[U-Boot] [PATCH v4 0/2] rockchip: rk3229: add sdram and sd support
Add sdram driver for rk3229 and other fix like pinctrl and sd node.
Changes in v4: - rebase on u-boot-rockchip master with patchset "move rockchip sdram driver to driver/ram"
Changes in v3: - move rk332x sdram driver to driver/ram - do the ram init in TPL instad of SPL
Kever Yang (2): rockchip: rk322x: add sdram driver rockchip: dts: rk3229: remove dram channel info
arch/arm/dts/rk3229-evb.dts | 1 - arch/arm/include/asm/arch-rockchip/sdram_rk322x.h | 581 +++++++++++++++ drivers/ram/rockchip/Makefile | 1 + drivers/ram/rockchip/sdram_rk322x.c | 855 ++++++++++++++++++++++ 4 files changed, 1437 insertions(+), 1 deletion(-) create mode 100644 arch/arm/include/asm/arch-rockchip/sdram_rk322x.h create mode 100644 drivers/ram/rockchip/sdram_rk322x.c
Add driver for rk322x to support sdram initialize in SPL.
Signed-off-by: Kever Yang kever.yang@rock-chips.com ---
arch/arm/include/asm/arch-rockchip/sdram_rk322x.h | 581 +++++++++++++++ drivers/ram/rockchip/Makefile | 1 + drivers/ram/rockchip/sdram_rk322x.c | 855 ++++++++++++++++++++++ 3 files changed, 1437 insertions(+) create mode 100644 arch/arm/include/asm/arch-rockchip/sdram_rk322x.h create mode 100644 drivers/ram/rockchip/sdram_rk322x.c
diff --git a/arch/arm/include/asm/arch-rockchip/sdram_rk322x.h b/arch/arm/include/asm/arch-rockchip/sdram_rk322x.h new file mode 100644 index 0000000..b40da40 --- /dev/null +++ b/arch/arm/include/asm/arch-rockchip/sdram_rk322x.h @@ -0,0 +1,581 @@ +/* + * (C) Copyright 2017 Rockchip Electronics Co., Ltd + * + * SPDX-License-Identifier: GPL-2.0+ + */ +#ifndef _ASM_ARCH_SDRAM_RK322X_H +#define _ASM_ARCH_SDRAM_RK322X_H + +#include <common.h> + +enum { + DDR3 = 3, + LPDDR2 = 5, + LPDDR3 = 6, + UNUSED = 0xFF, +}; + +struct rk322x_sdram_channel { + /* + * bit width in address, eg: + * 8 banks using 3 bit to address, + * 2 cs using 1 bit to address. + */ + u8 rank; + u8 col; + u8 bk; + u8 bw; + u8 dbw; + u8 row_3_4; + u8 cs0_row; + u8 cs1_row; +#if CONFIG_IS_ENABLED(OF_PLATDATA) + /* + * For of-platdata, which would otherwise convert this into two + * byte-swapped integers. With a size of 9 bytes, this struct will + * appear in of-platdata as a byte array. + * + * If OF_PLATDATA enabled, need to add a dummy byte in dts.(i.e 0xff) + */ + u8 dummy; +#endif +}; + +struct rk322x_ddr_pctl { + u32 scfg; + u32 sctl; + u32 stat; + u32 intrstat; + u32 reserved0[(0x40 - 0x10) / 4]; + u32 mcmd; + u32 powctl; + u32 powstat; + u32 cmdtstat; + u32 cmdtstaten; + u32 reserved1[(0x60 - 0x54) / 4]; + u32 mrrcfg0; + u32 mrrstat0; + u32 mrrstat1; + u32 reserved2[(0x7c - 0x6c) / 4]; + + u32 mcfg1; + u32 mcfg; + u32 ppcfg; + u32 mstat; + u32 lpddr2zqcfg; + u32 reserved3; + + u32 dtupdes; + u32 dtuna; + u32 dtune; + u32 dtuprd0; + u32 dtuprd1; + u32 dtuprd2; + u32 dtuprd3; + u32 dtuawdt; + u32 reserved4[(0xc0 - 0xb4) / 4]; + + u32 togcnt1u; + u32 tinit; + u32 trsth; + u32 togcnt100n; + u32 trefi; + u32 tmrd; + u32 trfc; + u32 trp; + u32 trtw; + u32 tal; + u32 tcl; + u32 tcwl; + u32 tras; + u32 trc; + u32 trcd; + u32 trrd; + u32 trtp; + u32 twr; + u32 twtr; + u32 texsr; + u32 txp; + u32 txpdll; + u32 tzqcs; + u32 tzqcsi; + u32 tdqs; + u32 tcksre; + u32 tcksrx; + u32 tcke; + u32 tmod; + u32 trstl; + u32 tzqcl; + u32 tmrr; + u32 tckesr; + u32 tdpd; + u32 tref_mem_ddr3; + u32 reserved5[(0x180 - 0x14c) / 4]; + u32 ecccfg; + u32 ecctst; + u32 eccclr; + u32 ecclog; + u32 reserved6[(0x200 - 0x190) / 4]; + u32 dtuwactl; + u32 dturactl; + u32 dtucfg; + u32 dtuectl; + u32 dtuwd0; + u32 dtuwd1; + u32 dtuwd2; + u32 dtuwd3; + u32 dtuwdm; + u32 dturd0; + u32 dturd1; + u32 dturd2; + u32 dturd3; + u32 dtulfsrwd; + u32 dtulfsrrd; + u32 dtueaf; + /* dfi control registers */ + u32 dfitctrldelay; + u32 dfiodtcfg; + u32 dfiodtcfg1; + u32 dfiodtrankmap; + /* dfi write data registers */ + u32 dfitphywrdata; + u32 dfitphywrlat; + u32 reserved7[(0x260 - 0x258) / 4]; + u32 dfitrddataen; + u32 dfitphyrdlat; + u32 reserved8[(0x270 - 0x268) / 4]; + u32 dfitphyupdtype0; + u32 dfitphyupdtype1; + u32 dfitphyupdtype2; + u32 dfitphyupdtype3; + u32 dfitctrlupdmin; + u32 dfitctrlupdmax; + u32 dfitctrlupddly; + u32 reserved9; + u32 dfiupdcfg; + u32 dfitrefmski; + u32 dfitctrlupdi; + u32 reserved10[(0x2ac - 0x29c) / 4]; + u32 dfitrcfg0; + u32 dfitrstat0; + u32 dfitrwrlvlen; + u32 dfitrrdlvlen; + u32 dfitrrdlvlgateen; + u32 dfiststat0; + u32 dfistcfg0; + u32 dfistcfg1; + u32 reserved11; + u32 dfitdramclken; + u32 dfitdramclkdis; + u32 dfistcfg2; + u32 dfistparclr; + u32 dfistparlog; + u32 reserved12[(0x2f0 - 0x2e4) / 4]; + + u32 dfilpcfg0; + u32 reserved13[(0x300 - 0x2f4) / 4]; + u32 dfitrwrlvlresp0; + u32 dfitrwrlvlresp1; + u32 dfitrwrlvlresp2; + u32 dfitrrdlvlresp0; + u32 dfitrrdlvlresp1; + u32 dfitrrdlvlresp2; + u32 dfitrwrlvldelay0; + u32 dfitrwrlvldelay1; + u32 dfitrwrlvldelay2; + u32 dfitrrdlvldelay0; + u32 dfitrrdlvldelay1; + u32 dfitrrdlvldelay2; + u32 dfitrrdlvlgatedelay0; + u32 dfitrrdlvlgatedelay1; + u32 dfitrrdlvlgatedelay2; + u32 dfitrcmd; + u32 reserved14[(0x3f8 - 0x340) / 4]; + u32 ipvr; + u32 iptr; +}; +check_member(rk322x_ddr_pctl, iptr, 0x03fc); + +struct rk322x_ddr_phy { + u32 ddrphy_reg[0x100]; +}; + +struct rk322x_pctl_timing { + u32 togcnt1u; + u32 tinit; + u32 trsth; + u32 togcnt100n; + u32 trefi; + u32 tmrd; + u32 trfc; + u32 trp; + u32 trtw; + u32 tal; + u32 tcl; + u32 tcwl; + u32 tras; + u32 trc; + u32 trcd; + u32 trrd; + u32 trtp; + u32 twr; + u32 twtr; + u32 texsr; + u32 txp; + u32 txpdll; + u32 tzqcs; + u32 tzqcsi; + u32 tdqs; + u32 tcksre; + u32 tcksrx; + u32 tcke; + u32 tmod; + u32 trstl; + u32 tzqcl; + u32 tmrr; + u32 tckesr; + u32 tdpd; + u32 trefi_mem_ddr3; +}; + +struct rk322x_phy_timing { + u32 mr[4]; + u32 mr11; + u32 bl; + u32 cl_al; +}; + +struct rk322x_msch_timings { + u32 ddrtiming; + u32 ddrmode; + u32 readlatency; + u32 activate; + u32 devtodev; +}; + +struct rk322x_service_sys { + u32 id_coreid; + u32 id_revisionid; + u32 ddrconf; + u32 ddrtiming; + u32 ddrmode; + u32 readlatency; + u32 activate; + u32 devtodev; +}; + +struct rk322x_base_params { + struct rk322x_msch_timings noc_timing; + u32 ddrconfig; + u32 ddr_freq; + u32 dramtype; + /* + * unused for rk322x + */ + u32 stride; + u32 odt; +}; + +/* PCT_DFISTCFG0 */ +#define DFI_INIT_START BIT(0) +#define DFI_DATA_BYTE_DISABLE_EN BIT(2) + +/* PCT_DFISTCFG1 */ +#define DFI_DRAM_CLK_SR_EN BIT(0) +#define DFI_DRAM_CLK_DPD_EN BIT(1) + +/* PCT_DFISTCFG2 */ +#define DFI_PARITY_INTR_EN BIT(0) +#define DFI_PARITY_EN BIT(1) + +/* PCT_DFILPCFG0 */ +#define TLP_RESP_TIME_SHIFT 16 +#define LP_SR_EN BIT(8) +#define LP_PD_EN BIT(0) + +/* PCT_DFITCTRLDELAY */ +#define TCTRL_DELAY_TIME_SHIFT 0 + +/* PCT_DFITPHYWRDATA */ +#define TPHY_WRDATA_TIME_SHIFT 0 + +/* PCT_DFITPHYRDLAT */ +#define TPHY_RDLAT_TIME_SHIFT 0 + +/* PCT_DFITDRAMCLKDIS */ +#define TDRAM_CLK_DIS_TIME_SHIFT 0 + +/* PCT_DFITDRAMCLKEN */ +#define TDRAM_CLK_EN_TIME_SHIFT 0 + +/* PCTL_DFIODTCFG */ +#define RANK0_ODT_WRITE_SEL BIT(3) +#define RANK1_ODT_WRITE_SEL BIT(11) + +/* PCTL_DFIODTCFG1 */ +#define ODT_LEN_BL8_W_SHIFT 16 + +/* PUBL_ACDLLCR */ +#define ACDLLCR_DLLDIS BIT(31) +#define ACDLLCR_DLLSRST BIT(30) + +/* PUBL_DXDLLCR */ +#define DXDLLCR_DLLDIS BIT(31) +#define DXDLLCR_DLLSRST BIT(30) + +/* PUBL_DLLGCR */ +#define DLLGCR_SBIAS BIT(30) + +/* PUBL_DXGCR */ +#define DQSRTT BIT(9) +#define DQRTT BIT(10) + +/* PIR */ +#define PIR_INIT BIT(0) +#define PIR_DLLSRST BIT(1) +#define PIR_DLLLOCK BIT(2) +#define PIR_ZCAL BIT(3) +#define PIR_ITMSRST BIT(4) +#define