[U-Boot-Users] [PATCH] fix BRCM570x related bugs
This fixes numerous bugs in the u-boot bcm570x driver implementation. The way the driver exists in u-boot before this fix, it allows to ping a host o few times, but could never complete a tftp transfer of a kernel image.
The main substance of the fixes is: - make sure that receive buffer descriptors always have buffers associated with them - don't use shared memory structure to assess the chip state (race conditions were causing lost indications and timeouts). Use the chip's registers and queues' contents to determine if the packet has been sent/received - initialize the phy as early as possible and keep it up even if the interface is halted
testing included numerous file transfers - no transfer timeouts were exibited. Befoire the fix no one transfer would complete, the system would get stuck after transferring part of the file with numerous timeouts along the way.
The MAKEALL is still running, so far so good.
Signed-off-by: vbendeb@google.com ==================================================
diff --git a/drivers/bcm570x.c b/drivers/bcm570x.c index 5f632a6..7e283ee 100644 --- a/drivers/bcm570x.c +++ b/drivers/bcm570x.c @@ -6,8 +6,7 @@
#include <common.h>
-#if (CONFIG_COMMANDS & CFG_CMD_NET) && (!defined(CONFIG_NET_MULTI)) && \ - defined(CONFIG_BCM570x) +#if (CONFIG_COMMANDS & CFG_CMD_NET) && defined(CONFIG_BCM570x)
#ifdef CONFIG_BMW #include <mpc824x.h> @@ -28,7 +27,6 @@ /* * PCI memory base for Ethernet device as well as device Interrupt. */ -#define BCM570X_MBAR 0x80100000 #define BCM570X_ILINE 1
@@ -36,6 +34,15 @@ #define MAX_PACKET_SIZE 1600 #define MAX_UNITS 4
+/* by default this driver uses the first interface's MAC address, + * if this needs to be changed, the platform specific config file + * should define BCM570X_MAC_ADDR_SRC as the appropriate field of the + * board descriptor structure (struct bd_info) + */ +#ifndef BCM570X_MAC_ADDR_SRC +#define BCM570X_MAC_ADDR_SRC bi_enetaddr +#endif + /* Globals to this module */ int initialized = 0; unsigned int ioBase = 0; @@ -116,6 +123,7 @@ typedef enum { BCM5702, BCM5703, BCM5703A31, + BCM5704, TC996T, TC996ST, TC996SSX, @@ -152,6 +160,7 @@ static struct { {"BCM5702"}, {"BCM5703"}, {"BCM5703A31"}, + {"BCM5704"}, {"TC996T"}, {"TC996ST"}, {"TC996SSX"}, @@ -190,6 +199,7 @@ static struct { { "Broadcom BCM5702 1000Base-T" }, { "Broadcom BCM5703 1000Base-T" }, { "Broadcom BCM5703 1000Base-SX" }, + { "Broadcom BCM5704 1000Base-T" }, { "3Com 3C996 10/100/1000 Server NIC" }, { "3Com 3C996 10/100/1000 Server NIC" }, { "3Com 3C996 Gigabit Fiber-SX Server NIC" }, @@ -249,6 +259,7 @@ struct pci_device_table { {0x14e4, 0x1646, 0x14e4, 0x8009, 0, 0, BCM5702 ,128,32}, {0x14e4, 0x1646, 0x0e11, 0xbb, 0, 0, NC7760 ,128,32}, {0x14e4, 0x1646, PCI_ANY_ID, PCI_ANY_ID, 0, 0, BCM5702 ,128,32}, + {0x14e4, 0x1648, PCI_ANY_ID, PCI_ANY_ID, 0, 0, BCM5704 ,128,32}, {0x14e4, 0x16a6, 0x14e4, 0x8009, 0, 0, BCM5702 ,128,32}, {0x14e4, 0x16a6, 0x0e11, 0xbb, 0, 0, NC7760 ,128,32}, {0x14e4, 0x16a6, PCI_ANY_ID, PCI_ANY_ID, 0, 0, BCM5702 ,128,32}, @@ -333,7 +344,8 @@ bcm570xReplenishRxBuffers(PUM_DEVICE_BLOCK pUmDevice) /* * Probe, Map, and Init 570x device. */ -int eth_init(bd_t *bis) +int +bcm570x_eth_init(bd_t *bis) { int i, rv, devFound = FALSE; pci_dev_t devbusfn; @@ -358,10 +370,11 @@ int eth_init(bd_t *bis) pci_write_config_dword(devbusfn, PCI_BASE_ADDRESS_1, 0);
- ioBase = BCM570X_MBAR; - - pci_write_config_dword(devbusfn, - PCI_BASE_ADDRESS_0, ioBase); + /* read the autoconfigured BAR value (don't forget to mask the + * four LSBs which carry extra information + */ + pci_read_config_dword(devbusfn, PCI_BASE_ADDRESS_0, &ioBase); + ioBase &= ~0xf;
/* * Enable PCI memory, IO, and Master -- don't @@ -392,8 +405,6 @@ int eth_init(bd_t *bis) /* Configure pci dev structure */ pUmDevice->pdev = devbusfn; pUmDevice->index = 0; - pUmDevice->tx_pkt = 0; - pUmDevice->rx_pkt = 0; devFound = TRUE; break; } @@ -457,8 +468,8 @@ int eth_init(bd_t *bis) (char*)malloc(strlen(board_info[bcm570xDevices[i].board_id].name)+1); strcpy(pUmDevice->name,board_info[bcm570xDevices[i].board_id].name);
