[U-Boot] [Patch 3/8] add at91 SoC access with c structures
* add new hardware header files for at91 emac, matrix, mc, pdc, st and tc controller * add at91rm9200 definitions, need for join at91rm9200 into at91 arch
Signed-off-by: Jens Scharsig js_at_ng@scharsoft.de --- include/asm-arm/arch-at91/at91_emac.h | 145 +++++++++++++++++++++++++++++++ include/asm-arm/arch-at91/at91_matrix.h | 125 ++++++++++++++++++++++++++ include/asm-arm/arch-at91/at91_mc.h | 89 +++++++++++++++++++ include/asm-arm/arch-at91/at91_pdc.h | 41 +++++++++ include/asm-arm/arch-at91/at91_st.h | 48 ++++++++++ include/asm-arm/arch-at91/at91_tc.h | 79 +++++++++++++++++ include/asm-arm/arch-at91/at91rm9200.h | 135 ++++++++++++++++++++++++++++ 7 files changed, 662 insertions(+), 0 deletions(-) create mode 100644 include/asm-arm/arch-at91/at91_emac.h create mode 100644 include/asm-arm/arch-at91/at91_matrix.h create mode 100644 include/asm-arm/arch-at91/at91_mc.h create mode 100644 include/asm-arm/arch-at91/at91_pdc.h create mode 100644 include/asm-arm/arch-at91/at91_st.h create mode 100644 include/asm-arm/arch-at91/at91_tc.h create mode 100644 include/asm-arm/arch-at91/at91rm9200.h
diff --git a/include/asm-arm/arch-at91/at91_emac.h b/include/asm-arm/arch-at91/at91_emac.h new file mode 100644 index 0000000..a367ed8 --- /dev/null +++ b/include/asm-arm/arch-at91/at91_emac.h @@ -0,0 +1,145 @@ +/* + * Memory Setup stuff - taken from blob memsetup.S + * + * Copyright (C) 2009 Jens Scharsig (js_at_ng@scharsoft.de) + * + * based on AT91RM9200 datasheet revision I (36. Ethernet MAC (EMAC)) + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef AT91_H +#define AT91_H + +typedef struct at91_emac { + u32 ctl; + u32 cfg; + u32 sr; + u32 tar; + u32 tcr; + u32 tsr; + u32 rbqp; + u32 reserved0; + u32 rsr; + u32 isr; + u32 ier; + u32 idr; + u32 imr; + u32 man; + u32 reserved1[2]; + u32 fra; + u32 scol; + u32 mocl; + u32 ok; + u32 seqe; + u32 ale; + u32 dte; + u32 lcol; + u32 ecol; + u32 cse; + u32 tue; + u32 cde; + u32 elr; + u32 rjb; + u32 usf; + u32 sqee; + u32 drfc; + u32 reserved2[3]; + u32 hsh; + u32 hsl; + u32 sh1l; + u32 sa1h; + u32 sa2l; + u32 sa2h; + u32 sa3l; + u32 sa3h; + u32 sa4l; + u32 sa4h; +} at91_emac_t; + +#define AT91_EMAC_CTL_LB 0x0001 +#define AT91_EMAC_CTL_LBL 0x0002 +#define AT91_EMAC_CTL_RE 0x0004 +#define AT91_EMAC_CTL_TE 0x0008 +#define AT91_EMAC_CTL_MPE 0x0010 +#define AT91_EMAC_CTL_CSR 0x0020 +#define AT91_EMAC_CTL_ISR 0x0040 +#define AT91_EMAC_CTL_WES 0x0080 +#define AT91_EMAC_CTL_BP 0x1000 + +#define AT91_EMAC_CFG_SPD 0x0001 +#define AT91_EMAC_CFG_FD 0x0002 +#define AT91_EMAC_CFG_BR 0x0004 +#define AT91_EMAC_CFG_CAF 