[U-Boot] [PATCH v2 0/4] Add STMFX gpio expander support for stm32mp157c-ev1 board
This series adds: - STMFX pinctrl driver - update STM32MP15 basic and trusted config - Add stmfx node in stm32mp157c-ev1 DT - Update stm32mp1 board to probe pinctrl drivers early to be able to hog pins.
There are dependencies with : - http://patchwork.ozlabs.org/project/uboot/list/?series=92268 - http://patchwork.ozlabs.org/project/uboot/list/?series=91422 which must be merged first.
Changes in v2: _ Add missing pinctrl2 alias in stm32mp157c-ev1-u-boot.dtsi _ Move pinctrl0 and pinctrl1 aliases in stm32mp157c-u-boot.dtsi _ Set stmfx_pinctrl status to "okay"
Patrice Chotard (2): board: stm32mp1: Force pinctrl driver probe in board_init() ARM: dts: Add STMFX gpio expander support for stm32mp157c-ev1
Patrick Delaunay (2): pinctrl: Add STMFX GPIO expander Pinctrl/GPIO driver config: stm32mp15: Enable STMFX support
arch/arm/dts/stm32mp157-u-boot.dtsi | 2 + arch/arm/dts/stm32mp157c-ev1-u-boot.dtsi | 2 + arch/arm/dts/stm32mp157c-ev1.dts | 18 ++ board/st/stm32mp1/stm32mp1.c | 9 + configs/stm32mp15_basic_defconfig | 5 +- configs/stm32mp15_trusted_defconfig | 5 +- drivers/pinctrl/Kconfig | 19 ++ drivers/pinctrl/Makefile | 1 + drivers/pinctrl/pinctrl-stmfx.c | 431 +++++++++++++++++++++++++++++++ 9 files changed, 488 insertions(+), 4 deletions(-) create mode 100644 drivers/pinctrl/pinctrl-stmfx.c
This patch adds pinctrl/GPIO driver for STMicroelectronics Multi-Function eXpander (STMFX) GPIO expander. STMFX is an I2C slave controller, offering up to 24 GPIOs. The driver relies on UCLASS_PINCTRL and UCLASS_GPIO.
Signed-off-by: Patrick Delaunay patrick.delaunay@st.com Signed-off-by: Patrice Chotard patrice.chotard@st.com Reviewed-by: CITOOLS smet-aci-reviews@lists.codex.cro.st.com Reviewed-by: CIBUILD smet-aci-builds@lists.codex.cro.st.com ---
Changes in v2: None
drivers/pinctrl/Kconfig | 19 ++ drivers/pinctrl/Makefile | 1 + drivers/pinctrl/pinctrl-stmfx.c | 431 ++++++++++++++++++++++++++++++++++++++++ 3 files changed, 451 insertions(+) create mode 100644 drivers/pinctrl/pinctrl-stmfx.c
diff --git a/drivers/pinctrl/Kconfig b/drivers/pinctrl/Kconfig index be709f73d7df..a0ac167d145a 100644 --- a/drivers/pinctrl/Kconfig +++ b/drivers/pinctrl/Kconfig @@ -209,6 +209,25 @@ config PINCTRL_STM32 the GPIO definitions and pin control functions for each available multiplex function.