- memcpy(pDevice->NodeAddress, bis->bi_enetaddr, 6); - LM_SetMacAddress(pDevice, bis->bi_enetaddr); + memcpy(pDevice->NodeAddress, bis->BCM570X_MAC_ADDR_SRC, 6); + LM_SetMacAddress(pDevice, bis->BCM570X_MAC_ADDR_SRC); /* Init queues .. */ QQ_InitQueue(&pUmDevice->rx_out_of_buf_q.Container, MAX_RX_PACKET_DESC_COUNT); @@ -495,8 +506,6 @@ int eth_init(bd_t *bis)
pUmDevice->opened = 1; pUmDevice->tx_full = 0; - pUmDevice->tx_pkt = 0; - pUmDevice->rx_pkt = 0; printf("eth%d: %s @0x%lx,", pDevice->index, pUmDevice->name, (unsigned long)ioBase); printf( "node addr "); @@ -519,14 +528,22 @@ int eth_init(bd_t *bis) printf("Broadcom BCM5701 Integrated Copper "); else if ((pDevice->PhyId & PHY_ID_MASK) == PHY_BCM5703_PHY_ID) printf("Broadcom BCM5703 Integrated Copper "); + else if ((pDevice->PhyId & PHY_ID_MASK) == PHY_BCM5704_PHY_ID) + printf("Broadcom BCM5704 Integrated Copper "); else if ((pDevice->PhyId & PHY_ID_MASK) == PHY_BCM8002_PHY_ID) printf("Broadcom BCM8002 SerDes "); else if (pDevice->EnableTbi) printf("Agilent HDMP-1636 SerDes "); else - printf("Unknown "); + printf("Unknown (ID:%x)", pDevice->PhyId & PHY_ID_MASK); printf("transceiver found\n");
+ /* start up the phy right away, reusing i as a scratch variable */ + LM_ReadPhy(pDevice, PHY_CTRL_REG, (unsigned*) &i); + if (i & PHY_CTRL_LOWER_POWER_MODE) { + LM_WritePhy (pDevice, PHY_CTRL_REG, i & ~PHY_CTRL_LOWER_POWER_MODE); + } + printf("eth%d: %s, MTU: %d,", pDevice->index, pDevice->BusSpeedStr, 1500);
@@ -605,39 +622,27 @@ eth_isr(void) }
pUmDevice->interrupt = 0; - }
int -eth_send(volatile void *packet, int length) +bcm570x_eth_send(volatile void *packet, int length) { - int status = 0; + int start_time, status = 0; #if ET_DEBUG unsigned char* ptr = (unsigned char*)packet; #endif PLM_PACKET pPacket; PUM_PACKET pUmPacket;
- /* Link down, return */ - while(pDevice->LinkStatus == LM_STATUS_LINK_DOWN) { -#if 0 - printf("eth%d: link down - check cable or link partner.\n", - pUmDevice->index); -#endif - eth_isr(); - - /* Wait to see link for one-half a second before sending ... */ - udelay(1500000); - - } - - /* Clear sent flag */ - pUmDevice->tx_pkt = 0; - /* Previously blocked */ if(pUmDevice->tx_full){ printf("eth%d: tx blocked.\n", pUmDevice->index); - return 0; + return 1; + } + + if (length <= 0){ + printf("eth: bad packet size: %d\n", length); + return 2; }
pPacket = (PLM_PACKET) @@ -646,19 +651,14 @@ eth_send(volatile void *packet, int length) if (pPacket == 0) { pUmDevice->tx_full = 1; printf("bcm570xEndSend: TX full!\n"); - return 0; + return 3; }
if (pDevice->SendBdLeft.counter == 0) { pUmDevice->tx_full = 1; printf("bcm570xEndSend: no more TX descriptors!\n"); QQ_PushHead(&pDevice->TxPacketFreeQ.Container, pPacket); - return 0; - } - - if (length <= 0){ - printf("eth: bad packet size: %d\n", length); - goto out; + return 4; }
/* Get packet buffers and fragment list */ @@ -671,18 +671,22 @@ eth_send(volatile void *packet, int length) if (pUmPacket->skbuff == NULL){ /* Packet was discarded */ printf("TX: failed (1)\n"); - status = 1; + status = 5; } else{ printf("TX: failed (2)\n"); - status = 2; + status = 6; } QQ_PushHead (&pDevice->TxPacketFreeQ.Container, pPacket); return status; }
/* Copy packet to DMA buffer */ - memset(pUmPacket->skbuff, 0x0, MAX_PACKET_SIZE); + if (length < MIN_ENET_FRAME_SIZE) { + length = MIN_ENET_FRAME_SIZE; + } + memcpy((void*)pUmPacket->skbuff, (void*)packet, length); + pPacket->PacketSize = length; pPacket->Flags |= SND_BD_FLAG_END|SND_BD_FLAG_COAL_NOW; pPacket->u.Tx.FragCount = 1; @@ -697,21 +701,30 @@ eth_send(volatile void *packet, int length) if (pUmPacket->skbuff == NULL){ printf("TX failed (1)!\n"); /* Packet was discarded */ - status = 3; + status = 7; } else { /* A resource problem ... */ printf("TX failed (2)!\n"); - status = 4; + status = 8; }
if (QQ_GetEntryCnt(&pDevice->TxPacketFreeQ.Container) == 0) { printf("TX: emptyQ!\n"); + status = 5; pUmDevice->tx_full = 1; } + + return status; }
