[U-Boot] [PATCH] sandbox: Fix README to indicate that vendor name is unset
This brings in a additional small fix which was missed in a recent update to the README.
Suggested-by: Masahiro Yamada yamada.m@jp.panasonic.com Signed-off-by: Simon Glass sjg@chromium.org ---
board/sandbox/README.sandbox | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/board/sandbox/README.sandbox b/board/sandbox/README.sandbox index 5f879f5..3c0df17 100644 --- a/board/sandbox/README.sandbox +++ b/board/sandbox/README.sandbox @@ -18,8 +18,8 @@ create unit tests which we can run to test this upper level code.
CONFIG_SANDBOX is defined when building a native board.
-The chosen vendor and board names are also 'sandbox', so there is a single -board in board/sandbox. +The board name is 'sandbox' but the vendor name is unset, so there is a +single board in board/sandbox.
CONFIG_SANDBOX_BIG_ENDIAN should be defined when running on big-endian machines.
Acked-by: Jagannadha Sutradharudu Teki jagannadh.teki@gmail.com
CONFIG_SANDBOX_BIG_ENDIAN should be defined when running on big-endian machines. -- 2.1.0.rc2.206.gedb03e5
Applied to u-boot-x86/patman
-- Jagan.
Jagan Teki