+config PINCTRL_STMFX + bool "STMicroelectronics STMFX I2C GPIO expander pinctrl driver" + depends on DM && PINCTRL_FULL + help + I2C driver for STMicroelectronics Multi-Function eXpander (STMFX) + GPIO expander. + Supports pin multiplexing control on stm32 SoCs. + + The driver is controlled by a device tree node which contains both + the GPIO definitions and pin control functions for each available + multiplex function. + +config SPL_PINCTRL_STMFX + bool "STMicroelectronics STMFX I2C GPIO expander pinctrl driver in SPL" + depends on SPL_PINCTRL_FULL + help + This option is an SPL-variant of the SPL_PINCTRL_STMFX option. + See the help of PINCTRL_STMFX for details. + config ASPEED_AST2500_PINCTRL bool "Aspeed AST2500 pin control driver" depends on DM && PINCTRL_GENERIC && ASPEED_AST2500 diff --git a/drivers/pinctrl/Makefile b/drivers/pinctrl/Makefile index e2c2b159d8c8..4b080b74dcd1 100644 --- a/drivers/pinctrl/Makefile +++ b/drivers/pinctrl/Makefile @@ -22,4 +22,5 @@ obj-$(CONFIG_ARCH_MVEBU) += mvebu/ obj-$(CONFIG_PINCTRL_SINGLE) += pinctrl-single.o obj-$(CONFIG_PINCTRL_STI) += pinctrl-sti.o obj-$(CONFIG_PINCTRL_STM32) += pinctrl_stm32.o +obj-$(CONFIG_$(SPL_)PINCTRL_STMFX) += pinctrl-stmfx.o obj-y += broadcom/ diff --git a/drivers/pinctrl/pinctrl-stmfx.c b/drivers/pinctrl/pinctrl-stmfx.c new file mode 100644 index 000000000000..5431df9813a1 --- /dev/null +++ b/drivers/pinctrl/pinctrl-stmfx.c @@ -0,0 +1,431 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2018, STMicroelectronics - All Rights Reserved + * + * Driver for STMicroelectronics Multi-Function eXpander (STMFX) GPIO expander + * based on Linux driver : pinctrl/pinctrl-stmfx.c + */ +#include <common.h> +#include <dm.h> +#include <i2c.h> +#include <asm/gpio.h> +#include <dm/device.h> +#include <dm/device-internal.h> +#include <dm/lists.h> +#include <dm/pinctrl.h> +#include <linux/bitfield.h> +#include <power/regulator.h> + +/* STMFX pins = GPIO[15:0] + aGPIO[7:0] */ +#define STMFX_MAX_GPIO 16 +#define STMFX_MAX_AGPIO 8 + +/* General */ +#define STMFX_REG_CHIP_ID 0x00 /* R */ +#define STMFX_REG_FW_VERSION_MSB 0x01 /* R */ +#define STMFX_REG_FW_VERSION_LSB 0x02 /* R */ +#define STMFX_REG_SYS_CTRL 0x40 /* RW */ + +/* MFX boot time is around 10ms, so after reset, we have to wait this delay */ +#define STMFX_BOOT_TIME_MS 10 + +/* GPIOs expander */ +/* GPIO_STATE1 0x10, GPIO_STATE2 0x11, GPIO_STATE3 0x12 */ +#define STMFX_REG_GPIO_STATE 0x10 /* R */ +/* GPIO_DIR1 0x60, GPIO_DIR2 0x61, GPIO_DIR3 0x63 */ +#define STMFX_REG_GPIO_DIR 0x60 /* RW */ +/* GPIO_TYPE1 0x64, GPIO_TYPE2 0x65, GPIO_TYPE3 0x66 */ +#define STMFX_REG_GPIO_TYPE 0x64 /* RW */ +/* GPIO_PUPD1 0x68, GPIO_PUPD2 0x69, GPIO_PUPD3 0x6A */ +#define STMFX_REG_GPIO_PUPD 0x68 /* RW */ +/* GPO_SET1 0x6C, GPO_SET2 0x6D, GPO_SET3 0x6E */ +#define STMFX_REG_GPO_SET 0x6C /* RW */ +/* GPO_CLR1 0x70, GPO_CLR2 0x71, GPO_CLR3 0x72 */ +#define STMFX_REG_GPO_CLR 0x70 /* RW */ + +/* STMFX_REG_CHIP_ID