- while(pUmDevice->tx_pkt == 0){ - /* Service TX */ + start_time = get_timer(0); + while(!QQ_Empty(&pDevice->TxPacketActiveQ.Container)){ + if (get_timer(start_time) > (CFG_HZ/10)) { + printf("TX: timeout!\n"); + return 9; + } + + /* get tx Serviced */ eth_isr(); } #if ET_DEBUG @@ -722,87 +735,62 @@ eth_send(volatile void *packet, int length) ptr[6],ptr[7],ptr[8],ptr[9],ptr[10],ptr[11],ptr[12], ptr[13],ptr[14],ptr[15]); #endif - pUmDevice->tx_pkt = 0; - QQ_PushHead(&pDevice->TxPacketFreeQ.Container, pPacket); - /* Done with send */ - out: - return status; + return 0; }
-/* Ethernet receive */ -int -eth_rx(void) +void +bcm570x_eth_rx(void) { - PLM_PACKET pPacket = NULL; - PUM_PACKET pUmPacket = NULL; - void *skb; - int size=0; + int size=0;
- while(TRUE) { - - bcm570x_service_isr: - /* Pull down packet if it is there */ + /* Pull down packets if any */ eth_isr();
- /* Indicate RX packets called */ - if(pUmDevice->rx_pkt){ - /* printf("eth_rx: got a packet...\n"); */ - pUmDevice->rx_pkt = 0; - } else { - /* printf("eth_rx: waiting for packet...\n"); */ - goto bcm570x_service_isr; - } + while(QQ_GetEntryCnt(&pDevice->RxPacketReceivedQ.Container)) { + PLM_PACKET pPacket; + PUM_PACKET pUmPacket;
- pPacket = (PLM_PACKET) - QQ_PopHead(&pDevice->RxPacketReceivedQ.Container); + pPacket = (PLM_PACKET) + QQ_PopHead(&pDevice->RxPacketReceivedQ.Container);
- if (pPacket == 0){ - printf("eth_rx: empty packet!\n"); - goto bcm570x_service_isr; - } + if (pPacket == 0){ + printf("eth_rx: empty packet!\n"); + continue; + }
- pUmPacket = (PUM_PACKET) pPacket; + pUmPacket = (PUM_PACKET) pPacket; #if ET_DEBUG - printf("eth_rx: packet @0x%x\n", - (int)pPacket); + printf("eth_rx: packet @0x%x\n", + (int)pPacket); #endif - /* If the packet generated an error, reuse buffer */ - if ((pPacket->PacketStatus != LM_STATUS_SUCCESS) || - ((size = pPacket->PacketSize) > pDevice->RxMtu)) { - - /* reuse skb */ - QQ_PushTail(&pDevice->RxPacketFreeQ.Container, pPacket); - printf("eth_rx: error in packet dma!\n"); - goto bcm570x_service_isr; - } - - /* Set size and address */ - skb = pUmPacket->skbuff; - size = pPacket->PacketSize; - - /* Pass the packet up to the protocol - * layers. - */ - NetReceive(skb, size); + /* If the packet generated an error, reuse buffer */ + if ((pPacket->PacketStatus != LM_STATUS_SUCCESS) || + ((size = pPacket->PacketSize) > pDevice->RxMtu)) { + printf("eth_rx: error in packet dma!\n"); + } else { + void *skb;
- /* Free packet buffer */ - bcm570xPktFree (pUmDevice->index, skb); - pUmPacket->skbuff = NULL; + /* Set size and address */ + skb = pUmPacket->skbuff; + size = pPacket->PacketSize;
- /* Reuse SKB */ - QQ_PushTail(&pDevice->RxPacketFreeQ.Container, pPacket); + /* Pass the packet up to the protocol + * layers. + */ + NetReceive(skb, size); + }
- return 0; /* Got a packet, bail ... */ - } - return size; + /* Reuse SKB */ + QQ_PushTail(&pDevice->RxPacketFreeQ.Container, pPacket); + } }
/* Shut down device */ void -eth_halt(void) +bcm570x_eth_halt(void) { int i; if ( initialized) @@ -1130,7 +1118,6 @@ MM_GetConfig(PLM_DEVICE_BLOCK pDevice) pDevice->WakeUpModeCap = LM_WAKE_UP_MODE_MAGIC_PACKET; pDevice->WakeUpMode = LM_WAKE_UP_MODE_MAGIC_PACKET; } - pDevice->NicSendBd = TRUE;
/* Don't update status blocks during interrupt */ pDevice->RxCoalescingTicksDuringInt = 0; @@ -1264,16 +1251,6 @@ MM_CoalesceTxBuffer(PLM_DEVICE_BLOCK pDevice, PLM_PACKET pPacket) PUM_PACKET pUmPacket = (PUM_PACKET) pPacket; PUM_DEVICE_BLOCK pUmDevice = (PUM_DEVICE_BLOCK) pDevice; void *skbnew; - int len = 0; - - if (len == 0) - return (LM_STATUS_SUCCESS); - - if (len > MAX_PACKET_SIZE){ - printf ("eth%d: xmit frame discarded, too big!, size = %d\n", - pUmDevice->index, len); - return (LM_STATUS_FAILURE); - }
skbnew = bcm570xPktAlloc(pUmDevice->index, MAX_PACKET_SIZE);
@@ -1290,15 +1267,6 @@ MM_CoalesceTxBuffer(PLM_DEVICE_BLOCK pDevice, PLM_PACKET pPacket) return (LM_STATUS_SUCCESS); }
- -LM_STATUS -MM_IndicateRxPackets(PLM_DEVICE_BLOCK pDevice) -{ - PUM_DEVICE_BLOCK pUmDevice = (PUM_DEVICE_BLOCK) pDevice; - pUmDevice->rx_pkt = 1; - return LM_STATUS_SUCCESS; -} - LM_STATUS MM_IndicateTxPackets(PLM_DEVICE_BLOCK pDevice) { @@ -1330,7 +1298,6 @@ MM_IndicateTxPackets(PLM_DEVICE_BLOCK pDevice)
