[PATCH] fs: Fix SPL build if SPL_FS_LOADER is enabled and FS_LOADER is disabled
When SPL_FS_LOADER is set to y and FS_LOADER is not enabled, the SPL build fails with the following errors:
AR spl/boot/built-in.o LD spl/u-boot-spl arm-none-linux-gnueabihf-ld.bfd: drivers/misc/fs_loader.o: in function `fw_get_filesystem_firmware': /u-boot/drivers/misc/fs_loader.c:162: undefined reference to `fs_set_blk_dev' arm-none-linux-gnueabihf-ld.bfd: /home/frh/tdx/src/u-boot/drivers/misc/ fs_loader.c:185: undefined reference to `fs_read' arm-none-linux-gnueabihf-ld.bfd: drivers/misc/fs_loader.o: in function `select_fs_dev': /u-boot/drivers/misc/fs_loader.c:89: undefined reference to `fs_set_blk_dev_with_part' make[1]: *** [scripts/Makefile.spl:527: spl/u-boot-spl] Error 1 make: *** [Makefile:2055: spl/u-boot-spl] Error 2
Fix it by replacing the FS_LOADER with SPL_FS_LOADER in the Makefile, so the fs.c with the necessary function definitions are compiled.
Fixes: b071a07743d4 ("drivers: misc: Makefile: Enable fs_loader compilation at SPL Level") Suggested-by: Francesco Dolcini francesco.dolcini@toradex.com Signed-off-by: Hiago De Franco hiago.franco@toradex.com --- fs/Makefile | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/fs/Makefile b/fs/Makefile index 7b05c79e0ccf..a3ee0a361d3d 100644 --- a/fs/Makefile +++ b/fs/Makefile @@ -5,7 +5,7 @@ # Copyright (c) 2012, NVIDIA CORPORATION. All rights reserved.
ifdef CONFIG_SPL_BUILD -obj-$(CONFIG_FS_LOADER) += fs.o +obj-$(CONFIG_SPL_FS_LOADER) += fs.o obj-$(CONFIG_SPL_FS_FAT) += fat/ obj-$(CONFIG_SPL_FS_EXT4) += ext4/ obj-$(CONFIG_SPL_FS_CBFS) += cbfs/
Fixes: b071a07743d4 ("drivers: misc: Makefile: Enable fs_loader compilation at SPL Level") Suggested-by: Francesco Dolcini francesco.dolcini@toradex.com Signed-off-by: Hiago De Franco hiago.franco@toradex.com Reviewed-by: Tom Rini trini@konsulko.com
This leads to failure to build on sandbox_noinst_defconfig.
--- a/drivers/block/Kconfig +++ b/drivers/block/Kconfig @@ -110,6 +110,7 @@ config EFI_MEDIA config SPL_BLK_FS bool "Load images from filesystems on block devices" depends on SPL_BLK + select SPL_FS_LOADER help Use generic support to load images from fat/ext filesystems on different types of block devices such as NVMe.
I think "depends on" and sandbox_noinst_defconfig should enable CONFIG_SPL_FS_LOADER too.
Hello Tom,
What do you mean?
The change I proposed fixes the issue you reported with sandbox_noinst_defconfig and I think is the right solution. Are you ok with that or are you proposing to just change sandbox_noinst_defconfig enabling CONFIG_SPL_FS_LOADER explicitly?
Francesco
On Thu, Sep 05, 2024 at 01:44:37AM +0200, Francesco Dolcini wrote:
Hello Tom,
What do you mean?
I'm saying, based on the other options which use SPL_FS_LOADER it should be a depends not select here, and that sandbox_noinst_defconfig should be enabling SPL_FS_LOADER. There's also an argument to be made that SPL_FS_LOADER (and FS_LOADER) should be unprompted options (ie "bool" without the text to explain the option) and selected by all of its users. I'm not immediately sure which is better now.
Francesco Dolcini
Hiago De Franco
