[U-Boot] [PATCH 1/3] mtd: spi: Add a new option SPL_SPI_FLASH_MTD to Kconfig
To allow SPI_FLASH_MTD being enabled separately in SPL we add a new option. The only user currently is the stm32mp15_basic board.
Signed-off-by: Frieder Schrempf frieder.schrempf@kontron.de --- drivers/mtd/spi/Kconfig | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/drivers/mtd/spi/Kconfig b/drivers/mtd/spi/Kconfig index d3b007a731..f5cb7f6577 100644 --- a/drivers/mtd/spi/Kconfig +++ b/drivers/mtd/spi/Kconfig @@ -196,4 +196,12 @@ config SPI_FLASH_MTD
If unsure, say N
+config SPL_SPI_FLASH_MTD + bool "SPI flash MTD support for SPL" + depends on SPI_FLASH + help + Enable the MTD support for the SPI flash layer in SPL. + + If unsure, say N + endmenu # menu "SPI Flash Support"
As SPI_FLASH_MTD is used in SPL and U-Boot proper, we enable both, now that a separate option for SPL was introduced.
Signed-off-by: Frieder Schrempf frieder.schrempf@kontron.de --- configs/stm32mp15_basic_defconfig | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/configs/stm32mp15_basic_defconfig b/configs/stm32mp15_basic_defconfig index 09785b5dc1..390319657f 100644 --- a/configs/stm32mp15_basic_defconfig +++ b/configs/stm32mp15_basic_defconfig @@ -7,10 +7,10 @@ CONFIG_TARGET_STM32MP1=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y # CONFIG_ARMV7_VIRT is not set +CONFIG_SPL_TEXT_BASE=0x2FFC2500 CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_BOOTCOMMAND="run bootcmd_stm32mp" -CONFIG_SPL_TEXT_BASE=0x2FFC2500 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION=3 CONFIG_SPL_I2C_SUPPORT=y @@ -90,6 +90,7 @@ CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_WINBOND=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set CONFIG_SPI_FLASH_MTD=y +CONFIG_SPL_SPI_FLASH_MTD=y CONFIG_DM_ETH=y CONFIG_DWC_ETH_QOS=y CONFIG_PHY=y
On Fri, 13 Sep 2019 22:43:43 +0000 Schrempf Frieder frieder.schrempf@kontron.de wrote:
Reviewed-by: Lukasz Majewski lukma@denx.de
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-59 Fax: (+49)-8142-66989-80 Email: lukma@denx.de
On Sat, Sep 14, 2019 at 4:18 AM Schrempf Frieder frieder.schrempf@kontron.de wrote:
Unrelated change wrt to commit message?
Hi Jagan,
Yes, this is unrelated, but that's what 'menuconfig' and 'savedefconfig' gave me as output. So I would think it's ok. If you don't think so, feel free to remove this change or let me know if I should remove it.
Thanks, Frieder
Hi Jagan,
On 17.10.19 08:42, Frieder Schrempf wrote:
Hi Jagan,
In patchwork all three patches of this series are marked with "Changes Requested". Can you please let me know what needs to be fixed?
Thanks, Frieder
On Tue, Oct 22, 2019 at 6:23 PM Schrempf Frieder frieder.schrempf@kontron.de wrote:
Hi Jagan,
Hi Jagan,
Thought you might drop that unrelated change and send next version, but anyway I have changed and
Applied to u-boot-spi/master
Hi Jagan,
Hi Jagan,
Hi Jagan,
I have asked you to "let me know if I should remove it" above and you didn't do so. Therefore I assumed you do it yourself, or you apply it as is.
Anyway, thanks a lot!
Regards, Frieder
Most boards currently use SPI_FLASH_MTD only in U-Boot proper, not in SPL. They often rely on hacks in the board header files to include this option conditionally. To be able to fix this, we previously introduced a separate option SPL_SPI_FLASH_MTD.
Therefore we can now adjust the Makefile and change the code in sf_probe.c and sf_internal.h to use CONFIG_IS_ENABLED(SPI_FLASH_MTD).
