[U-Boot] [PATCH v2 0/4] Tegra114: MMC: Add MMC driver for T114/Dalmore
This patchset adds SDMMC device-tree support to the Tegra114 dts files, and enables the Tegra MMC driver on Tegra114 Dalmore.
Tested on my Dalmore E1611 board, eMMC and SD-Card work fine, can load a kernel off of a SD card OK, card detect works, and the env is now stored in eMMC (end of the 2nd 'boot' sector, same as Tegra20/30).
Changes in v2: - Remove SDIOCFG_HSM define, unused - Remove I2C retries - Change CONFIG_ENV_OFFSET to match Dalmore's eMMC chip boot part size
Tom Warren (4): Tegra114: fdt: Add SDMMC (sdhci) nodes for T114 boards (Dalmore for now) Tegra114: Dalmore: Add SDIO3 pad config to pinctrl_config table Tegra114: MMC: Add SD bus power-rail init routine Tegra114: MMC: Enable DT MMC driver support for Tegra114 Dalmore boards
arch/arm/dts/tegra114.dtsi | 32 ++++++++++++ arch/arm/include/asm/arch-tegra114/gp_padctrl.h | 6 +++ board/nvidia/dalmore/dalmore.c | 67 +++++++++++++++++++++++++ board/nvidia/dalmore/pinmux-config-dalmore.h | 6 +++ board/nvidia/dts/tegra114-dalmore.dts | 13 +++++ include/configs/dalmore.h | 12 ++++- 6 files changed, 135 insertions(+), 1 deletion(-)
Took these values directly from the kernel dts files.
Signed-off-by: Tom Warren twarren@nvidia.com Reviewed-by: Stephen Warren swarren@nvidia.com --- v2: No change
arch/arm/dts/tegra114.dtsi | 32 ++++++++++++++++++++++++++++++++ board/nvidia/dts/tegra114-dalmore.dts | 13 +++++++++++++ 2 files changed, 45 insertions(+)
diff --git a/arch/arm/dts/tegra114.dtsi b/arch/arm/dts/tegra114.dtsi index 3b1ca35..f86d18d 100644 --- a/arch/arm/dts/tegra114.dtsi +++ b/arch/arm/dts/tegra114.dtsi @@ -184,4 +184,36 @@ /* PERIPH_ID_SBC6, PLLP_OUT0 */ clocks = <&tegra_car 105>; }; + + sdhci@78000000 { + compatible = "nvidia,tegra114-sdhci", "nvidia,tegra30-sdhci"; + reg = <0x78000000 0x200>; + interrupts = <0 14 0x04>; + clocks = <&tegra_car 14>; + status = "disable"; + }; + + sdhci@78000200 { + compatible = "nvidia,tegra114-sdhci", "nvidia,tegra30-sdhci"; + reg = <0x78000200 0x200>; + interrupts = <0 15 0x04>; + clocks = <&tegra_car 9>; + status = "disable"; + }; + + sdhci@78000400 { + compatible = "nvidia,tegra114-sdhci", "nvidia,tegra30-sdhci"; + reg = <0x78000400 0x200>; + interrupts = <0 19 0x04>; + clocks = <&tegra_car 69>; + status = "disable"; + }; + + sdhci@78000600 { + compatible = "nvidia,tegra114-sdhci", "nvidia,tegra30-sdhci"; + reg = <0x78000600 0x200>; + interrupts = <0 31 0x04>; + clocks = <&tegra_car 15>; + status = "disable"; + }; }; diff --git a/board/nvidia/dts/tegra114-dalmore.dts b/board/nvidia/dts/tegra114-dalmore.dts index 87cb0ba..86e9459 100644 --- a/board/nvidia/dts/tegra114-dalmore.dts +++ b/board/nvidia/dts/tegra114-dalmore.dts @@ -12,6 +12,8 @@ i2c2 = "/i2c@7000c400"; i2c3 = "/i2c@7000c500"; i2c4 = "/i2c@7000c700"; + sdhci0 = "/sdhci@78000600"; + sdhci1 = "/sdhci@78000400"; };
memory { @@ -48,4 +50,15 @@ status = "okay"; spi-max-frequency = <25000000>; }; + + sdhci@78000400 { + cd-gpios = <&gpio 170 1>; /* gpio PV2 */ + bus-width = <4>; + status = "okay"; + }; + + sdhci@78000600 { + bus-width = <8>; + status = "okay"; + }; };
SDIO1 (the SD-card slot on Dalmore) needs to have its pads setup before the MMC driver is added.
