[PATCH] board: ls1046ardb: force PCI device enumeration
Commit 045ecf899252 ("configs: enable DM_ETH support for LS1046ARDB") resulted in the PCI bus no longer being implicitly enumerated.
However, this is necessary for the fdt pcie fixups to work.
Therefore, similar to commit 8b6558bd4187 ("board: ls1088ardb: transition to DM_ETH"), pci_init() is now called in the board_init() routine when CONFIG_DM_ETH is active.
Signed-off-by: Martin Schiller ms@dev.tdt.de CC: Priyanka Jain priyanka.jain@nxp.com --- board/freescale/ls1046ardb/ls1046ardb.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/board/freescale/ls1046ardb/ls1046ardb.c b/board/freescale/ls1046ardb/ls1046ardb.c index 93ef903f29..d0abfe8869 100644 --- a/board/freescale/ls1046ardb/ls1046ardb.c +++ b/board/freescale/ls1046ardb/ls1046ardb.c @@ -93,6 +93,10 @@ int board_init(void) ppa_init(); #endif
+#if !defined(CONFIG_SYS_EARLY_PCI_INIT) && defined(CONFIG_DM_ETH) + pci_init(); +#endif + /* invert AQR105 IRQ pins polarity */ out_be32(&scfg->intpcr, AQR105_IRQ_MASK);
Martin Schiller