PIR_DRAMRST BIT(5) +#define PIR_DRAMINIT BIT(6) +#define PIR_QSTRN BIT(7) +#define PIR_RVTRN BIT(8) +#define PIR_ICPC BIT(16) +#define PIR_DLLBYP BIT(17) +#define PIR_CTLDINIT BIT(18) +#define PIR_CLRSR BIT(28) +#define PIR_LOCKBYP BIT(29) +#define PIR_ZCALBYP BIT(30) +#define PIR_INITBYP BIT(31) + +/* PGCR */ +#define PGCR_DFTLMT_SHIFT 3 +#define PGCR_DFTCMP_SHIFT 2 +#define PGCR_DQSCFG_SHIFT 1 +#define PGCR_ITMDMD_SHIFT 0 + +/* PGSR */ +#define PGSR_IDONE BIT(0) +#define PGSR_DLDONE BIT(1) +#define PGSR_ZCDONE BIT(2) +#define PGSR_DIDONE BIT(3) +#define PGSR_DTDONE BIT(4) +#define PGSR_DTERR BIT(5) +#define PGSR_DTIERR BIT(6) +#define PGSR_DFTERR BIT(7) +#define PGSR_RVERR BIT(8) +#define PGSR_RVEIRR BIT(9) + +/* PTR0 */ +#define PRT_ITMSRST_SHIFT 18 +#define PRT_DLLLOCK_SHIFT 6 +#define PRT_DLLSRST_SHIFT 0 + +/* PTR1 */ +#define PRT_DINIT0_SHIFT 0 +#define PRT_DINIT1_SHIFT 19 + +/* PTR2 */ +#define PRT_DINIT2_SHIFT 0 +#define PRT_DINIT3_SHIFT 17 + +/* DCR */ +#define DDRMD_LPDDR 0 +#define DDRMD_DDR 1 +#define DDRMD_DDR2 2 +#define DDRMD_DDR3 3 +#define DDRMD_LPDDR2_LPDDR3 4 +#define DDRMD_MASK 7 +#define DDRMD_SHIFT 0 +#define PDQ_MASK 7 +#define PDQ_SHIFT 4 + +/* DXCCR */ +#define DQSNRES_MASK 0xf +#define DQSNRES_SHIFT 8 +#define DQSRES_MASK 0xf +#define DQSRES_SHIFT 4 + +/* DTPR */ +#define TDQSCKMAX_SHIFT 27 +#define TDQSCKMAX_MASK 7 +#define TDQSCK_SHIFT 24 +#define TDQSCK_MASK 7 + +/* DSGCR */ +#define DQSGX_SHIFT 5 +#define DQSGX_MASK 7 +#define DQSGE_SHIFT 8 +#define DQSGE_MASK 7 + +/* SCTL */ +#define INIT_STATE 0 +#define CFG_STATE 1 +#define GO_STATE 2 +#define SLEEP_STATE 3 +#define WAKEUP_STATE 4 + +/* STAT */ +#define LP_TRIG_SHIFT 4 +#define LP_TRIG_MASK 7 +#define PCTL_STAT_MASK 7 +#define INIT_MEM 0 +#define CONFIG 1 +#define CONFIG_REQ 2 +#define ACCESS 3 +#define ACCESS_REQ 4 +#define LOW_POWER 5 +#define LOW_POWER_ENTRY_REQ 6 +#define LOW_POWER_EXIT_REQ 7 + +/* ZQCR*/ +#define PD_OUTPUT_SHIFT 0 +#define PU_OUTPUT_SHIFT 5 +#define PD_ONDIE_SHIFT 10 +#define PU_ONDIE_SHIFT 15 +#define ZDEN_SHIFT 28 + +/* DDLGCR */ +#define SBIAS_BYPASS BIT(23) + +/* MCFG */ +#define MDDR_LPDDR2_CLK_STOP_IDLE_SHIFT 24 +#define PD_IDLE_SHIFT 8 +#define MDDR_EN (2 << 22) +#define LPDDR2_EN (3 << 22) +#define LPDDR3_EN (1 << 22) +#define DDR2_EN (0 << 5) +#define DDR3_EN (1 << 5) +#define LPDDR2_S2 (0 << 6) +#define LPDDR2_S4 (1 << 6) +#define MDDR_LPDDR2_BL_2 (0 << 20) +#define MDDR_LPDDR2_BL_4 (1 << 20) +#define MDDR_LPDDR2_BL_8 (2 << 20) +#define MDDR_LPDDR2_BL_16 (3 << 20) +#define DDR2_DDR3_BL_4 0 +#define DDR2_DDR3_BL_8 1 +#define TFAW_SHIFT 18 +#define PD_EXIT_SLOW (0 << 17) +#define PD_EXIT_FAST (1 << 17) +#define PD_TYPE_SHIFT 16 +#define BURSTLENGTH_SHIFT 20 + +/* POWCTL */ +#define POWER_UP_START BIT(0) + +/* POWSTAT */ +#define POWER_UP_DONE BIT(0) + +/* MCMD */ +enum { + DESELECT_CMD = 0, + PREA_CMD, + REF_CMD, + MRS_CMD, + ZQCS_CMD, + ZQCL_CMD, + RSTL_CMD, + MRR_CMD = 8, + DPDE_CMD, +}; + +#define BANK_ADDR_MASK 7 +#define BANK_ADDR_SHIFT 17 +#define CMD_ADDR_MASK 0x1fff +#define CMD_ADDR_SHIFT 4 + +#define LPDDR23_MA_SHIFT 4 +#define LPDDR23_MA_MASK 0xff +#define LPDDR23_OP_SHIFT 12 +#define LPDDR23_OP_MASK 0xff + +#define START_CMD (1u << 31) + +/* DDRPHY REG */ +enum { + /* DDRPHY_REG0 */ + SOFT_RESET_MASK = 3, + SOFT_DERESET_ANALOG = 1 << 2, + SOFT_DERESET_DIGITAL = 1 << 3, + SOFT_RESET_SHIFT = 2, + + /* DDRPHY REG1 */ + PHY_DDR3 = 0, + PHY_DDR2 = 1, + PHY_LPDDR3 = 2, + PHY_LPDDR2 = 3, + + PHT_BL_8 = 1 << 2, + PHY_BL_4 = 0 << 2, + + /* DDRPHY_REG2 */ + MEMORY_SELECT_DDR3 = 0 << 0, + MEMORY_SELECT_LPDDR3 = 2 << 0, + MEMORY_SELECT_LPDDR2 = 3 << 0, + DQS_SQU_CAL_SEL_CS0_CS1 = 0 << 4, + DQS_SQU_CAL_SEL_CS1 = 1 << 4, + DQS_SQU_CAL_SEL_CS0 = 2 << 4, + DQS_SQU_CAL_NORMAL_MODE = 0 << 1, + DQS_SQU_CAL_BYPASS_MODE = 1 << 1, + DQS_SQU_CAL_START = 1 << 0, + DQS_SQU_NO_CAL = 0 << 0, +}; + +/* CK pull up/down driver strength control */ +enum { + PHY_RON_RTT_DISABLE = 0, + PHY_RON_RTT_451OHM = 1, + PHY_RON_RTT_225OHM, + PHY_RON_RTT_150OHM, + PHY_RON_RTT_112OHM, + PHY_RON_RTT_90OHM, + PHY_RON_RTT_75OHM, + PHY_RON_RTT_64OHM = 7, + + PHY_RON_RTT_56OHM = 16, + PHY_RON_RTT_50OHM, + PHY_RON_RTT_45OHM, + PHY_RON_RTT_41OHM, + PHY_RON_RTT_37OHM, + PHY_RON_RTT_34OHM, + PHY_RON_RTT_33OHM, + PHY_RON_RTT_30OHM = 23, + + PHY_RON_RTT_28OHM = 24, + PHY_RON_RTT_26OHM, + PHY_RON_RTT_25OHM, + PHY_RON_RTT_23OHM, + PHY_RON_RTT_22OHM, + PHY_RON_RTT_21OHM, + PHY_RON_RTT_20OHM, + PHY_RON_RTT_19OHM = 31, +}; + +/* DQS squelch DLL delay */ +enum { + DQS_DLL_NO_DELAY = 0, + DQS_DLL_22P5_DELAY, + DQS_DLL_45_DELAY, + DQS_DLL_67P5_DELAY, + DQS_DLL_90_DELAY, + DQS_DLL_112P5_DELAY, + DQS_DLL_135_DELAY, + DQS_DLL_157P5_DELAY, +}; + +/* GRF_SOC_CON0 */ +#define GRF_DDR_16BIT_EN (((0x1 << 0) << 16) | (0x1 << 0)) +#define GRF_DDR_32BIT_EN (((0x1 << 0) << 16) | (0x0 << 0)) +#define GRF_MSCH_NOC_16BIT_EN (((0x1 << 7) << 16) | (0x1 << 7)) +#define GRF_MSCH_NOC_32BIT_EN (((0x1 << 7) << 16) | (0x0 << 7)) + +#define GRF_DDRPHY_BUFFEREN_CORE_EN (((0x1 << 8) << 16) | (0x0 << 8)) +#define GRF_DDRPHY_BUFFEREN_CORE_DIS (((0x1 << 8) << 16) | (0x1 << 8)) + +#define GRF_DDR3_EN (((0x1 << 6) << 16) | (0x1 << 6)) +#define GRF_LPDDR2_3_EN (((0x1 << 6) << 16) | (0x0 << 6)) + +#define PHY_DRV_ODT_SET(n) (((n) << 4) | (n)) +#define DDR3_DLL_RESET (1 << 8) + +#endif /* _ASM_ARCH_SDRAM_RK322X_H */ diff --git a/drivers/ram/rockchip/Makefile b/drivers/ram/rockchip/Makefile index 6c78eff..45b5fe7 100644 --- a/drivers/ram/rockchip/Makefile +++ b/drivers/ram/rockchip/Makefile @@ -6,6 +6,7 @@
obj-$(CONFIG_ROCKCHIP_RK3368) = dmc-rk3368.o obj-$(CONFIG_ROCKCHIP_RK3188) = sdram_rk3188.o +obj-$(CONFIG_ROCKCHIP_RK322X) = sdram_rk322x.o obj-$(CONFIG_ROCKCHIP_RK3288) = sdram_rk3288.o obj-$(CONFIG_ROCKCHIP_RK3328) = sdram_rk3328.o obj-$(CONFIG_ROCKCHIP_RK3399) = sdram_rk3399.o diff --git a/drivers/ram/rockchip/sdram_rk322x.c b/drivers/ram/rockchip/sdram_rk322x.c new file mode 100644 index 0000000..cc3138b --- /dev/null +++ b/drivers/ram/rockchip/sdram_rk322x.c @@ -0,0 +1,855 @@ +/* + * (C) Copyright 2017 Rockchip Electronics Co., Ltd + * + * SPDX-License-Identifier: GPL-2.0 + */ +#include <common.h> +#include <clk.h> +#include <dm.h> +#include <dt-structs.h> +#include <errno.h> +#include <ram.h> +#include <regmap.h> +#include <syscon.h> +#include <asm/io.h> +#include <asm/arch/clock.h> +#include <asm/arch/cru_rk322x.h> +#include <asm/arch/grf_rk322x.h> +#include <asm/arch/hardware.h> +#include <asm/arch/sdram_rk322x.h> +#include <asm/arch/timer.h> +#include <asm/arch/uart.h> +#include <asm/arch/sdram_common.h> +#include <asm/types.h> +#include <linux/err.h> + +DECLARE_GLOBAL_DATA_PTR; +struct chan_info { + struct rk322x_ddr_pctl *pctl; + struct rk322x_ddr_phy *phy; + struct rk322x_service_sys *msch; +}; + +struct dram_info { + struct chan_info chan[1]; + struct ram_info info; + struct clk ddr_clk; + struct rk322x_cru *cru; + struct rk322x_grf *grf; +}; + +struct rk322x_sdram_params { +#if CONFIG_IS_ENABLED(OF_PLATDATA) + struct dtd_rockchip_rk3228_dmc of_plat; +#endif + struct rk322x_sdram_channel ch[1]; + struct rk322x_pctl_timing pctl_timing; + struct rk322x_phy_timing phy_timing; + struct rk322x_base_params base; + int num_channels; + struct regmap *map; +}; + +#ifdef CONFIG_TPL_BUILD +/* + * [7:6] bank(n:n bit bank) + * [5:4] row(13+n) + * [3] cs(0:1 cs, 1:2 cs) + * [2:1] bank(n:n bit bank) + * [0] col(10+n) + */ +const char ddr_cfg_2_rbc[] = { + ((0 << 6) | (0 << 4) | (0 << 3) | (1 << 2) | 1), + ((0 << 6) | (1 << 4) | (0 << 3) | (1 << 