[PATCH 01/10] spl: Make use of CONFIG_IS_ENABLED(OS_BOOT) in SPL/TPL common code paths
When building a system that has both TPL and SPL_OS_BOOT, code which tests for CONFIG_SPL_OS_BOOT will be built and enabled in TPL, which is not correct. While there is no CONFIG_TPL_OS_BOOT symbol at this time (and likely will not ever be) we can use CONFIG_IS_ENABLED(OS_BOOT) in these common paths to ensure we only compile these parts in the SPL case.
Signed-off-by: Tom Rini trini@konsulko.com --- arch/arm/lib/spl.c | 2 +- common/spl/spl.c | 6 +++--- common/spl/spl_ext.c | 2 +- common/spl/spl_fat.c | 2 +- common/spl/spl_mmc.c | 2 +- common/spl/spl_nand.c | 2 +- common/spl/spl_nor.c | 2 +- common/spl/spl_sata.c | 2 +- common/spl/spl_spi.c | 4 ++-- common/spl/spl_ubi.c | 2 +- common/spl/spl_usb.c | 2 +- common/spl/spl_xip.c | 2 +- 12 files changed, 15 insertions(+), 15 deletions(-)
diff --git a/arch/arm/lib/spl.c b/arch/arm/lib/spl.c index 4f9b84ba3449..b13897495dae 100644 --- a/arch/arm/lib/spl.c +++ b/arch/arm/lib/spl.c @@ -50,7 +50,7 @@ void __weak board_init_f(ulong dummy) * This function jumps to an image with argument. Normally an FDT or ATAGS * image. */ -#ifdef CONFIG_SPL_OS_BOOT +#if CONFIG_IS_ENABLED(OS_BOOT) #ifdef CONFIG_ARM64 void __noreturn jump_to_image_linux(struct spl_image_info *spl_image) { diff --git a/common/spl/spl.c b/common/spl/spl.c index 0c08da06e8f6..8bf91b48caa2 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -87,7 +87,7 @@ __weak int dram_init_banksize(void) * 0 to not start u-boot * positive if u-boot should start */ -#ifdef CONFIG_SPL_OS_BOOT +#if CONFIG_IS_ENABLED(OS_BOOT) __weak int spl_start_uboot(void) { puts(SPL_TPL_PROMPT @@ -353,7 +353,7 @@ int spl_parse_image_header(struct spl_image_info *spl_image, panic("** no mkimage signature but raw image not supported"); #endif
-#ifdef CONFIG_SPL_OS_BOOT +#if CONFIG_IS_ENABLED(OS_BOOT) ulong start, end;
if (!bootz_setup((ulong)header, &start, &end)) { @@ -797,7 +797,7 @@ void board_init_r(gd_t *dummy1, ulong dummy2) spl_invoke_opensbi(&spl_image); break; #endif -#ifdef CONFIG_SPL_OS_BOOT +#if CONFIG_IS_ENABLED(OS_BOOT) case IH_OS_LINUX: debug("Jumping to Linux\n"); #if defined(CONFIG_SYS_SPL_ARGS_ADDR) diff --git a/common/spl/spl_ext.c b/common/spl/spl_ext.c index d73f06276215..6a28fe9bdb50 100644 --- a/common/spl/spl_ext.c +++ b/common/spl/spl_ext.c @@ -64,7 +64,7 @@ end: return err < 0; }
-#ifdef CONFIG_SPL_OS_BOOT +#if CONFIG_IS_ENABLED(OS_BOOT) int spl_load_image_ext_os(struct spl_image_info *spl_image, struct blk_desc *block_dev, int partition) { diff --git a/common/spl/spl_fat.c b/common/spl/spl_fat.c index c2eb097365ff..576c2e876adc 100644 --- a/common/spl/spl_fat.c +++ b/common/spl/spl_fat.c @@ -112,7 +112,7 @@ end: return (err <= 0); }
-#ifdef CONFIG_SPL_OS_BOOT +#if CONFIG_IS_ENABLED(OS_BOOT) int spl_load_image_fat_os(struct spl_image_info *spl_image, struct blk_desc *block_dev, int partition) { diff --git a/common/spl/spl_mmc.c b/common/spl/spl_mmc.c index d52f8a3eefe6..e1a7d25bd05a 100644 --- a/common/spl/spl_mmc.c +++ b/common/spl/spl_mmc.c @@ -218,7 +218,7 @@ static int mmc_load_image_raw_partition(struct spl_image_info *spl_image, } #endif
-#ifdef CONFIG_SPL_OS_BOOT +#if CONFIG_IS_ENABLED(OS_BOOT) static int mmc_load_image_raw_os(struct spl_image_info *spl_image, struct mmc *mmc) { diff --git a/common/spl/spl_nand.c b/common/spl/spl_nand.c index 59f4a84a36ac..8ae7d04fa634 100644 --- a/common/spl/spl_nand.c +++ b/common/spl/spl_nand.c @@ -121,7 +121,7 @@ static int spl_nand_load_image(struct spl_image_info *spl_image,
header = spl_get_load_buffer(0, sizeof(*header));
-#ifdef CONFIG_SPL_OS_BOOT +#if CONFIG_IS_ENABLED(OS_BOOT) if (!spl_start_uboot()) { /* * load parameter image diff --git a/common/spl/spl_nor.c b/common/spl/spl_nor.c index 5270401db034..68c12413fa68 100644 --- a/common/spl/spl_nor.c +++ b/common/spl/spl_nor.c @@ -35,7 +35,7 @@ static int spl_nor_load_image(struct spl_image_info *spl_image, */ spl_image->flags |= SPL_COPY_PAYLOAD_ONLY;
-#ifdef CONFIG_SPL_OS_BOOT +#if CONFIG_IS_ENABLED(OS_BOOT) if (!spl_start_uboot()) { /* * Load Linux from its location in NOR flash to its defined diff --git a/common/spl/spl_sata.c b/common/spl/spl_sata.c index 535a9219efa5..e9f6c5f050b4 100644 --- a/common/spl/spl_sata.c +++ b/common/spl/spl_sata.c @@ -88,7 +88,7 @@ static int spl_sata_load_image(struct spl_image_info *spl_image, return -ENODEV; }
-#ifdef CONFIG_SPL_OS_BOOT +#if CONFIG_IS_ENABLED(OS_BOOT) if (spl_start_uboot() || spl_load_image_fat_os(spl_image, stor_dev, CONFIG_SYS_SATA_FAT_BOOT_PARTITION)) diff --git a/common/spl/spl_spi.c b/common/spl/spl_spi.c index 46ee4058e766..4e20a23dea09 100644 --- a/common/spl/spl_spi.c +++ b/common/spl/spl_spi.c @@ -18,7 +18,7 @@ #include <asm/global_data.h> #include <dm/ofnode.h>
-#ifdef CONFIG_SPL_OS_BOOT +#if CONFIG_IS_ENABLED(OS_BOOT) /* * Load the kernel, check for a valid header we can parse, and if found load * the kernel and then device tree. @@ -107,7 +107,7 @@ static int spl_spi_load_image(struct spl_image_info *spl_image, payload_offs); }
-#ifdef CONFIG_SPL_OS_BOOT +#if CONFIG_IS_ENABLED(OS_BOOT) if (spl_start_uboot() || spi_load_image_os(spl_image, flash, header)) #endif { diff --git a/common/spl/spl_ubi.c b/common/spl/spl_ubi.c index de6a63bd2d45..2f2d74a02de1 100644 --- a/common/spl/spl_ubi.c +++ b/common/spl/spl_ubi.c @@ -45,7 +45,7 @@ int spl_ubi_load_image(struct spl_image_info *spl_image, info.leb_start = CONFIG_SPL_UBI_LEB_START; info.peb_count = CONFIG_SPL_UBI_MAX_PEBS - info.peb_offset;
-#ifdef CONFIG_SPL_OS_BOOT +#if CONFIG_IS_ENABLED(OS_BOOT) if (!spl_start_uboot()) { volumes[0].vol_id = CONFIG_SPL_UBI_LOAD_KERNEL_ID; volumes[0].load_addr = (void *)CONFIG_SYS_LOAD_ADDR; diff --git a/common/spl/spl_usb.c b/common/spl/spl_usb.c index 3648de349273..67d503026ca8 100644 --- a/common/spl/spl_usb.c +++ b/common/spl/spl_usb.c @@ -47,7 +47,7 @@ int spl_usb_load(struct spl_image_info *spl_image,
debug("boot mode - FAT\n");
-#ifdef CONFIG_SPL_OS_BOOT +#if CONFIG_IS_ENABLED(OS_BOOT) if (spl_start_uboot() || spl_load_image_fat_os(spl_image, stor_dev, partition)) #endif diff --git a/common/spl/spl_xip.c b/common/spl/spl_xip.c index 8ce0a09ef3f4..ba4af38a3eca 100644 --- a/common/spl/spl_xip.c +++ b/common/spl/spl_xip.c @@ -12,7 +12,7 @@ static int spl_xip(struct spl_image_info *spl_image, struct spl_boot_device *bootdev) { -#ifdef CONFIG_SPL_OS_BOOT +#if CONFIG_IS_ENABLED(OS_BOOT) if (!spl_start_uboot()) { spl_image->arg = (void *)CONFIG_SYS_FDT_BASE; spl_image->name = "Linux";
This converts the following to Kconfig: CONFIG_SYS_HZ
Signed-off-by: Tom Rini trini@konsulko.com --- arch/arm/include/asm/arch-stv0991/stv0991_gpt.h | 1 - include/configs/MCR3000.h | 2 -- include/configs/amcore.h | 2 -- include/configs/ap121.h | 1 - include/configs/ap143.h | 1 - include/configs/ap152.h | 1 - include/configs/ci20.h | 1 - include/configs/cl-som-imx7.h | 2 -- include/configs/colibri_imx7.h | 2 -- include/configs/colibri_vf.h | 2 -- include/configs/dart_6ul.h | 2 -- include/configs/display5.h | 1 - include/configs/gazerbeam.h | 1 - include/configs/imx6-engicam.h | 2 -- include/configs/imx6dl-mamoj.h | 2 -- include/configs/imx7-cm.h | 2 -- include/configs/kontron-sl-mx6ul.h | 2 -- include/configs/kontron-sl-mx8mm.h | 2 -- include/configs/liteboard.h | 1 - include/configs/ls1012a_common.h | 2 -- include/configs/ls1043aqds.h | 2 -- include/configs/ls1046aqds.h | 2 -- include/configs/meerkat96.h | 2 -- include/configs/mt7620.h | 1 - include/configs/mt7628.h | 1 - include/configs/mx6ul_14x14_evk.h | 2 -- include/configs/mx6ullevk.h | 2 -- include/configs/mx7dsabresd.h | 2 -- include/configs/mx7ulp_evk.h | 2 -- include/configs/mys_6ulx.h | 2 -- include/configs/npi_imx6ull.h | 2 -- include/configs/omapl138_lcdk.h | 1 - include/configs/pcl063.h | 2 -- include/configs/pcl063_ull.h | 2 -- include/configs/pico-imx6ul.h | 2 -- include/configs/pico-imx7d.h | 2 -- include/configs/qemu-arm.h | 1 - include/configs/s5p4418_nanopi2.h | 1 - include/configs/smegw01.h | 2 -- include/configs/somlabs_visionsom_6ull.h | 2 -- include/configs/synquacer.h | 1 - include/configs/tbs2910.h | 2 -- include/configs/tplink_wdr4300.h | 1 - include/configs/warp7.h | 2 -- include/configs/xpress.h | 2 -- 45 files changed, 75 deletions(-)
diff --git a/arch/arm/include/asm/arch-stv0991/stv0991_gpt.h b/arch/arm/include/asm/arch-stv0991/stv0991_gpt.h index f1d5667c32bf..5b12d90d5859 100644 --- a/arch/arm/include/asm/arch-stv0991/stv0991_gpt.h +++ b/arch/arm/include/asm/arch-stv0991/stv0991_gpt.h @@ -36,7 +36,6 @@ struct gpt_regs *const gpt1_regs_ptr = #define GPT_FREE_RUNNING 0xFFFF
/* Timer, HZ specific defines */ -#define CONFIG_SYS_HZ 1000 #define CONFIG_SYS_HZ_CLOCK ((27 * 1000 * 1000) / GPT_PRESCALER_128)
#endif diff --git a/include/configs/MCR3000.h b/include/configs/MCR3000.h index 73858c56e515..bfb092ab170a 100644 --- a/include/configs/MCR3000.h +++ b/include/configs/MCR3000.h @@ -60,8 +60,6 @@
/* Miscellaneous configurable options */
-#define CONFIG_SYS_HZ 1000 - /* Definitions for initial stack pointer and data area (in DPRAM) */ #define CONFIG_SYS_INIT_RAM_ADDR (CONFIG_SYS_IMMR + 0x2800) #define CONFIG_SYS_INIT_RAM_SIZE (0x2e00 - 0x2800) diff --git a/include/configs/amcore.h b/include/configs/amcore.h index 98ad047bc4cd..ee2df6c6cf63 100644 --- a/include/configs/amcore.h +++ b/include/configs/amcore.h @@ -27,8 +27,6 @@ "erase 0xfff00000 0xffffffff; " \ "cp.b 0x20000 0xfff00000 ${filesize}\0"
-#define CONFIG_SYS_HZ 1000 - #define CONFIG_SYS_CLK 45000000 #define CONFIG_SYS_CPU_CLK (CONFIG_SYS_CLK * 2) /* Register Base Addrs */ diff --git a/include/configs/ap121.h b/include/configs/ap121.h index f3fc53ba484f..e23a7dc49565 100644 --- a/include/configs/ap121.h +++ b/include/configs/ap121.h @@ -6,7 +6,6 @@ #ifndef __CONFIG_H #define __CONFIG_H
-#define CONFIG_SYS_HZ 1000 #define CONFIG_SYS_MHZ 200 #define CONFIG_SYS_MIPS_TIMER_FREQ (CONFIG_SYS_MHZ * 1000000)
diff --git a/include/configs/ap143.h b/include/configs/ap143.h index fa13a801b771..80b64da93ff5 100644 --- a/include/configs/ap143.h +++ b/include/configs/ap143.h @@ -6,7 +6,6 @@ #ifndef __CONFIG_H #define __CONFIG_H
-#define CONFIG_SYS_HZ 1000 #define CONFIG_SYS_MHZ 325 #define CONFIG_SYS_MIPS_TIMER_FREQ (CONFIG_SYS_MHZ * 1000000)
diff --git a/include/configs/ap152.h b/include/configs/ap152.h index 3eaf19283bba..762cc67aa6c7 100644 --- a/include/configs/ap152.h +++ b/include/configs/ap152.h @@ -6,7 +6,6 @@ #ifndef __CONFIG_H #define __CONFIG_H
-#define CONFIG_SYS_HZ 1000 #define CONFIG_SYS_MHZ 375 #define CONFIG_SYS_MIPS_TIMER_FREQ (CONFIG_SYS_MHZ * 1000000)
diff --git a/include/configs/ci20.h b/include/configs/ci20.h index 1d4503ba5312..cefc8157216d 100644 --- a/include/configs/ci20.h +++ b/include/configs/ci20.h @@ -10,7 +10,6 @@ #define __CONFIG_CI20_H__
/* Ingenic JZ4780 clock configuration. */ -#define CONFIG_SYS_HZ 1000 #define CONFIG_SYS_MHZ 1200 #define CONFIG_SYS_MIPS_TIMER_FREQ (CONFIG_SYS_MHZ * 1000000)
diff --git a/include/configs/cl-som-imx7.h b/include/configs/cl-som-imx7.h index ebfe356eee0d..fe72bfd95cb9 100644 --- a/include/configs/cl-som-imx7.h +++ b/include/configs/cl-som-imx7.h @@ -92,8 +92,6 @@ "echo eMMC boot attempt ...; run emmcbootscript; run emmcboot; " \ "echo USB boot attempt ...; run usbbootscript; "
-#define CONFIG_SYS_HZ 1000 - /* Physical Memory Map */ #define PHYS_SDRAM MMDC0_ARB_BASE_ADDR
diff --git a/include/configs/colibri_imx7.h b/include/configs/colibri_imx7.h index 344b266db9e6..ac188ee3ac65 100644 --- a/include/configs/colibri_imx7.h +++ b/include/configs/colibri_imx7.h @@ -170,8 +170,6 @@
diff --git a/include/configs/colibri_vf.h b/include/configs/colibri_vf.h index 25a772914a27..71fe768d6792 100644 --- a/include/configs/colibri_vf.h +++ b/include/configs/colibri_vf.h @@ -110,8 +110,6 @@ #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE
-#define CONFIG_SYS_HZ 1000 - /* Physical memory map */ #define PHYS_SDRAM (0x80000000) #define PHYS_SDRAM_SIZE (256 * SZ_1M) diff --git a/include/configs/dart_6ul.h b/include/configs/dart_6ul.h index 6f861a099862..3080ae7cae4f 100644 --- a/include/configs/dart_6ul.h +++ b/include/configs/dart_6ul.h @@ -47,8 +47,6 @@
-#define CONFIG_SYS_HZ 1000 - /* Physical Memory Map */ #define PHYS_SDRAM MMDC0_ARB_BASE_ADDR #define PHYS_SDRAM_SIZE SZ_512M diff --git a/include/configs/display5.h b/include/configs/display5.h index 27854dfdf1e2..329a60f1d206 100644 --- a/include/configs/display5.h +++ b/include/configs/display5.h @@ -312,7 +312,6 @@ #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE
#define CONFIG_STANDALONE_LOAD_ADDR 0x10001000 -#define CONFIG_SYS_HZ 1000
/* Physical Memory Map */ #define PHYS_SDRAM MMDC0_ARB_BASE_ADDR diff --git a/include/configs/gazerbeam.h b/include/configs/gazerbeam.h index 12d108d6d6d7..ec5fc1569652 100644 --- a/include/configs/gazerbeam.h +++ b/include/configs/gazerbeam.h @@ -59,7 +59,6 @@ /* * Miscellaneous configurable options */ -#define CONFIG_SYS_HZ 1000 /* decrementer freq: 1ms ticks */
diff --git a/include/configs/imx6-engicam.h b/include/configs/imx6-engicam.h index 9af0a0404031..238d61549cf4 100644 --- a/include/configs/imx6-engicam.h +++ b/include/configs/imx6-engicam.h @@ -100,8 +100,6 @@
-#define CONFIG_SYS_HZ 1000 - #ifdef CONFIG_MX6UL # define DRAM_OFFSET(x) 0x87##x # define FDT_ADDR __stringify(DRAM_OFFSET(800000)) diff --git a/include/configs/imx6dl-mamoj.h b/include/configs/imx6dl-mamoj.h index 367f78d125d4..24f9ccc0de35 100644 --- a/include/configs/imx6dl-mamoj.h +++ b/include/configs/imx6dl-mamoj.h @@ -62,8 +62,6 @@
diff --git a/include/configs/imx7-cm.h b/include/configs/imx7-cm.h index 4d4c94b74eaa..553c7fe2ea95 100644 --- a/include/configs/imx7-cm.h +++ b/include/configs/imx7-cm.h @@ -72,8 +72,6 @@
#define CONFIG_BOOTCOMMAND "run boot${boot-mode}"
diff --git a/include/configs/kontron-sl-mx6ul.h b/include/configs/kontron-sl-mx6ul.h index 65aa25089426..34304f910285 100644 --- a/include/configs/kontron-sl-mx6ul.h +++ b/include/configs/kontron-sl-mx6ul.h @@ -22,8 +22,6 @@ #define CONFIG_SYS_INIT_RAM_ADDR IRAM_BASE_ADDR #define CONFIG_SYS_INIT_RAM_SIZE IRAM_SIZE
-#define CONFIG_SYS_HZ 1000 - #define CONFIG_SYS_INIT_SP_OFFSET \ (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_ADDR \ diff --git a/include/configs/kontron-sl-mx8mm.h b/include/configs/kontron-sl-mx8mm.h index 0d9ab3b75585..52aa4473a2fd 100644 --- a/include/configs/kontron-sl-mx8mm.h +++ b/include/configs/kontron-sl-mx8mm.h @@ -22,8 +22,6 @@ #define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 #define CONFIG_SYS_INIT_RAM_SIZE 0x200000