bitfields */ +#define STMFX_REG_CHIP_ID_MASK GENMASK(7, 0) + +/* STMFX_REG_SYS_CTRL bitfields */ +#define STMFX_REG_SYS_CTRL_GPIO_EN BIT(0) +#define STMFX_REG_SYS_CTRL_ALTGPIO_EN BIT(3) +#define STMFX_REG_SYS_CTRL_SWRST BIT(7) + +#define NR_GPIO_REGS 3 +#define NR_GPIOS_PER_REG 8 +#define get_reg(offset) ((offset) / NR_GPIOS_PER_REG) +#define get_shift(offset) ((offset) % NR_GPIOS_PER_REG) +#define get_mask(offset) (BIT(get_shift(offset))) + +struct stmfx_pinctrl { + struct udevice *gpio; +}; + +static int stmfx_read(struct udevice *dev, uint offset) +{ + return dm_i2c_reg_read(dev_get_parent(dev), offset); +} + +static int stmfx_write(struct udevice *dev, uint offset, unsigned int val) +{ + return dm_i2c_reg_write(dev_get_parent(dev), offset, val); +} + +static int stmfx_gpio_get(struct udevice *dev, unsigned int offset) +{ + u32 reg = STMFX_REG_GPIO_STATE + get_reg(offset); + u32 mask = get_mask(offset); + int ret; + + ret = stmfx_read(dev, reg); + + return ret < 0 ? ret : !!(ret & mask); +} + +static int stmfx_gpio_set(struct udevice *dev, unsigned int offset, int value) +{ + u32 reg = value ? STMFX_REG_GPO_SET : STMFX_REG_GPO_CLR; + u32 mask = get_mask(offset); + + return stmfx_write(dev, reg + get_reg(offset), mask); +} + +static int stmfx_gpio_get_function(struct udevice *dev, unsigned int offset) +{ + u32 reg = STMFX_REG_GPIO_DIR + get_reg(offset); + u32 mask = get_mask(offset); + int ret; + + ret = stmfx_read(dev, reg); + + if (ret < 0) + return ret; + /* On stmfx, gpio pins direction is (0)input, (1)output. */ + + return ret & mask ? GPIOF_OUTPUT : GPIOF_INPUT; +} + +static int stmfx_gpio_direction_input(struct udevice *dev, unsigned int offset) +{ + u32 reg = STMFX_REG_GPIO_DIR + get_reg(offset); + u32 mask = get_mask(offset); + int ret; + + ret = stmfx_read(dev, reg); + if (ret < 0) + return ret; + + ret &= ~mask; + + return stmfx_write(dev, reg, ret & ~mask); +} + +static int stmfx_gpio_direction_output(struct udevice *dev, + unsigned int offset, int value) +{ + u32 reg = STMFX_REG_GPIO_DIR + get_reg(offset); + u32 mask = get_mask(offset); + int ret; + + ret = stmfx_gpio_set(dev, offset, value); + if (ret < 0) + return ret; + + ret = stmfx_read(dev, reg); + if (ret < 0) + return ret; + + return stmfx_write(dev, reg, ret | mask); +} + +static int stmfx_gpio_probe(struct udevice *dev) +{ + struct gpio_dev_priv *uc_priv = dev_get_uclass_priv(dev); + struct ofnode_phandle_args args; + u8 sys_ctrl; + + uc_priv->bank_name = "stmfx"; + uc_priv->gpio_count = STMFX_MAX_GPIO + STMFX_MAX_AGPIO; + if (!dev_read_phandle_with_args(dev, "gpio-ranges", + NULL, 3, 0, &args)) { + uc_priv->gpio_count = args.args[2]; + } + + /* enable GPIO function */ + sys_ctrl = STMFX_REG_SYS_CTRL_GPIO_EN; + if (uc_priv->gpio_count > STMFX_MAX_GPIO) + sys_ctrl |= STMFX_REG_SYS_CTRL_ALTGPIO_EN; + stmfx_write(dev, STMFX_REG_SYS_CTRL, sys_ctrl); + + return 0; +} + +static const struct dm_gpio_ops stmfx_gpio_ops = { + .set_value = stmfx_gpio_set, + .get_value = stmfx_gpio_get, + .get_function = stmfx_gpio_get_function, + .direction_input = stmfx_gpio_direction_input, + .direction_output = stmfx_gpio_direction_output, +}; + +U_BOOT_DRIVER(stmfx_gpio) = { + .name = "stmfx-gpio", + .id = UCLASS_GPIO, + .probe = stmfx_gpio_probe, + .ops = &stmfx_gpio_ops, +}; + +#if CONFIG_IS_ENABLED(PINCONF) +static const struct pinconf_param stmfx_pinctrl_conf_params[] = { + { "bias-disable", PIN_CONFIG_BIAS_DISABLE, 0 }, + { "bias-pull-up", PIN_CONFIG_BIAS_PULL_UP, 0 }, + { "bias-pull-pin-default", PIN_CONFIG_BIAS_PULL_PIN_DEFAULT, 0 }, + { "bias-pull-down", PIN_CONFIG_BIAS_PULL_DOWN, 0 }, + { "drive-open-drain", PIN_CONFIG_DRIVE_OPEN_DRAIN, 0 }, + { "drive-push-pull", PIN_CONFIG_DRIVE_PUSH_PULL, 0 }, + { "output-high", PIN_CONFIG_OUTPUT, 1 }, + { "output-low", PIN_CONFIG_OUTPUT, 0 }, +}; + +static int stmfx_pinctrl_set_pupd(struct udevice *dev, + unsigned int pin, u32 pupd) +{ + u8 reg = STMFX_REG_GPIO_PUPD + get_reg(pin); + u32 mask = get_mask(pin); + int ret; + + ret = stmfx_read(dev, reg); + if (ret < 0) + return ret; + ret = (ret & ~mask) | (pupd ? mask : 0); + + return stmfx_write(dev, reg, ret); +} + +static int stmfx_pinctrl_set_type(struct udevice *dev, + unsigned int pin, u32 type) +{ + u8 reg = STMFX_REG_GPIO_TYPE + get_reg(pin); + u32 mask = get_mask(pin); + int ret; + + ret = stmfx_read(dev, reg); + if (ret < 0) + return ret; + ret = (ret & ~mask) | (type ? mask : 0); + + return stmfx_write(dev, reg, ret); +} + +static int stmfx_pinctrl_conf_set(struct udevice *dev, unsigned int pin, + unsigned int param, unsigned int arg) +{ + int ret, dir; + struct stmfx_pinctrl *plat = dev_get_platdata(dev); + + dir = stmfx_gpio_get_function(plat->gpio, pin); + + if (dir < 0) + return dir; + + switch (param) { + case PIN_CONFIG_BIAS_PULL_PIN_DEFAULT: + case PIN_CONFIG_BIAS_DISABLE: + case PIN_CONFIG_BIAS_PULL_DOWN: + ret = stmfx_pinctrl_set_pupd(dev, pin, 0); + break; + case PIN_CONFIG_BIAS_PULL_UP: + ret = stmfx_pinctrl_set_pupd(dev, pin, 1); + break; + case PIN_CONFIG_DRIVE_OPEN_DRAIN: + if (dir == GPIOF_OUTPUT) + ret = stmfx_pinctrl_set_type(dev, pin, 1); + else + ret = stmfx_pinctrl_set_type(dev, pin, 0); + break; + case PIN_CONFIG_DRIVE_PUSH_PULL: + if (dir == GPIOF_OUTPUT) + ret = stmfx_pinctrl_set_type(dev, pin, 0); + else + ret = stmfx_pinctrl_set_type(dev, pin, 1); + break; + case PIN_CONFIG_OUTPUT: + ret = stmfx_gpio_direction_output(plat->gpio, pin, arg); + break; + default: + return -ENOTSUPP; + } + + return ret; +} +#endif + +static int stmfx_pinctrl_get_pins_count(struct udevice *dev) +{ + struct stmfx_pinctrl *plat = dev_get_platdata(dev); + struct gpio_dev_priv *uc_priv; + + uc_priv = dev_get_uclass_priv(plat->gpio); + + return uc_priv->gpio_count; +} + +/* + * STMFX pins[15:0] are called "gpio[15:0]" + * and STMFX pins[23:16] are called "agpio[7:0]" + */ +#define MAX_PIN_NAME_LEN 7 +static char