2) | 1), + ((0 << 6) | (2 << 4) | (0 << 3) | (1 << 2) | 1), + ((0 << 6) | (3 << 4) | (0 << 3) | (1 << 2) | 1), + ((0 << 6) | (1 << 4) | (0 << 3) | (1 << 2) | 2), + ((0 << 6) | (2 << 4) | (0 << 3) | (1 << 2) | 2), + ((0 << 6) | (3 << 4) | (0 << 3) | (1 << 2) | 2), + ((0 << 6) | (0 << 4) | (0 << 3) | (1 << 2) | 0), + ((0 << 6) | (1 << 4) | (0 << 3) | (1 << 2) | 0), + ((0 << 6) | (2 << 4) | (0 << 3) | (1 << 2) | 0), + ((0 << 6) | (3 << 4) | (0 << 3) | (1 << 2) | 0), + ((0 << 6) | (2 << 4) | (0 << 3) | (0 << 2) | 1), + ((1 << 6) | (1 << 4) | (0 << 3) | (0 << 2) | 2), + ((1 << 6) | (1 << 4) | (0 << 3) | (0 << 2) | 1), + ((0 << 6) | (3 << 4) | (1 << 3) | (1 << 2) | 1), + ((0 << 6) | (3 << 4) | (1 << 3) | (1 << 2) | 0), +}; + +static void copy_to_reg(u32 *dest, const u32 *src, u32 n) +{ + int i; + + for (i = 0; i < n / sizeof(u32); i++) { + writel(*src, dest); + src++; + dest++; + } +} + +void phy_pctrl_reset(struct rk322x_cru *cru, + struct rk322x_ddr_phy *ddr_phy) +{ + rk_clrsetreg(&cru->cru_softrst_con[5], 1 << DDRCTRL_PSRST_SHIFT | + 1 << DDRCTRL_SRST_SHIFT | 1 << DDRPHY_PSRST_SHIFT | + 1 << DDRPHY_SRST_SHIFT, + 1 << DDRCTRL_PSRST_SHIFT | 1 << DDRCTRL_SRST_SHIFT | + 1 << DDRPHY_PSRST_SHIFT | 1 << DDRPHY_SRST_SHIFT); + + rockchip_udelay(10); + + rk_clrreg(&cru->cru_softrst_con[5], 1 << DDRPHY_PSRST_SHIFT | + 1 << DDRPHY_SRST_SHIFT); + rockchip_udelay(10); + + rk_clrreg(&cru->cru_softrst_con[5], 1 << DDRCTRL_PSRST_SHIFT | + 1 << DDRCTRL_SRST_SHIFT); + rockchip_udelay(10); + + clrbits_le32(&ddr_phy->ddrphy_reg[0], + SOFT_RESET_MASK << SOFT_RESET_SHIFT); + rockchip_udelay(10); + setbits_le32(&ddr_phy->ddrphy_reg[0], + SOFT_DERESET_ANALOG); + rockchip_udelay(5); + setbits_le32(&ddr_phy->ddrphy_reg[0], + SOFT_DERESET_DIGITAL); + + rockchip_udelay(1); +} + +void phy_dll_bypass_set(struct rk322x_ddr_phy *ddr_phy, u32 freq) +{ + u32 tmp; + + setbits_le32(&ddr_phy->ddrphy_reg[0x13], 0x10); + setbits_le32(&ddr_phy->ddrphy_reg[0x26], 0x10); + setbits_le32(&ddr_phy->ddrphy_reg[0x36], 0x10); + setbits_le32(&ddr_phy->ddrphy_reg[0x46], 0x10); + setbits_le32(&ddr_phy->ddrphy_reg[0x56], 0x10); + + clrbits_le32(&ddr_phy->ddrphy_reg[0x14], 0x8); + clrbits_le32(&ddr_phy->ddrphy_reg[0x27], 0x8); + clrbits_le32(&ddr_phy->ddrphy_reg[0x37], 0x8); + clrbits_le32(&ddr_phy->ddrphy_reg[0x47], 0x8); + clrbits_le32(&ddr_phy->ddrphy_reg[0x57], 0x8); + + if (freq <= 400) + setbits_le32(&ddr_phy->ddrphy_reg[0xa4], 0x1f); + else + clrbits_le32(&ddr_phy->ddrphy_reg[0xa4], 0x1f); + + if (freq <= 680) + tmp = 3; + else + tmp = 2; + + writel(tmp, &ddr_phy->ddrphy_reg[0x28]); + writel(tmp, &ddr_phy->ddrphy_reg[0x38]); + writel(tmp, &ddr_phy->ddrphy_reg[0x48]); + writel(tmp, &ddr_phy->ddrphy_reg[0x58]); +} + +static void send_command(struct rk322x_ddr_pctl *pctl, + u32 rank, u32 cmd, u32 arg) +{ + writel((START_CMD | (rank << 20) | arg | cmd), &pctl->mcmd); + rockchip_udelay(1); + while (readl(&pctl->mcmd) & START_CMD) + ; +} + +static void memory_init(struct chan_info *chan, + struct rk322x_sdram_params *sdram_params) +{ + struct rk322x_ddr_pctl *pctl = chan->pctl; + u32 dramtype = sdram_params->base.dramtype; + + if (dramtype == DDR3) { + send_command(pctl, 3, DESELECT_CMD, 0); + rockchip_udelay(1); + send_command(pctl, 3, PREA_CMD, 0); + send_command(pctl, 3, MRS_CMD, + (0x02 & BANK_ADDR_MASK) << BANK_ADDR_SHIFT | + (sdram_params->phy_timing.mr[2] & CMD_ADDR_MASK) << + CMD_ADDR_SHIFT); + + send_command(pctl, 3, MRS_CMD, + (0x03 & BANK_ADDR_MASK) << BANK_ADDR_SHIFT | + (sdram_params->phy_timing.mr[3] & CMD_ADDR_MASK) << + CMD_ADDR_SHIFT); + + send_command(pctl, 3, MRS_CMD, + (0x01 & BANK_ADDR_MASK) << BANK_ADDR_SHIFT | + (sdram_params->phy_timing.mr[1] & CMD_ADDR_MASK) << + CMD_ADDR_SHIFT); + + send_command(pctl, 3, MRS_CMD, + (0x00 & BANK_ADDR_MASK) << BANK_ADDR_SHIFT | + ((sdram_params->phy_timing.mr[0] | + DDR3_DLL_RESET) & + CMD_ADDR_MASK) << CMD_ADDR_SHIFT); + + send_command(pctl, 3, ZQCL_CMD, 0); + } else { + send_command(pctl, 3, MRS_CMD, + (0x63 & LPDDR23_MA_MASK) << LPDDR23_MA_SHIFT | + (0 & LPDDR23_OP_MASK) << + LPDDR23_OP_SHIFT); + rockchip_udelay(10); + send_command(pctl, 3, MRS_CMD, + (0x10 & LPDDR23_MA_MASK) << LPDDR23_MA_SHIFT | + (0xff & LPDDR23_OP_MASK) << + LPDDR23_OP_SHIFT); + rockchip_udelay(1); + send_command(pctl, 3, MRS_CMD, + (0x10 & LPDDR23_MA_MASK) << LPDDR23_MA_SHIFT | + (0xff & LPDDR23_OP_MASK) << + LPDDR23_OP_SHIFT); + rockchip_udelay(1); + send_command(pctl, 3, MRS_CMD, + (1 & LPDDR23_MA_MASK) << LPDDR23_MA_SHIFT | + (sdram_params->phy_timing.mr[1] & + LPDDR23_OP_MASK) << LPDDR23_OP_SHIFT); + send_command(pctl, 3, MRS_CMD, + (2 & LPDDR23_MA_MASK) << LPDDR23_MA_SHIFT | + (sdram_params->phy_timing.mr[2] & + LPDDR23_OP_MASK) << LPDDR23_OP_SHIFT); + send_command(pctl, 3, MRS_CMD, + (3 & LPDDR23_MA_MASK) << LPDDR23_MA_SHIFT | + (sdram_params->phy_timing.mr[3] & + LPDDR23_OP_MASK) << LPDDR23_OP_SHIFT); + if (dramtype == LPDDR3) + send_command(pctl, 3, MRS_CMD, (11 & LPDDR23_MA_MASK) << + LPDDR23_MA_SHIFT | + (sdram_params->phy_timing.mr11 & + LPDDR23_OP_MASK) << LPDDR23_OP_SHIFT); + } +} + +static u32 data_training(struct chan_info *chan) +{ + struct rk322x_ddr_phy *ddr_phy = chan->phy; + struct rk322x_ddr_pctl *pctl = chan->pctl; + u32 value; + u32 bw = (readl(&ddr_phy->ddrphy_reg[0]) >> 4) & 0xf; + u32 ret; + + /* disable auto refresh */ + value = readl(&pctl->trefi) | (1 << 31); + writel(1 << 31, &pctl->trefi); + + clrsetbits_le32(&ddr_phy->ddrphy_reg[2], 0x30, + DQS_SQU_CAL_SEL_CS0); + setbits_le32(&ddr_phy->ddrphy_reg[2], DQS_SQU_CAL_START); + + rockchip_udelay(30); + ret = readl(&ddr_phy->ddrphy_reg[0xff]); + + clrbits_le32(&ddr_phy->ddrphy_reg[2], + DQS_SQU_CAL_START); + + /* + * since data training will take about 20us, so send some auto + * refresh(about 7.8us) to complement the lost time + */ + send_command(pctl, 3, PREA_CMD, 0); + send_command(pctl, 3, REF_CMD, 0); + + writel(value, &pctl->trefi); + + if (ret & 0x10) { + ret = -1; + } else { + ret = (ret & 0xf) ^ bw; + ret = (ret == 0) ? 0 : -1; + } + return ret; +} + +static void move_to_config_state(struct rk322x_ddr_pctl *pctl) +{ + unsigned int state; + + while (1) { + state = readl(&pctl->stat) & PCTL_STAT_MASK; + switch (state) { + case LOW_POWER: + writel(WAKEUP_STATE, &pctl->sctl); + while ((readl(&pctl->stat) & PCTL_STAT_MASK) + != ACCESS) + ; + /* + * If at low power state, need wakeup first, and then + * enter the config, so fallthrough + */ + case ACCESS: + /* fallthrough */ + case INIT_MEM: + writel(CFG_STATE, &pctl->sctl); + while ((readl(&pctl->stat) & PCTL_STAT_MASK) != CONFIG) + ; + break; + case CONFIG: + return; + default: + break; + } + } +} + +static void move_to_access_state(struct rk322x_ddr_pctl *pctl) +{ + unsigned int state; + + while (1) { + state = readl(&pctl->stat) & PCTL_STAT_MASK; + switch (state) { + case LOW_POWER: + writel(WAKEUP_STATE, &pctl->sctl); + while ((readl(&pctl->stat) & PCTL_STAT_MASK) != ACCESS) + ; + break; + case INIT_MEM: + writel(CFG_STATE, &pctl->sctl); + while ((readl(&pctl->stat) & PCTL_STAT_MASK) != CONFIG) + ; + /* fallthrough */ + case CONFIG: + writel(GO_STATE, &pctl->sctl); + while ((readl(&pctl->stat) & PCTL_STAT_MASK) != ACCESS) + ; + break; + case ACCESS: + return; + default: + break; + } + } +} + +static void move_to_lowpower_state(struct rk322x_ddr_pctl *pctl) +{ + unsigned int state; + + while (1) { + state = readl(&pctl->stat) & PCTL_STAT_MASK; + switch (state) { + case INIT_MEM: + writel(CFG_STATE, &pctl->sctl); + while ((readl(&pctl->stat) & PCTL_STAT_MASK) != CONFIG) + ; + /* fallthrough */ + case CONFIG: + writel(GO_STATE, &pctl->sctl); + while ((readl(&pctl->stat) & PCTL_STAT_MASK) != ACCESS) + ; + break; + case ACCESS: + writel(SLEEP_STATE, &pctl->sctl); + while ((readl(&pctl->stat) & PCTL_STAT_MASK) != + LOW_POWER) + ; + break; + case LOW_POWER: + return; + default: + break; + } + } +} + +/* pctl should in low power mode when call this function */ +static void phy_softreset(struct dram_info *dram) +{ + struct rk322x_ddr_phy *ddr_phy = dram->chan[0].phy; + struct rk322x_grf *grf = dram->grf; + + writel(GRF_DDRPHY_BUFFEREN_CORE_EN, &grf->soc_con[0]); + clrbits_le32(&ddr_phy->ddrphy_reg[0], 0x3 << 2); + rockchip_udelay(1); + setbits_le32(&ddr_phy->ddrphy_reg[0], 1 << 2); + rockchip_udelay(5); + setbits_le32(&ddr_phy->ddrphy_reg[0], 1 << 3); + writel(GRF_DDRPHY_BUFFEREN_CORE_DIS, &grf->soc_con[0]); +} + +/* bw: 2: 32bit, 1:16bit */ +static void set_bw(struct dram_info *dram, u32 bw) +{ + struct rk322x_ddr_pctl *pctl = dram->chan[0].pctl; + struct rk322x_ddr_phy *ddr_phy = dram->chan[0].phy; + struct rk322x_grf *grf = dram->grf; + + if (bw == 1) { + setbits_le32(&pctl->ppcfg, 1); + clrbits_le32(&ddr_phy->ddrphy_reg[0], 0xc << 4); + writel(GRF_MSCH_NOC_16BIT_EN, &grf->soc_con[0]); + clrbits_le32(&ddr_phy->ddrphy_reg[0x46], 0x8); + clrbits_le32(&ddr_phy->ddrphy_reg[0x56], 0x8); + } else { + clrbits_le32(&pctl->ppcfg, 1); + setbits_le32(&ddr_phy->ddrphy_reg[0], 0xf << 4); + writel(GRF_DDR_32BIT_EN | GRF_MSCH_NOC_32BIT_EN, + &grf->soc_con[0]); + setbits_le32(&ddr_phy->ddrphy_reg[0x46], 0x8); + setbits_le32(&ddr_phy->ddrphy_reg[0x56], 0x8); + } +} + +static void pctl_cfg(struct rk322x_ddr_pctl *pctl, + struct rk322x_sdram_params *sdram_params, + struct rk322x_grf *grf) +{ + u32 burst_len; + u32 bw; + u32 dramtype = sdram_params->base.dramtype; + + if (sdram_params->ch[0].bw == 2) + bw = GRF_DDR_32BIT_EN | GRF_MSCH_NOC_32BIT_EN; + else + bw = GRF_MSCH_NOC_16BIT_EN; + + writel(DFI_INIT_START | DFI_DATA_BYTE_DISABLE_EN, &pctl->dfistcfg0); + writel(DFI_DRAM_CLK_SR_EN | DFI_DRAM_CLK_DPD_EN, &pctl->dfistcfg1); + writel(DFI_PARITY_INTR_EN | DFI_PARITY_EN, &pctl->dfistcfg2); + writel(0x51010, &pctl->dfilpcfg0); + + writel(1, &pctl->dfitphyupdtype0); + writel(0x0d, &pctl->dfitphyrdlat); + writel(0, &pctl->dfitphywrdata); + + writel(0, &pctl->dfiupdcfg); + copy_to_reg(&pctl->togcnt1u, &sdram_params->pctl_timing.togcnt1u, + sizeof(struct rk322x_pctl_timing)); + if (dramtype == DDR3) { + writel((1 << 3) | (1 << 11), + &pctl->dfiodtcfg); + writel(7 << 16, &pctl->dfiodtcfg1); + writel((readl(&pctl->tcl) - 1) / 2 - 1, &pctl->dfitrddataen); + writel((readl(&pctl->tcwl) - 1) / 2 - 1, &pctl->dfitphywrlat); + writel(500, &pctl->trsth); + writel(0 << MDDR_LPDDR2_CLK_STOP_IDLE_SHIFT | DDR3_EN | + DDR2_DDR3_BL_8 | (6 - 4) << TFAW_SHIFT | PD_EXIT_SLOW | + 1 << PD_TYPE_SHIFT | 0 << PD_IDLE_SHIFT, + &pctl->mcfg); + writel(bw | GRF_DDR3_EN, &grf->soc_con[0]); + } else { + if (sdram_params->phy_timing.bl & PHT_BL_8) + burst_len = MDDR_LPDDR2_BL_8; + else + burst_len = MDDR_LPDDR2_BL_4; + + writel(readl(&pctl->tcl) / 2 - 1, &pctl->dfitrddataen); + writel(readl(&pctl->tcwl) / 2 - 1, &pctl->dfitphywrlat); + writel(0, &pctl->trsth); + if (dramtype == LPDDR2) { + writel(0 << MDDR_LPDDR2_CLK_STOP_IDLE_SHIFT | + LPDDR2_S4 | LPDDR2_EN | burst_len | + (6 - 4) << TFAW_SHIFT | PD_EXIT_FAST | + 1 << PD_TYPE_SHIFT | 0 << PD_IDLE_SHIFT, + &pctl->mcfg); + writel(0, &pctl->dfiodtcfg); + writel(0, &pctl->dfiodtcfg1); + } else { + writel(0 << MDDR_LPDDR2_CLK_STOP_IDLE_SHIFT | + LPDDR2_S4 | LPDDR3_EN | burst_len | + (6 - 4) << TFAW_SHIFT | PD_EXIT_FAST | + 1 << PD_TYPE_SHIFT | 0 << PD_IDLE_SHIFT, + &pctl->mcfg); + writel((1 << 3) | (1 << 2), &pctl->dfiodtcfg); + writel((7 << 16) | 4, &pctl->dfiodtcfg1); + } + writel(bw | GRF_LPDDR2_3_EN, &grf->soc_con[0]); + } + setbits_le32(&pctl->scfg, 1); +} + +static void phy_cfg(struct chan_info *chan, + struct rk322x_sdram_params *sdram_params) +{ + struct rk322x_ddr_phy *ddr_phy = chan->phy; + struct rk322x_service_sys *axi_bus = chan->msch; + struct rk322x_msch_timings *noc_timing = &sdram_params->base.noc_timing; + struct rk322x_phy_timing *phy_timing = &sdram_params->phy_timing; + struct rk322x_pctl_timing *pctl_timing = &sdram_params->pctl_timing; + u32 cmd_drv, clk_drv, dqs_drv, dqs_odt; + + writel(noc_timing->ddrtiming, &axi_bus->ddrtiming); + writel(noc_timing->ddrmode, &axi_bus->ddrmode); + writel(noc_timing->readlatency, &axi_bus->readlatency); + writel(noc_timing->activate, &axi_bus->activate); + writel(noc_timing->devtodev, &axi_bus->devtodev); + + switch (sdram_params->base.dramtype) { + case DDR3: + writel(PHY_DDR3 | phy_timing->bl, &ddr_phy->ddrphy_reg[1]); + break; + case LPDDR2: + writel(PHY_LPDDR2 | phy_timing->bl, &ddr_phy->ddrphy_reg[1]); + break; + default: + writel(PHY_LPDDR2 | phy_timing->bl, &ddr_phy->ddrphy_reg[1]); + break; + } + + writel(phy_timing->cl_al, &ddr_phy->ddrphy_reg[0xb]); + writel(pctl_timing->tcwl, &ddr_phy->ddrphy_reg[0xc]); + + cmd_drv = PHY_RON_RTT_34OHM; + clk_drv = PHY_RON_RTT_45OHM; + dqs_drv = PHY_RON_RTT_34OHM; + if (sdram_params->base.dramtype == LPDDR2) + dqs_odt = PHY_RON_RTT_DISABLE; + else + dqs_odt = PHY_RON_RTT_225OHM; + + writel(cmd_drv, &ddr_phy->ddrphy_reg[0x11]); + clrsetbits_le32(&ddr_phy->ddrphy_reg[0x12], (0x1f << 3), cmd_drv << 3); + writel(clk_drv, &ddr_phy->ddrphy_reg[0x16]); + writel(clk_drv, &ddr_phy->ddrphy_reg[0x18]); + + writel(dqs_drv, &ddr_phy->ddrphy_reg[0x20]); + writel(dqs_drv, &ddr_phy->ddrphy_reg[0x2f]); + writel(dqs_drv, &ddr_phy->ddrphy_reg[0x30]); + writel(dqs_drv, &ddr_phy->ddrphy_reg[0x3f]); + writel(dqs_drv, &ddr_phy->ddrphy_reg[0x40]); + writel(dqs_drv, &ddr_phy->ddrphy_reg[0x4f]); + writel(dqs_drv, &ddr_phy->ddrphy_reg[0x50]); + writel(dqs_drv, &ddr_phy->ddrphy_reg[0x5f]); + + writel(dqs_odt, &ddr_phy->ddrphy_reg[0x21]); + writel(dqs_odt, &ddr_phy->ddrphy_reg[0x2e]); + writel(dqs_odt, &ddr_phy->ddrphy_reg[0x31]); + writel(dqs_odt, &ddr_phy->ddrphy_reg[0x3e]); + writel(dqs_odt, &ddr_phy->ddrphy_reg[0x41]); + writel(dqs_odt, &ddr_phy->ddrphy_reg[0x4e]); + writel(dqs_odt, &ddr_phy->ddrphy_reg[0x51]); + writel(dqs_odt, &ddr_phy->ddrphy_reg[0x5e]); +} + +void dram_cfg_rbc(struct chan_info *chan, + struct rk322x_sdram_params *sdram_params) +{ + char noc_config; + int i = 0; + struct rk322x_sdram_channel *config = &sdram_params->ch[0]; + struct rk322x_service_sys *axi_bus = chan->msch; + + move_to_config_state(chan->pctl); + + if ((config->rank == 2) && (config->cs1_row == config->cs0_row)) { + if ((config->col + config->bw) == 12) { + i = 14; + goto finish; + } else if ((config->col + config->bw) == 11) { + i = 15; + goto finish; + } + } + noc_config = ((config->cs0_row - 13) << 4) | ((config->bk - 2) << 2) | + (config->col + config->bw - 11); + for (i = 0; i < 11; i++) { + if (noc_config == ddr_cfg_2_rbc[i]) + break; + } + + if (i < 11) + goto finish; + + noc_config = ((config->bk - 2) << 6) | ((config->cs0_row - 13) << 4) | + (config->col + config->bw - 11); + + for (i = 11; i < 14; i++) { + if (noc_config == ddr_cfg_2_rbc[i]) + break; + } + if (i < 14) + goto finish; + else + i = 0; + +finish: + writel(i, &axi_bus->ddrconf); + move_to_access_state(chan->pctl); +} + +static void dram_all_config(const struct dram_info *dram, + struct rk322x_sdram_params *sdram_params) +{ + struct rk322x_sdram_channel *info = &sdram_params->ch[0]; + u32 sys_reg = 0; + + sys_reg |= sdram_params->base.dramtype << SYS_REG_DDRTYPE_SHIFT; + sys_reg |= (1 - 1) << SYS_REG_NUM_CH_SHIFT; + sys_reg |= info->row_3_4 << SYS_REG_ROW_3_4_SHIFT(0); + sys_reg |= 1 << SYS_REG_CHINFO_SHIFT(0); + sys_reg |= (info->rank - 1) << SYS_REG_RANK_SHIFT(0); + sys_reg |= (info->col - 9) << SYS_REG_COL_SHIFT(0); + sys_reg |= info->bk == 3 ? 