-#define CONFIG_SYS_HZ 1000 - #define CONFIG_SYS_INIT_SP_OFFSET \ (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_ADDR \ diff --git a/include/configs/liteboard.h b/include/configs/liteboard.h index dc6f15a2a228..b2f5134fc5c6 100644 --- a/include/configs/liteboard.h +++ b/include/configs/liteboard.h @@ -101,7 +101,6 @@ "else run netboot; fi"
/* Miscellaneous configurable options */ -#define CONFIG_SYS_HZ 1000
/* Physical Memory Map */ #define PHYS_SDRAM MMDC0_ARB_BASE_ADDR diff --git a/include/configs/ls1012a_common.h b/include/configs/ls1012a_common.h index 8a49f2d0075d..d072eaab8716 100644 --- a/include/configs/ls1012a_common.h +++ b/include/configs/ls1012a_common.h @@ -59,8 +59,6 @@ #define CONFIG_SYS_NS16550_REG_SIZE 1 #define CONFIG_SYS_NS16550_CLK (get_serial_clock())
-#define CONFIG_SYS_HZ 1000 - #define CONFIG_HWCONFIG #define HWCONFIG_BUFFER_SIZE 128
diff --git a/include/configs/ls1043aqds.h b/include/configs/ls1043aqds.h index 1d15f2fc5853..ee5660571e54 100644 --- a/include/configs/ls1043aqds.h +++ b/include/configs/ls1043aqds.h @@ -344,8 +344,6 @@ unsigned long get_board_sys_clk(void); * Miscellaneous configurable options */
diff --git a/include/configs/ls1046aqds.h b/include/configs/ls1046aqds.h index 2e3824041c9b..987df5f6e5c0 100644 --- a/include/configs/ls1046aqds.h +++ b/include/configs/ls1046aqds.h @@ -360,8 +360,6 @@ unsigned long get_board_sys_clk(void); * Miscellaneous configurable options */
diff --git a/include/configs/meerkat96.h b/include/configs/meerkat96.h index ac9a75bf2dea..ab8fa85f25eb 100644 --- a/include/configs/meerkat96.h +++ b/include/configs/meerkat96.h @@ -14,8 +14,6 @@
diff --git a/include/configs/mt7620.h b/include/configs/mt7620.h index a2de03429218..5a8862775bd6 100644 --- a/include/configs/mt7620.h +++ b/include/configs/mt7620.h @@ -8,7 +8,6 @@ #ifndef __CONFIG_MT7620_H #define __CONFIG_MT7620_H
-#define CONFIG_SYS_HZ 1000 #define CONFIG_SYS_MIPS_TIMER_FREQ 290000000
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE diff --git a/include/configs/mt7628.h b/include/configs/mt7628.h index e53e6a0d0a0e..8c4455b9fe13 100644 --- a/include/configs/mt7628.h +++ b/include/configs/mt7628.h @@ -8,7 +8,6 @@ #ifndef __CONFIG_MT7628_H #define __CONFIG_MT7628_H
#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE diff --git a/include/configs/mx6ul_14x14_evk.h b/include/configs/mx6ul_14x14_evk.h index 9ddb47910f3c..0b777fbbdc09 100644 --- a/include/configs/mx6ul_14x14_evk.h +++ b/include/configs/mx6ul_14x14_evk.h @@ -124,8 +124,6 @@
diff --git a/include/configs/mx6ullevk.h b/include/configs/mx6ullevk.h index 247d5e1bcc3a..e384d2a26962 100644 --- a/include/configs/mx6ullevk.h +++ b/include/configs/mx6ullevk.h @@ -121,8 +121,6 @@
diff --git a/include/configs/mx7dsabresd.h b/include/configs/mx7dsabresd.h index 92ce741768d6..f11e2e3f807f 100644 --- a/include/configs/mx7dsabresd.h +++ b/include/configs/mx7dsabresd.h @@ -87,8 +87,6 @@
#include <config_distro_bootcmd.h>
diff --git a/include/configs/mx7ulp_evk.h b/include/configs/mx7ulp_evk.h index 567a037089d7..6d7f09e2885e 100644 --- a/include/configs/mx7ulp_evk.h +++ b/include/configs/mx7ulp_evk.h @@ -112,8 +112,6 @@ "fi; " \ "fi"
-#define CONFIG_SYS_HZ 1000 - #define CONFIG_SYS_INIT_RAM_ADDR IRAM_BASE_ADDR #define CONFIG_SYS_INIT_RAM_SIZE SZ_256K
diff --git a/include/configs/mys_6ulx.h b/include/configs/mys_6ulx.h index 04c9879ccca5..6801fc109eae 100644 --- a/include/configs/mys_6ulx.h +++ b/include/configs/mys_6ulx.h @@ -21,8 +21,6 @@ /* MMC Configs */ #define CONFIG_SYS_FSL_ESDHC_ADDR USDHC2_BASE_ADDR
-#define CONFIG_SYS_HZ 1000 - /* Physical Memory Map */ #define PHYS_SDRAM MMDC0_ARB_BASE_ADDR #define PHYS_SDRAM_SIZE SZ_256M diff --git a/include/configs/npi_imx6ull.h b/include/configs/npi_imx6ull.h index 70e2898c1450..a10607ff66fc 100644 --- a/include/configs/npi_imx6ull.h +++ b/include/configs/npi_imx6ull.h @@ -23,8 +23,6 @@
#define CONFIG_NETMASK 255.255.255.0
diff --git a/include/configs/omapl138_lcdk.h b/include/configs/omapl138_lcdk.h index 4227610566dc..f2352d821616 100644 --- a/include/configs/omapl138_lcdk.h +++ b/include/configs/omapl138_lcdk.h @@ -21,7 +21,6 @@ #define CONFIG_SYS_OSCIN_FREQ 24000000 #define CONFIG_SYS_TIMERBASE DAVINCI_TIMER0_BASE #define CONFIG_SYS_HZ_CLOCK clk_get(DAVINCI_AUXCLK_CLKID) -#define CONFIG_SYS_HZ 1000
/* * Memory Info diff --git a/include/configs/pcl063.h b/include/configs/pcl063.h index f29f6dc5857e..31b7d07a24cd 100644 --- a/include/configs/pcl063.h +++ b/include/configs/pcl063.h @@ -33,8 +33,6 @@
-#define CONFIG_SYS_HZ 1000 - /* Physical Memory Map */ #define PHYS_SDRAM MMDC0_ARB_BASE_ADDR #define PHYS_SDRAM_SIZE SZ_256M diff --git a/include/configs/pcl063_ull.h b/include/configs/pcl063_ull.h index c1da1a011946..20ba3f192b04 100644 --- a/include/configs/pcl063_ull.h +++ b/include/configs/pcl063_ull.h @@ -36,8 +36,6 @@
-#define CONFIG_SYS_HZ 1000 - /* Physical Memory Map */ #define PHYS_SDRAM MMDC0_ARB_BASE_ADDR #define PHYS_SDRAM_SIZE SZ_256M diff --git a/include/configs/pico-imx6ul.h b/include/configs/pico-imx6ul.h index 6fed7522bddd..250e7747e7b5 100644 --- a/include/configs/pico-imx6ul.h +++ b/include/configs/pico-imx6ul.h @@ -108,8 +108,6 @@ #include <config_distro_bootcmd.h> #include <linux/stringify.h>
diff --git a/include/configs/pico-imx7d.h b/include/configs/pico-imx7d.h index c0464278b987..cbac95054923 100644 --- a/include/configs/pico-imx7d.h +++ b/include/configs/pico-imx7d.h @@ -107,8 +107,6 @@ #include <config_distro_bootcmd.h> #include <linux/stringify.h>
diff --git a/include/configs/qemu-arm.h b/include/configs/qemu-arm.h index bb4240a12848..1287fd167156 100644 --- a/include/configs/qemu-arm.h +++ b/include/configs/qemu-arm.h @@ -18,7 +18,6 @@ #define CONFIG_SYS_BOOTM_LEN SZ_64M
/* For timer, QEMU emulates an ARMv7/ARMv8 architected timer */ -#define CONFIG_SYS_HZ 1000
/* Environment options */
diff --git a/include/configs/s5p4418_nanopi2.h b/include/configs/s5p4418_nanopi2.h index 21feba0569e4..f49f5faa7f12 100644 --- a/include/configs/s5p4418_nanopi2.h +++ b/include/configs/s5p4418_nanopi2.h @@ -72,7 +72,6 @@ /* Not used: not need IRQ/FIQ stuff */ #undef CONFIG_USE_IRQ /* decrementer freq: 1ms ticks */ -#define CONFIG_SYS_HZ 1000
/*----------------------------------------------------------------------- * System initialize options (board_init_f) diff --git a/include/configs/smegw01.h b/include/configs/smegw01.h index 55ca80198511..bbdd42b1afb8 100644 --- a/include/configs/smegw01.h +++ b/include/configs/smegw01.h @@ -41,8 +41,6 @@ "run mmcboot; " \ "fi; " \
diff --git a/include/configs/somlabs_visionsom_6ull.h b/include/configs/somlabs_visionsom_6ull.h index 6af908afe6a7..a153c13a7ce6 100644 --- a/include/configs/somlabs_visionsom_6ull.h +++ b/include/configs/somlabs_visionsom_6ull.h @@ -68,8 +68,6 @@
diff --git a/include/configs/synquacer.h b/include/configs/synquacer.h index 13e9c64387ed..aac7b5dc3877 100644 --- a/include/configs/synquacer.h +++ b/include/configs/synquacer.h @@ -6,7 +6,6 @@ #define __CONFIG_H
/* Timers for fasp(TIMCLK) */ -#define CONFIG_SYS_HZ 1000 /* 1 msec */ #define CONFIG_SYS_TIMERBASE 0x31080000 /* AP Timer 1 (ARM-SP804) */
/* diff --git a/include/configs/tbs2910.h b/include/configs/tbs2910.h index 0438b5ae0c6d..58ccafc385ad 100644 --- a/include/configs/tbs2910.h +++ b/include/configs/tbs2910.h @@ -12,8 +12,6 @@
/* General configuration */
-#define CONFIG_SYS_HZ 1000 - /* Physical Memory Map */ #define CONFIG_SYS_SDRAM_BASE MMDC0_ARB_BASE_ADDR
diff --git a/include/configs/tplink_wdr4300.h b/include/configs/tplink_wdr4300.h index 3e76d638c99e..e6dc9f17fed6 100644 --- a/include/configs/tplink_wdr4300.h +++ b/include/configs/tplink_wdr4300.h @@ -6,7 +6,6 @@ #ifndef __CONFIG_H #define __CONFIG_H
-#define CONFIG_SYS_HZ 1000 #define CONFIG_SYS_MHZ 280 #define CONFIG_SYS_MIPS_TIMER_FREQ (CONFIG_SYS_MHZ * 1000000)
diff --git a/include/configs/warp7.h b/include/configs/warp7.h index 74fb988b7651..00031d87c120 100644 --- a/include/configs/warp7.h +++ b/include/configs/warp7.h @@ -96,8 +96,6 @@ "fi; " \ "fi"
diff --git a/include/configs/xpress.h b/include/configs/xpress.h index 1e2b6c09543e..51fee4406850 100644 --- a/include/configs/xpress.h +++ b/include/configs/xpress.h @@ -20,8 +20,6 @@
-#define CONFIG_SYS_HZ 1000 - /* Physical Memory Map */ #define PHYS_SDRAM MMDC0_ARB_BASE_ADDR #define PHYS_SDRAM_SIZE (128 << 20)
This converts the following to Kconfig: CONFIG_SYS_TEXT_BASE
Signed-off-by: Tom Rini trini@konsulko.com --- include/configs/bcm7260.h | 1 - include/configs/bcm7445.h | 1 - 2 files changed, 2 deletions(-)
diff --git a/include/configs/bcm7260.h b/include/configs/bcm7260.h index d799ffd066e8..1bae49e15f35 100644 --- a/include/configs/bcm7260.h +++ b/include/configs/bcm7260.h @@ -12,7 +12,6 @@
#define CONFIG_SYS_NS16550_COM1 0xf040c000
-#define CONFIG_SYS_TEXT_BASE 0x10100000 #define CONFIG_SYS_INIT_RAM_ADDR 0x10200000
#include "bcmstb.h" diff --git a/include/configs/bcm7445.h b/include/configs/bcm7445.h index 989482ef35a6..81c3d02c6be9 100644 --- a/include/configs/bcm7445.h +++ b/include/configs/bcm7445.h @@ -12,7 +12,6 @@
#define CONFIG_SYS_NS16550_COM1 0xf040ab00
-#define CONFIG_SYS_TEXT_BASE 0x80100000 #define CONFIG_SYS_INIT_RAM_ADDR 0x80200000
#include "bcmstb.h"
This converts the following to Kconfig: CONFIG_SUPPORT_EMMC_BOOT
Signed-off-by: Tom Rini trini@konsulko.com --- configs/apalis-imx8_defconfig | 1 + configs/apalis-imx8x_defconfig | 1 + configs/bcm_ns3_defconfig | 1 + configs/cgtqmx8_defconfig | 1 + configs/colibri-imx8x_defconfig | 1 + configs/imx8qm_mek_defconfig | 1 + configs/imx8qm_rom7720_a1_4G_defconfig | 1 + configs/octeontx2_95xx_defconfig | 1 + configs/octeontx2_96xx_defconfig | 1 + configs/octeontx_81xx_defconfig | 1 + configs/octeontx_83xx_defconfig | 1 + configs/phycore_pcl063_ull_defconfig | 1 + configs/pico-imx6_defconfig | 1 + configs/variscite_dart6ul_defconfig | 1 + include/configs/apalis-imx8.h | 1 - include/configs/apalis-imx8x.h | 1 - include/configs/bcm_ns3.h | 1 - include/configs/cgtqmx8.h | 1 - include/configs/colibri-imx8x.h | 1 - include/configs/dart_6ul.h | 1 - include/configs/imx8qm_mek.h | 1 - include/configs/imx8qm_rom7720.h | 2 -- include/configs/octeontx2_common.h | 1 - include/configs/octeontx_common.h | 1 - include/configs/pcl063_ull.h | 1 - include/configs/pico-imx6.h | 1 - 26 files changed, 14 insertions(+), 13 deletions(-)
diff --git a/configs/apalis-imx8_defconfig b/configs/apalis-imx8_defconfig index 2c5d6925a03e..a92204a9f95a 100644 --- a/configs/apalis-imx8_defconfig +++ b/configs/apalis-imx8_defconfig @@ -46,6 +46,7 @@ CONFIG_MXC_GPIO=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_IMX_LPI2C=y CONFIG_MISC=y +CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y CONFIG_PHY_ADDR_ENABLE=y diff --git a/configs/apalis-imx8x_defconfig b/configs/apalis-imx8x_defconfig index 4ad6f7fd07a2..98ea33aada71 100644 --- a/configs/apalis-imx8x_defconfig +++ b/configs/apalis-imx8x_defconfig @@ -53,6 +53,7 @@ CONFIG_SYS_I2C_IMX_LPI2C=y CONFIG_I2C_MUX=y CONFIG_I2C_MUX_PCA954x=y CONFIG_MISC=y +CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y CONFIG_PHY_ADDR_ENABLE=y diff --git a/configs/bcm_ns3_defconfig b/configs/bcm_ns3_defconfig index 3fa24351c741..4b8d71ad0374 100644 --- a/configs/bcm_ns3_defconfig +++ b/configs/bcm_ns3_defconfig @@ -36,6 +36,7 @@ CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_CLK=y CONFIG_CLK_CCF=y +CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_SDMA=y CONFIG_MMC_SDHCI_IPROC=y diff --git a/configs/cgtqmx8_defconfig b/configs/cgtqmx8_defconfig index c7dac3b6053a..4abe29e1d229 100644 --- a/configs/cgtqmx8_defconfig +++ b/configs/cgtqmx8_defconfig @@ -58,6 +58,7 @@ CONFIG_SYS_I2C_IMX_LPI2C=y CONFIG_I2C_MUX=y CONFIG_I2C_MUX_PCA954x=y CONFIG_MISC=y +CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y CONFIG_PHY_ADDR_ENABLE=y diff --git a/configs/colibri-imx8x_defconfig b/configs/colibri-imx8x_defconfig index d9c1e4d61650..ea0679602647 100644 --- a/configs/colibri-imx8x_defconfig +++ b/configs/colibri-imx8x_defconfig @@ -44,6 +44,7 @@ CONFIG_MXC_GPIO=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_IMX_LPI2C=y CONFIG_MISC=y +CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y CONFIG_PHY_ADDR_ENABLE=y diff --git a/configs/imx8qm_mek_defconfig b/configs/imx8qm_mek_defconfig index 01ba6cffb916..c264694e84bf 100644 --- a/configs/imx8qm_mek_defconfig +++ b/configs/imx8qm_mek_defconfig @@ -62,6 +62,7 @@ CONFIG_SYS_I2C_IMX_LPI2C=y CONFIG_I2C_MUX=y CONFIG_I2C_MUX_PCA954x=y CONFIG_MISC=y +CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y CONFIG_PHY_ADDR_ENABLE=y diff --git a/configs/imx8qm_rom7720_a1_4G_defconfig b/configs/imx8qm_rom7720_a1_4G_defconfig index bf7b1f134d48..5c86fb802865 100644 --- a/configs/imx8qm_rom7720_a1_4G_defconfig +++ b/configs/imx8qm_rom7720_a1_4G_defconfig @@ -59,6 +59,7 @@ CONFIG_SYS_I2C_IMX_LPI2C=y CONFIG_I2C_MUX=y CONFIG_I2C_MUX_PCA954x=y CONFIG_MISC=y +CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_FSL_ESDHC_IMX=y CONFIG_PHYLIB=y CONFIG_PHY_ADDR_ENABLE=y diff --git a/configs/octeontx2_95xx_defconfig b/configs/octeontx2_95xx_defconfig index 6d8457f1d070..6447c28c6d9d 100644 --- a/configs/octeontx2_95xx_defconfig +++ b/configs/octeontx2_95xx_defconfig @@ -77,6 +77,7 @@ CONFIG_NET_RANDOM_ETHADDR=y CONFIG_TFTP_TSIZE=y CONFIG_DM_I2C=y CONFIG_MISC=y +CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_MMC_HS400_SUPPORT=y CONFIG_MMC_OCTEONTX=y CONFIG_MTD=y diff --git a/configs/octeontx2_96xx_defconfig b/configs/octeontx2_96xx_defconfig index b72caef77d8f..75dcaa61ec93 100644 --- a/configs/octeontx2_96xx_defconfig +++ b/configs/octeontx2_96xx_defconfig @@ -83,6 +83,7 @@ CONFIG_I2C_SET_DEFAULT_BUS_NUM=y CONFIG_I2C_MUX=y CONFIG_I2C_MUX_PCA954x=y CONFIG_MISC=y +CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_MMC_HS400_SUPPORT=y CONFIG_MMC_OCTEONTX=y CONFIG_MTD=y diff --git a/configs/octeontx_81xx_defconfig b/configs/octeontx_81xx_defconfig index 52678d59ff1f..bda5df5f33db 100644 --- a/configs/octeontx_81xx_defconfig +++ b/configs/octeontx_81xx_defconfig @@ -82,6 +82,7 @@ CONFIG_SCSI_AHCI=y CONFIG_AHCI_PCI=y CONFIG_DM_I2C=y CONFIG_MISC=y +CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_MMC_OCTEONTX=y CONFIG_MTD=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/octeontx_83xx_defconfig b/configs/octeontx_83xx_defconfig index 3890c1e97d46..8d013770fae1 100644 --- a/configs/octeontx_83xx_defconfig +++ b/configs/octeontx_83xx_defconfig @@ -79,6 +79,7 @@ CONFIG_SCSI_AHCI=y CONFIG_AHCI_PCI=y CONFIG_DM_I2C=y CONFIG_MISC=y +CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_MMC_OCTEONTX=y CONFIG_MTD=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/phycore_pcl063_ull_defconfig b/configs/phycore_pcl063_ull_defconfig index d8ce8d2fb4b6..ecaaf89eb70a 100644 --- a/configs/phycore_pcl063_ull_defconfig +++ b/configs/phycore_pcl063_ull_defconfig @@ -35,6 +35,7 @@ CONFIG_ENV_OVERWRITE=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_DM_I2C_GPIO=y CONFIG_SYS_I2C_MXC=y +CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_FSL_USDHC=y CONFIG_MTD=y CONFIG_PHYLIB=y diff --git a/configs/pico-imx6_defconfig b/configs/pico-imx6_defconfig index fd102611f932..db7ff2afd6fc 100644 --- a/configs/pico-imx6_defconfig +++ b/configs/pico-imx6_defconfig @@ -64,6 +64,7 @@ CONFIG_FASTBOOT_BUF_ADDR=0x12000000 CONFIG_FASTBOOT_BUF_SIZE=0x10000000 CONFIG_FASTBOOT_FLASH=y CONFIG_FASTBOOT_FLASH_MMC_DEV=0 +CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y CONFIG_PHY_ATHEROS=y diff --git a/configs/variscite_dart6ul_defconfig b/configs/variscite_dart6ul_defconfig index d15886c14378..7d3f0431bc9a 100644 --- a/configs/variscite_dart6ul_defconfig +++ b/configs/variscite_dart6ul_defconfig @@ -37,6 +37,7 @@ CONFIG_DM_I2C_GPIO=y CONFIG_SYS_I2C_MXC=y CONFIG_MISC=y CONFIG_I2C_EEPROM=y +CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_FSL_USDHC=y CONFIG_MTD=y CONFIG_PHYLIB=y diff --git a/include/configs/apalis-imx8.h b/include/configs/apalis-imx8.h index ce5681499c93..b4411654880e 100644 --- a/include/configs/apalis-imx8.h +++ b/include/configs/apalis-imx8.h @@ -16,7 +16,6 @@ #define CONFIG_SYS_FSL_ESDHC_ADDR 0 #define USDHC1_BASE_ADDR 0x5b010000 #define USDHC2_BASE_ADDR 0x5b020000 -#define CONFIG_SUPPORT_EMMC_BOOT /* eMMC specific */
