[U-Boot] [PATCH][v2] driver: net: fsl-mc: Use aligned address for MC FW load
Firmware of Management Complex (MC) should be loaded at 512MB aligned address. So, -mc_ram_addr address calculation in mc_get_dram_addr() is updated to fetch aligned address -calculate_mc_private_ram_params() is removed as it is no longer required -num_256mb_blocks calculation is moved to mc_init()
Signed-off-by: Priyanka Jain priyanka.jain@nxp.com --- Changes for v2: Update mc_get_dram_addr() logic for adress calculation instead of updating variable mc_ram_addr
drivers/net/fsl-mc/mc.c | 87 ++++++++++++++++++----------------------------- 1 files changed, 33 insertions(+), 54 deletions(-)
diff --git a/drivers/net/fsl-mc/mc.c b/drivers/net/fsl-mc/mc.c index 46b8a6b..06d373d 100644 --- a/drivers/net/fsl-mc/mc.c +++ b/drivers/net/fsl-mc/mc.c @@ -41,6 +41,7 @@ struct fsl_dpbp_obj *dflt_dpbp = NULL; struct fsl_dpio_obj *dflt_dpio = NULL; struct fsl_dpni_obj *dflt_dpni = NULL; static u64 mc_lazy_dpl_addr; +u64 mc_ram_addr = 0;
#ifdef DEBUG void dump_ram_words(const char *title, void *addr) @@ -153,48 +154,6 @@ int parse_mc_firmware_fit_image(u64 mc_fw_addr, } #endif
-/* - * Calculates the values to be used to specify the address range - * for the MC private DRAM block, in the MCFBALR/MCFBAHR registers. - * It returns the highest 512MB-aligned address within the given - * address range, in '*aligned_base_addr', and the number of 256 MiB - * blocks in it, in 'num_256mb_blocks'. - */ -static int calculate_mc_private_ram_params(u64 mc_private_ram_start_addr, - size_t mc_ram_size, - u64 *aligned_base_addr, - u8 *num_256mb_blocks) -{ - u64 addr; - u16 num_blocks; - - if (mc_ram_size % MC_RAM_SIZE_ALIGNMENT != 0) { - printf("fsl-mc: ERROR: invalid MC private RAM size (%lu)\n", - mc_ram_size); - return -EINVAL; - } - - num_blocks = mc_ram_size / MC_RAM_SIZE_ALIGNMENT; - if (num_blocks < 1 || num_blocks > 0xff) { - printf("fsl-mc: ERROR: invalid MC private RAM size (%lu)\n", - mc_ram_size); - return -EINVAL; - } - - addr = (mc_private_ram_start_addr + mc_ram_size - 1) & - MC_RAM_BASE_ADDR_ALIGNMENT_MASK; - - if (addr < mc_private_ram_start_addr) { - printf("fsl-mc: ERROR: bad start address %#llx\n", - mc_private_ram_start_addr); - return -EFAULT; - } - - *aligned_base_addr = addr; - *num_256mb_blocks = num_blocks; - return 0; -} - static int mc_fixup_dpc(u64 dpc_addr) { void *blob = (void *)dpc_addr; @@ -443,7 +402,6 @@ int mc_init(u64 mc_fw_addr, u64 mc_dpc_addr) int error = 0; int portal_id = 0; struct mc_ccsr_registers __iomem *mc_ccsr_regs = MC_CCSR_BASE_ADDR; - u64 mc_ram_addr = mc_get_dram_addr(); u32 reg_gsr; u32 reg_mcfbalr; #ifndef CONFIG_SYS_LS_MC_FW_IN_DDR @@ -451,17 +409,18 @@ int mc_init(u64 mc_fw_addr, u64 mc_dpc_addr) size_t raw_image_size = 0; #endif struct mc_version mc_ver_info; - u64 mc_ram_aligned_base_addr; u8 mc_ram_num_256mb_blocks; size_t mc_ram_size = mc_get_dram_block_size();
- error = calculate_mc_private_ram_params(mc_ram_addr, - mc_ram_size, - &mc_ram_aligned_base_addr, - &mc_ram_num_256mb_blocks); - if (error != 0) + mc_ram_num_256mb_blocks = mc_ram_size / MC_RAM_SIZE_ALIGNMENT; + if (mc_ram_num_256mb_blocks < 1 || mc_ram_num_256mb_blocks > 0xff) { + printf("fsl-mc: ERROR: invalid MC private RAM size (%lu)\n", + mc_ram_size); goto out; + } + + mc_ram_addr = mc_get_dram_addr();
/* * Management Complex cores should be held at reset out of POR. @@ -503,11 +462,11 @@ int mc_init(u64 mc_fw_addr, u64 mc_dpc_addr) /* * Tell MC what is the address range of the DRAM block assigned to it: */ - reg_mcfbalr = (u32)mc_ram_aligned_base_addr | + reg_mcfbalr = (u32)mc_ram_addr | (mc_ram_num_256mb_blocks - 1); out_le32(&mc_ccsr_regs->reg_mcfbalr, reg_mcfbalr); out_le32(&mc_ccsr_regs->reg_mcfbahr, - (u32)(mc_ram_aligned_base_addr >> 32)); + (u32)(mc_ram_addr >> 32)); out_le32(&mc_ccsr_regs->reg_mcfapr, FSL_BYPASS_AMQ);
/* @@ -615,20 +574,40 @@ int get_dpl_apply_status(void) */ u64 mc_get_dram_addr(void) { - u64 mc_ram_addr; + u64 mc_private_ram_start_addr; + size_t mc_ram_size = mc_get_dram_block_size();
/* * The MC private DRAM block was already carved at the end of DRAM * by board_init_f() using CONFIG_SYS_MEM_TOP_HIDE: */ if (gd->bd->bi_dram[1].start) { - mc_ram_addr = + mc_private_ram_start_addr = gd->bd->bi_dram[1].start + gd->bd->bi_dram[1].size; } else { - mc_ram_addr = + mc_private_ram_start_addr = gd->bd->bi_dram[0].start + gd->bd->bi_dram[0].size; }
+ if (mc_ram_size == 0) { + printf("fsl-mc: ERROR: invalid MC private RAM size (%lu)\n", + mc_ram_size); + return -EINVAL; + } + + /* + * Calculate the highest 512MB aligned address within the + * given address range + */ + mc_ram_addr = (mc_private_ram_start_addr - 1 + + MC_RAM_BASE_ADDR_ALIGNMENT) & + MC_RAM_BASE_ADDR_ALIGNMENT_MASK; + + if (mc_ram_addr < mc_private_ram_start_addr) { + printf("fsl-mc: ERROR: bad start address %#llx\n", + mc_private_ram_start_addr); + return -EFAULT; + } return mc_ram_addr; }
You have global variable with the same name as local variable. It is confusing to me. Please avoid using global variable.
York
Priyanka Jain
york sun