pUmPacket->skbuff = 0; QQ_PushTail(&pDevice->TxPacketFreeQ.Container, pPacket); - pUmDevice->tx_pkt = 1; } if (pUmDevice->tx_full) { if (QQ_GetEntryCnt(&pDevice->TxPacketFreeQ.Container) >= @@ -1688,4 +1655,230 @@ QQ_GetTail( return pQueue->Array[Idx]; }
-#endif /* CFG_CMD_NET, !CONFIG_NET_MULTI, CONFIG_BCM570x */ +#if defined ETHERNET_DEBUG + +static void bcm_5750x_dump_rcb(T3_RCB* rcb, const char* name) +{ + if (rcb->u.s.Flags & T3_RCB_FLAG_RING_DISABLED) { + return; + } + + printf("%s at %p\n", name, rcb->HostRingAddr.Low); +} + +void static bcm570x_dump_status_block(void) +{ + int ii; + T3_RCB rcb; + + printf("Status: 0x%x\n", pDevice->pStatusBlkVirt->Status); + + /* now, check out all three rx producer rings (host to MAC) */ +#define HANDLE_RCB(r, src) \ + r.HostRingAddr.Low = REG_RD(pDevice, RcvDataBdIn.src.HostRingAddr.Low); \ + r.HostRingAddr.High = REG_RD(pDevice, RcvDataBdIn.src.HostRingAddr.High);\ + r.u.MaxLen_Flags = REG_RD(pDevice, RcvDataBdIn.src.u.MaxLen_Flags); \ + bcm_5750x_dump_rcb(&r, #src) + + HANDLE_RCB(rcb, JumboRcvRcb); + HANDLE_RCB(rcb, StdRcvRcb); + HANDLE_RCB(rcb, MiniRcvRcb); + + printf ("Ring Send Consumer Rx producer\n"); + for (ii = 0; ii < 16; ii++) { + printf(" %2.2d %3.3d %3.3d\n", ii, + pDevice->pStatusBlkVirt->Idx[ii].SendConIdx, + pDevice->pStatusBlkVirt->Idx[ii].RcvProdIdx); + } +} + +static void bcm570x_check_status_block(void) +{ + unsigned value; + + memset(pDevice->pStatusBlkVirt, 0, sizeof(*pDevice->pStatusBlkVirt)); + if (pDevice->pStatusBlkVirt->Status) { + /* just in case...*/ + printf("status block not cleared!\n"); + return; + } + + value = REG_RD(pDevice, HostCoalesce.Mode); + REG_WR(pDevice, HostCoalesce.Mode, value | HOST_COALESCE_NOW); + + value = get_timer(0); + while (!pDevice->pStatusBlkVirt->Status) { + if (get_timer(value) > (CFG_HZ/10)) { + printf("%s:%d can't retrieve status!\n", + __FUNCTION__, __LINE__); + return; + } + } + + bcm570x_dump_status_block(); +} + +static void bcm570x_dump(void) +{ + int ii, producer, consumer, ring_size; + T3_RCV_BD* ring; + + producer = MB_REG_RD(pDevice, Mailbox.RcvStdProdIdx.Low); + consumer = pDevice->pStatusBlkVirt->RcvStdConIdx; + + printf("Device base = %p\n", pDevice->pMemView); + printf("UmDevice base = %p\n", pUmDevice); + printf("Rx Producer indx(sw) = %d\n", pDevice->RxStdProdIdx); + printf("Rx Producer indx(hw) = %d\n", producer); + printf("Tx producer indx(sw) = %d\n", pDevice->SendProdIdx); + printf("Rx Status block at = %p\n", pDevice->pStatusBlkVirt); + + bcm570x_dump_status_block(); + + ring = (T3_RCV_BD*) REG_RD(pDevice, + RcvDataBdIn.StdRcvRcb.HostRingAddr.Low); + ring_size = REG_RD(pDevice, RcvDataBdIn.StdRcvRcb.u.MaxLen_Flags)>>16; + + printf("rx buffer list (%d->%d):\n", consumer, producer); + ii = 0; + while (consumer != producer){ + T3_RCV_BD* bd; + bd = ring + consumer++; + if (!(ii++%4)) { + printf ("\n"); + } + printf("%8.8p:%8.8p:%3.3d:%4.4d ", bd, + bd->HostAddr.Low, bd->Index, bd->Len); + if (consumer == ring_size) { + consumer = 0; + } + } + printf ("\n"); +} + +#if defined(CONFIG_NET_MULTI) +static +#endif +void bcm570x_info(struct eth_device* p, int argc, char* argv[]) +{ + if (argc < 1) { + bcm570x_dump(); + return; + } + + if (MATCH(argv[0], "status")) { + bcm570x_check_status_block(); + return; + } +} + +#endif /* ETHERNET_DEBUG ^^^ defined */ + +#if defined(CONFIG_NET_MULTI) + +int bcm570x_init(struct eth_device *dev, bd_t * bd) +{ + if (initialized) { + LM_UINT32 Value32; + LM_ReadPhy(pDevice, PHY_CTRL_REG, &Value32); + + if (Value32 & PHY_CTRL_LOWER_POWER_MODE) { + /* if phy is down - bring it back up */ + LM_WritePhy (pDevice, PHY_CTRL_REG, + Value32 & ~PHY_CTRL_LOWER_POWER_MODE); + } + return 1; + } + return 0; +} + +void bcm570x_halt(struct eth_device *dev) +{ + /* let's do nothing here - why not to keep the interface up at all + * times? */ +} + +int +bcm570x_send(struct eth_device *dev, volatile void *packet, int length) +{ + if (initialized) { + return bcm570x_eth_send( packet, length ); + } + return -1; +} + +int bcm570x_recv( struct eth_device* p ) +{ + if (initialized) { + bcm570x_eth_rx(); + } + return 0; +} + +int bcm570x_initialize( bd_t * bis ) +{ + struct eth_device *dev; + + if (bcm570x_eth_init( bis )) { + printf( "%s:%d - init failed!