return ret;
So, the correct thing to do here is memcpy(output, &rng, len); *olen = LWIP_MIN(len, sizeof(rng)); <-- mbedTLS sets len to 128, so although sizeof(rng); is ok for now we can't rely on that
Thanks /Ilias
return -EINVAL;
return -EINVAL;
} else {
tls_allocator.arg =
return -1;
} else {
-- 2.45.2
Hi Ilias,
+config WGET_HTTPS
- bool "wget https"
- depends on CMD_WGET
- depends on PROT_TCP_LWIP
select SHA256
select RSA
- select MBEDTLS_LIB_CRYPTO
- select MBEDTLS_LIB_TLS
- select RSA_VERIFY_WITH_PKEY
- select X509_CERTIFICATE_PARSER
- select PKCS7_MESSAGE_PARSER
- help
s/http/HTTP/ Maybe add "This adds support for https:// URLs"?
endif # if CMD_NET
- default 32768 if ARCH_QEMU default 3000000 help Default value for TCP_WND in the lwIP configuration
size_t *olen)
- struct udevice *dev;
- u64 rng = 0;
- int ret;
- *olen = 0;
- ret = uclass_get_device(UCLASS_RNG, 0, &dev);
- if (ret) {
return ret;
- ret = dm_rng_read(dev, &rng, sizeof(rng));
- if (ret)
return ret;
- memcpy(output, &rng, len);
- *olen = sizeof(rng);
return -EINVAL;
return -EINVAL;
}*port = HTTPS_PORT_DEFAULT;
p += prefix_len;
- } else {
}*port = HTTP_PORT_DEFAULT;
- if (*pp != '/') return -EINVAL; *path = pp;
- altcp_allocator_t tls_allocator;
- if (port == HTTPS_PORT_DEFAULT) {
Does this mean the port has to be 443 for HTTPS to be used? Or that plain HTTP is not possible over port 443? That would be overly restrictive IMO.
tls_allocator.arg =
return -1;
- conn.result_fn = httpc_result_cb; ctx.path = path; if (httpc_get_file_dns(server_name, port, path, &conn, httpc_recv_cb,
- if (strchr(uri, 0x7f)) { log_err("invalid character is used\n"); return false; }
- if (!strncmp(uri, "http://", strlen("http://"))) {
- } else if (!strncmp(uri, "https://", strlen("https://"))) {
- } else {
return false; }log_err("only http(s):// is supported\n");
- str_copy = strdup(uri); if (!str_copy) return false;
Thanks,
Hi Jerome
On Wed, 6 Nov 2024 at 13:50, Jerome Forissier jerome.forissier@linaro.org wrote:
Hi Ilias,
+config WGET_HTTPS
bool "wget https"
depends on CMD_WGET
select SHA256
select RSA
help
Sure
endif # if CMD_NET
size_t *olen)
u64 rng = 0;
int ret;
*olen = 0;
if (ret) {
return ret;
if (ret)
return ret;
return -EINVAL;
return -EINVAL;
} else {
We set that port in parse_url(). So if http:// is parsed we will, by default, set it to 80 and if https:// is found we set it to 443. But I think you are right, we already support configurable port numbers which I missed, so I'll just pass a bool to parse_url and only enable this for https:// regardless of the port
Cheers /Ilias
tls_allocator.arg =
return -1;
} else {
Thanks,
Jerome
QEMU already has an lwip variant of a defconfig. That defconfig is also configured with mbedTLS by default. So let's enable the remaining config options to enable wget for https:// as well and test that codepath in the CI
Reviewed-by: Jerome Forissier jerome.forissier@linaro.org Reviewed-by: Peter Robinson pbrobinson@gmail.com Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- configs/qemu_arm64_lwip_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/qemu_arm64_lwip_defconfig b/configs/qemu_arm64_lwip_defconfig index d3d8ef16e668..754c770c33fc 100644 --- a/configs/qemu_arm64_lwip_defconfig +++ b/configs/qemu_arm64_lwip_defconfig @@ -7,3 +7,4 @@ CONFIG_NET_LWIP=y CONFIG_CMD_DNS=y CONFIG_CMD_WGET=y CONFIG_EFI_HTTP_BOOT=y +CONFIG_WGET_HTTPS=y
Thanks,
We now can use a combination og lwIP & mbedTLS and download from https://. Describe the config options needed to enable it as well as some limitations
Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- doc/develop/uefi/uefi.rst | 45 +++++++++++++++++++++++++++++++++++++-- 1 file changed, 43 insertions(+), 2 deletions(-)
diff --git a/doc/develop/uefi/uefi.rst b/doc/develop/uefi/uefi.rst index 0760ca91d4fc..e19dcaac8056 100644 --- a/doc/develop/uefi/uefi.rst +++ b/doc/develop/uefi/uefi.rst @@ -681,8 +681,8 @@ UEFI variables. Booting according to these variables is possible via:: As of U-Boot v2020.10 UEFI variables cannot be set at runtime. The U-Boot command 'efidebug' can be used to set the variables.
