[U-Boot] [PATCH 1/3] microblaze: remove wrong define CONFIG_SYS_FLASH_PROTECTION
CONFIG_SYS_FLASH_PROTECTION will defined twice. The second one is outside the flash configuration context and we can remove it safely.
Signed-off-by: Stephan Linz linz@li-pro.net --- include/configs/microblaze-generic.h | 2 -- 1 files changed, 0 insertions(+), 2 deletions(-)
diff --git a/include/configs/microblaze-generic.h b/include/configs/microblaze-generic.h index 295d123..5f16820 100644 --- a/include/configs/microblaze-generic.h +++ b/include/configs/microblaze-generic.h @@ -200,8 +200,6 @@ # define CONFIG_ENV_IS_NOWHERE 1 # define CONFIG_ENV_SIZE 0x1000 # define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - CONFIG_ENV_SIZE) -/* hardware flash protection */ -# define CONFIG_SYS_FLASH_PROTECTION #endif /* !FLASH */
/* system ace */
Use XILINX_FLASH_START to set/unset FLASH and RAMENV.
Error was: board.c: In function 'board_init': board.c:134: error: 'XILINX_FLASH_START' undeclared (first use in this function) board.c:134: error: (Each undeclared identifier is reported only once board.c:134: error: for each function it appears in.)
Signed-off-by: Stephan Linz linz@li-pro.net --- include/configs/microblaze-generic.h | 12 +++++++++--- 1 files changed, 9 insertions(+), 3 deletions(-)
diff --git a/include/configs/microblaze-generic.h b/include/configs/microblaze-generic.h index 5f16820..2ef7d62 100644 --- a/include/configs/microblaze-generic.h +++ b/include/configs/microblaze-generic.h @@ -31,6 +31,15 @@ #define CONFIG_MICROBLAZE 1 #define MICROBLAZE_V5 1
+/* linear flash memory */ +#ifdef XILINX_FLASH_START +#define FLASH +#undef RAMENV /* hold environment in flash */ +#else +#undef FLASH +#define RAMENV /* hold environment in RAM */ +#endif + /* uart */ #ifdef XILINX_UARTLITE_BASEADDR # define CONFIG_XILINX_UARTLITE @@ -164,9 +173,6 @@ /* stack */ #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_MALLOC_BASE
-/*#define RAMENV */ -#define FLASH - #ifdef FLASH # define CONFIG_SYS_FLASH_BASE XILINX_FLASH_START # define CONFIG_SYS_FLASH_SIZE XILINX_FLASH_SIZE
Increase malloc area for UBI to >= 512k -- foreseeing of UBIFS set to 768k. To save memory in flash (CONFIG_SYS_MONITOR_LEN) the UBIFS is disabled by default.
Signed-off-by: Stephan Linz linz@li-pro.net --- include/configs/microblaze-generic.h | 20 ++++++++++++++++++-- 1 files changed, 18 insertions(+), 2 deletions(-)
diff --git a/include/configs/microblaze-generic.h b/include/configs/microblaze-generic.h index 2ef7d62..2fd2279 100644 --- a/include/configs/microblaze-generic.h +++ b/include/configs/microblaze-generic.h @@ -166,7 +166,7 @@ - CONFIG_SYS_MONITOR_LEN - GENERATED_BD_INFO_SIZE) #define CONFIG_SYS_MONITOR_END \ (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) -#define CONFIG_SYS_MALLOC_LEN SIZE +#define CONFIG_SYS_MALLOC_LEN (SIZE * 3) #define CONFIG_SYS_MALLOC_BASE \ (CONFIG_SYS_MONITOR_BASE - CONFIG_SYS_MALLOC_LEN)
@@ -273,6 +273,8 @@ # define CONFIG_CMD_FLASH # define CONFIG_CMD_IMLS # define CONFIG_CMD_JFFS2 +# define CONFIG_CMD_UBI +# undef CONFIG_CMD_UBIFS
# if !defined(RAMENV) # define CONFIG_CMD_SAVEENV @@ -285,7 +287,21 @@ #endif
#if defined(CONFIG_CMD_JFFS2) -/* JFFS2 partitions */ +# define CONFIG_MTD_PARTITIONS +#endif + +#if defined(CONFIG_CMD_UBIFS) +# define CONFIG_CMD_UBI +# define CONFIG_LZO +#endif + +#if defined(CONFIG_CMD_UBI) +# define CONFIG_MTD_PARTITIONS +# define CONFIG_RBTREE +#endif + +#if defined(CONFIG_MTD_PARTITIONS) +/* MTD partitions */ #define CONFIG_CMD_MTDPARTS /* mtdparts command line support */ #define CONFIG_MTD_DEVICE /* needed for mtdparts commands */ #define CONFIG_FLASH_CFI_MTD
Signed-off-by: Stephan Linzlinz@li-pro.net
/* system ace */
Applied all three patches to microblaze custodian repo with minor cleanup.
Thanks, Michal
Michal Simek
Stephan Linz
