Re: [U-Boot] Quark compile errors
Hi Andy,
On Wed, May 20, 2015 at 6:00 PM, Andy Pont andy.pont@sdcsystems.com wrote:
Hello,
I am trying to create a configuration for the Silicon Motion Osprey board which is a Quark SoC and their SM750 graphics controller.
I have cloned the Intel Galileo files and changed them accordingly and have defined the options for the VBIOS for the graphics controller but when I try to compile I get the following build failure:
Can you post your full configuration here?
CC arch/x86/lib/bios.o arch/x86/lib/bios.c: In function bint_exception_handlerb: arch/x86/lib/bios.c:61: error: unknown field beaxb specified in initializer arch/x86/lib/bios.c:61: warning: missing braces around initializer arch/x86/lib/bios.c:61: warning: (near initialization for breg_info.<anonymous>b) arch/x86/lib/bios.c:62: error: unknown field becxb specified in initializer arch/x86/lib/bios.c:63: error: unknown field bedxb specified in initializer arch/x86/lib/bios.c:64: error: unknown field bebxb specified in initializer arch/x86/lib/bios.c:65: error: unknown field bespb specified in initializer arch/x86/lib/bios.c:66: error: unknown field bebpb specified in initializer arch/x86/lib/bios.c:67: error: unknown field besib specified in initializer arch/x86/lib/bios.c:68: error: unknown field bedib specified in initializer make[1]: *** [arch/x86/lib/bios.o] Error 1
Could you advise what setting I have missed that is causing this build issue or is it the case that the bios.c file is defined for x86 capabilities beyond those of Quark?
Also, if anyone can tell me what $TERM setting I need to get the rogue "b" characters to actually display bold/bright then that would be great too!
I am using xterm, not sure if this helps.
$ echo $TERM xterm
Regards, Bin
Hi Bin,
I have attached the autoconf.mk and U-Boot .config files. Hopefully they tell you what you need.
$ echo $TERM xterm
That is what I have too. I guess it might be down to the way SecureCRT is interpreting what it is being sent rather than the Linux machine itself.
Regards,
Andy.
Andy Pont
Bin Meng
