[PATCH 1/1] clk: sifive: avoid declaring static variables in includes
The existing code is unnecessarily convoluted:
Arrays __prci_init_clocks_fu[5|7]40 are initialized with data. In separate includes fu[5|7]40-prci.h the size of the arrays is provided as constants.
By moving the structures prci_clk_fu[5|7]40 to the respective code modules we can directly use ARRAY_SIZE() to access the size of the data used for initialization.
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- drivers/clk/sifive/fu540-prci.c | 7 ++++++- drivers/clk/sifive/fu540-prci.h | 22 ---------------------- drivers/clk/sifive/fu740-prci.c | 7 ++++++- drivers/clk/sifive/fu740-prci.h | 22 ---------------------- drivers/clk/sifive/sifive-prci.c | 3 +-- drivers/clk/sifive/sifive-prci.h | 4 ++++ 6 files changed, 17 insertions(+), 48 deletions(-) delete mode 100644 drivers/clk/sifive/fu540-prci.h delete mode 100644 drivers/clk/sifive/fu740-prci.h
diff --git a/drivers/clk/sifive/fu540-prci.c b/drivers/clk/sifive/fu540-prci.c index ceb2c6fab0d..e55a26ab8fd 100644 --- a/drivers/clk/sifive/fu540-prci.c +++ b/drivers/clk/sifive/fu540-prci.c @@ -58,7 +58,7 @@ static const struct __prci_clock_ops sifive_fu540_prci_tlclksel_clk_ops = { };
/* List of clock controls provided by the PRCI */ -struct __prci_clock __prci_init_clocks_fu540[] = { +static struct __prci_clock __prci_init_clocks_fu540[] = { [PRCI_CLK_COREPLL] = { .name = "corepll", .parent_name = "hfclk", @@ -83,3 +83,8 @@ struct __prci_clock __prci_init_clocks_fu540[] = { .ops = &sifive_fu540_prci_tlclksel_clk_ops, }, }; + +const struct prci_clk_desc prci_clk_fu540 = { + .clks = __prci_init_clocks_fu540, + .num_clks = ARRAY_SIZE(__prci_init_clocks_fu540), +}; diff --git a/drivers/clk/sifive/fu540-prci.h b/drivers/clk/sifive/fu540-prci.h deleted file mode 100644 index 113301107da..00000000000 --- a/drivers/clk/sifive/fu540-prci.h +++ /dev/null @@ -1,22 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * Copyright (C) 2020-2021 SiFive, Inc. - * Zong Li - * Pragnesh Patel - */ - -#ifndef __SIFIVE_CLK_FU540_PRCI_H -#define __SIFIVE_CLK_FU540_PRCI_H - -#include "sifive-prci.h" - -#define NUM_CLOCK_FU540 4 - -extern struct __prci_clock __prci_init_clocks_fu540[NUM_CLOCK_FU540]; - -static const struct prci_clk_desc prci_clk_fu540 = { - .clks = __prci_init_clocks_fu540, - .num_clks = ARRAY_SIZE(__prci_init_clocks_fu540), -}; - -#endif /* __SIFIVE_CLK_FU540_PRCI_H */ diff --git a/drivers/clk/sifive/fu740-prci.c b/drivers/clk/sifive/fu740-prci.c index 5edc864e4bd..4274b215d2f 100644 --- a/drivers/clk/sifive/fu740-prci.c +++ b/drivers/clk/sifive/fu740-prci.c @@ -102,7 +102,7 @@ static const struct __prci_clock_ops sifive_fu740_prci_pcieaux_clk_ops = { };
/* List of clock controls provided by the PRCI */ -struct __prci_clock __prci_init_clocks_fu740[] = { +static struct __prci_clock __prci_init_clocks_fu740[] = { [FU740_PRCI_CLK_COREPLL] = { .name = "corepll", .parent_name = "hfclk", @@ -156,3 +156,8 @@ struct __prci_clock __prci_init_clocks_fu740[] = { .pwd = &__prci_pcieaux_data, } }; + +const struct prci_clk_desc prci_clk_fu740 = { + .clks = __prci_init_clocks_fu740, + .num_clks = ARRAY_SIZE(__prci_init_clocks_fu740), +}; diff --git a/drivers/clk/sifive/fu740-prci.h b/drivers/clk/sifive/fu740-prci.h deleted file mode 100644 index b74f0789061..00000000000 --- a/drivers/clk/sifive/fu740-prci.h +++ /dev/null @@ -1,22 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * Copyright (C) 2020-2021 SiFive, Inc. - * Zong Li - * Pragnesh Patel - */ - -#ifndef __SIFIVE_CLK_FU740_PRCI_H -#define __SIFIVE_CLK_FU740_PRCI_H - -#include "sifive-prci.h" - -#define NUM_CLOCK_FU740 9 - -extern struct __prci_clock __prci_init_clocks_fu740[NUM_CLOCK_FU740]; - -static const struct prci_clk_desc prci_clk_fu740 = { - .clks = __prci_init_clocks_fu740, - .num_clks = ARRAY_SIZE(__prci_init_clocks_fu740), -}; - -#endif /* __SIFIVE_CLK_FU740_PRCI_H */ diff --git a/drivers/clk/sifive/sifive-prci.c b/drivers/clk/sifive/sifive-prci.c index c8fb6002907..603a176d06a 100644 --- a/drivers/clk/sifive/sifive-prci.c +++ b/drivers/clk/sifive/sifive-prci.c @@ -34,8 +34,7 @@ #include <linux/math64.h> #include <dt-bindings/clock/sifive-fu740-prci.h>
-#include "fu540-prci.h" -#include "fu740-prci.h" +#include "sifive-prci.h"
/* * Private functions diff --git a/drivers/clk/sifive/sifive-prci.h b/drivers/clk/sifive/sifive-prci.h index 5ce33d61846..b391698081d 100644 --- a/drivers/clk/sifive/sifive-prci.h +++ b/drivers/clk/sifive/sifive-prci.h @@ -320,4 +320,8 @@ unsigned long sifive_prci_hfpclkplldiv_recalc_rate(struct __prci_clock *pc,
int sifive_prci_clock_enable(struct __prci_clock *pc, bool enable);
+/* Clock driver data */ +extern const struct prci_clk_desc prci_clk_fu540; +extern const struct prci_clk_desc prci_clk_fu740; + #endif /* __SIFIVE_CLK_SIFIVE_PRCI_H */
- Copyright (C) 2020-2021 SiFive, Inc.
- Zong Li
- Pragnesh Patel
- Zong Li
- Pragnesh Patel
- Private functions
- #endif /* __SIFIVE_CLK_SIFIVE_PRCI_H */
How does this affect SPL size?
--Sean
Reviewed-by: Leo Yu-Chi Liang ycliang@andestech.com
Leo Liang
Sean Anderson
