[U-Boot] [PATCH] Revert "spl: eMMC/SD: Provide one __weak spl_boot_mode() function"
This reverts commit d695d6627803dbb78a226e04b0436a01633a9936.
Commit d695d6627803 ("spl: eMMC/SD: Provide one __weak spl_boot_mode() function") breaks the build on several i.MX6 boards, such as cuboxi and wandboard:
U-Boot SPL 2018.03-rc1-00212-g48914fc119 (Feb 10 2018 - 11:04:33 +1300) Trying to boot from MMC1 Failed to mount ext2 filesystem... spl_load_image_ext: ext4fs mount err - 0
Revert it so that we can boot U-Boot again.
Reported-by: Jonathan Gray jsg@jsg.id.au Signed-off-by: Fabio Estevam fabio.estevam@nxp.com --- arch/arm/cpu/arm1136/mx35/generic.c | 21 +++++++++++++++++++++ arch/arm/cpu/armv7/ls102xa/spl.c | 17 +++++++++++++++++ arch/arm/cpu/armv8/fsl-layerscape/spl.c | 17 +++++++++++++++++ arch/arm/cpu/armv8/zynqmp/spl.c | 14 ++++++++++++++ arch/arm/mach-at91/spl.c | 15 +++++++++++++++ arch/arm/mach-davinci/spl.c | 5 +++++ arch/arm/mach-imx/spl.c | 23 +++++++++++++++++++++++ arch/arm/mach-mvebu/spl.c | 7 +++++++ arch/arm/mach-rockchip/rk3188-board-spl.c | 5 +++++ arch/arm/mach-rockchip/rk3288-board-spl.c | 5 +++++ arch/arm/mach-rockchip/rk3368-board-spl.c | 5 +++++ arch/arm/mach-rockchip/rk3399-board-spl.c | 5 +++++ arch/arm/mach-socfpga/spl.c | 11 +++++++++++ arch/arm/mach-sunxi/board.c | 6 ++++++ arch/arm/mach-zynq/spl.c | 7 +++++++ common/spl/spl_mmc.c | 11 ----------- 16 files changed, 163 insertions(+), 11 deletions(-)
diff --git a/arch/arm/cpu/arm1136/mx35/generic.c b/arch/arm/cpu/arm1136/mx35/generic.c index 4dcfc72..5297d62 100644 --- a/arch/arm/cpu/arm1136/mx35/generic.c +++ b/arch/arm/cpu/arm1136/mx35/generic.c @@ -524,3 +524,24 @@ u32 spl_boot_device(void)
return BOOT_DEVICE_NONE; } + +#ifdef CONFIG_SPL_BUILD +u32 spl_boot_mode(const u32 boot_device) +{ + switch (spl_boot_device()) { + case BOOT_DEVICE_MMC1: +#ifdef CONFIG_SPL_FAT_SUPPORT + return MMCSD_MODE_FS; +#else + return MMCSD_MODE_RAW; +#endif + break; + case BOOT_DEVICE_NAND: + return 0; + break; + default: + puts("spl: ERROR: unsupported device\n"); + hang(); + } +} +#endif diff --git a/arch/arm/cpu/armv7/ls102xa/spl.c b/arch/arm/cpu/armv7/ls102xa/spl.c index 1e4a164..1246eed 100644 --- a/arch/arm/cpu/armv7/ls102xa/spl.c +++ b/arch/arm/cpu/armv7/ls102xa/spl.c @@ -14,3 +14,20 @@ u32 spl_boot_device(void) #endif return BOOT_DEVICE_NAND; } + +u32 spl_boot_mode(const u32 boot_device) +{ + switch (spl_boot_device()) { + case BOOT_DEVICE_MMC1: +#ifdef CONFIG_SPL_FAT_SUPPORT + return MMCSD_MODE_FS; +#else + return MMCSD_MODE_RAW; +#endif + case BOOT_DEVICE_NAND: + return 0; + default: + puts("spl: error: unsupported device\n"); + hang(); + } +} diff --git a/arch/arm/cpu/armv8/fsl-layerscape/spl.c b/arch/arm/cpu/armv8/fsl-layerscape/spl.c index 3a74040..4093d15 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/spl.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/spl.c @@ -26,6 +26,23 @@ u32 spl_boot_device(void) return 0; }
+u32 spl_boot_mode(const u32 boot_device) +{ + switch (spl_boot_device()) { + case BOOT_DEVICE_MMC1: +#ifdef CONFIG_SPL_FAT_SUPPORT + return MMCSD_MODE_FS; +#else + return MMCSD_MODE_RAW; +#endif + case BOOT_DEVICE_NAND: + return 0; + default: + puts("spl: error: unsupported device\n"); + hang(); + } +} + #ifdef CONFIG_SPL_BUILD
