[U-Boot] [PULL] Please pull u-boot-imx
Hi Albert,
please pull from u-boot-imx, thanks !
cm_fx6 is still broken in u-boot-imx, but after merging with Tom's tree it is built correctly.
The following changes since commit 2a8c9c86b92a9ccee3c27286de317e19bb0530b3:
Merge branch 'u-boot-ti/master' into 'u-boot-arm/master' (2014-09-21 16:56:44 +0200)
git://www.denx.de/git/u-boot-imx.git master
for you to fetch changes up to 5e3a388cddce1685ccd9bc1b58ddb89a191ed88f:
nitrogen6x: config: enable EXT4 filesystem (2014-10-06 17:57:23 +0200)
---------------------------------------------------------------- Andrew Ruder (2): arm: mx31: use common timer functions arm: mx35: use common timer functions
Christian Gmeiner (1): imx6: add Bachmann OT1200 board
Diego Rondini (1): nitrogen6x: config: allow boot to USB stick
Eric Nelson (23): nitrogen6x: Update DDR timings for 2G memory arrangement nitrogen6x: implement board_cfb_skip() to disable text output nitrogen6x: configure SD2 pads for SDIO on USDHC2 nitrogen6x: power-down miscellanous peripherals nitrogen6x: staticize board file nitrogen6x: prevent warnings about board_ehci* callbacks nitrogen6x: display: add qvga panel nitrogen6x: display: add support for LG-9.7 LVDS display nitrogen6x: display: add LDB-WXGA-S for SPWG 1280x800 displays nitrogen6x: display: add support for fusion 7 display nitrogen6x: display: add svga display (800x600) nitrogen6x: display: add Ampire 1024x600 panel nitrogen6x: display: add wvga-lvds panel nitrogen6x: display use I2C detect for HDMI nitrogen6x: config: add USB Mass Storage (ums) support nitrogen6x: config: add initrd_high nitrogen6x: config: expose SATA, then MMC over USB nitrogen6x: config: enable USB keyboard support nitrogen6x: config: add CONFIG_CMD_MEMTEST nitrogen6x: config: enable "i2c edid" nitrogen6x: config: disable logo nitrogen6x: config: add gpio command nitrogen6x: config: enable Android fastboot
Fabio Estevam (9): mx6sxsabresd: Staticize i2c_pad_info1 mx6qsabreauto: Staticize when possible cm_fx6: Remove CONFIG_NETMASK mx51evk: Fix CONFIG_SYS_FSL_ESDHC_ADDR mx51evk: Add generic board support mx25pdk: Fix CONFIG_SYS_FSL_ESDHC_ADDR mx25pdk: Add generic board support wandboard: Select CONFIG_CMD_FUSE mx6sxsabresd: Fix PCI reset and power GPIO assignments
Guillaume GARDET (1): imx: nitrogen6x: Make use of both uSD and SD slots to load script or kernel on Sabrelite board
Kevin Mihelich (2): nitrogen6x: config: use FS_GENERIC load command nitrogen6x: config: enable EXT4 filesystem
Marek Vasut (11): usb: ehci: mxs: Add board-specific callbacks arm: mxs: Wait when disabling VDDMEM current limiter arm: mxs: Wait for DRAM to start arm: mxs: olinuxino: Enable USB only when needed arm: mxs: olinuxino: Fine-tune DRAM configuration arm: m28evk: Test if bootscript exists before loading it arm: m53evk: Test if bootscript exists before loading it arm: m28evk: Enable FS_GENERIC arm: m53evk: Enable FS_GENERIC arm: m28evk: Zap superfluous tab in env arm: m53evk: Zap superfluous tab in env
Nitin Garg (3): imx: ddr: Move mx6q_4x_mt41j128.cfg to mx6sabresd board imx: Support i.MX6 High Assurance Boot authentication imx6sx: Fix i.MX6SX HAB api function table offset
Peng Fan (3): imx:mx6sxsabresd: change CONFIG_SYS_FSL_ESDHC_ADDR imx:mx6qarm2: change CONFIG_SYS_FSL_ESDHC_ADDR imx:mx6slevk: change CONFIG_SYS_FSL_ESDHC_ADDR
Robert Winkler (1): nitrogen6x: display: add support lvds jeida screen
Stefan Agner (2): mtd: nand: add Freescale vf610_nfc driver arm: vf610: add NAND support for vf610twr
Stefan Roese (1): ARM: mx6: gw_ventana: Remove superfluous memset of GD in board_init_f
Stefano Babic (3): Merge branch 'master' of git://git.denx.de/u-boot-arm imx: Fix warning by building vf610twr_nand Merge branch 'master' of git://git.denx.de/u-boot-arm
Troy Kisky (4): nitrogen6x: simplify board_mmc_getcd nitrogen6x: configure SGTL5000, CSI camera clock outputs nitrogen6x: phy: add 100 us delay after phy reset nitrogen6x: config: allow more bootargs parameters
