[PATCH v2 0/5] configs: apple: Switch to standard boot + small adjustments
This series contains a few misc config changes for Apple silicon systems: - switch from the deprecated distro boot scripts to standard boot - allows EFI console resizing based on the video console size - enables 16x32 bitmap fonts as Apple devices come with high DPI displays - enables 64-bit LBA addressing
Signed-off-by: Janne Grunau j@jannau.net --- Changes in v2: - added Reviewed-by: tags - switched to BOOTSTD_FULL to enable efi_bootmgr and make interactive use easier - override BOOTCOMMAND to not list the bootflows - rebased onto v2024.04 - Link to v1: https://lore.kernel.org/r/20240317-apple_config-v1-0-1b862bc140a9@jannau.net
--- Hector Martin (1): apple_m1_defconfig: Turn on CONFIG_SYS_64BIT_LBA
Janne Grunau (4): configs: apple: Use "vidconsole,serial" as stdout/stderr configs: apple: Enable CMD_SELECT_FONT and FONT_16X32 arm: apple: Switch to standard boot arm: apple: Do not list bootflows on boot
arch/arm/Kconfig | 2 +- configs/apple_m1_defconfig | 4 ++++ include/configs/apple.h | 24 ++++-------------------- 3 files changed, 9 insertions(+), 21 deletions(-) --- base-commit: 25049ad560826f7dc1c4740883b0016014a59789 change-id: 20240317-apple_config-981fcd9028b9
This makes USB HDDs >2TiB work. The only reason this hasn't bitten us for the internal NVMe yet is the 4K sector size, because the largest SSD Apple sells is 8TB and we can handle up to 16TiB with that sector size. Close call.
Signed-off-by: Hector Martin marcan@marcan.st Reviewed-by: Mark Kettenis kettenis@openbsd.org Reviewed-by: Neal Gompa neal@gompa.dev Signed-off-by: Janne Grunau j@jannau.net --- configs/apple_m1_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/apple_m1_defconfig b/configs/apple_m1_defconfig index e00d72e8be..31d966f0ab 100644 --- a/configs/apple_m1_defconfig +++ b/configs/apple_m1_defconfig @@ -10,6 +10,7 @@ CONFIG_SYS_PBSIZE=276 CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_BOARD_LATE_INIT=y # CONFIG_NET is not set +CONFIG_SYS_64BIT_LBA=y CONFIG_APPLE_SPI_KEYB=y # CONFIG_MMC is not set CONFIG_NVME_APPLE=y
The display size querying in efi_console relies on this order. The display should be the primary output device and should be used to display more than 80x25 chars.
Reviewed-by: Mark Kettenis kettenis@openbsd.org Reviewed-by: Neal Gompa neal@gompa.dev Signed-off-by: Janne Grunau j@jannau.net --- include/configs/apple.h | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/include/configs/apple.h b/include/configs/apple.h index 0576bc04c9..a70440b3ad 100644 --- a/include/configs/apple.h +++ b/include/configs/apple.h @@ -6,8 +6,8 @@ /* Environment */ #define ENV_DEVICE_SETTINGS \ "stdin=serial,usbkbd,spikbd\0" \ - "stdout=serial,vidconsole\0" \ - "stderr=serial,vidconsole\0" + "stdout=vidconsole,serial\0" \ + "stderr=vidconsole,serial\0"
#if IS_ENABLED(CONFIG_CMD_NVME) #define BOOT_TARGET_NVME(func) func(NVME, nvme, 0)
Apple devices have high DPI displays so the larger fonts are preferable for improved readability. This does not yet change the used font based on the display's pixel density so the standard 8x16 font is still used by default.