pin_name[MAX_PIN_NAME_LEN]; +static const char *stmfx_pinctrl_get_pin_name(struct udevice *dev, + unsigned int selector) +{ + if (selector < STMFX_MAX_GPIO) + snprintf(pin_name, MAX_PIN_NAME_LEN, "gpio%u", selector); + else + snprintf(pin_name, MAX_PIN_NAME_LEN, "agpio%u", selector - 16); + return pin_name; +} + +static int stmfx_pinctrl_get_pin_muxing(struct udevice *dev, + unsigned int selector, + char *buf, int size) +{ + struct stmfx_pinctrl *plat = dev_get_platdata(dev); + int func; + + func = stmfx_gpio_get_function(plat->gpio, selector); + if (func < 0) + return func; + + snprintf(buf, size, "%s", func == GPIOF_INPUT ? "input" : "output"); + + return 0; +} + +static int stmfx_pinctrl_bind(struct udevice *dev) +{ + struct stmfx_pinctrl *plat = dev_get_platdata(dev); + + return device_bind_driver_to_node(dev->parent, + "stmfx-gpio", "stmfx-gpio", + dev_ofnode(dev), &plat->gpio); +}; + +static int stmfx_pinctrl_probe(struct udevice *dev) +{ + struct stmfx_pinctrl *plat = dev_get_platdata(dev); + + return device_probe(plat->gpio); +}; + +const struct pinctrl_ops stmfx_pinctrl_ops = { + .get_pins_count = stmfx_pinctrl_get_pins_count, + .get_pin_name = stmfx_pinctrl_get_pin_name, + .set_state = pinctrl_generic_set_state, + .get_pin_muxing = stmfx_pinctrl_get_pin_muxing, +#if CONFIG_IS_ENABLED(PINCONF) + .pinconf_set = stmfx_pinctrl_conf_set, + .pinconf_num_params = ARRAY_SIZE(stmfx_pinctrl_conf_params), + .pinconf_params = stmfx_pinctrl_conf_params, +#endif +}; + +static const struct udevice_id stmfx_pinctrl_match[] = { + { .compatible = "st,stmfx-0300-pinctrl", }, +}; + +U_BOOT_DRIVER(stmfx_pinctrl) = { + .name = "stmfx-pinctrl", + .id = UCLASS_PINCTRL, + .of_match = of_match_ptr(stmfx_pinctrl_match), + .bind = stmfx_pinctrl_bind, + .probe = stmfx_pinctrl_probe, + .ops = &stmfx_pinctrl_ops, + .platdata_auto_alloc_size = sizeof(struct stmfx_pinctrl), +}; + +static int stmfx_chip_init(struct udevice *dev) +{ + u8 id; + u8 version[2]; + int ret; + struct dm_i2c_chip *chip = dev_get_parent_platdata(dev); + + id = dm_i2c_reg_read(dev, STMFX_REG_CHIP_ID); + if (id < 0) { + dev_err(dev, "error reading chip id: %d\n", id); + return ret; + } + /* + * Check that ID is the complement of the I2C address: + * STMFX I2C address follows the 7-bit format (MSB), that's why + * client->addr is shifted. + * + * STMFX_I2C_ADDR| STMFX | Linux + * input pin | I2C device address | I2C device address + *--------------------------------------------------------- + * 0 | b: 1000 010x h:0x84 | 0x42 + * 1 | b: 1000 011x h:0x86 | 0x43 + */ + if (FIELD_GET(STMFX_REG_CHIP_ID_MASK, ~id) != (chip->chip_addr << 1)) { + dev_err(dev, "unknown chip id: %#x\n", id); + return -EINVAL; + } + + ret = dm_i2c_read(dev, STMFX_REG_FW_VERSION_MSB, + version, sizeof(version)); + if (ret) { + dev_err(dev, "error reading fw version: %d\n", ret); + return ret; + } + + dev_info(dev, "STMFX id: %#x, fw version: %x.