Ye.Li (6): imx: mx6qarm2: Add the kernel FDT Loading support imx: mx6qarm2: Change the mmcroot and mmcpart env value imx: mx6: Checking PLL2 PFD0 and PFD2 for periph_clk before PFD reset usb: ehci-mx6: Rename the USB register base address imx: mx6dlarm2: Add support for i.MX6DL arm2 DDR3 board imx: mx6dlarm2: Add support for i.MX6Q/DL arm2 LPDDR2 boards
arch/arm/Kconfig | 4 + arch/arm/cpu/arm1136/mx31/timer.c | 104 +------ arch/arm/cpu/arm1136/mx35/timer.c | 83 ------ arch/arm/cpu/arm926ejs/mxs/spl_mem_init.c | 13 +- arch/arm/cpu/armv7/mx6/clock.c | 27 ++ arch/arm/cpu/armv7/mx6/hab.c | 169 ++++++++++- arch/arm/cpu/armv7/mx6/soc.c | 39 ++- arch/arm/include/asm/arch-mx31/imx-regs.h | 10 + arch/arm/include/asm/arch-mx35/imx-regs.h | 12 + arch/arm/include/asm/arch-mx6/clock.h | 1 + arch/arm/include/asm/arch-mx6/hab.h | 16 +- arch/arm/include/asm/arch-mx6/imx-regs.h | 9 +- board/bachmann/ot1200/Kconfig | 23 ++ board/bachmann/ot1200/MAINTAINERS | 6 + board/bachmann/ot1200/Makefile | 9 + board/bachmann/ot1200/README | 20 ++ board/{freescale/imx/ddr => bachmann/ot1200}/mx6q_4x_mt41j128.cfg | 0 board/bachmann/ot1200/ot1200.c | 251 ++++++++++++++++ board/boundary/nitrogen6x/1066mhz_4x256mx16.cfg | 24 +- board/boundary/nitrogen6x/nitrogen6x.c | 292 +++++++++++++++++-- board/congatec/cgtqmx6eval/imximage.cfg | 169 +++++++++++ board/freescale/mx6qarm2/MAINTAINERS | 4 + board/freescale/mx6qarm2/imximage.cfg | 189 +++++++++++- board/freescale/mx6qarm2/imximage_mx6dl.cfg | 462 +++++++++++++++++++++++++++++ board/freescale/mx6qarm2/mx6qarm2.c | 11 +- board/freescale/mx6qsabreauto/mx6qsabreauto.c | 16 +- board/freescale/mx6sabresd/mx6q_4x_mt41j128.cfg | 169 +++++++++++ board/freescale/mx6sxsabresd/mx6sxsabresd.c | 2 +- board/freescale/vf610twr/MAINTAINERS | 1 + board/freescale/vf610twr/vf610twr.c | 47 ++- board/gateworks/gw_ventana/gw_ventana_spl.c | 7 - board/olimex/mx23_olinuxino/mx23_olinuxino.c | 46 ++- configs/cgtqmx6qeval_defconfig | 2 +- configs/mx6dlarm2_defconfig | 3 + configs/mx6dlarm2_lpddr2_defconfig | 3 + configs/mx6qarm2_defconfig | 2 +- configs/mx6qarm2_lpddr2_defconfig | 3 + configs/mx6qsabresd_defconfig | 2 +- configs/ot1200_defconfig | 3 + configs/vf610twr_defconfig | 2 +- configs/vf610twr_nand_defconfig | 3 + drivers/mtd/nand/Makefile | 1 + drivers/mtd/nand/vf610_nfc.c | 724 ++++++++++++++++++++++++++++++++++++++++++++++ drivers/usb/host/ehci-mx6.c | 4 +- drivers/usb/host/ehci-mxs.c | 16 + include/configs/cm_fx6.h | 1 - include/configs/m28evk.h | 13 +- include/configs/m53evk.h | 13 +- include/configs/mx25pdk.h | 3 +- include/configs/mx51evk.h | 3 +- include/configs/mx6qarm2.h | 49 +++- include/configs/mx6slevk.h | 2 +- include/configs/mx6sxsabresd.h | 6 +- include/configs/nitrogen6x.h | 113 ++++++-- include/configs/ot1200.h | 197 +++++++++++++ include/configs/vf610twr.h | 46 ++- include/configs/wandboard.h | 5 + 57 files changed, 3115 insertions(+), 339 deletions(-) create mode 100644 board/bachmann/ot1200/Kconfig create mode 100644 board/bachmann/ot1200/MAINTAINERS create mode 100644 board/bachmann/ot1200/Makefile create mode 100644 board/bachmann/ot1200/README rename board/{freescale/imx/ddr => bachmann/ot1200}/mx6q_4x_mt41j128.cfg (100%) create mode 100644 board/bachmann/ot1200/ot1200.c create mode 100644 board/congatec/cgtqmx6eval/imximage.cfg create mode 100644 board/freescale/mx6qarm2/imximage_mx6dl.cfg create mode 100644 board/freescale/mx6sabresd/mx6q_4x_mt41j128.cfg create mode 100644 configs/mx6dlarm2_defconfig create mode 100644 configs/mx6dlarm2_lpddr2_defconfig create mode 100644 configs/mx6qarm2_lpddr2_defconfig create mode 100644 configs/ot1200_defconfig create mode 100644 configs/vf610twr_nand_defconfig create mode 100644 drivers/mtd/nand/vf610_nfc.c
Best regards, Stefano
Hi Stefano,
On Wed, 08 Oct 2014 10:17:49 +0200, Stefano Babic sbabic@denx.de wrote:
Hi Albert,
Ok -- it has been building correctly in u-boot-arm/master for some time already.
Applied to u-boot-arm/master, thanks.
Amicalement,
Albert ARIBAUD
Stefano Babic