0 : 1 << SYS_REG_BK_SHIFT(0); + sys_reg |= (info->cs0_row - 13) << SYS_REG_CS0_ROW_SHIFT(0); + sys_reg |= (info->cs1_row - 13) << SYS_REG_CS1_ROW_SHIFT(0); + sys_reg |= (2 >> info->bw) << SYS_REG_BW_SHIFT(0); + sys_reg |= (2 >> info->dbw) << SYS_REG_DBW_SHIFT(0); + + writel(sys_reg, &dram->grf->os_reg[2]); +} + +#define TEST_PATTEN 0x5aa5f00f + +static int dram_cap_detect(struct dram_info *dram, + struct rk322x_sdram_params *sdram_params) +{ + u32 bw, row, col, addr; + u32 ret = 0; + struct rk322x_service_sys *axi_bus = dram->chan[0].msch; + + if (sdram_params->base.dramtype == DDR3) + sdram_params->ch[0].dbw = 1; + else + sdram_params->ch[0].dbw = 2; + + move_to_config_state(dram->chan[0].pctl); + /* bw detect */ + set_bw(dram, 2); + if (data_training(&dram->chan[0]) == 0) { + bw = 2; + } else { + bw = 1; + set_bw(dram, 1); + move_to_lowpower_state(dram->chan[0].pctl); + phy_softreset(dram); + move_to_config_state(dram->chan[0].pctl); + if (data_training(&dram->chan[0])) { + printf("BW detect error\n"); + ret = -EINVAL; + } + } + sdram_params->ch[0].bw = bw; + sdram_params->ch[0].bk = 3; + + if (bw == 2) + writel(6, &axi_bus->ddrconf); + else + writel(3, &axi_bus->ddrconf); + move_to_access_state(dram->chan[0].pctl); + for (col = 11; col >= 9; col--) { + writel(0, CONFIG_SYS_SDRAM_BASE); + addr = CONFIG_SYS_SDRAM_BASE + + (1 << (col + bw - 1)); + writel(TEST_PATTEN, addr); + if ((readl(addr) == TEST_PATTEN) && + (readl(CONFIG_SYS_SDRAM_BASE) == 0)) + break; + } + if (col == 8) { + printf("Col detect error\n"); + ret = -EINVAL; + goto out; + } else { + sdram_params->ch[0].col = col; + } + + writel(10, &axi_bus->ddrconf); + + /* Detect row*/ + for (row = 16; row >= 12; row--) { + writel(0, CONFIG_SYS_SDRAM_BASE); + addr = CONFIG_SYS_SDRAM_BASE + (1u << (row + 11 + 3 - 1)); + writel(TEST_PATTEN, addr); + if ((readl(addr) == TEST_PATTEN) && + (readl(CONFIG_SYS_SDRAM_BASE) == 0)) + break; + } + if (row == 11) { + printf("Row detect error\n"); + ret = -EINVAL; + } else { + sdram_params->ch[0].cs1_row = row; + sdram_params->ch[0].row_3_4 = 0; + sdram_params->ch[0].cs0_row = row; + } + /* cs detect */ + writel(0, CONFIG_SYS_SDRAM_BASE); + writel(TEST_PATTEN, CONFIG_SYS_SDRAM_BASE + (1u << 30)); + writel(~TEST_PATTEN, CONFIG_SYS_SDRAM_BASE + (1u << 30) + 4); + if ((readl(CONFIG_SYS_SDRAM_BASE + (1u << 30)) == TEST_PATTEN) && + (readl(CONFIG_SYS_SDRAM_BASE) == 0)) + sdram_params->ch[0].rank = 2; + else + sdram_params->ch[0].rank = 1; +out: + return ret; +} + +static int sdram_init(struct dram_info *dram, + struct rk322x_sdram_params *sdram_params) +{ + int ret; + + ret = clk_set_rate(&dram->ddr_clk, + sdram_params->base.ddr_freq * MHz * 2); + if (ret < 0) { + printf("Could not set DDR clock\n"); + return ret; + } + + phy_pctrl_reset(dram->cru, dram->chan[0].phy); + phy_dll_bypass_set(dram->chan[0].phy, sdram_params->base.ddr_freq); + pctl_cfg(dram->chan[0].pctl, sdram_params, dram->grf); + phy_cfg(&dram->chan[0], sdram_params); + writel(POWER_UP_START, &dram->chan[0].pctl->powctl); + while (!(readl(&dram->chan[0].pctl->powstat) & POWER_UP_DONE)) + ; + memory_init(&dram->chan[0], sdram_params); + move_to_access_state(dram->chan[0].pctl); + ret = dram_cap_detect(dram, sdram_params); + if (ret) + goto out; + dram_cfg_rbc(&dram->chan[0], sdram_params); + dram_all_config(dram, sdram_params); +out: + return ret; +} + +static int rk322x_dmc_ofdata_to_platdata(struct udevice *dev) +{ +#if !CONFIG_IS_ENABLED(OF_PLATDATA) + struct rk322x_sdram_params *params = dev_get_platdata(dev); + const void *blob = gd->fdt_blob; + int node = dev_of_offset(dev); + int ret; + + params->num_channels = 1; + + ret = fdtdec_get_int_array(blob, node, "rockchip,pctl-timing", + (u32 *)¶ms->pctl_timing, + sizeof(params->pctl_timing) / sizeof(u32)); + if (ret) { + printf("%s: Cannot read rockchip,pctl-timing\n", __func__); + return -EINVAL; + } + ret = fdtdec_get_int_array(blob, node, "rockchip,phy-timing", + (u32 *)¶ms->phy_timing, + sizeof(params->phy_timing) / sizeof(u32)); + if (ret) { + printf("%s: Cannot read rockchip,phy-timing\n", __func__); + return -EINVAL; + } + ret = fdtdec_get_int_array(blob, node, "rockchip,sdram-params", + (u32 *)¶ms->base, + sizeof(params->base) / sizeof(u32)); + if (ret) { + printf("%s: Cannot read rockchip,sdram-params\n", __func__); + return -EINVAL; + } + ret = regmap_init_mem(dev, ¶ms->map); + if (ret) + return ret; +#endif + + return 0; +} +#endif /* CONFIG_TPL_BUILD */ + +#if CONFIG_IS_ENABLED(OF_PLATDATA) +static int conv_of_platdata(struct udevice *dev) +{ + struct rk322x_sdram_params *plat = dev_get_platdata(dev); + struct dtd_rockchip_rk322x_dmc *of_plat = &plat->of_plat; + int ret; + + memcpy(&plat->pctl_timing, of_plat->rockchip_pctl_timing, + sizeof(plat->pctl_timing)); + memcpy(&plat->phy_timing, of_plat->rockchip_phy_timing, + sizeof(plat->phy_timing)); + memcpy(&plat->base, of_plat->rockchip_sdram_params, sizeof(plat->base)); + + plat->num_channels = 1; + ret = regmap_init_mem_platdata(dev, of_plat->reg, + ARRAY_SIZE(of_plat->reg) / 2, + &plat->map); + if (ret) + return ret; + + return 0; +} +#endif + +static int rk322x_dmc_probe(struct udevice *dev) +{ +#ifdef CONFIG_TPL_BUILD + struct rk322x_sdram_params *plat = dev_get_platdata(dev); + int ret; + struct udevice *dev_clk; +#endif + struct dram_info *priv = dev_get_priv(dev); + + priv->grf = syscon_get_first_range(ROCKCHIP_SYSCON_GRF); +#ifdef CONFIG_TPL_BUILD +#if CONFIG_IS_ENABLED(OF_PLATDATA) + ret = conv_of_platdata(dev); + if (ret) + return ret; +#endif + + priv->chan[0].msch = syscon_get_first_range(ROCKCHIP_SYSCON_MSCH); + priv->chan[0].pctl = regmap_get_range(plat->map, 0); + priv->chan[0].phy = regmap_get_range(plat->map, 1); + ret = rockchip_get_clk(&dev_clk); + if (ret) + return ret; + priv->ddr_clk.id = CLK_DDR; + ret = clk_request(dev_clk, &priv->ddr_clk); + if (ret) + return ret; + + priv->cru = rockchip_get_cru(); + if (IS_ERR(priv->cru)) + return PTR_ERR(priv->cru); + ret = sdram_init(priv, plat); + if (ret) + return ret; +#else + priv->info.base = CONFIG_SYS_SDRAM_BASE; + priv->info.size = rockchip_sdram_size( + (phys_addr_t)&priv->grf->os_reg[2]); +#endif + + return 0; +} + +static int rk322x_dmc_get_info(struct udevice *dev, struct ram_info *info) +{ + struct dram_info *priv = dev_get_priv(dev); + + *info = priv->info; + + return 0; +} + +static struct ram_ops rk322x_dmc_ops = { + .get_info = rk322x_dmc_get_info, +}; + +static const struct udevice_id rk322x_dmc_ids[] = { + { .compatible = "rockchip,rk3228-dmc" }, + { } +}; + +U_BOOT_DRIVER(dmc_rk322x) = { + .name = "rockchip_rk322x_dmc", + .id = UCLASS_RAM, + .of_match = rk322x_dmc_ids, + .ops = &rk322x_dmc_ops, +#ifdef CONFIG_TPL_BUILD + .ofdata_to_platdata = rk322x_dmc_ofdata_to_platdata, +#endif + .probe = rk322x_dmc_probe, + .priv_auto_alloc_size = sizeof(struct dram_info), +#ifdef CONFIG_TPL_BUILD + .platdata_auto_alloc_size = sizeof(struct rk322x_sdram_params), +#endif +}; +
Acked-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
As previously discussed, I'll merge this in its current form (i.e. duplicating code and data structures) with a commitment (AFAIK there is work ongoing towards this goal at Rockchip, but it will take a while to complete) to unify our DRAM drivers in one of the upcoming merge windows.