%02x\n", + id, version[0], version[1]); + + ret = dm_i2c_reg_read(dev, STMFX_REG_SYS_CTRL); + + if (ret < 0) + return ret; + + ret = dm_i2c_reg_write(dev, STMFX_REG_SYS_CTRL, + ret | STMFX_REG_SYS_CTRL_SWRST); + if (ret) + return ret; + + mdelay(STMFX_BOOT_TIME_MS); + + return ret; +} + +static int stmfx_probe(struct udevice *dev) +{ + struct udevice *vdd; + int ret; + + ret = device_get_supply_regulator(dev, "vdd-supply", &vdd); + if (ret && ret != -ENOENT) { + dev_err(dev, "vdd regulator error:%d\n", ret); + return ret; + } + if (!ret) { + ret = regulator_set_enable(vdd, true); + if (ret) { + dev_err(dev, "vdd enable failed: %d\n", ret); + return ret; + } + } + + return stmfx_chip_init(dev); +} + +static const struct udevice_id stmfx_match[] = { + { .compatible = "st,stmfx-0300", }, +}; + +U_BOOT_DRIVER(stmfx) = { + .name = "stmfx", + .id = UCLASS_I2C_GENERIC, + .of_match = of_match_ptr(stmfx_match), + .probe = stmfx_probe, + .bind = dm_scan_fdt_dev, +};
Activate PINCTRL_STMFX and needed part for generic pincontrol PINCTRL_FULL, PINCONF. Increase pre-reloc memory for MALLOC (needed for each DM pinconfig node).
Signed-off-by: Patrick Delaunay patrick.delaunay@st.com Reviewed-by: CITOOLS smet-aci-reviews@lists.codex.cro.st.com Signed-off-by: Patrice Chotard patrice.chotard@st.com ---
Changes in v2: None
configs/stm32mp15_basic_defconfig | 5 +++-- configs/stm32mp15_trusted_defconfig | 5 +++-- 2 files changed, 6 insertions(+), 4 deletions(-)
diff --git a/configs/stm32mp15_basic_defconfig b/configs/stm32mp15_basic_defconfig index ac52155699b3..6781adb81e73 100644 --- a/configs/stm32mp15_basic_defconfig +++ b/configs/stm32mp15_basic_defconfig @@ -1,6 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_STM32MP=y -CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_SYS_MALLOC_F_LEN=0x3000 CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL=y CONFIG_TARGET_STM32MP1=y @@ -55,8 +55,9 @@ CONFIG_DM_MMC=y CONFIG_STM32_SDMMC2=y CONFIG_PHY=y CONFIG_PHY_STM32_USBPHYC=y -# CONFIG_PINCTRL_FULL is not set +CONFIG_PINCONF=y # CONFIG_SPL_PINCTRL_FULL is not set +CONFIG_PINCTRL_STMFX=y CONFIG_DM_PMIC=y # CONFIG_SPL_PMIC_CHILDREN is not set CONFIG_PMIC_STPMIC1=y diff --git a/configs/stm32mp15_trusted_defconfig b/configs/stm32mp15_trusted_defconfig index 0ffea5bfb32c..a050cee6918e 100644 --- a/configs/stm32mp15_trusted_defconfig +++ b/configs/stm32mp15_trusted_defconfig @@ -1,6 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_STM32MP=y -CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_SYS_MALLOC_F_LEN=0x3000 CONFIG_TARGET_STM32MP1=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y @@ -48,7 +48,8 @@ CONFIG_DM_MMC=y CONFIG_STM32_SDMMC2=y CONFIG_PHY=y CONFIG_PHY_STM32_USBPHYC=y -# CONFIG_PINCTRL_FULL is not set +CONFIG_PINCONF=y +CONFIG_PINCTRL_STMFX=y CONFIG_DM_PMIC=y CONFIG_PMIC_STPMIC1=y CONFIG_DM_REGULATOR_FIXED=y
In order to insure that hog GPIOs are configured early during the boot process, force all pinctrl driver probing in board_init().
