[U-Boot] [PATCH] fsl_pci_init_port end-point initialization is broken
commit 70ed869e broke fsl pcie end-point initialization. Returning 0 is not correct. The function must return the first free bus number for the next controller.
fsl_pci_init() must still be called and a bus allocated even if the controller is an end-point.
Signed-off-by: Ed Swarthout Ed.Swarthout@freescale.com ---
This fixes the current breakage, but I don't think adding another layer (fsl_pci_init_port) and parameter structure is all that helpful.
So now there is:
pci_init_board() -> fsl_pci_init_port() -> fsl_pci_init() -> pciauto_setup_device()
with even less flexibility on setting up the inbound and outbound windows.
drivers/pci/fsl_pci_init.c | 19 +++++-------------- 1 files changed, 5 insertions(+), 14 deletions(-)
diff --git a/drivers/pci/fsl_pci_init.c b/drivers/pci/fsl_pci_init.c index 8fbab68..db2cd4b 100644 --- a/drivers/pci/fsl_pci_init.c +++ b/drivers/pci/fsl_pci_init.c @@ -420,20 +420,6 @@ int fsl_pci_init_port(struct fsl_pci_info *pci_info,
pci = (ccsr_fsl_pci_t *) pci_info->regs;
- if (pcie_ep) { - volatile pit_t *pi = &pci->pit[2]; - - pci_setup_indirect(hose, (u32)&pci->cfg_addr, - (u32)&pci->cfg_data); - out_be32(&pi->pitar, 0); - out_be32(&pi->piwbar, 0); - out_be32(&pi->piwar, PIWAR_EN | PIWAR_LOCAL | - PIWAR_READ_SNOOP | PIWAR_WRITE_SNOOP | PIWAR_IWS_4K); - - fsl_pci_config_unlock(hose); - return 0; - } - /* on non-PCIe controllers we don't have pme_msg_det so this code * should do nothing since the read will return 0 */ @@ -464,6 +450,11 @@ int fsl_pci_init_port(struct fsl_pci_info *pci_info,
fsl_pci_init(hose, (u32)&pci->cfg_addr, (u32)&pci->cfg_data);
+ if (pcie_ep) { + fsl_pci_config_unlock(hose); + hose->last_busno = hose->first_busno; + } + printf(" PCIE%x on bus %02x - %02x\n", pci_info->pci_num, hose->first_busno, hose->last_busno);
From: u-boot-bounces@lists.denx.de [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Swarthout Edward L-SWARTHOU Sent: Monday, November 02, 2009 8:36 PM To: u-boot@lists.denx.de Cc: Swarthout Edward L-SWARTHOU Subject: [U-Boot] [PATCH] fsl_pci_init_port end-point initialization isbroken
Acked-by: Vivek Mahajan vivek.mahajan@freescale.com
So now there is:
applied w/update (reverted 70ed869e and used a standard way to determine PCI host vs agent/end-point.
- k
Ed Swarthout
Kumar Gala
Mahajan Vivek-B08308
