[U-Boot] [PATCH] test: ofnode: test ofnode_device_is_compatible()
Test ofnode_device_is_compatible(), and also ofnode_path().
Requested-by: Simon Glass sjg@chromium.org Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
test/dm/Makefile | 1 + test/dm/ofnode.c | 19 +++++++++++++++++++ 2 files changed, 20 insertions(+) create mode 100644 test/dm/ofnode.c
diff --git a/test/dm/Makefile b/test/dm/Makefile index 513c456..97c978a 100644 --- a/test/dm/Makefile +++ b/test/dm/Makefile @@ -23,6 +23,7 @@ obj-$(CONFIG_DM_I2C) += i2c.o obj-$(CONFIG_LED) += led.o obj-$(CONFIG_DM_MAILBOX) += mailbox.o obj-$(CONFIG_DM_MMC) += mmc.o +obj-y += ofnode.o obj-$(CONFIG_DM_PCI) += pci.o obj-$(CONFIG_PHY) += phy.o obj-$(CONFIG_POWER_DOMAIN) += power-domain.o diff --git a/test/dm/ofnode.c b/test/dm/ofnode.c new file mode 100644 index 0000000..7dd6d88 --- /dev/null +++ b/test/dm/ofnode.c @@ -0,0 +1,19 @@ +/* + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <dm.h> +#include <dm/test.h> +#include <test/ut.h> + +static int dm_test_ofnode_compatible(struct unit_test_state *uts) +{ + ofnode root_node = ofnode_path("/"); + + ut_assert(ofnode_valid(root_node)); + ut_assert(ofnode_device_is_compatible(root_node, "sandbox")); + + return 0; +} +DM_TEST(dm_test_ofnode_compatible, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT);
On 26 April 2018 at 10:02, Masahiro Yamada yamada.masahiro@socionext.com wrote:
Thanks Masahiro, much appreciated.
Requested-by: Simon Glass sjg@chromium.org Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com Reviewed-by: Simon Glass sjg@chromium.org
Masahiro Yamada