0x0010 +#define AT91_EMAC_CFG_NBC 0x0020 +#define AT91_EMAC_CFG_MTI 0x0040 +#define AT91_EMAC_CFG_UNI 0x0080 +#define AT91_EMAC_CFG_BIG 0x0100 +#define AT91_EMAC_CFG_EAE 0x0200 +#define AT91_EMAC_CFG_CLK_MASK 0xFFFFF3FF +#define AT91_EMAC_CFG_MCLK_8 0x0000 +#define AT91_EMAC_CFG_MCLK_16 0x0400 +#define AT91_EMAC_CFG_MCLK_32 0x0800 +#define AT91_EMAC_CFG_MCLK_64 0x0C00 +#define AT91_EMAC_CFG_RTY 0x1000 +#define AT91_EMAC_CFG_RMII 0x2000 + +#define AT91_EMAC_SR_LINK 0x0001 +#define AT91_EMAC_SR_MDIO 0x0002 +#define AT91_EMAC_SR_IDLE 0x0004 + +#define AT91_EMAC_TCR_LEN(x) (x & 0x7FF) +#define AT91_EMAC_TCR_NCRC 0x8000 + +#define AT91_EMAC_TSR_OVR 0x0001 +#define AT91_EMAC_TSR_COL 0x0002 +#define AT91_EMAC_TSR_RLE 0x0004 +#define AT91_EMAC_TSR_TXIDLE 0x0008 +#define AT91_EMAC_TSR_BNQ 0x0010 +#define AT91_EMAC_TSR_COMP 0x0020 +#define AT91_EMAC_TSR_UND 0x0040 + +#define AT91_EMAC_RSR_BNA 0x0001 +#define AT91_EMAC_RSR_REC 0x0002 +#define AT91_EMAC_RSR_OVR 0x0004 + +/* ISR, IER, IDR, IMR use the same bits */ +#define AT91_EMAC_IxR_DONE 0x0001 +#define AT91_EMAC_IxR_RCOM 0x0002 +#define AT91_EMAC_IxR_RBNA 0x0004 +#define AT91_EMAC_IxR_TOVR 0x0008 +#define AT91_EMAC_IxR_TUND 0x0010 +#define AT91_EMAC_IxR_RTRY 0x0020 +#define AT91_EMAC_IxR_TBRE 0x0040 +#define AT91_EMAC_IxR_TCOM 0x0080 +#define AT91_EMAC_IxR_TIDLE 0x0100 +#define AT91_EMAC_IxR_LINK 0x0200 +#define AT91_EMAC_IxR_ROVR 0x0400 +#define AT91_EMAC_IxR_HRESP 0x0800 + +#define AT91_EMAC_MAN_DATA_MASK 0xFFFF +#define AT91_EMAC_MAN_CODE_802_3 0x00020000 +#define AT91_EMAC_MAN_REGA(reg) ((reg & 0x1F) << 18) +#define AT91_EMAC_MAN_PHYA(phy) ((phy & 0x1F) << 23) +#define AT91_EMAC_MAN_RW_R 0x20000000 +#define AT91_EMAC_MAN_RW_W 0x10000000 +#define AT91_EMAC_MAN_HIGH 0x40000000 +#define AT91_EMAC_MAN_LOW 0x80000000 + +#endif \ No newline at end of file diff --git a/include/asm-arm/arch-at91/at91_matrix.h b/include/asm-arm/arch-at91/at91_matrix.h new file mode 100644 index 0000000..8cbd2a2 --- /dev/null +++ b/include/asm-arm/arch-at91/at91_matrix.h @@ -0,0 +1,125 @@ +/* + * Memory Setup stuff - taken from blob memsetup.S + * + * Copyright (C) 2009 Jens Scharsig (js_at_ng@scharsoft.de) + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef AT91_MATRIX_H +#define AT91_MATRIX_H + +#ifdef __ASSEMBLY__ + +#if defined(CONFIG_AT91SAM9260) || defined(CONFIG_AT91SAM9G20) +#define AT91_ASM_MATRIX_CSA0 (AT91_MATRIX_BASE + 0x11C) +#elif defined(CONFIG_AT91SAM9261) +#define AT91_ASM_MATRIX_CSA0 (AT91_MATRIX_BASE + 0x30) +#elif defined(CONFIG_AT91SAM9263) +#define AT91_ASM_MATRIX_CSA0 (AT91_MATRIX_BASE + 0x120) +#elif defined(CONFIG_AT91SAM9G45) +#define