[PATCH v2 00/32] bootm: Refactoring to reduce reliance on CMDLINE (part A)
It would be useful to be able to boot an OS when CONFIG_CMDLINE is disabled. This could allow reduced code size.
Standard boot provides a way to handle programmatic boot, without scripts, so such a feature is possible. The main impediment is the inability to use the booting features of U-Boot without a command line. So the solution is to avoid passing command arguments and the like to code in boot/
A similar process has taken place with filesystems, for example, where we have (somewhat) separate Kconfig options for the filesystem commands and the filesystems themselves.
This series starts the process of refactoring the bootm logic so that it can be called from standard boot without using the command line. Mostly it removes the use of argc, argv and cmdtbl from the internal logic.
Some limited tidy-up is included, but this is kept to smaller patches, rather than trying to remove all #ifdefs etc. Some function comments are added, however.
A simple programmatic boot is provided as a starting point.
This work will likely take many series, so this is just the start.
Size growth with this series for firefly-rk3288 (Thumb2) is:
arm: (for 1/1 boards) all +23.0 rodata -49.0 text +72.0
This should be removed by:
https://source.denx.de/u-boot/custodians/u-boot-dm/-/issues/11
but it is not included in this series as it is already large enough.
No functional change is intended in this series.
Changes in v2: - Add new patch to adjust position of unmap_sysmem() in boot_get_kernel() - Add new patch to obtain command arguments - Fix 'boot_find_os' typo - Pass in the command name - Use the command table to provide the command name, instead of "bootm"
Simon Glass (32): arm: x86: Drop discarding of command linker-lists README: Correct docs for CONFIG_SPL_BUILD mmc: env: Unify the U_BOOT_ENV_LOCATION conditions treewide: Tidy up semicolon after command macros bootstd: Add missing header file from bootdev.h bootstd: Introduce programmable boot bootm: Drop arguments from bootm_start() bootm: Simplify arguments for bootm_pre_load() bootm: Move boot_get_kernel() higher in the file image: Tidy up genimg_get_kernel_addr_fit() bootm: Reduce arguments to boot_get_kernel() image: Document error codes from fit_image_load() bootm: Adjust boot_get_kernel() to return an error bootm: Adjust position of unmap_sysmem() in boot_get_kernel() bootm: Use the error return from boot_get_kernel() bootstage: Drop BOOTSTAGE_ID_FIT_KERNEL_INFO bootm: Move error printing out of boot_get_kernel() bootm: Reduce arguments to bootm_find_os() bootm: Reduce arguments to boot_get_ramdisk() fdt: Allow use of fdt_support inside if() statements bootm: Drop #ifdef in bootm_find_images() bootm: Pass image buffer to boot_get_fdt() bootm: Reduce arguments to boot_get_fdt() bootm: Reduce arguments to boot_get_fpga() bootm: Reduce arguments to boot_get_loadables() bootm: Simplify Android ramdisk addr in bootm_find_images() bootm: efi: Drop special call to bootm_find_other() bootm: optee: Drop special call to bootm_find_other() bootm: Adjust the parameters of bootm_find_images() bootm: Add a function to check overlap bootm: Reduce arguments to bootm_find_other() RFC: command: Introduce functions to obtain command arguments
README | 26 +- arch/arm/cpu/u-boot.lds | 3 - arch/x86/cpu/u-boot-64.lds | 4 - arch/x86/cpu/u-boot-spl.lds | 4 - arch/x86/cpu/u-boot.lds | 4 - board/freescale/common/vid.c | 2 +- board/xilinx/common/fru.c | 2 +- board/xilinx/versal/cmds.c | 2 +- board/xilinx/zynqmp/cmds.c | 2 +- boot/Kconfig | 11 + boot/Makefile | 2 + boot/bootm.c | 577 +++++++++++++++++++---------------- boot/bootm_os.c | 16 - boot/image-board.c | 67 +--- boot/image-fdt.c | 39 +-- boot/prog_boot.c | 51 ++++ cmd/booti.c | 4 +- cmd/bootz.c | 4 +- cmd/btrfs.c | 2 +- cmd/disk.c | 4 +- cmd/eeprom.c | 2 +- cmd/ext2.c | 4 +- cmd/fs.c | 8 +- cmd/fuse.c | 2 +- cmd/mmc.c | 2 +- cmd/pinmux.c | 2 +- cmd/qfw.c | 2 +- common/main.c | 9 + drivers/misc/gsc.c | 6 +- env/mmc.c | 2 +- fs/fs.c | 4 +- include/bootdev.h | 1 + include/bootm.h | 26 +- include/bootstage.h | 1 - include/bootstd.h | 9 + include/command.h | 35 ++- include/fdt_support.h | 5 +- include/image.h | 127 ++++++-- test/cmd_ut.c | 2 +- 39 files changed, 612 insertions(+), 463 deletions(-) create mode 100644 boot/prog_boot.c
Since we can now cleanly disable CMDLINE when needed, drop the rules which discard the command code. It will not be built in the first place.
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Tom Rini trini@konsulko.com ---
(no changes since v1)
arch/arm/cpu/u-boot.lds | 3 --- arch/x86/cpu/u-boot-64.lds | 4 ---- arch/x86/cpu/u-boot-spl.lds | 4 ---- arch/x86/cpu/u-boot.lds | 4 ---- 4 files changed, 15 deletions(-)
diff --git a/arch/arm/cpu/u-boot.lds b/arch/arm/cpu/u-boot.lds index fc4f63d83489..7724c9332c3b 100644 --- a/arch/arm/cpu/u-boot.lds +++ b/arch/arm/cpu/u-boot.lds @@ -14,9 +14,6 @@ OUTPUT_ARCH(arm) ENTRY(_start) SECTIONS { -#ifndef CONFIG_CMDLINE - /DISCARD/ : { *(__u_boot_list_2_cmd_*) } -#endif #if defined(CONFIG_ARMV7_SECURE_BASE) && defined(CONFIG_ARMV7_NONSEC) /* * If CONFIG_ARMV7_SECURE_BASE is true, secure code will not diff --git a/arch/x86/cpu/u-boot-64.lds b/arch/x86/cpu/u-boot-64.lds index d0398ff00d71..00a6d8691211 100644 --- a/arch/x86/cpu/u-boot-64.lds +++ b/arch/x86/cpu/u-boot-64.lds @@ -11,10 +11,6 @@ ENTRY(_start)
SECTIONS { -#ifndef CONFIG_CMDLINE - /DISCARD/ : { *(__u_boot_list_2_cmd_*) } -#endif - #ifdef CONFIG_TEXT_BASE . = CONFIG_TEXT_BASE; /* Location of bootcode in flash */ #endif diff --git a/arch/x86/cpu/u-boot-spl.lds b/arch/x86/cpu/u-boot-spl.lds index a0a2a06a18cd..50b4b1608552 100644 --- a/arch/x86/cpu/u-boot-spl.lds +++ b/arch/x86/cpu/u-boot-spl.lds @@ -11,10 +11,6 @@ ENTRY(_start)
SECTIONS { -#ifndef CONFIG_CMDLINE - /DISCARD/ : { *(__u_boot_list_2_cmd_*) } -#endif - . = IMAGE_TEXT_BASE; /* Location of bootcode in flash */ __text_start = .; .text : { diff --git a/arch/x86/cpu/u-boot.lds b/arch/x86/cpu/u-boot.lds index a31f4220a000..c418ff44aa08 100644 --- a/arch/x86/cpu/u-boot.lds +++ b/arch/x86/cpu/u-boot.lds @@ -11,10 +11,6 @@ ENTRY(_start)
SECTIONS { -#ifndef CONFIG_CMDLINE - /DISCARD/ : { *(__u_boot_list_2_cmd_*) } -#endif - . = CONFIG_TEXT_BASE; /* Location of bootcode in flash */ __text_start = .;
Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org
-#endif
-#endif
-#endif
-- 2.43.0.rc0.421.g78406f8d94-goog
This option is defined in both SPL and TPL builds, so correct the docs related to this. Also point to spl_phase() which is normally a better option. Mention VPL as well.
Signed-off-by: Simon Glass sjg@chromium.org Reported-by: Heinrich Schuchardt xypron.glpk@gmx.de ---
README | 26 ++++++++++++++++++-------- 1 file changed, 18 insertions(+), 8 deletions(-)
diff --git a/README b/README index 60c6b8a19db1..f26c34a5e200 100644 --- a/README +++ b/README @@ -1545,16 +1545,26 @@ Low Level (hardware related) configuration options: globally (CONFIG_CMD_MEMORY).
- CONFIG_SPL_BUILD - Set when the currently-running compilation is for an artifact - that will end up in the SPL (as opposed to the TPL or U-Boot - proper). Code that needs stage-specific behavior should check - this. + Set when the currently running compilation is for an artifact + that will end up in one of the 'xPL' builds, i.e. SPL, TPL or + VPL. Code that needs phase-specific behaviour can check this, + or (where possible) use spl_phase() instead. + + Note that CONFIG_SPL_BUILD *is* always defined when either + of CONFIG_TPL_BUILD / CONFIG_VPL_BUILD is defined. This can be + counter-intuitive and should perhaps be changed.
- CONFIG_TPL_BUILD - Set when the currently-running compilation is for an artifact - that will end up in the TPL (as opposed to the SPL or U-Boot - proper). Code that needs stage-specific behavior should check - this. + Set when the currently running compilation is for an artifact + that will end up in the TPL build (as opposed to SPL, VPL or + U-Boot proper). Code that needs phase-specific behaviour can + check this, or (where possible) use spl_phase() instead. + +- CONFIG_VPL_BUILD + Set when the currently running compilation is for an artifact + that will end up in the VPL build (as opposed to the SPL, TPL + or U-Boot proper). Code that needs phase-specific behaviour can + check this, or (where possible) use spl_phase() instead.
- CONFIG_ARCH_MAP_SYSMEM Generally U-Boot (and in particular the md command) uses
The declaration of U_BOOT_ENV_LOCATION() uses a different #ifdef condition from the code it calls. Use the same condition to avoid a build warning if CONFIG_CMD_SAVEENV is disabled.
env/mmc.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/env/mmc.c b/env/mmc.c index cb14bbb58f13..da84cddd74f0 100644 --- a/env/mmc.c +++ b/env/mmc.c @@ -495,7 +495,7 @@ U_BOOT_ENV_LOCATION(mmc) = { .location = ENVL_MMC, ENV_NAME("MMC") .load = env_mmc_load, -#ifndef CONFIG_SPL_BUILD +#if defined(CONFIG_CMD_SAVEENV) && !defined(CONFIG_SPL_BUILD) .save = env_save_ptr(env_mmc_save), .erase = ENV_ERASE_PTR(env_mmc_erase) #endif
The U_BOOT_CMD_COMPLETE() macro has a semicolon at the end, perhaps inadvertently. Some code has taken advantage of this.
Tidy this up by dropping the semicolon from the macro and adding it to macro invocations as required.
