[U-Boot] Please pull u-boot-x86
Hi Tom,
The following changes since commit 3ea0520512089cffbe02b7d6eb645cdfddb09c5c:
disk: part_dos: Use the original allocation scheme for the SPL case (2017-10-05 10:45:33 -0400)
git://git.denx.de/u-boot-x86.git
for you to fetch changes up to 256df1e1c6664e94926affe9318faa8258c18582:
x86: edison: Bring minimal ACPI support to the board (2017-10-07 15:07:59 +0800)
---------------------------------------------------------------- Andy Shevchenko (2): x86: tangier: Enable ACPI support for Intel Tangier x86: edison: Bring minimal ACPI support to the board
Stefan Roese (3): x86: theadorable-x86-common: Add further pci hotplug cmdline parameters x86: theadorable-x86-common: Move "-generic" into kernel-ver variable x86: theadorable-x86-xxx_defconfig: Enable setexpr command
arch/x86/cpu/tangier/Makefile | 1 + arch/x86/cpu/tangier/acpi.c | 87 +++++++++++++++++++++++++++++++ arch/x86/include/asm/arch-tangier/acpi/global_nvs.asl | 16 ++++++ arch/x86/include/asm/arch-tangier/acpi/platform.asl | 31 +++++++++++ arch/x86/include/asm/arch-tangier/acpi/southcluster.asl | 298 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ arch/x86/include/asm/arch-tangier/global_nvs.h | 22 ++++++++ board/intel/edison/.gitignore | 3 ++ board/intel/edison/Kconfig | 6 +++ board/intel/edison/Makefile | 1 + board/intel/edison/dsdt.asl | 13 +++++ configs/theadorable-x86-conga-qa3-e3845-pcie-x4_defconfig | 1 - configs/theadorable-x86-conga-qa3-e3845_defconfig | 1 - configs/theadorable-x86-dfi-bt700_defconfig | 1 - include/configs/edison.h | 3 ++ include/configs/theadorable-x86-common.h | 11 ++-- 15 files changed, 487 insertions(+), 8 deletions(-) create mode 100644 arch/x86/cpu/tangier/acpi.c create mode 100644 arch/x86/include/asm/arch-tangier/acpi/global_nvs.asl create mode 100644 arch/x86/include/asm/arch-tangier/acpi/platform.asl create mode 100644 arch/x86/include/asm/arch-tangier/acpi/southcluster.asl create mode 100644 arch/x86/include/asm/arch-tangier/global_nvs.h create mode 100644 board/intel/edison/.gitignore create mode 100644 board/intel/edison/dsdt.asl
Regards, Bin
Hello Bing,
Edison?! Edison is dead (end), as I know it... The project is cancelled. Correct me if I am wrong!
Much more important INTEL U-Boot businesses are ATOM E3900/APL-I family and CORE-5 BDW-DE (possible also BDW-DE NS),
What about these?
Thank you, Zoran Stojsavljevic _______
On Sat, Oct 7, 2017 at 9:16 AM, Bin Meng bmeng.cn@gmail.com wrote:
Hi Tom,
The following changes since commit 3ea0520512089cffbe02b7d6eb645c dfddb09c5c:
arch/x86/cpu/tangier/Makefile | 1 + arch/x86/cpu/tangier/acpi.c | 87 +++++++++++++++++++++++++++++++ arch/x86/include/asm/arch-tangier/acpi/global_nvs.asl | 16 ++++++ arch/x86/include/asm/arch-tangier/acpi/platform.asl | 31 +++++++++++ arch/x86/include/asm/arch-tangier/acpi/southcluster.asl | 298 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ +++++++++++++++++++++++++++++++++++++++++++++ arch/x86/include/asm/arch-tangier/global_nvs.h | 22 ++++++++ board/intel/edison/.gitignore | 3 ++ board/intel/edison/Kconfig | 6 +++ board/intel/edison/Makefile | 1 + board/intel/edison/dsdt.asl | 13 +++++ configs/theadorable-x86-conga-qa3-e3845-pcie-x4_defconfig | 1 - configs/theadorable-x86-conga-qa3-e3845_defconfig | 1 - configs/theadorable-x86-dfi-bt700_defconfig | 1 - include/configs/edison.h | 3 ++ include/configs/theadorable-x86-common.h | 11 ++-- 15 files changed, 487 insertions(+), 8 deletions(-) create mode 100644 arch/x86/cpu/tangier/acpi.c create mode 100644 arch/x86/include/asm/arch-tangier/acpi/global_nvs.asl create mode 100644 arch/x86/include/asm/arch-tangier/acpi/platform.asl create mode 100644 arch/x86/include/asm/arch- tangier/acpi/southcluster.asl create mode 100644 arch/x86/include/asm/arch-tangier/global_nvs.h create mode 100644 board/intel/edison/.gitignore create mode 100644 board/intel/edison/dsdt.asl
Regards, Bin _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de https://lists.denx.de/listinfo/u-boot
Hi Zoran,
On Sat, Oct 7, 2017 at 3:31 PM, Zoran Stojsavljevic zoran.stojsavljevic@gmail.com wrote:
Hello Bing,
I don't know that story. Loop Andy in to comment. But my understanding is that these are pretty much Intel Tangier SoC related, and Edison is just a reference board.
What about these?
As I mentioned before, these are on my todo list. If you or anyone else would like to contribute, patches are always welcome!
Regards, Bin
On Sat, 2017-10-07 at 16:32 +0800, Bin Meng wrote:
+Cc: Ferry (he might be interested in this thread)
Some people don't think so, there are ones who like the board.
Actually, while working for Linux kernel at Intel I'm using that board on almost daily basis to do many tests which are not related strictly to Edison or even Tangier.
That's correct [1].
But be honest, don't you like the idea to have an example of the board, which was never designed to be ACPI compatible, actually to become one (as much as hardware and ACPI specification allow to, of course)?
Besides that I have started looking into Edison's stuff around spring time of 2015. You may see my progress here [2] (first article dated 27.03.2015, the chapter "6 What is working and what doesn't" shows progress of upstreaming). U-Boot was appeared on my radar when the stock one stopped working with vanilla kernels.
See above.
Thanks, Bin, for including me in the loop.
...and Merrifield as a platform, which had been used in some x86-based phones.
Edison is one of the Intel's IoT boards, but the only board from Intel MID family [3].
What about these?
I can't answer on this. Work on Edison stuff may be considered as my hobby project (I have never been a part of an official team which had done Edison).
[1]: https://communities.intel.com/docs/DOC-112093 [2]: https://edison.internet-share.com/wiki/Using_a_vanilla_Linux_kernel _with_Intel_Edison [3]: https://en.wikipedia.org/wiki/Mobile_Internet_device#Intel_MID_plat forms
On Sat, Oct 07, 2017 at 03:16:26PM +0800, Bin Meng wrote:
Hi Tom,
Andy Shevchenko
Bin Meng
Zoran Stojsavljevic