void spl_board_init(void) diff --git a/arch/arm/cpu/armv8/zynqmp/spl.c b/arch/arm/cpu/armv8/zynqmp/spl.c index 0bfa5c1..bc7313a 100644 --- a/arch/arm/cpu/armv8/zynqmp/spl.c +++ b/arch/arm/cpu/armv8/zynqmp/spl.c @@ -115,6 +115,20 @@ u32 spl_boot_device(void) return 0; }
+u32 spl_boot_mode(const u32 boot_device) +{ + switch (boot_device) { + case BOOT_DEVICE_RAM: + return 0; + case BOOT_DEVICE_MMC1: + case BOOT_DEVICE_MMC2: + return MMCSD_MODE_FS; + default: + puts("spl: error: unsupported device\n"); + hang(); + } +} + #ifdef CONFIG_SPL_OS_BOOT int spl_start_uboot(void) { diff --git a/arch/arm/mach-at91/spl.c b/arch/arm/mach-at91/spl.c index 91add92..7e7e24b 100644 --- a/arch/arm/mach-at91/spl.c +++ b/arch/arm/mach-at91/spl.c @@ -87,3 +87,18 @@ u32 spl_boot_device(void) return BOOT_DEVICE_NONE; } #endif + +u32 spl_boot_mode(const u32 boot_device) +{ + switch (boot_device) { +#if defined(CONFIG_SYS_USE_MMC) || defined(CONFIG_SD_BOOT) + case BOOT_DEVICE_MMC1: + case BOOT_DEVICE_MMC2: + return MMCSD_MODE_FS; + break; +#endif + case BOOT_DEVICE_NONE: + default: + hang(); + } +} diff --git a/arch/arm/mach-davinci/spl.c b/arch/arm/mach-davinci/spl.c index 4c74db9..564c200 100644 --- a/arch/arm/mach-davinci/spl.c +++ b/arch/arm/mach-davinci/spl.c @@ -45,6 +45,11 @@ void spl_board_init(void) preloader_console_init(); }
+u32 spl_boot_mode(const u32 boot_device) +{ + return MMCSD_MODE_RAW; +} + u32 spl_boot_device(void) { switch (davinci_syscfg_regs->bootcfg) { diff --git a/arch/arm/mach-imx/spl.c b/arch/arm/mach-imx/spl.c index a9079fc..b2521b2 100644 --- a/arch/arm/mach-imx/spl.c +++ b/arch/arm/mach-imx/spl.c @@ -132,6 +132,29 @@ int g_dnl_bind_fixup(struct usb_device_descriptor *dev, const char *name) } #endif
+#if defined(CONFIG_SPL_MMC_SUPPORT) +/* called from spl_mmc to see type of boot mode for storage (RAW or FAT) */ +u32 spl_boot_mode(const u32 boot_device) +{ + switch (spl_boot_device()) { + /* for MMC return either RAW or FAT mode */ + case BOOT_DEVICE_MMC1: + case BOOT_DEVICE_MMC2: +#if defined(CONFIG_SPL_FAT_SUPPORT) + return MMCSD_MODE_FS; +#elif defined(CONFIG_SUPPORT_EMMC_BOOT) + return MMCSD_MODE_EMMCBOOT; +#else + return MMCSD_MODE_RAW; +#endif + break; + default: + puts("spl: ERROR: unsupported device\n"); + hang(); + } +} +#endif + #if defined(CONFIG_SECURE_BOOT)
/* diff --git a/arch/arm/mach-mvebu/spl.c b/arch/arm/mach-mvebu/spl.c index a5086f1..d16a62d 100644 --- a/arch/arm/mach-mvebu/spl.c +++ b/arch/arm/mach-mvebu/spl.c @@ -70,6 +70,13 @@ u32 spl_boot_device(void) return get_boot_device(); }
+#ifdef CONFIG_SPL_MMC_SUPPORT +u32 spl_boot_mode(const u32 boot_device) +{ + return MMCSD_MODE_RAW; +} +#endif + void board_init_f(ulong dummy) { int ret; diff --git a/arch/arm/mach-rockchip/rk3188-board-spl.c b/arch/arm/mach-rockchip/rk3188-board-spl.c index 74771d3..8e3b8ae 100644 --- a/arch/arm/mach-rockchip/rk3188-board-spl.c +++ b/arch/arm/mach-rockchip/rk3188-board-spl.c @@ -72,6 +72,11 @@ fallback: return BOOT_DEVICE_MMC1; }