\n", __FUNCTION__, __LINE__ ); + return -1; + } + + dev = (struct eth_device *)malloc(sizeof *dev); + if ( !dev ) { + printf( "%s:%d - dev allocation failed!\n", + __FUNCTION__, __LINE__ ); + return -1; + } + + memset (dev, 0, sizeof (*dev)); + memcpy (dev->enetaddr, bis->BCM570X_MAC_ADDR_SRC, + sizeof(dev->enetaddr)); + + memcpy(dev->name, pUmDevice->name, + min (strlen (pUmDevice->name), sizeof (dev->name))); + + dev->init = bcm570x_init; + dev->halt = bcm570x_halt; + dev->send = bcm570x_send; + dev->recv = bcm570x_recv; +#if defined ETHERNET_DEBUG + dev->info = bcm570x_info; +#endif + eth_register(dev); + + return 0; +} + +#else /* CONFIG_NET_MULTI ^^^ defined vvv NOT defined */ + +/* wrappers to comply with the non CONFIG_NET_MULTI mode */ + +int +eth_init( bd_t *bis ) +{ + return bcm570x_eth_init(bis); +} + +int +eth_send(volatile void *packet, int length) +{ + return eth_send(packet, length); +} + +int +eth_rx( void ) +{ + bcm570x_eth_rx(); + return 0; +} + +void +eth_halt(void) +{ + bcm570x_eth_halt(); +} + +#endif /* CONFIG_NET_MULTI ^^^ not defined */ + +#endif /* CFG_CMD_NET && CONFIG_BCM570x */ diff --git a/drivers/bcm570x_lm.h b/drivers/bcm570x_lm.h index 607f3fd..40d1946 100644 --- a/drivers/bcm570x_lm.h +++ b/drivers/bcm570x_lm.h @@ -425,7 +425,6 @@ LM_STATUS MM_WriteConfig32(PLM_DEVICE_BLOCK pDevice, LM_UINT32 Offset, LM_UINT32 Value32); LM_STATUS MM_MapMemBase(PLM_DEVICE_BLOCK pDevice); LM_STATUS MM_MapIoBase(PLM_DEVICE_BLOCK pDevice); -LM_STATUS MM_IndicateRxPackets(PLM_DEVICE_BLOCK pDevice); LM_STATUS MM_IndicateTxPackets(PLM_DEVICE_BLOCK pDevice); LM_STATUS MM_StartTxDma(PLM_DEVICE_BLOCK pDevice, PLM_PACKET pPacket); LM_STATUS MM_CompleteTxDma(PLM_DEVICE_BLOCK pDevice, PLM_PACKET pPacket); diff --git a/drivers/bcm570x_mm.h b/drivers/bcm570x_mm.h index b7cbf8a..88362dd 100644 --- a/drivers/bcm570x_mm.h +++ b/drivers/bcm570x_mm.h @@ -87,8 +87,6 @@ typedef struct _UM_DEVICE_BLOCK { volatile int interrupt; int tasklet_pending; int tasklet_busy; /* new -- unsupported */ - int rx_pkt; - int tx_pkt; #ifdef NICE_SUPPORT /* unsupported, this is a linux ioctl */ void (*nice_rx)(void*, void* ); void* nice_ctx; diff --git a/drivers/tigon3.c b/drivers/tigon3.c index ec2cd2a..5086592 100644 --- a/drivers/tigon3.c +++ b/drivers/tigon3.c @@ -12,8 +12,7 @@ /******************************************************************************/ #include <common.h> #include <asm/types.h> -#if (CONFIG_COMMANDS & CFG_CMD_NET) && !defined(CONFIG_NET_MULTI) && \ - defined(CONFIG_TIGON3) +#if (CONFIG_COMMANDS & CFG_CMD_NET) && defined(CONFIG_TIGON3) #ifdef CONFIG_BMW #include <mpc824x.h> #endif @@ -21,7 +20,6 @@ #include <linux/byteorder/big_endian.h> #include "bcm570x_mm.h"
-#define EMBEDDED 1 /******************************************************************************/ /* Local functions. */ /******************************************************************************/ @@ -1040,7 +1038,8 @@ PLM_DEVICE_BLOCK pDevice) pDevice->BondId != GRC_MISC_BD_ID_5703 && pDevice->BondId != GRC_MISC_BD_ID_5703S && pDevice->BondId != GRC_MISC_BD_ID_5704 && - pDevice->BondId != GRC_MISC_BD_ID_5704CIOBE) + pDevice->BondId != GRC_MISC_BD_ID_5704CIOBE && + pDevice->BondId != GRC_MISC_BD_ID_5704_A2) { return LM_STATUS_UNKNOWN_ADAPTER; } @@ -1652,15 +1651,14 @@ PLM_DEVICE_BLOCK pDevice) /* Set power state to D0. */ LM_SetPowerState(pDevice, LM_POWER_STATE_D0);
+#define QUEUE_INIT(x) QQ_InitQueue(&pDevice->x.Container, \ + ARRAY_SIZE(pDevice->x.EntryBuffer)) /* Intialize the queues. */ - QQ_InitQueue(&pDevice->RxPacketReceivedQ.Container, - MAX_RX_PACKET_DESC_COUNT); - QQ_InitQueue(&pDevice->RxPacketFreeQ.Container, - MAX_RX_PACKET_DESC_COUNT); - - QQ_InitQueue(&pDevice->TxPacketFreeQ.Container,MAX_TX_PACKET_DESC_COUNT); - QQ_InitQueue(&pDevice->TxPacketActiveQ.Container,MAX_TX_PACKET_DESC_COUNT); - QQ_InitQueue(&pDevice->TxPacketXmittedQ.Container,MAX_TX_PACKET_DESC_COUNT); + QUEUE_INIT(RxPacketReceivedQ); + QUEUE_INIT(RxPacketFreeQ); + QUEUE_INIT(TxPacketFreeQ); + QUEUE_INIT(TxPacketActiveQ); + QUEUE_INIT(TxPacketXmittedQ);