We also need to move all occurences of CONFIG_SPI_FLASH_MTD from the header files to the according defconfigs. The affected boards are socfpga, aristainetos, cm_fx6, display5, ventana, rcar-gen2, dh_imx6 and da850evm.
We do this all in one patch to guarantee bisectibility.
This change was tested with buildman to make sure it does not introduce any regressions by comparing the resulting binary sizes.
Signed-off-by: Frieder Schrempf frieder.schrempf@kontron.de --- configs/aristainetos2_defconfig | 1 + configs/aristainetos2b_defconfig | 1 + configs/aristainetos_defconfig | 1 + configs/cm_fx6_defconfig | 1 + configs/display5_defconfig | 1 + configs/display5_factory_defconfig | 1 + configs/socfpga_arria5_defconfig | 1 + configs/socfpga_cyclone5_defconfig | 1 + configs/socfpga_dbm_soc1_defconfig | 1 + configs/socfpga_de0_nano_soc_defconfig | 1 + configs/socfpga_de10_nano_defconfig | 1 + configs/socfpga_is1_defconfig | 1 + configs/socfpga_mcvevk_defconfig | 1 + configs/socfpga_sockit_defconfig | 1 + configs/socfpga_socrates_defconfig | 1 + configs/socfpga_sr1500_defconfig | 1 + configs/socfpga_vining_fpga_defconfig | 1 + drivers/mtd/spi/Makefile | 2 +- drivers/mtd/spi/sf_internal.h | 2 +- drivers/mtd/spi/sf_probe.c | 6 +++--- include/configs/aristainetos-common.h | 1 - include/configs/cm_fx6.h | 7 ------- include/configs/da850evm.h | 7 +------ include/configs/dh_imx6.h | 1 - include/configs/display5.h | 4 ---- include/configs/gw_ventana.h | 10 +--------- include/configs/rcar-gen2-common.h | 4 +--- include/configs/socfpga_common.h | 4 ---- 28 files changed, 25 insertions(+), 40 deletions(-)
diff --git a/configs/aristainetos2_defconfig b/configs/aristainetos2_defconfig index 18ef5d2dce..0bfc117762 100644 --- a/configs/aristainetos2_defconfig +++ b/configs/aristainetos2_defconfig @@ -44,6 +44,7 @@ CONFIG_SF_DEFAULT_CS=1 CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_MTD=y CONFIG_MTD_UBI_FASTMAP=y CONFIG_MTD_UBI_FASTMAP_AUTOCONVERT=1 CONFIG_PHYLIB=y diff --git a/configs/aristainetos2b_defconfig b/configs/aristainetos2b_defconfig index 1054c05d8c..e2da747a8f 100644 --- a/configs/aristainetos2b_defconfig +++ b/configs/aristainetos2b_defconfig @@ -42,6 +42,7 @@ CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_MTD=y CONFIG_MTD_UBI_FASTMAP=y CONFIG_MTD_UBI_FASTMAP_AUTOCONVERT=1 CONFIG_PHYLIB=y diff --git a/configs/aristainetos_defconfig b/configs/aristainetos_defconfig index 4080a7b310..5caf95c22f 100644 --- a/configs/aristainetos_defconfig +++ b/configs/aristainetos_defconfig @@ -43,6 +43,7 @@ CONFIG_SF_DEFAULT_BUS=3 CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_MTD=y CONFIG_MTD_UBI_FASTMAP=y CONFIG_MTD_UBI_FASTMAP_AUTOCONVERT=1 CONFIG_PHYLIB=y diff --git a/configs/cm_fx6_defconfig b/configs/cm_fx6_defconfig index fd0db4db5c..15be7db027 100644 --- a/configs/cm_fx6_defconfig +++ b/configs/cm_fx6_defconfig @@ -72,6 +72,7 @@ CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_SST=y CONFIG_SPI_FLASH_WINBOND=y +CONFIG_SPI_FLASH_MTD=y CONFIG_PHYLIB=y CONFIG_MII=y