-UEFI HTTP Boot -~~~~~~~~~~~~~~ +UEFI HTTP Boot using the legacy TCP stack +~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
HTTP Boot provides the capability for system deployment and configuration over the network. HTTP Boot can be activated by specifying:: @@ -715,6 +715,47 @@ We need to preset the "httpserverip" environment variable to proceed the wget::
setenv httpserverip 192.168.1.1
+UEFI HTTP(s) Boot using lwIP +~~~~~~~~~~~~~~~~~~~~~~~~~~~~ +Similar to the above U-Boot can do EFI HTTP boot using lwIP. If we combine this +with mbedTLS we can also download from https:// + +HTTP(s) Boot can be activated by specifying:: + + CONFIG_EFI_HTTP_BOOT + CONFIG_NET_LWIP + CONFIG_WGET_HTTPS + +For QEMU targets there's a Kconfig that supports this by default:: + + make qemu_arm64_lwip_defconfig + +The commands and functionality are similar to the legacy stack, with the notable +exception of not having to define an "httpserverip" if you are trying to resolve +an IP. However, lwIP code doesn't yet support redirects:: + + => efidebug boot add -u 1 netinst https://cdimage.debian.org/cdimage/weekly-builds/arm64/iso-cd/debian-testing... + => dhcp + DHCP client bound to address 10.0.2.15 (3 ms) + => efidebug boot order 1 + => bootefi bootmgr + + HTTP server error 302 + Loading Boot0001 'netinst' failed + EFI boot manager: Cannot load any image + +If the url you specified isn't a redirect:: + + => efidebug boot add -u 1 netinst https://download.rockylinux.org/pub/rocky/9/isos/aarch64/Rocky-9.4-aarch64-m... + => dhcp + => bootefi bootmgr + ####################################### + +If the downloaded file extension is .iso or .img file, efibootmgr tries to +mount the image and boot with the default file(e.g. EFI/BOOT/BOOTAA64.EFI). +If the downloaded file is PE-COFF image, load the downloaded file and +start it. + Executing the built in hello world application ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
Hi Ilias,
The proper spelling is "Mbed TLS" [1]
[1] https://www.trustedfirmware.org/projects/mbed-tls/
- CONFIG_EFI_HTTP_BOOT
- CONFIG_NET_LWIP
- CONFIG_WGET_HTTPS
- make qemu_arm64_lwip_defconfig
- => efidebug boot add -u 1 netinst https://cdimage.debian.org/cdimage/weekly-builds/arm64/iso-cd/debian-testing...
- => dhcp
- DHCP client bound to address 10.0.2.15 (3 ms)
- => efidebug boot order 1
- => bootefi bootmgr
- HTTP server error 302
- Loading Boot0001 'netinst' failed
- EFI boot manager: Cannot load any image
- => efidebug boot add -u 1 netinst https://download.rockylinux.org/pub/rocky/9/isos/aarch64/Rocky-9.4-aarch64-m...
- => dhcp
With the spelling fixed:
Thanks,
Ilias Apalodimas
Jerome Forissier
Raymond Mao
