[PATCH 1/1] efi_loader: document functions in efi_rng.c
Add the missing Sphinx documentation.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- doc/api/efi.rst | 6 ++++++ lib/efi_loader/efi_rng.c | 35 +++++++++++++++++++++++++++++++++++ 2 files changed, 41 insertions(+)
diff --git a/doc/api/efi.rst b/doc/api/efi.rst index 2ca344932e..bc59382608 100644 --- a/doc/api/efi.rst +++ b/doc/api/efi.rst @@ -131,6 +131,12 @@ Network protocols .. kernel-doc:: lib/efi_loader/efi_net.c :internal:
+Random number generator protocol +~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ + +.. kernel-doc:: lib/efi_loader/efi_rng.c + :internal: + Text IO protocols ~~~~~~~~~~~~~~~~~
diff --git a/lib/efi_loader/efi_rng.c b/lib/efi_loader/efi_rng.c index 432c986204..a1d0ec842c 100644 --- a/lib/efi_loader/efi_rng.c +++ b/lib/efi_loader/efi_rng.c @@ -13,6 +13,17 @@ DECLARE_GLOBAL_DATA_PTR;
const efi_guid_t efi_guid_rng_protocol = EFI_RNG_PROTOCOL_GUID;
+/** + * platform_get_rng_device() - retrieve random number generator + * + * This function retrieves the udevice implementing a hardware random + * number generator. + * + * This function may be overridden if special initialization is needed. + * + * @dev: udevice + * Return: status code + */ __weak efi_status_t platform_get_rng_device(struct udevice **dev) { int ret; @@ -29,6 +40,18 @@ __weak efi_status_t platform_get_rng_device(struct udevice **dev) return EFI_SUCCESS; }
+/** + * rng_getinfo() - get information about random number generation + * + * This function implement the GetInfo() service of the EFI random number + * generator protocol. See the UEFI spec for details. + * + * @this: random number generator protocol instance + * @rng_algorithm_list_size: number of random number generation algorithms + * @rng_algorithm_list: descriptions of random number generation + * algorithms + * Return: status code + */ static efi_status_t EFIAPI rng_getinfo(struct efi_rng_protocol *this, efi_uintn_t *rng_algorithm_list_size, efi_guid_t *rng_algorithm_list) @@ -64,6 +87,18 @@ back: return EFI_EXIT(ret); }
+/** + * rng_getrng() - get random value + * + * This function implement the GetRng() service of the EFI random number + * generator protocol. See the UEFI spec for details. + * + * @this: random number generator protocol instance + * @rng_algorithm: random number generation algorithm + * @rng_value_length: number of random bytes to generate, buffer length + * @rng_value: buffer to receive random bytes + * Return: status code + */ static efi_status_t EFIAPI getrng(struct efi_rng_protocol *this, efi_guid_t *rng_algorithm, efi_uintn_t rng_value_length, -- 2.24.1
