Fwd: New Defects reported by Coverity Scan for Das U-Boot
I've now updated to the latest Coverity scan tool and that eliminated some previous defects and found two new ones:
---------- Forwarded message --------- From: scan-admin@coverity.com Date: Mon, Jan 22, 2024 at 6:42 PM Subject: New Defects reported by Coverity Scan for Das U-Boot To: tom.rini@gmail.com
Please find the latest report on new defect(s) introduced to Das U-Boot found with Coverity Scan.
2 new defect(s) introduced to Das U-Boot found with Coverity Scan. 8 defect(s), reported by Coverity Scan earlier, were marked fixed in the recent build analyzed by Coverity Scan.
New defect(s) Reported-by: Coverity Scan Showing 2 of 2 defect(s)
** CID 478862: Memory - corruptions (OVERRUN)
________________________________________________________________________________________________________ *** CID 478862: Memory - corruptions (OVERRUN) /lib/initcall.c: 82 in initcall_run_list() 76 if (ret) { 77 if (CONFIG_IS_ENABLED(EVENT)) { 78 char buf[60]; 79 80 /* don't worry about buf size as we are dying here */ 81 if (type) {
CID 478862: Memory - corruptions (OVERRUN) Overrunning callee's array of size 15 by passing argument "type" (which evaluates to 255) in call to "event_type_name".
82 sprintf(buf, "event %d/%s", type, 83 event_type_name(type)); 84 } else { 85 sprintf(buf, "call %p", func); 86 } 87
** CID 478861: Memory - corruptions (OVERRUN)
________________________________________________________________________________________________________ *** CID 478861: Memory - corruptions (OVERRUN) /cmd/nvedit.c: 356 in print_static_flags() 350 static int print_static_flags(const char *var_name, const char *flags, 351 void *priv) 352 { 353 enum env_flags_vartype type = env_flags_parse_vartype(flags); 354 enum env_flags_varaccess access = env_flags_parse_varaccess(flags); 355
CID 478861: Memory - corruptions (OVERRUN) Overrunning callee's array of size 4 by passing argument "access" (which evaluates to 4) in call to "env_flags_get_varaccess_name".
356 printf("\t%-20s %-20s %-20s\n", var_name, 357 env_flags_get_vartype_name(type), 358 env_flags_get_varaccess_name(access)); 359 360 return 0; 361 }
