[U-Boot] [PATCH 1/2] dm: i2c: Add a flag that need generate stop bit
Usually the i2c bus needs to write the address of the register before reading the internal register data of the device (ignoring the transmission of the slave address).
Generally, the stop signal is not needed before the register is read, but there is a special chip that needs this stop signal (such as pcf2127). However, in the current i2c general code, the dm_i2c_read api encapsulates two messages, the first time is to set the register address message, the second time is a message to read the register data, so that no stop signal is generated.
This patch uses the DM_I2C_CHIP_ADDR_STOP flag for specific i2c chips, so if the i2c slave requires a stop signal, chips driver can set this flag, then call the dm_i2c_write to set the register address (a stop signal is generated after this API call), then call dm_i2c_read to read the register data.
Signed-off-by: Chuanhua Han chuanhua.han@nxp.com --- Changes in v4: - Replace DM_I2C_CHIP_RD_NO_I2C_SETUP_OFFSET with DM_I2C_CHIP_ADDR_STOP.
Changes in v3: - Use the new flag DM_I2C_CHIP_RD_NO_I2C_SETUP_OFFSET
Changes in v2: - Split the original patch into 3 patches - Add detailed description information for each patch
drivers/i2c/i2c-uclass.c | 6 ++++-- include/i2c.h | 1 + 2 files changed, 5 insertions(+), 2 deletions(-)
diff --git a/drivers/i2c/i2c-uclass.c b/drivers/i2c/i2c-uclass.c index e47abf1833..9804b5e8c7 100644 --- a/drivers/i2c/i2c-uclass.c +++ b/drivers/i2c/i2c-uclass.c @@ -135,8 +135,10 @@ int dm_i2c_read(struct udevice *dev, uint offset, uint8_t *buffer, int len) if (chip->flags & DM_I2C_CHIP_RD_ADDRESS) return i2c_read_bytewise(dev, offset, buffer, len); ptr = msg; - if (!i2c_setup_offset(chip, offset, offset_buf, ptr)) - ptr++; + if (!(chip->flags & DM_I2C_CHIP_ADDR_STOP)) { + if (!i2c_setup_offset(chip, offset, offset_buf, ptr)) + ptr++; + }
if (len) { ptr->addr = chip->chip_addr; diff --git a/include/i2c.h b/include/i2c.h index a5c760c711..3123cbf280 100644 --- a/include/i2c.h +++ b/include/i2c.h @@ -28,6 +28,7 @@ enum dm_i2c_chip_flags { DM_I2C_CHIP_10BIT = 1 << 0, /* Use 10-bit addressing */ DM_I2C_CHIP_RD_ADDRESS = 1 << 1, /* Send address for each read byte */ DM_I2C_CHIP_WR_ADDRESS = 1 << 2, /* Send address for each write byte */ + DM_I2C_CHIP_ADDR_STOP = 1 << 3, /* Need generate stop bit */ };
struct udevice;
The previous pcf2127 RTC chip could not read and set the correct time. When reading the data of internal registers, the read address was the value of register plus 1. This is because this chip requires the host to send a stop signal after setting the register address and before reading the register data.
This patch sets the DM_I2C_CHIP_ADDR_STOP flag in order to generate a stop signal and fixes the bug of the original read and write time.
Signed-off-by: Biwen Li biwen.li@nxp.com Signed-off-by: Chuanhua Han chuanhua.han@nxp.com --- Changes in v4: - Replace DM_I2C_CHIP_RD_NO_I2C_SETUP_OFFSET with DM_I2C_CHIP_ADDR_STOP.
Changes in v3: - When the rtc time is obtained, the address of the set register is separated from the read data.
drivers/rtc/pcf2127.c | 20 ++++++++++++++------ 1 file changed, 14 insertions(+), 6 deletions(-)
diff --git a/drivers/rtc/pcf2127.c b/drivers/rtc/pcf2127.c index dcf0340b4d..65794b98e6 100644 --- a/drivers/rtc/pcf2127.c +++ b/drivers/rtc/pcf2127.c @@ -24,12 +24,9 @@
static int pcf2127_rtc_set(struct udevice *dev, const struct rtc_time *tm) { - uchar buf[8]; + uchar buf[7] = {0}; int i = 0, ret;
- /* start register address */ - buf[i++] = PCF2127_REG_SC; - /* hours, minutes and seconds */ buf[i++] = bin2bcd(tm->tm_sec); buf[i++] = bin2bcd(tm->tm_min); @@ -44,7 +41,7 @@ static int pcf2127_rtc_set(struct udevice *dev, const struct rtc_time *tm) buf[i++] = bin2bcd(tm->tm_year % 100);
/* write register's data */ - ret = dm_i2c_write(dev, PCF2127_REG_CTRL1, buf, sizeof(buf)); + ret = dm_i2c_write(dev, PCF2127_REG_SC, buf, i);
return ret; } @@ -54,9 +51,12 @@ static int pcf2127_rtc_get(struct udevice *dev, struct rtc_time *tm) int ret = 0; uchar buf[10] = { PCF2127_REG_CTRL1 };
- ret = dm_i2c_write(dev, PCF2127_REG_CTRL1, buf, 1); + /* Set the address of the start register to be read */ + ret = dm_i2c_write(dev, PCF2127_REG_CTRL1, NULL, 0); if (ret < 0) return ret; + + /* Read register's data */ ret = dm_i2c_read(dev, PCF2127_REG_CTRL1, buf, sizeof(buf)); if (ret < 0) return ret; @@ -90,6 +90,13 @@ static int pcf2127_rtc_reset(struct udevice *dev) return 0; }
+static int pcf2127_probe(struct udevice *dev) +{ + i2c_set_chip_flags(dev, DM_I2C_CHIP_ADDR_STOP); + + return 0; +} + static const struct rtc_ops pcf2127_rtc_ops = { .get = pcf2127_rtc_get, .set = pcf2127_rtc_set, @@ -104,6 +111,7 @@ static const struct udevice_id pcf2127_rtc_ids[] = { U_BOOT_DRIVER(rtc_pcf2127) = { .name = "rtc-pcf2127", .id = UCLASS_RTC, + .probe = pcf2127_probe, .of_match = pcf2127_rtc_ids, .ops = &pcf2127_rtc_ops, };
Hi Chuanhua,
Thank you for the patch. It now looks far more better than the previous versions.