Signed-off-by: Tom Warren twarren@nvidia.com Reviewed-by: Stephen Warren swarren@nvidia.com --- v2: Remove SDIOCFG_HSM define, unused.
arch/arm/include/asm/arch-tegra114/gp_padctrl.h | 6 ++++++ board/nvidia/dalmore/dalmore.c | 4 ++++ board/nvidia/dalmore/pinmux-config-dalmore.h | 6 ++++++ 3 files changed, 16 insertions(+)
diff --git a/arch/arm/include/asm/arch-tegra114/gp_padctrl.h b/arch/arm/include/asm/arch-tegra114/gp_padctrl.h index 1ef1a14..41ce677 100644 --- a/arch/arm/include/asm/arch-tegra114/gp_padctrl.h +++ b/arch/arm/include/asm/arch-tegra114/gp_padctrl.h @@ -74,4 +74,10 @@ struct apb_misc_gp_ctlr { u32 aocfg0; /* 0x1AC: APB_MISC_GP_AOCFG0PADCTRL */ };
+/* SDMMC1/3 settings from section 27.5 of T114 TRM */ +#define SDIOCFG_DRVUP_SLWF 0 +#define SDIOCFG_DRVDN_SLWR 0 +#define SDIOCFG_DRVUP 0x24 +#define SDIOCFG_DRVDN 0x14 + #endif /* _TEGRA114_GP_PADCTRL_H_ */ diff --git a/board/nvidia/dalmore/dalmore.c b/board/nvidia/dalmore/dalmore.c index 2020a5f..7449b5b 100644 --- a/board/nvidia/dalmore/dalmore.c +++ b/board/nvidia/dalmore/dalmore.c @@ -16,6 +16,7 @@
#include <common.h> #include <asm/arch/pinmux.h> +#include <asm/arch/gp_padctrl.h> #include "pinmux-config-dalmore.h"
/* @@ -32,4 +33,7 @@ void pinmux_init(void)
pinmux_config_table(unused_pins_lowpower, ARRAY_SIZE(unused_pins_lowpower)); + + /* Initialize any non-default pad configs (APB_MISC_GP regs) */ + padgrp_config_table(dalmore_padctrl, ARRAY_SIZE(dalmore_padctrl)); } diff --git a/board/nvidia/dalmore/pinmux-config-dalmore.h b/board/nvidia/dalmore/pinmux-config-dalmore.h index 3ef6f4e..8c05a15 100644 --- a/board/nvidia/dalmore/pinmux-config-dalmore.h +++ b/board/nvidia/dalmore/pinmux-config-dalmore.h @@ -361,4 +361,10 @@ static struct pingroup_config tegra114_pinmux_set_nontristate[] = {
DEFAULT_PINMUX(SDMMC3_CD_N, SDMMC3, UP, NORMAL, INPUT), }; + +static struct padctrl_config dalmore_padctrl[] = { + /* (_padgrp, _slwf, _slwr, _drvup, _drvdn, _lpmd, _schmt, _hsm) */ + DEFAULT_PADCFG(SDIO3, SDIOCFG_DRVUP_SLWF, SDIOCFG_DRVDN_SLWR, \ + SDIOCFG_DRVUP, SDIOCFG_DRVDN, NONE, NONE, NONE), +}; #endif /* PINMUX_CONFIG_COMMON_H */
T114 requires SD bus power-rail bringup for the SDIO card on SDMMC3.