/* Networking */ #define CONFIG_IPADDR 192.168.10.2 diff --git a/include/configs/apalis-imx8x.h b/include/configs/apalis-imx8x.h index cd002235ec4a..5b00a3c7e0b9 100644 --- a/include/configs/apalis-imx8x.h +++ b/include/configs/apalis-imx8x.h @@ -15,7 +15,6 @@ #define CONFIG_SYS_FSL_ESDHC_ADDR 0 #define USDHC1_BASE_ADDR 0x5b010000 #define USDHC2_BASE_ADDR 0x5b020000 -#define CONFIG_SUPPORT_EMMC_BOOT /* eMMC specific */
#define CONFIG_IPADDR 192.168.10.2 #define CONFIG_NETMASK 255.255.255.0 diff --git a/include/configs/bcm_ns3.h b/include/configs/bcm_ns3.h index be60fe78b202..a57edf5238d3 100644 --- a/include/configs/bcm_ns3.h +++ b/include/configs/bcm_ns3.h @@ -42,7 +42,6 @@ #define CONFIG_SYS_BOOTM_LEN 0x01800000
/* Access eMMC Boot_1 and Boot_2 partitions */ -#define CONFIG_SUPPORT_EMMC_BOOT
/* enable 64-bit PCI resources */ #define CONFIG_SYS_PCI_64BIT 1 diff --git a/include/configs/cgtqmx8.h b/include/configs/cgtqmx8.h index 4012814988d0..df9bd90450ee 100644 --- a/include/configs/cgtqmx8.h +++ b/include/configs/cgtqmx8.h @@ -46,7 +46,6 @@ #define USDHC1_BASE_ADDR 0x5B010000 #define USDHC2_BASE_ADDR 0x5B020000 #define USDHC3_BASE_ADDR 0x5B030000 -#define CONFIG_SUPPORT_EMMC_BOOT /* eMMC specific */
#define CONFIG_ENV_OVERWRITE
diff --git a/include/configs/colibri-imx8x.h b/include/configs/colibri-imx8x.h index e823497cb396..03c363858669 100644 --- a/include/configs/colibri-imx8x.h +++ b/include/configs/colibri-imx8x.h @@ -17,7 +17,6 @@ #define CONFIG_SYS_FSL_ESDHC_ADDR 0 #define USDHC1_BASE_ADDR 0x5b010000 #define USDHC2_BASE_ADDR 0x5b020000 -#define CONFIG_SUPPORT_EMMC_BOOT /* eMMC specific */
#define CONFIG_IPADDR 192.168.10.2 #define CONFIG_NETMASK 255.255.255.0 diff --git a/include/configs/dart_6ul.h b/include/configs/dart_6ul.h index 3080ae7cae4f..dd1ba49788a1 100644 --- a/include/configs/dart_6ul.h +++ b/include/configs/dart_6ul.h @@ -41,7 +41,6 @@ /* MMC Configs */
#define CONFIG_SYS_FSL_ESDHC_ADDR USDHC2_BASE_ADDR -#define CONFIG_SUPPORT_EMMC_BOOT
/* I2C configs */
diff --git a/include/configs/imx8qm_mek.h b/include/configs/imx8qm_mek.h index 803daa45c80a..451140ea99dd 100644 --- a/include/configs/imx8qm_mek.h +++ b/include/configs/imx8qm_mek.h @@ -42,7 +42,6 @@ #define CONFIG_SYS_FSL_ESDHC_ADDR 0 #define USDHC1_BASE_ADDR 0x5B010000 #define USDHC2_BASE_ADDR 0x5B020000 -#define CONFIG_SUPPORT_EMMC_BOOT /* eMMC specific */
#ifdef CONFIG_AHAB_BOOT #define AHAB_ENV "sec_boot=yes\0" diff --git a/include/configs/imx8qm_rom7720.h b/include/configs/imx8qm_rom7720.h index 89b45546adc2..b524ce307076 100644 --- a/include/configs/imx8qm_rom7720.h +++ b/include/configs/imx8qm_rom7720.h @@ -22,8 +22,6 @@ #define USDHC2_BASE_ADDR 0x5B020000 #define USDHC3_BASE_ADDR 0x5B030000
-#define CONFIG_SUPPORT_EMMC_BOOT /* eMMC specific */ - /* FUSE command */
/* Boot M4 */ diff --git a/include/configs/octeontx2_common.h b/include/configs/octeontx2_common.h index 5e1c0073b0b3..6608b3410280 100644 --- a/include/configs/octeontx2_common.h +++ b/include/configs/octeontx2_common.h @@ -56,7 +56,6 @@ #if defined(CONFIG_MMC_OCTEONTX) #define MMC_SUPPORTS_TUNING /** EMMC specific defines */ -#define CONFIG_SUPPORT_EMMC_BOOT #define CONFIG_SUPPORT_EMMC_RPMB #endif
diff --git a/include/configs/octeontx_common.h b/include/configs/octeontx_common.h index 83dccf7d8ea2..3a0f081046d1 100644 --- a/include/configs/octeontx_common.h +++ b/include/configs/octeontx_common.h @@ -88,7 +88,6 @@
/** EMMC specific defines */ #if defined(CONFIG_MMC_OCTEONTX) -#define CONFIG_SUPPORT_EMMC_BOOT #define CONFIG_SUPPORT_EMMC_RPMB #endif
diff --git a/include/configs/pcl063_ull.h b/include/configs/pcl063_ull.h index 20ba3f192b04..0e047dfa43a8 100644 --- a/include/configs/pcl063_ull.h +++ b/include/configs/pcl063_ull.h @@ -30,7 +30,6 @@ /* MMC Configs */
/* I2C configs */
diff --git a/include/configs/pico-imx6.h b/include/configs/pico-imx6.h index 4e72caa45d7a..199c6e2763a9 100644 --- a/include/configs/pico-imx6.h +++ b/include/configs/pico-imx6.h @@ -28,7 +28,6 @@
/* MMC Configuration */ #define CONFIG_SYS_FSL_ESDHC_ADDR USDHC3_BASE_ADDR -#define CONFIG_SUPPORT_EMMC_BOOT #define CONFIG_SYS_FSL_ESDHC_HAS_DDR_MODE
/* USB Configs */
This converts the following to Kconfig: CONFIG_FEC_MXC
Signed-off-by: Tom Rini trini@konsulko.com --- configs/cl-som-imx7_defconfig | 1 + configs/cm_fx6_defconfig | 1 + configs/imx8mq_evk_defconfig | 1 + configs/imx8mq_phanbell_defconfig | 1 + configs/liteboard_defconfig | 1 + configs/m53menlo_defconfig | 1 + configs/mx6qsabrelite_defconfig | 1 + configs/mx6sxsabreauto_defconfig | 1 + configs/mx6sxsabresd_defconfig | 1 + configs/nitrogen6dl2g_defconfig | 1 + configs/nitrogen6dl_defconfig | 1 + configs/nitrogen6q2g_defconfig | 1 + configs/nitrogen6q_defconfig | 1 + configs/nitrogen6s1g_defconfig | 1 + configs/nitrogen6s_defconfig | 1 + configs/pico-dwarf-imx6ul_defconfig | 1 + configs/pico-hobbit-imx6ul_defconfig | 1 + configs/pico-imx6_defconfig | 1 + configs/pico-imx6ul_defconfig | 1 + configs/pico-imx8mq_defconfig | 1 + configs/pico-pi-imx6ul_defconfig | 1 + configs/somlabs_visionsom_6ull_defconfig | 1 + configs/tqma6dl_mba6_mmc_defconfig | 1 + configs/tqma6dl_mba6_spi_defconfig | 1 + configs/tqma6q_mba6_mmc_defconfig | 1 + configs/tqma6q_mba6_spi_defconfig | 1 + configs/tqma6s_mba6_mmc_defconfig | 1 + configs/tqma6s_mba6_spi_defconfig | 1 + configs/vf610twr_defconfig | 1 + configs/vf610twr_nand_defconfig | 1 + include/configs/cl-som-imx7.h | 1 - include/configs/cm_fx6.h | 1 - include/configs/imx27lite-common.h | 1 - include/configs/imx8mq_evk.h | 1 - include/configs/imx8mq_phanbell.h | 1 - include/configs/liteboard.h | 1 - include/configs/m53menlo.h | 1 - include/configs/mx6sxsabreauto.h | 2 -- include/configs/mx6sxsabresd.h | 1 - include/configs/nitrogen6x.h | 1 - include/configs/pico-imx6.h | 1 - include/configs/pico-imx6ul.h | 1 - include/configs/pico-imx8mq.h | 1 - include/configs/somlabs_visionsom_6ull.h | 1 - include/configs/tqma6.h | 1 - include/configs/vf610twr.h | 1 - include/configs/xpress.h | 1 - 47 files changed, 30 insertions(+), 18 deletions(-)
diff --git a/configs/cl-som-imx7_defconfig b/configs/cl-som-imx7_defconfig index 0e7136491753..3288879091d4 100644 --- a/configs/cl-som-imx7_defconfig +++ b/configs/cl-som-imx7_defconfig @@ -80,6 +80,7 @@ CONFIG_SPI_FLASH_SST=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_PHYLIB=y CONFIG_PHY_ATHEROS=y +CONFIG_FEC_MXC=y CONFIG_MII=y CONFIG_POWER_LEGACY=y CONFIG_DM_REGULATOR=y diff --git a/configs/cm_fx6_defconfig b/configs/cm_fx6_defconfig index 1c8bde3de4a3..7c5e23f38a02 100644 --- a/configs/cm_fx6_defconfig +++ b/configs/cm_fx6_defconfig @@ -93,6 +93,7 @@ CONFIG_SPI_FLASH_MTD=y CONFIG_PHYLIB=y CONFIG_PHY_ATHEROS=y CONFIG_DM_ETH=y +CONFIG_FEC_MXC=y CONFIG_MII=y CONFIG_DM_PMIC=y CONFIG_DM_REGULATOR=y diff --git a/configs/imx8mq_evk_defconfig b/configs/imx8mq_evk_defconfig index 62fe6f15236b..bee8d16e54bc 100644 --- a/configs/imx8mq_evk_defconfig +++ b/configs/imx8mq_evk_defconfig @@ -48,6 +48,7 @@ CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y CONFIG_PHY_ATHEROS=y CONFIG_DM_ETH=y +CONFIG_FEC_MXC=y CONFIG_PHY=y CONFIG_PHY_IMX8MQ_USB=y CONFIG_PINCTRL=y diff --git a/configs/imx8mq_phanbell_defconfig b/configs/imx8mq_phanbell_defconfig index 911c3391db5a..f8e7a3c4d223 100644 --- a/configs/imx8mq_phanbell_defconfig +++ b/configs/imx8mq_phanbell_defconfig @@ -52,6 +52,7 @@ CONFIG_SPL_SYS_I2C_LEGACY=y CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_FSL_USDHC=y CONFIG_DM_ETH=y +CONFIG_FEC_MXC=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX8M=y CONFIG_SPL_POWER_LEGACY=y diff --git a/configs/liteboard_defconfig b/configs/liteboard_defconfig index c8f3ee3fbd24..dbbe46ce551e 100644 --- a/configs/liteboard_defconfig +++ b/configs/liteboard_defconfig @@ -50,6 +50,7 @@ CONFIG_MTD=y CONFIG_PHYLIB=y CONFIG_PHY_SMSC=y CONFIG_DM_ETH=y +CONFIG_FEC_MXC=y CONFIG_MII=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y diff --git a/configs/m53menlo_defconfig b/configs/m53menlo_defconfig index 2c065c67ff41..76fc09d1f926 100644 --- a/configs/m53menlo_defconfig +++ b/configs/m53menlo_defconfig @@ -90,6 +90,7 @@ CONFIG_PHY_MICREL_KSZ8XXX=y CONFIG_DM_ETH=y CONFIG_DM_MDIO=y CONFIG_DM_ETH_PHY=y +CONFIG_FEC_MXC=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX5=y CONFIG_DM_REGULATOR=y diff --git a/configs/mx6qsabrelite_defconfig b/configs/mx6qsabrelite_defconfig index da1f03085698..bfb91b549ec2 100644 --- a/configs/mx6qsabrelite_defconfig +++ b/configs/mx6qsabrelite_defconfig @@ -63,6 +63,7 @@ CONFIG_SPI_FLASH_SST=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y +CONFIG_FEC_MXC=y CONFIG_MII=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y diff --git a/configs/mx6sxsabreauto_defconfig b/configs/mx6sxsabreauto_defconfig index 5bb481bd1723..4c0c8cf92c3b 100644 --- a/configs/mx6sxsabreauto_defconfig +++ b/configs/mx6sxsabreauto_defconfig @@ -48,6 +48,7 @@ CONFIG_SF_DEFAULT_SPEED=40000000 CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_ATHEROS=y +CONFIG_FEC_MXC=y CONFIG_MII=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y diff --git a/configs/mx6sxsabresd_defconfig b/configs/mx6sxsabresd_defconfig index 751aa53cf21b..11c76dfcfce6 100644 --- a/configs/mx6sxsabresd_defconfig +++ b/configs/mx6sxsabresd_defconfig @@ -50,6 +50,7 @@ CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_PHYLIB=y CONFIG_PHY_ATHEROS=y +CONFIG_FEC_MXC=y CONFIG_MII=y CONFIG_PCI=y CONFIG_PINCTRL=y diff --git a/configs/nitrogen6dl2g_defconfig b/configs/nitrogen6dl2g_defconfig index f0d6dd1e1bee..63e1f5556899 100644 --- a/configs/nitrogen6dl2g_defconfig +++ b/configs/nitrogen6dl2g_defconfig @@ -66,6 +66,7 @@ CONFIG_SPI_FLASH_SST=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y +CONFIG_FEC_MXC=y CONFIG_MII=y CONFIG_MXC_UART=y CONFIG_SPI=y diff --git a/configs/nitrogen6dl_defconfig b/configs/nitrogen6dl_defconfig index 54e5a4d39754..67891e7c7d25 100644 --- a/configs/nitrogen6dl_defconfig +++ b/configs/nitrogen6dl_defconfig @@ -66,6 +66,7 @@ CONFIG_SPI_FLASH_SST=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y +CONFIG_FEC_MXC=y CONFIG_MII=y CONFIG_MXC_UART=y CONFIG_SPI=y diff --git a/configs/nitrogen6q2g_defconfig b/configs/nitrogen6q2g_defconfig index c19284c30720..b18e70a43e07 100644 --- a/configs/nitrogen6q2g_defconfig +++ b/configs/nitrogen6q2g_defconfig @@ -68,6 +68,7 @@ CONFIG_SPI_FLASH_SST=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y +CONFIG_FEC_MXC=y CONFIG_MII=y CONFIG_MXC_UART=y CONFIG_SPI=y diff --git a/configs/nitrogen6q_defconfig b/configs/nitrogen6q_defconfig index ef23d610c6ee..c5b7f6e13d51 100644 --- a/configs/nitrogen6q_defconfig +++ b/configs/nitrogen6q_defconfig @@ -68,6 +68,7 @@ CONFIG_SPI_FLASH_SST=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y +CONFIG_FEC_MXC=y CONFIG_MII=y CONFIG_MXC_UART=y CONFIG_SPI=y diff --git a/configs/nitrogen6s1g_defconfig b/configs/nitrogen6s1g_defconfig index 31fb783eda7b..9757a1e7059e 100644 --- a/configs/nitrogen6s1g_defconfig +++ b/configs/nitrogen6s1g_defconfig @@ -66,6 +66,7 @@ CONFIG_SPI_FLASH_SST=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y +CONFIG_FEC_MXC=y CONFIG_MII=y CONFIG_MXC_UART=y CONFIG_SPI=y diff --git a/configs/nitrogen6s_defconfig b/configs/nitrogen6s_defconfig index 78d4b7b6c459..fc5f4ad6425b 100644 --- a/configs/nitrogen6s_defconfig +++ b/configs/nitrogen6s_defconfig @@ -66,6 +66,7 @@ CONFIG_SPI_FLASH_SST=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y +CONFIG_FEC_MXC=y CONFIG_MII=y CONFIG_MXC_UART=y CONFIG_SPI=y diff --git a/configs/pico-dwarf-imx6ul_defconfig b/configs/pico-dwarf-imx6ul_defconfig index cf49e7cc00f0..ea5d352d49bd 100644 --- a/configs/pico-dwarf-imx6ul_defconfig +++ b/configs/pico-dwarf-imx6ul_defconfig @@ -54,6 +54,7 @@ CONFIG_SYS_I2C_MXC=y CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y +CONFIG_FEC_MXC=y CONFIG_MII=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y diff --git a/configs/pico-hobbit-imx6ul_defconfig b/configs/pico-hobbit-imx6ul_defconfig index 089411122774..2bdb0538fd7a 100644 --- a/configs/pico-hobbit-imx6ul_defconfig +++ b/configs/pico-hobbit-imx6ul_defconfig @@ -57,6 +57,7 @@ CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ8XXX=y +CONFIG_FEC_MXC=y CONFIG_MII=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y diff --git a/configs/pico-imx6_defconfig b/configs/pico-imx6_defconfig index db7ff2afd6fc..0e041a2cf3f5 100644 --- a/configs/pico-imx6_defconfig +++ b/configs/pico-imx6_defconfig @@ -69,6 +69,7 @@ CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y CONFIG_PHY_ATHEROS=y CONFIG_DM_ETH=y +CONFIG_FEC_MXC=y