Changes in v4:
driver to driver/ram”
Thanks for doing this. This saves me a lot of work.
Regards, Philipp.
Changes in v3:
- (C) Copyright 2017 Rockchip Electronics Co., Ltd
+enum {
- DDR3 = 3,
- LPDDR2 = 5,
- LPDDR3 = 6,
- UNUSED = 0xFF,
- u8 rank;
- u8 col;
- u8 bk;
- u8 bw;
- u8 dbw;
- u8 row_3_4;
- u8 cs0_row;
- u8 cs1_row;
- u8 dummy;
+#endif +};
- u32 scfg;
- u32 sctl;
- u32 stat;
- u32 intrstat;
- u32 reserved0[(0x40 - 0x10) / 4];
- u32 mcmd;
- u32 powctl;
- u32 powstat;
- u32 cmdtstat;
- u32 cmdtstaten;
- u32 reserved1[(0x60 - 0x54) / 4];
- u32 mrrcfg0;
- u32 mrrstat0;
- u32 mrrstat1;
- u32 reserved2[(0x7c - 0x6c) / 4];
- u32 mcfg1;
- u32 mcfg;
- u32 ppcfg;
- u32 mstat;
- u32 lpddr2zqcfg;
- u32 reserved3;
- u32 dtupdes;
- u32 dtuna;
- u32 dtune;
- u32 dtuprd0;
- u32 dtuprd1;
- u32 dtuprd2;
- u32 dtuprd3;
- u32 dtuawdt;
- u32 reserved4[(0xc0 - 0xb4) / 4];
- u32 togcnt1u;
- u32 tinit;
- u32 trsth;
- u32 togcnt100n;
- u32 trefi;
- u32 tmrd;
- u32 trfc;
- u32 trp;
- u32 trtw;
- u32 tal;
- u32 tcl;
- u32 tcwl;
- u32 tras;
- u32 trc;
- u32 trcd;
- u32 trrd;
- u32 trtp;
- u32 twr;
- u32 twtr;
- u32 texsr;
- u32 txp;
- u32 txpdll;
- u32 tzqcs;
- u32 tzqcsi;
- u32 tdqs;
- u32 tcksre;
- u32 tcksrx;
- u32 tcke;
- u32 tmod;
- u32 trstl;
- u32 tzqcl;
- u32 tmrr;
- u32 tckesr;
- u32 tdpd;
- u32 tref_mem_ddr3;
- u32 reserved5[(0x180 - 0x14c) / 4];
- u32 ecccfg;
- u32 ecctst;
- u32 eccclr;
- u32 ecclog;
- u32 reserved6[(0x200 - 0x190) / 4];
- u32 dtuwactl;
- u32 dturactl;
- u32 dtucfg;
- u32 dtuectl;
- u32 dtuwd0;
- u32 dtuwd1;
- u32 dtuwd2;
- u32 dtuwd3;
- u32 dtuwdm;
- u32 dturd0;
- u32 dturd1;
- u32 dturd2;
- u32 dturd3;
- u32 dtulfsrwd;
- u32 dtulfsrrd;
- u32 dtueaf;
- /* dfi control registers */
- u32 dfitctrldelay;
- u32 dfiodtcfg;
- u32 dfiodtcfg1;
- u32 dfiodtrankmap;
- /* dfi write data registers */
- u32 dfitphywrdata;
- u32 dfitphywrlat;
- u32 reserved7[(0x260 - 0x258) / 4];
- u32 dfitrddataen;
- u32 dfitphyrdlat;
- u32 reserved8[(0x270 - 0x268) / 4];
- u32 dfitphyupdtype0;
- u32 dfitphyupdtype1;
- u32 dfitphyupdtype2;
- u32 dfitphyupdtype3;
- u32 dfitctrlupdmin;
- u32 dfitctrlupdmax;
- u32 dfitctrlupddly;
- u32 reserved9;
- u32 dfiupdcfg;
- u32 dfitrefmski;
- u32 dfitctrlupdi;
- u32 reserved10[(0x2ac - 0x29c) / 4];
- u32 dfitrcfg0;
- u32 dfitrstat0;
- u32 dfitrwrlvlen;
- u32 dfitrrdlvlen;
- u32 dfitrrdlvlgateen;
- u32 dfiststat0;
- u32 dfistcfg0;
- u32 dfistcfg1;
- u32 reserved11;
- u32 dfitdramclken;
- u32 dfitdramclkdis;
- u32 dfistcfg2;
- u32 dfistparclr;
- u32 dfistparlog;
- u32 reserved12[(0x2f0 - 0x2e4) / 4];
- u32 dfilpcfg0;
- u32 reserved13[(0x300 - 0x2f4) / 4];
- u32 dfitrwrlvlresp0;
- u32 dfitrwrlvlresp1;
- u32 dfitrwrlvlresp2;
- u32 dfitrrdlvlresp0;
- u32 dfitrrdlvlresp1;
- u32 dfitrrdlvlresp2;
- u32 dfitrwrlvldelay0;
- u32 dfitrwrlvldelay1;
- u32 dfitrwrlvldelay2;
- u32 dfitrrdlvldelay0;
- u32 dfitrrdlvldelay1;
- u32 dfitrrdlvldelay2;
- u32 dfitrrdlvlgatedelay0;
- u32 dfitrrdlvlgatedelay1;
- u32 dfitrrdlvlgatedelay2;
- u32 dfitrcmd;
- u32 reserved14[(0x3f8 - 0x340) / 4];
- u32 ipvr;
- u32 iptr;
- u32 ddrphy_reg[0x100];
- u32 togcnt1u;
- u32 tinit;
- u32 trsth;
- u32 togcnt100n;
- u32 trefi;
- u32 tmrd;
- u32 trfc;
- u32 trp;
- u32 trtw;
- u32 tal;
- u32 tcl;
- u32 tcwl;
- u32 tras;
- u32 trc;
- u32 trcd;
- u32 trrd;
- u32 trtp;
- u32 twr;
- u32 twtr;
- u32 texsr;
- u32 txp;
- u32 txpdll;
- u32 tzqcs;
- u32 tzqcsi;
- u32 tdqs;
- u32 tcksre;
- u32 tcksrx;
- u32 tcke;
- u32 tmod;
- u32 trstl;
- u32 tzqcl;
- u32 tmrr;
- u32 tckesr;
- u32 tdpd;
- u32 trefi_mem_ddr3;
- u32 mr[4];
- u32 mr11;
- u32 bl;
- u32 cl_al;
- u32 ddrtiming;
- u32 ddrmode;
- u32 readlatency;
- u32 activate;
- u32 devtodev;
- u32 id_coreid;
- u32 id_revisionid;
- u32 ddrconf;
- u32 ddrtiming;
- u32 ddrmode;
- u32 readlatency;
- u32 activate;
- u32 devtodev;
- struct rk322x_msch_timings noc_timing;
- u32 ddrconfig;
- u32 ddr_freq;
- u32 dramtype;
* unused for rk322x
- u32 stride;
- u32 odt;
+/* MCMD */ +enum {
- DESELECT_CMD = 0,
- PREA_CMD,
- REF_CMD,
- MRS_CMD,
- ZQCS_CMD,
- ZQCL_CMD,
- RSTL_CMD,
- MRR_CMD = 8,
- DPDE_CMD,
- /* DDRPHY_REG0 */
- SOFT_RESET_MASK = 3,
- SOFT_DERESET_ANALOG = 1 << 2,
- SOFT_DERESET_DIGITAL = 1 << 3,
- SOFT_RESET_SHIFT = 2,
- /* DDRPHY REG1 */
- PHY_DDR3 = 0,
- PHY_DDR2 = 1,
- PHY_LPDDR3 = 2,
- PHY_LPDDR2 = 3,
- PHT_BL_8 = 1 << 2,
- PHY_BL_4 = 0 << 2,
- /* DDRPHY_REG2 */
- MEMORY_SELECT_DDR3 = 0 << 0,
- MEMORY_SELECT_LPDDR3 = 2 << 0,
- MEMORY_SELECT_LPDDR2 = 3 << 0,
- DQS_SQU_CAL_SEL_CS0_CS1 = 0 << 4,
- DQS_SQU_CAL_SEL_CS1 = 1 << 4,
- DQS_SQU_CAL_SEL_CS0 = 2 << 4,
- DQS_SQU_CAL_NORMAL_MODE = 0 << 1,
- DQS_SQU_CAL_BYPASS_MODE = 1 << 1,
- DQS_SQU_CAL_START = 1 << 0,
- DQS_SQU_NO_CAL = 0 << 0,
- PHY_RON_RTT_DISABLE = 0,
- PHY_RON_RTT_451OHM = 1,
- PHY_RON_RTT_225OHM,
- PHY_RON_RTT_150OHM,
- PHY_RON_RTT_112OHM,
- PHY_RON_RTT_90OHM,
- PHY_RON_RTT_75OHM,
- PHY_RON_RTT_64OHM = 7,
- PHY_RON_RTT_56OHM = 16,
- PHY_RON_RTT_50OHM,
- PHY_RON_RTT_45OHM,
- PHY_RON_RTT_41OHM,
- PHY_RON_RTT_37OHM,
- PHY_RON_RTT_34OHM,
- PHY_RON_RTT_33OHM,
- PHY_RON_RTT_30OHM = 23,
- PHY_RON_RTT_28OHM = 24,
- PHY_RON_RTT_26OHM,
- PHY_RON_RTT_25OHM,
- PHY_RON_RTT_23OHM,
- PHY_RON_RTT_22OHM,
- PHY_RON_RTT_21OHM,
- PHY_RON_RTT_20OHM,
- PHY_RON_RTT_19OHM = 31,
- DQS_DLL_NO_DELAY = 0,
- DQS_DLL_22P5_DELAY,
- DQS_DLL_45_DELAY,
- DQS_DLL_67P5_DELAY,
- DQS_DLL_90_DELAY,
- DQS_DLL_112P5_DELAY,
- DQS_DLL_135_DELAY,
- DQS_DLL_157P5_DELAY,
- struct rk322x_ddr_pctl *pctl;
- struct rk322x_ddr_phy *phy;
- struct rk322x_service_sys *msch;
+struct dram_info {
- struct chan_info chan[1];
- struct ram_info info;
- struct clk ddr_clk;
- struct rk322x_cru *cru;
- struct rk322x_grf *grf;
int num_channels;
struct regmap *map;
- [7:6] bank(n:n bit bank)
- [5:4] row(13+n)
- [3] cs(0:1 cs, 1:2 cs)
- [2:1] bank(n:n bit bank)
- [0] col(10+n)
- ((0 << 6) | (0 << 4) | (0 << 3) | (1 << 2) | 1),
- ((0 << 6) | (1 << 4) | (0 << 3) | (1 << 2) | 1),
- ((0 << 6) | (2 << 4) | (0 << 3) | (1 << 2) | 1),
- ((0 << 6) | (3 << 4) | (0 << 3) | (1 << 2) | 1),
- ((0 << 6) | (1 << 4) | (0 << 3) | (1 << 2) | 2),
