[U-Boot] [PATCH] arm: stm32mp1: add PSCI support
Add minimal PSCI support for Linux.
Signed-off-by: Patrick Delaunay patrick.delaunay@st.com ---
arch/arm/mach-stm32mp/Kconfig | 3 + arch/arm/mach-stm32mp/Makefile | 1 + arch/arm/mach-stm32mp/include/mach/stm32.h | 2 + arch/arm/mach-stm32mp/psci.c | 91 ++++++++++++++++++++++++++++++ include/configs/stm32mp1.h | 5 ++ 5 files changed, 102 insertions(+) create mode 100644 arch/arm/mach-stm32mp/psci.c
diff --git a/arch/arm/mach-stm32mp/Kconfig b/arch/arm/mach-stm32mp/Kconfig index 9771af9..c1ad939 100644 --- a/arch/arm/mach-stm32mp/Kconfig +++ b/arch/arm/mach-stm32mp/Kconfig @@ -23,7 +23,10 @@ config SYS_SOC
config TARGET_STM32MP1 bool "Support stm32mp1xx" + select ARCH_SUPPORT_PSCI select CPU_V7 + select CPU_V7_HAS_NONSEC + select CPU_V7_HAS_VIRT select PINCTRL_STM32 select STM32_RESET help diff --git a/arch/arm/mach-stm32mp/Makefile b/arch/arm/mach-stm32mp/Makefile index a495c53..f746691 100644 --- a/arch/arm/mach-stm32mp/Makefile +++ b/arch/arm/mach-stm32mp/Makefile @@ -9,3 +9,4 @@ obj-y += dram_init.o obj-y += syscon.o
obj-$(CONFIG_SPL_BUILD) += spl.o +obj-$(CONFIG_ARMV7_PSCI) += psci.o diff --git a/arch/arm/mach-stm32mp/include/mach/stm32.h b/arch/arm/mach-stm32mp/include/mach/stm32.h index c7a2789..d6f960f 100644 --- a/arch/arm/mach-stm32mp/include/mach/stm32.h +++ b/arch/arm/mach-stm32mp/include/mach/stm32.h @@ -74,6 +74,8 @@ enum boot_device {
/* TAMP registers */ #define TAMP_BACKUP_REGISTER(x) (STM32_TAMP_BASE + 0x100 + 4 * x) +#define TAMP_BACKUP_MAGIC_NUMBER TAMP_BACKUP_REGISTER(4) +#define TAMP_BACKUP_BRANCH_ADDRESS TAMP_BACKUP_REGISTER(5) #define TAMP_BOOT_CONTEXT TAMP_BACKUP_REGISTER(20)
#define TAMP_BOOT_MODE_MASK GENMASK(15, 8) diff --git a/arch/arm/mach-stm32mp/psci.c b/arch/arm/mach-stm32mp/psci.c new file mode 100644 index 0000000..0912242 --- /dev/null +++ b/arch/arm/mach-stm32mp/psci.c @@ -0,0 +1,91 @@ +/* + * Copyright (C) 2018, STMicroelectronics - All Rights Reserved + * + * SPDX-License-Identifier: GPL-2.0+ BSD-3-Clause + */ + +#include <config.h> +#include <common.h> +#include <asm/armv7.h> +#include <asm/gic.h> +#include <asm/io.h> +#include <asm/psci.h> +#include <asm/secure.h> + +#define BOOT_API_A7_CORE1_MAGIC_NUMBER 0xCA7FACE1 + +#define RCC_MP_GRSTCSETR (STM32_RCC_BASE + 0x0404) +#define RCC_MP_GRSTCSETR_MPUP1RST BIT(5) +#define RCC_MP_GRSTCSETR_MPSYSRST BIT(0) + +static u32 __secure stm32mp_get_gicd_base_address(void) +{ + u32 periphbase; + + /* get the GIC base address from the CBAR register */ + asm("mrc p15, 4, %0, c15, c0, 0\n" : "=r" (periphbase)); + + return (periphbase & CBAR_MASK) + GIC_DIST_OFFSET; +} + +static void __secure stm32mp_smp_kick_all_cpus(void) +{ + u32 gic_dist_addr; + + gic_dist_addr = stm32mp_get_gicd_base_address(); + + /* kick all CPUs (except this one) by writing to GICD_SGIR */ + writel(1U << 24, gic_dist_addr + GICD_SGIR); +} + +int __secure psci_features(unsigned int psci_fid) +{ + switch (psci_fid) { + case ARM_PSCI_0_2_FN_PSCI_VERSION: + case ARM_PSCI_0_2_FN_CPU_ON: + case ARM_PSCI_0_2_FN_CPU_OFF: + case ARM_PSCI_0_2_FN_SYSTEM_RESET: + return 0x0; + } + return ARM_PSCI_RET_NI; +} + +unsigned int __secure psci_version(void) +{ + return ARM_PSCI_VER_1_0; +} + +int __secure psci_cpu_on(u32 __always_unused unused, u32 mpidr, u32 pc) +{ + u32 cpu = (mpidr & 0x3); + + /* store target PC */ + psci_save_target_pc(cpu, pc); + + /* write entrypoint in backup RAM register */ + writel((u32)&psci_cpu_entry, TAMP_BACKUP_BRANCH_ADDRESS); + + /* write magic number in backup register */ + writel(BOOT_API_A7_CORE1_MAGIC_NUMBER, TAMP_BACKUP_MAGIC_NUMBER); + stm32mp_smp_kick_all_cpus(); + + return ARM_PSCI_RET_SUCCESS; +} + +void __secure psci_cpu_off(void) +{ + /* reset core #1 : wfi is managed by BootRom */ + writel(RCC_MP_GRSTCSETR_MPUP1RST, RCC_MP_GRSTCSETR); + /* just waiting reset */ + while (1) + wfi(); +} + +void __secure psci_system_reset(u32 function_id) +{ + /* System reset */ + writel(RCC_MP_GRSTCSETR_MPSYSRST, RCC_MP_GRSTCSETR); + /* just waiting reset */ + while (1) + wfi(); +} diff --git a/include/configs/stm32mp1.h b/include/configs/stm32mp1.h index da0e259..e0e7747 100644 --- a/include/configs/stm32mp1.h +++ b/include/configs/stm32mp1.h @@ -19,6 +19,11 @@ #define CONFIG_SYS_HZ 1000 #define CONFIG_SYS_ARCH_TIMER
+/* PSCI support */ +#define CONFIG_ARMV7_PSCI_1_0 +#define CONFIG_ARMV7_SECURE_BASE STM32_SYSRAM_BASE +#define CONFIG_ARMV7_SECURE_MAX_SIZE STM32_SYSRAM_SIZE + /* * malloc() pool size */
- switch (psci_fid) {
- case ARM_PSCI_0_2_FN_PSCI_VERSION:
- case ARM_PSCI_0_2_FN_CPU_ON:
- case ARM_PSCI_0_2_FN_CPU_OFF:
- case ARM_PSCI_0_2_FN_SYSTEM_RESET:
return 0x0;
- return ARM_PSCI_RET_NI;
- return ARM_PSCI_VER_1_0;
I'm a bit worried, because while PSCI_VERSION reports PSCI 1.0, this does not appear to be conformant with teh PSCI 1.0 spec, as some mandatory functions are missing:
* AFFINITY_INFO -- Linux relies on this to ensure that CPUs have exited the kernel when calling CPU_OFF (e.g. so that we don't free any data / code that said CPU may be using on the path to calling CPU_OFF).
* SYSTEM_OFF -- Can you implement this similarly to SYSTEM_RESET?
What about the context_id? PSCI 0.2+ mandates it, and some project rely upon it (though Linux currently does not).
- u32 cpu = (mpidr & 0x3);
- /* store target PC */
- psci_save_target_pc(cpu, pc);
- /* write entrypoint in backup RAM register */
- writel((u32)&psci_cpu_entry, TAMP_BACKUP_BRANCH_ADDRESS);
- /* write magic number in backup register */
- writel(BOOT_API_A7_CORE1_MAGIC_NUMBER, TAMP_BACKUP_MAGIC_NUMBER);
- stm32mp_smp_kick_all_cpus();
- return ARM_PSCI_RET_SUCCESS;
Does some other part of U-Boot do some state tracking? What happens if this is called for a CPU that's already online?