CONFIG_RGMII=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y diff --git a/configs/pico-imx6ul_defconfig b/configs/pico-imx6ul_defconfig index e55c0b71cf21..3c5e9b078f01 100644 --- a/configs/pico-imx6ul_defconfig +++ b/configs/pico-imx6ul_defconfig @@ -61,6 +61,7 @@ CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ8XXX=y CONFIG_DM_ETH=y +CONFIG_FEC_MXC=y CONFIG_MII=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y diff --git a/configs/pico-imx8mq_defconfig b/configs/pico-imx8mq_defconfig index b90a49242477..264ba2b82e2f 100644 --- a/configs/pico-imx8mq_defconfig +++ b/configs/pico-imx8mq_defconfig @@ -50,6 +50,7 @@ CONFIG_SPL_SYS_I2C_LEGACY=y CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_FSL_USDHC=y CONFIG_DM_ETH=y +CONFIG_FEC_MXC=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX8M=y CONFIG_SPL_POWER_LEGACY=y diff --git a/configs/pico-pi-imx6ul_defconfig b/configs/pico-pi-imx6ul_defconfig index c3999ec7a4e7..ea6a263e2a6c 100644 --- a/configs/pico-pi-imx6ul_defconfig +++ b/configs/pico-pi-imx6ul_defconfig @@ -57,6 +57,7 @@ CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ8XXX=y +CONFIG_FEC_MXC=y CONFIG_MII=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y diff --git a/configs/somlabs_visionsom_6ull_defconfig b/configs/somlabs_visionsom_6ull_defconfig index 6523d2a976a0..06d8d5524932 100644 --- a/configs/somlabs_visionsom_6ull_defconfig +++ b/configs/somlabs_visionsom_6ull_defconfig @@ -42,6 +42,7 @@ CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ8XXX=y +CONFIG_FEC_MXC=y CONFIG_MII=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y diff --git a/configs/tqma6dl_mba6_mmc_defconfig b/configs/tqma6dl_mba6_mmc_defconfig index 9f3e8f6c85ea..698c8d0ee750 100644 --- a/configs/tqma6dl_mba6_mmc_defconfig +++ b/configs/tqma6dl_mba6_mmc_defconfig @@ -44,6 +44,7 @@ CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_WINBOND=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_FEC_MXC=y CONFIG_MII=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y diff --git a/configs/tqma6dl_mba6_spi_defconfig b/configs/tqma6dl_mba6_spi_defconfig index a7a97762546a..9a533b9dd9a4 100644 --- a/configs/tqma6dl_mba6_spi_defconfig +++ b/configs/tqma6dl_mba6_spi_defconfig @@ -48,6 +48,7 @@ CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_WINBOND=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_FEC_MXC=y CONFIG_MII=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y diff --git a/configs/tqma6q_mba6_mmc_defconfig b/configs/tqma6q_mba6_mmc_defconfig index 955877b34b68..a7c3b0ffeb09 100644 --- a/configs/tqma6q_mba6_mmc_defconfig +++ b/configs/tqma6q_mba6_mmc_defconfig @@ -44,6 +44,7 @@ CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_WINBOND=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_FEC_MXC=y CONFIG_MII=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y diff --git a/configs/tqma6q_mba6_spi_defconfig b/configs/tqma6q_mba6_spi_defconfig index d1f3f2be5d20..00d456cb873a 100644 --- a/configs/tqma6q_mba6_spi_defconfig +++ b/configs/tqma6q_mba6_spi_defconfig @@ -48,6 +48,7 @@ CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_WINBOND=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_FEC_MXC=y CONFIG_MII=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y diff --git a/configs/tqma6s_mba6_mmc_defconfig b/configs/tqma6s_mba6_mmc_defconfig index c46c7e24f383..d2af853b299a 100644 --- a/configs/tqma6s_mba6_mmc_defconfig +++ b/configs/tqma6s_mba6_mmc_defconfig @@ -44,6 +44,7 @@ CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_WINBOND=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_FEC_MXC=y CONFIG_MII=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y diff --git a/configs/tqma6s_mba6_spi_defconfig b/configs/tqma6s_mba6_spi_defconfig index feb98a601065..ef428aa9f7c9 100644 --- a/configs/tqma6s_mba6_spi_defconfig +++ b/configs/tqma6s_mba6_spi_defconfig @@ -48,6 +48,7 @@ CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_WINBOND=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_FEC_MXC=y CONFIG_MII=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y diff --git a/configs/vf610twr_defconfig b/configs/vf610twr_defconfig index 0a7b663ec6b4..9dae6f807285 100644 --- a/configs/vf610twr_defconfig +++ b/configs/vf610twr_defconfig @@ -51,6 +51,7 @@ CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ8XXX=y +CONFIG_FEC_MXC=y CONFIG_MII=y CONFIG_DM_SERIAL=y CONFIG_FSL_LPUART=y diff --git a/configs/vf610twr_nand_defconfig b/configs/vf610twr_nand_defconfig index 00df6fe5e593..5763570bef89 100644 --- a/configs/vf610twr_nand_defconfig +++ b/configs/vf610twr_nand_defconfig @@ -51,6 +51,7 @@ CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ8XXX=y +CONFIG_FEC_MXC=y CONFIG_MII=y CONFIG_DM_SERIAL=y CONFIG_FSL_LPUART=y diff --git a/include/configs/cl-som-imx7.h b/include/configs/cl-som-imx7.h index fe72bfd95cb9..fdc84297c623 100644 --- a/include/configs/cl-som-imx7.h +++ b/include/configs/cl-som-imx7.h @@ -13,7 +13,6 @@ #define CONFIG_MXC_UART_BASE UART1_IPS_BASE_ADDR
/* Network */ -#define CONFIG_FEC_MXC #define CONFIG_FEC_XCV_TYPE RGMII #define CONFIG_ETHPRIME "FEC" #define CONFIG_FEC_MXC_PHYADDR 0 diff --git a/include/configs/cm_fx6.h b/include/configs/cm_fx6.h index 7545979defaa..d61d759092c6 100644 --- a/include/configs/cm_fx6.h +++ b/include/configs/cm_fx6.h @@ -147,7 +147,6 @@ #endif
/* Ethernet */ -#define CONFIG_FEC_MXC #define CONFIG_FEC_MXC_PHYADDR 0 #define CONFIG_FEC_XCV_TYPE RGMII #define IMX_FEC_BASE ENET_BASE_ADDR diff --git a/include/configs/imx27lite-common.h b/include/configs/imx27lite-common.h index 27aab38926d7..c289d694e9b3 100644 --- a/include/configs/imx27lite-common.h +++ b/include/configs/imx27lite-common.h @@ -91,7 +91,6 @@ /* * Ethernet */ -#define CONFIG_FEC_MXC #define CONFIG_FEC_MXC_PHYADDR 0x1f
/* diff --git a/include/configs/imx8mq_evk.h b/include/configs/imx8mq_evk.h index f2eb77747679..dd768eb08642 100644 --- a/include/configs/imx8mq_evk.h +++ b/include/configs/imx8mq_evk.h @@ -54,7 +54,6 @@ #define CONFIG_MII #define CONFIG_ETHPRIME "FEC"
-#define CONFIG_FEC_MXC #define CONFIG_FEC_XCV_TYPE RGMII #define CONFIG_FEC_MXC_PHYADDR 0 #define FEC_QUIRK_ENET_MAC diff --git a/include/configs/imx8mq_phanbell.h b/include/configs/imx8mq_phanbell.h index 0ec1f69fdbc3..e6575da4746e 100644 --- a/include/configs/imx8mq_phanbell.h +++ b/include/configs/imx8mq_phanbell.h @@ -48,7 +48,6 @@ #define CONFIG_MII #define CONFIG_ETHPRIME "FEC"
-#define CONFIG_FEC_MXC #define CONFIG_FEC_XCV_TYPE RGMII #define CONFIG_FEC_MXC_PHYADDR 0 #define FEC_QUIRK_ENET_MAC diff --git a/include/configs/liteboard.h b/include/configs/liteboard.h index b2f5134fc5c6..d74b2bb96064 100644 --- a/include/configs/liteboard.h +++ b/include/configs/liteboard.h @@ -126,7 +126,6 @@ #endif
#ifdef CONFIG_CMD_NET -#define CONFIG_FEC_MXC #define CONFIG_FEC_ENET_DEV 0
#define IMX_FEC_BASE ENET_BASE_ADDR diff --git a/include/configs/m53menlo.h b/include/configs/m53menlo.h index 375a7588dc58..32f8e633c121 100644 --- a/include/configs/m53menlo.h +++ b/include/configs/m53menlo.h @@ -73,7 +73,6 @@ * Ethernet on SOC (FEC) */ #ifdef CONFIG_CMD_NET -#define CONFIG_FEC_MXC #define IMX_FEC_BASE FEC_BASE_ADDR #define CONFIG_FEC_MXC_PHYADDR 0x0 #define CONFIG_MII diff --git a/include/configs/mx6sxsabreauto.h b/include/configs/mx6sxsabreauto.h index df02c523084f..12b178391896 100644 --- a/include/configs/mx6sxsabreauto.h +++ b/include/configs/mx6sxsabreauto.h @@ -111,8 +111,6 @@
/* Network */
-#define CONFIG_FEC_MXC - #define IMX_FEC_BASE ENET2_BASE_ADDR #define CONFIG_FEC_MXC_PHYADDR 0x0
diff --git a/include/configs/mx6sxsabresd.h b/include/configs/mx6sxsabresd.h index df2bd97438ae..a554011d75dc 100644 --- a/include/configs/mx6sxsabresd.h +++ b/include/configs/mx6sxsabresd.h @@ -138,7 +138,6 @@ #define CONFIG_SYS_FSL_ESDHC_ADDR USDHC4_BASE_ADDR
#define IMX_FEC_BASE ENET_BASE_ADDR #define CONFIG_FEC_MXC_PHYADDR 0x1 diff --git a/include/configs/nitrogen6x.h b/include/configs/nitrogen6x.h index cd53c498975d..603299687f6b 100644 --- a/include/configs/nitrogen6x.h +++ b/include/configs/nitrogen6x.h @@ -32,7 +32,6 @@ #define CONFIG_LBA48 #endif
-#define CONFIG_FEC_MXC #define IMX_FEC_BASE ENET_BASE_ADDR #define CONFIG_FEC_XCV_TYPE RGMII #define CONFIG_ETHPRIME "FEC" diff --git a/include/configs/pico-imx6.h b/include/configs/pico-imx6.h index 199c6e2763a9..817e7140d854 100644 --- a/include/configs/pico-imx6.h +++ b/include/configs/pico-imx6.h @@ -130,7 +130,6 @@ #define CONFIG_BOARD_SIZE_LIMIT 715776
/* Ethernet Configuration */ -#define CONFIG_FEC_MXC #define CONFIG_MII #define IMX_FEC_BASE ENET_BASE_ADDR #define CONFIG_FEC_XCV_TYPE RGMII diff --git a/include/configs/pico-imx6ul.h b/include/configs/pico-imx6ul.h index 250e7747e7b5..3fe178316f7b 100644 --- a/include/configs/pico-imx6ul.h +++ b/include/configs/pico-imx6ul.h @@ -28,7 +28,6 @@
/* Network support */
-#define CONFIG_FEC_MXC #define IMX_FEC_BASE ENET2_BASE_ADDR #define CONFIG_FEC_MXC_PHYADDR 0x1 #define CONFIG_FEC_XCV_TYPE RMII diff --git a/include/configs/pico-imx8mq.h b/include/configs/pico-imx8mq.h index d858a7edf8df..f8805a12e416 100644 --- a/include/configs/pico-imx8mq.h +++ b/include/configs/pico-imx8mq.h @@ -48,7 +48,6 @@ #define CONFIG_MII #define CONFIG_ETHPRIME "FEC"
-#define CONFIG_FEC_MXC #define CONFIG_FEC_XCV_TYPE RGMII #define CONFIG_FEC_MXC_PHYADDR 1 #define FEC_QUIRK_ENET_MAC diff --git a/include/configs/somlabs_visionsom_6ull.h b/include/configs/somlabs_visionsom_6ull.h index a153c13a7ce6..a2fe54709daf 100644 --- a/include/configs/somlabs_visionsom_6ull.h +++ b/include/configs/somlabs_visionsom_6ull.h @@ -91,7 +91,6 @@ #endif
#ifdef CONFIG_CMD_NET -#define CONFIG_FEC_MXC #define IMX_FEC_BASE ENET_BASE_ADDR #define CONFIG_FEC_MXC_PHYADDR 0x1 #define CONFIG_FEC_XCV_TYPE RMII diff --git a/include/configs/tqma6.h b/include/configs/tqma6.h index 1efe9d57a84e..374a65aef4a4 100644 --- a/include/configs/tqma6.h +++ b/include/configs/tqma6.h @@ -55,7 +55,6 @@ #define CONFIG_USB_MAX_CONTROLLER_COUNT 2 #define CONFIG_EHCI_HCD_INIT_AFTER_RESET /* For OTG port */
#define CONFIG_ARP_TIMEOUT 200UL diff --git a/include/configs/vf610twr.h b/include/configs/vf610twr.h index 29d6c3576b83..6ec39a063d76 100644 --- a/include/configs/vf610twr.h +++ b/include/configs/vf610twr.h @@ -25,7 +25,6 @@ #define CONFIG_SYS_FSL_ESDHC_ADDR 0 #define CONFIG_SYS_FSL_ESDHC_NUM 1
-#define CONFIG_FEC_MXC #define IMX_FEC_BASE ENET_BASE_ADDR #define CONFIG_FEC_XCV_TYPE RMII #define CONFIG_FEC_MXC_PHYADDR 0 diff --git a/include/configs/xpress.h b/include/configs/xpress.h index 51fee4406850..f6645a72940b 100644 --- a/include/configs/xpress.h +++ b/include/configs/xpress.h @@ -42,7 +42,6 @@ #define CONFIG_MXC_USB_FLAGS 0 #define CONFIG_USB_MAX_CONTROLLER_COUNT 2
-#define CONFIG_FEC_MXC #define CONFIG_FEC_ENET_DEV 0 #define IMX_FEC_BASE ENET_BASE_ADDR #define CONFIG_FEC_MXC_PHYADDR 0x0
This converts the following to Kconfig: CONFIG_MCFUART
Signed-off-by: Tom Rini trini@konsulko.com --- configs/M5208EVBE_defconfig | 1 + configs/M5235EVB_Flash32_defconfig | 1 + configs/M5235EVB_defconfig | 1 + configs/M5249EVB_defconfig | 1 + configs/M5253DEMO_defconfig | 1 + configs/M5272C3_defconfig | 1 + configs/M5275EVB_defconfig | 1 + configs/M5282EVB_defconfig | 1 + configs/M53017EVB_defconfig | 1 + configs/M5329AFEE_defconfig | 1 + configs/M5329BFEE_defconfig | 1 + configs/M5373EVB_defconfig | 1 + configs/amcore_defconfig | 1 + configs/astro_mcf5373l_defconfig | 1 + configs/cobra5272_defconfig | 1 + configs/eb_cpu5282_defconfig | 1 + configs/eb_cpu5282_internal_defconfig | 1 + configs/stmark2_defconfig | 1 + include/configs/M5208EVBE.h | 1 - include/configs/M5235EVB.h | 1 - include/configs/M5249EVB.h | 1 - include/configs/M5253DEMO.h | 1 - include/configs/M5272C3.h | 1 - include/configs/M5275EVB.h | 1 - include/configs/M5282EVB.h | 1 - include/configs/M53017EVB.h | 1 - include/configs/M5329EVB.h | 1 - include/configs/M5373EVB.h | 1 - include/configs/amcore.h | 1 - include/configs/astro_mcf5373l.h | 1 - include/configs/cobra5272.h | 1 - include/configs/eb_cpu5282.h | 1 - include/configs/stmark2.h | 1 - 33 files changed, 18 insertions(+), 15 deletions(-)
diff --git a/configs/M5208EVBE_defconfig b/configs/M5208EVBE_defconfig index 4d2c300be0f5..100e30b246e3 100644 --- a/configs/M5208EVBE_defconfig +++ b/configs/M5208EVBE_defconfig @@ -31,3 +31,4 @@ CONFIG_SYS_FLASH_CFI=y CONFIG_DM_ETH=y CONFIG_MCFFEC=y CONFIG_MII=y +CONFIG_MCFUART=y diff --git a/configs/M5235EVB_Flash32_defconfig b/configs/M5235EVB_Flash32_defconfig index c6d4fb115f03..f8174c724064 100644 --- a/configs/M5235EVB_Flash32_defconfig +++ b/configs/M5235EVB_Flash32_defconfig @@ -36,3 +36,4 @@ CONFIG_SYS_FLASH_CFI=y CONFIG_DM_ETH=y CONFIG_MCFFEC=y CONFIG_MII=y +CONFIG_MCFUART=y diff --git a/configs/M5235EVB_defconfig b/configs/M5235EVB_defconfig index d271144eb994..a101216aad65 100644 --- a/configs/M5235EVB_defconfig +++ b/configs/M5235EVB_defconfig @@ -36,3 +36,4 @@ CONFIG_SYS_FLASH_CFI=y CONFIG_DM_ETH=y CONFIG_MCFFEC=y CONFIG_MII=y +CONFIG_MCFUART=y diff --git a/configs/M5249EVB_defconfig b/configs/M5249EVB_defconfig index 2b7588c0fb6b..faedf85c9c10 100644 --- a/configs/M5249EVB_defconfig +++ b/configs/M5249EVB_defconfig @@ -23,3 +23,4 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y +CONFIG_MCFUART=y diff --git a/configs/M5253DEMO_defconfig b/configs/M5253DEMO_defconfig index ff4142b9255a..b6b38835d15b 100644 --- a/configs/M5253DEMO_defconfig +++ b/configs/M5253DEMO_defconfig @@ -26,3 +26,4 @@ CONFIG_SYS_FSL_I2C_OFFSET=0x280 CONFIG_SYS_I2C_SLAVE=0x7F CONFIG_SYS_I2C_SPEED=80000 CONFIG_MTD_NOR_FLASH=y +CONFIG_MCFUART=y diff --git a/configs/M5272C3_defconfig b/configs/M5272C3_defconfig index 37b357d9668b..4794b9ee06d9 100644 --- a/configs/M5272C3_defconfig +++ b/configs/M5272C3_defconfig @@ -27,3 +27,4 @@ CONFIG_SYS_FLASH_CFI=y CONFIG_DM_ETH=y CONFIG_MCFFEC=y CONFIG_MII=y +CONFIG_MCFUART=y diff --git a/configs/M5275EVB_defconfig b/configs/M5275EVB_defconfig index 51cbd729fba1..37bf76f15f8f 100644 --- a/configs/M5275EVB_defconfig +++ b/configs/M5275EVB_defconfig @@ -33,3 +33,4 @@ CONFIG_SYS_FLASH_CFI=y CONFIG_DM_ETH=y CONFIG_MCFFEC=y CONFIG_MII=y +CONFIG_MCFUART=y diff --git a/configs/M5282EVB_defconfig b/configs/M5282EVB_defconfig index 74937278f2f3..68ba3be0ac3e 100644 --- a/configs/M5282EVB_defconfig +++ b/configs/M5282EVB_defconfig @@ -27,3 +27,4 @@ CONFIG_SYS_FLASH_CFI=y CONFIG_DM_ETH=y CONFIG_MCFFEC=y CONFIG_MII=y +CONFIG_MCFUART=y diff --git