[U-Boot] [PATCH v2] pinctrl: move dm_scan_fdt_node() out of pinctrl uclass
Commit c5acf4a2b3c6 ("pinctrl: Add the concept of peripheral IDs") added some additional change that was not mentioned in the git-log.
That commit added dm_scan_fdt_node() in the pinctrl uclass binding. It should be handled by the simple-bus driver or the low-level driver, not by the pinctrl framework.
I guess Simon's motivation was to bind GPIO banks located under the Rockchip pinctrl device. It is true some chips have sub-devices under their pinctrl devices, but it is basically SoC-specific matter.
This commit partly reverts commit c5acf4a2b3c6 to keep the only pinctrl-generic features in the uclass. The dm_scan_fdt_node() should be called from the rk3288_pinctrl driver.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com Acked-by: Simon Glass sjg@chromium.org Tested-by: Simon Glass sjg@chromium.org ---
Changes in v2: - Drop "By the way ..." part from git-log
drivers/pinctrl/pinctrl-uclass.c | 15 +++++++++------ drivers/pinctrl/rockchip/pinctrl_rk3288.c | 8 ++++++++ 2 files changed, 17 insertions(+), 6 deletions(-)
diff --git a/drivers/pinctrl/pinctrl-uclass.c b/drivers/pinctrl/pinctrl-uclass.c index 58001ef..b5fdcd1 100644 --- a/drivers/pinctrl/pinctrl-uclass.c +++ b/drivers/pinctrl/pinctrl-uclass.c @@ -11,7 +11,6 @@ #include <dm/device.h> #include <dm/lists.h> #include <dm/pinctrl.h> -#include <dm/root.h> #include <dm/uclass.h>
DECLARE_GLOBAL_DATA_PTR; @@ -160,8 +159,7 @@ static int pinctrl_select_state_full(struct udevice *dev, const char *statename)
static int pinconfig_post_bind(struct udevice *dev) { - /* Scan the bus for devices */ - return dm_scan_fdt_node(dev, gd->fdt_blob, dev->of_offset, false); + return 0; } #endif
@@ -249,10 +247,15 @@ static int pinctrl_post_bind(struct udevice *dev) }
/* - * The pinctrl driver child nodes should be bound so that peripheral - * devices can easily search in parent devices during later DT-parsing. + * If set_state callback is set, we assume this pinctrl driver is the + * full implementation. In this case, its child nodes should be bound + * so that peripheral devices can easily search in parent devices + * during later DT-parsing. */ - return pinconfig_post_bind(dev); + if (ops->set_state) + return pinconfig_post_bind(dev); + + return 0; }
UCLASS_DRIVER(pinctrl) = { diff --git a/drivers/pinctrl/rockchip/pinctrl_rk3288.c b/drivers/pinctrl/rockchip/pinctrl_rk3288.c index 5205498..c432a00 100644 --- a/drivers/pinctrl/rockchip/pinctrl_rk3288.c +++ b/drivers/pinctrl/rockchip/pinctrl_rk3288.c @@ -17,6 +17,7 @@ #include <asm/arch/periph.h> #include <asm/arch/pmu_rk3288.h> #include <dm/pinctrl.h> +#include <dm/root.h>
@@ -415,6 +416,12 @@ static struct pinctrl_ops rk3288_pinctrl_ops = { .get_periph_id = rk3288_pinctrl_get_periph_id, };
+static int rk3288_pinctrl_bind(struct udevice *dev) +{ + /* scan child GPIO banks */ + return dm_scan_fdt_node(dev, gd->fdt_blob, dev->of_offset, false); +} + static int rk3288_pinctrl_probe(struct udevice *dev) { struct rk3288_pinctrl_priv *priv = dev_get_priv(dev); @@ -437,5 +444,6 @@ U_BOOT_DRIVER(pinctrl_rk3288) = { .of_match = rk3288_pinctrl_ids, .priv_auto_alloc_size = sizeof(struct rk3288_pinctrl_priv), .ops = &rk3288_pinctrl_ops, + .bind = rk3288_pinctrl_bind, .probe = rk3288_pinctrl_probe, };
On Saturday, 5 September 2015, Masahiro Yamada yamada.masahiro@socionext.com wrote:
Changes in v2:
} #endif
if (ops->set_state)
1.9.1
Masahiro Yamada
