[U-Boot] [PATCH] ARM: mvebu: db-88f6820: remove redundant comment
After migration to Kconfig the comment about TEXT_BASE has become redundant.
Signed-off-by: Chris Packham judge.packham@gmail.com ---
include/configs/db-88f6820-amc.h | 5 ----- include/configs/db-88f6820-gp.h | 5 ----- 2 files changed, 10 deletions(-)
diff --git a/include/configs/db-88f6820-amc.h b/include/configs/db-88f6820-amc.h index 2f1ffa2754c7..e68246cc0f4f 100644 --- a/include/configs/db-88f6820-amc.h +++ b/include/configs/db-88f6820-amc.h @@ -10,11 +10,6 @@ * High Level Configuration Options (easy to change) */
-/* - * TEXT_BASE needs to be below 16MiB, since this area is scrubbed - * for DDR ECC byte filling in the SPL before loading the main - * U-Boot into it. - */ #define CONFIG_SYS_TCLK 200000000 /* 200MHz */
/* diff --git a/include/configs/db-88f6820-gp.h b/include/configs/db-88f6820-gp.h index f2aa21a43e5f..3900cbed2d70 100644 --- a/include/configs/db-88f6820-gp.h +++ b/include/configs/db-88f6820-gp.h @@ -10,11 +10,6 @@ * High Level Configuration Options (easy to change) */
-/* - * TEXT_BASE needs to be below 16MiB, since this area is scrubbed - * for DDR ECC byte filling in the SPL before loading the main - * U-Boot into it. - */ #define CONFIG_SYS_TCLK 250000000 /* 250MHz */
Applied to u-boot-marvell/master
Thanks, Stefan
Chris Packham
Stefan Roese