CONFIG_DM_PMIC=y diff --git a/configs/display5_defconfig b/configs/display5_defconfig index 8609cd5a8c..5a4cc772be 100644 --- a/configs/display5_defconfig +++ b/configs/display5_defconfig @@ -75,6 +75,7 @@ CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=50000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_MTD=y CONFIG_PHYLIB=y CONFIG_PHY_MARVELL=y CONFIG_FEC_MXC=y diff --git a/configs/display5_factory_defconfig b/configs/display5_factory_defconfig index 70c64260d8..66c68e5ea9 100644 --- a/configs/display5_factory_defconfig +++ b/configs/display5_factory_defconfig @@ -74,6 +74,7 @@ CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=50000000 CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_MTD=y CONFIG_PHYLIB=y CONFIG_FEC_MXC=y CONFIG_MII=y diff --git a/configs/socfpga_arria5_defconfig b/configs/socfpga_arria5_defconfig index 89e5ff8c71..30c2d19941 100644 --- a/configs/socfpga_arria5_defconfig +++ b/configs/socfpga_arria5_defconfig @@ -47,6 +47,7 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_SPI_FLASH_MTD=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y CONFIG_DM_ETH=y diff --git a/configs/socfpga_cyclone5_defconfig b/configs/socfpga_cyclone5_defconfig index 00f2104276..dfe011b959 100644 --- a/configs/socfpga_cyclone5_defconfig +++ b/configs/socfpga_cyclone5_defconfig @@ -48,6 +48,7 @@ CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_SPI_FLASH_MTD=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y CONFIG_DM_ETH=y diff --git a/configs/socfpga_dbm_soc1_defconfig b/configs/socfpga_dbm_soc1_defconfig index 1877010a19..ee693f3def 100644 --- a/configs/socfpga_dbm_soc1_defconfig +++ b/configs/socfpga_dbm_soc1_defconfig @@ -46,6 +46,7 @@ CONFIG_SYS_I2C_DW=y CONFIG_DM_MMC=y CONFIG_MMC_DW=y CONFIG_MTD_DEVICE=y +CONFIG_SPI_FLASH_MTD=y CONFIG_DM_ETH=y CONFIG_PHY_GIGE=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/socfpga_de0_nano_soc_defconfig b/configs/socfpga_de0_nano_soc_defconfig index de50f17174..e91d6f62f8 100644 --- a/configs/socfpga_de0_nano_soc_defconfig +++ b/configs/socfpga_de0_nano_soc_defconfig @@ -43,6 +43,7 @@ CONFIG_SYS_I2C_DW=y CONFIG_DM_MMC=y CONFIG_MMC_DW=y CONFIG_MTD_DEVICE=y +CONFIG_SPI_FLASH_MTD=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y CONFIG_DM_ETH=y diff --git a/configs/socfpga_de10_nano_defconfig b/configs/socfpga_de10_nano_defconfig index 03961195ac..ffe9d6c10c 100644 --- a/configs/socfpga_de10_nano_defconfig +++ b/configs/socfpga_de10_nano_defconfig @@ -39,6 +39,7 @@ CONFIG_SYS_I2C_DW=y CONFIG_DM_MMC=y CONFIG_MMC_DW=y CONFIG_MTD_DEVICE=y +CONFIG_SPI_FLASH_MTD=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y CONFIG_DM_ETH=y diff --git a/configs/socfpga_is1_defconfig b/configs/socfpga_is1_defconfig index 6ea06c1104..76ab87250b 100644 --- a/configs/socfpga_is1_defconfig +++ b/configs/socfpga_is1_defconfig @@ -43,6 +43,7 @@ CONFIG_SYS_I2C_DW=y CONFIG_MTD_DEVICE=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_MTD=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y CONFIG_DM_ETH=y diff --git a/configs/socfpga_mcvevk_defconfig b/configs/socfpga_mcvevk_defconfig index 161bd6fca3..4d3caaa8ad 100644 --- a/configs/socfpga_mcvevk_defconfig +++ b/configs/socfpga_mcvevk_defconfig @@ -42,6 +42,7 @@ CONFIG_DM_I2C=y CONFIG_SYS_I2C_DW=y CONFIG_DM_MMC=y CONFIG_MMC_DW=y +CONFIG_SPI_FLASH_MTD=y CONFIG_DM_ETH=y CONFIG_PHY_GIGE=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/socfpga_sockit_defconfig b/configs/socfpga_sockit_defconfig index 8ec1c05571..0ffcfda21e 100644 --- a/configs/socfpga_sockit_defconfig +++ b/configs/socfpga_sockit_defconfig @@ -48,6 +48,7 @@ CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_SPI_FLASH_MTD=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y CONFIG_DM_ETH=y diff --git a/configs/socfpga_socrates_defconfig b/configs/socfpga_socrates_defconfig index 15f81d1a4b..193af0b0df 100644 --- a/configs/socfpga_socrates_defconfig +++ b/configs/socfpga_socrates_defconfig @@ -48,6 +48,7 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_MTD=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y CONFIG_DM_ETH=y diff --git a/configs/socfpga_sr1500_defconfig b/configs/socfpga_sr1500_defconfig index 941bf1124a..899dd8396b 100644 --- a/configs/socfpga_sr1500_defconfig +++ b/configs/socfpga_sr1500_defconfig @@ -49,6 +49,7 @@ CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=100000000 CONFIG_SPI_FLASH_STMICRO=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_SPI_FLASH_MTD=y CONFIG_PHY_MARVELL=y CONFIG_DM_ETH=y CONFIG_PHY_GIGE=y diff --git a/configs/socfpga_vining_fpga_defconfig b/configs/socfpga_vining_fpga_defconfig index 96f806ab5f..f96f536169 100644 --- a/configs/socfpga_vining_fpga_defconfig +++ b/configs/socfpga_vining_fpga_defconfig @@ -72,6 +72,7 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_SPI_FLASH_MTD=y CONFIG_MTD_UBI_FASTMAP=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y diff --git a/drivers/mtd/spi/Makefile b/drivers/mtd/spi/Makefile index f99f6cb16e..fb67ba32c6 100644 --- a/drivers/mtd/spi/Makefile +++ b/drivers/mtd/spi/Makefile @@ -19,5 +19,5 @@ endif
obj-$(CONFIG_SPI_FLASH) += spi-nor.o obj-$(CONFIG_SPI_FLASH_DATAFLASH) += sf_dataflash.o sf.o -obj-$(CONFIG_SPI_FLASH_MTD) += sf_mtd.o +obj-$(CONFIG_$(SPL_)SPI_FLASH_MTD) += sf_mtd.o obj-$(CONFIG_SPI_FLASH_SANDBOX) += sandbox.o diff --git a/drivers/mtd/spi/sf_internal.h b/drivers/mtd/spi/sf_internal.h index a6bf734830..8542b03685 100644 --- a/drivers/mtd/spi/sf_internal.h +++ b/drivers/mtd/spi/sf_internal.h @@ -94,7 +94,7 @@ int spi_flash_cmd_write(struct spi_slave *spi, const u8 *cmd, size_t cmd_len, int spi_flash_cmd_get_sw_write_prot(struct spi_flash *flash);
-#ifdef CONFIG_SPI_FLASH_MTD +#if CONFIG_IS_ENABLED(SPI_FLASH_MTD) int spi_flash_mtd_register(struct spi_flash *flash); void spi_flash_mtd_unregister(void); #endif diff --git a/drivers/mtd/spi/sf_probe.c b/drivers/mtd/spi/sf_probe.c index 73297e1a0a..f051e473ff 100644 --- a/drivers/mtd/spi/sf_probe.c +++ b/drivers/mtd/spi/sf_probe.c @@ -44,7 +44,7 @@ static int spi_flash_probe_slave(struct spi_flash *flash) if (ret) goto err_read_id;