Reviewed-by: Mark Kettenis kettenis@openbsd.org Reviewed-by: Neal Gompa neal@gompa.dev Signed-off-by: Janne Grunau j@jannau.net --- configs/apple_m1_defconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/configs/apple_m1_defconfig b/configs/apple_m1_defconfig index 31d966f0ab..c30aec7c55 100644 --- a/configs/apple_m1_defconfig +++ b/configs/apple_m1_defconfig @@ -9,6 +9,7 @@ CONFIG_SYS_PBSIZE=276 # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_BOARD_LATE_INIT=y +CONFIG_CMD_SELECT_FONT=y # CONFIG_NET is not set CONFIG_SYS_64BIT_LBA=y CONFIG_APPLE_SPI_KEYB=y @@ -19,6 +20,7 @@ CONFIG_USB_XHCI_DWC3=y CONFIG_USB_XHCI_PCI=y CONFIG_USB_DWC3=y CONFIG_USB_KEYBOARD=y +CONFIG_VIDEO_FONT_16X32=y CONFIG_SYS_WHITE_ON_BLACK=y CONFIG_NO_FB_CLEAR=y CONFIG_VIDEO_SIMPLE=y
Use standard boot instead of the distro boot scripts. Use BOOTSTD_FULL instead of BOOTSTD_DEFAULTS for easier interactive use.
Signed-off-by: Janne Grunau j@jannau.net --- arch/arm/Kconfig | 2 +- include/configs/apple.h | 20 ++------------------ 2 files changed, 3 insertions(+), 19 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 01d6556c42..9b83b2e6f8 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1034,7 +1034,7 @@ config ARCH_APPLE select USB imply CMD_DM imply CMD_GPT - imply DISTRO_DEFAULTS + imply BOOTSTD_FULL imply OF_HAS_PRIOR_STAGE
config ARCH_OWL diff --git a/include/configs/apple.h b/include/configs/apple.h index a70440b3ad..1e08b11448 100644 --- a/include/configs/apple.h +++ b/include/configs/apple.h @@ -9,26 +9,10 @@ "stdout=vidconsole,serial\0" \ "stderr=vidconsole,serial\0"
-#if IS_ENABLED(CONFIG_CMD_NVME) - #define BOOT_TARGET_NVME(func) func(NVME, nvme, 0) -#else - #define BOOT_TARGET_NVME(func) -#endif - -#if IS_ENABLED(CONFIG_CMD_USB) - #define BOOT_TARGET_USB(func) func(USB, usb, 0) -#else - #define BOOT_TARGET_USB(func) -#endif - -#define BOOT_TARGET_DEVICES(func) \ - BOOT_TARGET_NVME(func) \ - BOOT_TARGET_USB(func) - -#include <config_distro_bootcmd.h> +#define BOOT_TARGETS "nvme usb"
#define CFG_EXTRA_ENV_SETTINGS \ ENV_DEVICE_SETTINGS \ - BOOTENV + "boot_targets=" BOOT_TARGETS "\0"
#endif
On Thu, Apr 18, 2024 at 3:00 PM Janne Grunau via B4 Relay devnull+j.jannau.net@kernel.org wrote:
-#else
-#endif
-#else
-#endif
BOOTENV
#endif
-- 2.44.0
From: Janne Grunau via B4 Relay devnull+j.jannau.net@kernel.org Date: Thu, 18 Apr 2024 21:00:28 +0200
- imply BOOTSTD_FULL imply OF_HAS_PRIOR_STAGE
-#else
-#endif
-#else
-#endif
- BOOTENV
- "boot_targets=" BOOT_TARGETS "\0"
#endif
-- 2.44.0
The bootflow list is only seen briefly and is probably more confusing than helpful.
diff --git a/configs/apple_m1_defconfig b/configs/apple_m1_defconfig index c30aec7c55..4eac1a9e2d 100644 --- a/configs/apple_m1_defconfig +++ b/configs/apple_m1_defconfig @@ -8,6 +8,7 @@ CONFIG_SYS_CBSIZE=256 CONFIG_SYS_PBSIZE=276 # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_BOOTCOMMAND="bootflow scan -b" CONFIG_BOARD_LATE_INIT=y CONFIG_CMD_SELECT_FONT=y # CONFIG_NET is not set
-- 2.44.0
From: Janne Grunau via B4 Relay devnull+j.jannau.net@kernel.org Date: Thu, 18 Apr 2024 21:00:29 +0200
To be honest, I think that applies to all boards using BOOTSSTD_FILL. Which probably means the -l should be dropped from the default BOOTCOMMAND for BOOTSTD_FULL. But until that happens:
-- 2.44.0
Mark Kettenis
Neal Gompa