board/freescale/common/vid.c | 2 +- board/xilinx/common/fru.c | 2 +- board/xilinx/versal/cmds.c | 2 +- board/xilinx/zynqmp/cmds.c | 2 +- cmd/btrfs.c | 2 +- cmd/eeprom.c | 2 +- cmd/ext2.c | 4 ++-- cmd/fs.c | 8 ++++---- cmd/pinmux.c | 2 +- cmd/qfw.c | 2 +- include/command.h | 2 +- 11 files changed, 15 insertions(+), 15 deletions(-)
diff --git a/board/freescale/common/vid.c b/board/freescale/common/vid.c index 5ec3f2a76b19..fc5d400cfe18 100644 --- a/board/freescale/common/vid.c +++ b/board/freescale/common/vid.c @@ -793,4 +793,4 @@ U_BOOT_CMD( vdd_read, 1, 0, do_vdd_read, "read VDD", " - Read the voltage specified in mV" -) +); diff --git a/board/xilinx/common/fru.c b/board/xilinx/common/fru.c index c916c3d6b4c8..12b21317496a 100644 --- a/board/xilinx/common/fru.c +++ b/board/xilinx/common/fru.c @@ -85,4 +85,4 @@ U_BOOT_CMD( fru, 8, 1, do_fru, "FRU table info", fru_help_text -) +); diff --git a/board/xilinx/versal/cmds.c b/board/xilinx/versal/cmds.c index 9cc2cdcebf1c..2a74e49aedec 100644 --- a/board/xilinx/versal/cmds.c +++ b/board/xilinx/versal/cmds.c @@ -98,4 +98,4 @@ U_BOOT_LONGHELP(versal, U_BOOT_CMD(versal, 4, 1, do_versal, "versal sub-system", versal_help_text -) +); diff --git a/board/xilinx/zynqmp/cmds.c b/board/xilinx/zynqmp/cmds.c index f1f3eff501e1..9524688f27d9 100644 --- a/board/xilinx/zynqmp/cmds.c +++ b/board/xilinx/zynqmp/cmds.c @@ -427,4 +427,4 @@ U_BOOT_CMD( zynqmp, 9, 1, do_zynqmp, "ZynqMP sub-system", zynqmp_help_text -) +); diff --git a/cmd/btrfs.c b/cmd/btrfs.c index 98daea99e9ed..2843835d08b8 100644 --- a/cmd/btrfs.c +++ b/cmd/btrfs.c @@ -24,4 +24,4 @@ U_BOOT_CMD(btrsubvol, 3, 1, do_btrsubvol, "list subvolumes of a BTRFS filesystem", "<interface> <dev[:part]>\n" " - List subvolumes of a BTRFS filesystem." -) +); diff --git a/cmd/eeprom.c b/cmd/eeprom.c index 0b6ca8c505fb..322765ad02a0 100644 --- a/cmd/eeprom.c +++ b/cmd/eeprom.c @@ -435,4 +435,4 @@ U_BOOT_CMD( "The values which can be provided with the -l option are:\n" CONFIG_EEPROM_LAYOUT_HELP_STRING"\n" #endif -) +); diff --git a/cmd/ext2.c b/cmd/ext2.c index 57a99516a6ac..a0ce0cf5796b 100644 --- a/cmd/ext2.c +++ b/cmd/ext2.c @@ -42,7 +42,7 @@ U_BOOT_CMD( "list files in a directory (default /)", "<interface> <dev[:part]> [directory]\n" " - list files from 'dev' on 'interface' in a 'directory'" -) +);
U_BOOT_CMD( ext2load, 6, 0, do_ext2load, @@ -50,4 +50,4 @@ U_BOOT_CMD( "<interface> [<dev[:part]> [addr [filename [bytes [pos]]]]]\n" " - load binary file 'filename' from 'dev' on 'interface'\n" " to address 'addr' from ext2 filesystem." -) +); diff --git a/cmd/fs.c b/cmd/fs.c index 6044f73af5b4..46cb43dcdb5b 100644 --- a/cmd/fs.c +++ b/cmd/fs.c @@ -39,7 +39,7 @@ U_BOOT_CMD( " If 'bytes' is 0 or omitted, the file is read until the end.\n" " 'pos' gives the file byte position to start reading from.\n" " If 'pos' is 0 or omitted, the file is read from the start." -) +);
static int do_save_wrapper(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) @@ -56,7 +56,7 @@ U_BOOT_CMD( " 'bytes' gives the size to save in bytes and is mandatory.\n" " 'pos' gives the file byte position to start writing to.\n" " If 'pos' is 0 or omitted, the file is written from the start." -) +);
static int do_ls_wrapper(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) @@ -70,7 +70,7 @@ U_BOOT_CMD( "<interface> [<dev[:part]> [directory]]\n" " - List files in directory 'directory' of partition 'part' on\n" " device type 'interface' instance 'dev'." -) +);
static int do_ln_wrapper(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) @@ -84,7 +84,7 @@ U_BOOT_CMD( "<interface> <dev[:part]> target linkname\n" " - create a symbolic link to 'target' with the name 'linkname' on\n" " device type 'interface' instance 'dev'." -) +);
static int do_fstype_wrapper(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) diff --git a/cmd/pinmux.c b/cmd/pinmux.c index f17cf4110d9f..105f01eaafff 100644 --- a/cmd/pinmux.c +++ b/cmd/pinmux.c @@ -178,4 +178,4 @@ U_BOOT_CMD(pinmux, CONFIG_SYS_MAXARGS, 1, do_pinmux, "list - list UCLASS_PINCTRL devices\n" "pinmux dev [pincontroller-name] - select pin-controller device\n" "pinmux status [-a | pin-name] - print pin-controller muxing [for all | for pin-name]\n" -) +); diff --git a/cmd/qfw.c b/cmd/qfw.c index d6ecfa60d5a7..1b8c775ebf5a 100644 --- a/cmd/qfw.c +++ b/cmd/qfw.c @@ -121,4 +121,4 @@ U_BOOT_CMD( " - list : print firmware(s) currently loaded\n" " - cpus : print online cpu number\n" " - load <kernel addr> <initrd addr> : load kernel and initrd (if any), and setup for zboot\n" -) +); diff --git a/include/command.h b/include/command.h index 6262365e128f..5bd3ecbe8f91 100644 --- a/include/command.h +++ b/include/command.h @@ -390,7 +390,7 @@ int cmd_source_script(ulong addr, const char *fit_uname, const char *confname); #define U_BOOT_CMD_COMPLETE(_name, _maxargs, _rep, _cmd, _usage, _help, _comp) \ ll_entry_declare(struct cmd_tbl, _name, cmd) = \ U_BOOT_CMD_MKENT_COMPLETE(_name, _maxargs, _rep, _cmd, \ - _usage, _help, _comp); + _usage, _help, _comp)
#define U_BOOT_CMDREP_COMPLETE(_name, _maxargs, _cmd_rep, _usage, \ _help, _comp) \
#define U_BOOT_CMDREP_COMPLETE(_name, _maxargs, _cmd_rep, _usage, \ _help, _comp) \ -- 2.43.0.rc0.421.g78406f8d94-goog
Add a dm/uclass-id.h to the bootdev header file, since it uses enum uclass_id
include/bootdev.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/include/bootdev.h b/include/bootdev.h index b079a91b5b7f..c1362673d418 100644 --- a/include/bootdev.h +++ b/include/bootdev.h @@ -7,6 +7,7 @@ #ifndef __bootdev_h #define __bootdev_h
+#include <dm/uclass-id.h> #include <linux/list.h>
struct bootflow;
struct bootflow;
At present bootstd requires CONFIG_CMDLINE to operate. Add a new 'programmable' boot which can be used when no command line is available. For now it does almost nothing, since most bootmeths require the command line.
boot/Kconfig | 11 ++++++++++ boot/Makefile | 2 ++ boot/prog_boot.c | 51 +++++++++++++++++++++++++++++++++++++++++++++++ common/main.c | 9 +++++++++ include/bootstd.h | 9 +++++++++ 5 files changed, 82 insertions(+) create mode 100644 boot/prog_boot.c
diff --git a/boot/Kconfig b/boot/Kconfig index ef71883a5026..586d7a69fab3 100644 --- a/boot/Kconfig +++ b/boot/Kconfig @@ -459,6 +459,17 @@ config BOOTSTD_BOOTCOMMAND standard boot does not support all of the features of distro boot yet.
+config BOOTSTD_PROG + bool "Use programmatic boot" + depends on !CMDLINE + default y + help + Enable this to provide a board_run_command() function which can boot + a systen without using commands. + + Note: This currently has many limitations and is not a useful booting + solution. Future work will eventually make this a viable option. + config BOOTMETH_GLOBAL bool help diff --git a/boot/Makefile b/boot/Makefile index 3fd048bb41ab..de0eafed14b1 100644 --- a/boot/Makefile +++ b/boot/Makefile @@ -25,6 +25,8 @@ obj-$(CONFIG_$(SPL_TPL_)BOOTSTD) += bootflow.o obj-$(CONFIG_$(SPL_TPL_)BOOTSTD) += bootmeth-uclass.o obj-$(CONFIG_$(SPL_TPL_)BOOTSTD) += bootstd-uclass.o
+obj-$(CONFIG_$(SPL_TPL_)BOOTSTD_PROG) += prog_boot.o + obj-$(CONFIG_$(SPL_TPL_)BOOTMETH_EXTLINUX) += bootmeth_extlinux.o obj-$(CONFIG_$(SPL_TPL_)BOOTMETH_EXTLINUX_PXE) += bootmeth_pxe.o obj-$(CONFIG_$(SPL_TPL_)BOOTMETH_EFILOADER) += bootmeth_efi.o diff --git a/boot/prog_boot.c b/boot/prog_boot.c new file mode 100644 index 000000000000..045554b93db0 --- /dev/null +++ b/boot/prog_boot.c @@ -0,0 +1,51 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2021 Google LLC + * Written by Simon Glass sjg@chromium.org + */ + +#define LOG_CATEGORY UCLASS_BOOTSTD + +#include <bootflow.h> +#include <bootstd.h> +#include <command.h> +#include <dm.h> + +/* + * show_bootmeths() - List available bootmeths + * + * We could refactor this to use do_bootmeth_list() if more detail (or ordering) + * are needed + */ +static void show_bootmeths(void) +{ + struct udevice *dev; + struct uclass *uc; + + printf("Bootmeths: "); + uclass_id_foreach_dev(UCLASS_BOOTMETH, dev, uc) + printf(" %s", dev->name); + printf("\n"); +} + +int bootstd_prog_boot(void) +{ + struct bootflow_iter iter; + struct bootflow bflow; + int ret, flags, i; + + printf("Programmatic boot starting\n"); + show_bootmeths(); + flags = BOOTFLOWIF_HUNT | BOOTFLOWIF_SHOW | BOOTFLOWIF_SKIP_GLOBAL; + + bootstd_clear_glob(); + for (i = 0, ret = bootflow_scan_first(NULL, NULL, &iter, flags, &bflow); + i < 1000 && ret != -ENODEV; + i++, ret = bootflow_scan_next(&iter, &bflow)) { + if (!bflow.err) + bootflow_run_boot(&iter, &bflow); + bootflow_free(&bflow); + } + + return -EFAULT; +} diff --git a/common/main.c b/common/main.c index 7c70de2e59a8..2668f3bb1637 100644 --- a/common/main.c +++ b/common/main.c @@ -9,6 +9,7 @@ #include <common.h> #include <autoboot.h> #include <bootstage.h> +#include <bootstd.h> #include <cli.h> #include <command.h> #include <console.h> @@ -67,6 +68,14 @@ void main_loop(void)
autoboot_command(s);
+ if (IS_ENABLED(CONFIG_BOOTSTD_PROG)) { + int ret; + + ret = bootstd_prog_boot(); + printf("Standard boot failed (err=%dE)\n", ret); + } + cli_loop(); + panic("No CLI available"); } diff --git a/include/bootstd.h b/include/bootstd.h index 7802564bcc63..99ce7b64e7c5 100644 --- a/include/bootstd.h +++ b/include/bootstd.h @@ -94,4 +94,13 @@ int bootstd_get_priv(struct bootstd_priv **stdp); */ void bootstd_clear_glob(void);
+/** + * bootstd_prog_boot() - Run standard boot in a fully programmatic mode + * + * Attempts to boot without making any use of U-Boot commands + * + * Returns: -ve error value (does not return except on failure to boot) + */ +int bootstd_prog_boot(void); + #endif
[snip]
- if (IS_ENABLED(CONFIG_BOOTSTD_PROG)) {
int ret;
- cli_loop();
- panic("No CLI available");
I think this this brings in at least a 3rd option now, we should try and condense things a little or clean it up maybe. We have common/autoboot.c which is what will fire off menu_show() and drop things in to that menu instead of the cmdline (but that does have cmdline as an option to run, and I suspect that just exits gracefully from the cmd). With CMDLINE=n, cli_loop prints we can't do anything and then panics, so we should also maybe panic() in the case it bootstd_prog_boot fails rather than continue?
This function does not use its arguments. Drop them.
boot/bootm.c | 5 ++--- 1 file changed, 2 insertions(+), 3 deletions(-)
diff --git a/boot/bootm.c b/boot/bootm.c index cb61485c226c..fda97706fc26 100644 --- a/boot/bootm.c +++ b/boot/bootm.c @@ -69,8 +69,7 @@ static void boot_start_lmb(struct bootm_headers *images) static inline void boot_start_lmb(struct bootm_headers *images) { } #endif
-static int bootm_start(struct cmd_tbl *cmdtp, int flag, int argc, - char *const argv[]) +static int bootm_start(void) { memset((void *)&images, 0, sizeof(images)); images.verify = env_get_yesno("verify"); @@ -783,7 +782,7 @@ int do_bootm_states(struct cmd_tbl *cmdtp, int flag, int argc, * any error. */ if (states & BOOTM_STATE_START) - ret = bootm_start(cmdtp, flag, argc, argv); + ret = bootm_start();
if (!ret && (states & BOOTM_STATE_PRE_LOAD)) ret = bootm_pre_load(cmdtp, flag, argc, argv);
char *const argv[])
ret = bootm_start(); if (!ret && (states & BOOTM_STATE_PRE_LOAD)) ret = bootm_pre_load(cmdtp, flag, argc, argv);
Move the argument decoding to the caller, to avoid needing to pass the command-line arguments.
Add a function comment while we are here.
boot/bootm.c | 23 ++++++++++++++++------- 1 file changed, 16 insertions(+), 7 deletions(-)
diff --git a/boot/bootm.c b/boot/bootm.c index fda97706fc26..1482a2cc783f 100644 --- a/boot/bootm.c +++ b/boot/bootm.c @@ -82,22 +82,31 @@ static int bootm_start(void) return 0; }
-static ulong bootm_data_addr(int argc, char *const argv[]) +static ulong bootm_data_addr(const char *addr_str) { ulong addr;
- if (argc > 0) - addr = simple_strtoul(argv[0], NULL, 16); + if (addr_str) + addr = hextoul(addr_str, NULL); else addr = image_load_addr;
return addr; }
-static int bootm_pre_load(struct cmd_tbl *cmdtp, int flag, int argc, - char *const argv[]) +/** + * bootm_pre_load() - Handle the pre-load processing + * + * This can be used to do a full signature check of the image, for example. + * It calls image_pre_load() with the data address of the image to check. + * + * @addr_str: String containing load address in hex, or NULL to use + * image_load_addr + * Return: 0 if OK, CMD_RET_FAILURE on failure + */ +static int bootm_pre_load(const char *addr_str) { - ulong data_addr = bootm_data_addr(argc, argv); + ulong data_addr = bootm_data_addr(addr_str); int ret = 0;
if (IS_ENABLED(CONFIG_CMD_BOOTM_PRE_LOAD)) @@ -785,7 +794,7 @@ int do_bootm_states(struct cmd_tbl *cmdtp, int flag, int argc, ret = bootm_start();
if (!ret && (states & BOOTM_STATE_PRE_LOAD)) - ret = bootm_pre_load(cmdtp, flag, argc, argv); + ret = bootm_pre_load(argv[0]);
if (!ret && (states & BOOTM_STATE_FINDOS)) ret = bootm_find_os(cmdtp, flag, argc, argv);
Move this code and image_get_kernel() higher in the file to avoid the need for a forward declaration.