-#ifdef CONFIG_SPI_FLASH_MTD +#if CONFIG_IS_ENABLED(SPI_FLASH_MTD) ret = spi_flash_mtd_register(flash); #endif
@@ -83,7 +83,7 @@ struct spi_flash *spi_flash_probe(unsigned int busnum, unsigned int cs,
void spi_flash_free(struct spi_flash *flash) { -#ifdef CONFIG_SPI_FLASH_MTD +#if CONFIG_IS_ENABLED(SPI_FLASH_MTD) spi_flash_mtd_unregister(); #endif spi_free_slave(flash->spi); @@ -152,7 +152,7 @@ static int spi_flash_std_probe(struct udevice *dev)
static int spi_flash_std_remove(struct udevice *dev) { -#ifdef CONFIG_SPI_FLASH_MTD +#if CONFIG_IS_ENABLED(SPI_FLASH_MTD) spi_flash_mtd_unregister(); #endif return 0; diff --git a/include/configs/aristainetos-common.h b/include/configs/aristainetos-common.h index e998d9b1b2..b451c7e7dc 100644 --- a/include/configs/aristainetos-common.h +++ b/include/configs/aristainetos-common.h @@ -30,7 +30,6 @@ #define CONFIG_ETHPRIME "FEC" #define CONFIG_FEC_MXC_PHYADDR 0
-#define CONFIG_SPI_FLASH_MTD #define CONFIG_SYS_SPI_ST_ENABLE_WP_PIN
#define CONFIG_EXTRA_ENV_SETTINGS \ diff --git a/include/configs/cm_fx6.h b/include/configs/cm_fx6.h index b957e9cba4..c1a6625fcb 100644 --- a/include/configs/cm_fx6.h +++ b/include/configs/cm_fx6.h @@ -38,13 +38,6 @@ #define CONFIG_MXC_UART_BASE UART4_BASE #define CONFIG_SYS_BAUDRATE_TABLE {9600, 19200, 38400, 57600, 115200}
-/* SPI flash */ - -/* MTD support */ -#ifndef CONFIG_SPL_BUILD -#define CONFIG_SPI_FLASH_MTD -#endif - /* Environment */ #define CONFIG_ENV_SECT_SIZE (64 * 1024) #define CONFIG_ENV_SIZE (8 * 1024) diff --git a/include/configs/da850evm.h b/include/configs/da850evm.h index 41f0813a01..6876134a00 100644 --- a/include/configs/da850evm.h +++ b/include/configs/da850evm.h @@ -190,16 +190,11 @@ #define CONFIG_ENV_SECT_SIZE CONFIG_SYS_FLASH_SECT_SZ #endif
-#ifdef CONFIG_USE_SPIFLASH -#ifdef CONFIG_ENV_IS_IN_SPI_FLASH +#if defined(CONFIG_USE_SPIFLASH) && defined(CONFIG_ENV_IS_IN_SPI_FLASH) #define CONFIG_ENV_SIZE (64 << 10) #define CONFIG_ENV_OFFSET (512 << 10) #define CONFIG_ENV_SECT_SIZE (64 << 10) #endif -#ifdef CONFIG_SPL_BUILD -#undef CONFIG_SPI_FLASH_MTD -#endif -#endif
/* * U-Boot general configuration diff --git a/include/configs/dh_imx6.h b/include/configs/dh_imx6.h index c516e6ed4c..485bc2d997 100644 --- a/include/configs/dh_imx6.h +++ b/include/configs/dh_imx6.h @@ -59,7 +59,6 @@ #if defined(CONFIG_SPL_BUILD) #undef CONFIG_DM_SPI #undef CONFIG_DM_SPI_FLASH -#undef CONFIG_SPI_FLASH_MTD #endif
/* UART */ diff --git a/include/configs/display5.h b/include/configs/display5.h index e503e4a0ce..64f211307a 100644 --- a/include/configs/display5.h +++ b/include/configs/display5.h @@ -35,10 +35,6 @@ * 0x1540000 - 0x1640000 : SPI.factory (1MiB) */
-#ifndef CONFIG_SPL_BUILD -#define CONFIG_SPI_FLASH_MTD -#endif - /* Below values are "dummy" - only to avoid build break */ #define CONFIG_SYS_SPI_KERNEL_OFFS 0x150000 #define CONFIG_SYS_SPI_ARGS_OFFS 0x140000 diff --git a/include/configs/gw_ventana.h b/include/configs/gw_ventana.h index a27627e721..e543061bff 100644 --- a/include/configs/gw_ventana.h +++ b/include/configs/gw_ventana.h @@ -47,15 +47,7 @@ #define CONFIG_MXC_UART #define CONFIG_MXC_UART_BASE UART2_BASE