/* Allocate shared memory for: status block, the buffers for receive */ /* rings -- standard, mini, jumbo, and return rings. */ @@ -1780,13 +1778,17 @@ PLM_DEVICE_BLOCK pDevice) /* Allocate memory for packet descriptors. */ Size = (pDevice->RxPacketDescCnt + pDevice->TxPacketDescCnt) * MM_PACKET_DESC_SIZE; - Status = MM_AllocateMemory(pDevice, Size, (PLM_VOID *) &pPacket); + Status = MM_AllocateMemory(pDevice, Size, (PLM_VOID*)(void*)&pPacket); if(Status != LM_STATUS_SUCCESS) { return Status; } pDevice->pPacketDescBase = (PLM_VOID) pPacket;
+#if ET_DEBUG + printf("LM_Init_adapter: TX descriptors located at 0x%x\n", (void *)pPacket); +#endif + /* Create transmit packet descriptors from the memory block and add them */ /* to the TxPacketFreeQ for each send ring. */ for(j = 0; j < pDevice->TxPacketDescCnt; j++) @@ -1803,6 +1805,9 @@ PLM_DEVICE_BLOCK pDevice) pPacket = (PLM_PACKET) ((PLM_UINT8) pPacket + MM_PACKET_DESC_SIZE); } /* for(j.. */
+#if ET_DEBUG + printf("LM_Init_adapter: RX descriptors located at 0x%x\n", (void *)pPacket); +#endif /* Create receive packet descriptors from the memory block and add them */ /* to the RxPacketFreeQ. Create the Standard packet descriptors. */ for(j = 0; j < pDevice->RxStdDescCnt; j++) @@ -2822,7 +2827,14 @@ PLM_DEVICE_BLOCK pDevice) { if (pDevice->ChipRevId == T3_CHIP_ID_5704_A0) { - Value16 = REG_RD(pDevice, PciCfg.PciXCommand); + /* + * Patched to remove warnings; need A0 chip to test. + * If you can test this and find it wrong, please fix. + * Might need BYTE_SWAP_16_BIT() here and on store, + * but that logic is in disarray in this code. + */ + volatile u16 *p16 = &pDevice->pMemView->PciCfg.PciXCommand; + Value16 = *p16; Value16 &= ~(PCIX_CMD_MAX_SPLIT_MASK | PCIX_CMD_MAX_BURST_MASK); Value16 |= ((PCIX_CMD_MAX_BURST_CPIOB << PCIX_CMD_MAX_BURST_SHL) & PCIX_CMD_MAX_BURST_MASK); @@ -2831,7 +2843,7 @@ PLM_DEVICE_BLOCK pDevice) Value16 |= (pDevice->SplitModeMaxReq << PCIX_CMD_MAX_SPLIT_SHL) & PCIX_CMD_MAX_SPLIT_MASK; } - REG_WR(pDevice, PciCfg.PciXCommand, Value16); + *p16 = Value16; } }
@@ -3026,137 +3038,6 @@ LM_EnableInterrupt( /* Return: */ /* LM_STATUS_SUCCESS */ /******************************************************************************/ -#if 0 -LM_STATUS -LM_SendPacket(PLM_DEVICE_BLOCK pDevice, PLM_PACKET pPacket) -{ - LM_UINT32 FragCount; - PT3_SND_BD pSendBd; - PT3_SND_BD pShadowSendBd; - LM_UINT32 Value32, Len; - LM_UINT32 Idx; - - if (T3_ASIC_REV(pDevice->ChipRevId) == T3_ASIC_REV_5700) { - return LM_5700SendPacket(pDevice, pPacket); - } - - /* Update the SendBdLeft count. */ - atomic_sub(pPacket->u.Tx.FragCount, &pDevice->SendBdLeft); - - /* Initalize the send buffer descriptors. */ - Idx = pDevice->SendProdIdx; - - pSendBd = &pDevice->pSendBdVirt[Idx]; - - /* Next producer index. */ - if (pDevice->NicSendBd == TRUE) - { - T3_64BIT_HOST_ADDR paddr; - - pShadowSendBd = &pDevice->ShadowSendBd[Idx]; - for(FragCount = 0; ; ) - { - MM_MapTxDma(pDevice, pPacket, &paddr, &Len, FragCount); - /* Initialize the pointer to the send buffer fragment. */ - if (paddr.High != pShadowSendBd->HostAddr.High) - { - __raw_writel(paddr.High, &(pSendBd->HostAddr.High)); - pShadowSendBd->HostAddr.High = paddr.High; - } - __raw_writel(paddr.Low, &(pSendBd->HostAddr.Low)); - - /* Setup the control flags and send buffer size. */ - Value32 = (Len << 16) | pPacket->Flags; - - Idx = (Idx + 1) & T3_SEND_RCB_ENTRY_COUNT_MASK; - - FragCount++; - if (FragCount >= pPacket->u.Tx.FragCount) - { - Value32 |= SND_BD_FLAG_END; - if (Value32 != pShadowSendBd->u1.Len_Flags) - { - __raw_writel(Value32, &(pSendBd->u1.Len_Flags)); - pShadowSendBd->u1.Len_Flags = Value32; - } - if (pPacket->Flags & SND_BD_FLAG_VLAN_TAG) { - __raw_writel(pPacket->VlanTag, &(pSendBd->u2.VlanTag)); - } - break; - } - else - { - if (Value32 != pShadowSendBd->u1.Len_Flags) - { - __raw_writel(Value32, &(pSendBd->u1.Len_Flags)); - pShadowSendBd->u1.Len_Flags = Value32; - } - if (pPacket->Flags & SND_BD_FLAG_VLAN_TAG) { - __raw_writel(pPacket->VlanTag, &(pSendBd->u2.VlanTag)); - } - } - - pSendBd++; - pShadowSendBd++; - if (Idx == 0) - { - pSendBd = &pDevice->pSendBdVirt[0]; - pShadowSendBd = &pDevice->ShadowSendBd[0]; - } - } /* for */ - - /* Put the packet descriptor in the ActiveQ. */ - QQ_PushTail(&pDevice->TxPacketActiveQ.Container, pPacket); - - wmb(); - MB_REG_WR(pDevice, Mailbox.SendNicProdIdx[0].Low, Idx); - - } - else - { - for(FragCount = 0; ; ) - { - /* Initialize the pointer to the send buffer fragment. */ - MM_MapTxDma(pDevice, pPacket, &pSendBd->HostAddr, &Len, FragCount); - - pSendBd->u2.VlanTag = pPacket->VlanTag; - - /* Setup the control flags and send buffer size. */ - Value32 = (Len << 16) | pPacket->Flags; - - Idx = (Idx + 1) & T3_SEND_RCB_ENTRY_COUNT_MASK; - - FragCount++; - if (FragCount >= pPacket->u.Tx.FragCount) - { - pSendBd->u1.Len_Flags = Value32 | SND_BD_FLAG_END; - break; - } - else - { - pSendBd->u1.Len_Flags = Value32; - } - pSendBd++; - if (Idx == 0) - { - pSendBd = &pDevice->pSendBdVirt[0]; - } - } /* for */ - - /* Put the packet descriptor in the ActiveQ. */ - QQ_PushTail(&pDevice->TxPacketActiveQ.Container, pPacket); - - wmb(); - MB_REG_WR(pDevice, Mailbox.SendHostProdIdx[0].Low, Idx); - - } - - /* Update the producer index. */ - pDevice->SendProdIdx = Idx; - - return LM_STATUS_SUCCESS; -} -#endif
LM_STATUS LM_SendPacket(PLM_DEVICE_BLOCK pDevice, PLM_PACKET pPacket) @@ -3594,9 +3475,6 @@ PLM_DEVICE_BLOCK pDevice) { /* Indicate packets to the protocol. */ MM_IndicateTxPackets(pDevice); - - /* Indicate received packets to the protocols. */ - MM_IndicateRxPackets(pDevice); } else { @@ -4020,14 +3898,6 @@ LM_ServiceInterrupts( LM_ServiceTxInterrupt(pDevice);
/* No spinlock for this queue since this routine is serialized. */ - if(!QQ_Empty(&pDevice->RxPacketReceivedQ.Container)) - { - /* Indicate receive packets. */ - MM_IndicateRxPackets(pDevice); - /* LM_QueueRxPackets(pDevice); */ - } - - /* No spinlock for this queue since this routine is serialized. */ if(!QQ_Empty(&pDevice->TxPacketXmittedQ.Container)) { MM_IndicateTxPackets(pDevice); @@ -6197,4 +6067,4 @@ LM_DmaTest(PLM_DEVICE_BLOCK pDevice, PLM_UINT8 pBufferVirt, } return LM_STATUS_SUCCESS; } -#endif /* CFG_CMD_NET, !CONFIG_NET_MULTI, CONFIG_TIGON3 */ +#endif /* CFG_CMD_NET, CONFIG_TIGON3 */ diff --git a/drivers/tigon3.h b/drivers/tigon3.h index ea4367d..a2c690c 100644 --- a/drivers/tigon3.h +++ b/drivers/tigon3.h @@ -2403,6 +2403,7 @@ typedef struct { #define GRC_MISC_BD_ID_5702FE 0x00004000 #define GRC_MISC_BD_ID_5704 0x00000000 #define GRC_MISC_BD_ID_5704CIOBE 0x00004000 + #define GRC_MISC_BD_ID_5704_A2 0x00008000
/* Miscellaneous local control register. */ T3_32BIT_REGISTER LocalCtrl; diff --git a/include/common.h b/include/common.h index 3c4b37b..acbbcb2 100644 --- a/include/common.h +++ b/include/common.h @@ -634,4 +634,6 @@ void show_boot_progress (int status); #error Read section CONFIG_SKIP_LOWLEVEL_INIT in README. #endif
+#define ARRAY_SIZE(x) (sizeof(x) / sizeof((x)[0])) + #endif /* __COMMON_H_ */ diff --git a/include/net.h b/include/net.h index 461e038..e5ac66f 100644 --- a/include/net.h +++ b/include/net.h @@ -84,7 +84,8 @@ typedef void rxhand_f(uchar *, unsigned, unsigned, unsigned); */ typedef void thand_f(void);
-#define NAMESIZE 16 +/* some ETH interface names in bcm5704 driver are pretty long...*/ +#define ETH_NAMESIZE 50
enum eth_state_t { ETH_STATE_INIT, @@ -93,7 +94,7 @@ enum eth_state_t { };
struct eth_device { - char name[NAMESIZE]; + char name[ETH_NAMESIZE]; unsigned char enetaddr[6]; int iobase; int state; @@ -105,13 +106,27 @@ struct eth_device {
struct eth_device *next; void *priv; +#ifdef ETHERNET_DEBUG + void (*info) (struct eth_device*, int argc, char* argv[]); +#endif };
+#ifdef ETHERNET_DEBUG + +typedef void bypass_rx_f( volatile uchar*, int); + +extern void set_bypass_rx( bypass_rx_f f ); +extern void remove_bypass_rx( void ); + +#endif + extern int eth_initialize(bd_t *bis); /* Initialize network subsystem */ extern int eth_register(struct eth_device* dev);/* Register network device */ extern void eth_try_another(int first_restart); /* Change the device */ #ifdef CONFIG_NET_MULTI extern void eth_set_current(void); /* set nterface to ethcur var. */ + /* traverse the list of registered ethernet interfaces */ +extern char *eth_get_next_name (char* this_name); #endif extern struct eth_device *eth_get_dev(void); /* get the current device MAC */ extern struct eth_device *eth_get_dev_by_name(char *devname); /* get device */ @@ -458,4 +473,10 @@ extern void copy_filename (char *dst, char *src, int size);