AT91_ASM_MATRIX_CSA0 (AT91_MATRIX_BASE + 0x128) +#else +#error AT91_ASM_MATRIX_CSA0 is not definied for current CPU +#endif + +#define AT91_ASM_MATRIX_MCFG AT91_MATRIX_BASE + +#else +#if defined(CONFIG_AT91SAM9260) || defined(CONFIG_AT91SAM9G20) +#define AT91_MATRIX_MASTERS 6 +#define AT91_MATRIX_SLAVES 5 +#elif defined(CONFIG_AT91SAM9261) +#define AT91_MATRIX_MASTERS 1 +#define AT91_MATRIX_SLAVES 5 +#elif defined(CONFIG_AT91SAM9263) +#define AT91_MATRIX_MASTERS 9 +#define AT91_MATRIX_SLAVES 7 +#elif defined(CONFIG_AT91SAM9G45) +#define AT91_MATRIX_MASTERS 11 +#define AT91_MATRIX_SLAVES 8 +#else +#error CPU not supported. Please update at91_matrix.h +#endif + +typedef struct at91_prority { + u32 a; + u32 b; +} at91_prority_t; + + +typedef struct at91_matrix { + u32 mcfg[AT91_MATRIX_MASTERS]; +#if defined(CONFIG_AT91SAM9261) + u32 scfg[AT91_MATRIX_SLAVES]; + u32 res61_1[3]; + u32 tcr; + u32 res61_2[2]; + u32 csa; + u32 pucr; + u32 res61_3[114]; +#else +#if (AT91_MATRIX_MASTERS < 16) + u32 reserve1[16 - AT91_MATRIX_MASTERS]; +#endif + u32 scfg[AT91_MATRIX_SLAVES]; +#if (AT91_MATRIX_SLAVES < 16) + u32 reserve2[16 - AT91_MATRIX_SLAVES]; +#endif + at91_prority_t pr[AT91_MATRIX_SLAVES]; +#if (AT91_MATRIX_SLAVES < 16) + u32 reserve3[32 - (2 * AT91_MATRIX_SLAVES)]; +#endif + u32 mrcr; /* 0x100 Master Remap Control */ + u32 reserve4[3]; +#if defined(CONFIG_AT91SAM9G45) + u32 ccr[52] /* 0x110 - 0x1E0 Chip Configuration */ + u32 womr; /* 0x1E4 Write Protect Mode */ + u32 wpsr; /* 0x1E8 Write Protect Status */ + u32 resg45_1[10]; +#elif defined(CONFIG_AT91SAM9260) || defined(CONFIG_AT91SAM9G20) + u32 res60_1[3]; + u32 csa; + u32 res60_2[56]; +#elif defined(CONFIG_AT91SAM9263) + u32 res63_1; + u32 tcmr; + u32 res63_2[2]; + u32 csa[2]; + u32 res63_3[54]; +#else + u32 reserve5[60]; +#endif +#endif +} at91_matrix_t; + +#endif /* __ASSEMBLY__ */ + +#define AT91_MATRIX_CSA_DBPUC 0x00000100 +#define AT91_MATRIX_CSA_VDDIOMSEL_1_8V 0x00000000 +#define AT91_MATRIX_CSA_VDDIOMSEL_3_3V 0x00010000 + +#define AT91_MATRIX_CSA_EBI_CS1A 0x00000002 +#define AT91_MATRIX_CSA_EBI_CS3A 0x00000008 +#define AT91_MATRIX_CSA_EBI_CS4A 0x00000010 +#define AT91_MATRIX_CSA_EBI_CS5A 0x00000020 + +#define AT91_MATRIX_CSA_EBI1_CS2A 0x00000008 + +#endif \ No newline at end of file diff --git a/include/asm-arm/arch-at91/at91_mc.h b/include/asm-arm/arch-at91/at91_mc.h new file mode 100644 index 0000000..3be00f5 --- /dev/null +++ b/include/asm-arm/arch-at91/at91_mc.h @@ -0,0 +1,89 @@ +/* + * Memory Setup stuff - taken from blob memsetup.S + * + * Copyright (C) 2009 Jens Scharsig (js_at_ng@scharsoft.de) + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef AT91_MC_H +#define AT91_MC_H + +typedef struct at91_ebi { + u32 csa; /* 0x00 Chip Select Assignment Register */ + u32 cfgr; /* 0x04 Configuration Register */ + u32 reserved[2]; +} at91_ebi_t; + +#define AT91_EBI_CSA_CS0A 0x0001 +#define AT91_EBI_CSA_CS1A 0x0002 + +#define AT91_EBI_CSA_CS3A 0x0008 +#define AT91_EBI_CSA_CS4A 0x0010 + +typedef struct at91_sdramc { + u32 mr; /* 0x00 SDRAMC Mode Register */ + u32 tr; /* 0x04 SDRAMC Refresh Timer Register */ + u32 cr; /* 0x08 SDRAMC Configuration Register */ + u32 ssr; /* 0x0C SDRAMC Self Refresh Register */ + u32 lpr; /* 0x10 SDRAMC Low Power Register */ + u32 ier; /* 0x14 SDRAMC Interrupt Enable Register */ + u32 idr; /* 0x18 SDRAMC Interrupt Disable Register */ + u32 imr; /* 0x1C SDRAMC Interrupt Mask Register */ + u32 icr; /* 0x20 SDRAMC Interrupt Status Register */ + u32 reserved[3]; +} at91_sdramc_t; + +typedef struct at91_smc { + u32 csr[8]; /* 0x00 SDRAMC Mode Register */ +} at91_smc_t; + +#define AT91_SMC_CSR_RWHOLD(x) ((x & 0x7) << 28) +#define AT91_SMC_CSR_RWSETUP(x) ((x & 0x7) << 24) +#define AT91_SMC_CSR_ACSS_STANDARD 0x00000000 +#define AT91_SMC_CSR_ACSS_1CYCLE 0x00010000 +#define AT91_SMC_CSR_ACSS_2CYCLE 0x00020000 +#define AT91_SMC_CSR_ACSS_3CYCLE 0x00030000 +#define AT91_SMC_CSR_DRP 0x00008000 +#define AT91_SMC_CSR_DBW_8 0x00004000 +#define AT91_SMC_CSR_DBW_16 0x00002000 +#define AT91_SMC_CSR_BAT_8 0x00000000 +#define AT91_SMC_CSR_BAT_16 0x00001000 +#define AT91_SMC_CSR_TDF(x) ((x & 0xF) << 8) +#define AT91_SMC_CSR_WSEN 0x00000080 +#define AT91_SMC_CSR_NWS(x) (x & 0x7F) + +typedef struct at91_bfc { + u32 mr; /* 0x00 SDRAMC Mode Register */ +} at91_bfc_t; + +typedef struct at91_mc { + u32 rcr; /* 0x00 MC Remap Control Register */ + u32 asr; /* 0x04 MC Abort Status Register */ + u32 aasr; /* 0x08 MC Abort Address Status Reg */ + u32 mpr; /* 0x0C MC Master Priority Register */ + u32 reserved1[20]; /* 0x10-0x5C */ + at91_ebi_t ebi; /* 0x60 - 0x6C EBI */ + at91_smc_t smc; /* 0x70 - 0x8C SMC User Interface */ + at91_sdramc_t sdramc; /* 0x90 - 0xBC SDRAMC User Interface */ + at91_bfc_t bfc; /* 0xC0 BFC User Interface */ + u32 reserved2[15]; +} at91_mc_t; + +#endif \ No newline at end of file diff --git a/include/asm-arm/arch-at91/at91_pdc.h b/include/asm-arm/arch-at91/at91_pdc.h new file mode 100644 index 0000000..dd12587 --- /dev/null +++ b/include/asm-arm/arch-at91/at91_pdc.h @@ -0,0 +1,41 @@ +/* + * Memory Setup stuff - taken from blob memsetup.S + * + * Copyright (C) 2009 Jens Scharsig (js_at_ng@scharsoft.de) + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef AT91_PDC_H +#define AT91_PDC_H + +typedef struct