[U-Boot] [PATCH] nand: omap_gpmc: Change correctable bit-flips messages to debug()
Messages on corrected bit-flips are not really useful, as bit-flips are perfectly normal. Let's avoid cluttering the console and make them debug.
Signed-off-by: Ezequiel Garcia ezequiel@vanguardiasur.com.ar --- drivers/mtd/nand/omap_gpmc.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/mtd/nand/omap_gpmc.c b/drivers/mtd/nand/omap_gpmc.c index 4372988ed2ab..4814fa202a65 100644 --- a/drivers/mtd/nand/omap_gpmc.c +++ b/drivers/mtd/nand/omap_gpmc.c @@ -558,10 +558,10 @@ static int omap_correct_data_bch(struct mtd_info *mtd, uint8_t *dat, bit_pos = error_loc[count] % 8; if (byte_pos < SECTOR_BYTES) { dat[byte_pos] ^= 1 << bit_pos; - printf("nand: bit-flip corrected @data=%d\n", byte_pos); + debug("nand: bit-flip corrected @data=%d\n", byte_pos); } else if (byte_pos < error_max) { read_ecc[byte_pos - SECTOR_BYTES] ^= 1 << bit_pos; - printf("nand: bit-flip corrected @oob=%d\n", byte_pos - + debug("nand: bit-flip corrected @oob=%d\n", byte_pos - SECTOR_BYTES); } else { err = -EBADMSG; @@ -663,7 +663,7 @@ static int omap_correct_data_bch_sw(struct mtd_info *mtd, u_char *data, /* correct data only, not ecc bytes */ if (errloc[i] < 8*512) data[errloc[i]/8] ^= 1 << (errloc[i] & 7); - printf("corrected bitflip %u\n", errloc[i]); + debug("corrected bitflip %u\n", errloc[i]); #ifdef DEBUG puts("read_ecc: "); /*
Ezequiel Garcia
