[U-Boot] [PATCH 0/2] Generic firmware loader
This patchset contains generic firmware loader which is very close to Linux firmware loader but for U-Boot framework. Generic firmware loader can be used load whatever into target location, and then consumer driver would use it to program whatever, ie. the FPGA.
This series is working on top of u-boot-socfpga.git - http://git.denx.de/u-boot-socfpga.git .
Tien Fong Chee (2): arm: socfpga: Remove static declaration on spl_mmc_find_device function common: Generic firmware loader for file system
common/Makefile | 1 + common/fs_loader.c | 299 +++++++++++++++++++++++++++++++++++++++++++++++++++ common/spl/spl_mmc.c | 2 +- include/fs_loader.h | 30 ++++++ include/spl.h | 2 + 5 files changed, 333 insertions(+), 1 deletion(-) create mode 100644 common/fs_loader.c create mode 100644 include/fs_loader.h
This patch removes the static declation on spl_mmc_find_device_function so this function is accessible by the caller from other file. This patch is required for later patch.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com --- common/spl/spl_mmc.c | 2 +- include/spl.h | 2 ++ 2 files changed, 3 insertions(+), 1 deletion(-)
diff --git a/common/spl/spl_mmc.c b/common/spl/spl_mmc.c index b57e0b0..183d05a 100644 --- a/common/spl/spl_mmc.c +++ b/common/spl/spl_mmc.c @@ -114,7 +114,7 @@ static int spl_mmc_get_device_index(u32 boot_device) return -ENODEV; }
-static int spl_mmc_find_device(struct mmc **mmcp, u32 boot_device) +int spl_mmc_find_device(struct mmc **mmcp, u32 boot_device) { #if CONFIG_IS_ENABLED(DM_MMC) struct udevice *dev; diff --git a/include/spl.h b/include/spl.h index 308ce7b..912983a 100644 --- a/include/spl.h +++ b/include/spl.h @@ -10,6 +10,7 @@ /* Platform-specific defines */ #include <linux/compiler.h> #include <asm/spl.h> +#include <mmc.h>
/* Value in r0 indicates we booted from U-Boot */ #define UBOOT_NOT_LOADED_FROM_SPL 0x13578642 @@ -72,6 +73,7 @@ void preloader_console_init(void); u32 spl_boot_device(void); u32 spl_boot_mode(const u32 boot_device); void spl_set_bd(void); +int spl_mmc_find_device(struct mmc **mmcp, u32 boot_device);
/** * spl_set_header_raw_uboot() - Set up a standard SPL image structure
On 12/11/2017 11:53 AM, tien.fong.chee@intel.com wrote:
So the tags would imply this has a lot to do with SoCFPGA, but this is not touching any file in the SoCFPGA. The tags are thus completely bogus.
- spl_set_header_raw_uboot() - Set up a standard SPL image structure
Opps...sorry, i forgot to remove the socfpga tag. I would fix it.
diff --git a/common/spl/spl_mmc.c b/common/spl/spl_mmc.c index b57e0b0..183d05a 100644 --- a/common/spl/spl_mmc.c +++ b/common/spl/spl_mmc.c @@ -114,7 +114,7 @@ static int spl_mmc_get_device_index(u32 boot_device) return -ENODEV; } -static int spl_mmc_find_device(struct mmc **mmcp, u32 boot_device) +int spl_mmc_find_device(struct mmc **mmcp, u32 boot_device) { #if CONFIG_IS_ENABLED(DM_MMC) struct udevice *dev; diff --git a/include/spl.h b/include/spl.h index 308ce7b..912983a 100644 --- a/include/spl.h +++ b/include/spl.h @@ -10,6 +10,7 @@ /* Platform-specific defines */ #include <linux/compiler.h> #include <asm/spl.h> +#include <mmc.h> /* Value in r0 indicates we booted from U-Boot */ #define UBOOT_NOT_LOADED_FROM_SPL 0x13578642 @@ -72,6 +73,7 @@ void preloader_console_init(void); u32 spl_boot_device(void); u32 spl_boot_mode(const u32 boot_device); void spl_set_bd(void); +int spl_mmc_find_device(struct mmc **mmcp, u32 boot_device); /** * spl_set_header_raw_uboot() - Set up a standard SPL image structure
This is file system generic loader which can be used to load the file image from the storage into target such as memory. The consumer driver would then use this loader to program whatever, ie. the FPGA device.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com --- common/Makefile | 1 + common/fs_loader.c | 299 ++++++++++++++++++++++++++++++++++++++++++++++++++++ include/fs_loader.h | 30 ++++++ 3 files changed, 330 insertions(+) create mode 100644 common/fs_loader.c create mode 100644 include/fs_loader.h