It is not using generic flag and can be reused by other ICs with similar issues.
Let's wait for Heiko's opinion.
Reviewed-by: Lukasz Majewski lukma@denx.de
Changes in v4:
Changes in v3:
- uchar buf[8];
- uchar buf[7] = {0}; int i = 0, ret;
return ret;
- /* Set the address of the start register to be read */
- ret = dm_i2c_write(dev, PCF2127_REG_CTRL1, NULL, 0); if (ret < 0) return ret;
- /* Read register's data */ ret = dm_i2c_read(dev, PCF2127_REG_CTRL1, buf, sizeof(buf)); if (ret < 0) return ret;
- i2c_set_chip_flags(dev, DM_I2C_CHIP_ADDR_STOP);
- .probe = pcf2127_probe, .of_match = pcf2127_rtc_ids, .ops = &pcf2127_rtc_ops,
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-59 Fax: (+49)-8142-66989-80 Email: lukma@denx.de
Hello Lukasz,
Am 18.06.2019 um 10:06 schrieb Lukasz Majewski:
Hi Chuanhua,
Yep!
I already started a travis build, see:
https://travis-ci.org/hsdenx/u-boot-i2c/builds/547057368
Thanks for your comments!
bye, Heiko
Changes in v4:
Changes in v3:
- uchar buf[8];
return ret; }
- static const struct rtc_ops pcf2127_rtc_ops = { .get = pcf2127_rtc_get, .set = pcf2127_rtc_set,
- .probe = pcf2127_probe, .of_match = pcf2127_rtc_ids, .ops = &pcf2127_rtc_ops, };
Lukasz Majewski
+ Simon Glass
-----Original Message----- From: Lukasz Majewski lukma@denx.de Sent: 2019年6月18日 16:06 To: Chuanhua Han chuanhua.han@nxp.com Cc: hs@denx.de; sjg@chromium.org; Biwen Li biwen.li@nxp.com; u-boot@lists.denx.de Subject: [EXT] Re: [PATCH 2/2] rtc: pcf2127: Fixed bug with rtc settings and getting error time
Hi Chuanhua,
Changes in v4:
Changes in v3:
- uchar buf[8];
return ret;
+static int pcf2127_probe(struct udevice *dev) {
Lukasz Majewski
Changes in v4:
Changes in v3:
ptr++;
ptr++;
- DM_I2C_CHIP_ADDR_STOP = 1 << 3, /* Need generate stop bit */
struct udevice;
Lukasz Majewski
+ Simon Glass
-----Original Message----- From: Lukasz Majewski lukma@denx.de Sent: 2019年6月18日 16:07 To: Chuanhua Han chuanhua.han@nxp.com Cc: hs@denx.de; sjg@chromium.org; Biwen Li biwen.li@nxp.com; u-boot@lists.denx.de Subject: [EXT] Re: [PATCH 1/2] dm: i2c: Add a flag that need generate stop bit
Changes in v4:
Changes in v3:
ptr++;
ptr++;
struct udevice;
Lukasz Majewski
Hi Chuanhua,
On Sun, 23 Jun 2019 at 22:48, Chuanhua Han chuanhua.han@nxp.com wrote:
- Simon Glass
I already asked why you cannot use dm_i2c_xfer() to do what you want, but I did not see your response. Can you please send your response again here on this thread? The dm_i2c_xfer() function is designed to handle any sorts of quirk that are needed. I'd like to avoid quirks in the core code if possible.
If you really want to add a quirk, then I would like to put it behind a CONFIG_I2C_QUIRKS option, and use:
if (IS_ENABLED(CONFIG_I2C_QUIRKS) || !(chip->flags & DM_I2C_CHIP_ADDR_STOP)) { if (!i2c_setup_offset(chip, offset, offset_buf, ptr)) ptr++;
so we don't affect code size on other platforms. After all this feature is just for one broken chip and should not negatively affect everyone else that follows the spec correctly.
I am worried about all the SPL-affecting changing that add a few bytes here and there, but really add up.
But my first preference would be to use i2c_xfer() if possible.
-----Original Message----- From: Simon Glass sjg@chromium.org Sent: 2019年7月7日 1:17 To: Chuanhua Han chuanhua.han@nxp.com Cc: Lukasz Majewski lukma@denx.de; hs@denx.de; Biwen Li biwen.li@nxp.com; u-boot@lists.denx.de Subject: Re: [EXT] Re: [PATCH 1/2] dm: i2c: Add a flag that need generate stop bit
Caution: EXT Email
Hi Chuanhua,
- Simon Glass
OK,thanks,I will send next version!
Chuanhua Han
Heiko Schocher
Lukasz Majewski