+/* + * this definition should be used by all ethernet drivers + */ +#define MAC_ADDR_SIZE 6 +#define MIN_ENET_FRAME_SIZE 60 /* crcless */ + #endif /* __NET_H__ */
Dear Vadim,
in message 3b09bd800705231630m97ffa48hbaa1c71f3a5f002@mail.gmail.com you wrote:
Please read http://www.denx.de/wiki/UBoot/CodingStyle and fix your patch (and the driver).
Biggest problem: your patch does not apply at all:
-> patch -p1 --dry-run </tmp/0 patching file drivers/bcm570x.c Hunk #1 FAILED at 6. Hunk #2 FAILED at 27. Hunk #4 FAILED at 123. Hunk #6 FAILED at 199. Hunk #7 FAILED at 259. Hunk #9 FAILED at 370. Hunk #10 FAILED at 405. Hunk #11 succeeded at 468 with fuzz 1. Hunk #12 succeeded at 506 with fuzz 2. Hunk #13 FAILED at 528. Hunk #14 FAILED at 622. Hunk #15 FAILED at 651. Hunk #16 FAILED at 671. Hunk #17 FAILED at 701. Hunk #18 FAILED at 735. Hunk #19 succeeded at 1118 with fuzz 2. patch: **** malformed patch at line 518: PLM_PACKET pPacket)
Part of the problem is that your mailer corrupted the patch by folding long lines.
Then, there are many coding style violations in your patch: indentation not by TABs, indentation not yu a multiple of 8 columns, spaces missing after function names and after "if" and before "{", etc.
Also, I object in changing the NAMESIZE definition in include/net.h; if 16 characters are not enough for your interface names, you should shorten the names instead. Nobody wants to type such long names anyway.
Also, please break up your patch into orthogonal and independent patches - your changes to include/net.h have nothing to do with your driver fixes and must be submitted separately.
Wolfgang,
thank you for a quick reply. Sorry for not following the coding conventions, I'll address this concern, I am more worried why there are so many patch failures. What's the revision of the file you're applying the patch against and what is the exact patch command you're using?
cheers, /vb
On 5/23/07, Wolfgang Denk wd@denx.de wrote:
Dear Vadim,
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de Save energy: Drive a smaller shell.
This SF.net email is sponsored by DB2 Express Download DB2 Express C - the FREE version of DB2 express and take control of your XML. No limits. Just data. Click to get it now. http://sourceforge.net/powerbar/db2/ _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
Hi Vadim,
--- Vadim Bendebury vbendeb@yahoo.com wrote:
Wolfgang,
cheers, /vb
Here are the expectations:
1. Patch will apply against the current git head 2. The command used by custodians is
git am --signoff --whitespace=strip < PATCH_FILE
Notice that this strips offending whitespace. You should take care to not have any in the first place, though.
I suggest that before sending a patch, you clone the head and try this command. That way you can hopefully avoid *some* scorn from Wolfgang. Speaking of which... I'll try to preempt him and warn you about top-quoting. It's considered bad form.
Thanks for working on this and we look forward to your patches.
cheers, Ben
Ben and Wolfgang,
thank you for the hints.
One problem with following the coding standards is that if I apply the linux Lindent script, the entire file (drivers/bcm570x.c) gets changed - it does not follow the u-boot/Linux coding standards in the first place (I suspect other files being changed with my submission are like that too). I can make sure that the lines I changed are compliant but this would make the file(s) look ugly with a mix of styles, or I can run the entire file through Lindent, but then the diffs would be polluted.
What's the best way to proceed here?
Cheers, /v
On 5/24/07, Ben Warren bwarren@qstreams.com wrote:
Hi Vadim,
Wolfgang,
cheers, /vb
- Patch will apply against the current git head
- The command used by custodians is
cheers, Ben
Ben Warren
Vadim Bendebury
Vadim Bendebury