No attempt is made to remove #ifdefs or adjust the code in any other way.
boot/bootm.c | 376 +++++++++++++++++++++++++-------------------------- 1 file changed, 186 insertions(+), 190 deletions(-)
diff --git a/boot/bootm.c b/boot/bootm.c index 1482a2cc783f..598f880d86dd 100644 --- a/boot/bootm.c +++ b/boot/bootm.c @@ -44,12 +44,195 @@ DECLARE_GLOBAL_DATA_PTR;
struct bootm_headers images; /* pointers to os/initrd/fdt images */
+__weak void board_quiesce_devices(void) +{ +} + +#if CONFIG_IS_ENABLED(LEGACY_IMAGE_FORMAT) +/** + * image_get_kernel - verify legacy format kernel image + * @img_addr: in RAM address of the legacy format image to be verified + * @verify: data CRC verification flag + * + * image_get_kernel() verifies legacy image integrity and returns pointer to + * legacy image header if image verification was completed successfully. + * + * returns: + * pointer to a legacy image header if valid image was found + * otherwise return NULL + */ +static struct legacy_img_hdr *image_get_kernel(ulong img_addr, int verify) +{ + struct legacy_img_hdr *hdr = (struct legacy_img_hdr *)img_addr; + + if (!image_check_magic(hdr)) { + puts("Bad Magic Number\n"); + bootstage_error(BOOTSTAGE_ID_CHECK_MAGIC); + return NULL; + } + bootstage_mark(BOOTSTAGE_ID_CHECK_HEADER); + + if (!image_check_hcrc(hdr)) { + puts("Bad Header Checksum\n"); + bootstage_error(BOOTSTAGE_ID_CHECK_HEADER); + return NULL; + } + + bootstage_mark(BOOTSTAGE_ID_CHECK_CHECKSUM); + image_print_contents(hdr); + + if (verify) { + puts(" Verifying Checksum ... "); + if (!image_check_dcrc(hdr)) { + printf("Bad Data CRC\n"); + bootstage_error(BOOTSTAGE_ID_CHECK_CHECKSUM); + return NULL; + } + puts("OK\n"); + } + bootstage_mark(BOOTSTAGE_ID_CHECK_ARCH); + + if (!image_check_target_arch(hdr)) { + printf("Unsupported Architecture 0x%x\n", image_get_arch(hdr)); + bootstage_error(BOOTSTAGE_ID_CHECK_ARCH); + return NULL; + } + return hdr; +} +#endif + +/** + * boot_get_kernel - find kernel image + * @os_data: pointer to a ulong variable, will hold os data start address + * @os_len: pointer to a ulong variable, will hold os data length + * + * boot_get_kernel() tries to find a kernel image, verifies its integrity + * and locates kernel data. + * + * returns: + * pointer to image header if valid image was found, plus kernel start + * address and length, otherwise NULL + */ static const void *boot_get_kernel(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[], struct bootm_headers *images, - ulong *os_data, ulong *os_len); - -__weak void board_quiesce_devices(void) + ulong *os_data, ulong *os_len) { +#if CONFIG_IS_ENABLED(LEGACY_IMAGE_FORMAT) + struct legacy_img_hdr *hdr; +#endif + ulong img_addr; + const void *buf; + const char *fit_uname_config = NULL; + const char *fit_uname_kernel = NULL; +#if CONFIG_IS_ENABLED(FIT) + int os_noffset; +#endif + +#ifdef CONFIG_ANDROID_BOOT_IMAGE + const void *boot_img; + const void *vendor_boot_img; +#endif + img_addr = genimg_get_kernel_addr_fit(argc < 1 ? NULL : argv[0], + &fit_uname_config, + &fit_uname_kernel); + + if (IS_ENABLED(CONFIG_CMD_BOOTM_PRE_LOAD)) + img_addr += image_load_offset; + + bootstage_mark(BOOTSTAGE_ID_CHECK_MAGIC); + + /* check image type, for FIT images get FIT kernel node */ + *os_data = *os_len = 0; + buf = map_sysmem(img_addr, 0); + switch (genimg_get_format(buf)) { +#if CONFIG_IS_ENABLED(LEGACY_IMAGE_FORMAT) + case IMAGE_FORMAT_LEGACY: + printf("## Booting kernel from Legacy Image at %08lx ...\n", + img_addr); + hdr = image_get_kernel(img_addr, images->verify); + if (!hdr) + return NULL; + bootstage_mark(BOOTSTAGE_ID_CHECK_IMAGETYPE); + + /* get os_data and os_len */ + switch (image_get_type(hdr)) { + case IH_TYPE_KERNEL: + case IH_TYPE_KERNEL_NOLOAD: + *os_data = image_get_data(hdr); + *os_len = image_get_data_size(hdr); + break; + case IH_TYPE_MULTI: + image_multi_getimg(hdr, 0, os_data, os_len); + break; + case IH_TYPE_STANDALONE: + *os_data = image_get_data(hdr); + *os_len = image_get_data_size(hdr); + break; + default: + printf("Wrong Image Type for %s command\n", + cmdtp->name); + bootstage_error(BOOTSTAGE_ID_CHECK_IMAGETYPE); + return NULL; + } + + /* + * copy image header to allow for image overwrites during + * kernel decompression. + */ + memmove(&images->legacy_hdr_os_copy, hdr, + sizeof(struct legacy_img_hdr)); + + /* save pointer to image header */ + images->legacy_hdr_os = hdr; + + images->legacy_hdr_valid = 1; + bootstage_mark(BOOTSTAGE_ID_DECOMP_IMAGE); + break; +#endif +#if CONFIG_IS_ENABLED(FIT) + case IMAGE_FORMAT_FIT: + os_noffset = fit_image_load(images, img_addr, + &fit_uname_kernel, &fit_uname_config, + IH_ARCH_DEFAULT, IH_TYPE_KERNEL, + BOOTSTAGE_ID_FIT_KERNEL_START, + FIT_LOAD_IGNORED, os_data, os_len); + if (os_noffset < 0) + return NULL; + + images->fit_hdr_os = map_sysmem(img_addr, 0); + images->fit_uname_os = fit_uname_kernel; + images->fit_uname_cfg = fit_uname_config; + images->fit_noffset_os = os_noffset; + break; +#endif +#ifdef CONFIG_ANDROID_BOOT_IMAGE + case IMAGE_FORMAT_ANDROID: + boot_img = buf; + vendor_boot_img = NULL; + if (IS_ENABLED(CONFIG_CMD_ABOOTIMG)) { + boot_img = map_sysmem(get_abootimg_addr(), 0); + vendor_boot_img = map_sysmem(get_avendor_bootimg_addr(), 0); + } + printf("## Booting Android Image at 0x%08lx ...\n", img_addr); + if (android_image_get_kernel(boot_img, vendor_boot_img, images->verify, + os_data, os_len)) + return NULL; + if (IS_ENABLED(CONFIG_CMD_ABOOTIMG)) { + unmap_sysmem(vendor_boot_img); + unmap_sysmem(boot_img); + } + break; +#endif + default: + printf("Wrong Image Format for %s command\n", cmdtp->name); + bootstage_error(BOOTSTAGE_ID_FIT_KERNEL_INFO); + return NULL; + } + + debug(" kernel data at 0x%08lx, len = 0x%08lx (%ld)\n", + *os_data, *os_len, *os_len); + + return buf; }
#ifdef CONFIG_LMB @@ -942,193 +1125,6 @@ int bootm_boot_start(ulong addr, const char *cmdline) return ret; }
-#if CONFIG_IS_ENABLED(LEGACY_IMAGE_FORMAT) -/** - * image_get_kernel - verify legacy format kernel image - * @img_addr: in RAM address of the legacy format image to be verified - * @verify: data CRC verification flag - * - * image_get_kernel() verifies legacy image integrity and returns pointer to - * legacy image header if image verification was completed successfully. - * - * returns: - * pointer to a legacy image header if valid image was found - * otherwise return NULL - */ -static struct legacy_img_hdr *image_get_kernel(ulong img_addr, int verify) -{ - struct legacy_img_hdr *hdr = (struct legacy_img_hdr *)img_addr; - - if (!image_check_magic(hdr)) { - puts("Bad Magic Number\n"); - bootstage_error(BOOTSTAGE_ID_CHECK_MAGIC); - return NULL; - } - bootstage_mark(BOOTSTAGE_ID_CHECK_HEADER); - - if (!image_check_hcrc(hdr)) { - puts("Bad Header Checksum\n"); - bootstage_error(BOOTSTAGE_ID_CHECK_HEADER); - return NULL; - } - - bootstage_mark(BOOTSTAGE_ID_CHECK_CHECKSUM); - image_print_contents(hdr); - - if (verify) { - puts(" Verifying Checksum ... "); - if (!image_check_dcrc(hdr)) { - printf("Bad Data CRC\n"); - bootstage_error(BOOTSTAGE_ID_CHECK_CHECKSUM); - return NULL; - } - puts("OK\n"); - } - bootstage_mark(BOOTSTAGE_ID_CHECK_ARCH); - - if (!image_check_target_arch(hdr)) { - printf("Unsupported Architecture 0x%x\n", image_get_arch(hdr)); - bootstage_error(BOOTSTAGE_ID_CHECK_ARCH); - return NULL; - } - return hdr; -} -#endif - -/** - * boot_get_kernel - find kernel image - * @os_data: pointer to a ulong variable, will hold os data start address - * @os_len: pointer to a ulong variable, will hold os data length - * - * boot_get_kernel() tries to find a kernel image, verifies its integrity - * and locates kernel data. - * - * returns: - * pointer to image header if valid image was found, plus kernel start - * address and length, otherwise NULL - */ -static const void *boot_get_kernel(struct cmd_tbl *cmdtp, int flag, int argc, - char *const argv[], struct bootm_headers *images, - ulong *os_data, ulong *os_len) -{ -#if CONFIG_IS_ENABLED(LEGACY_IMAGE_FORMAT) - struct legacy_img_hdr *hdr; -#endif - ulong img_addr; - const void *buf; - const char *fit_uname_config = NULL; - const char *fit_uname_kernel = NULL; -#if CONFIG_IS_ENABLED(FIT) - int os_noffset; -#endif - -#ifdef CONFIG_ANDROID_BOOT_IMAGE - const void *boot_img; - const void *vendor_boot_img; -#endif - img_addr = genimg_get_kernel_addr_fit(argc < 1 ? NULL : argv[0], - &fit_uname_config, - &fit_uname_kernel); - - if (IS_ENABLED(CONFIG_CMD_BOOTM_PRE_LOAD)) - img_addr += image_load_offset; - - bootstage_mark(BOOTSTAGE_ID_CHECK_MAGIC); - - /* check image type, for FIT images get FIT kernel node */ - *os_data = *os_len = 0; - buf = map_sysmem(img_addr, 0); - switch (genimg_get_format(buf)) { -#if CONFIG_IS_ENABLED(LEGACY_IMAGE_FORMAT) - case IMAGE_FORMAT_LEGACY: - printf("## Booting kernel from Legacy Image at %08lx ...\n", - img_addr); - hdr = image_get_kernel(img_addr, images->verify); - if (!hdr) - return NULL; - bootstage_mark(BOOTSTAGE_ID_CHECK_IMAGETYPE); - - /* get os_data and os_len */ - switch (image_get_type(hdr)) { - case IH_TYPE_KERNEL: - case IH_TYPE_KERNEL_NOLOAD: - *os_data = image_get_data(hdr); - *os_len = image_get_data_size(hdr); - break; - case IH_TYPE_MULTI: - image_multi_getimg(hdr, 0, os_data, os_len); - break; - case IH_TYPE_STANDALONE: - *os_data = image_get_data(hdr); - *os_len = image_get_data_size(hdr); - break; - default: - printf("Wrong Image Type for %s command\n", - cmdtp->name); - bootstage_error(BOOTSTAGE_ID_CHECK_IMAGETYPE); - return NULL; - } - - /* - * copy image header to allow for image overwrites during - * kernel decompression. - */ - memmove(&images->legacy_hdr_os_copy, hdr, - sizeof(struct legacy_img_hdr)); - - /* save pointer to image header */ - images->legacy_hdr_os = hdr; - - images->legacy_hdr_valid = 1; - bootstage_mark(BOOTSTAGE_ID_DECOMP_IMAGE); - break; -#endif -#if CONFIG_IS_ENABLED(FIT) - case IMAGE_FORMAT_FIT: - os_noffset = fit_image_load(images, img_addr, - &fit_uname_kernel, &fit_uname_config, - IH_ARCH_DEFAULT, IH_TYPE_KERNEL, - BOOTSTAGE_ID_FIT_KERNEL_START, - FIT_LOAD_IGNORED, os_data, os_len); - if (os_noffset < 0) - return NULL; - - images->fit_hdr_os = map_sysmem(img_addr, 0); - images->fit_uname_os = fit_uname_kernel; - images->fit_uname_cfg = fit_uname_config; - images->fit_noffset_os = os_noffset; - break; -#endif -#ifdef CONFIG_ANDROID_BOOT_IMAGE - case IMAGE_FORMAT_ANDROID: - boot_img = buf; - vendor_boot_img = NULL; - if (IS_ENABLED(CONFIG_CMD_ABOOTIMG)) { - boot_img = map_sysmem(get_abootimg_addr(), 0); - vendor_boot_img = map_sysmem(get_avendor_bootimg_addr(), 0); - } - printf("## Booting Android Image at 0x%08lx ...\n", img_addr); - if (android_image_get_kernel(boot_img, vendor_boot_img, images->verify, - os_data, os_len)) - return NULL; - if (IS_ENABLED(CONFIG_CMD_ABOOTIMG)) { - unmap_sysmem(vendor_boot_img); - unmap_sysmem(boot_img); - } - break; -#endif - default: - printf("Wrong Image Format for %s command\n", cmdtp->name); - bootstage_error(BOOTSTAGE_ID_FIT_KERNEL_INFO); - return NULL; - } - - debug(" kernel data at 0x%08lx, len = 0x%08lx (%ld)\n", - *os_data, *os_len, *os_len); - - return buf; -} - /** * switch_to_non_secure_mode() - switch to non-secure mode *
This function does not modify its first argument, so mark it const. Also move the comments to the header file and expand them to provide more useful information.
