[PATCH] common: spl: spl_fit.c: report an error on hash check fail
When the hash check fails on a loadable image, the SPL/TPL simply jump to the next one. This commit changes this behaviour, when the hash check fails on a loadable image, the function spl_load_simple_fit stops and report an error.
Signed-off-by: Philippe Reynes philippe.reynes@softathome.com --- common/spl/spl_fit.c | 7 +++++-- 1 file changed, 5 insertions(+), 2 deletions(-)
diff --git a/common/spl/spl_fit.c b/common/spl/spl_fit.c index 6418062b93..0de4a2b543 100644 --- a/common/spl/spl_fit.c +++ b/common/spl/spl_fit.c @@ -667,8 +667,11 @@ int spl_load_simple_fit(struct spl_image_info *spl_image,
ret = spl_load_fit_image(info, sector, fit, base_offset, node, &image_info); - if (ret < 0) - continue; + if (ret < 0) { + printf("%s: can't load image loadables index %d (ret = %d)\n", + __func__, index, ret); + return ret; + }
if (!spl_fit_image_get_os(fit, node, &os_type)) debug("Loadable is %s\n", genimg_get_os_name(os_type));
On Tue, 24 Nov 2020 at 08:15, Philippe Reynes philippe.reynes@softathome.com wrote:
This should have a test. We have sandbox SPL test support now so it should not be too hard.
Signed-off-by: Philippe Reynes philippe.reynes@softathome.com Reviewed-by: Simon Glass sjg@chromium.org
Philippe Reynes