- ((0 << 6) | (2 << 4) | (0 << 3) | (1 << 2) | 2),
- ((0 << 6) | (3 << 4) | (0 << 3) | (1 << 2) | 2),
- ((0 << 6) | (0 << 4) | (0 << 3) | (1 << 2) | 0),
- ((0 << 6) | (1 << 4) | (0 << 3) | (1 << 2) | 0),
- ((0 << 6) | (2 << 4) | (0 << 3) | (1 << 2) | 0),
- ((0 << 6) | (3 << 4) | (0 << 3) | (1 << 2) | 0),
- ((0 << 6) | (2 << 4) | (0 << 3) | (0 << 2) | 1),
- ((1 << 6) | (1 << 4) | (0 << 3) | (0 << 2) | 2),
- ((1 << 6) | (1 << 4) | (0 << 3) | (0 << 2) | 1),
- ((0 << 6) | (3 << 4) | (1 << 3) | (1 << 2) | 1),
- ((0 << 6) | (3 << 4) | (1 << 3) | (1 << 2) | 0),
- int i;
- for (i = 0; i < n / sizeof(u32); i++) {
writel(*src, dest);
src++;
dest++;
- rk_clrsetreg(&cru->cru_softrst_con[5], 1 << DDRCTRL_PSRST_SHIFT |
- rockchip_udelay(10);
- rk_clrreg(&cru->cru_softrst_con[5], 1 << DDRPHY_PSRST_SHIFT |
- rk_clrreg(&cru->cru_softrst_con[5], 1 << DDRCTRL_PSRST_SHIFT |
- clrbits_le32(&ddr_phy->ddrphy_reg[0],
- setbits_le32(&ddr_phy->ddrphy_reg[0],
- rockchip_udelay(5);
- rockchip_udelay(1);
- u32 tmp;
- setbits_le32(&ddr_phy->ddrphy_reg[0x13], 0x10);
- setbits_le32(&ddr_phy->ddrphy_reg[0x26], 0x10);
- setbits_le32(&ddr_phy->ddrphy_reg[0x36], 0x10);
- setbits_le32(&ddr_phy->ddrphy_reg[0x46], 0x10);
- setbits_le32(&ddr_phy->ddrphy_reg[0x56], 0x10);
- clrbits_le32(&ddr_phy->ddrphy_reg[0x14], 0x8);
- clrbits_le32(&ddr_phy->ddrphy_reg[0x27], 0x8);
- clrbits_le32(&ddr_phy->ddrphy_reg[0x37], 0x8);
- clrbits_le32(&ddr_phy->ddrphy_reg[0x47], 0x8);
- clrbits_le32(&ddr_phy->ddrphy_reg[0x57], 0x8);
- if (freq <= 400)
- else
- if (freq <= 680)
tmp = 3;
- else
tmp = 2;
- writel(tmp, &ddr_phy->ddrphy_reg[0x28]);
- writel(tmp, &ddr_phy->ddrphy_reg[0x38]);
- writel(tmp, &ddr_phy->ddrphy_reg[0x48]);
- writel(tmp, &ddr_phy->ddrphy_reg[0x58]);
- writel((START_CMD | (rank << 20) | arg | cmd), &pctl->mcmd);
- while (readl(&pctl->mcmd) & START_CMD)
- struct rk322x_ddr_pctl *pctl = chan->pctl;
- u32 dramtype = sdram_params->base.dramtype;
- if (dramtype == DDR3) {
rockchip_udelay(1);
CMD_ADDR_SHIFT);
CMD_ADDR_SHIFT);
CMD_ADDR_SHIFT);
DDR3_DLL_RESET) &
- } else {
LPDDR23_OP_SHIFT);
LPDDR23_OP_SHIFT);
rockchip_udelay(1);
LPDDR23_OP_SHIFT);
rockchip_udelay(1);
LPDDR23_MA_SHIFT |
- struct rk322x_ddr_phy *ddr_phy = chan->phy;
- u32 value;
- u32 bw = (readl(&ddr_phy->ddrphy_reg[0]) >> 4) & 0xf;
- u32 ret;
- /* disable auto refresh */
- value = readl(&pctl->trefi) | (1 << 31);
- writel(1 << 31, &pctl->trefi);
- clrsetbits_le32(&ddr_phy->ddrphy_reg[2], 0x30,
- setbits_le32(&ddr_phy->ddrphy_reg[2], DQS_SQU_CAL_START);
- rockchip_udelay(30);
- ret = readl(&ddr_phy->ddrphy_reg[0xff]);
- clrbits_le32(&ddr_phy->ddrphy_reg[2],
DQS_SQU_CAL_START);
- send_command(pctl, 3, PREA_CMD, 0);
- send_command(pctl, 3, REF_CMD, 0);
- writel(value, &pctl->trefi);
- if (ret & 0x10) {
ret = -1;
- } else {
- return ret;
- unsigned int state;
- while (1) {
switch (state) {
case LOW_POWER:
!= ACCESS)
case ACCESS:
/* fallthrough */
case INIT_MEM:
break;
case CONFIG:
return;
default:
break;
- while (1) {
switch (state) {
case LOW_POWER:
break;
case INIT_MEM:
/* fallthrough */
case CONFIG:
break;
case ACCESS:
return;
default:
break;
- while (1) {
switch (state) {
case INIT_MEM:
/* fallthrough */
case CONFIG:
break;
case ACCESS:
LOW_POWER)
break;
case LOW_POWER:
return;
default:
break;
- struct rk322x_ddr_phy *ddr_phy = dram->chan[0].phy;
- struct rk322x_grf *grf = dram->grf;
- writel(GRF_DDRPHY_BUFFEREN_CORE_EN, &grf->soc_con[0]);
- clrbits_le32(&ddr_phy->ddrphy_reg[0], 0x3 << 2);
- setbits_le32(&ddr_phy->ddrphy_reg[0], 1 << 2);
- setbits_le32(&ddr_phy->ddrphy_reg[0], 1 << 3);
- writel(GRF_DDRPHY_BUFFEREN_CORE_DIS, &grf->soc_con[0]);
- struct rk322x_ddr_pctl *pctl = dram->chan[0].pctl;
- if (bw == 1) {
- } else {
&grf->soc_con[0]);
- u32 burst_len;
- u32 bw;
- if (sdram_params->ch[0].bw == 2)
- else
- writel(DFI_INIT_START | DFI_DATA_BYTE_DISABLE_EN, &pctl->dfistcfg0);
- writel(DFI_DRAM_CLK_SR_EN | DFI_DRAM_CLK_DPD_EN, &pctl->dfistcfg1);
- writel(DFI_PARITY_INTR_EN | DFI_PARITY_EN, &pctl->dfistcfg2);
- writel(0x51010, &pctl->dfilpcfg0);
- writel(1, &pctl->dfitphyupdtype0);
- writel(0x0d, &pctl->dfitphyrdlat);
- writel(0, &pctl->dfitphywrdata);
- writel(0, &pctl->dfiupdcfg);
- copy_to_reg(&pctl->togcnt1u, &sdram_params->pctl_timing.togcnt1u,
&pctl->dfiodtcfg);
&pctl->mcfg);
- } else {
else
&pctl->mcfg);
} else {
&pctl->mcfg);
- setbits_le32(&pctl->scfg, 1);
- struct rk322x_service_sys *axi_bus = chan->msch;
- struct rk322x_msch_timings *noc_timing = &sdram_params->base.noc_timing;
- struct rk322x_phy_timing *phy_timing = &sdram_params->phy_timing;
- struct rk322x_pctl_timing *pctl_timing = &sdram_params->pctl_timing;
- u32 cmd_drv, clk_drv, dqs_drv, dqs_odt;
- writel(noc_timing->ddrtiming, &axi_bus->ddrtiming);
- writel(noc_timing->ddrmode, &axi_bus->ddrmode);
- writel(noc_timing->readlatency, &axi_bus->readlatency);
- writel(noc_timing->activate, &axi_bus->activate);
- writel(noc_timing->devtodev, &axi_bus->devtodev);
- switch (sdram_params->base.dramtype) {
- case DDR3:
break;
- case LPDDR2:
break;
- default:
break;
- writel(phy_timing->cl_al, &ddr_phy->ddrphy_reg[0xb]);
- writel(pctl_timing->tcwl, &ddr_phy->ddrphy_reg[0xc]);
- cmd_drv = PHY_RON_RTT_34OHM;
- clk_drv = PHY_RON_RTT_45OHM;
- dqs_drv = PHY_RON_RTT_34OHM;
- if (sdram_params->base.dramtype == LPDDR2)
- else
- writel(cmd_drv, &ddr_phy->ddrphy_reg[0x11]);
- clrsetbits_le32(&ddr_phy->ddrphy_reg[0x12], (0x1f << 3), cmd_drv << 3);
- writel(clk_drv, &ddr_phy->ddrphy_reg[0x16]);
- writel(clk_drv, &ddr_phy->ddrphy_reg[0x18]);
- writel(dqs_drv, &ddr_phy->ddrphy_reg[0x20]);
- writel(dqs_drv, &ddr_phy->ddrphy_reg[0x2f]);
- writel(dqs_drv, &ddr_phy->ddrphy_reg[0x30]);
- writel(dqs_drv, &ddr_phy->ddrphy_reg[0x3f]);
- writel(dqs_drv, &ddr_phy->ddrphy_reg[0x40]);
- writel(dqs_drv, &ddr_phy->ddrphy_reg[0x4f]);
- writel(dqs_drv, &ddr_phy->ddrphy_reg[0x50]);
- writel(dqs_drv, &ddr_phy->ddrphy_reg[0x5f]);
- writel(dqs_odt, &ddr_phy->ddrphy_reg[0x21]);
- writel(dqs_odt, &ddr_phy->ddrphy_reg[0x2e]);
- writel(dqs_odt, &ddr_phy->ddrphy_reg[0x31]);
- writel(dqs_odt, &ddr_phy->ddrphy_reg[0x3e]);