-#ifdef CONFIG_SPI_FLASH - -/* SPI */ -#ifdef CONFIG_CMD_SF - #define CONFIG_SPI_FLASH_MTD - /* GPIO 3-19 (21248) */ -#endif - -#elif defined(CONFIG_SPL_NAND_SUPPORT) +#if !defined(CONFIG_SPI_FLASH) && defined(CONFIG_SPL_NAND_SUPPORT) /* Enable NAND support */ #ifdef CONFIG_CMD_NAND #define CONFIG_SYS_MAX_NAND_DEVICE 1 diff --git a/include/configs/rcar-gen2-common.h b/include/configs/rcar-gen2-common.h index 71a5909045..e940a8b70a 100644 --- a/include/configs/rcar-gen2-common.h +++ b/include/configs/rcar-gen2-common.h @@ -46,11 +46,9 @@ #define CONFIG_ENV_SIZE_REDUND (CONFIG_SYS_MONITOR_LEN)
/* SF MTD */ -#if defined(CONFIG_SPI_FLASH_MTD) && !defined(CONFIG_SPL_BUILD) -#else +#ifdef CONFIG_SPL_BUILD #undef CONFIG_DM_SPI #undef CONFIG_DM_SPI_FLASH -#undef CONFIG_SPI_FLASH_MTD #endif
/* Timer */ diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index b11fe021a7..96b32cd99a 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -133,10 +133,6 @@ /* * QSPI support */ -/* Enable multiple SPI NOR flash manufacturers */ -#ifndef CONFIG_SPL_BUILD -#define CONFIG_SPI_FLASH_MTD -#endif /* QSPI reference clock */ #ifndef __ASSEMBLY__ unsigned int cm_get_qspi_controller_clk_hz(void);
Thanks, Stefan
Reviewed-by: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com
Thanks, Stefan
Hi Frieder,
Acked-by: Lukasz Majewski lukma@denx.de
@@ -83,7 +83,7 @@ struct spi_flash *spi_flash_probe(unsigned int busnum, unsigned int cs, void spi_flash_free(struct spi_flash *flash) { -#ifdef CONFIG_SPI_FLASH_MTD +#if CONFIG_IS_ENABLED(SPI_FLASH_MTD) spi_flash_mtd_unregister(); #endif spi_free_slave(flash->spi); @@ -152,7 +152,7 @@ static int spi_flash_std_probe(struct udevice *dev) static int spi_flash_std_remove(struct udevice *dev) { -#ifdef CONFIG_SPI_FLASH_MTD +#if CONFIG_IS_ENABLED(SPI_FLASH_MTD) spi_flash_mtd_unregister(); #endif return 0; diff --git a/include/configs/aristainetos-common.h b/include/configs/aristainetos-common.h index e998d9b1b2..b451c7e7dc 100644 --- a/include/configs/aristainetos-common.h +++ b/include/configs/aristainetos-common.h @@ -30,7 +30,6 @@ #define CONFIG_ETHPRIME "FEC" #define CONFIG_FEC_MXC_PHYADDR 0
#define CONFIG_EXTRA_ENV_SETTINGS \ diff --git a/include/configs/cm_fx6.h b/include/configs/cm_fx6.h index b957e9cba4..c1a6625fcb 100644 --- a/include/configs/cm_fx6.h +++ b/include/configs/cm_fx6.h @@ -38,13 +38,6 @@ #define CONFIG_MXC_UART_BASE UART4_BASE #define CONFIG_SYS_BAUDRATE_TABLE {9600, 19200, 38400, 57600, 115200} -/* SPI flash */
Chciałbym się jeszcze dopytać - czy restauracja Kaskada / Aruana o
- U-Boot general configuration
- 0x1540000 - 0x1640000 : SPI.factory (1MiB)
-#endif
- QSPI support
Lukasz Majewski
Hello Frieder,
Am 14.09.2019 um 00:44 schrieb Schrempf Frieder:
Reviewed-by: Heiko Schocher hs@denx.de
bye, Heiko
I don't know much about the U-Boot release cycle, so maybe these are stupid questions.
