[PATCH] efi_loader: log function in image loader
Use log_err() for error messages. Replace debug() by EFI_PRINT().
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- lib/efi_loader/efi_image_loader.c | 44 +++++++++++++++---------------- 1 file changed, 22 insertions(+), 22 deletions(-)
diff --git a/lib/efi_loader/efi_image_loader.c b/lib/efi_loader/efi_image_loader.c index eea42cc204..da50fc31f1 100644 --- a/lib/efi_loader/efi_image_loader.c +++ b/lib/efi_loader/efi_image_loader.c @@ -7,9 +7,12 @@ * Copyright (c) 2016 Alexander Graf */
+#define LOG_CATEGORY LOGC_EFI + #include <common.h> #include <cpu_func.h> #include <efi_loader.h> +#include <log.h> #include <malloc.h> #include <pe.h> #include <sort.h> @@ -153,14 +156,14 @@ static efi_status_t efi_loader_relocate(const IMAGE_BASE_RELOCATION *rel, case IMAGE_REL_BASED_RISCV_LOW12S: /* We know that we're 4k aligned */ if (delta & 0xfff) { - printf("Unsupported reloc offset\n"); + log_err("Unsupported reloc offset\n"); return EFI_LOAD_ERROR; } break; #endif default: - printf("Unknown Relocation off %x type %x\n", - offset, type); + log_err("Unknown Relocation off %x type %x\n", + offset, type); return EFI_LOAD_ERROR; } relocs++; @@ -202,7 +205,7 @@ static void efi_set_code_and_data_type( loaded_image_info->image_data_type = EFI_RUNTIME_SERVICES_DATA; break; default: - printf("%s: invalid image type: %u\n", __func__, image_type); + log_err("invalid image type: %u\n", image_type); /* Let's assume it is an application */ loaded_image_info->image_code_type = EFI_LOADER_CODE; loaded_image_info->image_data_type = EFI_LOADER_DATA; @@ -499,7 +502,7 @@ static bool efi_image_authenticate(void *efi, size_t efi_size) size_t new_efi_size, auth_size; bool ret = false;
- debug("%s: Enter, %d\n", __func__, ret); + EFI_PRINT("%s: Enter, %d\n", __func__, ret);
if (!efi_secure_boot_enabled()) return true; @@ -645,14 +648,14 @@ static bool efi_image_authenticate(void *efi, size_t efi_size) break; }
- debug("Signature was not verified by "db"\n"); + EFI_PRINT("Signature was not verified by "db"\n");
if (efi_signature_lookup_digest(regs, db)) { ret = true; break; }
- debug("Image's digest was not found in "db" or "dbx"\n"); + EFI_PRINT("Image's digest was not found in "db" or "dbx"\n"); }
err: @@ -662,7 +665,7 @@ err: free(regs); free(new_efi);
- debug("%s: Exit, %d\n", __func__, ret); + EFI_PRINT("%s: Exit, %d\n", __func__, ret); return ret; } #else @@ -704,14 +707,14 @@ efi_status_t efi_load_pe(struct efi_loaded_image_obj *handle,
/* Sanity check for a file header */ if (efi_size < sizeof(*dos)) { - printf("%s: Truncated DOS Header\n", __func__); + log_err("Truncated DOS Header\n"); ret = EFI_LOAD_ERROR; goto err; }
dos = efi; if (dos->e_magic != IMAGE_DOS_SIGNATURE) { - printf("%s: Invalid DOS Signature\n", __func__); + log_err("Invalid DOS Signature\n"); ret = EFI_LOAD_ERROR; goto err; } @@ -722,14 +725,14 @@ efi_status_t efi_load_pe(struct efi_loaded_image_obj *handle, * of the 64bit header which is longer than the 32bit header. */ if (efi_size < dos->e_lfanew + sizeof(IMAGE_NT_HEADERS64)) { - printf("%s: Invalid offset for Extended Header\n", __func__); + log_err("Invalid offset for Extended Header\n"); ret = EFI_LOAD_ERROR; goto err; }
nt = (void *) ((char *)efi + dos->e_lfanew); if (nt->Signature != IMAGE_NT_SIGNATURE) { - printf("%s: Invalid NT Signature\n", __func__); + log_err("Invalid NT Signature\n"); ret = EFI_LOAD_ERROR; goto err; } @@ -741,8 +744,8 @@ efi_status_t efi_load_pe(struct efi_loaded_image_obj *handle, }
if (!supported) { - printf("%s: Machine type 0x%04x is not supported\n", - __func__, nt->FileHeader.Machine); + log_err("Machine type 0x%04x is not supported\n", + nt->FileHeader.Machine); ret = EFI_LOAD_ERROR; goto err; } @@ -753,8 +756,7 @@ efi_status_t efi_load_pe(struct efi_loaded_image_obj *handle,
if (efi_size < ((void *)sections + sizeof(sections[0]) * num_sections - efi)) { - printf("%s: Invalid number of sections: %d\n", - __func__, num_sections); + log_err("Invalid number of sections: %d\n", num_sections); ret = EFI_LOAD_ERROR; goto err; } @@ -782,8 +784,7 @@ efi_status_t efi_load_pe(struct efi_loaded_image_obj *handle, efi_reloc = efi_alloc(virt_size, loaded_image_info->image_code_type); if (!efi_reloc) { - printf("%s: Could not allocate %lu bytes\n", - __func__, virt_size); + log_err("Out of memory\n"); ret = EFI_OUT_OF_RESOURCES; goto err; } @@ -799,8 +800,7 @@ efi_status_t efi_load_pe(struct efi_loaded_image_obj *handle, efi_reloc = efi_alloc(virt_size, loaded_image_info->image_code_type); if (!efi_reloc) { - printf("%s: Could not allocate %lu bytes\n", - __func__, virt_size); + log_err("Out of memory\n"); ret = EFI_OUT_OF_RESOURCES; goto err; } @@ -809,8 +809,8 @@ efi_status_t efi_load_pe(struct efi_loaded_image_obj *handle, rel = efi_reloc + opt->DataDirectory[rel_idx].VirtualAddress; virt_size = ALIGN(virt_size, opt->SectionAlignment); } else { - printf("%s: Invalid optional header magic %x\n", __func__, - nt->OptionalHeader.Magic); + log_err("Invalid optional header magic %x\n", + nt->OptionalHeader.Magic); ret = EFI_LOAD_ERROR; goto err; } -- 2.20.1