boot/bootm.c | 3 +-- boot/image-board.c | 17 +---------------- include/image.h | 29 ++++++++++++++++++++++++++--- 3 files changed, 28 insertions(+), 21 deletions(-)
diff --git a/boot/bootm.c b/boot/bootm.c index 598f880d86dd..e323c8b758e9 100644 --- a/boot/bootm.c +++ b/boot/bootm.c @@ -122,8 +122,7 @@ static const void *boot_get_kernel(struct cmd_tbl *cmdtp, int flag, int argc, #endif ulong img_addr; const void *buf; - const char *fit_uname_config = NULL; - const char *fit_uname_kernel = NULL; + const char *fit_uname_config = NULL, *fit_uname_kernel = NULL; #if CONFIG_IS_ENABLED(FIT) int os_noffset; #endif diff --git a/boot/image-board.c b/boot/image-board.c index d500da1b4b91..062c76badecc 100644 --- a/boot/image-board.c +++ b/boot/image-board.c @@ -198,22 +198,7 @@ void memmove_wd(void *to, void *from, size_t len, ulong chunksz) } }
-/** - * genimg_get_kernel_addr_fit - get the real kernel address and return 2 - * FIT strings - * @img_addr: a string might contain real image address - * @fit_uname_config: double pointer to a char, will hold pointer to a - * configuration unit name - * @fit_uname_kernel: double pointer to a char, will hold pointer to a subimage - * name - * - * genimg_get_kernel_addr_fit get the real kernel start address from a string - * which is normally the first argv of bootm/bootz - * - * returns: - * kernel start address - */ -ulong genimg_get_kernel_addr_fit(char * const img_addr, +ulong genimg_get_kernel_addr_fit(const char *const img_addr, const char **fit_uname_config, const char **fit_uname_kernel) { diff --git a/include/image.h b/include/image.h index 2e3cf839ee36..798c5f9c16e4 100644 --- a/include/image.h +++ b/include/image.h @@ -612,9 +612,32 @@ int boot_get_setup(struct bootm_headers *images, uint8_t arch, ulong *setup_star #define IMAGE_FORMAT_FIT 0x02 /* new, libfdt based format */ #define IMAGE_FORMAT_ANDROID 0x03 /* Android boot image */
-ulong genimg_get_kernel_addr_fit(char * const img_addr, - const char **fit_uname_config, - const char **fit_uname_kernel); +/** + * genimg_get_kernel_addr_fit() - Parse FIT specifier + * + * Get the real kernel start address from a string which is normally the first + * argv of bootm/bootz + * + * These cases are dealt with, based on the value of @img_addr: + * NULL: Returns image_load_addr, does not set last two args + * "<addr>": Returns address + * + * For FIT: + * "[<addr>]#<conf>": Returns address (or image_load_addr), + * sets fit_uname_config to config name + * "[<addr>]:<subimage>": Returns address (or image_load_addr) and sets + * fit_uname_kernel to the subimage name + * + * @img_addr: a string might contain real image address (or NULL) + * @fit_uname_config: Returns configuration unit name + * @fit_uname_kernel: Returns subimage name + * + * Returns: kernel start address + */ +ulong genimg_get_kernel_addr_fit(const char *const img_addr, + const char **fit_uname_config, + const char **fit_uname_kernel); + ulong genimg_get_kernel_addr(char * const img_addr); int genimg_get_format(const void *img_addr); int genimg_has_config(struct bootm_headers *images);
This function only uses one argument and just needs to know the name of the command which called it. Adjust the function to use only what it needs. This will make it easier to call from a non-command context.
Tidy up the function comment while we are here.
Changes in v2: - Use the command table to provide the command name, instead of "bootm"
boot/bootm.c | 22 +++++++++++++--------- 1 file changed, 13 insertions(+), 9 deletions(-)
diff --git a/boot/bootm.c b/boot/bootm.c index e323c8b758e9..ea1575bd07eb 100644 --- a/boot/bootm.c +++ b/boot/bootm.c @@ -102,9 +102,14 @@ static struct legacy_img_hdr *image_get_kernel(ulong img_addr, int verify) #endif
/** - * boot_get_kernel - find kernel image + * boot_get_kernel() - find kernel image + * + * @cmd_name: Name of the command calling this function, e.g. "bootm" + * @addr_fit: first argument to bootm: address, fit configuration, etc. * @os_data: pointer to a ulong variable, will hold os data start address * @os_len: pointer to a ulong variable, will hold os data length + * address and length, otherwise NULL + * pointer to image header if valid image was found, plus kernel start * * boot_get_kernel() tries to find a kernel image, verifies its integrity * and locates kernel data. @@ -113,8 +118,8 @@ static struct legacy_img_hdr *image_get_kernel(ulong img_addr, int verify) * pointer to image header if valid image was found, plus kernel start * address and length, otherwise NULL */ -static const void *boot_get_kernel(struct cmd_tbl *cmdtp, int flag, int argc, - char *const argv[], struct bootm_headers *images, +static const void *boot_get_kernel(const char *cmd_name, const char *addr_fit, + struct bootm_headers *images, ulong *os_data, ulong *os_len) { #if CONFIG_IS_ENABLED(LEGACY_IMAGE_FORMAT) @@ -131,8 +136,7 @@ static const void *boot_get_kernel(struct cmd_tbl *cmdtp, int flag, int argc, const void *boot_img; const void *vendor_boot_img; #endif - img_addr = genimg_get_kernel_addr_fit(argc < 1 ? NULL : argv[0], - &fit_uname_config, + img_addr = genimg_get_kernel_addr_fit(addr_fit, &fit_uname_config, &fit_uname_kernel);
if (IS_ENABLED(CONFIG_CMD_BOOTM_PRE_LOAD)) @@ -169,7 +173,7 @@ static const void *boot_get_kernel(struct cmd_tbl *cmdtp, int flag, int argc, break; default: printf("Wrong Image Type for %s command\n", - cmdtp->name); + cmd_name); bootstage_error(BOOTSTAGE_ID_CHECK_IMAGETYPE); return NULL; } @@ -223,7 +227,7 @@ static const void *boot_get_kernel(struct cmd_tbl *cmdtp, int flag, int argc, break; #endif default: - printf("Wrong Image Format for %s command\n", cmdtp->name); + printf("Wrong Image Format for %s command\n", cmd_name); bootstage_error(BOOTSTAGE_ID_FIT_KERNEL_INFO); return NULL; } @@ -312,8 +316,8 @@ static int bootm_find_os(struct cmd_tbl *cmdtp, int flag, int argc, int ret;
/* get kernel image header, start address and length */ - os_hdr = boot_get_kernel(cmdtp, flag, argc, argv, - &images, &images.os.image_start, &images.os.image_len); + os_hdr = boot_get_kernel(cmdtp->name, argv[0], &images, + &images.os.image_start, &images.os.image_len); if (images.os.image_len == 0) { puts("ERROR: can't get kernel image!\n"); return 1;
Put a list of these in the function documentation so it is easier to decode what went wrong.
include/image.h | 8 +++++++- 1 file changed, 7 insertions(+), 1 deletion(-)
diff --git a/include/image.h b/include/image.h index 798c5f9c16e4..d37e44721672 100644 --- a/include/image.h +++ b/include/image.h @@ -728,7 +728,13 @@ int boot_get_fdt_fit(struct bootm_headers *images, ulong addr, * @param load_op Decribes what to do with the load address * @param datap Returns address of loaded image * @param lenp Returns length of loaded image - * Return: node offset of image, or -ve error code on error + * Return: node offset of image, or -ve error code on error: + * -ENOEXEC - unsupported architecture + * -ENOENT - could not find image / subimage + * -EACCES - hash, signature or decryptions failure + * -EBADF - invalid OS or image type, or cannot get image load-address + * -EXDEV - memory overwritten / overlap + * -NOEXEC - image decompression error, or invalid FDT */ int fit_image_load(struct bootm_headers *images, ulong addr, const char **fit_unamep, const char **fit_uname_configp,
This function obtains lots of error codes and then throws them away. Update it to return the error, moving the image pointer to an argument.
boot/bootm.c | 35 +++++++++++++++++++++-------------- 1 file changed, 21 insertions(+), 14 deletions(-)
diff --git a/boot/bootm.c b/boot/bootm.c index ea1575bd07eb..1f3a01994cbe 100644 --- a/boot/bootm.c +++ b/boot/bootm.c @@ -110,6 +110,7 @@ static struct legacy_img_hdr *image_get_kernel(ulong img_addr, int verify) * @os_len: pointer to a ulong variable, will hold os data length * address and length, otherwise NULL * pointer to image header if valid image was found, plus kernel start + * @kernp: image header if valid image was found, otherwise NULL * * boot_get_kernel() tries to find a kernel image, verifies its integrity * and locates kernel data. @@ -118,9 +119,9 @@ static struct legacy_img_hdr *image_get_kernel(ulong img_addr, int verify) * pointer to image header if valid image was found, plus kernel start * address and length, otherwise NULL */ -static const void *boot_get_kernel(const char *cmd_name, const char *addr_fit, - struct bootm_headers *images, - ulong *os_data, ulong *os_len) +static int boot_get_kernel(const char *cmd_name, const char *addr_fit, + struct bootm_headers *images, ulong *os_data, + ulong *os_len, const void **kernp) { #if CONFIG_IS_ENABLED(LEGACY_IMAGE_FORMAT) struct legacy_img_hdr *hdr; @@ -154,7 +155,7 @@ static const void *boot_get_kernel(const char *cmd_name, const char *addr_fit, img_addr); hdr = image_get_kernel(img_addr, images->verify); if (!hdr) - return NULL; + return -EINVAL; bootstage_mark(BOOTSTAGE_ID_CHECK_IMAGETYPE);
/* get os_data and os_len */ @@ -175,7 +176,7 @@ static const void *boot_get_kernel(const char *cmd_name, const char *addr_fit, printf("Wrong Image Type for %s command\n", cmd_name); bootstage_error(BOOTSTAGE_ID_CHECK_IMAGETYPE); - return NULL; + return -EPROTOTYPE; }
/* @@ -200,7 +201,7 @@ static const void *boot_get_kernel(const char *cmd_name, const char *addr_fit, BOOTSTAGE_ID_FIT_KERNEL_START, FIT_LOAD_IGNORED, os_data, os_len); if (os_noffset < 0) - return NULL; + return -ENOENT;
images->fit_hdr_os = map_sysmem(img_addr, 0); images->fit_uname_os = fit_uname_kernel; @@ -209,7 +210,9 @@ static const void *boot_get_kernel(const char *cmd_name, const char *addr_fit, break; #endif #ifdef CONFIG_ANDROID_BOOT_IMAGE - case IMAGE_FORMAT_ANDROID: + case IMAGE_FORMAT_ANDROID: { + int ret; + boot_img = buf; vendor_boot_img = NULL; if (IS_ENABLED(CONFIG_CMD_ABOOTIMG)) { @@ -217,25 +220,28 @@ static const void *boot_get_kernel(const char *cmd_name, const char *addr_fit, vendor_boot_img = map_sysmem(get_avendor_bootimg_addr(), 0); } printf("## Booting Android Image at 0x%08lx ...\n", img_addr); - if (android_image_get_kernel(boot_img, vendor_boot_img, images->verify, - os_data, os_len)) - return NULL; + ret = android_image_get_kernel(boot_img, vendor_boot_img, + images->verify, os_data, os_len); + if (ret) + return ret; if (IS_ENABLED(CONFIG_CMD_ABOOTIMG)) { unmap_sysmem(vendor_boot_img); unmap_sysmem(boot_img); } break; + } #endif default: printf("Wrong Image Format for %s command\n", cmd_name); bootstage_error(BOOTSTAGE_ID_FIT_KERNEL_INFO); - return NULL; + return -EBADF; }
debug(" kernel data at 0x%08lx, len = 0x%08lx (%ld)\n", *os_data, *os_len, *os_len); + *kernp = buf;
- return buf; + return 0; }
#ifdef CONFIG_LMB @@ -316,8 +322,9 @@ static int bootm_find_os(struct cmd_tbl *cmdtp, int flag, int argc, int ret;
/* get kernel image header, start address and length */ - os_hdr = boot_get_kernel(cmdtp->name, argv[0], &images, - &images.os.image_start, &images.os.image_len); + ret = boot_get_kernel(cmdtp->name, argv[0], &images, + &images.os.image_start, &images.os.image_len, + &os_hdr); if (images.os.image_len == 0) { puts("ERROR: can't get kernel image!\n"); return 1;
These unmaps should happen regardless of the return value. Move them before the 'return' statement.
boot/bootm.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/boot/bootm.c b/boot/bootm.c index 1f3a01994cbe..6ed60bf05084 100644 --- a/boot/bootm.c +++ b/boot/bootm.c @@ -222,12 +222,12 @@ static int boot_get_kernel(const char *cmd_name, const char *addr_fit, printf("## Booting Android Image at 0x%08lx ...\n", img_addr); ret = android_image_get_kernel(boot_img, vendor_boot_img, images->verify, os_data, os_len); - if (ret) - return ret; if (IS_ENABLED(CONFIG_CMD_ABOOTIMG)) { unmap_sysmem(vendor_boot_img); unmap_sysmem(boot_img); } + if (ret) + return ret; break; } #endif
Rather than looking for a zero-sized image, use the error code returned to determine if things are OK.
boot/bootm.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/boot/bootm.c b/boot/bootm.c index 6ed60bf05084..a23c791a9e15 100644 --- a/boot/bootm.c +++ b/boot/bootm.c @@ -324,9 +324,9 @@ static int bootm_find_os(struct cmd_tbl *cmdtp, int flag, int argc, /* get kernel image header, start address and length */ ret = boot_get_kernel(cmdtp->name, argv[0], &images, &images.os.image_start, &images.os.image_len, - &os_hdr); - if (images.os.image_len == 0) { - puts("ERROR: can't get kernel image!\n"); + &os_hdr); + if (ret) { + printf("ERROR %dE: can't get kernel image!\n", ret); return 1; }
This is a misnomer since we don't necessarily know that the image is a FIT. Use the existing BOOTSTAGE_ID_CHECK_IMAGETYPE instead.