Jagan, I saw that these 3 patches are assigned to you. When will you pick them? For the current release, or the next one?
Do we still need an ack for patch 2/3 from the stm32mp maintainers?
Thanks, Frieder
On Thu, Sep 26, 2019 at 7:32 PM Schrempf Frieder frieder.schrempf@kontron.de wrote:
Next release, since it out of MW.
On Sat, Sep 14, 2019 at 4:14 AM Schrempf Frieder frieder.schrempf@kontron.de wrote:
These ifdef changes look unrelated wrt actual patch. any comments?
Also please rebase and send this patch, rest look fine for me.
Hi Jagan,
No, they are not unrelated. This is the actual reason for having this patch after all. We want to be able to enable/disable the code for CONFIG_SPI_FLASH_MTD per build target (SPL, U-Boot proper). These changes need to be done in a single patch together with the defconfig and Makefile changes to sustain bisectibility.
Ok, I will rebase on current master and send a v2.
Thanks, Frieder
On Wed, Oct 23, 2019 at 12:35 PM Schrempf Frieder frieder.schrempf@kontron.de wrote:
Hi Jagan,
What I'm trying to say here is, #ifdef CONFIG_SPI_FLASH_MTD and #if CONFIG_IS_ENABLED(SPI_FLASH_MTD) is the same but the latter is improved version which I feel it is related to another patch.
Hi Jagan,
Hi Jagan,
The spi Kconfig code is so convoluted, that we shall try to do it in a single patch (as was done here).
Otherwise we will end up with not bisectable code.
Lukasz Majewski
Hi Jagan,
No, "#ifdef CONFIG_FOO" is definitely not the same as "#if CONFIG_IS_ENABLED(FOO)". Please have a look at the definition of CONFIG_IS_ENABLED: [1].
"CONFIG_IS_ENABLED(FOO)" will resolve to 1 if CONFIG_SPL_FOO and CONFIG_SPL_BUILD are defined.
"#ifdef CONFIG_FOO" will only resolve to 1 if CONFIG_FOO is defined.
[1] https://elixir.bootlin.com/u-boot/latest/source/include/linux/kconfig.h#L82
On Wed, Oct 23, 2019 at 12:56 PM Schrempf Frieder frieder.schrempf@kontron.de wrote:
Hi Jagan,
Make sense, I would rather confused or missed a point. thanks.
Hi Jagan,
This is not correct. CONFIG_IS_ENABLED(SPI_FLASH_MTD) also handles CONFIG_SPL_SPI_FLASH_MTD & CONFIG_TPL_SPI_FLASH_MTD.
Thanks, Stefan
Hi Jagan,
Got it Stefan, thanks.
Hi Frieder,
Thanks for preparing the patch.
If unsure, say N
- bool "SPI flash MTD support for SPL"
- depends on SPI_FLASH
- help
If unsure, say N
Lukasz Majewski
On Sat, Sep 14, 2019 at 4:13 AM Schrempf Frieder frieder.schrempf@kontron.de wrote:
participants (6)
Heiko Schocher
Jagan Teki
Lukasz Majewski
Schrempf Frieder
Simon Goldschmidt
Stefan Roese