Thanks, Mark.
Hi Mark,
-----Original Message----- From: Mark Rutland [mailto:mark.rutland@arm.com]
+int __secure psci_features(unsigned int psci_fid) {
return 0x0;
+unsigned int __secure psci_version(void) {
I push this patch for STM32MP1 to be able to boot the Kernel version on board (requested by ST Linux team : https://patchwork.kernel.org/patch/10167343/)
This patch a minimal PSCI support to be able to boot.... And I miss these part of the requirement PSCI v1.0 and also in issue in Linux trace:
[ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.0 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
Thanks to point these point . So I will add them in a second patch " arm: stm32mp1: complete PSCI v1.0 support"
I want keep this patch in v1, to have it merged in v2018.05-rc1, I hope... Even if it is only a first step for a full PSCI v1.0 support, that allow linux kernel boot.
And I need some time to check how to handle SYSTEM_OFF , to do the "completely removes power" because I don't think if it is possible today.
+int __secure psci_cpu_on(u32 __always_unused unused, u32 mpidr, u32 +pc) {
Yes context_id is not used in my code.....
In fact, I use the same psci_cpu_on prototypes and logic than other platform : ./arch/arm/cpu/armv7/sunxi/psci.c:246 ./arch/arm/mach-uniphier/arm32/psci.c:134 ./arch/arm/cpu/armv7/ls102xa/psci.S:117
=> all are based on psci_save_target_pc() to save the PC in secure context (psci_target_pc[]) ./arch/arm/cpu/armv7/psci-common.c:29
But context is not saved or used in generic PSCI code, only pc is restored => ./arch/arm/cpu/armv7/psci.S:330 r0 = psci_get_target_pc() is called before _do_nonsec_entry
I will check deeper in this U-Boot PSCI code.
=> I try to solve the problem and push a RFC or a patch to have feedback form other PSCI user. Even it is not block for Linux point of view, as context ID is not used in linux code always = 0: ./drivers/firmware/psci.c: static int psci_cpu_on(unsigned long cpuid, unsigned long entry_point) .... err = invoke_psci_fn(fn, cpuid, entry_point, 0);
No issue, the CPU continue to run.... TAMP register is only used by BootRom to unpark the cpu on boot, update of the backup have no impact when the CPU is running.
I will add a comment in the next patch " arm: stm32mp1: complete PSCI v1.0 support" and also check if I can add test the cpu state to manage other possible return value (never used in U-Boot): PSCI_RET_ALREADY_ON PSCI_RET_ON_PENDING
Thanks, Mark.
Very thanks for the review. That allows me to read deeper the PSCI documents.
Tom: do you think that this patch can be merged in v2018.05-rc1 ? and I will sent a 2nd patch for full PCSI v1.0 support and correct the missing parts reported by Mark.
Thanks
Patrick
On Thu, Mar 29, 2018 at 04:59:21PM +0000, Patrick DELAUNAY wrote:
Hi Mark,
return 0x0;
Thanks, Mark.
Lets see how far along you get before the v2018.05 final. I don't think it's a good idea to claim PSCI 1.0 support and not provide all of the required functionality, as that would be breaking the point of declaring that you support something like that :) Thanks!
Hi Tom
Hi Mark,
trace:
support"
boot.
+int __secure psci_cpu_on(u32 __always_unused unused, u32 mpidr, +u32 +pc) {
(psci_target_pc[])
other PSCI user.
code always = 0:
support"
Thanks, Mark.
-- Tom
I understood and I am agree that it is better, So I will push a v2 as soon as possible with minimal PSCI v1.0 (adding the 2 missing functions).
And an other patch to save the context ID for PSCI on arm v7 (with perhaps impact on other platform).
Patrick
Mark Rutland
Patrick DELAUNAY
Patrick Delaunay