Signed-off-by: Patrick Delaunay patrick.delaunay@st.com Signed-off-by: Patrice Chotard patrice.chotard@st.com Reviewed-by: CITOOLS smet-aci-reviews@lists.codex.cro.st.com ---
Changes in v2: None
board/st/stm32mp1/stm32mp1.c | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/board/st/stm32mp1/stm32mp1.c b/board/st/stm32mp1/stm32mp1.c index ff7790e310d7..24d299ac33bd 100644 --- a/board/st/stm32mp1/stm32mp1.c +++ b/board/st/stm32mp1/stm32mp1.c @@ -543,9 +543,18 @@ static void sysconf_init(void) /* board dependent setup after realloc */ int board_init(void) { + struct udevice *dev; + /* address of boot parameters */ gd->bd->bi_boot_params = STM32_DDR_BASE + 0x100;
+ /* probe all PINCTRL for hog */ + for (uclass_first_device(UCLASS_PINCTRL, &dev); + dev; + uclass_next_device(&dev)) { + pr_debug("probe pincontrol = %s\n", dev->name); + } + board_key_check();
sysconf_init();
Adds alias to set the pincontrol seq id. For STMFX gpio expander, force sequence number after the last bank (GPIOZ) to avoid conflict between STM32MP and STMFX gpio bank sequence number.
arch/arm/dts/stm32mp157-u-boot.dtsi | 2 ++ arch/arm/dts/stm32mp157c-ev1-u-boot.dtsi | 2 ++ arch/arm/dts/stm32mp157c-ev1.dts | 18 ++++++++++++++++++ 3 files changed, 22 insertions(+)
diff --git a/arch/arm/dts/stm32mp157-u-boot.dtsi b/arch/arm/dts/stm32mp157-u-boot.dtsi index 2594702c926f..ab6f673ea24c 100644 --- a/arch/arm/dts/stm32mp157-u-boot.dtsi +++ b/arch/arm/dts/stm32mp157-u-boot.dtsi @@ -17,6 +17,8 @@ gpio9 = &gpioj; gpio10 = &gpiok; gpio25 = &gpioz; + pinctrl0 = &pinctrl; + pinctrl1 = &pinctrl_z; };
config { diff --git a/arch/arm/dts/stm32mp157c-ev1-u-boot.dtsi b/arch/arm/dts/stm32mp157c-ev1-u-boot.dtsi index be3b1526288f..6a18d032ae54 100644 --- a/arch/arm/dts/stm32mp157c-ev1-u-boot.dtsi +++ b/arch/arm/dts/stm32mp157c-ev1-u-boot.dtsi @@ -7,8 +7,10 @@
/ { aliases { + gpio26 = &stmfx_pinctrl; i2c1 = &i2c2; i2c4 = &i2c5; + pinctrl2 = &stmfx_pinctrl; spi0 = &qspi; }; }; diff --git a/arch/arm/dts/stm32mp157c-ev1.dts b/arch/arm/dts/stm32mp157c-ev1.dts index e114c9b628b8..3c85909c42bd 100644 --- a/arch/arm/dts/stm32mp157c-ev1.dts +++ b/arch/arm/dts/stm32mp157c-ev1.dts @@ -98,6 +98,24 @@ i2c-scl-rising-time-ns = <185>; i2c-scl-falling-time-ns = <20>; status = "okay"; + + stmfx: stmfx@42 { + compatible = "st,stmfx-0300"; + reg = <0x42>; + interrupts = <8 IRQ_TYPE_EDGE_RISING>; + interrupt-parent = <&gpioi>; + vdd-supply = <&v3v3>; + + stmfx_pinctrl: stmfx-pin-controller { + compatible = "st,stmfx-0300-pinctrl"; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + gpio-ranges = <&stmfx_pinctrl 0 0 24>; + status = "okay"; + }; + }; };
&i2c5 {
Patrice Chotard
