[PATCH v2] arm: dts: imx8mp: Generate single bootable binary
binman conversion made flashing flash.bin and u-boot.itb necessary. Update binman config to create a single flash.bin image again.
This updates imx8mp_evk and phyCORE-i.MX8MP as they share the same binman config.
Updated also imx8mp_evk documentation.
Tested on phyCORE-i.MX8MP.
Signed-off-by: Teresa Remmet t.remmet@phytec.de Reviewed-by: Fabio Estevam festevam@gmail.com Reviewed-by: Heiko Schocher hs@denx.de --- Changes in v2: - Added filename to spl node - Use u-boot-spl-ddr.bin in the LOADER section
arch/arm/dts/imx8mp-u-boot.dtsi | 19 ++++++++++++++++++- .../imx8mp_evk/imximage-8mp-lpddr4.cfg | 2 +- .../phytec/phycore_imx8mp/imximage-8mp-sd.cfg | 2 +- doc/board/nxp/imx8mp_evk.rst | 1 - 4 files changed, 20 insertions(+), 4 deletions(-)
diff --git a/arch/arm/dts/imx8mp-u-boot.dtsi b/arch/arm/dts/imx8mp-u-boot.dtsi index a6ede2ed6e30..120c4c4dbb13 100644 --- a/arch/arm/dts/imx8mp-u-boot.dtsi +++ b/arch/arm/dts/imx8mp-u-boot.dtsi @@ -82,7 +82,9 @@ }; };
- flash { + spl { + filename = "spl.bin"; + mkimage { args = "-n spl/u-boot-spl.cfgout -T imx8mimage -e 0x920000";
@@ -149,4 +151,19 @@ }; }; }; + + imx-boot { + filename = "flash.bin"; + pad-byte = <0x00>; + + spl: blob-ext@1 { + filename = "spl.bin"; + offset = <0x0>; + }; + + uboot: blob-ext@2 { + filename = "u-boot.itb"; + offset = <0x58000>; + }; + }; }; diff --git a/board/freescale/imx8mp_evk/imximage-8mp-lpddr4.cfg b/board/freescale/imx8mp_evk/imximage-8mp-lpddr4.cfg index b2920b4908ed..4c3ecf5a71ad 100644 --- a/board/freescale/imx8mp_evk/imximage-8mp-lpddr4.cfg +++ b/board/freescale/imx8mp_evk/imximage-8mp-lpddr4.cfg @@ -7,4 +7,4 @@
ROM_VERSION v2 BOOT_FROM sd -LOADER mkimage.flash.mkimage 0x920000 +LOADER u-boot-spl-ddr.bin 0x920000 diff --git a/board/phytec/phycore_imx8mp/imximage-8mp-sd.cfg b/board/phytec/phycore_imx8mp/imximage-8mp-sd.cfg index b2920b4908ed..4c3ecf5a71ad 100644 --- a/board/phytec/phycore_imx8mp/imximage-8mp-sd.cfg +++ b/board/phytec/phycore_imx8mp/imximage-8mp-sd.cfg @@ -7,4 +7,4 @@
ROM_VERSION v2 BOOT_FROM sd -LOADER mkimage.flash.mkimage 0x920000 +LOADER u-boot-spl-ddr.bin 0x920000 diff --git a/doc/board/nxp/imx8mp_evk.rst b/doc/board/nxp/imx8mp_evk.rst index 609a29f3ebc3..b996ae055e69 100644 --- a/doc/board/nxp/imx8mp_evk.rst +++ b/doc/board/nxp/imx8mp_evk.rst @@ -52,7 +52,6 @@ Burn the flash.bin to the MicroSD card at offset 32KB: .. code-block:: bash
$sudo dd if=build/flash.bin of=/dev/sd[x] bs=1K seek=32 conv=notrunc; sync - $sudo dd if=build/u-boot.itb of=/dev/sd[x] bs=1K seek=384 conv=notrunc; sync
Boot ----
binman conversion made flashing flash.bin and u-boot.itb necessary. Update binman config to create a single flash.bin image again. This updates imx8mp_evk and phyCORE-i.MX8MP as they share the same binman config. Updated also imx8mp_evk documentation. Tested on phyCORE-i.MX8MP. Signed-off-by: Teresa Remmet t.remmet@phytec.de Reviewed-by: Fabio Estevam festevam@gmail.com Reviewed-by: Heiko Schocher hs@denx.de
Best regards, Stefano Babic
sbabic@denx.de
Teresa Remmet