diff --git a/common/Makefile b/common/Makefile index cec506f..2934221 100644 --- a/common/Makefile +++ b/common/Makefile @@ -130,3 +130,4 @@ obj-$(CONFIG_CMD_DFU) += dfu.o obj-y += command.o obj-y += s_record.o obj-y += xyzModem.o +obj-y += fs_loader.o diff --git a/common/fs_loader.c b/common/fs_loader.c new file mode 100644 index 0000000..269af25 --- /dev/null +++ b/common/fs_loader.c @@ -0,0 +1,299 @@ +/* + * Copyright (C) 2017 Intel Corporation <www.intel.com> + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <common.h> +#include <errno.h> +#include <fs.h> +#include <fs_loader.h> +#include <nand.h> +#include <sata.h> +#include <spi.h> +#include <spi_flash.h> +#include <spl.h> +#include <linux/string.h> +#include <usb.h> + +static struct device_location default_locations[] = { + { + .name = "mmc", + .devpart = "0:1", + }, + { + .name = "usb", + .devpart = "0:1", + }, + { + .name = "sata", + .devpart = "0:1", + }, +}; + +/* USB build is not supported yet in SPL */ +#ifndef CONFIG_SPL_BUILD +#ifdef CONFIG_USB_STORAGE +static int init_usb(void) +{ + int err; + + err = usb_init(); + if (err) + return err; + +#ifndef CONFIG_DM_USB + err = usb_stor_scan(1) < 0 ? -ENODEV : 0; +#endif + + return err; +} +#else +static int init_usb(void) +{ + printf("Error: Cannot load flash image: no USB support\n"); + return -ENOSYS; +} +#endif +#endif + +#ifdef CONFIG_SATA +static int init_storage_sata(void) +{ + return sata_probe(0); +} +#else +static int init_storage_sata(void) +{ + printf("Error: Cannot load image: no SATA support\n"); + return -ENOSYS; +} +#endif + +#ifdef CONFIG_CMD_UBIFS +static int mount_ubifs(struct device_location *location) +{ + int ret; + char cmd[32]; + + sprintf(cmd, "ubi part %s", location->mtdpart); + + ret = run_command(cmd, 0); + if (ret) + return ret; + + sprintf(cmd, "ubifsmount %s", location->ubivol); + + ret = run_command(cmd, 0); + + return ret; +} + +static int umount_ubifs(void) +{ + return run_command("ubifsumount", 0); +} +#else +static int mount_ubifs(struct device_location *location) +{ + printf("Error: Cannot load image: no UBIFS support\n"); + return -ENOSYS; +} +#endif + +#if defined(CONFIG_SPL_MMC_SUPPORT) && defined(CONFIG_SPL_BUILD) +static int init_mmc(void) +{ + /* Just for the case MMC is not yet initialized */ + struct mmc *mmc = NULL; + int err; + + spl_mmc_find_device(&mmc, spl_boot_device()); + + err = mmc_init(mmc); + if (err) { + printf("spl: mmc init failed with error: %d\n", err); + return err; + } + + return err; +} +#else +static int init_mmc(void) +{ + /* Expect somewhere already initialize MMC */ + return 0; +} +#endif + +static int select_fs_dev(struct device_location *location) +{ + int ret = 0; + + if (!strcmp("mmc", location->name)) { + ret = fs_set_blk_dev("mmc", location->devpart, FS_TYPE_ANY); + } + else if (!strcmp("usb", location->name)) { + ret = fs_set_blk_dev("usb", location->devpart, FS_TYPE_ANY); + } + else if (!strcmp("sata", location->name)) { + ret = fs_set_blk_dev("sata", location->devpart, FS_TYPE_ANY); + } + else if (!strcmp("ubi", location->name)) { + if (location->ubivol != NULL) + ret = fs_set_blk_dev("ubi", NULL, FS_TYPE_UBIFS); + else + ret = -ENODEV; + } + else { + printf("Error: unsupported location storage.\n"); + return -ENODEV; + } + + if (ret) + printf("Error: could not access storage.\n"); + + return ret; +} + +static int init_storage_device(struct device_location *location) +{ + int ret = 0; +#ifndef CONFIG_SPL_BUILD + /* USB build is not supported yet in SPL */ + if (!strcmp("usb", location->name)) + ret = init_usb(); +#endif + + if (!strcmp("mmc", location->name)) + ret = init_mmc(); + + if (!strcmp("sata", location->name)) + ret = init_storage_sata(); + + if (location->ubivol != NULL) + ret = mount_ubifs(location); + + return ret; +} + +static void set_storage_devpart(char *name, char *devpart) +{ + size_t i; + + for (i = 0; i < ARRAY_SIZE(default_locations); i++) { + if (!strcmp(default_locations[i].name, name)) + default_locations[i].devpart = devpart; + } + + return; +} + +/* + * Prepare firmware struct; + * return -ve if fail. + */ +static int _request_firmware_prepare(struct