boot/bootm.c | 2 +- include/bootstage.h | 1 - 2 files changed, 1 insertion(+), 2 deletions(-)
diff --git a/boot/bootm.c b/boot/bootm.c index a23c791a9e15..9bd93f5dee7a 100644 --- a/boot/bootm.c +++ b/boot/bootm.c @@ -233,7 +233,7 @@ static int boot_get_kernel(const char *cmd_name, const char *addr_fit, #endif default: printf("Wrong Image Format for %s command\n", cmd_name); - bootstage_error(BOOTSTAGE_ID_FIT_KERNEL_INFO); + bootstage_error(BOOTSTAGE_ID_CHECK_IMAGETYPE); return -EBADF; }
diff --git a/include/bootstage.h b/include/bootstage.h index affb0e5c6a6a..59a76d0f0c40 100644 --- a/include/bootstage.h +++ b/include/bootstage.h @@ -147,7 +147,6 @@ enum bootstage_id {
BOOTSTAGE_ID_FIT_CONFIG = 110, BOOTSTAGE_ID_FIT_TYPE, - BOOTSTAGE_ID_FIT_KERNEL_INFO,
BOOTSTAGE_ID_FIT_COMPRESSION, BOOTSTAGE_ID_FIT_OS,
The same error message is printed in two places. Move it out to the caller so we can avoid passing in the command name. Leave the bootstage handling where it is.
boot/bootm.c | 25 +++++++++++-------------- 1 file changed, 11 insertions(+), 14 deletions(-)
diff --git a/boot/bootm.c b/boot/bootm.c index 9bd93f5dee7a..7aca2bf8146c 100644 --- a/boot/bootm.c +++ b/boot/bootm.c @@ -104,7 +104,6 @@ static struct legacy_img_hdr *image_get_kernel(ulong img_addr, int verify) /** * boot_get_kernel() - find kernel image * - * @cmd_name: Name of the command calling this function, e.g. "bootm" * @addr_fit: first argument to bootm: address, fit configuration, etc. * @os_data: pointer to a ulong variable, will hold os data start address * @os_len: pointer to a ulong variable, will hold os data length @@ -115,13 +114,11 @@ static struct legacy_img_hdr *image_get_kernel(ulong img_addr, int verify) * boot_get_kernel() tries to find a kernel image, verifies its integrity * and locates kernel data. * - * returns: - * pointer to image header if valid image was found, plus kernel start - * address and length, otherwise NULL + * Return: 0 on success, -ve on error. -EPROTOTYPE means that the image is in + * a wrong or unsupported format */ -static int boot_get_kernel(const char *cmd_name, const char *addr_fit, - struct bootm_headers *images, ulong *os_data, - ulong *os_len, const void **kernp) +static int boot_get_kernel(const char *addr_fit, struct bootm_headers *images, + ulong *os_data, ulong *os_len, const void **kernp) { #if CONFIG_IS_ENABLED(LEGACY_IMAGE_FORMAT) struct legacy_img_hdr *hdr; @@ -173,8 +170,6 @@ static int boot_get_kernel(const char *cmd_name, const char *addr_fit, *os_len = image_get_data_size(hdr); break; default: - printf("Wrong Image Type for %s command\n", - cmd_name); bootstage_error(BOOTSTAGE_ID_CHECK_IMAGETYPE); return -EPROTOTYPE; } @@ -232,9 +227,8 @@ static int boot_get_kernel(const char *cmd_name, const char *addr_fit, } #endif default: - printf("Wrong Image Format for %s command\n", cmd_name); bootstage_error(BOOTSTAGE_ID_CHECK_IMAGETYPE); - return -EBADF; + return -EPROTOTYPE; }
debug(" kernel data at 0x%08lx, len = 0x%08lx (%ld)\n", @@ -322,10 +316,13 @@ static int bootm_find_os(struct cmd_tbl *cmdtp, int flag, int argc, int ret;
/* get kernel image header, start address and length */ - ret = boot_get_kernel(cmdtp->name, argv[0], &images, - &images.os.image_start, &images.os.image_len, - &os_hdr); + ret = boot_get_kernel(argv[0], &images, &images.os.image_start, + &images.os.image_len, &os_hdr); if (ret) { + if (ret == -EPROTOTYPE) + printf("Wrong Image Type for %s command\n", + cmdtp->name); + printf("ERROR %dE: can't get kernel image!\n", ret); return 1; }
This function only uses one argument so pass it in directly.
Changes in v2: - Fix 'boot_find_os' typo - Pass in the command name
boot/bootm.c | 17 +++++++++++------ 1 file changed, 11 insertions(+), 6 deletions(-)
diff --git a/boot/bootm.c b/boot/bootm.c index 7aca2bf8146c..922989b9cfcf 100644 --- a/boot/bootm.c +++ b/boot/bootm.c @@ -304,8 +304,14 @@ static int bootm_pre_load(const char *addr_str) return ret; }
-static int bootm_find_os(struct cmd_tbl *cmdtp, int flag, int argc, - char *const argv[]) +/** + * bootm_find_os(): Find the OS to boot + * + * @cmd_name: Command name that started this boot, e.g. "bootm" + * @addr_fit: Address and/or FIT specifier (first arg of bootm command) + * Return: 0 on success, -ve on error + */ +static int bootm_find_os(const char *cmd_name, const char *addr_fit) { const void *os_hdr; #ifdef CONFIG_ANDROID_BOOT_IMAGE @@ -316,12 +322,11 @@ static int bootm_find_os(struct cmd_tbl *cmdtp, int flag, int argc, int ret;
/* get kernel image header, start address and length */ - ret = boot_get_kernel(argv[0], &images, &images.os.image_start, + ret = boot_get_kernel(addr_fit, &images, &images.os.image_start, &images.os.image_len, &os_hdr); if (ret) { if (ret == -EPROTOTYPE) - printf("Wrong Image Type for %s command\n", - cmdtp->name); + printf("Wrong Image Type for %s command\n", cmd_name);
printf("ERROR %dE: can't get kernel image!\n", ret); return 1; @@ -987,7 +992,7 @@ int do_bootm_states(struct cmd_tbl *cmdtp, int flag, int argc, ret = bootm_pre_load(argv[0]);
if (!ret && (states & BOOTM_STATE_FINDOS)) - ret = bootm_find_os(cmdtp, flag, argc, argv); + ret = bootm_find_os(cmdtp->name, argv[0]);
if (!ret && (states & BOOTM_STATE_FINDOTHER)) ret = bootm_find_other(cmdtp, flag, argc, argv);
This function normally only uses one argument so pass it in directly. Move comments to the header file so could one day include these functions in API docs. Fix up the u8 argument while here, since it avoids the compiler having to mask the value on some machines.
The Android case here is bit strange, since it can use argv[0], so deal with that in the caller.
boot/bootm.c | 15 ++++++++++++++- boot/image-board.c | 39 ++------------------------------------- include/image.h | 27 +++++++++++++++++++++++++-- 3 files changed, 41 insertions(+), 40 deletions(-)
diff --git a/boot/bootm.c b/boot/bootm.c index 922989b9cfcf..d5893e82d128 100644 --- a/boot/bootm.c +++ b/boot/bootm.c @@ -489,10 +489,23 @@ static int bootm_find_os(const char *cmd_name, const char *addr_fit) int bootm_find_images(int flag, int argc, char *const argv[], ulong start, ulong size) { + const char *select = NULL; int ret;
+ if (IS_ENABLED(CONFIG_ANDROID_BOOT_IMAGE)) { + char *buf; + + /* Look for an Android boot image */ + buf = map_sysmem(images.os.start, 0); + if (buf && genimg_get_format(buf) == IMAGE_FORMAT_ANDROID) + select = argc ? argv[0] : env_get("loadaddr"); + } + + if (argc >= 2) + select = argv[1]; + /* find ramdisk */ - ret = boot_get_ramdisk(argc, argv, &images, IH_INITRD_ARCH, + ret = boot_get_ramdisk(select, &images, IH_INITRD_ARCH, &images.rd_start, &images.rd_end); if (ret) { puts("Ramdisk image is corrupt or invalid\n"); diff --git a/boot/image-board.c b/boot/image-board.c index 062c76badecc..60e514fc150e 100644 --- a/boot/image-board.c +++ b/boot/image-board.c @@ -456,49 +456,14 @@ static int select_ramdisk(struct bootm_headers *images, const char *select, u8 a return 0; }
-/** - * boot_get_ramdisk - main ramdisk handling routine - * @argc: command argument count - * @argv: command argument list - * @images: pointer to the bootm images structure - * @arch: expected ramdisk architecture - * @rd_start: pointer to a ulong variable, will hold ramdisk start address - * @rd_end: pointer to a ulong variable, will hold ramdisk end - * - * boot_get_ramdisk() is responsible for finding a valid ramdisk image. - * Currently supported are the following ramdisk sources: - * - multicomponent kernel/ramdisk image, - * - commandline provided address of decicated ramdisk image. - * - * returns: - * 0, if ramdisk image was found and valid, or skiped - * rd_start and rd_end are set to ramdisk start/end addresses if - * ramdisk image is found and valid - * - * 1, if ramdisk image is found but corrupted, or invalid - * rd_start and rd_end are set to 0 if no ramdisk exists - */ -int boot_get_ramdisk(int argc, char *const argv[], struct bootm_headers *images, - u8 arch, ulong *rd_start, ulong *rd_end) +int boot_get_ramdisk(char const *select, struct bootm_headers *images, + uint arch, ulong *rd_start, ulong *rd_end) { ulong rd_data, rd_len; - const char *select = NULL;
*rd_start = 0; *rd_end = 0;
- if (IS_ENABLED(CONFIG_ANDROID_BOOT_IMAGE)) { - char *buf; - - /* Look for an Android boot image */ - buf = map_sysmem(images->os.start, 0); - if (buf && genimg_get_format(buf) == IMAGE_FORMAT_ANDROID) - select = (argc == 0) ? env_get("loadaddr") : argv[0]; - } - - if (argc >= 2) - select = argv[1]; - /* * Look for a '-' which indicates to ignore the * ramdisk argument diff --git a/include/image.h b/include/image.h index d37e44721672..3e48ad5b303e 100644 --- a/include/image.h +++ b/include/image.h @@ -644,8 +644,31 @@ int genimg_has_config(struct bootm_headers *images);
int boot_get_fpga(int argc, char *const argv[], struct bootm_headers *images, uint8_t arch, const ulong *ld_start, ulong * const ld_len); -int boot_get_ramdisk(int argc, char *const argv[], struct bootm_headers *images, - uint8_t arch, ulong *rd_start, ulong *rd_end); + +/** + * boot_get_ramdisk() - Locate the ramdisk + * + * @select: address or name of ramdisk to use, or NULL for default + * @images: pointer to the bootm images structure + * @arch: expected ramdisk architecture + * @rd_start: pointer to a ulong variable, will hold ramdisk start address + * @rd_end: pointer to a ulong variable, will hold ramdisk end + * + * boot_get_ramdisk() is responsible for finding a valid ramdisk image. + * Currently supported are the following ramdisk sources: + * - multicomponent kernel/ramdisk image, + * - commandline provided address of decicated ramdisk image. + * + * returns: + * 0, if ramdisk image was found and valid, or skiped + * rd_start and rd_end are set to ramdisk start/end addresses if + * ramdisk image is found and valid + * + * 1, if ramdisk image is found but corrupted, or invalid + * rd_start and rd_end are set to 0 if no ramdisk exists + */ +int boot_get_ramdisk(char const *select, struct bootm_headers *images, + uint arch, ulong *rd_start, ulong *rd_end);
/** * boot_get_loadable - routine to load a list of binaries to memory
Most of the fdt_support.h header file is included only if OF_LIBFDT or OF_CONTROL are enabled. This means that calling functions defined in that file must happen inside an #ifdef
This is unnecessary, so reduce the condition to just !USE_HOSTCC
include/fdt_support.h | 5 ++--- 1 file changed, 2 insertions(+), 3 deletions(-)
diff --git a/include/fdt_support.h b/include/fdt_support.h index 2cd836689821..feda0d997409 100644 --- a/include/fdt_support.h +++ b/include/fdt_support.h @@ -7,8 +7,7 @@ #ifndef __FDT_SUPPORT_H #define __FDT_SUPPORT_H
-#if (defined(CONFIG_OF_LIBFDT) || defined(CONFIG_OF_CONTROL)) && \ - !defined(USE_HOSTCC) +#if !defined(USE_HOSTCC)
#include <asm/u-boot.h> #include <linux/libfdt.h> @@ -418,7 +417,7 @@ int fdt_valid(struct fdt_header **blobp); */ int fdt_get_cells_len(const void *blob, char *nr_cells_name);
-#endif /* ifdef CONFIG_OF_LIBFDT */ +#endif /* !USE_HOSTCC */
#ifdef USE_HOSTCC int fdtdec_get_int(const void *blob, int node, const char *prop_name,
The OF_LIBFDT #ifdef makes it harder to use a local variable for that code block. Convert it to if() instead.
boot/bootm.c | 42 +++++++++++++++++++++--------------------- 1 file changed, 21 insertions(+), 21 deletions(-)
diff --git a/boot/bootm.c b/boot/bootm.c index d5893e82d128..d9c62d730f7f 100644 --- a/boot/bootm.c +++ b/boot/bootm.c @@ -524,29 +524,29 @@ int bootm_find_images(int flag, int argc, char *const argv[], ulong start, return 1; }
-#if CONFIG_IS_ENABLED(OF_LIBFDT) - /* find flattened device tree */ - ret = boot_get_fdt(flag, argc, argv, IH_ARCH_DEFAULT, &images, - &images.ft_addr, &images.ft_len); - if (ret) { - puts("Could not find a valid device tree\n"); - return 1; - } + if (CONFIG_IS_ENABLED(OF_LIBFDT)) { + /* find flattened device tree */ + ret = boot_get_fdt(flag, argc, argv, IH_ARCH_DEFAULT, &images, + &images.ft_addr, &images.ft_len); + if (ret) { + puts("Could not find a valid device tree\n"); + return 1; + }
- /* check if FDT overlaps OS image */ - if (images.ft_addr && - (((ulong)images.ft_addr >= start && - (ulong)images.ft_addr < start + size) || - ((ulong)images.ft_addr + images.ft_len >= start && - (ulong)images.ft_addr + images.ft_len < start + size))) { - printf("ERROR: FDT image overlaps OS image (OS=0x%lx..0x%lx)\n", - start, start + size); - return 1; - } + /* check if FDT overlaps OS image */ + if (images.ft_addr && + (((ulong)images.ft_addr >= start && + (ulong)images.ft_addr < start + size) || + ((ulong)images.ft_addr + images.ft_len >= start && + (ulong)images.ft_addr + images.ft_len < start + size))) { + printf("ERROR: FDT image overlaps OS image (OS=0x%lx..0x%lx)\n", + start, start + size); + return 1; + }
- if (IS_ENABLED(CONFIG_CMD_FDT)) - set_working_fdt_addr(map_to_sysmem(images.ft_addr)); -#endif + if (IS_ENABLED(CONFIG_CMD_FDT)) + set_working_fdt_addr(map_to_sysmem(images.ft_addr)); + }
#if CONFIG_IS_ENABLED(FIT) if (IS_ENABLED(CONFIG_FPGA)) {
Rather than having boot_get_fdt() calculate this, move the calculation into the caller. This removes the access to argv[0] in this function, so we can later refactor it to just accept argv[2] instead of the whole argv[].
