[U-Boot-Users] tsec ethernet link bug?
Hi
I'm using a 8548CDS board and I have a link plugged into eth1 (but not eth0). When I run u-boot, it thinks that eth0 is plugged in and keeps trying tftp on that port.
I think there is a little bug in the code - here is a diff. Basically priv->link inadvertently gets set to 1 when the timeout case breaks out of the while loop inside the routine mii_parse_sr().
Could somebody please confirm if they have seen this?
thanks.
diff --git a/drivers/tsec.c b/drivers/tsec.c index f860dae..06c25bc 100644 --- a/drivers/tsec.c +++ b/drivers/tsec.c @@ -363,7 +363,7 @@ uint mii_parse_sr(uint mii_reg, struct t if (i > PHY_AUTONEGOTIATE_TIMEOUT) { puts (" TIMEOUT !\n"); priv->link = 0; - break; + return 0; }
if ((i++ % 1000) == 0) {
sagarwal
