[U-Boot] [PATCH] ARM: arm1176: Define arch_cpu_init() at the SoC level
Commit 86c6326 "ARM: arm1176: enable instruction cache in arch_cpu_init()" defined arch_cpu_init() in a file that is shared across all arm1176 SoCs. tnetv107x already implemented this function, which caused linking to break. Move the new conflicting arch_cpu_init() into arm1176/bcm2835/init.c so that it doesn't conflict; grep indicates this function is usually defined at the SoC-level, not the CPU-level, at least for ARM.
Signed-off-by: Stephen Warren swarren@wwwdotorg.org --- arch/arm/cpu/arm1176/bcm2835/Makefile | 2 +- arch/arm/cpu/arm1176/bcm2835/init.c | 24 ++++++++++++++++++++++++ arch/arm/cpu/arm1176/cpu.c | 7 ------- 3 files changed, 25 insertions(+), 8 deletions(-) create mode 100644 arch/arm/cpu/arm1176/bcm2835/init.c
diff --git a/arch/arm/cpu/arm1176/bcm2835/Makefile b/arch/arm/cpu/arm1176/bcm2835/Makefile index 4ea6d6b..95da6a8 100644 --- a/arch/arm/cpu/arm1176/bcm2835/Makefile +++ b/arch/arm/cpu/arm1176/bcm2835/Makefile @@ -17,7 +17,7 @@ include $(TOPDIR)/config.mk LIB = $(obj)lib$(SOC).o
SOBJS := lowlevel_init.o -COBJS := reset.o timer.o +COBJS := init.o reset.o timer.o
SRCS := $(SOBJS:.o=.c) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) diff --git a/arch/arm/cpu/arm1176/bcm2835/init.c b/arch/arm/cpu/arm1176/bcm2835/init.c new file mode 100644 index 0000000..e90d3bb --- /dev/null +++ b/arch/arm/cpu/arm1176/bcm2835/init.c @@ -0,0 +1,24 @@ +/* + * (C) Copyright 2012 Stephen Warren + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * version 2 as published by the Free Software Foundation. + * + * This program is distributed in the hope that it will be useful, but + * WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <common.h> + +int arch_cpu_init(void) +{ + icache_enable(); + + return 0; +} diff --git a/arch/arm/cpu/arm1176/cpu.c b/arch/arm/cpu/arm1176/cpu.c index 532a90b..c0fd114 100644 --- a/arch/arm/cpu/arm1176/cpu.c +++ b/arch/arm/cpu/arm1176/cpu.c @@ -65,10 +65,3 @@ static void cache_flush (void) /* mem barrier to sync things */ asm ("mcr p15, 0, %0, c7, c10, 4": :"r" (0)); } - -int arch_cpu_init(void) -{ - icache_enable(); - - return 0; -}
Dear Stephen Warren,
Acked-by: Marek Vasut marex@denx.de
- (C) Copyright 2012 Stephen Warren
- project.
- modify it under the terms of the GNU General Public License
- version 2 as published by the Free Software Foundation.
- This program is distributed in the hope that it will be useful, but
- WITHOUT ANY WARRANTY; without even the implied warranty of
- icache_enable();
- icache_enable();
Best regards, Marek Vasut
Hi Albert, Tom,
On Sat, 1 Sep 2012 19:27:56 -0700 Stephen Warren swarren@wwwdotorg.org wrote:
Could you please apply this patch? It fixes the build error for tnetv107x_evm board. Currently MAKEALL doesn't build this board, but this [1] patch enables building it and it fails. Thanks!
Anatolij
On Tue, Sep 25, 2012 at 10:01:34PM +0200, Anatolij Gustschin wrote:
Hi Albert, Tom,
I know this could go through u-boot-arm, but to try and ease Albert's backlog, I've taken this for u-boot/master, thanks!
Anatolij Gustschin
Stephen Warren