at91_pdc { + u32 rpr; /* 0x100 Receive Pointer Register */ + u32 rcr; /* 0x104 Receive Counter Register */ + u32 tpr; /* 0x108 Transmit Pointer Register */ + u32 tcr; /* 0x10C Transmit Counter Register */ + u32 pnpr; /* 0x110 Receive Next Pointer Register */ + u32 pncr; /* 0x114 Receive Next Counter Register */ + u32 tnpr; /* 0x118 Transmit Next Pointer Register */ + u32 tncr; /* 0x11C Transmit Next Counter Register */ + u32 ptcr; /* 0x120 Transfer Control Register */ + u32 ptsr; /* 0x124 Transfer Status Register */ +} at91_pdc_t; + +#endif diff --git a/include/asm-arm/arch-at91/at91_st.h b/include/asm-arm/arch-at91/at91_st.h new file mode 100644 index 0000000..2b8d153 --- /dev/null +++ b/include/asm-arm/arch-at91/at91_st.h @@ -0,0 +1,48 @@ +/* + * Memory Setup stuff - taken from blob memsetup.S + * + * Copyright (C) 2009 Jens Scharsig (js_at_ng@scharsoft.de) + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef AT91_ST_H +#define AT91_ST_H + +typedef struct at91_st { + + u32 cr; + u32 pimr; + u32 wdmr; + u32 rtmr; + u32 sr; + u32 ier; + u32 idr; + u32 imr; + u32 rtar; + u32 crtr; +} at91_st_t; + +#define AT91_ST_CR_WDRST 1 + +#define AT91_ST_WDMR_WDV(x) (x & 0xFFFF) +#define AT91_ST_WDMR_RSTEN 0x00010000 +#define AT91_ST_WDMR_EXTEN 0x00020000 + +#endif \ No newline at end of file diff --git a/include/asm-arm/arch-at91/at91_tc.h b/include/asm-arm/arch-at91/at91_tc.h new file mode 100644 index 0000000..b40cd20 --- /dev/null +++ b/include/asm-arm/arch-at91/at91_tc.h @@ -0,0 +1,79 @@ +/* + * Memory Setup stuff - taken from blob memsetup.S + * + * Copyright (C) 2009 Jens Scharsig (js_at_ng@scharsoft.de) + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef AT91_TC_H +#define AT91_TC_H + +typedef struct at91_tcc { + u32 ccr; /* 0x00 Channel Control Register */ + u32 cmr; /* 0x04 Channel Mode Register */ + u32 reserved1[2]; + u32 cv; /* 0x10 Counter Value */ + u32 ra; /* 0x14 Register A */ + u32 rb; /* 0x18 Register B */ + u32 rc; /* 0x1C Register C */ + u32 sr; /* 0x20 Status Register */ + u32 ier; /* 0x24 Interrupt Enable Register */ + u32 idr; /* 0x28 Interrupt Disable Register */ + u32 imr; /* 0x2C Interrupt Mask Register */ + u32 reserved3[4]; +} at91_tcc_t; + +#define AT91_TC_CCR_CLKEN 0x00000001 +#define AT91_TC_CCR_CLKDIS 0x00000002 +#define AT91_TC_CCR_SWTRG 0x00000004 + +#define AT91_TC_CMR_CPCTRG 0x00004000 + +#define AT91_TC_CMR_TCCLKS_CLOCK1 0x00000000 +#define AT91_TC_CMR_TCCLKS_CLOCK2 0x00000001 +#define AT91_TC_CMR_TCCLKS_CLOCK3 0x00000002 +#define AT91_TC_CMR_TCCLKS_CLOCK4 0x00000003 +#define AT91_TC_CMR_TCCLKS_CLOCK5 0x00000004 +#define AT91_TC_CMR_TCCLKS_XC0 0x00000005 +#define AT91_TC_CMR_TCCLKS_XC1 0x00000006 +#define AT91_TC_CMR_TCCLKS_XC2 0x00000007 + +typedef struct at91_tc { + at91_tcc_t tc[3]; /* 0x00 TC Channel 0-2 */ + u32 bcr; /* 0xC0 TC Block Control Register */ + u32 bmr; /* 0xC4 TC Block Mode Register */ +} at91_tc_t; + +#define AT91_TC_BMR_TC0XC0S_TCLK0 0x00000000 +#define AT91_TC_BMR_TC0XC0S_NONE 0x00000001 +#define AT91_TC_BMR_TC0XC0S_TIOA1 0x00000002 +#define AT91_TC_BMR_TC0XC0S_TIOA2 0x00000003 + +#define AT91_TC_BMR_TC1XC1S_TCLK1 0x00000000 +#define AT91_TC_BMR_TC1XC1S_NONE 0x00000004 +#define AT91_TC_BMR_TC1XC1S_TIOA0 0x00000008 +#define AT91_TC_BMR_TC1XC1S_TIOA2 0x0000000C + +#define AT91_TC_BMR_TC2XC2S_TCLK2 0x00000000 +#define AT91_TC_BMR_TC2XC2S_NONE 0x00000010 +#define AT91_TC_BMR_TC2XC2S_TIOA0 0x00000020 +#define AT91_TC_BMR_TC2XC2S_TIOA1 0x00000030 + +#endif diff --git a/include/asm-arm/arch-at91/at91rm9200.h b/include/asm-arm/arch-at91/at91rm9200.h new file mode 100644 index 0000000..da6843b --- /dev/null +++ b/include/asm-arm/arch-at91/at91rm9200.h @@ -0,0 +1,135 @@ +/* + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your optionany later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __AT91RM9200_H__ +#define __AT91RM9200_H__ + +/* Periperial Identifiers */ + +#define AT91_ID_SYS 1 /* System Peripheral */ +#define AT91_ID_PIOA 2 /* PIO port A */ +#define AT91_ID_PIOB 3 /* PIO port B */ +#define AT91_ID_PIOC 4 /* PIO port C */ +#define AT91_ID_PIOD 5 /* PIO port D BGA only */ +#define AT91_ID_USART0 6 /* USART 0 */ +#define AT91_ID_USART1 7 /* USART 1 */ +#define AT91_ID_USART2 8 /* USART 2 */ +#define AT91_ID_USART3 9 /* USART 3 */ +#define AT91_ID_MCI 10 /* Multimedia Card Interface */ +#define AT91_ID_UDP 11 /* USB Device Port */ +#define AT91_ID_TWI 12 /* Two Wire Interface */ +#define AT91_ID_SPI 13 /* Serial Peripheral Interface */ +#define AT91_ID_SSC0 14 /* Synch. Serial Controller 0 */ +#define AT91_ID_SSC1 15 /* Synch. Serial Controller 1 */ +#define AT91_ID_SSC2 16 /* Synch. Serial Controller 2 */ +#define AT91_ID_TC0 17 /* Timer Counter 0 */ +#define AT91_ID_TC1 18 /* Timer Counter 1 */ +#define AT91_ID_TC2 19 /* Timer Counter 2 */ +#define AT91_ID_TC3 20 /* Timer Counter 3 */ +#define AT91_ID_TC4 21 /* Timer Counter 4 */ +#define AT91_ID_TC5 22 /* Timer Counter 5 */ +#define AT91_ID_UHP 23 /* OHCI USB Host Port */ +#define AT91_ID_EMAC 24 /* Ethernet MAC */ +#define AT91_ID_IRQ0 25 /* Advanced Interrupt Controller */ +#define AT91_ID_IRQ1 26 /* Advanced Interrupt Controller */ +#define AT91_ID_IRQ2 27 /* Advanced Interrupt Controller */ +#define AT91_ID_IRQ3 28 /* Advanced Interrupt Controller */ +#define