- writel(dqs_odt, &ddr_phy->ddrphy_reg[0x41]);
- writel(dqs_odt, &ddr_phy->ddrphy_reg[0x4e]);
- writel(dqs_odt, &ddr_phy->ddrphy_reg[0x51]);
- writel(dqs_odt, &ddr_phy->ddrphy_reg[0x5e]);
- char noc_config;
- int i = 0;
- struct rk322x_sdram_channel *config = &sdram_params->ch[0];
- move_to_config_state(chan->pctl);
- if ((config->rank == 2) && (config->cs1_row == config->cs0_row)) {
i = 14;
goto finish;
i = 15;
goto finish;
- noc_config = ((config->cs0_row - 13) << 4) | ((config->bk - 2) << 2) |
- for (i = 0; i < 11; i++) {
break;
- if (i < 11)
goto finish;
- noc_config = ((config->bk - 2) << 6) | ((config->cs0_row - 13) << 4) |
- for (i = 11; i < 14; i++) {
break;
- if (i < 14)
goto finish;
- else
i = 0;
+finish:
- writel(i, &axi_bus->ddrconf);
- move_to_access_state(chan->pctl);
- struct rk322x_sdram_channel *info = &sdram_params->ch[0];
- u32 sys_reg = 0;
- sys_reg |= sdram_params->base.dramtype << SYS_REG_DDRTYPE_SHIFT;
- sys_reg |= (1 - 1) << SYS_REG_NUM_CH_SHIFT;
- sys_reg |= info->row_3_4 << SYS_REG_ROW_3_4_SHIFT(0);
- sys_reg |= 1 << SYS_REG_CHINFO_SHIFT(0);
- sys_reg |= (info->rank - 1) << SYS_REG_RANK_SHIFT(0);
- sys_reg |= (info->col - 9) << SYS_REG_COL_SHIFT(0);
- sys_reg |= info->bk == 3 ? 0 : 1 << SYS_REG_BK_SHIFT(0);
- sys_reg |= (info->cs0_row - 13) << SYS_REG_CS0_ROW_SHIFT(0);
- sys_reg |= (info->cs1_row - 13) << SYS_REG_CS1_ROW_SHIFT(0);
- sys_reg |= (2 >> info->bw) << SYS_REG_BW_SHIFT(0);
- sys_reg |= (2 >> info->dbw) << SYS_REG_DBW_SHIFT(0);
- writel(sys_reg, &dram->grf->os_reg[2]);
- u32 bw, row, col, addr;
- u32 ret = 0;
- struct rk322x_service_sys *axi_bus = dram->chan[0].msch;
- if (sdram_params->base.dramtype == DDR3)
- else
- move_to_config_state(dram->chan[0].pctl);
- /* bw detect */
- set_bw(dram, 2);
- if (data_training(&dram->chan[0]) == 0) {
bw = 2;
- } else {
bw = 1;
set_bw(dram, 1);
ret = -EINVAL;
- sdram_params->ch[0].bw = bw;
- sdram_params->ch[0].bk = 3;
- if (bw == 2)
- else
- move_to_access_state(dram->chan[0].pctl);
- for (col = 11; col >= 9; col--) {
break;
- if (col == 8) {
ret = -EINVAL;
goto out;
- } else {
- writel(10, &axi_bus->ddrconf);
- /* Detect row*/
- for (row = 16; row >= 12; row--) {
break;
- if (row == 11) {
ret = -EINVAL;
- } else {
- /* cs detect */
- writel(0, CONFIG_SYS_SDRAM_BASE);
- writel(TEST_PATTEN, CONFIG_SYS_SDRAM_BASE + (1u << 30));
- writel(~TEST_PATTEN, CONFIG_SYS_SDRAM_BASE + (1u << 30) + 4);
- if ((readl(CONFIG_SYS_SDRAM_BASE + (1u << 30)) == TEST_PATTEN) &&
- else
+out:
- return ret;
- int ret;
- ret = clk_set_rate(&dram->ddr_clk,
- if (ret < 0) {
return ret;
- phy_pctrl_reset(dram->cru, dram->chan[0].phy);
- phy_dll_bypass_set(dram->chan[0].phy, sdram_params->base.ddr_freq);
- pctl_cfg(dram->chan[0].pctl, sdram_params, dram->grf);
- phy_cfg(&dram->chan[0], sdram_params);
- writel(POWER_UP_START, &dram->chan[0].pctl->powctl);
- while (!(readl(&dram->chan[0].pctl->powstat) & POWER_UP_DONE))
- memory_init(&dram->chan[0], sdram_params);
- ret = dram_cap_detect(dram, sdram_params);
- if (ret)
goto out;
- dram_cfg_rbc(&dram->chan[0], sdram_params);
- dram_all_config(dram, sdram_params);
+out:
- return ret;
- struct rk322x_sdram_params *params = dev_get_platdata(dev);
- const void *blob = gd->fdt_blob;
- int node = dev_of_offset(dev);
- int ret;
- params->num_channels = 1;
- ret = fdtdec_get_int_array(blob, node, "rockchip,pctl-timing",
- if (ret) {
return -EINVAL;
- ret = fdtdec_get_int_array(blob, node, "rockchip,phy-timing",
- if (ret) {
return -EINVAL;
- ret = fdtdec_get_int_array(blob, node, "rockchip,sdram-params",
(u32 *)¶ms->base,
- if (ret) {
return -EINVAL;
- ret = regmap_init_mem(dev, ¶ms->map);
- if (ret)
return ret;
- struct rk322x_sdram_params *plat = dev_get_platdata(dev);
- struct dtd_rockchip_rk322x_dmc *of_plat = &plat->of_plat;
- int ret;
- memcpy(&plat->pctl_timing, of_plat->rockchip_pctl_timing,
- memcpy(&plat->phy_timing, of_plat->rockchip_phy_timing,
- memcpy(&plat->base, of_plat->rockchip_sdram_params, sizeof(plat->base));
- plat->num_channels = 1;
- ret = regmap_init_mem_platdata(dev, of_plat->reg,
&plat->map);
- if (ret)
return ret;
+} +#endif
- int ret;
- struct udevice *dev_clk;
- struct dram_info *priv = dev_get_priv(dev);
- priv->grf = syscon_get_first_range(ROCKCHIP_SYSCON_GRF);
- ret = conv_of_platdata(dev);
- if (ret)
return ret;
- priv->chan[0].msch = syscon_get_first_range(ROCKCHIP_SYSCON_MSCH);
- priv->chan[0].pctl = regmap_get_range(plat->map, 0);
- priv->chan[0].phy = regmap_get_range(plat->map, 1);
- ret = rockchip_get_clk(&dev_clk);
- if (ret)
return ret;
- priv->ddr_clk.id = CLK_DDR;
- ret = clk_request(dev_clk, &priv->ddr_clk);
- if (ret)
return ret;
- priv->cru = rockchip_get_cru();
- if (IS_ERR(priv->cru))
- ret = sdram_init(priv, plat);
- if (ret)
return ret;
+#else
- priv->info.base = CONFIG_SYS_SDRAM_BASE;
- priv->info.size = rockchip_sdram_size(
- *info = priv->info;
- .get_info = rk322x_dmc_get_info,
- { .compatible = "rockchip,rk3228-dmc" },
- .name = "rockchip_rk322x_dmc",
- .id = UCLASS_RAM,
- .of_match = rk322x_dmc_ids,
- .ops = &rk322x_dmc_ops,
- .ofdata_to_platdata = rk322x_dmc_ofdata_to_platdata,
- .probe = rk322x_dmc_probe,
- .priv_auto_alloc_size = sizeof(struct dram_info),
- .platdata_auto_alloc_size = sizeof(struct rk322x_sdram_params),
+#endif +};
-- 1.9.1
Signed-off-by: Kever Yang kever.yang@rock-chips.com Acked-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Changes in v4:
Changes in v3:
Applied to u-boot-rockchip, thanks!
The dram channel info will be auto detect by the driver, we do not need it.
Changes in v4: None Changes in v3: None
arch/arm/dts/rk3229-evb.dts | 1 - 1 file changed, 1 deletion(-)
diff --git a/arch/arm/dts/rk3229-evb.dts b/arch/arm/dts/rk3229-evb.dts index 64f1c2d..ae0b0a4 100644 --- a/arch/arm/dts/rk3229-evb.dts +++ b/arch/arm/dts/rk3229-evb.dts @@ -40,7 +40,6 @@ };
&dmc { - rockchip,sdram-channel = /bits/ 8 <1 10 3 2 1 0 15 15>; rockchip,pctl-timing = <0x96 0xC8 0x1F3 0xF 0x8000004D 0x4 0x4E 0x6 0x3 0x0 0x6 0x5 0xC 0x10 0x6 0x4 0x4 0x5 0x4 0x200 0x3 0xA 0x40 0x0 0x1
Dr. Philipp Tomsich
Kever Yang
Philipp Tomsich
