[U-Boot-Users] Peripheral initialization hooks
Hello all,
I have a PPC852T platform running U-Boot. My platform has the ability to enable or disable the Ethernet PHY directly, and at boot the PHY is disabled. It must be enabled, through a register in an FPGA that is accessed through a separate chip select.
Is it acceptable to modify board_init_r() to include a call to an enable/disable function that would only apply if my board were defined? Or are there any hooks for board-specific initializations?
Also, given that this is related to Ethernet, I think it's best that I enable the PHY immediately before querying the config for 'ethaddr' in board_init_r(). Agree/disagree?
TIA,
Steve
Steve Strublic
Network Solutions Group
Hypercom Corporation
Phoenix, AZ
The hooks are already there. I would recommend board_early_init_f() or board_early_init_r() which can be turned on/off by the board configuration header file.
Regards, -Shawn.
Steve,
Also, given that this is related to Ethernet, I think it’s best that I enable the PHY immediately before querying the config for ‘ethaddr’ in board_init_r(). Agree/disagree?
I personally would stay away modifying common code if there is a way to do it. You surely will make it modifications conditional for your board but still it is a distribution of your board programming logic into other files that are not obvious immediately.
What if you enable CONFIG_BOARD_EARLY_INIT_F in your board config file and create a board_early_init_f() that enables all your PHYs and leave it enabled?
Unless there is a serious issues with that, I would choose to keep all your PHYs enabled. This assumes that you have initialized your FPGA CS in your board initialization.
I use early init to initialize PLL to generate correct frquency for my external serial console clock and a number of other clocks.
Tolunay
In message 482F3C06ECF00C44AEC226520C6FCB1A51ECB9@EXCHANGEVS.HYPERCOM.COM you wrote:
No, it is not, as there are already too many such hooks available.
Yes, there are.
Shawn Jin
Steve Strublic
Tolunay Orkun