Signed-off-by: Tom Warren twarren@nvidia.com Reviewed-by: Stephen Warren swarren@nvidia.com --- v2: Remove I2C retries
board/nvidia/dalmore/dalmore.c | 62 ++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 62 insertions(+)
diff --git a/board/nvidia/dalmore/dalmore.c b/board/nvidia/dalmore/dalmore.c index 7449b5b..2c23a29 100644 --- a/board/nvidia/dalmore/dalmore.c +++ b/board/nvidia/dalmore/dalmore.c @@ -18,6 +18,10 @@ #include <asm/arch/pinmux.h> #include <asm/arch/gp_padctrl.h> #include "pinmux-config-dalmore.h" +#include <i2c.h> + +#define BAT_I2C_ADDRESS 0x48 /* TPS65090 charger */ +#define PMU_I2C_ADDRESS 0x58 /* TPS65913 PMU */
/* * Routine: pinmux_init @@ -37,3 +41,61 @@ void pinmux_init(void) /* Initialize any non-default pad configs (APB_MISC_GP regs) */ padgrp_config_table(dalmore_padctrl, ARRAY_SIZE(dalmore_padctrl)); } + +#if defined(CONFIG_TEGRA_MMC) +/* + * Do I2C/PMU writes to bring up SD card bus power + * + */ +void board_sdmmc_voltage_init(void) +{ + uchar reg, data_buffer[1]; + int ret; + + ret = i2c_set_bus_num(0);/* PMU is on bus 0 */ + if (ret) + printf("%s: i2c_set_bus_num returned %d\n", __func__, ret); + + /* TPS65913: LDO9_VOLTAGE = 3.3V */ + data_buffer[0] = 0x31; + reg = 0x61; + + ret = i2c_write(PMU_I2C_ADDRESS, reg, 1, data_buffer, 1); + if (ret) + printf("%s: PMU i2c_write %02X<-%02X returned %d\n", + __func__, reg, data_buffer[0], ret); + + /* TPS65913: LDO9_CTRL = Active */ + data_buffer[0] = 0x01; + reg = 0x60; + + ret = i2c_write(PMU_I2C_ADDRESS, reg, 1, data_buffer, 1); + if (ret) + printf("%s: PMU i2c_write %02X<-%02X returned %d\n", + __func__, reg, data_buffer[0], ret); + + /* TPS65090: FET6_CTRL = enable output auto discharge, enable FET6 */ + data_buffer[0] = 0x03; + reg = 0x14; + + ret = i2c_write(BAT_I2C_ADDRESS, reg, 1, data_buffer, 1); + if (ret) + printf("%s: BAT i2c_write %02X<-%02X returned %d\n", + __func__, reg, data_buffer[0], ret); +} + +/* + * Routine: pin_mux_mmc + * Description: setup the MMC muxes, power rails, etc. + */ +void pin_mux_mmc(void) +{ + /* + * NOTE: We don't do mmc-specific pin muxes here. + * They were done globally in pinmux_init(). + */ + + /* Bring up the SDIO3 power rail */ + board_sdmmc_voltage_init(); +} +#endif /* MMC */
Tested on my Dalmore E1611 board, eMMC and SD-Card work fine, can load a kernel off of an SD card OK, card detect works, and the env is now stored in eMMC (end of the 2nd 'boot' sector, same as Tegra20/30).
Signed-off-by: Tom Warren twarren@nvidia.com Reviewed-by: Stephen Warren swarren@nvidia.com --- v2: Change CONFIG_ENV_OFFSET to match the size of Dalmore's eMMC chip
include/configs/dalmore.h | 12 +++++++++++- 1 file changed, 11 insertions(+), 1 deletion(-)
diff --git a/include/configs/dalmore.h b/include/configs/dalmore.h index c7deea5..3f4b70e 100644 --- a/include/configs/dalmore.h +++ b/include/configs/dalmore.h @@ -50,7 +50,17 @@ #define CONFIG_SYS_I2C_SPEED 100000 #define CONFIG_CMD_I2C
-#define CONFIG_ENV_IS_NOWHERE +/* SD/MMC */ +#define CONFIG_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_TEGRA_MMC +#define CONFIG_CMD_MMC + +/* Environment in eMMC, at the end of 2nd "boot sector" */ +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_SYS_MMC_ENV_DEV 0 +#define CONFIG_SYS_MMC_ENV_PART 2 +#define CONFIG_ENV_OFFSET (((4096 - 512) * 1024) - CONFIG_ENV_SIZE)
#define MACH_TYPE_DALMORE 4304 /* not yet in mach-types.h */
Sorry, I don't know what I was thinking when I wrote that expression in response to the last time you posted this patch. I think it should be simply:
#define CONFIG_ENV_OFFSET ((4096 * 1024) - CONFIG_ENV_SIZE)
Feel free to fix this up when applying; no need to repost.
Stephen Warren
Tom Warren