a/configs/M53017EVB_defconfig b/configs/M53017EVB_defconfig index b4eb9687e5ab..ebaba23d2c1b 100644 --- a/configs/M53017EVB_defconfig +++ b/configs/M53017EVB_defconfig @@ -34,3 +34,4 @@ CONFIG_SYS_FLASH_CFI=y CONFIG_DM_ETH=y CONFIG_MCFFEC=y CONFIG_MII=y +CONFIG_MCFUART=y diff --git a/configs/M5329AFEE_defconfig b/configs/M5329AFEE_defconfig index 2c0ef9d0afbb..8f66cd978e3a 100644 --- a/configs/M5329AFEE_defconfig +++ b/configs/M5329AFEE_defconfig @@ -36,3 +36,4 @@ CONFIG_MTD_RAW_NAND=y CONFIG_DM_ETH=y CONFIG_MCFFEC=y CONFIG_MII=y +CONFIG_MCFUART=y diff --git a/configs/M5329BFEE_defconfig b/configs/M5329BFEE_defconfig index 1ff8c87d4fe0..a44ebad10178 100644 --- a/configs/M5329BFEE_defconfig +++ b/configs/M5329BFEE_defconfig @@ -36,3 +36,4 @@ CONFIG_MTD_RAW_NAND=y CONFIG_DM_ETH=y CONFIG_MCFFEC=y CONFIG_MII=y +CONFIG_MCFUART=y diff --git a/configs/M5373EVB_defconfig b/configs/M5373EVB_defconfig index 82264cda9c15..aa4224d9de07 100644 --- a/configs/M5373EVB_defconfig +++ b/configs/M5373EVB_defconfig @@ -36,3 +36,4 @@ CONFIG_MTD_RAW_NAND=y CONFIG_DM_ETH=y CONFIG_MCFFEC=y CONFIG_MII=y +CONFIG_MCFUART=y diff --git a/configs/amcore_defconfig b/configs/amcore_defconfig index 4befa7a62bdd..259809e3c4b7 100644 --- a/configs/amcore_defconfig +++ b/configs/amcore_defconfig @@ -29,3 +29,4 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y +CONFIG_MCFUART=y diff --git a/configs/astro_mcf5373l_defconfig b/configs/astro_mcf5373l_defconfig index 45796df36308..073ecc92c988 100644 --- a/configs/astro_mcf5373l_defconfig +++ b/configs/astro_mcf5373l_defconfig @@ -37,3 +37,4 @@ CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_PROTECTION=y CONFIG_SYS_FLASH_CFI=y +CONFIG_MCFUART=y diff --git a/configs/cobra5272_defconfig b/configs/cobra5272_defconfig index bbcdf45697c8..ca5c0b434beb 100644 --- a/configs/cobra5272_defconfig +++ b/configs/cobra5272_defconfig @@ -23,3 +23,4 @@ CONFIG_DM_ETH=y CONFIG_MCFFEC=y CONFIG_MII=y CONFIG_BAUDRATE=19200 +CONFIG_MCFUART=y diff --git a/configs/eb_cpu5282_defconfig b/configs/eb_cpu5282_defconfig index 9bbfcf284d0f..5b372e12b6e9 100644 --- a/configs/eb_cpu5282_defconfig +++ b/configs/eb_cpu5282_defconfig @@ -36,5 +36,6 @@ CONFIG_SYS_FLASH_CFI=y CONFIG_DM_ETH=y CONFIG_MCFFEC=y CONFIG_MII=y +CONFIG_MCFUART=y CONFIG_SPLASH_SCREEN=y CONFIG_VIDEO_VCXK=y diff --git a/configs/eb_cpu5282_internal_defconfig b/configs/eb_cpu5282_internal_defconfig index abc87ecc6573..ad0f6f821b93 100644 --- a/configs/eb_cpu5282_internal_defconfig +++ b/configs/eb_cpu5282_internal_defconfig @@ -35,5 +35,6 @@ CONFIG_SYS_FLASH_CFI=y CONFIG_DM_ETH=y CONFIG_MCFFEC=y CONFIG_MII=y +CONFIG_MCFUART=y CONFIG_SPLASH_SCREEN=y CONFIG_VIDEO_VCXK=y diff --git a/configs/stmark2_defconfig b/configs/stmark2_defconfig index bca22c5830ff..c55e5be7159a 100644 --- a/configs/stmark2_defconfig +++ b/configs/stmark2_defconfig @@ -36,6 +36,7 @@ CONFIG_DM_SPI_FLASH=y CONFIG_SF_DEFAULT_SPEED=50000000 CONFIG_SPI_FLASH_ISSI=y CONFIG_SPI_FLASH_MTD=y +CONFIG_MCFUART=y CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_CF_SPI=y diff --git a/include/configs/M5208EVBE.h b/include/configs/M5208EVBE.h index e0c8d361d161..6a69ac45aee4 100644 --- a/include/configs/M5208EVBE.h +++ b/include/configs/M5208EVBE.h @@ -13,7 +13,6 @@ * High Level Configuration Options * (easy to change) */ -#define CONFIG_MCFUART #define CONFIG_SYS_UART_PORT (0)
#undef CONFIG_WATCHDOG diff --git a/include/configs/M5235EVB.h b/include/configs/M5235EVB.h index b37c915538c3..7421f3b7605d 100644 --- a/include/configs/M5235EVB.h +++ b/include/configs/M5235EVB.h @@ -18,7 +18,6 @@ * (easy to change) */
#undef CONFIG_WATCHDOG diff --git a/include/configs/M5249EVB.h b/include/configs/M5249EVB.h index 7015f790dee5..7ee0ec6a4a89 100644 --- a/include/configs/M5249EVB.h +++ b/include/configs/M5249EVB.h @@ -19,7 +19,6 @@ */ #define CONFIG_MCFTMR
#undef CONFIG_WATCHDOG diff --git a/include/configs/M5253DEMO.h b/include/configs/M5253DEMO.h index d892cbb50858..e9a792292193 100644 --- a/include/configs/M5253DEMO.h +++ b/include/configs/M5253DEMO.h @@ -10,7 +10,6 @@
#undef CONFIG_WATCHDOG /* disable watchdog */ diff --git a/include/configs/M5272C3.h b/include/configs/M5272C3.h index 01c8ac6dd62a..1204aa07a9c4 100644 --- a/include/configs/M5272C3.h +++ b/include/configs/M5272C3.h @@ -18,7 +18,6 @@ */ #define CONFIG_MCFTMR
#undef CONFIG_WATCHDOG diff --git a/include/configs/M5275EVB.h b/include/configs/M5275EVB.h index 35048613b9f7..8e03fc995f83 100644 --- a/include/configs/M5275EVB.h +++ b/include/configs/M5275EVB.h @@ -23,7 +23,6 @@
/* Configuration for environment diff --git a/include/configs/M5282EVB.h b/include/configs/M5282EVB.h index fde108404458..800a73191410 100644 --- a/include/configs/M5282EVB.h +++ b/include/configs/M5282EVB.h @@ -18,7 +18,6 @@ */ #define CONFIG_MCFTMR
#undef CONFIG_MONITOR_IS_IN_RAM /* define if monitor is started from a pre-loader */ diff --git a/include/configs/M53017EVB.h b/include/configs/M53017EVB.h index 2e5b82a5f533..7b33677c551d 100644 --- a/include/configs/M53017EVB.h +++ b/include/configs/M53017EVB.h @@ -18,7 +18,6 @@ * (easy to change) */
#undef CONFIG_WATCHDOG diff --git a/include/configs/M5329EVB.h b/include/configs/M5329EVB.h index e3e7d8b7e0eb..19d8cfe32173 100644 --- a/include/configs/M5329EVB.h +++ b/include/configs/M5329EVB.h @@ -18,7 +18,6 @@ * (easy to change) */
#undef CONFIG_WATCHDOG diff --git a/include/configs/M5373EVB.h b/include/configs/M5373EVB.h index 256a66fb0575..e2ddc4893e77 100644 --- a/include/configs/M5373EVB.h +++ b/include/configs/M5373EVB.h @@ -20,7 +20,6 @@ * (easy to change) */
#undef CONFIG_WATCHDOG diff --git a/include/configs/amcore.h b/include/configs/amcore.h index ee2df6c6cf63..fd05ea69e3bb 100644 --- a/include/configs/amcore.h +++ b/include/configs/amcore.h @@ -11,7 +11,6 @@ #define CONFIG_HOSTNAME "AMCORE"
#define CONFIG_MCFTMR -#define CONFIG_MCFUART #define CONFIG_SYS_UART_PORT 0
#define CONFIG_BOOTCOMMAND "bootm ffc20000" diff --git a/include/configs/astro_mcf5373l.h b/include/configs/astro_mcf5373l.h index 077af08c2bea..36e351f35833 100644 --- a/include/configs/astro_mcf5373l.h +++ b/include/configs/astro_mcf5373l.h @@ -81,7 +81,6 @@ * in u-boot command interface */
-#define CONFIG_MCFUART #define CONFIG_SYS_UART_PORT (2) #define CONFIG_SYS_UART2_ALT3_GPIO
diff --git a/include/configs/cobra5272.h b/include/configs/cobra5272.h index efc6b5bd1be0..dbb47ccb2a73 100644 --- a/include/configs/cobra5272.h +++ b/include/configs/cobra5272.h @@ -43,7 +43,6 @@ * --- */
/* --- diff --git a/include/configs/eb_cpu5282.h b/include/configs/eb_cpu5282.h index 6a5e1d3a7534..1949c3f558f3 100644 --- a/include/configs/eb_cpu5282.h +++ b/include/configs/eb_cpu5282.h @@ -14,7 +14,6 @@ * High Level Configuration Options (easy to change) * *----------------------------------------------------------------------*/
#undef CONFIG_MONITOR_IS_IN_RAM /* starts uboot direct */ diff --git a/include/configs/stmark2.h b/include/configs/stmark2.h index a71de0545894..4573093d4ca4 100644 --- a/include/configs/stmark2.h +++ b/include/configs/stmark2.h @@ -10,7 +10,6 @@
#define CONFIG_HOSTNAME "stmark2"
#define LDS_BOARD_TEXT \
This converts the following to Kconfig: CONFIG_OF_EMBED
Signed-off-by: Tom Rini trini@konsulko.com --- README | 7 ------- configs/adp-ae3xx_defconfig | 1 + configs/adp-ag101p_defconfig | 1 + include/configs/adp-ae3xx.h | 1 - include/configs/adp-ag101p.h | 1 - include/configs/cgtqmx8.h | 2 -- include/configs/imx8qm_mek.h | 2 -- include/configs/imx8qxp_mek.h | 2 -- 8 files changed, 2 insertions(+), 15 deletions(-)
diff --git a/README b/README index 840b192aae50..420513f1bf14 100644 --- a/README +++ b/README @@ -673,13 +673,6 @@ The following options need to be configured: U-Boot needs to get its device tree from somewhere. This can be done using one of the three options below:
- CONFIG_OF_EMBED - If this variable is defined, U-Boot will embed a device tree - binary in its image. This device tree file should be in the - board directory and called <soc>-<board>.dts. The binary file - is then picked up in board_init_f() and made available through - the global data structure as gd->fdt_blob. - CONFIG_OF_SEPARATE If this variable is defined, U-Boot will build a device tree binary. It will be called u-boot.dtb. Architecture-specific diff --git a/configs/adp-ae3xx_defconfig b/configs/adp-ae3xx_defconfig index cf2535ed6f8e..4b81cdc1c21c 100644 --- a/configs/adp-ae3xx_defconfig +++ b/configs/adp-ae3xx_defconfig @@ -24,6 +24,7 @@ CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y +CONFIG_OF_EMBED=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y diff --git a/configs/adp-ag101p_defconfig b/configs/adp-ag101p_defconfig index c1cdb11a7c46..ee87154dadd5 100644 --- a/configs/adp-ag101p_defconfig +++ b/configs/adp-ag101p_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_DATE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y +CONFIG_OF_EMBED=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_FLASH=y CONFIG_ENV_ADDR=0x80140000 diff --git a/include/configs/adp-ae3xx.h b/include/configs/adp-ae3xx.h index b6a78b1370ef..973033d6b4d5 100644 --- a/include/configs/adp-ae3xx.h +++ b/include/configs/adp-ae3xx.h @@ -24,7 +24,6 @@ #ifdef CONFIG_SKIP_LOWLEVEL_INIT #ifdef CONFIG_OF_CONTROL #undef CONFIG_OF_SEPARATE -#define CONFIG_OF_EMBED #endif #endif
diff --git a/include/configs/adp-ag101p.h b/include/configs/adp-ag101p.h index 3e78d5ce1705..f533ada73f47 100644 --- a/include/configs/adp-ag101p.h +++ b/include/configs/adp-ag101p.h @@ -26,7 +26,6 @@ #ifdef CONFIG_SKIP_LOWLEVEL_INIT #ifdef CONFIG_OF_CONTROL #undef CONFIG_OF_SEPARATE -#define CONFIG_OF_EMBED #endif #endif
diff --git a/include/configs/cgtqmx8.h b/include/configs/cgtqmx8.h index df9bd90450ee..11b186a3ab7c 100644 --- a/include/configs/cgtqmx8.h +++ b/include/configs/cgtqmx8.h @@ -30,8 +30,6 @@ #define CONFIG_SPL_RAW_IMAGE_ARM_TRUSTED_FIRMWARE
#define CONFIG_SPL_ABORT_ON_RAW_IMAGE - -#define CONFIG_OF_EMBED #endif
#define CONFIG_REMAKE_ELF diff --git a/include/configs/imx8qm_mek.h b/include/configs/imx8qm_mek.h index 451140ea99dd..d3c3e580acb1 100644 --- a/include/configs/imx8qm_mek.h +++ b/include/configs/imx8qm_mek.h @@ -30,8 +30,6 @@ #define CONFIG_SPL_RAW_IMAGE_ARM_TRUSTED_FIRMWARE
#define CONFIG_REMAKE_ELF diff --git a/include/configs/imx8qxp_mek.h b/include/configs/imx8qxp_mek.h index a7ca48f1f6b9..3b1f957364c9 100644 --- a/include/configs/imx8qxp_mek.h +++ b/include/configs/imx8qxp_mek.h @@ -28,8 +28,6 @@ #define CONFIG_SPL_RAW_IMAGE_ARM_TRUSTED_FIRMWARE
Signed-off-by: Tom Rini trini@konsulko.com Reviewed-by: Rick Chen rick@andestech.com
This converts the following to Kconfig: CONFIG_BMP_16BPP
Signed-off-by: Tom Rini trini@konsulko.com --- configs/am335x_guardian_defconfig | 1 + include/configs/am335x_guardian.h | 1 - 2 files changed, 1 insertion(+), 1 deletion(-)
diff --git a/configs/am335x_guardian_defconfig b/configs/am335x_guardian_defconfig index ea4032fe1ff0..9d9d6283e059 100644 --- a/configs/am335x_guardian_defconfig +++ b/configs/am335x_guardian_defconfig @@ -122,6 +122,7 @@ CONFIG_USB_GADGET_PRODUCT_NUM=0xd022 CONFIG_USB_ETHER=y CONFIG_SYS_WHITE_ON_BLACK=y CONFIG_AM335X_LCD=y +CONFIG_BMP_16BPP=y CONFIG_SPL_WDT=y # CONFIG_SPL_USE_TINY_PRINTF is not set CONFIG_SPL_OF_LIBFDT=y diff --git a/include/configs/am335x_guardian.h b/include/configs/am335x_guardian.h index 68b4e4f59033..a1f24bb2d11a 100644 --- a/include/configs/am335x_guardian.h +++ b/include/configs/am335x_guardian.h @@ -80,7 +80,6 @@
#endif /* ! CONFIG_SPL_BUILD */
-#define CONFIG_BMP_16BPP #define SPLASH_SCREEN_NAND_PART "nand0,10" #define SPLASH_SCREEN_BMP_FILE_SIZE 0x26000 #define SPLASH_SCREEN_BMP_LOAD_ADDR 0x82000000
This converts the following to Kconfig: CONFIG_SPL_DRIVERS_MISC CONFIG_SPL_ENV_SUPPORT CONFIG_SPL_GPIO CONFIG_SPL_I2C CONFIG_SPL_LDSCRIPT CONFIG_SPL_LIBCOMMON_SUPPORT CONFIG_SPL_LIBGENERIC_SUPPORT CONFIG_SPL_LOAD_FIT_ADDRESS CONFIG_SPL_MMC CONFIG_SPL_NAND_SUPPORT CONFIG_SPL_NO_CPU_SUPPORT CONFIG_SPL_OS_BOOT CONFIG_SPL_POWER CONFIG_SPL_STACK_R CONFIG_SPL_STACK_R_ADDR CONFIG_SPL_WATCHDOG CONFIG_SPL_TEXT_BASE
Signed-off-by: Tom Rini trini@konsulko.com --- README | 7 ------- configs/controlcenterdc_defconfig | 3 +++ configs/imx6dl_icore_nand_defconfig | 1 + configs/imx6dl_mamoj_defconfig | 1 + configs/imx6q_icore_nand_defconfig | 1 + configs/imx6qdl_icore_mipi_defconfig | 2 ++ configs/imx6qdl_icore_mmc_defconfig | 2 ++ configs/imx6qdl_icore_nand_defconfig | 1 + configs/imx6qdl_icore_rqs_defconfig | 2 ++ configs/imx6ul_geam_mmc_defconfig | 2 ++ configs/imx6ul_geam_nand_defconfig | 1 + configs/imx6ul_isiot_emmc_defconfig | 2 ++ configs/imx6ul_isiot_nand_defconfig | 1 + configs/imx8mq_evk_defconfig | 8 ++++++++ configs/imx8mq_phanbell_defconfig | 7 +++++++ configs/ls1021aiot_sdcard_defconfig | 6 ++++++ configs/ls1046aqds_nand_defconfig | 8 +++++++- configs/mccmon6_nor_defconfig | 1 + configs/mccmon6_sd_defconfig | 1 + configs/mx23_olinuxino_defconfig | 1 + configs/mx23evk_defconfig | 1 + configs/mx28evk_auart_console_defconfig | 1 + configs/mx28evk_defconfig | 1 + configs/mx28evk_nand_defconfig | 1 + configs/mx28evk_spi_defconfig | 1 + configs/pico-imx8mq_defconfig | 8 ++++++++ configs/vyasa-rk3288_defconfig | 1 + drivers/mtd/nand/raw/Kconfig | 6 +++--- include/configs/capricorn-common.h | 1 - include/configs/cgtqmx8.h | 2 -- include/configs/controlcenterdc.h | 5 ----- include/configs/imx6-engicam.h | 6 ------ include/configs/imx8mp_evk.h | 1 - include/configs/imx8mq_evk.h | 9 --------- include/configs/imx8mq_phanbell.h | 9 --------- include/configs/imx8qm_mek.h | 1 - include/configs/imx8qxp_mek.h | 1 - include/configs/imx8ulp_evk.h | 3 --- include/configs/ls1021aiot.h | 6 ------ include/configs/ls1046a_common.h | 9 +-------- include/configs/ls1088a_common.h | 1 - include/configs/mccmon6.h | 1 - include/configs/mx6_common.h | 4 ---- include/configs/mx7_common.h | 4 ---- include/configs/mxs.h | 1 - include/configs/phycore_imx8mp.h | 1 - include/configs/pico-imx8mq.h | 9 --------- include/configs/sama5d27_wlsom1_ek.h | 1 - include/configs/smartweb.h | 2 -- include/configs/sunxi-common.h | 2 -- include/configs/topic_miami.h | 3 --- include/configs/vyasa-rk3288.h | 3 --- include/configs/xilinx_zynqmp.h | 1 - 53 files changed, 68 insertions(+), 96 deletions(-)
diff --git a/README b/README index 420513f1bf14..0f5288817155 100644 --- a/README +++ b/README @@ -1941,9 +1941,6 @@ The following options need to be configured: CONFIG_SPL Enable building of SPL globally.