+u32 spl_boot_mode(const u32 boot_device) +{ + return MMCSD_MODE_RAW; +} + static int setup_arm_clock(void) { struct udevice *dev; diff --git a/arch/arm/mach-rockchip/rk3288-board-spl.c b/arch/arm/mach-rockchip/rk3288-board-spl.c index f3ea624..f64a548 100644 --- a/arch/arm/mach-rockchip/rk3288-board-spl.c +++ b/arch/arm/mach-rockchip/rk3288-board-spl.c @@ -78,6 +78,11 @@ fallback: return BOOT_DEVICE_MMC1; }
+u32 spl_boot_mode(const u32 boot_device) +{ + return MMCSD_MODE_RAW; +} + #ifdef CONFIG_SPL_MMC_SUPPORT static int configure_emmc(struct udevice *pinctrl) { diff --git a/arch/arm/mach-rockchip/rk3368-board-spl.c b/arch/arm/mach-rockchip/rk3368-board-spl.c index 8055ae5..72d2c97 100644 --- a/arch/arm/mach-rockchip/rk3368-board-spl.c +++ b/arch/arm/mach-rockchip/rk3368-board-spl.c @@ -57,6 +57,11 @@ void board_init_f(ulong dummy) } }
+u32 spl_boot_mode(const u32 boot_device) +{ + return MMCSD_MODE_RAW; +} + u32 spl_boot_device(void) { return BOOT_DEVICE_MMC1; diff --git a/arch/arm/mach-rockchip/rk3399-board-spl.c b/arch/arm/mach-rockchip/rk3399-board-spl.c index d35990e..b96903e 100644 --- a/arch/arm/mach-rockchip/rk3399-board-spl.c +++ b/arch/arm/mach-rockchip/rk3399-board-spl.c @@ -60,6 +60,11 @@ u32 spl_boot_device(void) return boot_device; }
+u32 spl_boot_mode(const u32 boot_device) +{ + return MMCSD_MODE_RAW; +} + #define TIMER_CHN10_BASE 0xff8680a0 #define TIMER_END_COUNT_L 0x00 #define TIMER_END_COUNT_H 0x04 diff --git a/arch/arm/mach-socfpga/spl.c b/arch/arm/mach-socfpga/spl.c index 9bf3b9a..71bae82 100644 --- a/arch/arm/mach-socfpga/spl.c +++ b/arch/arm/mach-socfpga/spl.c @@ -66,6 +66,17 @@ u32 spl_boot_device(void) } }
+#ifdef CONFIG_SPL_MMC_SUPPORT +u32 spl_boot_mode(const u32 boot_device) +{ +#if defined(CONFIG_SPL_FAT_SUPPORT) || defined(CONFIG_SPL_EXT_SUPPORT) + return MMCSD_MODE_FS; +#else + return MMCSD_MODE_RAW; +#endif +} +#endif + #if defined(CONFIG_TARGET_SOCFPGA_GEN5) static void socfpga_nic301_slave_ns(void) { diff --git a/arch/arm/mach-sunxi/board.c b/arch/arm/mach-sunxi/board.c index 1753fae..0c60ee0 100644 --- a/arch/arm/mach-sunxi/board.c +++ b/arch/arm/mach-sunxi/board.c @@ -260,6 +260,12 @@ u32 spl_boot_device(void) return sunxi_get_boot_device(); }
+/* No confirmation data available in SPL yet. Hardcode bootmode */ +u32 spl_boot_mode(const u32 boot_device) +{ + return MMCSD_MODE_RAW; +} + void board_init_f(ulong dummy) { spl_init(); diff --git a/arch/arm/mach-zynq/spl.c b/arch/arm/mach-zynq/spl.c index 0a303f4..b7e6d98 100644 --- a/arch/arm/mach-zynq/spl.c +++ b/arch/arm/mach-zynq/spl.c @@ -69,6 +69,13 @@ u32 spl_boot_device(void) return mode; }
+#ifdef CONFIG_SPL_MMC_SUPPORT +u32 spl_boot_mode(const u32 boot_device) +{ + return MMCSD_MODE_FS; +} +#endif + #ifdef CONFIG_SPL_OS_BOOT int spl_start_uboot(void) { diff --git a/common/spl/spl_mmc.c b/common/spl/spl_mmc.c index 351f4ed..b57e0b0 100644 --- a/common/spl/spl_mmc.c +++ b/common/spl/spl_mmc.c @@ -281,17 +281,6 @@ static int spl_mmc_do_fs_boot(struct spl_image_info *spl_image, struct mmc *mmc) } #endif
-u32 __weak spl_boot_mode(const u32 boot_device) -{ -#if defined(CONFIG_SPL_FAT_SUPPORT) || defined(CONFIG_SPL_EXT_SUPPORT) - return MMCSD_MODE_FS; -#elif defined(CONFIG_SUPPORT_EMMC_BOOT) - return MMCSD_MODE_EMMCBOOT; -#else - return MMCSD_MODE_RAW; -#endif -} - int spl_mmc_load_image(struct spl_image_info *spl_image, struct spl_boot_device *bootdev) {
Fabio Estevam