firmware **firmware_p, + const char *name, void *dbuf, + size_t size, u32 offset) +{ + struct firmware *firmware = NULL; + int ret = 0; + + *firmware_p = NULL; + + if (!name || name[0] == '\0') + ret = -EINVAL; + + *firmware_p = firmware = calloc(1, sizeof(*firmware)); + + if (!firmware) { + printf("%s: calloc(struct firmware) failed\n", __func__); + return -ENOMEM; + } + + firmware->name = name; + firmware->data = dbuf; + firmware->size = size; + firmware->offset = offset; + + return ret; +} + +/* + * fw_get_filesystem_firmware - load firmware into a allocated buffer + * @firmware_p: pointer to firmware image + * @location: An array of supported firmware location + * + * @return: size of total read + * -ve when error + */ +static int fw_get_filesystem_firmware(struct device_location *location, + struct firmware *firmware_p) +{ + loff_t actread; + char *dev_part; + int ret; + + dev_part = env_get("FW_DEV_PART"); + if (dev_part) + set_storage_devpart(location->name, dev_part); + + ret = init_storage_device(location); + if (ret) + goto out; + + select_fs_dev(location); + + ret = fs_read(firmware_p->name, (ulong)firmware_p->data, + firmware_p->offset, firmware_p->size, &actread); + + if (ret || (actread != firmware_p->size)) { + printf("Error: %d Failed to read %s from flash %lld ", + ret, + firmware_p->name, + actread); + printf("!= %d.\n", firmware_p->size); + return -EPERM; + } else { + ret = actread; + } + +out: +#ifdef CONFIG_CMD_UBIFS + if (location->ubivol != NULL) + umount_ubifs(); +#endif + + return ret; +} + +/* + * request_firmware_into_buf - load firmware into a previously allocated buffer + * @firmware_p: pointer to firmware image + * @name: name of firmware file + * @buf: address of buffer to load firmware into + * @size: size of buffer + * @offset: offset of a file for start reading + * + * This firmware is loaded directly into the buffer pointed to by @buf and + * the @firmware_p data member is pointed at @buf. + * + * @return: size of total read + * -ve when error + */ +int request_firmware_into_buf(struct firmware **firmware_p, + const char *name, + struct device_location *location, + void *buf, size_t size, u32 offset) +{ + int ret; + + ret = _request_firmware_prepare(firmware_p, name, buf, size, offset); + if (ret < 0) /* error */ + return ret; + + ret = fw_get_filesystem_firmware(location, *firmware_p); + + return ret; +} diff --git a/include/fs_loader.h b/include/fs_loader.h new file mode 100644 index 0000000..dacc1f3 --- /dev/null +++ b/include/fs_loader.h @@ -0,0 +1,30 @@ +/* + * Copyright (C) 2017 Intel Corporation <www.intel.com> + * + * SPDX-License-Identifier: GPL-2.0 + */ +#ifndef _FS_LOADER_H_ +#define _FS_LOADER_H_ + +#include <linux/types.h> + +struct firmware { + size_t size; /* Size of a file */ + const u8 *data; /* Buffer for file */ + const char *name; /* Filename */ + u32 offset; /* Offset of reading a file */ + void *priv; /* Firmware loader private fields */ +}; + +struct device_location { + char *name; /* Such as mmc, usb,and sata. */ + char *devpart; /* Use the load command dev:part conventions */ + char *mtdpart; /* MTD partition for ubi part */ + char *ubivol; /* UBI volume-name for ubifsmount */ +}; + +int request_firmware_into_buf(struct firmware **firmware_p, + const char *name, + struct device_location *location, + void *buf, size_t size, u32 offset); +#endif
On Mon, 11 Dec 2017 18:53:46 +0800 tien.fong.chee@intel.com wrote:
- Prepare firmware struct;
- return -ve if fail.
- struct firmware *firmware = NULL;
- int ret = 0;
- *firmware_p = NULL;
Sigh. This is useless...
- if (!name || name[0] == '\0')
ret = -EINVAL;
unless you do a 'return -EINVAL' here!
- *firmware_p = firmware = calloc(1, sizeof(*firmware));
- if (!firmware) {
return -ENOMEM;
- firmware->name = name;
- firmware->data = dbuf;
- firmware->size = size;
- firmware->offset = offset;
- return ret;
Lothar Waßmann
- int ret = 0;
ret = -EINVAL;
You are right, i missed to change this to return. I would fix it.
- if (!firmware) {
__func__);
return -ENOMEM;
- return ret;
Lothar Waßmann
Chee, Tien Fong
Lothar Waßmann
