[U-Boot] ppc405ep boot freeze with u-boot 1.3.4
Hi
I have a custom ppc405ep board with 128MB SDRAM, very similar to the AMCC Taihu board. U-Boot 1.1.4 works perfectly fine. But version 1.3.4 freezes after saying "Relocating now" in debug mode.
Additionally, I've observed a strange effect concerning memory size: When a BDI2000 emulator is connected and the SDRAM size is set to 64MB or less, the board starts to the prompt. When a BDI2000 emulator is connected and the SDRAM size is set to 128MB, it freezes as well.
Has somebody any ideas, where the problem could reside, or what else to do, to isolate the problem?
Every comment is welcome ;-), Reto
Hi Reto,
This is an indication of an SDRAM initialization problem.
What does this mean: "the SDRAM size is set to 64MB"? Who *set's* the SDRAM size? Does the board do an SDRAM size autodetection? Which SDRAM init code is used? You probably don't reset the SDRAM controller after running an SDRAM initialization from the BDI2000. How do you start via the BDI2000? With "reset run"? Or differently?
Even 1.3.4 is old. I suggest that you give the latest git version a try. And please use the code in cpu/ppc4xx/sdram.c to init the SDRAM controller. How many SDRAM banks do you use? 1 or 2? If you use two then you need to enable both banks via those config options:
/* * SDRAM configuration (please see cpu/ppc/sdram.[ch]) */ #define CONFIG_SDRAM_BANK0 1 /* init onboard SDRAM bank 0 */ #define CONFIG_SDRAM_BANK1 1 /* init onboard SDRAM bank 1 */ ...
Please see taihu.h or zeus.h as a reference. This should help.
Best regards, Stefan
Hi Stefan
You were right...
Actually that was exactly the problem: I had overloaded the function "initdram(int board)" in my "board.c" to initialize the SDRAM stuff. The solution was to trash my own code and let U-Boot use the routines defined in cpu/ppc4xx/sdram.c. Now it works perfectly.
Thank you very much for your help!
Best regards, Reto
Reto Stalder
Stefan Roese