Move the function comment to the header file and fix the u8 argument, while we are here.
boot/bootm.c | 11 +++++++---- boot/image-fdt.c | 32 +++----------------------------- include/image.h | 31 ++++++++++++++++++++++++++++--- 3 files changed, 38 insertions(+), 36 deletions(-)
diff --git a/boot/bootm.c b/boot/bootm.c index d9c62d730f7f..cd11994e21ce 100644 --- a/boot/bootm.c +++ b/boot/bootm.c @@ -490,11 +490,11 @@ int bootm_find_images(int flag, int argc, char *const argv[], ulong start, ulong size) { const char *select = NULL; + ulong img_addr; + void *buf; int ret;
if (IS_ENABLED(CONFIG_ANDROID_BOOT_IMAGE)) { - char *buf; - /* Look for an Android boot image */ buf = map_sysmem(images.os.start, 0); if (buf && genimg_get_format(buf) == IMAGE_FORMAT_ANDROID) @@ -525,9 +525,12 @@ int bootm_find_images(int flag, int argc, char *const argv[], ulong start, }
if (CONFIG_IS_ENABLED(OF_LIBFDT)) { + img_addr = argc ? hextoul(argv[0], NULL) : image_load_addr; + buf = map_sysmem(img_addr, 0); + /* find flattened device tree */ - ret = boot_get_fdt(flag, argc, argv, IH_ARCH_DEFAULT, &images, - &images.ft_addr, &images.ft_len); + ret = boot_get_fdt(buf, flag, argc, argv, IH_ARCH_DEFAULT, + &images, &images.ft_addr, &images.ft_len); if (ret) { puts("Could not find a valid device tree\n"); return 1; diff --git a/boot/image-fdt.c b/boot/image-fdt.c index f10200f64743..6ff2d52d6c70 100644 --- a/boot/image-fdt.c +++ b/boot/image-fdt.c @@ -447,43 +447,17 @@ static int select_fdt(struct bootm_headers *images, const char *select, u8 arch, return 0; }
-/** - * boot_get_fdt - main fdt handling routine - * @argc: command argument count - * @argv: command argument list - * @arch: architecture (IH_ARCH_...) - * @images: pointer to the bootm images structure - * @of_flat_tree: pointer to a char* variable, will hold fdt start address - * @of_size: pointer to a ulong variable, will hold fdt length - * - * boot_get_fdt() is responsible for finding a valid flat device tree image. - * Currently supported are the following ramdisk sources: - * - multicomponent kernel/ramdisk image, - * - commandline provided address of decicated ramdisk image. - * - * returns: - * 0, if fdt image was found and valid, or skipped - * of_flat_tree and of_size are set to fdt start address and length if - * fdt image is found and valid - * - * 1, if fdt image is found but corrupted - * of_flat_tree and of_size are set to 0 if no fdt exists - */ -int boot_get_fdt(int flag, int argc, char *const argv[], uint8_t arch, - struct bootm_headers *images, char **of_flat_tree, ulong *of_size) +int boot_get_fdt(void *buf, int flag, int argc, char *const argv[], uint arch, + struct bootm_headers *images, char **of_flat_tree, + ulong *of_size) { - ulong img_addr; ulong fdt_addr; char *fdt_blob = NULL; - void *buf; const char *select = NULL;
*of_flat_tree = NULL; *of_size = 0;
- img_addr = (argc == 0) ? image_load_addr : hextoul(argv[0], NULL); - buf = map_sysmem(img_addr, 0); - if (argc > 2) select = argv[2]; if (select || genimg_has_config(images)) { diff --git a/include/image.h b/include/image.h index 3e48ad5b303e..a4555f25fb56 100644 --- a/include/image.h +++ b/include/image.h @@ -808,9 +808,34 @@ int image_locate_script(void *buf, int size, const char *fit_uname, int fit_get_node_from_config(struct bootm_headers *images, const char *prop_name, ulong addr);
-int boot_get_fdt(int flag, int argc, char *const argv[], uint8_t arch, - struct bootm_headers *images, - char **of_flat_tree, ulong *of_size); +/** + * boot_get_fdt() - locate FDT devicetree to use for booting + * + * @buf: Pointer to image + * @argc: command argument count + * @argv: command argument list + * @arch: architecture (IH_ARCH_...) + * @images: pointer to the bootm images structure + * @of_flat_tree: pointer to a char* variable, will hold fdt start address + * @of_size: pointer to a ulong variable, will hold fdt length + * + * boot_get_fdt() is responsible for finding a valid flat device tree image. + * Currently supported are the following FDT sources: + * - multicomponent kernel/ramdisk/FDT image, + * - commandline provided address of decicated FDT image. + * + * Return: + * 0, if fdt image was found and valid, or skipped + * of_flat_tree and of_size are set to fdt start address and length if + * fdt image is found and valid + * + * 1, if fdt image is found but corrupted + * of_flat_tree and of_size are set to 0 if no fdt exists + */ +int boot_get_fdt(void *buf, int flag, int argc, char *const argv[], uint arch, + struct bootm_headers *images, char **of_flat_tree, + ulong *of_size); + void boot_fdt_add_mem_rsv_regions(struct lmb *lmb, void *fdt_blob); int boot_relocate_fdt(struct lmb *lmb, char **of_flat_tree, ulong *of_size);
This function only uses one argument from bootm (argv[2]) so pass it in directly.
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Tom Rini trini@konsulko.com ---
(no changes since v1)
boot/bootm.c | 5 +++-- boot/image-fdt.c | 9 +++------ include/image.h | 5 ++--- 3 files changed, 8 insertions(+), 11 deletions(-)
diff --git a/boot/bootm.c b/boot/bootm.c index cd11994e21ce..5dc9cdeb244f 100644 --- a/boot/bootm.c +++ b/boot/bootm.c @@ -529,8 +529,9 @@ int bootm_find_images(int flag, int argc, char *const argv[], ulong start, buf = map_sysmem(img_addr, 0);
/* find flattened device tree */ - ret = boot_get_fdt(buf, flag, argc, argv, IH_ARCH_DEFAULT, - &images, &images.ft_addr, &images.ft_len); + ret = boot_get_fdt(buf, argc > 2 ? argv[2] : NULL, + IH_ARCH_DEFAULT, &images, &images.ft_addr, + &images.ft_len); if (ret) { puts("Could not find a valid device tree\n"); return 1; diff --git a/boot/image-fdt.c b/boot/image-fdt.c index 6ff2d52d6c70..08fca08b710a 100644 --- a/boot/image-fdt.c +++ b/boot/image-fdt.c @@ -447,19 +447,16 @@ static int select_fdt(struct bootm_headers *images, const char *select, u8 arch, return 0; }
-int boot_get_fdt(void *buf, int flag, int argc, char *const argv[], uint arch, +int boot_get_fdt(void *buf, const char *select, uint arch, struct bootm_headers *images, char **of_flat_tree, ulong *of_size) { - ulong fdt_addr; - char *fdt_blob = NULL; - const char *select = NULL; + char *fdt_blob = NULL; + ulong fdt_addr;
- if (argc > 2) - select = argv[2]; if (select || genimg_has_config(images)) { int ret;
diff --git a/include/image.h b/include/image.h index a4555f25fb56..04f35de9d082 100644 --- a/include/image.h +++ b/include/image.h @@ -812,8 +812,7 @@ int fit_get_node_from_config(struct bootm_headers *images, * boot_get_fdt() - locate FDT devicetree to use for booting * * @buf: Pointer to image - * @argc: command argument count - * @argv: command argument list + * @select: FDT to select (this is normally argv[2] of the bootm command) * @arch: architecture (IH_ARCH_...) * @images: pointer to the bootm images structure * @of_flat_tree: pointer to a char* variable, will hold fdt start address @@ -832,7 +831,7 @@ int fit_get_node_from_config(struct bootm_headers *images, * 1, if fdt image is found but corrupted * of_flat_tree and of_size are set to 0 if no fdt exists */ -int boot_get_fdt(void *buf, int flag, int argc, char *const argv[], uint arch, +int boot_get_fdt(void *buf, const char *select, uint arch, struct bootm_headers *images, char **of_flat_tree, ulong *of_size);
This function only uses two arguments. The 'arch' always has a constant value, so drop it. This simplifies the function call.
boot/bootm.c | 3 +-- boot/image-board.c | 5 ++--- include/image.h | 9 +++++++-- 3 files changed, 10 insertions(+), 7 deletions(-)
diff --git a/boot/bootm.c b/boot/bootm.c index 5dc9cdeb244f..ae3fceb392da 100644 --- a/boot/bootm.c +++ b/boot/bootm.c @@ -555,8 +555,7 @@ int bootm_find_images(int flag, int argc, char *const argv[], ulong start, #if CONFIG_IS_ENABLED(FIT) if (IS_ENABLED(CONFIG_FPGA)) { /* find bitstreams */ - ret = boot_get_fpga(argc, argv, &images, IH_ARCH_DEFAULT, - NULL, NULL); + ret = boot_get_fpga(&images); if (ret) { printf("FPGA image is corrupted or invalid\n"); return 1; diff --git a/boot/image-board.c b/boot/image-board.c index 60e514fc150e..b926275ec917 100644 --- a/boot/image-board.c +++ b/boot/image-board.c @@ -616,8 +616,7 @@ int boot_get_setup(struct bootm_headers *images, u8 arch, return boot_get_setup_fit(images, arch, setup_start, setup_len); }
-int boot_get_fpga(int argc, char *const argv[], struct bootm_headers *images, - u8 arch, const ulong *ld_start, ulong * const ld_len) +int boot_get_fpga(struct bootm_headers *images) { ulong tmp_img_addr, img_data, img_len; void *buf; @@ -659,7 +658,7 @@ int boot_get_fpga(int argc, char *const argv[], struct bootm_headers *images, tmp_img_addr, (const char **)&uname, &images->fit_uname_cfg, - arch, + IH_ARCH_DEFAULT, IH_TYPE_FPGA, BOOTSTAGE_ID_FPGA_INIT, FIT_LOAD_OPTIONAL_NON_ZERO, diff --git a/include/image.h b/include/image.h index 04f35de9d082..63f2bd3b3713 100644 --- a/include/image.h +++ b/include/image.h @@ -642,8 +642,13 @@ ulong genimg_get_kernel_addr(char * const img_addr); int genimg_get_format(const void *img_addr); int genimg_has_config(struct bootm_headers *images);
-int boot_get_fpga(int argc, char *const argv[], struct bootm_headers *images, - uint8_t arch, const ulong *ld_start, ulong * const ld_len); +/** + * boot_get_fpga() - Locate the FPGA image + * + * @images: Information about images being loaded + * Return 0 if OK, non-zero on failure + */ +int boot_get_fpga(struct bootm_headers *images);
/** * boot_get_ramdisk() - Locate the ramdisk
boot/bootm.c | 3 +-- boot/image-board.c | 6 +++--- include/image.h | 24 +++++++++--------------- 3 files changed, 13 insertions(+), 20 deletions(-)
diff --git a/boot/bootm.c b/boot/bootm.c index ae3fceb392da..aae097df0c7f 100644 --- a/boot/bootm.c +++ b/boot/bootm.c @@ -563,8 +563,7 @@ int bootm_find_images(int flag, int argc, char *const argv[], ulong start, }
/* find all of the loadables */ - ret = boot_get_loadable(argc, argv, &images, IH_ARCH_DEFAULT, - NULL, NULL); + ret = boot_get_loadable(&images); if (ret) { printf("Loadable(s) is corrupt or invalid\n"); return 1; diff --git a/boot/image-board.c b/boot/image-board.c index b926275ec917..bb0ca9d7f22f 100644 --- a/boot/image-board.c +++ b/boot/image-board.c @@ -718,8 +718,7 @@ static void fit_loadable_process(u8 img_type, fit_loadable_handler->handler(img_data, img_len); }
-int boot_get_loadable(int argc, char *const argv[], struct bootm_headers *images, - u8 arch, const ulong *ld_start, ulong * const ld_len) +int boot_get_loadable(struct bootm_headers *images) { /* * These variables are used to hold the current image location @@ -765,7 +764,8 @@ int boot_get_loadable(int argc, char *const argv[], struct bootm_headers *images fit_img_result = fit_image_load(images, tmp_img_addr, &uname, &images->fit_uname_cfg, - arch, IH_TYPE_LOADABLE, + IH_ARCH_DEFAULT, + IH_TYPE_LOADABLE, BOOTSTAGE_ID_FIT_LOADABLE_START, FIT_LOAD_OPTIONAL_NON_ZERO, &img_data, &img_len); diff --git a/include/image.h b/include/image.h index 63f2bd3b3713..b89912a50f98 100644 --- a/include/image.h +++ b/include/image.h @@ -676,28 +676,22 @@ int boot_get_ramdisk(char const *select, struct bootm_headers *images, uint arch, ulong *rd_start, ulong *rd_end);
/** - * boot_get_loadable - routine to load a list of binaries to memory - * @argc: Ignored Argument - * @argv: Ignored Argument + * boot_get_loadable() - load a list of binaries to memory + * * @images: pointer to the bootm images structure - * @arch: expected architecture for the image - * @ld_start: Ignored Argument - * @ld_len: Ignored Argument * - * boot_get_loadable() will take the given FIT configuration, and look - * for a field named "loadables". Loadables, is a list of elements in - * the FIT given as strings. exe: + * Takes the given FIT configuration, then looks for a field named + * "loadables", a list of elements in the FIT given as strings, e.g.: * loadables = "linux_kernel", "fdt-2"; - * this function will attempt to parse each string, and load the - * corresponding element from the FIT into memory. Once placed, - * no aditional actions are taken. * - * @return: + * Each string is parsed, loading the corresponding element from the FIT into + * memory. Once placed, no additional actions are taken. + * + * Return: * 0, if only valid images or no images are found * error code, if an error occurs during fit_image_load */ -int boot_get_loadable(int argc, char *const argv[], struct bootm_headers *images, - uint8_t arch, const ulong *ld_start, ulong *const ld_len); +int boot_get_loadable(struct bootm_headers *images);
int boot_get_setup_fit(struct bootm_headers *images, uint8_t arch, ulong *setup_start, ulong *setup_len);
The Android mechanism uses the loadaddr envrionment-variable to get the load address, if none is provided. This is equivalent to image_load_addr so use that instead, converting it to a string as needed.