- CONFIG_SPL_LDSCRIPT - LDSCRIPT for linking the SPL binary. - CONFIG_SPL_MAX_FOOTPRINT Maximum size in memory allocated to the SPL, BSS included. When defined, the linker checks that the actual memory @@ -1998,10 +1995,6 @@ The following options need to be configured: CONFIG_SYS_SPL_MALLOC_SIZE The size of the malloc pool used in SPL.
- CONFIG_SPL_OS_BOOT - Enable booting directly to an OS from SPL. - See also: doc/README.falcon - CONFIG_SPL_DISPLAY_PRINT For ARM, enable an optional function to print more information about the running system. diff --git a/configs/controlcenterdc_defconfig b/configs/controlcenterdc_defconfig index 5cfd61f4158a..a9daf3602153 100644 --- a/configs/controlcenterdc_defconfig +++ b/configs/controlcenterdc_defconfig @@ -4,6 +4,8 @@ CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_MVEBU=y CONFIG_SYS_TEXT_BASE=0x00800000 CONFIG_SPL_GPIO=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_NR_DRAM_BANKS=2 CONFIG_TARGET_CONTROLCENTERDC=y @@ -30,6 +32,7 @@ CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_BOARD_LATE_INIT=y CONFIG_LAST_STAGE_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y +CONFIG_SPL_I2C=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_ELF is not set # CONFIG_CMD_GO is not set diff --git a/configs/imx6dl_icore_nand_defconfig b/configs/imx6dl_icore_nand_defconfig index fb9ba0838e16..5caf78fe6752 100644 --- a/configs/imx6dl_icore_nand_defconfig +++ b/configs/imx6dl_icore_nand_defconfig @@ -23,6 +23,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_BOOTDELAY=3 CONFIG_SPL_DMA=y +CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_WATCHDOG=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="icorem6qdl> " diff --git a/configs/imx6dl_mamoj_defconfig b/configs/imx6dl_mamoj_defconfig index 70268d0ab5d6..25c97c229040 100644 --- a/configs/imx6dl_mamoj_defconfig +++ b/configs/imx6dl_mamoj_defconfig @@ -11,6 +11,7 @@ CONFIG_TARGET_MX6DL_MAMOJ=y CONFIG_SYS_MALLOC_LEN=0x2300000 CONFIG_DEFAULT_DEVICE_TREE="imx6dl-mamoj" CONFIG_SPL_TEXT_BASE=0x00908000 +CONFIG_SPL_DRIVERS_MISC=y CONFIG_IMX_HAB=y # CONFIG_CMD_BMODE is not set CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/imx6q_icore_nand_defconfig b/configs/imx6q_icore_nand_defconfig index c9915a7dc9be..769b675a76b7 100644 --- a/configs/imx6q_icore_nand_defconfig +++ b/configs/imx6q_icore_nand_defconfig @@ -24,6 +24,7 @@ CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOOTDELAY=3 CONFIG_SPL_DMA=y +CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_WATCHDOG=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="icorem6qdl> " diff --git a/configs/imx6qdl_icore_mipi_defconfig b/configs/imx6qdl_icore_mipi_defconfig index 8c9843696f2a..634714e476b9 100644 --- a/configs/imx6qdl_icore_mipi_defconfig +++ b/configs/imx6qdl_icore_mipi_defconfig @@ -14,6 +14,7 @@ CONFIG_TARGET_MX6Q_ENGICAM=y CONFIG_SYS_MALLOC_LEN=0x1000000 CONFIG_DEFAULT_DEVICE_TREE="imx6q-icore-mipi" CONFIG_SPL_TEXT_BASE=0x00908000 +CONFIG_SPL_MMC=y CONFIG_SPL_SERIAL=y CONFIG_SPL=y CONFIG_DEBUG_UART_BASE=0x021f0000 @@ -29,6 +30,7 @@ CONFIG_SPL_LOAD_FIT=y CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOOTDELAY=3 +CONFIG_SPL_RAW_IMAGE_SUPPORT=y CONFIG_SPL_OS_BOOT=y CONFIG_SPL_WATCHDOG=y CONFIG_HUSH_PARSER=y diff --git a/configs/imx6qdl_icore_mmc_defconfig b/configs/imx6qdl_icore_mmc_defconfig index f17e472a5833..35f3ece2638c 100644 --- a/configs/imx6qdl_icore_mmc_defconfig +++ b/configs/imx6qdl_icore_mmc_defconfig @@ -14,6 +14,7 @@ CONFIG_TARGET_MX6Q_ENGICAM=y CONFIG_SYS_MALLOC_LEN=0x1000000 CONFIG_DEFAULT_DEVICE_TREE="imx6q-icore" CONFIG_SPL_TEXT_BASE=0x00908000 +CONFIG_SPL_MMC=y CONFIG_SPL_SERIAL=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 CONFIG_SYS_BOOTCOUNT_ADDR=0x020D8024 @@ -32,6 +33,7 @@ CONFIG_SPL_LOAD_FIT=y CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOOTDELAY=3 +CONFIG_SPL_RAW_IMAGE_SUPPORT=y CONFIG_SPL_OS_BOOT=y CONFIG_SPL_WATCHDOG=y CONFIG_HUSH_PARSER=y diff --git a/configs/imx6qdl_icore_nand_defconfig b/configs/imx6qdl_icore_nand_defconfig index c9915a7dc9be..769b675a76b7 100644 --- a/configs/imx6qdl_icore_nand_defconfig +++ b/configs/imx6qdl_icore_nand_defconfig @@ -24,6 +24,7 @@ CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOOTDELAY=3 CONFIG_SPL_DMA=y +CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_WATCHDOG=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="icorem6qdl> " diff --git a/configs/imx6qdl_icore_rqs_defconfig b/configs/imx6qdl_icore_rqs_defconfig index 4594df010e92..85151a55f74f 100644 --- a/configs/imx6qdl_icore_rqs_defconfig +++ b/configs/imx6qdl_icore_rqs_defconfig @@ -14,6 +14,7 @@ CONFIG_TARGET_MX6Q_ENGICAM=y CONFIG_SYS_MALLOC_LEN=0x1000000 CONFIG_DEFAULT_DEVICE_TREE="imx6q-icore-rqs" CONFIG_SPL_TEXT_BASE=0x00908000 +CONFIG_SPL_MMC=y CONFIG_SPL_SERIAL=y CONFIG_SPL=y CONFIG_SPL_LIBDISK_SUPPORT=y @@ -26,6 +27,7 @@ CONFIG_SPL_LOAD_FIT=y CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOOTDELAY=3 +CONFIG_SPL_RAW_IMAGE_SUPPORT=y CONFIG_SPL_OS_BOOT=y CONFIG_SPL_WATCHDOG=y CONFIG_HUSH_PARSER=y diff --git a/configs/imx6ul_geam_mmc_defconfig b/configs/imx6ul_geam_mmc_defconfig index 541ab31f8a0e..dbd89eaafae9 100644 --- a/configs/imx6ul_geam_mmc_defconfig +++ b/configs/imx6ul_geam_mmc_defconfig @@ -14,6 +14,7 @@ CONFIG_TARGET_MX6UL_ENGICAM=y CONFIG_SYS_MALLOC_LEN=0x1000000 CONFIG_DEFAULT_DEVICE_TREE="imx6ul-geam" CONFIG_SPL_TEXT_BASE=0x00908000 +CONFIG_SPL_MMC=y CONFIG_SPL_SERIAL=y CONFIG_SPL=y CONFIG_SPL_LIBDISK_SUPPORT=y @@ -24,6 +25,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOOTDELAY=3 +CONFIG_SPL_RAW_IMAGE_SUPPORT=y CONFIG_SPL_WATCHDOG=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="geam6ul> " diff --git a/configs/imx6ul_geam_nand_defconfig b/configs/imx6ul_geam_nand_defconfig index f1860978d6ec..fe12f36e197c 100644 --- a/configs/imx6ul_geam_nand_defconfig +++ b/configs/imx6ul_geam_nand_defconfig @@ -24,6 +24,7 @@ CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOOTDELAY=3 CONFIG_SPL_DMA=y +CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_WATCHDOG=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="geam6ul> " diff --git a/configs/imx6ul_isiot_emmc_defconfig b/configs/imx6ul_isiot_emmc_defconfig index 8b27b8d23bdc..22356c5ccdc9 100644 --- a/configs/imx6ul_isiot_emmc_defconfig +++ b/configs/imx6ul_isiot_emmc_defconfig @@ -14,6 +14,7 @@ CONFIG_TARGET_MX6UL_ENGICAM=y CONFIG_SYS_MALLOC_LEN=0x1000000 CONFIG_DEFAULT_DEVICE_TREE="imx6ul-isiot-emmc" CONFIG_SPL_TEXT_BASE=0x00908000 +CONFIG_SPL_MMC=y CONFIG_SPL_SERIAL=y CONFIG_SPL=y CONFIG_SPL_LIBDISK_SUPPORT=y @@ -24,6 +25,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOOTDELAY=3 +CONFIG_SPL_RAW_IMAGE_SUPPORT=y CONFIG_SPL_WATCHDOG=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="isiotmx6ul> " diff --git a/configs/imx6ul_isiot_nand_defconfig b/configs/imx6ul_isiot_nand_defconfig index 34c0bb7eeb0d..48d2bf942043 100644 --- a/configs/imx6ul_isiot_nand_defconfig +++ b/configs/imx6ul_isiot_nand_defconfig @@ -24,6 +24,7 @@ CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_SUPPORT_RAW_INITRD=y CONFIG_BOOTDELAY=3 CONFIG_SPL_DMA=y +CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_WATCHDOG=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="isiotmx6ul> " diff --git a/configs/imx8mq_evk_defconfig b/configs/imx8mq_evk_defconfig index bee8d16e54bc..f9bab65e1206 100644 --- a/configs/imx8mq_evk_defconfig +++ b/configs/imx8mq_evk_defconfig @@ -1,6 +1,9 @@ CONFIG_ARM=y CONFIG_ARCH_IMX8M=y CONFIG_SYS_TEXT_BASE=0x40200000 +CONFIG_SPL_GPIO=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_ENV_SIZE=0x1000 CONFIG_ENV_OFFSET=0x400000 CONFIG_SYS_I2C_MXC_I2C1=y @@ -11,7 +14,9 @@ CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="imx8mq-evk" CONFIG_SPL_TEXT_BASE=0x7E1000 CONFIG_TARGET_IMX8MQ_EVK=y +CONFIG_SPL_MMC=y CONFIG_SPL_SERIAL=y +CONFIG_SPL_DRIVERS_MISC=y CONFIG_SPL=y CONFIG_DISTRO_DEFAULTS=y CONFIG_SYS_LOAD_ADDR=0x40480000 @@ -22,6 +27,9 @@ CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_LATE_INIT=y CONFIG_SPL_BOARD_INIT=y +CONFIG_SPL_I2C=y +CONFIG_SPL_POWER=y +CONFIG_SPL_WATCHDOG=y # CONFIG_BOOTM_NETBSD is not set # CONFIG_CMD_EXPORTENV is not set # CONFIG_CMD_IMPORTENV is not set diff --git a/configs/imx8mq_phanbell_defconfig b/configs/imx8mq_phanbell_defconfig index f8e7a3c4d223..bae79d633ac1 100644 --- a/configs/imx8mq_phanbell_defconfig +++ b/configs/imx8mq_phanbell_defconfig @@ -1,6 +1,9 @@ CONFIG_ARM=y CONFIG_ARCH_IMX8M=y CONFIG_SYS_TEXT_BASE=0x40200000 +CONFIG_SPL_GPIO=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SYS_MALLOC_F_LEN=0x4000 CONFIG_ENV_SIZE=0x1000 CONFIG_ENV_OFFSET=0x400000 @@ -12,7 +15,9 @@ CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="imx8mq-phanbell" CONFIG_SPL_TEXT_BASE=0x7E1000 CONFIG_TARGET_IMX8MQ_PHANBELL=y +CONFIG_SPL_MMC=y CONFIG_SPL_SERIAL=y +CONFIG_SPL_DRIVERS_MISC=y CONFIG_SPL=y CONFIG_SYS_LOAD_ADDR=0x40480000 CONFIG_FIT=y @@ -22,6 +27,8 @@ CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" CONFIG_SD_BOOT=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL_BOARD_INIT=y +CONFIG_SPL_I2C=y +CONFIG_SPL_POWER=y CONFIG_HUSH_PARSER=y # CONFIG_BOOTM_NETBSD is not set # CONFIG_CMD_EXPORTENV is not set diff --git a/configs/ls1021aiot_sdcard_defconfig b/configs/ls1021aiot_sdcard_defconfig index 742cfaa787ad..502263c452ca 100644 --- a/configs/ls1021aiot_sdcard_defconfig +++ b/configs/ls1021aiot_sdcard_defconfig @@ -1,6 +1,8 @@ CONFIG_ARM=y CONFIG_TARGET_LS1021AIOT=y CONFIG_SYS_TEXT_BASE=0x82000000 +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0x100000 @@ -11,6 +13,7 @@ CONFIG_SYS_MALLOC_LEN=0x1002000 CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-iot-duart" CONFIG_SPL_TEXT_BASE=0x10000000 +CONFIG_SPL_MMC=y CONFIG_SPL_SERIAL=y CONFIG_SPL=y CONFIG_AHCI=y @@ -25,7 +28,10 @@ CONFIG_ID_EEPROM=y CONFIG_SPL_FSL_PBL=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xe8 +CONFIG_SPL_ENV_SUPPORT=y +CONFIG_SPL_I2C=y CONFIG_SPL_MPC8XXX_INIT_DDR=y +CONFIG_SPL_WATCHDOG=y CONFIG_CMD_BOOTZ=y CONFIG_CMD_GREPENV=y CONFIG_SYS_I2C_EEPROM_ADDR_LEN=2 diff --git a/configs/ls1046aqds_nand_defconfig b/configs/ls1046aqds_nand_defconfig index 8168b6e585f8..6d8e9b197333 100644 --- a/configs/ls1046aqds_nand_defconfig +++ b/configs/ls1046aqds_nand_defconfig @@ -1,6 +1,8 @@ CONFIG_ARM=y CONFIG_TARGET_LS1046AQDS=y CONFIG_SYS_TEXT_BASE=0x82000000 +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_NR_DRAM_BANKS=2 CONFIG_SYS_MEMTEST_START=0x80000000 CONFIG_SYS_MEMTEST_END=0x9fffffff @@ -17,6 +19,7 @@ CONFIG_SPL_TEXT_BASE=0x10000000 CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_FSL_LS_PPA=y CONFIG_SPL_SERIAL=y +CONFIG_SPL_DRIVERS_MISC=y CONFIG_SPL=y CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y @@ -35,7 +38,11 @@ CONFIG_SPL_FSL_PBL=y CONFIG_SPL_BOARD_INIT=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x110 +CONFIG_SPL_ENV_SUPPORT=y +CONFIG_SPL_I2C=y CONFIG_SPL_MPC8XXX_INIT_DDR=y +CONFIG_SPL_NAND_SUPPORT=y +CONFIG_SPL_WATCHDOG=y CONFIG_CMD_BOOTZ=y CONFIG_CMD_IMLS=y CONFIG_CMD_GREPENV=y @@ -96,4 +103,3 @@ CONFIG_FSL_DSPI=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y -CONFIG_EFI_LOADER_BOUNCE_BUFFER=y diff --git a/configs/mccmon6_nor_defconfig b/configs/mccmon6_nor_defconfig index c8b8df314467..f5755de9b1f6 100644 --- a/configs/mccmon6_nor_defconfig +++ b/configs/mccmon6_nor_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_SYS_TEXT_BASE=0x17800000 CONFIG_SPL_GPIO=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x20000 diff --git a/configs/mccmon6_sd_defconfig b/configs/mccmon6_sd_defconfig index bf32c7104b92..402f97fb72dd 100644 --- a/configs/mccmon6_sd_defconfig +++ b/configs/mccmon6_sd_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_SYS_TEXT_BASE=0x17800000 CONFIG_SPL_GPIO=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x20000 diff --git a/configs/mx23_olinuxino_defconfig b/configs/mx23_olinuxino_defconfig index 7fc7cc66ef65..8a77aa4641bf 100644 --- a/configs/mx23_olinuxino_defconfig +++ b/configs/mx23_olinuxino_defconfig @@ -19,6 +19,7 @@ CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_ARCH_MISC_INIT=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_NO_CPU_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_GPIO=y CONFIG_CMD_MMC=y diff --git a/configs/mx23evk_defconfig b/configs/mx23evk_defconfig index 8808f20d45d0..ba468adb9f3b 100644 --- a/configs/mx23evk_defconfig +++ b/configs/mx23evk_defconfig @@ -19,6 +19,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_ARCH_MISC_INIT=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_NO_CPU_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y CONFIG_CMD_DM=y diff --git a/configs/mx28evk_auart_console_defconfig b/configs/mx28evk_auart_console_defconfig index 9346efb699ea..d57db5f1a7b7 100644 --- a/configs/mx28evk_auart_console_defconfig +++ b/configs/mx28evk_auart_console_defconfig @@ -18,6 +18,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_ARCH_MISC_INIT=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_NO_CPU_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_FLASH is not set diff --git a/configs/mx28evk_defconfig b/configs/mx28evk_defconfig index fa73fa2a221e..4e6426b124e8 100644 --- a/configs/mx28evk_defconfig +++ b/configs/mx28evk_defconfig @@ -20,6 +20,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_ARCH_MISC_INIT=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_NO_CPU_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y CONFIG_CMD_DM=y diff --git a/configs/mx28evk_nand_defconfig b/configs/mx28evk_nand_defconfig index 17f5ba45a457..2f708de5a043 100644 --- a/configs/mx28evk_nand_defconfig +++ b/configs/mx28evk_nand_defconfig @@ -18,6 +18,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_ARCH_MISC_INIT=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_NO_CPU_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_FLASH is not set diff --git a/configs/mx28evk_spi_defconfig b/configs/mx28evk_spi_defconfig index 9ccc30d42ae4..424ebcfb25b8 100644 --- a/configs/mx28evk_spi_defconfig +++ b/configs/mx28evk_spi_defconfig @@ -16,6 +16,7 @@ CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_ARCH_MISC_INIT=y # CONFIG_SPL_FRAMEWORK is not set +CONFIG_SPL_NO_CPU_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_CMD_BOOTZ=y # CONFIG_CMD_FLASH is not set diff --git a/configs/pico-imx8mq_defconfig b/configs/pico-imx8mq_defconfig index 264ba2b82e2f..a0f312dfce22 100644 --- a/configs/pico-imx8mq_defconfig +++ b/configs/pico-imx8mq_defconfig @@ -1,6 +1,9 @@ CONFIG_ARM=y CONFIG_ARCH_IMX8M=y CONFIG_SYS_TEXT_BASE=0x40200000 +CONFIG_SPL_GPIO=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_ENV_SIZE=0x1000 CONFIG_ENV_OFFSET=0x400000 CONFIG_SYS_I2C_MXC_I2C1=y @@ -11,7 +14,9 @@ CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="imx8mq-pico-pi" CONFIG_SPL_TEXT_BASE=0x7E1000 CONFIG_TARGET_PICO_IMX8MQ=y +CONFIG_SPL_MMC=y CONFIG_SPL_SERIAL=y +CONFIG_SPL_DRIVERS_MISC=y CONFIG_SPL=y CONFIG_SYS_LOAD_ADDR=0x40480000 CONFIG_FIT=y @@ -21,6 +26,9 @@ CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_LATE_INIT=y CONFIG_SPL_BOARD_INIT=y +CONFIG_SPL_I2C=y +CONFIG_SPL_POWER=y +CONFIG_SPL_WATCHDOG=y CONFIG_HUSH_PARSER=y # CONFIG_BOOTM_NETBSD is not set # CONFIG_CMD_EXPORTENV is not set diff --git a/configs/vyasa-rk3288_defconfig b/configs/vyasa-rk3288_defconfig index 752987f11cbe..84d28c7bfcbc 100644 --- a/configs/vyasa-rk3288_defconfig +++ b/configs/vyasa-rk3288_defconfig @@ -21,6 +21,7 @@ CONFIG_SILENT_CONSOLE=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 +CONFIG_SPL_OS_BOOT=y CONFIG_CMD_SPL=y CONFIG_CMD_GPIO=y CONFIG_CMD_GPT=y diff --git a/drivers/mtd/nand/raw/Kconfig b/drivers/mtd/nand/raw/Kconfig index cb0c0a158187..df9eae1691c4 100644 --- a/drivers/mtd/nand/raw/Kconfig +++ b/drivers/mtd/nand/raw/Kconfig @@ -480,7 +480,7 @@ comment "Generic NAND options" config SYS_NAND_BLOCK_SIZE hex "NAND chip eraseblock size" depends on ARCH_SUNXI || SPL_NAND_SUPPORT || TPL_NAND_SUPPORT - depends on !NAND_MXS_DT && !NAND_DENALI_DT && !NAND_LPC32XX_MLC + depends on !NAND_MXS && !NAND_DENALI_DT && !NAND_LPC32XX_MLC && !NAND_FSL_IFC help Number of data bytes in one eraseblock for the NAND chip on the board. This is the multiple of NAND_PAGE_SIZE and the number of @@ -505,7 +505,7 @@ config SYS_NAND_PAGE_SIZE depends on ARCH_SUNXI || NAND_OMAP_GPMC || NAND_LPC32XX_SLC || \ SPL_NAND_SIMPLE || (NAND_MXC && SPL_NAND_SUPPORT) || \ (NAND_ATMEL && SPL_NAND_SUPPORT) || SPL_GENERATE_ATMEL_PMECC_HEADER - depends on !NAND_MXS_DT && !NAND_DENALI_DT && !NAND_LPC32XX_MLC + depends on !NAND_MXS && !NAND_DENALI_DT && !NAND_LPC32XX_MLC help Number of data bytes in one page for the NAND chip on the board, not including the OOB area. @@ -515,7 +515,7 @@ config SYS_NAND_OOBSIZE depends on ARCH_SUNXI || NAND_OMAP_GPMC || NAND_LPC32XX_SLC || \ SPL_NAND_SIMPLE || (NAND_MXC && SPL_NAND_SUPPORT) || \ (NAND_ATMEL && SPL_NAND_SUPPORT) || SPL_GENERATE_ATMEL_PMECC_HEADER - depends on !NAND_MXS_DT && !NAND_DENALI_DT && !NAND_LPC32XX_MLC + depends on !NAND_MXS && !NAND_DENALI_DT && !NAND_LPC32XX_MLC help Number of bytes in the Out-Of-Band area for the NAND chip on the board. diff --git a/include/configs/capricorn-common.h b/include/configs/capricorn-common.h index 59e827e320a8..58ab1b7deed4 100644 --- a/include/configs/capricorn-common.h +++ b/include/configs/capricorn-common.h @@ -21,7 +21,6 @@ #define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR #define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0x800
-#define CONFIG_SPL_LDSCRIPT "arch/arm/cpu/armv8/u-boot-spl.lds" #define CONFIG_SPL_STACK 0x013E000 #define CONFIG_SPL_BSS_START_ADDR 0x00128000 #define CONFIG_SPL_BSS_MAX_SIZE 0x1000 /* 4 KB */ diff --git a/include/configs/cgtqmx8.h b/include/configs/cgtqmx8.h index 11b186a3ab7c..7ddd731a53fd 100644 --- a/include/configs/cgtqmx8.h +++ b/include/configs/cgtqmx8.h @@ -12,13 +12,11 @@ #include <asm/arch/imx-regs.h>
#ifdef CONFIG_SPL_BUILD -#define CONFIG_SPL_TEXT_BASE 0x0 #define CONFIG_SPL_MAX_SIZE (124 * 1024) #define CONFIG_SYS_MONITOR_LEN (1024 * 1024) #define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR #define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0x800
-#define CONFIG_SPL_LDSCRIPT "arch/arm/cpu/armv8/u-boot-spl.lds" #define CONFIG_SPL_STACK 0x013E000 #define CONFIG_SPL_BSS_START_ADDR 0x00128000 #define CONFIG_SPL_BSS_MAX_SIZE 0x1000 /* 4 KB */ diff --git a/include/configs/controlcenterdc.h b/include/configs/controlcenterdc.h index 21e61e5e8f52..5120c7b37770 100644 --- a/include/configs/controlcenterdc.h +++ b/include/configs/controlcenterdc.h @@ -72,13 +72,8 @@ #define CONFIG_SPL_STACK (0x40000000 + ((212 - 16) << 10)) #define CONFIG_SPL_BOOTROM_SAVE (CONFIG_SPL_STACK + 4)
-#define CONFIG_SPL_LIBCOMMON_SUPPORT -#define CONFIG_SPL_LIBGENERIC_SUPPORT -#define CONFIG_SPL_I2C - #if CONFIG_SPL_BOOT_DEVICE == SPL_BOOT_SDIO_MMC_CARD /* SPL related MMC defines */ -#define CONFIG_SPL_MMC #ifdef CONFIG_SPL_BUILD #define CONFIG_FIXED_SDHCI_ALIGNED_BUFFER 0x00180000 /* in SDRAM */ #endif diff --git a/include/configs/imx6-engicam.h b/include/configs/imx6-engicam.h index 238d61549cf4..fed6545fdf9f 100644 --- a/include/configs/imx6-engicam.h +++ b/include/configs/imx6-engicam.h @@ -162,12 +162,6 @@
/* SPL */ #ifdef CONFIG_SPL -# ifdef CONFIG_ENV_IS_IN_NAND -# define CONFIG_SPL_NAND_SUPPORT -# else -# define CONFIG_SPL_MMC -# endif - # include "imx6_spl.h" #endif
diff --git a/include/configs/imx8mp_evk.h b/include/configs/imx8mp_evk.h index 2427603d008b..1c636d94f6f7 100644 --- a/include/configs/imx8mp_evk.h +++ b/include/configs/imx8mp_evk.h @@ -20,7 +20,6 @@
#ifdef CONFIG_SPL_BUILD /*#define CONFIG_ENABLE_DDR_TRAINING_DEBUG*/ -#define CONFIG_SPL_LDSCRIPT "arch/arm/cpu/armv8/u-boot-spl.lds" #define CONFIG_SPL_STACK 0x960000 #define CONFIG_SPL_BSS_START_ADDR 0x0098FC00 #define CONFIG_SPL_BSS_MAX_SIZE 0x400 /* 1 KB */ diff --git a/include/configs/imx8mq_evk.h b/include/configs/imx8mq_evk.h index dd768eb08642..53fbeffb453f 100644 --- a/include/configs/imx8mq_evk.h +++ b/include/configs/imx8mq_evk.h @@ -19,16 +19,7 @@
#ifdef CONFIG_SPL_BUILD /*#define CONFIG_ENABLE_DDR_TRAINING_DEBUG*/ -#define CONFIG_SPL_WATCHDOG -#define CONFIG_SPL_DRIVERS_MISC -#define CONFIG_SPL_POWER -#define CONFIG_SPL_I2C -#define CONFIG_SPL_LDSCRIPT "arch/arm/cpu/armv8/u-boot-spl.lds" #define CONFIG_SPL_STACK 0x187FF0 -#define CONFIG_SPL_LIBCOMMON_SUPPORT -#define CONFIG_SPL_LIBGENERIC_SUPPORT -#define CONFIG_SPL_GPIO -#define CONFIG_SPL_MMC #define CONFIG_SPL_BSS_START_ADDR 0x00180000 #define CONFIG_SPL_BSS_MAX_SIZE 0x2000 /* 8 KB */ #define CONFIG_SYS_SPL_MALLOC_START 0x42200000 diff --git a/include/configs/imx8mq_phanbell.h b/include/configs/imx8mq_phanbell.h index e6575da4746e..d17f70fc4b23 100644 --- a/include/configs/imx8mq_phanbell.h +++ b/include/configs/imx8mq_phanbell.h @@ -16,16 +16,7 @@
#ifdef CONFIG_SPL_BUILD /*#define CONFIG_ENABLE_DDR_TRAINING_DEBUG*/ -#define CONFIG_SPL_WATCHDOG -#define CONFIG_SPL_DRIVERS_MISC -#define CONFIG_SPL_POWER -#define CONFIG_SPL_I2C -#define CONFIG_SPL_LDSCRIPT "arch/arm/cpu/armv8/u-boot-spl.lds" #define CONFIG_SPL_STACK 0x187FF0 -#define CONFIG_SPL_LIBCOMMON_SUPPORT -#define CONFIG_SPL_LIBGENERIC_SUPPORT -#define CONFIG_SPL_GPIO -#define CONFIG_SPL_MMC #define CONFIG_SPL_BSS_START_ADDR 0x00180000 #define CONFIG_SPL_BSS_MAX_SIZE 0x2000 /* 8 KB */ #define CONFIG_SYS_SPL_MALLOC_START 0x42200000 diff --git a/include/configs/imx8qm_mek.h b/include/configs/imx8qm_mek.h index d3c3e580acb1..11b5c16e37ef 100644 --- a/include/configs/imx8qm_mek.h +++ b/include/configs/imx8qm_mek.h @@ -18,7 +18,6 @@ #define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR #define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0x800
-#define CONFIG_SPL_LDSCRIPT "arch/arm/cpu/armv8/u-boot-spl.lds" #define CONFIG_SPL_STACK 0x013E000 #define CONFIG_SPL_BSS_START_ADDR 0x00128000 #define CONFIG_SPL_BSS_MAX_SIZE 0x1000 /* 4 KB */ diff --git a/include/configs/imx8qxp_mek.h b/include/configs/imx8qxp_mek.h index 3b1f957364c9..f59a9ef5e2c2 100644 --- a/include/configs/imx8qxp_mek.h +++ b/include/configs/imx8qxp_mek.h @@ -16,7 +16,6 @@ #define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR #define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0x800
-#define CONFIG_SPL_LDSCRIPT "arch/arm/cpu/armv8/u-boot-spl.lds" #define CONFIG_SPL_STACK 0x013E000 #define CONFIG_SPL_BSS_START_ADDR 0x00128000 #define CONFIG_SPL_BSS_MAX_SIZE 0x1000 /* 4 KB */ diff --git a/include/configs/imx8ulp_evk.h b/include/configs/imx8ulp_evk.h index 8e9a159e9b37..919eb5fff241 100644 --- a/include/configs/imx8ulp_evk.h +++ b/include/configs/imx8ulp_evk.h @@ -18,7 +18,6 @@ #define CONFIG_SYS_UBOOT_BASE (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512)
#ifdef CONFIG_SPL_BUILD -#define CONFIG_SPL_LDSCRIPT "arch/arm/cpu/armv8/u-boot-spl.lds" #define CONFIG_SPL_STACK 0x22050000 #define CONFIG_SPL_BSS_START_ADDR 0x22048000 #define CONFIG_SPL_BSS_MAX_SIZE 0x2000 /* 8 KB */ @@ -27,8 +26,6 @@
#define CONFIG_MALLOC_F_ADDR 0x22040000
-#define CONFIG_SPL_LOAD_FIT_ADDRESS 0x95000000 /* SPL_RAM needed */ - #define CONFIG_SPL_ABORT_ON_RAW_IMAGE /* For RAW image gives a error info not panic */
#endif diff --git a/include/configs/ls1021aiot.h b/include/configs/ls1021aiot.h index 7a7640a49c73..f73dafef0534 100644 --- a/include/configs/ls1021aiot.h +++ b/include/configs/ls1021aiot.h @@ -48,12 +48,6 @@ #define SDRAM_CFG_BI 0x00000001
#ifdef CONFIG_SD_BOOT -#define CONFIG_SPL_LIBCOMMON_SUPPORT -#define CONFIG_SPL_LIBGENERIC_SUPPORT -#define CONFIG_SPL_ENV_SUPPORT -#define CONFIG_SPL_I2C -#define CONFIG_SPL_WATCHDOG -#define CONFIG_SPL_MMC #define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0xe8
#define CONFIG_SPL_MAX_SIZE 0x1a000 diff --git a/include/configs/ls1046a_common.h b/include/configs/ls1046a_common.h index f199c94ed10b..7822e9d9faf2 100644 --- a/include/configs/ls1046a_common.h +++ b/include/configs/ls1046a_common.h @@ -95,14 +95,7 @@ /* NAND SPL */ #ifdef CONFIG_NAND_BOOT #define CONFIG_SPL_PBL_PAD -#define CONFIG_SPL_LIBCOMMON_SUPPORT -#define CONFIG_SPL_LIBGENERIC_SUPPORT -#define CONFIG_SPL_ENV_SUPPORT -#define CONFIG_SPL_WATCHDOG -#define CONFIG_SPL_I2C - -#define CONFIG_SPL_NAND_SUPPORT -#define CONFIG_SPL_DRIVERS_MISC + #define CONFIG_SPL_MAX_SIZE 0x17000 /* 90 KiB */ #define CONFIG_SPL_STACK 0x1001f000 #define CONFIG_SYS_NAND_U_BOOT_DST CONFIG_SYS_TEXT_BASE diff --git a/include/configs/ls1088a_common.h b/include/configs/ls1088a_common.h index 9ae0b8e0ae4f..c816ee16f2ad 100644 --- a/include/configs/ls1088a_common.h +++ b/include/configs/ls1088a_common.h @@ -204,7 +204,6 @@ unsigned long long get_qixis_addr(void); #ifdef CONFIG_SPL #define CONFIG_SPL_BSS_START_ADDR 0x80100000 #define CONFIG_SPL_BSS_MAX_SIZE 0x00100000 -#define CONFIG_SPL_LDSCRIPT "arch/arm/cpu/armv8/u-boot-spl.lds" #define CONFIG_SPL_MAX_SIZE 0x16000 #define CONFIG_SPL_STACK (CONFIG_SYS_FSL_OCRAM_BASE + 0x9ff0) #define CONFIG_SPL_TARGET "u-boot-with-spl.bin" diff --git a/include/configs/mccmon6.h b/include/configs/mccmon6.h index a0803227c88f..11b9ceb54756 100644 --- a/include/configs/mccmon6.h +++ b/include/configs/mccmon6.h @@ -9,7 +9,6 @@
#include "mx6_common.h"
-#define CONFIG_SPL_LIBCOMMON_SUPPORT #include "imx6_spl.h"
#define CONFIG_SYS_UBOOT_BASE (CONFIG_SYS_FLASH_BASE + 0x80000) diff --git a/include/configs/mx6_common.h b/include/configs/mx6_common.h index 5c0b729ccd97..983402f7df8b 100644 --- a/include/configs/mx6_common.h +++ b/include/configs/mx6_common.h @@ -39,8 +39,4 @@
/* MMC */
-#ifdef CONFIG_SPL_BUILD -#define CONFIG_SPL_DRIVERS_MISC -#endif - #endif diff --git a/include/configs/mx7_common.h b/include/configs/mx7_common.h index eeb535efa1b8..32b44fe92412 100644 --- a/include/configs/mx7_common.h +++ b/include/configs/mx7_common.h @@ -38,10 +38,6 @@
