[U-Boot-Users] Coldfire 5272C3 Ethernet Support?
Is ethernet support currently working for the Coldfire 5272C3 eval board off the git repository? Whenever I'm trying to transmit (ping, etc) I'm getting a "TX timeout" and no packets are making it to the wire. From what I can tell my receives aren't going much better.
Going back through the archives I found a post from March that seemed to bring up the same issue but with no visible resolution. If the tip is broken does anyone know what the last version that was functional on the 5272C3 was?
Thanks,
Andrew Beard
This email and any attachments are only for use by the intended recipient(s) and may contain legally privileged, confidential, proprietary or otherwise private information. Any unauthorized use, reproduction, dissemination, distribution or other disclosure of the contents of this e-mail or its attachments is strictly prohibited. If you have received this email in error, please notify the sender immediately and delete the original.
Andrew,
Thanks for pointing out the problem. The Ethernet unable to transmit and causes "TX timeout" is due to timer function (udelay) is not working properly and used an incorrect timer memory mapped. Please append defined(CONFIG_M5272) after CONFIG_M5253 in <u-boot>/include/asm-m68k/timer.h. I will provide the patch sometimes next week.
Regards, TsiChung
________________________________
From: u-boot-users-bounces@lists.sourceforge.net [mailto:u-boot-users-bounces@lists.sourceforge.net] On Behalf Of abeard@Wabtec.com Sent: Monday, June 16, 2008 4:37 PM To: u-boot-users@lists.sourceforge.net Subject: [U-Boot-Users] Coldfire 5272C3 Ethernet Support?
Thanks,
Andrew Beard
abeard@Wabtec.com
Liew Tsi Chung