This change will permit passing img_addr to this function, in a future change.
boot/bootm.c | 10 +++++++--- 1 file changed, 7 insertions(+), 3 deletions(-)
diff --git a/boot/bootm.c b/boot/bootm.c index aae097df0c7f..db1466cecf2d 100644 --- a/boot/bootm.c +++ b/boot/bootm.c @@ -490,15 +490,20 @@ int bootm_find_images(int flag, int argc, char *const argv[], ulong start, ulong size) { const char *select = NULL; + char addr_str[17]; ulong img_addr; void *buf; int ret;
+ img_addr = argc ? hextoul(argv[0], NULL) : image_load_addr; + if (IS_ENABLED(CONFIG_ANDROID_BOOT_IMAGE)) { /* Look for an Android boot image */ buf = map_sysmem(images.os.start, 0); - if (buf && genimg_get_format(buf) == IMAGE_FORMAT_ANDROID) - select = argc ? argv[0] : env_get("loadaddr"); + if (buf && genimg_get_format(buf) == IMAGE_FORMAT_ANDROID) { + strcpy(addr_str, simple_xtoa(img_addr)); + select = addr_str; + } }
if (argc >= 2) @@ -525,7 +530,6 @@ int bootm_find_images(int flag, int argc, char *const argv[], ulong start, }
if (CONFIG_IS_ENABLED(OF_LIBFDT)) { - img_addr = argc ? hextoul(argv[0], NULL) : image_load_addr; buf = map_sysmem(img_addr, 0);
The normal bootm flow calls bootm_find_other() can call the BOOTM_STATE_FINDOTHER state as part of its processing. Fix the condition there so that this hack can be removed.
boot/bootm.c | 10 +++++----- boot/bootm_os.c | 6 ------ 2 files changed, 5 insertions(+), 11 deletions(-)
diff --git a/boot/bootm.c b/boot/bootm.c index db1466cecf2d..dc64de952c23 100644 --- a/boot/bootm.c +++ b/boot/bootm.c @@ -580,11 +580,11 @@ int bootm_find_images(int flag, int argc, char *const argv[], ulong start, static int bootm_find_other(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { - if (((images.os.type == IH_TYPE_KERNEL) || - (images.os.type == IH_TYPE_KERNEL_NOLOAD) || - (images.os.type == IH_TYPE_MULTI)) && - (images.os.os == IH_OS_LINUX || - images.os.os == IH_OS_VXWORKS)) + if ((images.os.type == IH_TYPE_KERNEL || + images.os.type == IH_TYPE_KERNEL_NOLOAD || + images.os.type == IH_TYPE_MULTI) && + (images.os.os == IH_OS_LINUX || images.os.os == IH_OS_VXWORKS || + images.os.os == IH_OS_EFI)) return bootm_find_images(flag, argc, argv, 0, 0);
return 0; diff --git a/boot/bootm_os.c b/boot/bootm_os.c index 9c035b5be886..9af084a9f823 100644 --- a/boot/bootm_os.c +++ b/boot/bootm_os.c @@ -493,18 +493,12 @@ static int do_bootm_tee(int flag, int argc, char *const argv[], static int do_bootm_efi(int flag, int argc, char *const argv[], struct bootm_headers *images) { - int ret; efi_status_t efi_ret; void *image_buf;
if (flag != BOOTM_STATE_OS_GO) return 0;
- /* Locate FDT, if provided */ - ret = bootm_find_images(flag, argc, argv, 0, 0); - if (ret) - return ret; - /* Initialize EFI drivers */ efi_ret = efi_init_obj_list(); if (efi_ret != EFI_SUCCESS) {
Also drop the confusing check for the OS type, since do_bootm_tee() is only called if the condition is met - see bootm_os_get_boot_func()
boot/bootm.c | 2 +- boot/bootm_os.c | 10 ---------- 2 files changed, 1 insertion(+), 11 deletions(-)
diff --git a/boot/bootm.c b/boot/bootm.c index dc64de952c23..45491e3f30aa 100644 --- a/boot/bootm.c +++ b/boot/bootm.c @@ -584,7 +584,7 @@ static int bootm_find_other(struct cmd_tbl *cmdtp, int flag, int argc, images.os.type == IH_TYPE_KERNEL_NOLOAD || images.os.type == IH_TYPE_MULTI) && (images.os.os == IH_OS_LINUX || images.os.os == IH_OS_VXWORKS || - images.os.os == IH_OS_EFI)) + images.os.os == IH_OS_EFI || images.os.os == IH_OS_TEE)) return bootm_find_images(flag, argc, argv, 0, 0);
return 0; diff --git a/boot/bootm_os.c b/boot/bootm_os.c index 9af084a9f823..265df3dda626 100644 --- a/boot/bootm_os.c +++ b/boot/bootm_os.c @@ -467,11 +467,6 @@ static int do_bootm_tee(int flag, int argc, char *const argv[], { int ret;
- /* Verify OS type */ - if (images->os.os != IH_OS_TEE) { - return 1; - }; - /* Validate OPTEE header */ ret = optee_verify_bootm_image(images->os.image_start, images->os.load, @@ -479,11 +474,6 @@ static int do_bootm_tee(int flag, int argc, char *const argv[], if (ret) return ret;
- /* Locate FDT etc */ - ret = bootm_find_images(flag, argc, argv, 0, 0); - if (ret) - return ret; - /* From here we can run the regular linux boot path */ return do_bootm_linux(flag, argc, argv, images); }
Rather than passing it all the command-line args, pass in the pieces that it needs. These are the image address, the ramdisk address/name and the FDT address/name.
Ultimately this will allow usage of this function without being called from the command line.
Move the function comment to the header file and tidy it a little.
boot/bootm.c | 45 ++++++++++++++------------------------------- cmd/booti.c | 4 +++- cmd/bootz.c | 4 +++- include/bootm.h | 26 +++++++++++++++++++++++--- 4 files changed, 43 insertions(+), 36 deletions(-)
diff --git a/boot/bootm.c b/boot/bootm.c index 45491e3f30aa..fe6e84601f58 100644 --- a/boot/bootm.c +++ b/boot/bootm.c @@ -468,35 +468,14 @@ static int bootm_find_os(const char *cmd_name, const char *addr_fit) return 0; }
-/** - * bootm_find_images - wrapper to find and locate various images - * @flag: Ignored Argument - * @argc: command argument count - * @argv: command argument list - * @start: OS image start address - * @size: OS image size - * - * boot_find_images() will attempt to load an available ramdisk, - * flattened device tree, as well as specifically marked - * "loadable" images (loadables are FIT only) - * - * Note: bootm_find_images will skip an image if it is not found - * - * @return: - * 0, if all existing images were loaded correctly - * 1, if an image is found but corrupted, or invalid - */ -int bootm_find_images(int flag, int argc, char *const argv[], ulong start, - ulong size) +int bootm_find_images(ulong img_addr, const char *conf_ramdisk, + const char *conf_fdt, ulong start, ulong size) { - const char *select = NULL; + const char *select = conf_ramdisk; char addr_str[17]; - ulong img_addr; void *buf; int ret;
- img_addr = argc ? hextoul(argv[0], NULL) : image_load_addr; - if (IS_ENABLED(CONFIG_ANDROID_BOOT_IMAGE)) { /* Look for an Android boot image */ buf = map_sysmem(images.os.start, 0); @@ -506,8 +485,8 @@ int bootm_find_images(int flag, int argc, char *const argv[], ulong start, } }
- if (argc >= 2) - select = argv[1]; + if (conf_ramdisk) + select = conf_ramdisk;
/* find ramdisk */ ret = boot_get_ramdisk(select, &images, IH_INITRD_ARCH, @@ -533,9 +512,8 @@ int bootm_find_images(int flag, int argc, char *const argv[], ulong start, buf = map_sysmem(img_addr, 0);
/* find flattened device tree */ - ret = boot_get_fdt(buf, argc > 2 ? argv[2] : NULL, - IH_ARCH_DEFAULT, &images, &images.ft_addr, - &images.ft_len); + ret = boot_get_fdt(buf, conf_fdt, IH_ARCH_DEFAULT, &images, + &images.ft_addr, &images.ft_len); if (ret) { puts("Could not find a valid device tree\n"); return 1; @@ -584,8 +562,13 @@ static int bootm_find_other(struct cmd_tbl *cmdtp, int flag, int argc, images.os.type == IH_TYPE_KERNEL_NOLOAD || images.os.type == IH_TYPE_MULTI) && (images.os.os == IH_OS_LINUX || images.os.os == IH_OS_VXWORKS || - images.os.os == IH_OS_EFI || images.os.os == IH_OS_TEE)) - return bootm_find_images(flag, argc, argv, 0, 0); + images.os.os == IH_OS_EFI || images.os.os == IH_OS_TEE)) { + ulong img_addr; + + img_addr = argc ? hextoul(argv[0], NULL) : image_load_addr; + return bootm_find_images(img_addr, argc > 1 ? argv[1] : NULL, + argc > 2 ? argv[2] : NULL, 0, 0); + }
return 0; } diff --git a/cmd/booti.c b/cmd/booti.c index a6c7db272c57..dc73c83f0db0 100644 --- a/cmd/booti.c +++ b/cmd/booti.c @@ -95,7 +95,9 @@ static int booti_start(struct cmd_tbl *cmdtp, int flag, int argc, * Handle the BOOTM_STATE_FINDOTHER state ourselves as we do not * have a header that provide this informaiton. */ - if (bootm_find_images(flag, argc, argv, relocated_addr, image_size)) + if (bootm_find_images(image_load_addr, argc > 1 ? argv[1] : NULL, + argc > 2 ? argv[2] : NULL, relocated_addr, + image_size)) return 1;
return 0; diff --git a/cmd/bootz.c b/cmd/bootz.c index dd6fe4904b02..bcf232b4f305 100644 --- a/cmd/bootz.c +++ b/cmd/bootz.c @@ -54,7 +54,9 @@ static int bootz_start(struct cmd_tbl *cmdtp, int flag, int argc, * Handle the BOOTM_STATE_FINDOTHER state ourselves as we do not * have a header that provide this informaiton. */ - if (bootm_find_images(flag, argc, argv, images->ep, zi_end - zi_start)) + if (bootm_find_images(image_load_addr, argc > 1 ? argv[1] : NULL, + argc > 2 ? argv[2] : NULL, images->ep, + zi_end - zi_start)) return 1;
return 0; diff --git a/include/bootm.h b/include/bootm.h index 10a1bd65a754..f5229ea90b33 100644 --- a/include/bootm.h +++ b/include/bootm.h @@ -52,9 +52,29 @@ int boot_selected_os(int argc, char *const argv[], int state,
ulong bootm_disable_interrupts(void);
-/* This is a special function used by booti/bootz */ -int bootm_find_images(int flag, int argc, char *const argv[], ulong start, - ulong size); +/** + * bootm_find_images() - find and locate various images + * + * @img_addr: Address of image being loaded + * @conf_ramdisk: Indicates the ramdisk to use (typically second arg of bootm) + * @conf_fdt: Indicates the FDT to use (typically third arg of bootm) + * @start: OS image start address + * @size: OS image size + * + * boot_find_images() will attempt to load an available ramdisk, + * flattened device tree, as well as specifically marked + * "loadable" images (loadables are FIT only) + * + * Note: bootm_find_images will skip an image if it is not found + * + * This is a special function used by booti/bootz + * + * Return: + * 0, if all existing images were loaded correctly + * 1, if an image is found but corrupted, or invalid + */ +int bootm_find_images(ulong img_addr, const char *conf_ramdisk, + const char *conf_fdt, ulong start, ulong size);
/* * Measure the boot images. Measurement is the process of hashing some binary
Move this code into a function to reduce code size and make it easier to understand. Drop the unnecessary 0x to help a little with code size.