#define CONFIG_ARMV7_SECURE_BASE 0x00900000
-#ifdef CONFIG_SPL_BUILD -#define CONFIG_SPL_DRIVERS_MISC -#endif - /* * If we have defined the OPTEE ram size and not OPTEE it means that we were * launched by OPTEE, because of that we shall skip all the low level diff --git a/include/configs/mxs.h b/include/configs/mxs.h index 51624a27c465..591c57218400 100644 --- a/include/configs/mxs.h +++ b/include/configs/mxs.h @@ -45,7 +45,6 @@
/* SPL */ #ifndef CONFIG_SPL_FRAMEWORK -#define CONFIG_SPL_NO_CPU_SUPPORT #define CONFIG_SPL_START_S_PATH "arch/arm/cpu/arm926ejs/mxs" #endif
diff --git a/include/configs/phycore_imx8mp.h b/include/configs/phycore_imx8mp.h index 874c94e01f91..356544a67274 100644 --- a/include/configs/phycore_imx8mp.h +++ b/include/configs/phycore_imx8mp.h @@ -20,7 +20,6 @@ (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512)
#ifdef CONFIG_SPL_BUILD -#define CONFIG_SPL_LDSCRIPT "arch/arm/cpu/armv8/u-boot-spl.lds" #define CONFIG_SPL_STACK 0x960000 #define CONFIG_SPL_BSS_START_ADDR 0x98FC00 #define CONFIG_SPL_BSS_MAX_SIZE SZ_1K diff --git a/include/configs/pico-imx8mq.h b/include/configs/pico-imx8mq.h index f8805a12e416..2afcf0059d50 100644 --- a/include/configs/pico-imx8mq.h +++ b/include/configs/pico-imx8mq.h @@ -16,16 +16,7 @@
#ifdef CONFIG_SPL_BUILD /*#define CONFIG_ENABLE_DDR_TRAINING_DEBUG*/ -#define CONFIG_SPL_WATCHDOG -#define CONFIG_SPL_DRIVERS_MISC -#define CONFIG_SPL_POWER -#define CONFIG_SPL_I2C -#define CONFIG_SPL_LDSCRIPT "arch/arm/cpu/armv8/u-boot-spl.lds" #define CONFIG_SPL_STACK 0x187FF0 -#define CONFIG_SPL_LIBCOMMON_SUPPORT -#define CONFIG_SPL_LIBGENERIC_SUPPORT -#define CONFIG_SPL_GPIO -#define CONFIG_SPL_MMC #define CONFIG_SPL_BSS_START_ADDR 0x00180000 #define CONFIG_SPL_BSS_MAX_SIZE 0x2000 /* 8 KB */ #define CONFIG_SYS_SPL_MALLOC_START 0x42200000 diff --git a/include/configs/sama5d27_wlsom1_ek.h b/include/configs/sama5d27_wlsom1_ek.h index 09ebf4886010..e611e7b51047 100644 --- a/include/configs/sama5d27_wlsom1_ek.h +++ b/include/configs/sama5d27_wlsom1_ek.h @@ -27,7 +27,6 @@ #endif
/* SPL */ -#define CONFIG_SPL_TEXT_BASE 0x200000 #define CONFIG_SPL_MAX_SIZE 0x10000 #define CONFIG_SPL_BSS_START_ADDR 0x20000000 #define CONFIG_SPL_BSS_MAX_SIZE 0x80000 diff --git a/include/configs/smartweb.h b/include/configs/smartweb.h index 2538287e4cfd..f43304d8448b 100644 --- a/include/configs/smartweb.h +++ b/include/configs/smartweb.h @@ -137,8 +137,6 @@
#ifdef CONFIG_SPL_BUILD #define CONFIG_SYS_INIT_SP_ADDR 0x301000 -#define CONFIG_SPL_STACK_R -#define CONFIG_SPL_STACK_R_ADDR CONFIG_SYS_TEXT_BASE #else /* * Initial stack pointer: 4k - GENERATED_GBL_DATA_SIZE in internal SRAM, diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index c576d65efaf8..7260eb72a40f 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -48,7 +48,6 @@ /* Note SPL_STACK_R_ADDR is set through Kconfig, we include it here * since it needs to fit in with the other values. By also #defining it * we get warnings if the Kconfig value mismatches. */ -#define CONFIG_SPL_STACK_R_ADDR 0x2fe00000 #define CONFIG_SPL_BSS_START_ADDR 0x2ff80000 #else #define SDRAM_OFFSET(x) 0x4##x @@ -57,7 +56,6 @@ /* Note SPL_STACK_R_ADDR is set through Kconfig, we include it here * since it needs to fit in with the other values. By also #defining it * we get warnings if the Kconfig value mismatches. */ -#define CONFIG_SPL_STACK_R_ADDR 0x4fe00000 #define CONFIG_SPL_BSS_START_ADDR 0x4ff80000 #endif
diff --git a/include/configs/topic_miami.h b/include/configs/topic_miami.h index 18179e9b7e91..cbb5c6dea032 100644 --- a/include/configs/topic_miami.h +++ b/include/configs/topic_miami.h @@ -22,9 +22,6 @@ #define CONFIG_SPL_MAX_FOOTPRINT CONFIG_SYS_SPI_U_BOOT_OFFS #define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img"
-/* No falcon support */ -#undef CONFIG_SPL_OS_BOOT - /* FPGA commands that we don't use */
/* Extras */ diff --git a/include/configs/vyasa-rk3288.h b/include/configs/vyasa-rk3288.h index 3dc10b29c3fa..87259258f77b 100644 --- a/include/configs/vyasa-rk3288.h +++ b/include/configs/vyasa-rk3288.h @@ -21,9 +21,6 @@ func(MMC, mmc, 1) \
#ifndef CONFIG_TPL_BUILD - -#define CONFIG_SPL_OS_BOOT - /* Falcon Mode */ #define CONFIG_SPL_FS_LOAD_ARGS_NAME "args" #define CONFIG_SPL_FS_LOAD_KERNEL_NAME "uImage" diff --git a/include/configs/xilinx_zynqmp.h b/include/configs/xilinx_zynqmp.h index f8607b761728..e21480578750 100644 --- a/include/configs/xilinx_zynqmp.h +++ b/include/configs/xilinx_zynqmp.h @@ -251,7 +251,6 @@ #endif
#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_DFU) -# define CONFIG_SPL_ENV_SUPPORT # define CONFIG_SPL_HASH # define CONFIG_ENV_MAX_ENTRIES 10 #endif
This converts the following to Kconfig: CONFIG_BOARD_EARLY_INIT_F CONFIG_BOARD_LATE_INIT CONFIG_DISPLAY_BOARDINFO CONFIG_DISPLAY_BOARDINFO_LATE
Signed-off-by: Tom Rini trini@konsulko.com --- configs/apalis-imx8_defconfig | 1 + configs/cgtqmx8_defconfig | 1 + configs/colibri-imx8x_defconfig | 1 + configs/imx8ulp_evk_defconfig | 2 ++ configs/r2dplus_defconfig | 1 + configs/stm32f746-disco_defconfig | 1 - configs/stm32f769-disco_defconfig | 1 - configs/x530_defconfig | 1 + include/configs/apalis-imx8.h | 2 -- include/configs/apalis_imx6.h | 2 -- include/configs/cgtqmx8.h | 2 -- include/configs/colibri-imx8x.h | 2 -- include/configs/colibri_imx6.h | 2 -- include/configs/imx8ulp_evk.h | 3 --- include/configs/r2dplus.h | 2 -- include/configs/stm32f746-disco.h | 2 -- include/configs/topic_miami.h | 1 - include/configs/x530.h | 2 -- 18 files changed, 7 insertions(+), 22 deletions(-)
diff --git a/configs/apalis-imx8_defconfig b/configs/apalis-imx8_defconfig index a92204a9f95a..92ec9c6dd321 100644 --- a/configs/apalis-imx8_defconfig +++ b/configs/apalis-imx8_defconfig @@ -17,6 +17,7 @@ CONFIG_FIT=y CONFIG_OF_SYSTEM_SETUP=y CONFIG_LOG=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_CMD_CPU=y # CONFIG_BOOTM_NETBSD is not set diff --git a/configs/cgtqmx8_defconfig b/configs/cgtqmx8_defconfig index 4abe29e1d229..3c86663f2755 100644 --- a/configs/cgtqmx8_defconfig +++ b/configs/cgtqmx8_defconfig @@ -23,6 +23,7 @@ CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" CONFIG_BOOTDELAY=3 CONFIG_LOG=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SEPARATE_BSS=y CONFIG_SYS_MMCSD_FS_BOOT_PARTITION=0 diff --git a/configs/colibri-imx8x_defconfig b/configs/colibri-imx8x_defconfig index ea0679602647..76da33e80364 100644 --- a/configs/colibri-imx8x_defconfig +++ b/configs/colibri-imx8x_defconfig @@ -16,6 +16,7 @@ CONFIG_SYS_LOAD_ADDR=0x80280000 CONFIG_FIT=y CONFIG_LOG=y # CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_CMD_CPU=y # CONFIG_BOOTM_NETBSD is not set diff --git a/configs/imx8ulp_evk_defconfig b/configs/imx8ulp_evk_defconfig index 23afbbb914dd..2a627f9df055 100644 --- a/configs/imx8ulp_evk_defconfig +++ b/configs/imx8ulp_evk_defconfig @@ -25,6 +25,8 @@ CONFIG_FIT_VERBOSE=y CONFIG_BOOTDELAY=0 CONFIG_BOOTCOMMAND="run distro_bootcmd;run bsp_bootcmd" CONFIG_DEFAULT_FDT_FILE="imx8ulp-evk" +CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_BOARD_LATE_INIT=y CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_BOOTROM_SUPPORT=y CONFIG_SPL_SEPARATE_BSS=y diff --git a/configs/r2dplus_defconfig b/configs/r2dplus_defconfig index 16a24c30b214..ff7dc8560d8d 100644 --- a/configs/r2dplus_defconfig +++ b/configs/r2dplus_defconfig @@ -11,6 +11,7 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttySC0,115200" CONFIG_USE_PREBOOT=y CONFIG_PREBOOT="pci enum" +CONFIG_DISPLAY_BOARDINFO=y CONFIG_HUSH_PARSER=y CONFIG_CMD_IMLS=y CONFIG_CMD_DM=y diff --git a/configs/stm32f746-disco_defconfig b/configs/stm32f746-disco_defconfig index e5e7ef798c39..864ea871041f 100644 --- a/configs/stm32f746-disco_defconfig +++ b/configs/stm32f746-disco_defconfig @@ -19,7 +19,6 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk consoleblank=0 ignore_loglevel" # CONFIG_USE_BOOTCOMMAND is not set # CONFIG_DISPLAY_CPUINFO is not set -# CONFIG_DISPLAY_BOARDINFO is not set CONFIG_BOARD_LATE_INIT=y CONFIG_SYS_PROMPT="U-Boot > " CONFIG_CMD_GPT=y diff --git a/configs/stm32f769-disco_defconfig b/configs/stm32f769-disco_defconfig index bb122d691d56..aa04fe3dfbcc 100644 --- a/configs/stm32f769-disco_defconfig +++ b/configs/stm32f769-disco_defconfig @@ -19,7 +19,6 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk consoleblank=0 ignore_loglevel" # CONFIG_USE_BOOTCOMMAND is not set # CONFIG_DISPLAY_CPUINFO is not set -# CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SYS_PROMPT="U-Boot > " CONFIG_CMD_GPT=y # CONFIG_RANDOM_UUID is not set diff --git a/configs/x530_defconfig b/configs/x530_defconfig index 6ba7ee2131e4..6f73eacfe9de 100644 --- a/configs/x530_defconfig +++ b/configs/x530_defconfig @@ -24,6 +24,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_SILENT_CONSOLE=y CONFIG_SILENT_U_BOOT_ONLY=y CONFIG_SILENT_CONSOLE_UPDATE_ON_RELOC=y +CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_MISC_INIT_R=y CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_WATCHDOG=y diff --git a/include/configs/apalis-imx8.h b/include/configs/apalis-imx8.h index b4411654880e..27007c57b3cd 100644 --- a/include/configs/apalis-imx8.h +++ b/include/configs/apalis-imx8.h @@ -11,8 +11,6 @@
-#define CONFIG_DISPLAY_BOARDINFO_LATE - #define CONFIG_SYS_FSL_ESDHC_ADDR 0 #define USDHC1_BASE_ADDR 0x5b010000 #define USDHC2_BASE_ADDR 0x5b020000 diff --git a/include/configs/apalis_imx6.h b/include/configs/apalis_imx6.h index 23fca1e447be..dfed1615b9be 100644 --- a/include/configs/apalis_imx6.h +++ b/include/configs/apalis_imx6.h @@ -12,8 +12,6 @@
-#undef CONFIG_DISPLAY_BOARDINFO - #include <asm/arch/imx-regs.h> #include <asm/mach-imx/gpio.h>
diff --git a/include/configs/cgtqmx8.h b/include/configs/cgtqmx8.h index 7ddd731a53fd..d9b59b98cdf8 100644 --- a/include/configs/cgtqmx8.h +++ b/include/configs/cgtqmx8.h @@ -32,8 +32,6 @@
-#define CONFIG_BOARD_EARLY_INIT_F - /* Flat Device Tree Definitions */ #define CONFIG_OF_BOARD_SETUP
diff --git a/include/configs/colibri-imx8x.h b/include/configs/colibri-imx8x.h index 03c363858669..82926afbdf60 100644 --- a/include/configs/colibri-imx8x.h +++ b/include/configs/colibri-imx8x.h @@ -12,8 +12,6 @@
-#define CONFIG_DISPLAY_BOARDINFO_LATE - #define CONFIG_SYS_FSL_ESDHC_ADDR 0 #define USDHC1_BASE_ADDR 0x5b010000 #define USDHC2_BASE_ADDR 0x5b020000 diff --git a/include/configs/colibri_imx6.h b/include/configs/colibri_imx6.h index 44135b2f2147..b103186bf463 100644 --- a/include/configs/colibri_imx6.h +++ b/include/configs/colibri_imx6.h @@ -12,8 +12,6 @@
diff --git a/include/configs/imx8ulp_evk.h b/include/configs/imx8ulp_evk.h index 919eb5fff241..3d506ba37f3d 100644 --- a/include/configs/imx8ulp_evk.h +++ b/include/configs/imx8ulp_evk.h @@ -32,9 +32,6 @@
-#define CONFIG_BOARD_EARLY_INIT_F -#define CONFIG_BOARD_LATE_INIT - /* ENET Config */ #if defined(CONFIG_FEC_MXC) #define CONFIG_ETHPRIME "FEC" diff --git a/include/configs/r2dplus.h b/include/configs/r2dplus.h index 36930fa3f1a7..58ca6c28b53f 100644 --- a/include/configs/r2dplus.h +++ b/include/configs/r2dplus.h @@ -4,8 +4,6 @@ #define CONFIG_CPU_SH7751 1 #define __LITTLE_ENDIAN__ 1
-#define CONFIG_DISPLAY_BOARDINFO - /* SCIF */ #define CONFIG_CONS_SCIF1 1
diff --git a/include/configs/stm32f746-disco.h b/include/configs/stm32f746-disco.h index 493699e9507e..2f2a349dcdcd 100644 --- a/include/configs/stm32f746-disco.h +++ b/include/configs/stm32f746-disco.h @@ -42,8 +42,6 @@ "ramdisk_addr_r=0xC0438000\0" \ BOOTENV
-#define CONFIG_DISPLAY_BOARDINFO - /* For SPL */ #ifdef CONFIG_SUPPORT_SPL #define CONFIG_SPL_STACK CONFIG_SYS_INIT_SP_ADDR diff --git a/include/configs/topic_miami.h b/include/configs/topic_miami.h index cbb5c6dea032..88bb4a8fd5ed 100644 --- a/include/configs/topic_miami.h +++ b/include/configs/topic_miami.h @@ -98,6 +98,5 @@ #define CONFIG_BOOTCOMMAND "if mmcinfo; then " \ "if fatload mmc 0 0x1900000 ${bootscript}; then source 0x1900000; " \ "fi; fi; run $modeboot" -#undef CONFIG_DISPLAY_BOARDINFO
#endif /* __CONFIG_TOPIC_MIAMI_H */ diff --git a/include/configs/x530.h b/include/configs/x530.h index f4d64495ffaf..e78e249e41ae 100644 --- a/include/configs/x530.h +++ b/include/configs/x530.h @@ -10,8 +10,6 @@ * High Level Configuration Options (easy to change) */
-#define CONFIG_DISPLAY_BOARDINFO_LATE - /* * NS16550 Configuration */
On Sat, Oct 30, 2021 at 11:03:48PM -0400, Tom Rini wrote:
When building a system that has both TPL and SPL_OS_BOOT, code which tests for CONFIG_SPL_OS_BOOT will be built and enabled in TPL, which is not correct. While there is no CONFIG_TPL_OS_BOOT symbol at this time (and likely will not ever be) we can use CONFIG_IS_ENABLED(OS_BOOT) in these common paths to ensure we only compile these parts in the SPL case.
