[U-Boot] Please pull from u-boot-i2c
Hello Tom,
please pull from u-boot-i2c master
The following changes since commit a43aebee89acf57b4e22018f401cffc9fef4fd85:
usb: ulpi: kconfig: Remove meaningless choice default (2018-02-05 20:58:12 -0500)
git://git.denx.de/u-boot-i2c.git master
for you to fetch changes up to 8bcf12ccce89ef9c77d9322930445b4f4ca3b822:
i2c: mvtwsi.c: Avoid NULL dereference (2018-02-06 07:02:32 +0100)
---------------------------------------------------------------- Heinrich Schuchardt (1): i2c: mvtwsi.c: Avoid NULL dereference
Mario Six (6): i2c: fsl_i2c: Fix style violations i2c: fsl_i2c: Remove inline declarations i2c: fsl_i2c: Make live-tree compatible i2c: ihs_i2c: Prepare DM conversion i2c: ihs_i2c: Make DM compatible i2c: ihs_i2c: Factor out send_buffer method
drivers/i2c/Kconfig | 6 +++ drivers/i2c/fsl_i2c.c | 127 +++++++++++++++++++++++++++++------------------------------ drivers/i2c/ihs_i2c.c | 279 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++------------------ drivers/i2c/mvtwsi.c | 3 +- 4 files changed, 311 insertions(+), 104 deletions(-)
No warnings on travis: https://travis-ci.org/hsdenx/u-boot-i2c/builds/337874954
bye, Heiko
On Tue, Feb 06, 2018 at 01:45:49PM +0100, Heiko Schocher wrote:
Hello Tom,
Heiko Schocher