Use this in bootm_find_images()
boot/bootm.c | 51 ++++++++++++++++++++++++++++++++++----------------- 1 file changed, 34 insertions(+), 17 deletions(-)
diff --git a/boot/bootm.c b/boot/bootm.c index fe6e84601f58..371f404a02a5 100644 --- a/boot/bootm.c +++ b/boot/bootm.c @@ -468,6 +468,37 @@ static int bootm_find_os(const char *cmd_name, const char *addr_fit) return 0; }
+/** + * check_overlap() - Check if an image overlaps the OS + * + * @name: Name of image to check (used to print error) + * @base: Base address of image + * @end: End address of image (+1) + * @os_start: Start of OS + * @os_size: Size of OS in bytes + * Return: 0 if OK, -EXDEV if the image overlaps the OS + */ +static int check_overlap(const char *name, ulong base, ulong end, + ulong os_start, ulong os_size) +{ + ulong os_end; + + if (!base) + return 0; + os_end = os_start + os_size; + + if ((base >= os_start && base < os_end) || + (end > os_start && end <= os_end) || + (base < os_start && end >= os_end)) { + printf("ERROR: %s image overlaps OS image (OS=%lx..%lx)\n", + name, os_start, os_end); + + return -EXDEV; + } + + return 0; +} + int bootm_find_images(ulong img_addr, const char *conf_ramdisk, const char *conf_fdt, ulong start, ulong size) { @@ -497,16 +528,8 @@ int bootm_find_images(ulong img_addr, const char *conf_ramdisk, }
/* check if ramdisk overlaps OS image */ - if (images.rd_start && (((ulong)images.rd_start >= start && - (ulong)images.rd_start < start + size) || - ((ulong)images.rd_end > start && - (ulong)images.rd_end <= start + size) || - ((ulong)images.rd_start < start && - (ulong)images.rd_end >= start + size))) { - printf("ERROR: RD image overlaps OS image (OS=0x%lx..0x%lx)\n", - start, start + size); + if (check_overlap("RD", images.rd_start, images.rd_end, start, size)) return 1; - }
if (CONFIG_IS_ENABLED(OF_LIBFDT)) { buf = map_sysmem(img_addr, 0); @@ -520,15 +543,9 @@ int bootm_find_images(ulong img_addr, const char *conf_ramdisk, }
/* check if FDT overlaps OS image */ - if (images.ft_addr && - (((ulong)images.ft_addr >= start && - (ulong)images.ft_addr < start + size) || - ((ulong)images.ft_addr + images.ft_len >= start && - (ulong)images.ft_addr + images.ft_len < start + size))) { - printf("ERROR: FDT image overlaps OS image (OS=0x%lx..0x%lx)\n", - start, start + size); + if (check_overlap("FDT", map_to_sysmem(images.ft_addr), + images.ft_len, start, size)) return 1; - }
if (IS_ENABLED(CONFIG_CMD_FDT)) set_working_fdt_addr(map_to_sysmem(images.ft_addr));
Rather than passing the full list of command arguments, pass only those which are needed.
boot/bootm.c | 20 +++++++++++--------- 1 file changed, 11 insertions(+), 9 deletions(-)
diff --git a/boot/bootm.c b/boot/bootm.c index 371f404a02a5..07aae26af01f 100644 --- a/boot/bootm.c +++ b/boot/bootm.c @@ -572,19 +572,16 @@ int bootm_find_images(ulong img_addr, const char *conf_ramdisk, return 0; }
-static int bootm_find_other(struct cmd_tbl *cmdtp, int flag, int argc, - char *const argv[]) +static int bootm_find_other(ulong img_addr, const char *conf_ramdisk, + const char *conf_fdt) { if ((images.os.type == IH_TYPE_KERNEL || images.os.type == IH_TYPE_KERNEL_NOLOAD || images.os.type == IH_TYPE_MULTI) && (images.os.os == IH_OS_LINUX || images.os.os == IH_OS_VXWORKS || images.os.os == IH_OS_EFI || images.os.os == IH_OS_TEE)) { - ulong img_addr; - - img_addr = argc ? hextoul(argv[0], NULL) : image_load_addr; - return bootm_find_images(img_addr, argc > 1 ? argv[1] : NULL, - argc > 2 ? argv[2] : NULL, 0, 0); + return bootm_find_images(img_addr, conf_ramdisk, conf_fdt, 0, + 0); }
return 0; @@ -1013,8 +1010,13 @@ int do_bootm_states(struct cmd_tbl *cmdtp, int flag, int argc, if (!ret && (states & BOOTM_STATE_FINDOS)) ret = bootm_find_os(cmdtp->name, argv[0]);
- if (!ret && (states & BOOTM_STATE_FINDOTHER)) - ret = bootm_find_other(cmdtp, flag, argc, argv); + if (!ret && (states & BOOTM_STATE_FINDOTHER)) { + ulong img_addr; + + img_addr = argc ? hextoul(argv[0], NULL) : image_load_addr; + ret = bootm_find_other(img_addr, argc > 1 ? argv[1] : NULL, + argc > 2 ? argv[2] : NULL); + }
if (IS_ENABLED(CONFIG_MEASURED_BOOT) && !ret && (states & BOOTM_STATE_MEASURE))
Add some functions which provide an argument to a command, or NULL if the argument does not exist.
Use the same numbering as argv[] since it seems less confusing than the previous idea.
Signed-off-by: Simon Glass sjg@chromium.org Suggested-by: Tom Rini trini@konsulko.com ---
Changes in v2: - Add new patch to obtain command arguments
boot/bootm.c | 4 ++-- cmd/booti.c | 4 ++-- cmd/bootz.c | 4 ++-- cmd/disk.c | 4 ++-- cmd/fuse.c | 2 +- cmd/mmc.c | 2 +- drivers/misc/gsc.c | 6 +++--- fs/fs.c | 4 ++-- include/command.h | 33 +++++++++++++++++++++++++++++++++ test/cmd_ut.c | 2 +- 10 files changed, 49 insertions(+), 16 deletions(-)
diff --git a/boot/bootm.c b/boot/bootm.c index 07aae26af01f..a0d17be7742c 100644 --- a/boot/bootm.c +++ b/boot/bootm.c @@ -1014,8 +1014,8 @@ int do_bootm_states(struct cmd_tbl *cmdtp, int flag, int argc, ulong img_addr;
img_addr = argc ? hextoul(argv[0], NULL) : image_load_addr; - ret = bootm_find_other(img_addr, argc > 1 ? argv[1] : NULL, - argc > 2 ? argv[2] : NULL); + ret = bootm_find_other(img_addr, cmd_arg1(argc, argv), + cmd_arg2(argc, argv)); }
if (IS_ENABLED(CONFIG_MEASURED_BOOT) && !ret && diff --git a/cmd/booti.c b/cmd/booti.c index dc73c83f0db0..2db8f4a16ff2 100644 --- a/cmd/booti.c +++ b/cmd/booti.c @@ -95,8 +95,8 @@ static int booti_start(struct cmd_tbl *cmdtp, int flag, int argc, * Handle the BOOTM_STATE_FINDOTHER state ourselves as we do not * have a header that provide this informaiton. */ - if (bootm_find_images(image_load_addr, argc > 1 ? argv[1] : NULL, - argc > 2 ? argv[2] : NULL, relocated_addr, + if (bootm_find_images(image_load_addr, cmd_arg1(argc, argv), + cmd_arg2(argc, argv), relocated_addr, image_size)) return 1;
diff --git a/cmd/bootz.c b/cmd/bootz.c index bcf232b4f305..a652879ea5ec 100644 --- a/cmd/bootz.c +++ b/cmd/bootz.c @@ -54,8 +54,8 @@ static int bootz_start(struct cmd_tbl *cmdtp, int flag, int argc, * Handle the BOOTM_STATE_FINDOTHER state ourselves as we do not * have a header that provide this informaiton. */ - if (bootm_find_images(image_load_addr, argc > 1 ? argv[1] : NULL, - argc > 2 ? argv[2] : NULL, images->ep, + if (bootm_find_images(image_load_addr, cmd_arg1(argc, argv), + cmd_arg2(argc, argv), images->ep, zi_end - zi_start)) return 1;
diff --git a/cmd/disk.c b/cmd/disk.c index 3d7bc2f60189..92eaa02f4a13 100644 --- a/cmd/disk.c +++ b/cmd/disk.c @@ -40,8 +40,8 @@ int common_diskboot(struct cmd_tbl *cmdtp, const char *intf, int argc,
bootstage_mark(BOOTSTAGE_ID_IDE_BOOT_DEVICE);
- part = blk_get_device_part_str(intf, (argc == 3) ? argv[2] : NULL, - &dev_desc, &info, 1); + part = blk_get_device_part_str(intf, cmd_arg2(argc, argv), + &dev_desc, &info, 1); if (part < 0) { bootstage_error(BOOTSTAGE_ID_IDE_TYPE); return 1; diff --git a/cmd/fuse.c b/cmd/fuse.c index 0676bb7a812f..f884c894fb00 100644 --- a/cmd/fuse.c +++ b/cmd/fuse.c @@ -44,7 +44,7 @@ static int confirm_prog(void) static int do_fuse(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { - const char *op = argc >= 2 ? argv[1] : NULL; + const char *op = cmd_arg1(argc, argv); int confirmed = argc >= 3 && !strcmp(argv[2], "-y"); u32 bank, word, cnt, val, cmp; ulong addr; diff --git a/cmd/mmc.c b/cmd/mmc.c index 96befb27eec6..2d5430a53079 100644 --- a/cmd/mmc.c +++ b/cmd/mmc.c @@ -946,7 +946,7 @@ static int do_mmc_partconf(struct cmd_tbl *cmdtp, int flag, }
if (argc == 2 || argc == 3) - return mmc_partconf_print(mmc, argc == 3 ? argv[2] : NULL); + return mmc_partconf_print(mmc, cmd_arg2(argc, argv));
ack = dectoul(argv[2], NULL); part_num = dectoul(argv[3], NULL); diff --git a/drivers/misc/gsc.c b/drivers/misc/gsc.c index 65c9c2c6ce37..feb02f970650 100644 --- a/drivers/misc/gsc.c +++ b/drivers/misc/gsc.c @@ -531,10 +531,10 @@ static int do_gsc(struct cmd_tbl *cmdtp, int flag, int argc, char * const argv[] if (!gsc_wd_disable(dev)) return CMD_RET_SUCCESS; } else if (strcasecmp(argv[1], "thermal") == 0) { - char *cmd, *val; + const char *cmd, *val;
- cmd = (argc > 2) ? argv[2] : NULL; - val = (argc > 3) ? argv[3] : NULL; + cmd = cmd_arg2(argc, argv); + val = cmd_arg3(argc, argv); if (!gsc_thermal(dev, cmd, val)) return CMD_RET_SUCCESS; } diff --git a/fs/fs.c b/fs/fs.c index 4cb4310c9cc2..f33b85f92b61 100644 --- a/fs/fs.c +++ b/fs/fs.c @@ -749,7 +749,7 @@ int do_load(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[], if (argc > 7) return CMD_RET_USAGE;
- if (fs_set_blk_dev(argv[1], (argc >= 3) ? argv[2] : NULL, fstype)) { + if (fs_set_blk_dev(argv[1], cmd_arg2(argc, argv), fstype)) { log_err("Can't set block device\n"); return 1; } @@ -818,7 +818,7 @@ int do_ls(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[], if (argc > 4) return CMD_RET_USAGE;
- if (fs_set_blk_dev(argv[1], (argc >= 3) ? argv[2] : NULL, fstype)) + if (fs_set_blk_dev(argv[1], cmd_arg2(argc, argv), fstype)) return 1;
if (fs_ls(argc >= 4 ? argv[3] : "/")) diff --git a/include/command.h b/include/command.h index 5bd3ecbe8f91..4cec63454534 100644 --- a/include/command.h +++ b/include/command.h @@ -60,6 +60,39 @@ struct cmd_tbl { #endif };
+/** + * cmd_arg_get() - Get a particular argument + * + * @argc: Number of arguments + * @argv: Argument vector of length @argc + * @argnum: Argument to get (0=first) + * Return: Pointer to argument @argnum if it exists, else NULL + */ +static inline const char *cmd_arg_get(int argc, char *const argv[], int argnum) +{ + return argc > argnum ? argv[argnum] : NULL; +} + +static inline const char *cmd_arg0(int argc, char *const argv[]) +{ + return cmd_arg_get(argc, argv, 0); +} + +static inline const char *cmd_arg1(int argc, char *const argv[]) +{ + return cmd_arg_get(argc, argv, 1); +} + +static inline const char *cmd_arg2(int argc, char *const argv[]) +{ + return cmd_arg_get(argc, argv, 2); +} + +static inline const char *cmd_arg3(int argc, char *const argv[]) +{ + return cmd_arg_get(argc, argv, 3); +} + #if defined(CONFIG_CMD_RUN) int do_run(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); diff --git a/test/cmd_ut.c b/test/cmd_ut.c index 2d5b80f992e3..2ead1c68e0ea 100644 --- a/test/cmd_ut.c +++ b/test/cmd_ut.c @@ -45,7 +45,7 @@ int cmd_ut_category(const char *name, const char *prefix, }
ret = ut_run_list(name, prefix, tests, n_ents, - argc > 1 ? argv[1] : NULL, runs_per_text, force_run, + cmd_arg1(argc, argv), runs_per_text, force_run, test_insert);
return ret ? CMD_RET_FAILURE : 0;
Ilias Apalodimas