AT91_ID_IRQ4 29 /* Advanced Interrupt Controller */ +#define AT91_ID_IRQ5 30 /* Advanced Interrupt Controller */ +#define AT91_ID_IRQ6 31 /* Advanced Interrupt Controller */ + +#define AT91_USB_HOST_BASE 0x00300000 + +#define AT91_TC_BASE 0xFFFA0000 +#define AT91_UDP_BASE 0xFFFB0000 +#define AT91_MCI_BASE 0xFFFB4000 +#define AT91_TWI_BASE 0xFFFB8000 +#define AT91_EMAC_BASE 0xFFFBC000 +#define AT91_USART_BASE 0xFFFC0000 /* 4x 0x4000 Offset */ +#define AT91_SCC_BASE 0xFFFD0000 /* 4x 0x4000 Offset */ +#define AT91_SPI_BASE 0xFFFE0000 + +#define AT91_AIC_BASE 0xFFFFF000 +#define AT91_DBGU_BASE 0xFFFFF200 +#define AT91_PIO_BASE 0xFFFFF400 /* 4x 0x200 Offset */ +#define AT91_PMC_BASE 0xFFFFFC00 +#define AT91_ST_BASE 0xFFFFFD00 +#define AT91_ST_BASE 0xFFFFFD00 +#define AT91_RTC_BASE 0xFFFFFE00 +#define AT91_MC_BASE 0xFFFFFF00 + + +/* AT91RM9200 Periperial Multiplexing A */ +/* Port A */ +#define AT91_PMX_AA_EREFCK 0x00000080 +#define AT91_PMX_AA_ETXCK 0x00000080 +#define AT91_PMX_AA_ETXEN 0x00000100 +#define AT91_PMX_AA_ETX0 0x00000200 +#define AT91_PMX_AA_ETX1 0x00000400 +#define AT91_PMX_AA_ECRS 0x00000800 +#define AT91_PMX_AA_ECRSDV 0x00000800 +#define AT91_PMX_AA_ERX0 0x00001000 +#define AT91_PMX_AA_ERX1 0x00002000 +#define AT91_PMX_AA_ERXER 0x00004000 +#define AT91_PMX_AA_EMDC 0x00008000 +#define AT91_PMX_AA_EMDIO 0x00010000 + +#define AT91_PMX_AA_TXD2 0x00810000 + +#define AT91_PMX_AA_TWD 0x02000000 +#define AT91_PMX_AA_TWCK 0x04000000 + +/* Port B */ +#define AT91_PMX_BA_ERXCK 0x00080000 +#define AT91_PMX_BA_ECOL 0x00040000 +#define AT91_PMX_BA_ERXDV 0x00020000 +#define AT91_PMX_BA_ERX3 0x00010000 +#define AT91_PMX_BA_ERX2 0x00008000 +#define AT91_PMX_BA_ETXER 0x00004000 +#define AT91_PMX_BA_ETX3 0x00002000 +#define AT91_PMX_BA_ETX2 0x00001000 + +/* Port B */ + +#define AT91_PMX_CA_BFCK 0x00000001 +#define AT91_PMX_CA_BFRDY 0x00000002 +#define AT91_PMX_CA_SMOE 0x00000002 +#define AT91_PMX_CA_BFAVD 0x00000004 +#define AT91_PMX_CA_BFBAA 0x00000008 +#define AT91_PMX_CA_SMWE 0x00000008 +#define AT91_PMX_CA_BFOE 0x00000010 +#define AT91_PMX_CA_BFWE 0x00000020 +#define AT91_PMX_CA_NWAIT 0x00000040 +#define AT91_PMX_CA_A23 0x00000080 +#define AT91_PMX_CA_A24 0x00000100 +#define AT91_PMX_CA_A25 0x00000200 +#define AT91_PMX_CA_CFRNW 0x00000200 +#define AT91_PMX_CA_NCS4 0x00000400 +#define AT91_PMX_CA_CFCS 0x00000400 +#define AT91_PMX_CA_NCS5 0x00000800 +#define AT91_PMX_CA_CFCE1 0x00001000 +#define AT91_PMX_CA_NCS6 0x00001000 +#define AT91_PMX_CA_CFCE2 0x00002000 +#define AT91_PMX_CA_NCS7 0x00002000 +#define AT91_PMX_CA_D16_31 0xFFFF0000 + +#define AT91_CPU_NAME "AT91RM9200" + +#endif
Jens Scharsig
