[U-Boot] [PATCH 1/2] MX31: mx31pdk: fix nand_spl
Commit f326cbba98bae21d41df8daac0bd78121d557af1 breaks mx31pdk, as the _end section in u-boot.lds is missing for the nand_spl production.
Signed-off-by: Stefano Babic sbabic@denx.de CC: Fabio Estevam fabio.estevam@freescale.com --- nand_spl/board/freescale/mx31pdk/u-boot.lds | 2 ++ 1 files changed, 2 insertions(+), 0 deletions(-)
diff --git a/nand_spl/board/freescale/mx31pdk/u-boot.lds b/nand_spl/board/freescale/mx31pdk/u-boot.lds index 324a932..d2b08f6 100644 --- a/nand_spl/board/freescale/mx31pdk/u-boot.lds +++ b/nand_spl/board/freescale/mx31pdk/u-boot.lds @@ -63,6 +63,8 @@ SECTIONS *(.dynsym) }
+ _end = .; + .bss __rel_dyn_start (OVERLAY) : { __bss_start = .; *(.bss)
Hi Stefano,
What command line should one use to reproduce the issue? I just did a ./MAKEALL mx31pdk from the current u-boot-arm master branch and it builds fine, which I suspect sould not be possible if it missed the _end symbol.
Amicalement,
On 04/03/2011 02:08 PM, Albert ARIBAUD wrote:
Hi Stefano,
Hi Albert,
you should issue mx31pdk_nand. I do not know why there is a special target in the Makefile, I do not think this is necessary and only boards.cfg could be used. But this has nothing to do with the reported error, answering your question I have seen something else strange ;-)
The mx31pdk supports booting from NOR or from NAND, using two different configuration. You compiled for NOR, and everything works fine - only the nand_spl part has this issue.
Stefano
Hi Albert,
--- On Sun, 4/3/11, Albert ARIBAUD albert.aribaud@free.fr wrote:
From: Albert ARIBAUD albert.aribaud@free.fr Subject: Re: [U-Boot] [PATCH 1/2] MX31: mx31pdk: fix nand_spl To: u-boot@lists.denx.de Date: Sunday, April 3, 2011, 9:08 AM Hi Stefano,
mx31pdk,
nand_spl
production.
Please do a ´make mx31pdk_nand_config´
Regards,
Fabio Estevam
Hi Stefano,
After applying your patch I was able to build and boot MX31PDK from NAND, so here goes my:
Tested-by: Fabio Estevam fabio.estevam@freescale.com
Regards,
Fabio Estevam
Le 04/04/2011 00:04, Fabio Estevam a écrit :
Hi Stefano,
Signed-off-by: Stefano Babicsbabic@denx.de
Tested-by: Fabio Estevamfabio.estevam@freescale.com
Regards,
Fabio Estevam
Applied to u-boot-arm/master, thanks!
Amicalement,
Albert ARIBAUD
Fabio Estevam
Fabio Estevam
Stefano Babic
